Other Parts Discussed in Thread: TMDSCSK388
I want to solve this error please help me. I am using DM388 CSK kit. and when I was done all process and I got this type of error result in Tera term and also in minicom. I tried program in Windows platform and also on Linux platform. I have connected all cable as per they given in PDF. The PDF provided on 'TMDSCSK388' ti website.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Getty on tty1.
[ 17.479398] autorun-usecase.sh[112]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 17.487583] autorun-usecase.sh[112]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 17.489024] autorun-usecase.sh[112]: : values=115,115
[ 17.500532] autorun-usecase.sh[112]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ OK ] Started Serial Getty on ttyS0.
[ 17.516558] autorun-usecase.sh[112]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 17.533077] autorun-usecase.sh[112]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 17.534515] autorun-usecase.sh[112]: : values=72,72
[ 17.535781] autorun-usecase.sh[112]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ OK ] Reached target Login Prompts.
[ 17.547167] autorun-usecase.sh[112]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 17.586877] autorun-usecase.sh[112]: ; type=BOOLEAN,access=rw------,values=1
[ 17.588272] autorun-usecase.sh[112]: : values=on
[ 17.589722] autorun-usecase.sh[112]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
Starting uim-sysfs.service...
[ 17.601720] autorun-usecase.sh[112]: ; type=BOOLEAN,access=rw------,values=1
[ OK ] Started System Logging Service.
[ OK ] Started Kernel Logging Service.
[ 17.661788] autorun-usecase.sh[112]: : values=on
[ 17.693610] autorun-usecase.sh[112]: Mount mtd6 and mtd7 partitions
[ OK ] Started D-Bus System Message Bus.
[ 17.780872] ubi0: attaching mtd6
[ 17.945748] ubi0: scanning is finished
[ 18.024934] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 18.030986] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 18.037924] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 18.044657] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 18.051667] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 18.057627] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 18.064884] ubi0: max/mean erase counter: 27/14, WL threshold: 4096, image sequence number: 2367567630
[ 18.074248] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 18.083913] ubi0: background thread "ubi_bgt0d" started, PID 142
Starting Network Service...
[ 18.329431] net eth0: initializing cpsw version 1.10 (0)
[ 18.334791] net eth0: initialized cpsw ale version 1.3
[ 18.343307] net eth0: phy found : id is : 0x2000a231
[ 18.348370] libphy: PHY not found
[ 18.351794] net eth0: phy "" not found on slave 1, err -19
[ OK ] Started Network Service.
[ 18.380120] autorun-usecase.sh[112]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126)
[ 18.453832] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.987251] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 150
[ 19.044668] UBIFS (ubi0:0): recovery needed
[ 19.403633] UBIFS (ubi0:0): recovery completed
[ 19.408277] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 19.416238] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.426235] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 19.436387] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 19.442879] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID CCD16CCE-643B-4FE0-8D48-DEAEE5B4A223, small LPT model
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ 20.191574] ubi1: attaching mtd7
[ 20.461462] ubi1: scanning is finished
[ 20.490642] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 20.496963] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 20.503942] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 20.510694] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 20.517701] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 20.523735] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 20.531018] ubi1: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 455573015
[ 20.540122] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 20.553620] ubi1: background thread "ubi_bgt1d" started, PID 161
[ OK ] Started uim-sysfs.service.
[ 20.595785] autorun-usecase.sh[112]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 12)
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
[ 21.147233] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 180
[ 21.176284] UBIFS (ubi1:0): recovery needed
[ 21.196043] UBIFS (ubi1:0): recovery completed
[ 21.200682] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 21.208672] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.218656] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 21.229156] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 21.235809] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9B011D6F-144D-4DAC-8697-9B0E6BA1215C, small LPT model
[ 21.751660] autorun-usecase.sh[112]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 22.338052] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.346000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.613920] cfg80211: World regulatory domain updated:
[ 22.619211] cfg80211: DFS Master region: unset
[ 22.623591] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 22.633419] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.641481] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.649540] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.657598] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 22.667142] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 22.676667] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 22.684811] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.692868] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 23.448286] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 23.847747] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 23.874791] wlcore: loaded
[ 24.474695] random: nonblocking pool is initialized
[ 24.489451] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 24.610240] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 24.626904] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 28.770752] autorun-usecase.sh[112]: SSID: JioFi2_ED54B0
[ 28.772531] autorun-usecase.sh[112]: SSID: Inacces
[ 28.773980] autorun-usecase.sh[112]: SSID: Tejovat_Eprize
[ 29.182065] <1>SysLink version : 2.21.02.10
[ 29.182065] SysLink module created on Date:Feb 13 2017 Time:17:42:37
[ 29.192737] <1>Trace enabled
[ 29.195632] <1>Trace SetFailureReason enabled
[ 29.279900] autorun-usecase.sh[112]: /dev/mem opened.
