hello sir,
when i run the board with prepare sd card it gives me " TimeOut from Boot_proc error"
this is my log file
can you help me to solve this problem i try all possible ways but issue was not resolved even i tried from manual too but it will not work can you please help me..!
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
[ 20.778119] autorun-usecase.sh[114]: wifi: in STA mode
ti81xx login: [ 20.918148] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 20.927081] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.617702] cfg80211: World regulatory domain updated:
[ 21.622895] cfg80211: DFS Master region: unset
[ 21.627355] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 21.637181] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.645224] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.653286] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.661347] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 21.670891] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 21.680439] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 21.688581] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.696622] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 22.448738] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 22.847825] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 22.874935] wlcore: loaded
[ 23.473412] random: nonblocking pool is initialized
[ 23.489608] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 23.610309] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 23.626943] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 27.870413] autorun-usecase.sh[114]: SSID: Tejovat_Eprize
[ 27.872211] autorun-usecase.sh[114]: SSID: Inacces
[ 27.873627] autorun-usecase.sh[114]: SSID: NETGEAR83
[ 27.874942] autorun-usecase.sh[114]: SSID: JioFi2_ED54B0
[ 27.876264] autorun-usecase.sh[114]: SSID: NETGEAR83-5G
[ 28.279678] <1>SysLink version : 2.21.02.10
[ 28.279678] SysLink module created on Date:Feb 13 2017 Time:17:42:37
[ 28.290334] <1>Trace enabled
[ 28.293230] <1>Trace SetFailureReason enabled
[ 28.384820] autorun-usecase.sh[114]: /dev/mem opened.
[ 28.386549] autorun-usecase.sh[114]: Phy Addr : 0x48181560 Data : 0x00000002
[ 28.387940] autorun-usecase.sh[114]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 28.389258] autorun-usecase.sh[114]: Phy Addr : 0x48180508 Data : 0x00000302
[ 28.404064] autorun-usecase.sh[114]: Phy Addr : 0x48180520 Data : 0x00000002
[ 28.405818] autorun-usecase.sh[114]: Phy Addr : 0x48180524 Data : 0x00000002
[ 28.409713] autorun-usecase.sh[114]: Phy Addr : 0x48180528 Data : 0x00000002
[ 28.411515] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 28.413001] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 28.414512] autorun-usecase.sh[114]: DDR IOs RX is shutdown
[ 28.415893] autorun-usecase.sh[114]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 29.350571] autorun-usecase.sh[114]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (233) - No such process
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 29.459712] autorun-usecase.sh[114]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 30.481069] autorun-usecase.sh[114]: mkfs.fat 3.0.28 (2015-05-16)
[ 30.482916] autorun-usecase.sh[114]: unable to get drive geometry, using default 255/63
[ 30.484451] autorun-usecase.sh[114]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 30.485720] autorun-usecase.sh[114]: hidden sectors 0x0000;
[ 30.486948] autorun-usecase.sh[114]: logical sector size is 512,
[ 30.488194] autorun-usecase.sh[114]: using 0xf8 media descriptor, with 1024 sectors;
[ 30.489409] autorun-usecase.sh[114]: drive number 0x80;
[ 30.500570] autorun-usecase.sh[114]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 30.505466] autorun-usecase.sh[114]: FAT size is 1 sector, and provides 247 clusters.
[ 30.507462] autorun-usecase.sh[114]: There is 1 reserved sector.
[ 30.509653] autorun-usecase.sh[114]: Root directory contains 512 slots and uses 32 sectors.
[ 30.512659] autorun-usecase.sh[114]: Volume ID is 9c0ce5b5, no volume label.
