RTOS/TMS320C6678: Some problems on IPC
Part Number: TMS320C6678
Tool/software: TI-RTOS
I got some problems on IPC. I began with a example IPC design, it works well. Then I try to treat Core0 as master core and connected it to the other six cores(Core1 to Core6), it can attach each other. But when I treat Core6 as master core and connected it to Core0 to Core5, the program can't get through. Here is my main function and .cfg file,could you help me to find out what problems?
 * Copyright (c) 2012, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== notify_multicore.c ========
 *  Single-image version of Notify example
 *  See notify_multicore.k file for expected output.
#include <xdc/std.h>
/*  -----------------------------------XDC.RUNTIME module Headers    */
#include <xdc/runtime/System.h>
/*  ----------------------------------- IPC module Headers           */
#include <ti/ipc/MultiProc.h>
#include <ti/ipc/Notify.h>
#include <ti/ipc/Ipc.h>
/*  ----------------------------------- BIOS6 module Headers         */
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/BIOS.h>
/*  ----------------------------------- To get globals from .cfg Header */
#include <xdc/cfg/global.h>
#define INTERRUPT_LINE  0
/* Notify event number that the app uses */
#define EVENTID         10
#define masterProc 6
#define sloverNum  6
UInt16	received_num = 0;
 *  ======== cbFxn ========
 *  This function was registered with Notify. It is called when any event is
 *  sent to this processor.
Void cbFxn(UInt16 procId, UInt16 lineId,
           UInt32 eventId, UArg arg, UInt32 payload)
	if(procId !=masterProc)
		received_num ++;
		if(received_num == sloverNum)
			received_num = 0;
			Semaphore_post(semHandle);
	else{
 *  ======== tsk0_func ========
 *  Sends an event to the next processor then pends on a semaphore.
 *  The semaphore is posted by the callback function.
Void tsk0_func(UArg arg0, UArg arg1)
    Int i = 0;
    Int status;
    if(MultiProc_self() == masterProc){
    	while(i <sloverNum){
    		status = Notify_sendEvent(i,INTERRUPT_LINE,EVENTID,i,TRUE);
    		if(status <0){
    			continue;
    		System_printf("materCore has sent event to slaveCore %d\n",i);
    		i++;
    	System_printf("all event has been sent\n");
    	Semaphore_pend(semHandle,BIOS_WAIT_FOREVER);
    	System_printf("all slave core has received event from master\n");
    else{
    	status = Notify_sendEvent(masterProc,INTERRUPT_LINE, EVENTID, 2,TRUE);
    	if(status < 0){
    		System_abort("sendEvent to MasterCore failed\n");
    	System_printf("slaveCore %d has sent event to master core",MultiProc_self());
 *  ======== main ========
 *  Synchronizes all processors (in Ipc_start), calls BIOS_start, and registers
 *  for an incoming event
Int main(Int argc, Char* argv[])
    Int status;
    Int procId = 0;
    status = Ipc_start();
    if (status < 0) {
        System_abort("Ipc_start failed\n");
    	while(procId < sloverNum)
			while(Ipc_attach(procId)){
				Task_sleep(1);
			status = Notify_registerEvent(procId,INTERRUPT_LINE, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL);
			if (status < 0)
				System_abort("Notify_registerEvent for sloverCore1 failed\n");
			procId++;
    else{
    	while(Ipc_attach(masterProc)){
    		Task_sleep(1);
    	status = Notify_registerEvent(masterProc,INTERRUPT_LINE, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL);
    	if(status <0){
    BIOS_start();
    return (0);
 *  @(#) ti.sdo.ipc.examples.multicore.evm667x; 1, 0, 0, 0,1; 5-22-2012 16:36:06; /db/vtree/library/trees/ipc/ipc-h32/src/ xlibrary
 * are met:
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
 *  Get the list of names that the build device supports.
 *  I.e. ["CORE0", "CORE1", "CORE2" ... ]
var nameList = MultiProc.getDeviceProcNames();
 *  Since this is a single-image example, we don't (at build-time) which
 *  processor we're building for.  We therefore supply 'null'
 *  as the local procName and use MultiProc_setLocalId to set the procId
 *  at runtime.
MultiProc.setConfig(null, nameList);
var System   = xdc.useModule('xdc.runtime.System');
var SysStd   = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Modules explicitly used in the application */
var Notify      = xdc.useModule('ti.sdo.ipc.Notify');
var Ipc         = xdc.useModule('ti.sdo.ipc.Ipc');
var BIOS        = xdc.useModule('ti.sysbios.BIOS');
BIOS.heapSize   = 0x8000;
var Task        = xdc.useModule('ti.sysbios.knl.Task');
var tsk0 = Task.create('&tsk0_func');
tsk0.instance.name = "tsk0";
/* To avoid wasting shared memory for MessageQ transports */
for (var i = 0; i < MultiProc.numProcessors; i++) {
    Ipc.setEntryMeta({
        remoteProcId: i,
        setupMessageQ: false,
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_PAIR;
/* Shared Memory base address and length */
var SHAREDMEM           = 0x0C000000;
var SHAREDMEMSIZE       = 0x00200000;
 *  Need to define the shared region. The IPC modules use this
 *  to make portable pointers. All processors need to add this
 *  call with their base address of the shared memory region.
 *  If the processor cannot access the memory, do not add it.
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.setEntryMeta(0,
    { base: SHAREDMEM,
      len:  SHAREDMEMSIZE,
      ownerProcId: 0,
      isValid: true,
/* Create a semaphore with count 0 */
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
Program.global.semHandle = Semaphore.create(0);
