Hello Sir,Actually i have ti kit DM388 i am booted the SD card and inserted in the board and when i started to video streaming it gives error it automatically get turn out from system and gives error
[ 62.473785] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 62.474532] autorun-usecase.sh[112]: Program exit.
following is my boot log can you help me
Thanks & Regard
Vishakha
********************* BOOT LOG ***************************
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 21.424080] cfg80211: World regulatory domain updated:
[ 21.429338] cfg80211: DFS Master region: unset
[ 21.433734] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 21.443563] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.451624] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.459683] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.467744] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 21.477287] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 21.486813] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 21.494956] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.503014] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 22.119482] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 22.517860] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 22.544914] wlcore: loaded
[ 23.156445] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 23.179960] random: nonblocking pool is initialized
[ 23.280387] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 23.296821] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 27.440085] autorun-usecase.sh[112]: SSID: Tejovat_Eprize
[ 27.441893] autorun-usecase.sh[112]: SSID: Inacces
[ 27.443351] autorun-usecase.sh[112]: SSID: JioFi2_ED54B0
[ 27.837825] <1>SysLink version : 2.21.02.10
[ 27.837825] SysLink module created on Date:Feb 13 2017 Time:17:42:37
[ 27.848460] <1>Trace enabled
[ 27.851355] <1>Trace SetFailureReason enabled
[ 27.944256] autorun-usecase.sh[112]: /dev/mem opened.
[ 27.946010] autorun-usecase.sh[112]: Phy Addr : 0x48181560 Data : 0x00000002
[ 27.947440] autorun-usecase.sh[112]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 27.949774] autorun-usecase.sh[112]: Phy Addr : 0x48180508 Data : 0x00000302
[ 27.951532] autorun-usecase.sh[112]: Phy Addr : 0x48180520 Data : 0x00000002
[ 27.953084] autorun-usecase.sh[112]: Phy Addr : 0x48180524 Data : 0x00000002
[ 27.954571] autorun-usecase.sh[112]: Phy Addr : 0x48180528 Data : 0x00000002
[ 27.958382] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.960261] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.961777] autorun-usecase.sh[112]: DDR IOs RX is shutdown
[ 27.963861] autorun-usecase.sh[112]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 28.909252] autorun-usecase.sh[112]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (226) - No such process
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 29.015612] autorun-usecase.sh[112]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 30.036552] autorun-usecase.sh[112]: mkfs.fat 3.0.28 (2015-05-16)
[ 30.038407] autorun-usecase.sh[112]: unable to get drive geometry, using default 255/63
[ 30.041032] autorun-usecase.sh[112]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 30.051033] autorun-usecase.sh[112]: hidden sectors 0x0000;
[ 30.056142] autorun-usecase.sh[112]: logical sector size is 512,
[ 30.058124] autorun-usecase.sh[112]: using 0xf8 media descriptor, with 1024 sectors;
[ 30.060428] autorun-usecase.sh[112]: drive number 0x80;
[ 30.063383] autorun-usecase.sh[112]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 30.065044] autorun-usecase.sh[112]: FAT size is 1 sector, and provides 247 clusters.
[ 30.080954] autorun-usecase.sh[112]: There is 1 reserved sector.
[ 30.085046] autorun-usecase.sh[112]: Root directory contains 512 slots and uses 32 sectors.
[ 30.090164] autorun-usecase.sh[112]: Volume ID is 9c347de7, no volume label.