[ 29.281685] autorun-usecase.sh[112]: Phy Addr : 0x48181560 Data : 0x00000002
[ 29.283106] autorun-usecase.sh[112]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 29.292959] autorun-usecase.sh[112]: Phy Addr : 0x48180508 Data : 0x00000302
[ 29.301754] autorun-usecase.sh[112]: Phy Addr : 0x48180520 Data : 0x00000002
[ 29.303566] autorun-usecase.sh[112]: Phy Addr : 0x48180524 Data : 0x00000002
[ 29.305883] autorun-usecase.sh[112]: Phy Addr : 0x48180528 Data : 0x00000002
[ 29.310408] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.312166] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.313660] autorun-usecase.sh[112]: DDR IOs RX is shutdown
[ 29.315174] autorun-usecase.sh[112]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 30.267122] autorun-usecase.sh[112]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (229) - No such process
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 30.369943] autorun-usecase.sh[112]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 31.402561] autorun-usecase.sh[112]: mkfs.fat 3.0.28 (2015-05-16)
[ 31.404298] autorun-usecase.sh[112]: unable to get drive geometry, using default 255/63
[ 31.405648] autorun-usecase.sh[112]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 31.407088] autorun-usecase.sh[112]: hidden sectors 0x0000;
[ 31.408328] autorun-usecase.sh[112]: logical sector size is 512,
[ 31.409609] autorun-usecase.sh[112]: using 0xf8 media descriptor, with 1024 sectors;
[ 31.420871] autorun-usecase.sh[112]: drive number 0x80;
[ 31.425757] autorun-usecase.sh[112]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 31.428346] autorun-usecase.sh[112]: FAT size is 1 sector, and provides 247 clusters.
[ 31.431318] autorun-usecase.sh[112]: There is 1 reserved sector.
[ 31.433083] autorun-usecase.sh[112]: Root directory contains 512 slots and uses 32 sectors.
[ 31.434796] autorun-usecase.sh[112]: Volume ID is 9c074aae, no volume label.
[ 31.677199] Mass Storage Function, version: 2009/09/11
[ 31.682390] LUN: removable file: (no medium)
[ 31.687058] LUN: removable file: /dev/sbulla
[ 31.691413] Number of LUNs=1
[ 31.721339] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 31.728410] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 31.735492] g_mass_storage gadget: g_mass_storage ready
[ 31.766029] autorun-usecase.sh[112]: Creat queue id:0
[ 31.768099] autorun-usecase.sh[112]: queue id:0
[ 31.771552] autorun-usecase.sh[112]: Creat queue id:32769
[ 31.774938] autorun-usecase.sh[112]: queue id:32769
[ 31.783434] autorun-usecase.sh[112]: Creat queue id:65538
[ 31.785430] autorun-usecase.sh[112]: queue id:65538
[ 31.792627] autorun-usecase.sh[112]: Creat queue id:98307
[ 31.804594] autorun-usecase.sh[112]: queue id:98307
[ 31.810116] autorun-usecase.sh[112]: queue id:32769
[host] Attached to slave procId 1.12]:
[host] Attached to slave procId 0.12]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[112]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[112]:
[host] After Ipc_loadcallback status [0x00000000]
[host] After Ipc_startcallback status [0x00000000]
[ 32.927653] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.929398] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.934999] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.938088] autorun-usecase.sh[112]: [m3vpss ] Received character 's'
[ 33.027510] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.029332] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.037090] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.050588] autorun-usecase.sh[112]: [m3video] Received character 's'
[ 33.052686] autorun-usecase.sh[112]: queue id:65538
[ 33.060134] autorun-usecase.sh[112]: Creat queue id:131076
[ 33.062061] autorun-usecase.sh[112]: queue id:131076
[ 33.070415] autorun-usecase.sh[112]: CPU is TI812x
[ 33.076062] autorun-usecase.sh[112]: vsenable : 0
[ 33.180575] autorun-usecase.sh[112]: Creat queue id:163845
[ 33.184140] autorun-usecase.sh[112]: queue id:163845
[ 33.186083] autorun-usecase.sh[112]: queue id:65538
[ 33.261897] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.263677] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.265078] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.305914] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.308412] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.312350] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.338921] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.340936] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.342502] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.344029] autorun-usecase.sh[112]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.345611] autorun-usecase.sh[112]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.361642] autorun-usecase.sh[112]: [m3video]
[ 33.370166] autorun-usecase.sh[112]: [m3vpss ] notify_attach rtnVal 0
[ 33.373298] autorun-usecase.sh[112]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.377791] autorun-usecase.sh[112]: [m3vpss ] initProxyServer rtnVal 0
[ 33.380848] autorun-usecase.sh[112]: [m3video]
[ 33.382928] autorun-usecase.sh[112]: [m3vpss ]
[ 33.384565] autorun-usecase.sh[112]: [m3video] 35: SYSTEM : System Common Init in progress !!!
