Part Number: PROCESSOR-SDK-AM57X
Hi Team,
I have a question from the customer below, I have sent the attached file to Ron, but he recommended i post on the forums. Can you please review their inquiry and let me know if you have any questions?
Thanks for the help!
_____
"I've made some headway in evaluating the AM57x hardware offload. I've gotten a test OpenCV/CL application running and I'm getting some strange results. I used the instructions found here to assert OpenCL was working correctly, and ran my benchmark. I'm seeing that hardware offload is slower in every case my contrived benchmark runs (see attached logs).
My tests included 160x120, 320x240, and 1920x1080 frames at uint8, uint16 and float32 bit depth run both with and without hardware offload. The attached logs were captured while the CPU was underclocked to 1.0GHz. I'm currently running the same tests on 1.2 and 1.5GHz and will have those results in a day or so.
I'm running all my tests on a Phytec phyCORE-AM57x. Phytec uses the latest release of Project Arago in their RDK. I'm fairly certain my DSP slowdown is not caused by my hardware, though I'd love to be proved wrong.
Can you help me understand these results? Are there certain filters I should always use the CPU for? What benchmarks did TI run to get these results? Can I get access to those benchmarking tools to verify the claims on TI's website? Is there anything else I can provide to help find the root cause of this slowdown?"
