dm6446 demo build failure -- xdc.PACKAGE_NOT_FOUND
Other Parts Discussed in Thread: OMAP3530
I reinstalled the dm6446 files, and tried a rebuild and I get the following error.  Does anybody else have this issue?  any ideas?
======== Building decode ========
Configuring application using decode.cfg
configuring decode.x470MV from package/cfg/decode_x470MV.cfg ...
Info: Configuring engine named 'decode' from the info file for DSP server './decodeCombo.x64P',
          located in package 'ti.sdo.servers.decode':
      Target app will look for the DSP server image 'decodeCombo.x64P' in its current directory.
      Adding codec 'h264dec' (ti.sdo.codecs.h264dec.ce.H264DEC), scratch groupId=0
      Adding codec 'mpeg2dec' (ti.sdo.codecs.mpeg2dec.ce.MPEG2DEC), scratch groupId=0
      Adding codec 'mpeg4dec' (ti.sdo.codecs.mpeg4dec.ce.MPEG4DEC), scratch groupId=0
      Adding codec 'aachedec' (ti.sdo.codecs.aachedec.ce.AACHEDEC), scratch groupId=1
      Adding codec 'g711dec' (ti.sdo.codecs.g711dec.ce.G711DEC), scratch groupId=1
Info: Reading DSP memory map from the info file for DSP server './decodeCombo.x64P',
js: "/home/dm6446/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages/xdc/xdc.tci", line 299: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: /home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/package.xdc found along the package path, but no schema file was found.  Ensure that the package 'ti.sdo.simplewidget' is completely built.
    "/home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/decode/decode.cfg", line 36
    "./package/cfg/decode_x470MV.cfg", line 479
    "./package/cfg/decode_x470MV.cfg", line 434
gmake: *** [package/cfg/decode_x470MV.c] Error 1
js: "/home/dm6446/dvsdk_2_00_00_22/xdctools_3_10_05_61/packages/xdc/tools/Cmdr.xs", line 40: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
make[2]: *** [decode_config/linker.cmd] Error 1
make[2]: Leaving directory `/home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/decode'
make[1]: *** [decode] Error 2
make[1]: Leaving directory `/home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446'
make: *** [demos] Error 2
dm6446@lola:~/dvsdk_2_00_00_22$
dm6446@lola:~/dvsdk_2_00_00_22$ make check
Checking that components in Rules.make are found:
Done checking! If no warning messages above, all components are found..
dm6446@lola:~/dvsdk_2_00_00_22$ cat Rules.make
# This make variable must be set before the DVSDK components can be built.
PLATFORM=dm6446
ifndef PLATFORM
   $(error PLATFORM must be set in Rules.make to dm355, dm6467 or dm6446 before building)
endif
# The installation directory of the DVSDK
DVSDK_INSTALL_DIR=$(HOME)/dvsdk_2_00_00_22
# For backwards compatibility
DVEVM_INSTALL_DIR=$(DVSDK_INSTALL_DIR)
# Where the DVSDK demos are installed
DEMO_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dvsdk_demos_2_00_00_07
# Where the Digital Video Test Bench is installed
DVTB_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dvtb_4_00_08
# Where the Davinci Multimedia Application Interface is installed
DMAI_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dmai_1_20_00_06
# Where the Codec Engine package is installed.
CE_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/codec_engine_2_23_01
# Where the XDAIS package is installed.
XDAIS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/xdais_6_23
# Where the DSP Link package is installed.
LINK_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dsplink-1_61_03-prebuilt
# Where the CMEM (contiguous memory allocator) package is installed.
CMEM_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/linuxutils_2_23_01
# Where the EDMA3 Low Level Driver is installed.
EDMA3_LLD_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/edma3_lld_1_05_00
ifeq ($(PLATFORM),dm6467)
   CODEC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dm6467_dvsdk_combos_2_05
endif
ifeq ($(PLATFORM),dm6446)
   CODEC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dm6446_dvsdk_combos_2_05
endif
ifeq ($(PLATFORM),dm355)
   CODEC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dm355_codecs_1_13_000
endif
# Where the RTSC tools package is installed.
XDC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/xdctools_3_10_05_61
# Where Framework Components product is installed
FC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/framework_components_2_23_01
# Where DSP/BIOS is installed
BIOS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/bios_5_33_03
# BIOS Utilities
BIOSUTILS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/biosutils_1_01_00
# Additional RTSC package repositories to be picked up by components.
USER_XDC_PATH=$(CE_INSTALL_DIR)/examples
#above works around DMAI path bug
# Where the TI c6x code generation tools are installed
CODEGEN_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/cg6x_6_0_21
# Platform Support Package installation directory.
PSP_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/PSP_02_00_00_140
# The directory that points to your kernel source directory.
LINUXKERNEL_INSTALL_DIR=$(HOME)/workdir/lsp/ti-davinci/linux-2.6.18_pro500
# The prefix to be added before the GNU compiler tools (optionally including
# path), i.e. "arm_v5t_le-" or "/opt/bin/arm_v5t_le-".
MVTOOL_DIR=/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le
MVTOOL_PREFIX=$(MVTOOL_DIR)/bin/arm_v5t_le-
# Where to copy the resulting executables and data to (when executing 'make
# install') in a proper file structure. This EXEC_DIR should either be visible
# from the target, or you will have to copy this (whole) directory onto the
# target filesystem.
EXEC_DIR=$(DVSDK_INSTALL_DIR)/install/$(PLATFORM)
#EXEC_DIR=$(HOME)/workdir/filesys  #!!!