[ 33.386153] autorun-usecase.sh[112]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.387652] autorun-usecase.sh[112]: [m3video] 36: SYSTEM: IPC init in progress !!!
[ 33.389111] autorun-usecase.sh[112]: [m3vpss ]
[ 33.390744] autorun-usecase.sh[112]: [m3video] 36: SYSTEM: Attaching to [HOST] ...
[ 33.392279] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 33.393759] autorun-usecase.sh[112]: [m3video] 86: SYSTEM: Attaching to [HOST] ...
[ 33.395213] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 33.396699] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 33.398205] autorun-usecase.sh[112]: [m3video] 98: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.399660] autorun-usecase.sh[112]: [m3video] 98: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.401282] autorun-usecase.sh[112]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
[ 33.402808] autorun-usecase.sh[112]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.404275] autorun-usecase.sh[112]: [m3vpss ] 118: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.405761] autorun-usecase.sh[112]: [m3video] 149: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.407223] autorun-usecase.sh[112]: [m3video] 169: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 33.408742] autorun-usecase.sh[112]: [m3vpss ] 168: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.410605] autorun-usecase.sh[112]: [m3video] 169: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.412238] autorun-usecase.sh[112]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 33.413824] autorun-usecase.sh[112]: [m3vpss ] 169: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.415334] autorun-usecase.sh[112]: [m3vpss ] 169: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 33.416805] autorun-usecase.sh[112]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 33.418283] autorun-usecase.sh[112]: [m3vpss ] 171: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.419808] autorun-usecase.sh[112]: [m3vpss ] 172: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 33.421522] autorun-usecase.sh[112]: [m3vpss ] 172: SYSTEM: IPC init DONE !!!
[ 33.423056] autorun-usecase.sh[112]: [m3vpss ] 183: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.424598] autorun-usecase.sh[112]: [m3vpss ] 183: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.426192] autorun-usecase.sh[112]: [m3vpss ] 185: SYSTEM : System Common Init Done !!!
[ 33.427734] autorun-usecase.sh[112]: [m3video] 269: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.429284] autorun-usecase.sh[112]: [m3video] 269: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 33.431016] autorun-usecase.sh[112]: [m3video] 269: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 33.432909] autorun-usecase.sh[112]: [m3video] 271: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.434440] autorun-usecase.sh[112]: [m3video] 271: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 33.435955] autorun-usecase.sh[112]: [m3video] 272: SYSTEM: IPC init DONE !!!
[ 33.437447] autorun-usecase.sh[112]: [m3video] 282: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.438907] autorun-usecase.sh[112]: [m3video] 283: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.440442] autorun-usecase.sh[112]: [m3video] 285: SYSTEM : System Common Init Done !!!
[ 33.442115] autorun-usecase.sh[112]: [m3video] 584: SYSTEM : System Video Init in progress !!!
[ 33.443623] autorun-usecase.sh[112]: [m3video] 585: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 33.445131] autorun-usecase.sh[112]: [m3vpss ] 585: SYSTEM : System VPSS Init in progress !!!
