Part Number: 66AK2G02
Other Parts Discussed in Thread: LP2996A
Dear Champs,
I'm reviewing customer's schematic for DDR3 part, and have some questions.
Could you please check below my questions with customer's schematic of DDR3 part?
Although I informed we confirmed working with DDR3L only and we have not verified with DDR3, customer will use DDR3, and I think DDR3 also should work, right?
* When 1 x 16bit DDR3 used, should DQS2,3 be pull-up and down, right?
* When I checked GP EVM and ICE board, RZQ pin was pull-down using 240Ohm, but I found below comments on datasheet and pull-down resister value is different. Could you please let me know what is correct?
In Table4-3 of datasheet,
(1) An external 49.9Ω ±1% resistor must be connected between this pin and VSS
* DDR3_CLKOUT_P0/N0 should be connected to CK pin of DDR3 memory?
* DDR_CLK_P/N should be opened when DDR_PLL was not used?
When DDR_PLL should be implemented?
* Can DDR_RESET be connected to DDR3 memory without pull-down? I found DDR_RESET was pull-down in ICE board schematic.
* Could you please check below my customer's terminator implementation? DDR_REF_0.75V_PW can be used for VDDR_VTT, right?
Thanks and Best Regards,
SI.
