Linux/PROCESSOR-SDK-AM335X: Debian flashing issue
Part Number: PROCESSOR-SDK-AM335X
Tool/software: Linux
CCCC
U-Boot SPL 2016.03 (May 17 2017 - 17:44:11)
Trying to boot from UART
CCCC - CRC mode, 2743(SOH)/0(STX)/0(CAN) packets, 6 retries
Loaded 350832 bytes
U-Boot 2016.03 (May 17 2017 - 17:44:11 +0530)
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
board_init
Reset Source: Global warm SW reset has occurred.
Reset Source: Power-on reset has occurred.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
board_late_init
Net:   cpsw, usb_ether
Hit any key to stop autoboot:  5  4  3  2  1  0
Unknown command 'console=ttyO0,115200n8' - try 'help'
Unknown command '' - try 'help'
=> setenv ipaddr 192.168.10.10
=> setenv serverip 192.168.10.11
=> setenv netmask 255.255.255.0
=> saveenv
Saving Environment to MMC...
Writing to MMC(1)... done
=> saveenv       setenv netmask 255.255.255.0                            taddr}'"
=> run NFS_BOOT;
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.10.11; our IP address is 192.168.10.10
Filename 'vmlinuz-4.4.6-ti-rt-r14'.
Load address: 0x80007fc0
Loading: *#################################################################
	 3.1 MiB/s
done
Bytes transferred = 7159936 (6d4080 hex)
Using cpsw device
Filename 'am335x-boneblack.dtb'.
Load address: 0x80f80000
	 2.9 MiB/s
done
Bytes transferred = 61582 (f08e hex)
Kernel image @ 0x80007fc0 [ 0x000000 - 0x6d4080 ]
## Flattened Device Tree blob at 80f80000
   Booting using the fdt blob at 0x80f80000
   Loading Device Tree to 8ffed000, end 8ffff08d ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.6 (root@Genx3) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT RT Wed May 17 17:53:00 IST 2017
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: TI AM335x BeagleBone Black
[    0.000000] cma: Reserved 24 MiB at 0x9e000000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon )
[    0.000000] PERCPU: Embedded 14 pages/cpu @df90c000 s25664 r8192 d23488 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129408
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=192.168.10.11:/opt/BPL/nfs_rootfs ip=192.168.10.10:::::eth0 rootfstype=ext4 rootwait fixrtc
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 479536K/522240K available (6793K kernel code, 851K rwdata, 3204K rodata, 536K init, 939K bss, 18128K reserved, 24576K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09cb7cc   (9998 kB)
[    0.000000]       .init : 0xc09cc000 - 0xc0a52000   ( 536 kB)
[    0.000000]       .data : 0xc0a52000 - 0xc0b26e24   ( 852 kB)
[    0.000000]        .bss : 0xc0b29000 - 0xc0c13f20   ( 940 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000022] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000030] OMAP clocksource: timer1 at 24000000 Hz
[    0.000218] Console: colour dummy device 80x30
[    0.000387] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000390] This ensures that you still see kernel messages. Please
[    0.000393] update your kernel commandline.
[    0.046840] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.046859] pid_max: default: 32768 minimum: 301
[    0.046996] Security Framework initialized
[    0.047004] Yama: becoming mindful.
[    0.047035] AppArmor: AppArmor disabled by boot time parameter
[    0.047198] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.047205] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.048093] Initializing cgroup subsys io
[    0.048114] Initializing cgroup subsys memory
[    0.048151] Initializing cgroup subsys devices
[    0.048165] Initializing cgroup subsys freezer
[    0.048178] Initializing cgroup subsys net_cls
[    0.048189] Initializing cgroup subsys perf_event
[    0.048200] Initializing cgroup subsys net_prio
[    0.048211] Initializing cgroup subsys pids
[    0.048328] CPU: Testing write buffer coherency: ok
[    0.048337] ftrace: allocating 31297 entries in 62 pages
[    0.133543] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.133725] Setting up static identity map for 0x80008240 - 0x8000828c
[    0.166909] Brought up 1 CPUs
[    0.166933] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.166943] CPU: All CPU(s) started in SVC mode.