[ 33.446613] autorun-usecase.sh[112]: [m3video] 585: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 33.448165] autorun-usecase.sh[112]: [m3video] 586: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 33.449632] autorun-usecase.sh[112]: [m3video] 588: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 33.451490] autorun-usecase.sh[112]: [m3video] 588: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 33.784108] autorun-usecase.sh[112]: [m3video] 589: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 33.785760] autorun-usecase.sh[112]: [m3video] 598: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 33.787295] autorun-usecase.sh[112]: [m3vpss ] === I2C0/2 Clk is active ===
[ 33.788843] autorun-usecase.sh[112]: [m3video] 599: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 33.790398] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 33.791909] autorun-usecase.sh[112]: [m3video] 599: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 33.793503] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 33.795166] autorun-usecase.sh[112]: [m3video] 601: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 33.796720] autorun-usecase.sh[112]: [m3vpss ] 604: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 33.798363] autorun-usecase.sh[112]: [m3video] 602: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 33.800067] autorun-usecase.sh[112]: [m3vpss ] 605: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 33.801629] autorun-usecase.sh[112]: [m3video] 602: SYSTEM: ListElem Shared Addr = 0xbe9a4800
[ 33.803333] autorun-usecase.sh[112]: [m3vpss ] 605: SYSTEM: ListElem Shared Addr = 0xbe9be480
[ 36.296373] autorun-usecase.sh[112]: [m3viApproDrvInit: 7
[ 36.298201] autorun-usecase.sh[112]: queue id:163845
[ 38.884654] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.886474] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.887884] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.889204] autorun-usecase.sh[112]: [m3vpss ] Received character 't'
[ 38.912041] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.913774] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.915219] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.916520] autorun-usecase.sh[112]: [m3video] Received character 't'
[ 38.945336] autorun-usecase.sh[112]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 39.019382] DMA: Module install successful, device major num = 244
[ 39.025736] DRV: Module install successful
[ 39.029907] DRV: Module built on Feb 13 2017 17:52:30
[ 39.099662]
[ 39.099662] soc_is_dm38x
[ 39.167046] HDMI W1 rev 4.0
[ 39.169943] HDMI CEC Spec version 1.2
[ 39.547119] I2C No Ack
[ 39.549721] HDMI failed to read E-EDID
[ 39.759906] autorun-usecase.sh[112]: queue id:0
[host]034347] autorun-usecase.sh[112]:
[host] ORG 0x46c00524: 0case.sh[112]:
[host] NEW 0x46c00524: 2case.sh[112]:
[host]041560] autorun-usecase.sh[112]:
[host] Application Start Completed12]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 40.154265] autorun-usecase.sh[112]: [ 40.186518] DMA: ChannelID allocated:4
[host] 13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 13: SYSTEM: C[ 40.203046] DMA: ChannelID allocated:5
PU [VPSS-M3] syslink proc ID is [1] !!!
[host] 13: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 16: SYSTEM: IPC init DONE !!!:
[host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 18: SYSTEM: ListElem Shared Addr = 0xb55de580
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 20: SYSTEM: ListElem Shared Addr = 0xb55f8200
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 23: SYSTEM: ListElem Shared Addr = 0xb5611e80
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 24: SYSTEM: ListElem Shared Addr = 0xb5631880
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb5651280
[host] 29: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa7387000,size = 65011712
[ 40.232991] autorun-usecase.sh[112]: ##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f1a000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]276837] autorun-usecase.sh[112]:
[ 40.279126] autorun-usecase.sh[112]: ********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 140: MCFW : CPU Revision [ES1.0] !!!
[host] 140: MCFW : Detected [UNKNOWN] Board !!!
[host] 140: MCFW : Base Board Revision [REV A] !!!
[ 40.313306] autorun-usecase.sh[112]: deo] 604: HDVICP: Doing PRCM for IVAHD[0] ...
[ 40.315190] autorun-usecase.sh[112]: [m3video] 604: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 40.316873] autorun-usecase.sh[112]: [m3video] 605: SYSTEM : Initializing Links !!!