[ 30.327854] Mass Storage Function, version: 2009/09/11
[ 30.333047] LUN: removable file: (no medium)
[ 30.337681] LUN: removable file: /dev/sbulla
[ 30.341976] Number of LUNs=1
[ 30.373268] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 30.380345] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 30.387456] g_mass_storage gadget: g_mass_storage ready
[ 30.442638] autorun-usecase.sh[112]: Creat queue id:0
[ 30.444742] autorun-usecase.sh[112]: queue id:0
[ 30.448159] autorun-usecase.sh[112]: Creat queue id:32769
[ 30.457199] autorun-usecase.sh[112]: queue id:32769
[ 30.462420] autorun-usecase.sh[112]: Creat queue id:65538
[ 30.464321] autorun-usecase.sh[112]: queue id:65538
[ 30.468232] autorun-usecase.sh[112]: Creat queue id:98307
[ 30.480124] autorun-usecase.sh[112]: queue id:98307
[ 30.482113] autorun-usecase.sh[112]: queue id:32769
[host] Attached to slave procId 1.12]:
[host] Attached to slave procId 0.12]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[112]:
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[112]:
[host] After Ipc_startcallback status [0x00000000]
[ 31.456055] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.457930] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.459352] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.461614] autorun-usecase.sh[112]: [m3vpss ] Received character 's'
[ 31.552652] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.554469] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.560540] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.563748] autorun-usecase.sh[112]: [m3video] Received character 's'
[ 31.566053] autorun-usecase.sh[112]: queue id:65538
[ 31.569485] autorun-usecase.sh[112]: Creat queue id:131076
[ 31.571769] autorun-usecase.sh[112]: queue id:131076
[ 31.573509] autorun-usecase.sh[112]: CPU is TI812x
[ 31.575141] autorun-usecase.sh[112]: vsenable : 0
[ 31.716028] autorun-usecase.sh[112]: Creat queue id:163845
[ 31.720999] autorun-usecase.sh[112]: queue id:163845
[ 31.737756] autorun-usecase.sh[112]: queue id:65538
[ 31.795190] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.797592] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.803982] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.843451] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.845229] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.846595] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.866556] autorun-usecase.sh[112]: ApproDrvInit: 7
[ 31.868860] autorun-usecase.sh[112]: queue id:163845
[ 31.872477] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.876884] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.881704] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.885468] autorun-usecase.sh[112]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.889136] autorun-usecase.sh[112]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.893423] autorun-usecase.sh[112]: [m3video]
[ 31.898102] autorun-usecase.sh[112]: [m3vpss ] notify_attach rtnVal 0
[ 31.900339] autorun-usecase.sh[112]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.902432] autorun-usecase.sh[112]: [m3vpss ] initProxyServer rtnVal 0
[ 31.904105] autorun-usecase.sh[112]: [m3video]
[ 31.905774] autorun-usecase.sh[112]: [m3vpss ]
[ 31.907394] autorun-usecase.sh[112]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 31.908988] autorun-usecase.sh[112]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.910730] autorun-usecase.sh[112]: [m3video] 39: SYSTEM: IPC init in progress !!!
[ 31.912633] autorun-usecase.sh[112]: [m3vpss ]
[ 31.914228] autorun-usecase.sh[112]: [m3video] 39: SYSTEM: Attaching to [HOST] ...
[ 31.915833] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 31.917380] autorun-usecase.sh[112]: [m3vpss ] 68: SYSTEM: IPC init in progress !!!
[ 31.918961] autorun-usecase.sh[112]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 31.920670] autorun-usecase.sh[112]: [m3video] 89: SYSTEM: Attaching to [HOST] ...
[ 31.922373] autorun-usecase.sh[112]: [m3video] 90: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.923960] autorun-usecase.sh[112]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 31.925524] autorun-usecase.sh[112]: [m3video] 90: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.927127] autorun-usecase.sh[112]: [m3vpss ] 119: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.928673] autorun-usecase.sh[112]: [m3vpss ] 119: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.930508] autorun-usecase.sh[112]: [m3video] 140: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.932172] autorun-usecase.sh[112]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.933790] autorun-usecase.sh[112]: [m3video] 169: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 31.935430] autorun-usecase.sh[112]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 31.937062] autorun-usecase.sh[112]: [m3video] 170: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.938642] autorun-usecase.sh[112]: [m3vpss ] 170: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.940394] autorun-usecase.sh[112]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 31.942006] autorun-usecase.sh[112]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 31.943738] autorun-usecase.sh[112]: [m3vpss ] 172: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.945317] autorun-usecase.sh[112]: [m3vpss ] 172: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 31.947003] autorun-usecase.sh[112]: [m3vpss ] 173: SYSTEM: IPC init DONE !!!
[ 31.948577] autorun-usecase.sh[112]: [m3vpss ] 184: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.950307] autorun-usecase.sh[112]: [m3vpss ] 184: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.952041] autorun-usecase.sh[112]: [m3vpss ] 186: SYSTEM : System Common Init Done !!!
[ 31.953868] autorun-usecase.sh[112]: [m3video] 270: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.955503] autorun-usecase.sh[112]: [m3video] 270: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 31.957163] autorun-usecase.sh[112]: [m3video] 270: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 31.958757] autorun-usecase.sh[112]: [m3video] 272: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.960478] autorun-usecase.sh[112]: [m3video] 272: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 31.962084] autorun-usecase.sh[112]: [m3video] 273: SYSTEM: IPC init DONE !!!
