66AK2L06: What is the exactly arm boot magic address on 66AK2L06?
Part Number: 66AK2L06
Hi all,
As the link shows,
e2e.ti.com/.../2232107
I am struggling with bringing secondary arm core up on 66AK2L06.
I review boot-monitor commit log on git.ti.com and find out that TI made change about arm boot magic address.
Currently the arm boot magic address and entry setting in boot-monitor is show as follow:
    #define CORE_N_BASE_ADDR_ARM0	0x02501040
    unsigned int *addr = (unsigned int *)CORE_N_BASE_ADDR_ARM0;
    for (i = 1; i < ARM_CLUSTER_NUM_CPUS; i++) {
            addr[i * 2] = (unsigned int )_skern_123_init;
But the secondary arm core doesn't execute instruction at all on my board.
I have added debug function in skernel.S to check if secondary arm core could execute instruction by putting debug info on UART0 with assembly code.
It's like this:
.global	_skern_123_init
_skern_123_init:
@ we came here after RBL fast boot
@ we don't need to save SP and other registers
@ we just install monitor vectors and stack for us
    b __debug_test
If I revert the arm boot magic address to old one as follows:
    #define CORE_N_BASE_ADDR_ARM0 0x0c1d2500
 addr[i] = (unsigned int )_skern_123_init;
The secondary arm core can execute my debug code and put debug information on UART0.
But it hangs up after executing mcr instruction as follows:
_skern_123_init:
       @b __debug_test
       mrs r8, cpsr
bic r8, r8, #0x1f
orr r8, r8, #0x16
msr cpsr_c, r8
        @b __debug_test
ldr r1, =monitor_vectors
        @b __debug_test
mcr p15, #0, r1, c12, c0, #1   @secondary arm hangs when execute this instruction
        b __debug_test @no reach here
mrc p15, #0, r0, c0, c0, #5
and r0,  r0, #3
        @b __debug_test @no reach here
It's so fuzzy. There isn't any document which illustrate the arm boot magic address on 66AK2L06.
What should I do on this issue?