dm6446@lola:~/dvsdk_2_00_00_22$ ls -ls
total 1456
   4 drwxrwxr-x  2 dm6446 dm6446    4096 2009-10-29 10:58 bin
   4 drwxr-xr-x  5 dm6446 dm6446    4096 2009-10-29 11:34 bios_5_33_03
   4 drwxrwxr-x  4 dm6446 dm6446    4096 2009-10-29 10:58 biosutils_1_01_00
   4 drwxrwxr-x  5 dm6446 dm6446    4096 2009-10-29 10:58 ceutils_1_06
   4 drwxr-xr-x  6 dm6446 dm6446    4096 2009-10-29 11:45 cg6x_6_0_21
   4 drwxrwxr-x  7 dm6446 dm6446    4096 2009-10-29 10:58 cg_xml_2_12_00
   4 drwxrwxr-x  3 dm6446 dm6446    4096 2009-10-29 11:50 clips
   4 drwxrwxr-x  8 dm6446 dm6446    4096 2009-10-29 11:03 codec_engine_2_23_01
  28 -rw-r--r--  1 dm6446 dm6446   27811 2009-05-26 18:05 dm355_2_00_00_22_release_notes.html
   4 drwxrwxr-x  6 dm6446 dm6446    4096 2009-10-29 11:04 dm355_codecs_1_13_000
  28 -rw-r--r--  1 dm6446 dm6446   24769 2009-05-26 18:06 dm6446_2_00_00_22_release_notes.html
   4 drwxr-xr-x  3 dm6446 dm6446    4096 2009-10-29 11:48 dm6446_dvsdk_combos_2_05
  24 -rw-r--r--  1 dm6446 dm6446   22931 2009-05-26 18:06 dm6467_2_00_00_22_release_notes.html
   4 drwxrwxr-x  4 dm6446 dm6446    4096 2009-10-29 11:04 dmai_1_20_00_06
   4 drwxrwxr-x  3 dm6446 dm6446    4096 2009-10-29 11:06 docs
   4 drwxrwxr-x  3 dm6446 dm6446    4096 2009-10-29 11:06 dsplink-1_61_03-prebuilt
   4 drwxrwxr-x  7 dm6446 dm6446    4096 2009-10-29 16:13 dvsdk_demos_2_00_00_07
   4 drwxrwxr-x  3 dm6446 dm6446    4096 2009-10-29 11:09 dvtb_4_00_08
   4 drwxrwxr-x  6 dm6446 dm6446    4096 2009-10-29 11:09 edma3_lld_1_05_00
   4 drwxrwxr-x  5 dm6446 dm6446    4096 2009-10-29 11:10 examples
   4 drwxrwxr-x  9 dm6446 dm6446    4096 2009-10-29 11:11 framework_components_2_23_01
   4 drwxr-xr-x  3 dm6446 dm6446    4096 2009-10-29 15:27 install
   4 drwxrwxr-x  5 dm6446 dm6446    4096 2009-10-29 11:11 kernel_binaries
   4 drwxr-xr-x  2 dm6446 dm6446    4096 2009-10-29 11:49 licenses
   4 drwxrwxr-x  7 dm6446 dm6446    4096 2009-10-29 11:11 linuxutils_2_23_01
  20 -rw-r--r--  1 dm6446 dm6446   16643 2009-05-26 12:35 Makefile
   4 drwxrwxr-x  2 dm6446 dm6446    4096 2009-10-29 11:11 mapdmaq
   4 drwxrwxr-x  2 dm6446 dm6446    4096 2009-10-29 11:11 mapdmaq-hd
   4 drwxrwxr-x  6 dm6446 dm6446    4096 2009-10-29 11:12 PSP_02_00_00_140
   4 drwxrwxr-x  2 dm6446 dm6446    4096 2009-10-29 11:12 quilt
   4 -rw-r--r--  1 dm6446 dm6446    2978 2009-10-29 17:00 Rules.make
   4 -rw-r--r--  1 dm6446 dm6446    2937 2009-10-29 16:16 Rules.make~
1236 -rwxr-xr-x  1 dm6446 dm6446 1259634 2009-10-29 16:29 uninstall
   4 drwxrwxr-x  9 dm6446 dm6446    4096 2009-10-29 11:12 xdais_6_23
   4 drwxr-xr-x 11 dm6446 dm6446    4096 2009-10-29 11:29 xdctools_3_10_05_61
  • mmm, did you configure kernel for DM6446 and rebuild prior to trying to build DVSDK tree?  I believe the Getting Started Guide suggests this.  I am using this DVSDK version as well and had no problems re-building it that helps give you some comfort that it is likely a minor step missing.