[ 30.757495] Mass Storage Function, version: 2009/09/11
[ 30.762686] LUN: removable file: (no medium)
[ 30.767394] LUN: removable file: /dev/sbulla
[ 30.771693] Number of LUNs=1
[ 30.806288] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 30.813362] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 30.820473] g_mass_storage gadget: g_mass_storage ready
[ 30.875206] autorun-usecase.sh[114]: Creat queue id:0
[ 30.877284] autorun-usecase.sh[114]: queue id:0
[ 30.879848] autorun-usecase.sh[114]: Creat queue id:32769
[ 30.882554] autorun-usecase.sh[114]: queue id:32769
[ 30.893489] autorun-usecase.sh[114]: Creat queue id:65538
[ 30.895285] autorun-usecase.sh[114]: queue id:65538
[ 30.897918] autorun-usecase.sh[114]: Creat queue id:98307
[ 30.920389] autorun-usecase.sh[114]: queue id:98307
[ 30.930142] autorun-usecase.sh[114]: queue id:32769
[host] Attached to slave procId 0.14]:
[host] Attached to slave procId 1.14]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[114]:
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[114]:
[host] After Ipc_startcallback status [0x00000000]
[ 34.930334] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.932094] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.933476] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.934761] autorun-usecase.sh[114]: [m3vpss ] Received character 's'
[ 35.028567] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 35.030787] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 35.038021] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 35.060245] autorun-usecase.sh[114]: [m3video] Received character 's'
[ 35.070143] autorun-usecase.sh[114]: queue id:65538
[ 35.072244] autorun-usecase.sh[114]: Creat queue id:131076
[ 35.073831] autorun-usecase.sh[114]: queue id:131076
[ 35.075346] autorun-usecase.sh[114]: CPU is TI812x
[ 35.076801] autorun-usecase.sh[114]: vsenable : 0
[ 35.225992] autorun-usecase.sh[114]: Creat queue id:163845
[ 35.228179] autorun-usecase.sh[114]: queue id:163845
[ 35.231331] autorun-usecase.sh[114]: queue id:65538
[ 35.293813] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 35.295661] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 35.297066] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 35.371267] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 35.373065] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 35.374493] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 35.375817] autorun-usecase.sh[114]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 35.398177] autorun-usecase.sh[114]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 35.402014] autorun-usecase.sh[114]: [m3video]
[ 35.404988] autorun-usecase.sh[114]: [m3vpss ] notify_attach rtnVal 0
[ 35.406834] autorun-usecase.sh[114]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 35.408394] autorun-usecase.sh[114]: [m3video]
[ 35.409868] autorun-usecase.sh[114]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 35.411480] autorun-usecase.sh[114]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 35.413118] autorun-usecase.sh[114]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 35.414573] autorun-usecase.sh[114]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 35.416003] autorun-usecase.sh[114]: [m3vpss ] initProxyServer rtnVal 0
[ 35.417418] autorun-usecase.sh[114]: [m3vpss ]
[ 35.418882] autorun-usecase.sh[114]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 35.420378] autorun-usecase.sh[114]: [m3vpss ]
[ 35.421914] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 35.423614] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 35.425145] autorun-usecase.sh[114]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 35.426581] autorun-usecase.sh[114]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 35.428054] autorun-usecase.sh[114]: [m3video] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 35.429536] autorun-usecase.sh[114]: [m3video] 119: SYSTEM: Attaching to [VPSS-M3] ...
[ 35.431084] autorun-usecase.sh[114]: [m3vpss ] 136: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 35.432772] autorun-usecase.sh[114]: [m3vpss ] 136: SYSTEM: Attaching to [VIDEO-M3] ...
[ 35.434295] autorun-usecase.sh[114]: [m3video] 168: SYSTEM: Attaching to [VPSS-M3] ...
[ 35.435806] autorun-usecase.sh[114]: [m3video] 186: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 35.437254] autorun-usecase.sh[114]: [m3vpss ] 186: SYSTEM: Attaching to [VIDEO-M3] ...