[    0.168446] devtmpfs: initialized
[    0.195114] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.221454] omap_hwmod: debugss: _wait_target_disable failed
[    0.275737] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.280663] xor: measuring software checksum speed
[    0.318948]    arm4regs  :  1221.000 MB/sec
[    0.358878]    8regs     :   931.000 MB/sec
[    0.398873]    32regs    :  1174.000 MB/sec
[    0.438872]    neon      :  1690.000 MB/sec
[    0.438883] xor: using function: neon (1690.000 MB/sec)
[    0.438926] pinctrl core: initialized pinctrl subsystem
[    0.441217] NET: Registered protocol family 16
[    0.445995] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.458921] cpuidle: using governor ladder
[    0.470922] cpuidle: using governor menu
[    0.477344] OMAP GPIO hardware version 0.1
[    0.492260] No ATAGs?
[    0.492296] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.492700] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.492714] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.599090] raid6: int32x1  gen()   239 MB/s
[    0.666935] raid6: int32x1  xor()   227 MB/s
[    0.734992] raid6: int32x2  gen()   363 MB/s
[    0.802972] raid6: int32x2  xor()   267 MB/s
[    0.870881] raid6: int32x4  gen()   360 MB/s
[    0.938958] raid6: int32x4  xor()   251 MB/s
[    1.007058] raid6: int32x8  gen()   332 MB/s
[    1.074970] raid6: int32x8  xor()   224 MB/s
[    1.142905] raid6: neonx1   gen()  1455 MB/s
[    1.210891] raid6: neonx1   xor()   843 MB/s
[    1.278883] raid6: neonx2   gen()  1773 MB/s
[    1.346887] raid6: neonx2   xor()  1171 MB/s
[    1.414888] raid6: neonx4   gen()  1913 MB/s
[    1.482893] raid6: neonx4   xor()  1185 MB/s
[    1.550916] raid6: neonx8   gen()   876 MB/s
[    1.618887] raid6: neonx8   xor()   794 MB/s
[    1.618898] raid6: using algorithm neonx4 gen() 1913 MB/s
[    1.618907] raid6: .... xor() 1185 MB/s, rmw enabled
[    1.618916] raid6: using intx1 recovery algorithm
[    1.630454] edma 49000000.edma: TI EDMA DMA engine driver
[    1.634841] SCSI subsystem initialized
[    1.639427] usbcore: registered new interface driver usbfs
[    1.639526] usbcore: registered new interface driver hub
[    1.639648] usbcore: registered new device driver usb
[    1.640376] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[    1.640431] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[    1.640592] pps_core: LinuxPPS API ver. 1 registered
[    1.640602] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.640637] PTP clock support registered
[    1.641664] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    1.644078] NetLabel: Initializing
[    1.644095] NetLabel:  domain hash size = 128
[    1.644103] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.644171] NetLabel:  unlabeled traffic allowed by default
[    1.644553] clocksource: Switched to clocksource timer1
[    1.804757] NET: Registered protocol family 2
[    1.805640] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    1.805708] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[    1.805854] TCP: Hash tables configured (established 4096 bind 4096)
[    1.805937] UDP hash table entries: 256 (order: 2, 16384 bytes)
[    1.805974] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[    1.806256] NET: Registered protocol family 1
[    1.810956] RPC: Registered named UNIX socket transport module.
[    1.810975] RPC: Registered udp transport module.
[    1.810983] RPC: Registered tcp transport module.
