Part Number: AM4378
Hello, I can not find the datasheet references in the following URL. processors.wiki.ti.com/.../AM437x_IDK_EVM_HW_User_Guide
Could you please tell me the location of the datasheet ?
ay0689
Part Number: AM4378
ay0689
Hello Biser-san,
thank you for your information.
We need the matching revision of the AM437x datasheet to understand the wiki's content and to proceed our board design.
Could you please send it to me?
Thanks and best regards,
ay0689
Hello Biser-san,
My colleague sent me the AM437x RevC datasheet. But its contents regarding the tables are the same as RevD(the latest version).
I searched with keywords of PCB Design Guidelines in RevD datasheet and created the following table.
PCB Guidelines deviation with respect to datasheet is provided below.
| S.No | PCB Design Guidelines | Datasheet Reference SPRS851D (RevD) | Deviation | Reason For deviation |
| 1 | Full VDDS_DDR power reference layers under the DDR3 routing region | Table 5-53 | Signals other than DDR in Layer 4 are also referenced with the VDDS_DDR power plane | Due to Space Constraints |
| 2 | Placement X2 ( DDR device 1 to Device 2 Distance ) - 600 mils (Max) | Table 5-54 | 740 mils | To Enable Ease of Routing |
| 3 | VDDS_DDR bulk bypass capacitor count 2 Devices (Min) | Table 5-55 | Only one bulk capacitor used | Due to Space constraints |
| 4 | VDDS_DDR bulk bypass total capacitance 20 μF (Min) | Table 5-55 | 2 x 10 uF capacitors required. But only one 10 uF used | Due to Space constraints |
| 5 | DDR3 bulk bypass capacitor count 2 Devices (Min) | Table 5-55 | One device (22uF) Capacitor used | Due to Space constraints |
| 6 | DDR3 bulk bypass total capacitance 20 μF (Min) | Table 5-55 | One 22uF Capacitor used | Due to Space constraints |
| 7 | VDDS_DDR HS bypass capacitor count 20 Devices (Min) | Table 5-56 | 6 bypass capacitors used | Due to Space constraints |
| 8 | VDDS_DDR HS bypass capacitor total capacitance 1 μF ( Min) | Table 5-56 | 0.01uF X 6 Capacitors used | Due to Space constraints |
| 9 | DDR 1 - 2: DDR3 device HS bypass capacitor total capacitance - 0.85 μF (Min) | Table 5-56 | 0.01uF x14 Capacitors used | Due to Space Constraints |
| 10 | CK and ADDR_CTRL nominal trace length - 100 mils (Max) | Table 5-59,5-70 | More than 200 mils difference | Due to Space & Routing Constraints |
| 11 | Split plane crossing | ??? | Found across the board | Due to Space & Routing Constraints |
Table 16: PCB Guidelines Deviations
I could not find the key word "Split plane crossing" in RevD datasheet. Could you please tell me the table number that corresponds to that meaning in RevD datasheet reference?
ay0689