[ 35.438660] autorun-usecase.sh[114]: [m3video] 186: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.440157] autorun-usecase.sh[114]: [m3vpss ] 186: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 35.441606] autorun-usecase.sh[114]: [m3vpss ] 186: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.443289] autorun-usecase.sh[114]: [m3vpss ] 187: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 35.444726] autorun-usecase.sh[114]: [m3vpss ] 187: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 35.446192] autorun-usecase.sh[114]: [m3vpss ] 189: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 35.447643] autorun-usecase.sh[114]: [m3vpss ] 189: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 35.449073] autorun-usecase.sh[114]: [m3vpss ] 190: SYSTEM: IPC init DONE !!!
[ 35.450567] autorun-usecase.sh[114]: [m3vpss ] 200: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 35.452059] autorun-usecase.sh[114]: [m3vpss ] 201: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 35.453919] autorun-usecase.sh[114]: [m3vpss ] 203: SYSTEM : System Common Init Done !!!
[ 35.455391] autorun-usecase.sh[114]: [m3video] 287: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.456844] autorun-usecase.sh[114]: [m3video] 287: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 35.458278] autorun-usecase.sh[114]: [m3video] 288: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 35.459746] autorun-usecase.sh[114]: [m3video] 290: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 35.461295] autorun-usecase.sh[114]: [m3video] 290: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 35.462788] autorun-usecase.sh[114]: [m3video] 290: SYSTEM: IPC init DONE !!!
[ 35.464387] autorun-usecase.sh[114]: [m3video] 301: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 35.465848] autorun-usecase.sh[114]: [m3video] 301: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 35.467256] autorun-usecase.sh[114]: [m3video] 303: SYSTEM : System Common Init Done !!!
[ 35.468717] autorun-usecase.sh[114]: [m3vpss ] 603: SYSTEM : System VPSS Init in progress !!!
[ 35.470206] autorun-usecase.sh[114]: [m3vpss ] === I2C0/2 Clk is active ===
[ 35.471664] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 35.473179] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 35.474767] autorun-usecase.sh[114]: [m3vpss ] 622: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 35.476235] autorun-usecase.sh[114]: [m3vpss ] 622: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 35.477669] autorun-usecase.sh[114]: [m3vpss ] 622: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 35.810856] autorun-usecase.sh[114]: [m3vpss ] 625: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 35.812626] autorun-usecase.sh[114]: [m3vpss ] 625: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 35.814136] autorun-usecase.sh[114]: [m3vpss ] 625: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 35.815650] autorun-usecase.sh[114]: [m3vpss ] 638: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 35.817218] autorun-usecase.sh[114]: [m3vpss ] 639: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 35.818703] autorun-usecase.sh[114]: [m3vpss ] 639: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 35.820248] autorun-usecase.sh[114]: [m3vpss ] 642: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 35.821740] autorun-usecase.sh[114]: [m3vpss ] 642: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 35.823186] autorun-usecase.sh[114]: [m3vpss ] 642: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 35.824614] autorun-usecase.sh[114]: [m3vpss ] 645: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 35.826118] autorun-usecase.sh[114]: [m3vpss ] 645: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 35.827580] autorun-usecase.sh[114]: [m3vpss ] 645: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 35.829236] autorun-usecase.sh[114]: [m3vpss ] 651: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 35.830939] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 35.832506] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.780636] autorun-usecase.sh[114]: ApproDrvInit: 7
[ 36.782442] autorun-usecase.sh[114]: queue id:163845
[ 39.780938] autorun-usecase.sh[114]: queue id:0
[ 40.892224] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 40.893936] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 40.895324] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 40.896644] autorun-usecase.sh[114]: [m3vpss ] Received character 't'
[ 40.920191] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 40.922314] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 40.926310] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 40.929584] autorun-usecase.sh[114]: [m3video] Received character 't'
[ 40.956204] autorun-usecase.sh[114]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 41.023596] DMA: Module install successful, device major num = 244
[ 41.029997] DRV: Module install successful
[ 41.034134] DRV: Module built on Feb 13 2017 17:52:30
[ 41.098491]
[ 41.098491] soc_is_dm38x
[ 41.168719] HDMI W1 rev 4.0
[ 41.171574] HDMI CEC Spec version 1.2
[ 41.547153] I2C No Ack
[ 41.549656] HDMI failed to read E-EDID
[ 41.880348] autorun-usecase.sh[114]: ApproDrvInit: 3
[ 41.894035] autorun-usecase.sh[114]: queue id:163845
[host]034733] autorun-usecase.sh[114]:
[host] ORG 0x46c00524: 0case.sh[114]:
[host] NEW 0x46c00524: 2case.sh[114]:
[host]042026] autorun-usecase.sh[114]:
[host] Application Start Completed14]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 10: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 42.195092] DMA: ChannelID allocated:4nk proc ID is [0] !!!