[ 31.963824] autorun-usecase.sh[112]: [m3video] 283: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.965425] autorun-usecase.sh[112]: [m3video] 284: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.967085] autorun-usecase.sh[112]: [m3video] 286: SYSTEM : System Common Init Done !!!
[ 31.968685] autorun-usecase.sh[112]: [m3video] 585: SYSTEM : System Video Init in progress !!!
[ 31.970422] autorun-usecase.sh[112]: [m3vpss ] 586: SYSTEM : System VPSS Init in progress !!!
[ 31.972049] autorun-usecase.sh[112]: [m3video] 586: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 31.973757] autorun-usecase.sh[112]: [m3video] 586: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 31.975529] autorun-usecase.sh[112]: [m3video] 587: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 31.977107] autorun-usecase.sh[112]: [m3video] 589: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 32.310858] autorun-usecase.sh[112]: [m3video] 589: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 32.312568] autorun-usecase.sh[112]: [m3video] 590: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 32.314197] autorun-usecase.sh[112]: [m3video] 599: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 32.315958] autorun-usecase.sh[112]: [m3vpss ] === I2C0/2 Clk is active ===
[ 32.317538] autorun-usecase.sh[112]: [m3video] 600: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 32.319123] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 32.320816] autorun-usecase.sh[112]: [m3video] 600: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 32.322483] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 32.324106] autorun-usecase.sh[112]: [m3video] 602: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 32.325817] autorun-usecase.sh[112]: [m3vpss ] 605: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 32.327378] autorun-usecase.sh[112]: [m3video] 603: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 32.328948] autorun-usecase.sh[112]: [m3video] 603: SYSTEM: ListElem Shared Addr = 0xbe9a4800
[ 32.330585] autorun-usecase.sh[112]: [m3vpss ] 605: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 32.332425] autorun-usecase.sh[112]: [m3video] 605: HDVICP: Doing PRCM for IVAHD[0] ...
[ 37.418300] autorun-usecase.sh[112]: [m3video] [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 37.422393] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 37.424237] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 37.428818] autorun-usecase.sh[112]: [m3vpss ] Received character 't'
[ 37.447060] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 37.449270] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 37.453270] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 37.456527] autorun-usecase.sh[112]: [m3video] Received character 't'
[ 37.482865] autorun-usecase.sh[112]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 37.553843] DMA: Module install successful, device major num = 244
[ 37.560253] DRV: Module install successful
[ 37.564381] DRV: Module built on Feb 13 2017 17:52:30
[ 37.626567]
[ 37.626567] soc_is_dm38x
[ 37.695982] HDMI W1 rev 4.0
[ 37.698870] HDMI CEC Spec version 1.2
[ 38.077185] I2C No Ack
[ 38.079687] HDMI failed to read E-EDID
[ 38.440575] autorun-usecase.sh[112]: queue id:0
[host]565994] autorun-usecase.sh[112]:
[host] ORG 0x46c00524: 0case.sh[112]:
[host] NEW 0x46c00524: 2case.sh[112]:
[host]571677] autorun-usecase.sh[112]:
[host] Application Start Completed12]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 38.683788] autorun-usecase.sh[112]: [ 38.716207] DMA: ChannelID allocated:4
[host] 11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 12: SYSTEM: C[ 38.732408] DMA: ChannelID allocated:5
PU [VPSS-M3] syslink proc ID is [1] !!!
[host] 13: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 16: SYSTEM: IPC init DONE !!!:
[host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 17: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 17: SYSTEM: ListElem Shared Addr = 0xb5612580
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 20: SYSTEM: ListElem Shared Addr = 0xb562c200
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 24: SYSTEM: ListElem Shared Addr = 0xb5645e80
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 25: SYSTEM: ListElem Shared Addr = 0xb5665880
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb5685280
[host] 29: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa73bb000,size = 65011712
[ 38.762631] autorun-usecase.sh[112]: ##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f4e000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]807560] autorun-usecase.sh[112]:
[ 38.809662] autorun-usecase.sh[112]: ********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 141: MCFW : CPU Revision [ES1.0] !!!
[host] 141: MCFW : Detected [UNKNOWN] Board !!!
[host] 141: MCFW : Base Board Revision [REV A] !!!
[ 38.842725] autorun-usecase.sh[112]: 605: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 38.844649] autorun-usecase.sh[112]: [m3video] 606: SYSTEM : Initializing Links !!!