[    1.810992] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.812028] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.815085] futex hash table entries: 256 (order: 2, 16384 bytes)
[    1.815213] audit: initializing netlink subsys (disabled)
[    1.815286] audit: type=2000 audit(1.748:1): initialized
[    1.829257] zbud: loaded
[    1.829947] VFS: Disk quotas dquot_6.6.0
[    1.830206] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.837014] NFS: Registering the id_resolver key type
[    1.837082] Key type id_resolver registered
[    1.837092] Key type id_legacy registered
[    1.837123] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.837498] fuse init (API version 7.23)
[    1.838074] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.855656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.859956] io scheduler noop registered
[    1.859978] io scheduler deadline registered
[    1.860071] io scheduler cfq registered (default)
[    1.861848] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    1.863899] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    1.865794] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.869741] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[    2.732489] console [ttyS0] enabled
[    2.737190] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 159, base_baud = 3000000) is a 8250
[    2.747044] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 160, base_baud = 3000000) is a 8250
[    2.812587] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    2.818732] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    2.825309] davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[    2.837430] libphy: 4a101000.mdio: probed
[    2.841489] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    2.851449] cpsw 4a100000.ethernet: Detected MACID = b0:d5:cc:99:9a:c9
[    2.860449] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.867102] ehci-platform: EHCI generic platform driver
[    2.872656] ehci-omap: OMAP-EHCI Host Controller driver
[    2.878421] usbcore: registered new interface driver usblp
[    2.884030] usbcore: registered new interface driver usb-storage
[    2.891969] 47401300.usb-phy supply vcc not found, using dummy regulator
[    2.911305] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[    2.917120] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[    2.925262] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.932088] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.939346] usb usb1: Product: MUSB HDRC host driver
[    2.944336] usb usb1: Manufacturer: Linux 4.4.6 musb-hcd
[    2.949674] usb usb1: SerialNumber: musb-hdrc.0.auto
[    2.955696] hub 1-0:1.0: USB hub found
[    2.959519] hub 1-0:1.0: 1 port detected
[    2.973481] 47401b00.usb-phy supply vcc not found, using dummy regulator
[    3.002321] mousedev: PS/2 mouse device common for all mice
[    3.009198] omap_rtc 44e3e000.rtc: already running
[    3.014520] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    3.023055] i2c /dev entries driver
[    3.028346] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    3.036391] omap_hsmmc 48060000.mmc: Got CD GPIO
[    3.074944] omap_hsmmc 48060000.mmc: card busy
[    3.080925] omap_hsmmc 48060000.mmc: card busy
[    3.106159] hidraw: raw HID events driver (C) Jiri Kosina
[    3.112686] usbcore: registered new interface driver usbhid
[    3.116573] omap_hsmmc 481d8000.mmc: card busy
[    3.122766] usbhid: USB HID core driver
[    3.126858] omap_hsmmc 481d8000.mmc: card busy
[    3.131491] ashmem: initialized
[    3.135607]  remoteproc0: wkup_m3 is available
[    3.142980]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    3.154884]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    3.172968] NET: Registered protocol family 10
[    3.174392] mmc1: MAN_BKOPS_EN bit is not set
[    3.177890] mmc1: new high speed MMC card at address 0001
[    3.188499] mmcblk0: mmc1:0001 Q2J54A 3.64 GiB
[    3.197683] mmcblk0boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[    3.201135] mip6: Mobile IPv6
[    3.201156] NET: Registered protocol family 17
[    3.201331] Key type dns_resolver registered
[    3.201341] mpls_gso: MPLS GSO support
[    3.201561] omap_voltage_late_init: Voltage driver support not added
[    3.202427] PM: Cannot get wkup_m3_ipc handle
[    3.202526] ThumbEE CPU extension supported.
[    3.202551] Registering SWP/SWPB emulation handler
[    3.203793] registered taskstats version 1
[    3.203961] zswap: loaded using pool lzo/zbud
[    3.217643] Btrfs loaded
[    3.236861] Key type encrypted registered
[    3.250651] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/input/input0
[    3.274272] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    3.274863] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.275132] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    3.281798] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.282263] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.282727] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.283180] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.283222] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    3.289199]  remoteproc0: powering up wkup_m3
[    3.289216]  remoteproc0: Booting fw image am335x-pm-firmware.elf, size 219735
[    3.289685] cpu: dev_pm_opp_of_cpumask_add_table: couldn't find opp table for cpu:0, -19
[    3.289701] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    3.290104] PM: bootloader does not support rtc-only!