[host] 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[ 42.172377] autorun-[ 42.209621] DMA: ChannelID allocated:5
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 13: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 15: SYSTEM: IPC init DONE !!!:
[host] 16: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 16: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 17: SYSTEM: ListElem Shared Addr = 0xb56a4580
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 18: SYSTEM: ListElem Shared Addr = 0xb56be200
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 22: SYSTEM: ListElem Shared Addr = 0xb56d7e80
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 23: SYSTEM: ListElem Shared Addr = 0xb56f7880
[host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 33: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 34: SYSTEM: ListElem Shared Addr = 0xb5717280
[host] 36: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa744d000,size = 65011712
[ 42.256328] autorun-usecase.sh[114]: ##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 42.262235] autorun-usecase.sh[114]: queue id:0
[ 42.263925] autorun-usecase.sh[114]: queue id:32769
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6fe0000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]299549] autorun-usecase.sh[114]:
[ 42.301902] autorun-usecase.sh[114]: ********** SMART ANALYTICS USECASE ********
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 160: MCFW : CPU Revision [ES1.0] !!!
[host] 161: MCFW : Detected [UNKNOWN] Board !!!
[host] 161: MCFW : Base Board Revision [REV A] !!!
[ 42.331548] autorun-usecase.sh[114]: 0 ...
[ 42.333327] autorun-usecase.sh[114]: [m3vpss ] 652: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 42.335138] autorun-usecase.sh[114]: [m3vpss ] 652: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 42.336797] autorun-usecase.sh[114]: [m3vpss ] 655: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 42.338695] autorun-usecase.sh[114]: [m3vpss ] 655: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 42.340441] autorun-usecase.sh[114]: [m3vpss ] 655: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 42.342151] autorun-usecase.sh[114]: [m3vpss ] 657: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 42.343826] autorun-usecase.sh[114]: [m3vpss ] 658: SYSTEM : FVID2 Init in progress !!!
[ 42.345430] autorun-usecase.sh[114]: [m3video] 703: SYSTEM : System Video Init in progress !!!
[ 42.347028] autorun-usecase.sh[114]: [m3video] 704: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 42.348659] autorun-usecase.sh[114]: [m3video] 704: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 42.350361] autorun-usecase.sh[114]: [m3video] 704: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 42.352076] autorun-usecase.sh[114]: [m3video] 707: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 42.353751] autorun-usecase.sh[114]: [m3video] 707: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 42.355593] autorun-usecase.sh[114]: [m3video] 707: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 42.357361] autorun-usecase.sh[114]: [m3video] 717: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 42.358997] autorun-usecase.sh[114]: [m3video] 717: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 42.360734] autorun-usecase.sh[114]: [m3video] 718: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 42.692947] autorun-usecase.sh[114]: [m3video] 720: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 42.694682] autorun-usecase.sh[114]: [m3video] 720: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 42.696348] autorun-usecase.sh[114]: [m3video] 721: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 42.698021] autorun-usecase.sh[114]: [m3video] 723: HDVICP: Doing PRCM for IVAHD[0] ...
[ 42.699626] autorun-usecase.sh[114]: [m3video] 723: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 42.701317] autorun-usecase.sh[114]: [m3video] 724: SYSTEM : Initializing Links !!!
