RTOS/AM3352: ISDK semaphore overflow
Part Number: AM3352
Other Parts Discussed in Thread: SYSBIOS, , PRU-ICSS-INDUSTRIAL-SW
Tool/software: TI-RTOS
Hi, everyone
when i use TI RTOS, i got a semphore overflow.
I ONLY post a  semphore in timer3 isr, and pending the semphore in a task, after a long time running, a semphore overflow happen.
A).  message display in CCS console
ti.sysbios.knl.Semaphore: line 319: assertion failure: A_overflow: Count has exceeded 65535 and rolled over.
xdc.runtime.Error.raise: terminating execution
B). code at semphore.c
After sem->count++, the sem->count  equal to 0, so Assert_isTrue called the overflow process. that's mean sem->count before is -1
As I know, the semphore never less than 0, am i right,  how can this happen.
C) . debug call stack
My Develop Enviroment
Compile : CCS 6.1.3
CPU       : AM3352
RTOS     :am335x_sysbios_ind_sdk_1.0.0.6
What's can cause this question, Is there any wrong with my usage.
Thank you.
    ISDK 1.X is no longer supported.
    TI is moving support of all protocols for AM335x and AM437x to PRU-ICSS-INDUSTRIAL-SW in order to provide a single model for industrial software delivery on current and future devices. PRU-ICSS-INDUSTRIAL-SW is already in use for AM57x devices.
    AM335x and AM437x industrial protocol support has begun migrating from SYSBIOSSDK-IND-SITARA (Ind SDK 2.x) to PRU-ICSS-INDUSTRIAL-SW. All current protocols for AM335x and AM437x will be supported on PRU-ICSS-INDUSTRIAL-SW by the end of June 2017.
    TI stopped providing free support for SYSBIOSSDK-IND-AM335x on 31 March 2017, and will no longer provide free support for SYSBIOSSDK-IND-SITARA after 30 June 2017.
    If you are interested in receiving maintenance releases and technical support for either of these SDKs after these dates please contact IndSDKSupport@list.ti.com or your TI representative.
    I think we need some clarification here... IA-SDK is targeting Industrial Comms solutions based on PRU-ICSS implementations. But there are no PRUs in AM3352...
    Otherwise semaphores are not directly related to IA-SDK. It is more a SysBios question. So if you rephrase the question you may get the right support. Don't forget to tell your environment (CCS and BIOS/XDC versions..). Otherwise Biser's comment is correct.
    Frank
  • The RTOS forum read only now, Where is the sysbios forum, could you post a link, thank you.
  • RTOS questions should be posted on device forums.