[ 40.318553] autorun-usecase.sh[112]: [m3video] 605: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 40.321230] autorun-usecase.sh[112]: [m3vpss ] 608: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 40.323029] autorun-usecase.sh[112]: [m3vpss ] 608: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 40.324771] autorun-usecase.sh[112]: [m3video] 606: SYSTEM : FREE SPACE : SR0 Heap = 15985792 B (15 MB)
[ 40.326515] autorun-usecase.sh[112]: [m3vpss ] 608: SYSTEM: ListElem Shared Addr = 0xbe9c1980
[ 40.328147] autorun-usecase.sh[112]: [m3video] 606: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 40.329834] autorun-usecase.sh[112]: [m3vpss ] 622: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 40.331570] autorun-usecase.sh[112]: [m3vpss ] 622: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 40.333278] autorun-usecase.sh[112]: [m3video] 606: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.335116] autorun-usecase.sh[112]: [m3vpss ] 623: SYSTEM: ListElem Shared Addr = 0xbe9c4e80
[ 40.336874] autorun-usecase.sh[112]: [m3vpss ] 625: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 40.338572] autorun-usecase.sh[112]: [m3video] 606: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.340320] autorun-usecase.sh[112]: [m3vpss ] 625: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 40.674186] autorun-usecase.sh[112]: [m3video] 607: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.675926] autorun-usecase.sh[112]: [m3vpss ] 626: SYSTEM: ListElem Shared Addr = 0xbe9e4880
[ 40.677741] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_init()
[ 40.679767] autorun-usecase.sh[112]: [m3vpss ] 628: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 40.681547] autorun-usecase.sh[112]: [m3vpss ] 629: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 40.683234] autorun-usecase.sh[112]: [m3vpss ] 629: SYSTEM: ListElem Shared Addr = 0xbea04280
[ 40.684941] autorun-usecase.sh[112]: [m3vpss ] 635: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[ 40.686630] autorun-usecase.sh[112]: [m3vpss ] 636: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 40.688299] autorun-usecase.sh[112]: [m3vpss ] 636: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 40.690275] autorun-usecase.sh[112]: [m3vpss ] 638: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 40.692051] autorun-usecase.sh[112]: [m3vpss ] 639: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 40.693718] autorun-usecase.sh[112]: [m3vpss ] 639: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 40.695399] autorun-usecase.sh[112]: [m3vpss ] 641: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 40.697327] autorun-usecase.sh[112]: [m3vpss ] 641: SYSTEM : FVID2 Init in progress !!!
[ 40.699021] autorun-usecase.sh[112]: [m3video] 667: SYSTEM : Initializing Links ... DONE !!!
[ 40.699663] autorun-usecase.sh[112]: [m3video] 667: SYSTEM : System Video Init Done !!!
[ 40.700372] autorun-usecase.sh[112]: [m3vpss ] 711: SYSTEM : FVID2 Init in progress DONE !!!
[ 40.701029] autorun-usecase.sh[112]: [m3vpss ] 711: SYSTEM : Device Init in progress !!!
[ 40.701575] autorun-usecase.sh[112]: [m3vpss ] Iss_init called !!!!!!
[ 40.702060] autorun-usecase.sh[112]: [m3vpss ] CPIS_init DONE !!!!!!
[ 40.702520] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 40.703041] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 40.703499] autorun-usecase.sh[112]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 40.704023] autorun-usecase.sh[112]: [m3vpss ] 905: SYSTEM : Device Init in progress DONE !!!
[ 40.704477] autorun-usecase.sh[112]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 40.704979] autorun-usecase.sh[112]: [ 40.941377] DMA: ChannelID allocated:6
[m3vpss ] 6014: SYSTEM : System VPSS Init Done !!!
[ 40.70[ 40.950881] DMA: ChannelID allocated:7
5432] autorun-usecase.sh[112]: [m3vpss ] 6014: UTILS: DMA: HWI Create for INT62 !!!
[ 40.705878] autorun-usecase.sh[112]: [m3vpss ] 6015: SYSTEM : Initializing Links !!!
[ 40.706477] autorun-usecase.sh[112]: [m3vpss ] 6015: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 40.706940] autorun-usecase.sh[112]: [m3vpss ] 6015: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.707467] autorun-usecase.sh[112]: [m3vpss ] 6015: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 40.707921] autorun-usecase.sh[112]: [m3vpss ] 6016: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.708436] autorun-usecase.sh[112]: [m3vpss ] 6016: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.708896] autorun-usecase.sh[112]: [m3vpss ] 6146: SYSTEM : Initializing Links ... DONE !![ 41.035075] DMA: ChannelID allocated:12
[ 40.709398] autorun-usecase.sh[112]: [m3vpss ] tiedVencs [ 41.042327] DMA: ChannelID allocated:13
VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 40.709849] autorun-us[ 41.051769] DMA: ChannelID allocated:14
ecase.sh[112]: [m3vpss ] VPS_DCTRL_INST_0
[ 40.710395] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 40.710868] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 40.711321] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 40.711868] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 40.712328] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.066900] autorun-usecase.sh[112]: [m3vpss ] HDCOMPCLK
[ 41.067494] autorun-usecase.sh[112]: [m3vpss ] 7479: CAMERA: Create in progress !!!