[ 42.702965] autorun-usecase.sh[114]: [m3video] 724: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 42.704638] autorun-usecase.sh[114]: [m3vpss ] 729: SYSTEM : FVID2 Init in progress DONE !!!
[ 42.705173] autorun-usecase.sh[114]: [m3vpss ] 729: SYSTEM : Device Init in progress !!!
[ 42.705718] autorun-usecase.sh[114]: [m3video] 724: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 42.706184] autorun-usecase.sh[114]: [m3vpss ] Iss_init called !!!!!!
[ 42.706701] autorun-usecase.sh[114]: [m3vpss ] CPIS_init DONE !!!!!!
[ 42.707150] autorun-usecase.sh[114]: [m3video] 725: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 42.707638] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 42.708301] autorun-usecase.sh[114]: [m3video] 725: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 42.708899] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 42.709373] autorun-usecase.sh[114]: [m3video] 725: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 42.709890] autorun-usecase.sh[114]: [m3video] 726: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 42.710419] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_init()
[ 42.710942] autorun-usecase.sh[114]: [m3video] 785: SYSTEM : Initializing Links ... DONE !!!
[ 42.711403] autorun-usecase.sh[114]: [m3video] 785: SYSTEM : System Video Init Done !!!
[ 42.711892] autorun-usecase.sh[114]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 42.712344] autorun-usecase.sh[114]: [m3vpss ] 923: SYSTEM : Device Init in progress DONE !!!
[ 42.712788] autorun-usecase.sh[114]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 42.713293] autorun-usecase.sh[114]: [m3vpss ] 6032: SYSTEM : System VPSS Init Done !!!
[ 42.713769] autorun-usecase.sh[114]: [m3vpss ] 6033: UTILS: DMA: HWI Create for INT62 !!!
[ 42.714264] aut[ 42.975753] DMA: ChannelID allocated:6
orun-usecase.sh[114]: [m3vpss ] 6033: SYSTEM : Initializing L[ 42.980831] DMA: ChannelID allocated:7
inks !!!
[ 42.714769] autorun-usecase.sh[114]: [m3vpss ] 6033: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 42.715255] autorun-usecase.sh[114]: [m3vpss ] 6033: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 42.715704] autorun-usecase.sh[114]: [m3vpss ] 6034: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 42.716144] autorun-usecase.sh[114]: [m3vpss ] 6034: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 42.716655] autorun-usecase.sh[114]: [m3vpss ] 6034: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 42.717094] autorun-usecase.sh[114]: [m3vpss ] 6165: SYSTEM : Initializing Links ... DONE !!!
[ 42.717582] autorun-usecase.sh[114]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 42.718014] autorun-usecase.sh[114]: [m3vpss ] VPS_DCTRL_INST_[ 43.066120] DMA: ChannelID allocated:12
0
[ 42.718485] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_[ 43.072273] DMA: ChannelID allocated:13
DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 42.718921] autoru[ 43.081955] DMA: ChannelID allocated:14
n-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 42.719387] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 42.719888] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 42.720386] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 43.074928] autorun-usecase.sh[114]: [m3vpss ] HDCOMPCLK
[ 43.075527] autorun-usecase.sh[114]: [m3vpss ] 7516: CAMERA: Create in progress !!!
[ 43.076251] autorun-usecase.sh[114]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 43.076780] autorun-usecase.sh[114]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 43.077250] autorun-usecase.sh[114]: [m3vpss ] 7516: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 43.079549] autorun-usecase.sh[114]: [m3vpss ] 7517: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 43.080937] autorun-usecase.sh[114]: [m3vp
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1240: IPC_BITS_IN : Create in progress !!!
[host] 1240: IPC_BITS_IN : ListMPOpen start !!!
[host] 1240: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1241: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1241: IPC_BITS_IN : ListMPOpen done !!!
[host] 1242: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1242: IPC_BITS_IN : Create Done !!!