[ 38.846347] autorun-usecase.sh[112]: [m3vpss ] 606: SYSTEM: ListElem Shared Addr = 0xbe9be480
[ 38.848011] autorun-usecase.sh[112]: [m3vpss ] 608: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 38.849721] autorun-usecase.sh[112]: [m3video] 606: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 38.851440] autorun-usecase.sh[112]: [m3vpss ] 609: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 38.853224] autorun-usecase.sh[112]: [m3vpss ] 609: SYSTEM: ListElem Shared Addr = 0xbe9c1980
[ 38.854853] autorun-usecase.sh[112]: [m3video] 607: SYSTEM : FREE SPACE : SR0 Heap = 15985792 B (15 MB)
[ 38.856548] autorun-usecase.sh[112]: [m3video] 607: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 38.858210] autorun-usecase.sh[112]: [m3vpss ] 623: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 38.859875] autorun-usecase.sh[112]: [m3vpss ] 623: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 38.861589] autorun-usecase.sh[112]: [m3video] 607: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 38.863541] autorun-usecase.sh[112]: [m3vpss ] 623: SYSTEM: ListElem Shared Addr = 0xbe9c4e80
[ 38.865326] autorun-usecase.sh[112]: [m3vpss ] 626: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 38.867006] autorun-usecase.sh[112]: [m3video] 608: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 38.868693] autorun-usecase.sh[112]: [m3video] 608: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 39.203618] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_init()
[ 39.205328] autorun-usecase.sh[112]: [m3vpss ] 626: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 39.207021] autorun-usecase.sh[112]: [m3vpss ] 627: SYSTEM: ListElem Shared Addr = 0xbe9e4880
[ 39.208754] autorun-usecase.sh[112]: [m3vpss ] 629: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 39.210432] autorun-usecase.sh[112]: [m3vpss ] 630: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 39.212141] autorun-usecase.sh[112]: [m3vpss ] 630: SYSTEM: ListElem Shared Addr = 0xbea04280
[ 39.213793] autorun-usecase.sh[112]: [m3vpss ] 636: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[ 39.215483] autorun-usecase.sh[112]: [m3vpss ] 637: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 39.217106] autorun-usecase.sh[112]: [m3vpss ] 637: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 39.218790] autorun-usecase.sh[112]: [m3vpss ] 639: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 39.220462] autorun-usecase.sh[112]: [m3vpss ] 640: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 39.222171] autorun-usecase.sh[112]: [m3vpss ] 640: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 39.223777] autorun-usecase.sh[112]: [m3vpss ] 642: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 39.225707] autorun-usecase.sh[112]: [m3vpss ] 642: SYSTEM : FVID2 Init in progress !!!
[ 39.227444] autorun-usecase.sh[112]: [m3video] 668: SYSTEM : Initializing Links ... DONE !!!
[ 39.228085] autorun-usecase.sh[112]: [m3video] 668: SYSTEM : System Video Init Done !!!
[ 39.228589] autorun-usecase.sh[112]: [m3vpss ] 712: SYSTEM : FVID2 Init in progress DONE !!!
[ 39.229130] autorun-usecase.sh[112]: [m3vpss ] 712: SYSTEM : Device Init in progress !!!
[ 39.229592] autorun-usecase.sh[112]: [m3vpss ] Iss_init called !!!!!!
[ 39.230181] autorun-usecase.sh[112]: [m3vpss ] CPIS_init DONE !!!!!!
[ 39.230663] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 39.231166] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 39.231636] autorun-usecase.sh[112]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 39.232097] autorun-usecase.sh[112]: [m3vpss ] 906: SYSTEM : Device Init in progress DONE !!!
[ 39.232612] autorun-usecase.sh[112]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 39.233070] autorun-usecase.sh[112]: [m3vpss ] 6015: SYSTEM : System VPSS Init Done !!!
[ 39.233590] autorun-usecase.sh[112]: [m3vpss ] 6016: UTILS: DMA: HW[ 39.484042] DMA: ChannelID allocated:6
I Create for INT62 !!!
[ 39.234043] autorun-usecase.sh[112]: [ 39.491680] DMA: ChannelID allocated:7
[m3vpss ] 6016: SYSTEM : Initializing Links !!!
[ 39.234545] autorun-usecase.sh[112]: [m3vpss ] 6016: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 39.235005] autorun-usecase.sh[112]: [m3vpss ] 6016: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 39.235516] autorun-usecase.sh[112]: [m3vpss ] 6017: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 39.236036] autorun-usecase.sh[112]: [m3vpss ] 6017: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 39.236485] autorun-usecase.sh[112]: [m3vpss ] 6017: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 39.237008] autorun-usecase.sh[112]: [m3vpss ] 6148: SYSTEM : Initializing Links ... DONE !!!