[ 41.068013] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 41.068487] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 41.068936] autorun-usecase.sh[112]: [m3vpss ] 7479: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 41.071384] autorun-usecase.sh[112]: [m3vpss ] 7480: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 41.072542] autorun-usecase.sh[112]: [m3vpss
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1212: IPC_BITS_IN : Create in progress !!!
[host] 1212: IPC_BITS_IN : ListMPOpen start !!!
[host] 1212: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1213: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1213: IPC_BITS_IN : ListMPOpen done !!!
[host] 1214: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1214: IPC_BITS_IN : Create Done !!!
[ 41.407422] autorun-usecase.sh[112]: ] Iss_captCreate:1661
[ 41.408051] autorun-usecase.sh[112]: [m3vpss ] 7689: CAMERA: Create Done !!!
[ 41.408610] autorun-usecase.sh[112]: [m3vpss ] 7778: CAMERA: Detect video in progress !!!
[ 41.409098] autorun-usecase.sh[112]: [m3vpss ] 7778: CAMERA: Detect video Done !!!
[ 41.409560] autorun-usecase.sh[112]: [m3vpss ] 7850: DUP : Create Done !!!
[ 41.410118] autorun-usecase.sh[112]: [m3vpss ] 7850: IPC_OUT_M3 : Create in progress !!!
[ 41.410593] autorun-usecase.sh[112]: [m3vpss ] 7852: IPC_OUT_M3 : Create Done !!!
[ 41.411117] autorun-usecase.sh[112]: [m3video] 7852: IPC_IN_M3 : Create in progress !!!
[ 41.411570] autorun-usecase.sh[112]: [m3vpss ] DCC server task running
[ 41.412086] autorun-usecase.sh[112]: [m3video] 7853: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 41.412537] autorun-usecase.sh[112]: [m3video] 7853: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 41.413038] autorun-usecase.sh[112]: [m3video] 7856: IPC_IN_M3 : Create Done !!!
[ 41.413480] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_tskMain()
[ 41.413953] autorun-usecase.sh[112]: [m3video] inChInfo->width = 1920
[ 41.414448] autorun-usecase.sh[112]: [m3video] inChInfo->height = 1080
[ 41.414886] autorun-usecase.sh[112]: [m3video] inChInfo->pitch[0] = 1984
[ 41.415574] autorun-usecase.sh[112]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 .
[ 41.416048] autorun-usecase.sh[112]: [m3video] [MCTNF] startX = 0
[ 41.416731] autorun-usecase.sh[112]: [m3video] [MCTNF] startY = 0
[ 41.417347] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->width = 1920
[ 41.417845] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->height = 1080
[ 41.418299] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 41.418822] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 41.419310] autorun-usecase.sh[112]: [m3video] 8033: IPC_OUT_M3 : Create in progress !!!
[ 41.419843] autorun-usecase.sh[112]: [m3video] 8035: IPC_OUT_M3 : Create Done !!!
[ 41.420371] autorun-usecase.sh[112]: [m3vpss ] 8035: IPC_IN_M3 : Create in progress !!!
[ 41.420892] autorun-usecase.sh[112]: [m3vpss ] 8035: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 41.421352] autorun-usecase.sh[112]: [m3vpss ] 8036: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 41.421845] autorun-usecase.sh[112]: [m3vpss ] 8037: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 41.422298] autorun-usecase.sh[112]: [m3vpss ] 8039: IPC_IN_M3 : Create Done !!!
[ 41.422736] autorun-usecase.sh[112]: [m3vpss ] 8040: NSF: Create in progress !!!
[ 41.423394] autorun-usecase.sh[112]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 41.423875] autorun-usecase.sh[112]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 41.424408] autorun-usecase.sh[112]: [m3vpss ] 8162: NSF: Create Done !!!
[ 41.424894] autorun-usecase.sh[112]: [m3vpss ] 8163: Mux : Creating... !!!
[ 41.425422] autorun-usecase.sh[112]: [m3vpss ] 8164: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not!
[ 41.425879] autorun-usecase.sh[112]: [m3vpss ] 8165: Mux : Create Done !!!
[ 41.426370] autorun-usecase.sh[112]: [m3vpss ] 8172: DUP : Create Done !!!
