Tool/software: Linux
Hi,all.
My custom board had done as follows:
[ 122.848338] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1 [ 135.566159] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
But when I ran gles1test1, I got:
libEGL warning: DRI3: Screen seems not DRI3 capable libEGL warning: DRI2: failed to authenticate 'eglCreateWindowSurface' returned egl error 'EGL_BAD_NATIVE_WINDOW' (0x300b)
modetest:
trying to open device 'i915'...failed trying to open device 'amdgpu'...failed trying to open device 'radeon'...failed trying to open device 'nouveau'...failed trying to open device 'vmwgfx'...failed trying to open device 'omapdrm'...done Encoders: id crtc type possible crtcs possible clones 30 33 TMDS 0x00000001 0x00000000 Connectors: id encoder status name size (mm) modes encoders 31 30 connected unknown-1 0x0 1 30 modes: name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot) 1024x768 73 1024 1174 1224 1344 768 780 786 816 80000 flags: nhsync, nvsync; type: preferred, driver props: 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 0 CRTCs: id fb pos size 33 40 (0,0) (1024x768) 0 1024 1174 1224 1344 768 780 786 816 80000 flags: nhsync, nvsync; type: props: 26 trans-key-mode: flags: enum enums: disable=0 gfx-dst=1 vid-src=2 value: 0 27 trans-key: flags: range values: 0 16777215 value: 0 28 background: flags: range values: 0 16777215 value: 0 29 alpha_blender: flags: range values: 0 1 value: 0 23 zorder: flags: range values: 0 3 value: 0 Planes: id crtc fb CRTC x,y x,y gamma size possible crtcs 32 33 40 0,0 0,0 0 0x00000001 formats: RG16 RX12 AR12 RG24 RX24 XR24 RA24 AR24 props: 5 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 1 23 zorder: flags: range values: 0 3 value: 0 24 global_alpha: flags: range values: 0 255 value: 255 25 pre_mult_alpha: flags: range values: 0 1 value: 0 34 0 0 0,0 0,0 0 0x00000001 formats: RG16 RX12 RG24 XR24 YUYV UYVY props: 5 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 0 23 zorder: flags: range values: 0 3 value: 1 24 global_alpha: flags: range values: 0 255 value: 255 25 pre_mult_alpha: flags: range values: 0 1 value: 0 35 0 0 0,0 0,0 0 0x00000001 formats: RG16 RX12 AR12 RG24 RX24 XR24 RA24 AR24 YUYV UYVY props: 5 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 0 23 zorder: flags: range values: 0 3 value: 2 24 global_alpha: flags: range values: 0 255 value: 255 25 pre_mult_alpha: flags: range values: 0 1 value: 0 Frame buffers: id size pitch
and glxinfo
eglGetConfigs():
EGL config number: 0
EGL vendor string: Mesa Project
EGL version string: 1.4 (DRI2)
EGL extensions: EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_MESA_configless_context
EGL client APIs are: OpenGL OpenGL_ES
EGL config Attributes:
EGL_CONFIG_ID = 0x1
EGL_BUFFER_SIZE = 0x20
EGL_RED_SIZE = 0x8
EGL_GREEN_SIZE = 0x8
EGL_BLUE_SIZE = 0x8
EGL_LUMINANCE_SIZE = 0x0
EGL_ALPHA_SIZE = 0x8
EGL_ALPHA_MASK_SIZE = 0x0
EGL_BIND_TO_TEXTURE_RGB = 0x1
EGL_BIND_TO_TEXTURE_RGBA = 0x1
EGL_COLOR_BUFFER_TYPE = 0x308e
EGL_CONFIG_CAVEAT = 0x3038
EGL_CONFORMANT = 0x4d
EGL_DEPTH_SIZE = 0x0
EGL_LEVEL = 0x0
EGL_MAX_PBUFFER_WIDTH = 0x1000
EGL_MAX_PBUFFER_HEIGHT = 0x1000
EGL_MAX_PBUFFER_PIXELS = 0x0
EGL_MAX_SWAP_INTERVAL = 0x0
EGL_MIN_SWAP_INTERVAL = 0x0
EGL_NATIVE_RENDERABLE = 0x1
EGL_NATIVE_VISUAL_ID = 0x21
EGL_NATIVE_VISUAL_TYPE = 0x4
EGL_RENDERABLE_TYPE = 0x4d EGL_OPENGL_ES2_BIT EGL_OPENGL_ES_BIT EGL_OPENGL_BIT
EGL_SAMPLE_BUFFERS = 0x0
EGL_SAMPLES = 0x0
EGL_STENCIL_SIZE = 0x0
EGL_SURFACE_TYPE = 0x407 EGL_PBUFFER_BIT EGL_PIXMAP_BIT EGL_WINDOW_BIT
EGL_TRANSPARENT_TYPE = 0x3038
EGL_TRANSPARENT_RED_VALUE = 0x0
EGL_TRANSPARENT_GREEN_VALUE = 0x0
EGL_TRANSPARENT_BLUE_VALUE = 0x0
Creating Window surface..
Unable to create surface
How to solve it?