[ 39.237460] autorun-usecase.sh[112]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 39.237973] autorun-u[ 39.576813] DMA: ChannelID allocated:12
secase.sh[112]: [m3vpss ] VPS_DCTRL_INST_0
[ 39.238424] auto[ 39.583182] DMA: ChannelID allocated:13
run-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT [ 39.592505] DMA: ChannelID allocated:14
SYSTEM_DC_VENC_DVO2
[ 39.238915] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 39.239370] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 39.239815] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 39.240365] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 39.590950] autorun-usecase.sh[112]: [m3vpss ] HDCOMPCLK
[ 39.591539] autorun-usecase.sh[112]: [m3vpss ] 7477: CAMERA: Create in progress !!!
[ 39.592227] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 39.592778] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 39.593320] autorun-usecase.sh[112]: [m3vpss ] 7477: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 39.596077] autorun-usecase.sh[112]: [m3vpss ] 7478: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 39.597207] autorun-usecase.sh[112]: [m3vpss
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1223: IPC_BITS_IN : Create in progress !!!
[host] 1223: IPC_BITS_IN : ListMPOpen start !!!
[host] 1223: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1224: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1224: IPC_BITS_IN : ListMPOpen done !!!
[host] 1225: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1225: IPC_BITS_IN : Create Done !!!
[ 39.948037] autorun-usecase.sh[112]: ] Iss_captCreate:1661
[ 39.948697] autorun-usecase.sh[112]: [m3vpss ] 7691: CAMERA: Create Done !!!
[ 39.949205] autorun-usecase.sh[112]: [m3vpss ] 7781: CAMERA: Detect video in progress !!!
[ 39.949743] autorun-usecase.sh[112]: [m3vpss ] 7781: CAMERA: Detect video Done !!!
[ 39.950257] autorun-usecase.sh[112]: [m3video] 7856: IPC_IN_M3 : Create in progress !!!
[ 39.950785] autorun-usecase.sh[112]: [m3vpss ] 7854: DUP : Create Done !!!
[ 39.951243] autorun-usecase.sh[112]: [m3video] 7857: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 39.951684] autorun-usecase.sh[112]: [m3vpss ] 7855: IPC_OUT_M3 : Create in progress !!!
[ 39.952191] autorun-usecase.sh[112]: [m3video] 7857: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 39.952631] autorun-usecase.sh[112]: [m3vpss ] 7856: IPC_OUT_M3 : Create Done !!!
[ 39.953136] autorun-usecase.sh[112]: [m3video] 7860: IPC_IN_M3 : Create Done !!!
[ 39.953607] autorun-usecase.sh[112]: [m3vpss ] DCC server task running
[ 39.954103] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_tskMain()
[ 39.954547] autorun-usecase.sh[112]: [m3video] inChInfo->width = 1920
[ 39.955011] autorun-usecase.sh[112]: [m3video] inChInfo->height = 1080
[ 39.955457] autorun-usecase.sh[112]: [m3video] inChInfo->pitch[0] = 1984
[ 39.956125] autorun-usecase.sh[112]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 39.956624] autorun-usecase.sh[112]: [m3video] [MCTNF] startX = 0
[ 39.957086] autorun-usecase.sh[112]: [m3video] [MCTNF] startY = 0
[ 39.957596] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->width = 1920
[ 39.958114] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->height = 1080
[ 39.958630] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 39.959076] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 39.959596] autorun-usecase.sh[112]: [m3vpss ] 8043: IPC_IN_M3 : Create in progress !!!
[ 39.960091] autorun-usecase.sh[112]: [m3video] 8042: IPC_OUT_M3 : Create in progress !!!
[ 39.960603] autorun-usecase.sh[112]: [m3vpss ] 8044: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 39.961058] autorun-usecase.sh[112]: [m3video] 8043: IPC_OUT_M3 : Create Done !!!
[ 39.961497] autorun-usecase.sh[112]: [m3vpss ] 8044: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 39.962001] autorun-usecase.sh[112]: [m3vpss ] 8045: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 39.962442] autorun-usecase.sh[112]: [m3vpss ] 8047: IPC_IN_M3 : Create Done !!!
[ 39.962947] autorun-usecase.sh[112]: [m3vpss ] 8048: NSF: Create in progress !!!
[ 39.963393] autorun-usecase.sh[112]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 39.963978] autorun-usecase.sh[112]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 39.964471] autorun-usecase.sh[112]: [m3vpss ] 8173: NSF: Create Done !!!
