Tool/software: Linux
Hi All,
I got a file am335x_pinmux.h from hardware guy.
I have two doubts:
1. I only got one file am335x_pinmux.h not mux.h so it is ok?
2. I had doubts but still I tried below by replacing the content of mux.h from am335x_pinmux.h, Commented content of ./board/ti/evm/evm.h
as per http://processors.wiki.ti.com/index.php/?title=Pin_Mux_Utility_for_ARM_MPU_Processors&oldid=198349
For AM35x / AM37x / OMAP35x the generated pinmux settings may be used to customize the U-Boot source code.
Before rebuilding U-BOOT for your system, the following steps are neccessary:
1) Replace the mux.h header file with the mux.h output file from Pin Mux Utility
2) Copy the pinmux.h output file from Pin Mux Utility into the directory containing the evm.h file.
3) Modify the original evm.h file, commenting out or deleting the original section of code that
makes the pin mux programming macro calls.
I am getting compilation errors..
So, Please help me out.
* Note: This file was auto-generated by TI PinMux on 6/13/2017 at 1:39:45 PM.
* \file am335x_pinmux.h
* \brief This file contains pad configure register offsets and bit-field
* value macros for different configurations,
* 6 SLEWCTRL Select between faster or slower slew rate
* 5 RXACTIVE Input enable value for the Pad
* 4 PULLTYPESEL Pad pullup/pulldown type selection
* 3 PULLUDEN Pad Pullup/pulldown enable
* 2-0 MUXMODE Pad functional signal mux select
* \copyright Copyright (CU) 2017 Texas Instruments Incorporated -
* http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDINGU, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#ifndef AM335X_PIN_MUX_H_
#define AM335X_PIN_MUX_H_
/* Include Files */
#include "pinmux.h"
#ifdef __cplusplus
extern "C" {
#endif
/* Macros & Typedefs */
#define PIN_MODE(mode) (mode)
/** \brief Active mode configurations */
/** \brief Pull up/down disabled */
#define PIN_PULL_UD_EN (0x1U << 3U)
/** \brief Pull UP enable */
#define PIN_PULL_TYPE_SEL (0x1U << 4U)
/** \brief Receiver enable */
#define PIN_RX_ACTIVE (0x1U << 5U)
/** \brief Slew rate */
#define PIN_SLEW_SLOW (0x1U << 6U)
/** \brief Pad config register offset in control module */
enum pinOffsets
PIN_OFFSET_MIN = 0x0800U,
PIN_GPMC_AD0 = 0x0800U,
PIN_GPMC_AD1 = 0x0804U,
PIN_GPMC_AD2 = 0x0808U,
PIN_GPMC_AD3 = 0x080cU,
PIN_GPMC_AD4 = 0x0810U,
PIN_GPMC_AD5 = 0x0814U,
PIN_GPMC_AD6 = 0x0818U,
PIN_GPMC_AD7 = 0x081cU,
PIN_GPMC_AD8 = 0x0820U,
PIN_GPMC_AD9 = 0x0824U,
PIN_GPMC_AD10 = 0x0828U,
PIN_GPMC_AD11 = 0x082cU,
PIN_GPMC_AD12 = 0x0830U,
PIN_GPMC_AD13 = 0x0834U,
PIN_GPMC_AD14 = 0x0838U,
PIN_GPMC_AD15 = 0x083cU,
PIN_GPMC_A0 = 0x0840U,
PIN_GPMC_A1 = 0x0844U,
PIN_GPMC_A2 = 0x0848U,
PIN_GPMC_A3 = 0x084cU,
PIN_GPMC_A4 = 0x0850U,
PIN_GPMC_A5 = 0x0854U,
PIN_GPMC_A6 = 0x0858U,
PIN_GPMC_A7 = 0x085cU,
PIN_GPMC_A8 = 0x0860U,
