Part Number: DRA622C-Q1
I face problem with proper Ethernet connection. PHY I use has RMII connection to J5Eco. Connection is established but rather unstable with lots of errors.
It seems to be same problem as described for Sitara - https://e2e.ti.com/support/arm/sitara_arm/f/791/p/262854/921662
Question - is it possible to disable internal J5Eco clock? Solution for Sitara described in http://www.ti.com/lit/er/sprz360i/sprz360i.pdf
Additionally as I read in DRA62x reference manual it shall be possible using RMIIx_IO_CLK_EN bits in GMII_SEL (again perhaps same as for Sitara) but there is no information on RMIIx_IO_CLK_EN in GMII_SEL register description. Setting bits 6 and 7 do not help, it seems these are read only.