[ 39.965007] autorun-usecase.sh[112]: [m3vpss ] 8173: Mux : Creating... !!!
[ 39.965484] autorun-usecase.sh[112]: [m3vpss ] 8175: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 39.965942] autorun-usecase.sh[112]: [m3vpss ] 8175: Mux : Create Done !!!
[ 39.966476] autorun-usecase.sh[112]: [m3vpss ] 8182: DUP : Create Done !!!
[ 39.966923] autorun-usecase.sh[112]: [m3vpss ] 8189: DUP : Create Done !!!
[ 39.967427] autorun-usecase.sh[112]: [m3vpss ] 8189: Mux : Creating... !!!
[ 39.967877] autorun-usecase.sh[112]: [m3vpss ] 8191: Mux : Create Done !!!
[ 39.968538] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 39.969013] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 39.969527] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 39.969986] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 39.970551] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 39.971014] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 39.971467] autorun-usecase.sh[112]: [m3vpss ] 8201: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 39.972123] autorun-usecase.sh[112]: [m3vpss ] 8204: SWOSD : Create Done !!!
[ 40.306330] autorun-usecase.sh[112]: [m3vpss ] 8277: DUP : Create Done !!!
[ 40.306878] autorun-usecase.sh[112]: [m3vpss ] 8277: SCLR: Create in progress !!!
[ 40.307350] autorun-usecase.sh[112]: [m3vpss ] 8282: SCLR : Loading Up-scaling Co-effs ...
[ 40.307806] autorun-usecase.sh[112]: [m3vpss ] 8282: SCLR : Co-effs Loading ... DONE !!!
[ 40.308271] autorun-usecase.sh[112]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 40.308713] autorun-usecase.sh[112]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 40.309158] autorun-usecase.sh[112]: [m3vpss ] 8283: SCLR: Create Done !!!
[ 40.309840] autorun-usecase.sh[112]: [m3vpss ] 8290: DUP : Create Done !!!
[ 40.310361] autorun-usecase.sh[112]: [m3vpss ] 8228: VA : Create Done !!!
[ 40.310918] autorun-usecase.sh[112]: [m3vpss ] 8245: FD : Alg Create Done !!!
[ 40.311401] autorun-usecase.sh[112]: [m3vpss ] 8245: FD : Create Done !!!
[ 40.311916] autorun-usecase.sh[112]: [m3video] 8322: IPC_IN_M3 : Create in progress !!!
[ 40.312368] autorun-usecase.sh[112]: [m3vpss ] 8253: VA : ALG Init Done !!!
[ 40.312865] autorun-usecase.sh[112]: [m3video] 8322: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 40.313314] autorun-usecase.sh[112]: [m3vpss ] 8320: IPC_OUT_M3 : Create in progress !!!
[ 40.313802] autorun-usecase.sh[112]: [m3video] 8322: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 40.314258] autorun-usecase.sh[112]: [m3vpss ] 8321: IPC_OUT_M3 : Create Done !!!
[ 40.314698] autorun-usecase.sh[112]: [m3video] 8325: IPC_IN_M3 : Create Done !!!
[ 40.315204] autorun-usecase.sh[112]: [m3vpss ] 8321: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
[ 40.315651] autorun-usecase.sh[112]: [m3video] 8325: ENCODE: Create in progress ... !!!
[ 40.316145] autorun-usecase.sh[112]: [m3video] 8452: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 40.316594] autorun-usecase.sh[112]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 40.317096] autorun-usecase.sh[112]: [m3video] 8533: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 40.317725] autorun-usecase.sh[112]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 40.318245] autorun-usecase.sh[112]: [m3video] 8617: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 40.318718] autorun-usecase.sh[112]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 40.319171] autorun-usecase.sh[112]: [m3video] 8618: ENCODE: All CH Create ... DONE !!!
[ 40.319688] autorun-usecase.sh[112]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 40.320263] autorun-usecase.sh[112]: [m3video] 8620: ENCODE: Create ... DONE !!!
[ 40.558304] autorun-usecase.sh[112]: [m3video] 8584: VSTABApproDrvInit: 3
[ 40.570214] autorun-usecase.sh[112]: queue id:163845
[ 40.574617] autorun-usecase.sh[112]: queue id:0
[ 40.575455] autorun-usecase.sh[112]: queue id:32769
[ 42.471880] autorun-usecase.sh[112]: queue id:0
[ 58.443509] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 58.444278] autorun-usecase.sh[112]: Program exit.
