Other Parts Discussed in Thread: TMDSEVM572X
When you generate a pinmux design using the cloud-based pinmux tool for the AM5718, and select Device: AM5718_SR2.0_BETA, currently the tool doesn't produce devicetree file output for the generated files. This also seems to be the case for any device which is in Beta status on the pinmux tool, correct?
Is there any other way to auto-generate device tree output when you generate a pinmux configuration using this utility or is there another utility or means to auto generate a device tree file from the pinmux configuration?
Thanks!
Jeff Andich