[    3.290638] omap_rtc 44e3e000.rtc: setting system clock to 2016-05-26 08:51:06 UTC (1464252666)
[    3.290653] of_cfs_init
[    3.290806] of_cfs_init: OK
[    3.296946]  remoteproc0: remote processor wkup_m3 is now up
[    3.297000] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[    3.308972] net eth0: initializing cpsw version 1.12 (0)
[    3.311358] net eth0: phy found : id is : 0x7c0f1
[    3.325304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.431082] mmcblk0boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[    7.341190] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    7.348621] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    7.364756] IP-Config: Guessing netmask 255.255.255.0
[    7.370047] IP-Config: Complete:
[    7.373301]      device=eth0, hwaddr=b0:d5:cc:99:9a:c9, ipaddr=192.168.10.10, mask=255.255.255.0, gw=255.255.255.255
[    7.383873]      host=192.168.10.10, domain=, nis-domain=(none)
[    7.389823]      bootserver=255.255.255.255, rootserver=192.168.10.11, rootpath=
[    7.410135] VFS: Mounted root (nfs filesystem) on device 0:16.
[    7.416727] devtmpfs: mounted
[    7.420465] Freeing unused kernel memory: 536K (c09cc000 - c0a52000)
[    7.715251] random: systemd urandom read with 61 bits of entropy available
[    7.741609] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    7.755596] systemd[1]: Detected architecture 'arm'.
Welcome to Debian GNU/Linux 8 (jessie)!
[    7.775227] systemd[1]: Set hostname to <arm>.
[    8.003795] systemd-fstab-generator[112]: Failed to create mount unit file /run/systemd/generator/-.mount, as it already exists. Duplicate entry in /etc/fstab?
[    8.086387] systemd[111]: /lib/systemd/system-generators/systemd-fstab-generator failed with error code 1.
[    8.462169] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    8.470710] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.478486] systemd[1]: Expecting device dev-ttyS0.device...
[    8.492968] systemd[1]: Starting Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems (Pre).
[    8.504893] systemd[1]: Reached target Remote File Systems (Pre).
[    8.511163] systemd[1]: Starting Encrypted Volumes.
[  OK  ] Reached target Encrypted Volumes.
[    8.524891] systemd[1]: Reached target Encrypted Volumes.
[    8.530526] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    8.539060] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    8.547272] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary Executable File Formats F...utomount Point.
[    8.568864] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.578469] systemd[1]: Starting Swap.
[  OK  ] Reached target Swap.
[    8.588881] systemd[1]: Reached target Swap.
[    8.593300] systemd[1]: Starting Root Slice.
[  OK  ] Created slice Root Slice.
[    8.604868] systemd[1]: Created slice Root Slice.
[    8.609727] systemd[1]: Starting User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    8.624904] systemd[1]: Created slice User and Session Slice.
[    8.630813] systemd[1]: Starting Delayed Shutdown Socket.
[  OK  ] Listening on Delayed Shutdown Socket.
[    8.644898] systemd[1]: Listening on Delayed Shutdown Socket.
[    8.650795] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    8.668880] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    8.675994] systemd[1]: Starting Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    8.688891] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.695044] systemd[1]: Starting udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    8.708898] systemd[1]: Listening on udev Control Socket.
[    8.714509] systemd[1]: Starting udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    8.732875] systemd[1]: Listening on udev Kernel Socket.
[    8.738372] systemd[1]: Starting Journal Socket.
[  OK  ] Listening on Journal Socket.
[    8.748881] systemd[1]: Listening on Journal Socket.
[    8.754114] systemd[1]: Starting System Slice.
[  OK  ] Created slice System Slice.
[    8.764925] systemd[1]: Created slice System Slice.
[    8.770770] systemd[1]: Started File System Check on Root Device.