[ 43.437343] autorun-usecase.sh[114]: ss ] Iss_captCreate:1661
[ 43.437948] autorun-usecase.sh[114]: [m3vpss ] 7730: CAMERA: Create Done !!!
[ 43.438563] autorun-usecase.sh[114]: [m3vpss ] 7820: CAMERA: Detect video in progress !!!
[ 43.439036] autorun-usecase.sh[114]: [m3vpss ] 7820: CAMERA: Detect video Done !!!
[ 43.439561] autorun-usecase.sh[114]: [m3vpss ] 7893: DUP : Create Done !!!
[ 43.440051] autorun-usecase.sh[114]: [m3vpss ] 7893: IPC_OUT_M3 : Create in progress !!!
[ 43.440584] autorun-usecase.sh[114]: [m3vpss ] 7895: IPC_OUT_M3 : Create Done !!!
[ 43.441040] autorun-usecase.sh[114]: [m3video] 7895: IPC_IN_M3 : Create in progress !!!
[ 43.441530] autorun-usecase.sh[114]: [m3vpss ] DCC server task running
[ 43.441971] autorun-usecase.sh[114]: [m3video] 7896: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 43.442404] autorun-usecase.sh[114]: [m3video] 7896: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 43.442899] autorun-usecase.sh[114]: [m3video] 7899: IPC_IN_M3 : Create Done !!!
[ 43.443328] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_tskMain()
[ 43.443829] autorun-usecase.sh[114]: [m3video] inChInfo->width = 1920
[ 43.444292] autorun-usecase.sh[114]: [m3video] inChInfo->height = 1080
[ 43.444765] autorun-usecase.sh[114]: [m3video] inChInfo->pitch[0] = 1984
[ 43.445206] autorun-usecase.sh[114]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 43.445875] autorun-usecase.sh[114]: [m3video] [MCTNF] startX = 0
[ 43.446343] autorun-usecase.sh[114]: [m3vpss ] 8082: IPC_IN_M3 : Create in progress !!!
[ 43.446790] autorun-usecase.sh[114]: [m3video] [MCTNF] startY = 0
[ 43.447359] autorun-usecase.sh[114]: [m3vpss ] 8082: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 43.447807] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->width = 1920
[ 43.448312] autorun-usecase.sh[114]: [m3vpss ] 8083: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 43.448752] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->height = 1080
[ 43.449235] autorun-usecase.sh[114]: [m3vpss ] 8084: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 43.449702] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 43.450218] autorun-usecase.sh[114]: [m3vpss ] 8086: IPC_IN_M3 : Create Done !!!
[ 43.450680] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 43.451119] autorun-usecase.sh[114]: [m3vpss ] 8087: NSF: Create in progress !!!
[ 43.451627] autorun-usecase.sh[114]: [m3video] 8080: IPC_OUT_M3 : Create in progress !!!
[ 43.452062] autorun-usecase.sh[114]: [m3video] 8082: IPC_OUT_M3 : Create Done !!!
[ 43.452543] autorun-usecase.sh[114]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 43.452978] autorun-usecase.sh[114]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 43.453580] autorun-usecase.sh[114]: [m3vpss ] 8211: NSF: Create Done !!!
[ 43.454068] autorun-usecase.sh[114]: [m3vpss ] 8212: Mux : Creating... !!!
[ 43.454527] autorun-usecase.sh[114]: [m3vpss ] 8213: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 43.455046] autorun-usecase.sh[114]: [m3vpss ] 8214: Mux : Create Done !!!
[ 43.455520] autorun-usecase.sh[114]: [m3vpss ] 8221: DUP : Create Done !!!
[ 43.456030] autorun-usecase.sh[114]: [m3vpss ] 8227: DUP : Create Done !!!
[ 43.456469] autorun-usecase.sh[114]: [m3vpss ] 8228: Mux : Creating... !!!
[ 43.456936] autorun-usecase.sh[114]: [m3vpss ] 8230: Mux : Create Done !!!
