Did you export the file using the remote file viewer? You can do this in Platform Builder by selecting the Menu:
Target --> Remote Tools --> File Viewer
In the remote file viewer, select:
File --> Export File
and browse to the directory where you have the all.x64P file.
Janet
Hi Xu,
Maybe in your case, the all.x64P is built into your image, and is sitting in the Windows directory. So when you changed "myEngine.server" to "windows\\\\all.x64P", you gave the correct full path to the server. If you were to import the file using the remote file viewer at the root of the WinCE file system, then setting "myEngine.server" to just "all.x64P" would be sufficient for the file to be found.
Janet
xu haiyang: Is your issue resolved? If so, could you please select the "Verify Answer" button for the relevant answer post. Thanks.