PIN_GPMC_A9 = 0x0864U,
PIN_GPMC_A10 = 0x0868U,
PIN_GPMC_A11 = 0x086cU,
PIN_GPMC_WAIT0 = 0x0870U,
PIN_GPMC_WPN = 0x0874U,
PIN_GPMC_BE1N = 0x0878U,
PIN_GPMC_CSN0 = 0x087cU,
PIN_GPMC_CSN1 = 0x0880U,
PIN_GPMC_CSN2 = 0x0884U,
PIN_GPMC_CSN3 = 0x0888U,
PIN_GPMC_CLK = 0x088cU,
PIN_GPMC_ADVN_ALE = 0x0890U,
PIN_GPMC_OEN_REN = 0x0894U,
PIN_GPMC_WEN = 0x0898U,
PIN_GPMC_BE0N_CLE = 0x089cU,
PIN_LCD_DATA0 = 0x08a0U,
PIN_LCD_DATA1 = 0x08a4U,
PIN_LCD_DATA2 = 0x08a8U,
PIN_LCD_DATA3 = 0x08acU,
PIN_LCD_DATA4 = 0x08b0U,
PIN_LCD_DATA5 = 0x08b4U,
PIN_LCD_DATA6 = 0x08b8U,
PIN_LCD_DATA7 = 0x08bcU,
PIN_LCD_DATA8 = 0x08c0U,
PIN_LCD_DATA9 = 0x08c4U,
PIN_LCD_DATA10 = 0x08c8U,
PIN_LCD_DATA11 = 0x08ccU,
PIN_LCD_DATA12 = 0x08d0U,
PIN_LCD_DATA13 = 0x08d4U,
PIN_LCD_DATA14 = 0x08d8U,
PIN_LCD_DATA15 = 0x08dcU,
PIN_LCD_VSYNC = 0x08e0U,
PIN_LCD_HSYNC = 0x08e4U,
PIN_LCD_PCLK = 0x08e8U,
PIN_LCD_AC_BIAS_EN = 0x08ecU,
PIN_MMC0_DAT3 = 0x08f0U,
PIN_MMC0_DAT2 = 0x08f4U,
PIN_MMC0_DAT1 = 0x08f8U,
PIN_MMC0_DAT0 = 0x08fcU,
PIN_MMC0_CLK = 0x0900U,
PIN_MMC0_CMD = 0x0904U,
PIN_GMII1_COL = 0x0908U,
PIN_GMII1_CRS = 0x090cU,
PIN_GMII1_RXER = 0x0910U,
PIN_GMII1_TXEN = 0x0914U,
PIN_GMII1_RXDV = 0x0918U,
PIN_GMII1_TXD3 = 0x091cU,
PIN_GMII1_TXD2 = 0x0920U,
PIN_GMII1_TXD1 = 0x0924U,
PIN_GMII1_TXD0 = 0x0928U,
PIN_GMII1_TXCLK = 0x092cU,
PIN_GMII1_RXCLK = 0x0930U,
PIN_GMII1_RXD3 = 0x0934U,
PIN_GMII1_RXD2 = 0x0938U,
PIN_GMII1_RXD1 = 0x093cU,
PIN_GMII1_RXD0 = 0x0940U,
PIN_RMII1_REFCLK = 0x0944U,
PIN_MDIO_DATA = 0x0948U,
PIN_MDIO_CLK = 0x094cU,
PIN_SPI0_SCLK = 0x0950U,
PIN_SPI0_D0 = 0x0954U,
PIN_SPI0_D1 = 0x0958U,
PIN_SPI0_CS0 = 0x095cU,
PIN_SPI0_CS1 = 0x0960U,
PIN_ECAP0_IN_PWM0_OUT = 0x0964U,
PIN_UART0_CTSN = 0x0968U,
PIN_UART0_RTSN = 0x096cU,
PIN_UART0_RXD = 0x0970U,
PIN_UART0_TXD = 0x0974U,
PIN_UART1_CTSN = 0x0978U,
PIN_UART1_RTSN = 0x097cU,
PIN_UART1_RXD = 0x0980U,
PIN_UART1_TXD = 0x0984U,
PIN_I2C0_SDA = 0x0988U,
PIN_I2C0_SCL = 0x098cU,
PIN_MCASP0_ACLKX = 0x0990U,
PIN_MCASP0_FSX = 0x0994U,
PIN_MCASP0_AXR0 = 0x0998U,
PIN_MCASP0_AHCLKR = 0x099cU,
PIN_MCASP0_ACLKR = 0x09a0U,
PIN_MCASP0_FSR = 0x09a4U,
PIN_MCASP0_AXR1 = 0x09a8U,
PIN_MCASP0_AHCLKX = 0x09acU,
PIN_XDMA_EVENT_INTR0 = 0x09b0U,
PIN_XDMA_EVENT_INTR1 = 0x09b4U,
PIN_NRESETIN_OUT = 0x09b8U,
PIN_NNMI = 0x09c0U,
PIN_TMS = 0x09d0U,
PIN_TDI = 0x09d4U,
PIN_TDO = 0x09d8U,
PIN_TCK = 0x09dcU,
PIN_NTRST = 0x09e0U,
PIN_EMU0 = 0x09e4U,
PIN_EMU1 = 0x09e8U,
PIN_RTC_PORZ = 0x09f8U,
PIN_PMIC_POWER_EN = 0x09fcU,
PIN_EXT_WAKEUP = 0x0a00U,
PIN_ENZ_KALDO_1P8V = 0x0a04U,
PIN_USB0_DRVVBUS = 0x0a1cU,
PIN_USB1_DRVVBUS = 0x0a34U,
SMA2_REGISTER = 0x1320U,
PIN_OFFSET_MAX = 0x1320U
/* Global Variables */
/** \brief Auto-generated pinmux configuration data for the board. */
extern pinmuxBoardCfg_t gAM335xPinmuxData[];
#ifdef __cplusplus
#endif /* __cplusplus */
#endif /* AM335X_PIN_MUX_H_ */