[    8.777088] systemd[1]: Starting system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    8.788961] systemd[1]: Created slice system-getty.slice.
[    8.794537] systemd[1]: Starting system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    8.808920] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.815588] systemd[1]: Starting Increase datagram queue length...
[    8.839479] systemd[1]: Starting Load Kernel Modules...
[    8.943755] random: nonblocking pool is initialized
[    8.955316] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required static device nodes...rrent kernel...
[    9.038502] systemd[1]: Mounted Huge Pages File System.
[    9.100103] systemd[1]: Mounting Debug File System...
[    9.145710] systemd[1]: Mounting POSIX Message Queue File System...
[    9.207641] systemd[1]: Started Set Up Additional Binary Formats.
[    9.227509] systemd[1]: Starting udev Coldplug all Devices...
[    9.294872] systemd[1]: Starting Slices.
[  OK  ] Reached target Slices.
[    9.333627] systemd[1]: Reached target Slices.
[    9.341188] systemd[1]: Starting Remount Root and Kernel File Systems...
[  OK  ] Mounted POSIX Message Queue File System.
[    9.433180] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted Debug File System.
[    9.461184] systemd[1]: Mounted Debug File System.
[  OK  ] Started Increase datagram queue length.
[    9.489174] systemd[1]: Started Increase datagram queue length.
[    9.513152] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[    9.585098] systemd[1]: Failed to start Load Kernel Modules.
[    9.592426] systemd[1]: Unit systemd-modules-load.service entered failed state.
[  OK  ] Started Create list of required static device nodes ...current kernel.
[    9.633151] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    9.678891] systemd[1]: systemd-remount-fs.service: main process exited, code=exited, status=1/FAILURE
[FAILED] Failed to start Remount Root and Kernel File Systems.
See 'systemctl status systemd-remount-fs.service' for details.
[    9.745110] systemd[1]: Failed to start Remount Root and Kernel File Systems.
[    9.760768] systemd[1]: Unit systemd-remount-fs.service entered failed state.
[  OK  ] Started udev Coldplug all Devices.
[    9.921012] systemd[1]: Started udev Coldplug all Devices.
[   10.101214] systemd[1]: Started Various fixups to make systemd work better on Debian.
[   10.109265] systemd[1]: Starting Load/Save Random Seed...
[   10.126598] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.172262] systemd[1]: Starting Apply Kernel Variables...
[   10.218883] systemd[1]: Mounting Configuration File System...
[   10.303293] systemd[1]: Mounting FUSE Control File System...
[   10.380102] systemd[1]: Starting Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[   10.417242] systemd[1]: Listening on Syslog Socket.
[   10.430536] systemd[1]: Starting Journal Service...
[  OK  ] Started Journal Service.
[   10.489852] systemd[1]: Started Journal Service.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Reached target Remote File Systems.
         Starting Trigger Flushing of Journal to Persistent Storage...
[   11.049804] systemd-udevd[217]: starting version 215
         Starting LSB: Raise network interfaces....
[  OK  ] Started udev Kernel Device Manager.
[   11.517200] systemd-journald[208]: Received request to flush runtime journal from PID 1
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
         Starting Copy rules generated while the root was ro...
         Starting LSB: Tune IDE hard disks...
[  OK  ] Started Copy rules generated while the root was ro.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started LSB: Tune IDE hard disks.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Started LSB: Raise network interfaces..
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on CUPS Printing Service Sockets.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Basic System.
         Starting Restore /etc/resolv.conf if the system cras...s shut down....
         Starting Generic Board Startup...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting Regular background program processing daemon...
[  OK  ] Started Regular background program processing daemon.
         Starting Cape Manager Service...
         Starting /etc/rc.local Compatibility...
         Starting LSB: Start busybox udhcpd at boot time...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting LSB: Apache2 web server...
         Starting Login Service...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting System Logging Service...
         Starting Permit User Sessions...
         Starting CUPS Printing Service...