  • I still get the following error.  how do I
    What is the root of the problem?
    make[2]: Target `all' not remade because of errors.
    Making all in subdirectory encode...
    make[2]: Entering directory `/home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/dm6446/encode'
  • simple widget package should be rebuilt as a result of performing
     > make clean
    > make
    in root DVSDK directory.  Also, the one thing I noticed from your log above is that you seem to have a newer version of xdctools that came with dvsdk_2_00_00_22 installation (xdctools_3_10_03); I am not sure if this is a big deal or not, but something that may be worth investigating...
  • I went back to xdctools_3_10_03 and got the same error.  any other ideas?
  • I am using dvsdk_2_00_00_22 and am able to rebuild the demos fine when following instructions on Getting Started Guide.  Are you sure you are running make from root dvsdk directory (which would take care of building simplewidget) and not the demo directory?  If so, then you may want to r-install dvsdk as it appears these is stuff missing from your source tree.
  • We ran 'make' from  the directory with the missing file, and it built whatever was needed.  A full make from the dvsdk_xxx runs to completion now.
      516  cd /home/dm6446/dvsdk_2_00_00_22/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget
      517  ls
      518  ls package.xdc
      519  make
    Brett
  • this is great news!
  • Hi all,
    I am facing the same issue posted above. my log is below which is similar to the one posted earlier.
    configuring decode.xv5T from package/cfg/decode_xv5T.cfg ...
    Info: Configuring engine named 'decode' from the info file for DSP server './bin/cs.x64P',
    located in package 'ti.sdo.server.cs':
    Target app will look for the DSP server image 'cs.x64P' in its current directory.
    Adding codec 'g711enc' (ti.sdo.codecs.g711enc.ce.G711ENC), scratch groupId=1
    Adding codec 'h264enc' (ti.sdo.codecs.h264enc.ce.H264ENC), scratch groupId=0
    Adding codec 'jpegdec' (ti.sdo.codecs.jpegdec.ce.JPEGDEC), scratch groupId=0
    Adding codec 'jpegenc' (ti.sdo.codecs.jpegenc.ce.JPEGENC), scratch groupId=0
    Adding codec 'mpeg4enc' (ti.sdo.codecs.mpeg4enc.ce.MPEG4ENC), scratch groupId=0
    Adding codec 'deinterlacer' (ti.sdo.codecs.deinterlacer.ce.I2P), scratch groupId=0
    Info: Reading DSP memory map from the info file for DSP server './bin/cs.x64P',
    js: "/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dvsdk_demos_3_01_00_13/omap3530/decode/decode.cfg", line 33: XDCException: xdc.PACKAGE_NOT_FOUND: /home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dvsdk_demos_3_01_00_13/packages/ti/sdo/simplewidget/package.xdc found along the package path, but no schema file was found. Ensure that the package 'ti.sdo.simplewidget' is completely built.
    "./package/cfg/decode_xv5T.cfg", line 474
    "./package/cfg/decode_xv5T.cfg", line 429
    gmake: *** [package/cfg/decode_xv5T.c] Error 1
    js: "/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/xdctools_3_16_01_27/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    make[3]: *** [decode_config/linker.cmd] Error 1
    make[3]: Leaving directory `/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dvsdk_demos_3_01_00_13/omap3530/decode'
    make[2]: *** [decode] Error 2
    make[2]: Leaving directory `/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dvsdk_demos_3_01_00_13/omap3530'
    make[1]: *** [omap3530] Error 2
    make[1]: Leaving directory `/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dvsdk_demos_3_01_00_13'
    I tired the solution give above. there I get the following error.
    thalib@SilentStorm:$cd packages/ti/sdo/simplewidget/
    thalib@SilentStorm:$make
    Building package interface for simplewidget..
    making package.mak (because of package.bld) ...
    js: "/home/thalib/project/dsp_proj/dvsdk_3_01_00_10/xdctools_3_16_01_27/packages/xdc/xdc.tci", line 546: XDCException: xdc.bld.ROOTDIR_NOT_SET: 'rootDir' has not been set for the target gnu.targets.arm.GCArmv5T; define 'rootDir' in /home/thalib/project/dsp_proj/dvsdk_3_01_00_10/dmai_2_05_00_12/packages/config.bld
    all files complete.
    From the error message I tried to change the rootDir variable. but didn't work.
    Could some one help.
    HM Thalib.
