Part Number: AM5728
Other Parts Discussed in Thread: BEAGLEBOARD-X15, , PMP, DRA752, TMP102
Tool/software: Linux
hi,all
booting linux failed! sdk version is 'ti-processor-sdk-linux-am57xx-evm-03.02.00.05-Linux-x86-Install.bin';
reboot on following message:
[ OK ] Started Journal Service.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
Starting Create Static Device Nodes in /dev...
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 6.357771] systemd-journald[152]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ 6.882806] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ OK ] Started Create Volatile Files and Directories.
[ 6.941013] remoteproc0: 58820000.ipu is available
[ 6.945919] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 6.963319] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 7.011627] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 7.023056] remoteproc1: 55020000.ipu is available
[ 7.031022] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 7.044937] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started udev Coldplug all Devices.
[ 7.082056] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 7.096331] remoteproc2: 40800000.dsp is available
[ 7.101844] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ OK ] Found device /dev/ttyS2.
[ 7.122317] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Reached target System Initialization.[ 7.153085] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 7.172827] remoteproc3: 41000000.dsp is available
reboot and reboot again until power down.
anyone coule help me to solve the problem?
Thanks.
