TDA2EVM5777: Ground plane estimation
Part Number: TDA2EVM5777
I am trying to run the stand alone application of ground plane estimation module which is in the following path "C:\VISION_SDK_02_12_00_00\ti_components\algorithms_codecs\REL.200.V.SFM.C66X.00.01.00.00\200.V.SFM.C66X.00.01\modules\ti_ground_plane_estimation\test" .
I would like to know how to generate "InObjectFile.bin","out_camera_data_proj.yml" files.
and under the reference folder their is no sample output ,if possible please provide it
Swati
  • Hi
    Not sure why you are not able to find those in <INSTALL DIR>\ti_components\algorithms_codecs\REL.200.V.SFM.C66X.00.01.00.00\200.V.SFM.C66X.00.01\modules\ti_ground_plane_estimation\test\testvecs\input\
    Attached "InObjectFile.bin" and "out_camera_data_proj.yml" files that I see on my installation in that folder.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/out_5F00_camera_5F00_data_5F00_proj.yml
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/InObjectFile.bin
    Alex
  • Hi, Swati,
    The SDK experts are notified and they will comment directly in the thread.
    Mariya
    I have already seen "InObjectFile.bin" and "out_camera_data_proj.yml" files in the" C:\VISION_SDK_02_12_00_00\ti_components\algorithms_codecs\REL.200.V.SFM.C66X.00.01.00.00\200.V.SFM.C66X.00.01\modules\ti_ground_plane_estimation\test\testvecs\input" path.
    Can you please let me know how to generate "InObjectFile.bin" and "out_camera_data_proj.yml" files.
    Swati
  • These files are holding information as mentioned below
    1. InObjectFile.bin"  - Ground plane parameters
    2. out_camera_data_proj.yml" - Pose information of the camera
    Pose information of camera can be obtained by IMU sensor/steering and typically all car can supply this information through CAN bus.
    Ground plane parameters can also be obtained by any external algorithm. I will check if I can share the details of some algorithm.
    with Regards,
    Pramod