[ 41.426813] autorun-usecase.sh[112]: [m3vpss ] 8178: DUP : Create Done !!!
[ 41.427246] autorun-usecase.sh[112]: [m3vpss ] 8179: Mux : Creating... !!!
[ 41.427812] autorun-usecase.sh[112]: [m3vpss ] 8181: Mux : Create Done !!!
[ 41.428340] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 41.428891] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 41.429346] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 41.429857] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 41.430363] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 41.430902] autorun-usecase.sh[112]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 41.431529] autorun-usecase.sh[112]: [m3vpss ] 8190: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 41.432094] autorun-usecase.sh[112]: [m3vpss ] 8195: SWOSD : Create Done !!!
[ 41.766502] autorun-usecase.sh[112]: [m3vpss ] 8267: DUP : Create Done !!!
[ 41.766970] autorun-usecase.sh[112]: [m3vpss ] 8268: SCLR: Create in progress !!!
[ 41.767346] autorun-usecase.sh[112]: [m3vpss ] 8273: SCLR : Loading Up-scaling Co-effs ...
[ 41.767684] autorun-usecase.sh[112]: [m3vpss ] 8273: SCLR : Co-effs Loading ... DONE !!!
[ 41.768020] autorun-usecase.sh[112]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 41.768352] autorun-usecase.sh[112]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 41.769290] autorun-usecase.sh[112]: [m3vpss ] 8273: SCLR: Create Done !!!
[ 41.769832] autorun-usecase.sh[112]: [m3vpss ] 8280:+-----------------------------+
[ 41.770501] autorun-usecase.sh[112]: [m3vpss ] 8219:| |
[ 41.770986] autorun-usecase.sh[112]: [m3vpss ] 8237:| Cannot open /dev/ttyUSB0! |
[ 41.771550] autorun-usecase.sh[112]: [m3vpss ] 8237:| |
[ 41.772009] autorun-usecase.sh[112]: [m3vpss ] 8245:+-----------------------------+
[ 41.772529] autorun-usecase.sh[112]: [m3video] 8313: IPC_IN_M3 : Create in progress !!!
[ 41.772983] autorun-usecase.sh[112]: [m3vpss ] 8311: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR :!
[ 41.773489] autorun-usecase.sh[112]: [m3video] 8313: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 41.773939] autorun-usecase.sh[112]: [m3vpss ] 8311: IPC_OUT_M3 : Create in progress !!!
[ 41.774378] autorun-usecase.sh[112]: [m3video] 8314: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 41.774879] autorun-usecase.sh[112]: [m3vpss ] 8313: IPC_OUT_M3 : Create Done !!!
[ 41.775316] autorun-usecase.sh[112]: [m3video] 8317: IPC_IN_M3 : Create Done !!!
[ 41.775825] autorun-usecase.sh[112]: [m3video] 8317: ENCODE: Create in progress ... !!!
[ 41.776271] autorun-usecase.sh[112]: [m3video] 8443: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ].
[ 41.776872] autorun-usecase.sh[112]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 41.777406] autorun-usecase.sh[112]: [m3video] 8524: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bi.
[ 41.777925] autorun-usecase.sh[112]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 41.778388] autorun-usecase.sh[112]: [m3video] 8608: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ].
[ 41.778843] autorun-usecase.sh[112]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 41.779355] autorun-usecase.sh[112]: [m3video] 8609: ENCODE: All CH Create ... DONE !!!
[ 41.779799] autorun-usecase.sh[112]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 41.780495] autorun-usecase.sh[112]: [m3video] 8612: ENCODE: Create ... DONE !!!
[ 43.334379] autorun-usecase.sh[112]: [m3video] 8578: VSTABApproDrvInit: 3
[ 43.346424] autorun-usecase.sh[112]: queue id:163845
[ 43.351842] autorun-usecase.sh[112]: queue id:0
[ 43.352745] autorun-usecase.sh[112]: queue id:32769
[ 45.240430] autorun-usecase.sh[112]: queue id:0
[ 59.762913] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 59.763700] autorun-usecase.sh[112]: Program exit.
[ 65.242461] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 65.243210] autorun-usecase.sh[112]: Program exit.
[ 122.337938] cpsw 4a100000.ethernet eth0: Link is Down
Q. why we get a time out occure?
Q. when WLAN0 is off and Ethernet is ON then Why not they provide live streamming through LAN?