[ 43.457546] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 43.458055] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 43.458511] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 43.458950] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 43.459459] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 43.459894] autorun-usecase.sh[114]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 43.460432] autorun-usecase.sh[114]: [m3vpss ] 8240: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 43.791586] autorun-usecase.sh[114]: [m3vpss ] 8240: SWOSD : Create Done !!!
[ 43.792463] autorun-usecase.sh[114]: [m3vpss ] 8313: DUP : Create Done !!!
[ 43.793106] autorun-usecase.sh[114]: [m3vpss ] 8313: SCLR: Create in progress !!!
[ 43.793773] autorun-usecase.sh[114]: [m3vpss ] 8319: SCLR : Loading Up-scaling Co-effs ...
[ 43.795531] autorun-usecase.sh[114]: [m3vpss ] 8319: SCLR : Co-effs Loading ... DONE !!!
[ 43.796367] autorun-usecase.sh[114]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 43.797772] autorun-usecase.sh[114]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 43.798609] autorun-usecase.sh[114]: [m3vpss ] 8319: SCLR: Create Done !!!
[ 43.799535] autorun-usecase.sh[114]: [m3vpss ] 8326: DUP : Create Done !!!
[ 43.800342] autorun-usecase.sh[114]: [m3vpss ] 8264: VA : Create Done !!!
[ 43.800942] autorun-usecase.sh[114]: [m3vpss ] 8281: FD : Alg Create Done !!!
[ 43.801564] autorun-usecase.sh[114]: [m3vpss ] 8282: FD : Create Done !!!
[ 43.802204] autorun-usecase.sh[114]: [m3video] 8358: IPC_IN_M3 : Create in progress !!!
[ 43.802772] autorun-usecase.sh[114]: [m3vpss ] 8290: VA : ALG Init Done !!!
[ 43.803367] autorun-usecase.sh[114]: [m3video] 8358: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 43.803929] autorun-usecase.sh[114]: [m3vpss ] 8356: Assertion @ Line: 2242 in links_common/va/vaLink_alg.c: libStatus == DMVAL_NO_ERROR : failed !!!
[ 43.804541] autorun-usecase.sh[114]: [m3video] 8359: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 43.805101] autorun-usecase.sh[114]: [m3vpss ] 8356: IPC_OUT_M3 : Create in progress !!!
[ 43.805756] autorun-usecase.sh[114]: [m3video] 8362: IPC_IN_M3 : Create Done !!!
[ 43.806321] autorun-usecase.sh[114]: [m3vpss ] 8357: IPC_OUT_M3 : Create Done !!!
[ 43.806948] autorun-usecase.sh[114]: [m3video] 8362: ENCODE: Create in progress ... !!!
[ 43.807755] autorun-usecase.sh[114]: [m3video] 8488: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 43.808360] autorun-usecase.sh[114]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 43.808992] autorun-usecase.sh[114]: [m3video] 8569: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 43.809567] autorun-usecase.sh[114]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 43.810284] autorun-usecase.sh[114]: [m3video] 8653: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1984, 1984) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 43.810858] autorun-usecase.sh[114]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 43.811468] autorun-usecase.sh[114]: [m3video] 8654: ENCODE: All CH Create ... DONE !!!
[ 43.812096] autorun-usecase.sh[114]: [m3video] ENCLINK:HEAPID:0 USED:28144
[ 43.812885] autorun-usecase.sh[114]: [m3video] 8657: ENCODE: Create ... DONE !!!
[ 43.813684] autorun-usecase.sh[114]: [m3video] 8621: VSTqueue id:0
[ 59.784055] autorun-usecase.sh[114]: TimeOut occure in boot_proc.
[ 59.784793] autorun-usecase.sh[114]: Program exit.
[ 63.799414] autorun-usecase.sh[114]: TimeOut occure in boot_proc.
[ 63.800196] autorun-usecase.sh[114]: Program exit.