[  OK  ] Started CUPS Printing Service.
         Starting Make remote CUPS printers available locally...
[  OK  ] Started Make remote CUPS printers available locally.
[  OK  ] Started Restore /etc/resolv.conf if the system crash...was shut down..
[  OK  ] Started Cape Manager Service.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started LSB: Start busybox udhcpd at boot time.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started System Logging Service.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[   18.502585] g_multi: unknown parameter '192.168.10.11:/opt/BPL/nfs_rootf1' ignored
[   18.654066] using random self ethernet address
[   18.658670] using random host ethernet address
[   18.687002] using host ethernet address: B0:D5:CC:99:9A:CB
[   18.729868] using self ethernet address: B0:D5:CC:99:9A:C0[   18.849003] Mass Storage Function, version: 2009/09/11
[   18.858348] LUN: removable file: (no medium)
[   18.875775] lun0: unable to open backing file: /dev/nfs
[   18.910434] g_multi musb-hdrc.1.auto: failed to start g_multi: -2
[  OK  ] Started Login Service.
         Starting LSB: set CPUFreq kernel parameters...
         Starting Getty on tty1...
[  OK  ] Started Getty on tty1.
         Starting Serial Getty on ttyS0...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Expecting device dev-ttyGS0.device...
[  OK  ] Started LSB: Apache2 web server.
Debian GNU/Linux 8 arm ttyS0
default username:password is [debian:temppwd]
The IP Address for eth0 is: 192.168.10.10
arm login: root (automatic login)
Last login: Thu May 26 08:44:51 UTC 2016 on ttyS0
Linux arm 4.4.6 #1 SMP PREEMPT RT Wed May 17 17:53:00 IST 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@arm:~# flashFlash.sh
Thu May 26 08:51:57 UTC 2016
/dev/mmcblk0
Flashing uboot................
10+0 records in
10+0 records out
10485760 bytes (10 MB) copied, 0.964735 s, 10.9 MB/s
0+1 records in
0+1 records out
74180 bytes (74 kB) copied, 0.0255975 s, 2.9 MB/s
0+1 records in
0+1 records out
350896 bytes (351 kB) copied, 0.0818751 s, 4.3 MB/s
Flashing FS................
Welcome to fdisk (util-linux 2.25.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x3628886b.
Command (m for help): No partition is defined yet!
Could not delete partition 3069262673
Command (m for help): Partition type
   p   primary (0 primary, 0 extended, 4 free)
   e   extended (container for logical partitions)
Select (default p): Partition number (1-4, default 1): First sector (2048-7634943, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (4096-7634943, default 7634943):
Created a new partitio[   55.743201]  mmcblk0: p1
n 1 of type 'Linux' and of size 3.7 GiB.
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Flashing emmc
mke2fs 1.42.12 (29-Aug-2014)
Discarding device blocks:   4096/953856528384/953856             done
Creating filesystem with 953856 4k blocks and 238560 inodes
Filesystem UUID: ab936900-852d-4347-b393-bbe3a13bc839
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736
Allocating group tables:  0/30     done
Writing inode tables:  0/30     done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information:  0/30     done
Flashing Debian in eMMC................
[   64.390129] loop: module loaded
[   64.592297] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[   64.717401] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Thu May 26 08:56:19 UTC 2016
root@arm:~# reboot
         Starting Synchronise Hardware Clock to System Clock...
[  OK  ] Stopped target System Time Synchronized.
         Stopping User Manager for UID 0...
[  OK  ] Stopped target Multi-User System.
         Stopping Make remote CUPS printers available locally...
         Stopping OpenBSD Secure Shell server...
         Stopping Regular background program processing daemon...
         Stopping LSB: Start busybox udhcpd at boot time...
         Stopping LSB: Advanced IEEE 802.11 management daemon...
         Stopping LSB: set CPUFreq kernel parameters...
         Stopping LSB: Apache2 web server...
[  OK  ] Stopped target Login Prompts.
         Stopping Getty on tty1...
