TDA2EXEVM: EMIF: control the offset ratio value from read DQS to read DQ
Part Number: TDA2EXEVM
Do we have any EMIF registers to control offset ratio value from read DQS to read DQ?
For the write DQS/DQ offset we have EMIF_EXT_PHY_CONTROL_25 register but I cannot find the same for read.
What I'm trying to do is to change the slave ratio offset manually so that we could calculate the setup/hold time (by checking the points from read failure to success) but cannot find the relevant registers.
Please let me know if you have any better ideas to measure read setup/hold time.
Regards, James