         Stopping Serial Getty on ttyS0...
         Stopping D-Bus System Message Bus...
         Stopping System Logging Service...
[  OK  ] Stopped OpenBSD Secure Shell server.
[  OK  ] Stopped Regular background program processing daemon.
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped Make remote CUPS printers available locally.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped Serial Getty on ttyS0.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped LSB: Start busybox udhcpd at boot time.
[  OK  ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Stopped LSB: set CPUFreq kernel parameters.
[  OK  ] Started Synchronise Hardware Clock to System Clock.
         Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
         Stopping Login Service...
[  OK  ] Removed slice user-0.slice.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Removed slice system-getty.slice.
         Stopping /etc/rc.local Compatibility...
[  OK  ] Stopped /etc/rc.local Compatibility.
         Stopping Permit User Sessions...
         Stopping CUPS Printing Service...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped CUPS Printing Service.
[  OK  ] Stopped LSB: Apache2 web server.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Closed Syslog Socket.
[  OK  ] Closed CUPS Printing Service Sockets.
[  OK  ] Stopped target System Initialization.
         Stopping Network Time Synchronization...
         Stopping Apply Kernel Variables...
[  OK  ] Stopped Apply Kernel Variables.
         Stopping Update UTMP about System Boot/Shutdown...
[  OK  ] Stopped target Encrypted Volumes.
[  OK  ] Stopped target Swap.
[  OK  ] Stopped target Network is Online.
[  OK  ] Stopped target Network.
         Stopping LSB: Raise network interfaces....
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Remote File Systems (Pre).
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Stopped LSB: Raise network interfaces..
         Stopping Load/Save Random Seed...
         Stopping Create Volatile Files and Directories...
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /run/user/0...
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Unmounted /run/user/0.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped target Local File Systems (Pre).
         Stopping Create Static Device Nodes in /dev...
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  706.113302] watchdog watchdog0: watchdog did not stop!
[  706.161682] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  706.202899] systemd-journald[208]: Received SIGTERM from PID 1 (systemd-shutdow).
[  706.226106] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  706.263711] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[  706.273784] systemd-shutdown[1]: Unmounting file systems.
[  706.281352] systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections.
[  706.296887] systemd-shutdown[1]: Unmounting /sys/kernel/config.
[  706.312696] systemd-shutdown[1]: Unmounting /dev/mqueue.
[  706.328686] systemd-shutdown[1]: Unmounting /sys/kernel/debug.
[  706.357522] systemd-shutdown[1]: All filesystems unmounted.
[  706.363242] systemd-shutdown[1]: Deactivating swaps.
[  706.368856] systemd-shutdown[1]: All swaps deactivated.
[  706.374258] systemd-shutdown[1]: Detaching loop devices.
[  706.383233] systemd-shutdown[1]: All loop devices detached.
[  706.389004] systemd-shutdown[1]: Detaching DM devices.
[  706.395528] systemd-shutdown[1]: All DM devices detached.
[  706.405990] systemd-shutdown[1]: Rebooting.
[  706.433084] musb-hdrc musb-hdrc.0.auto: remove, state 4
[  706.438460] usb usb1: USB disconnect, device number 1
[  706.444422] musb-hdrc musb-hdrc.0.auto: USB bus 1 deregistered
[  706.451210] reboot: Restarting system
Trying to boot from MMC
Card did not respond to voltage select!
*** Warning - MMC init failed, using default environment
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
board_init
board_late_init
CCCC
Loaded 350832 bytes
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
board_init
board_late_init
=> saveenv
=> run NFS_BOOT;
Using cpsw device
	 3.1 MiB/s
done
Using cpsw device
	 2.9 MiB/s
done
Starting kernel ...
/dev/mmcblk0
10+0 records in
10+0 records out
0+1 records in
0+1 records out
0+1 records in
0+1 records out
Syncing disks.
Flashing emmc
root@arm:~# reboot
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
board_init
board_late_init
Nitin
