Hi Everyone,
I'm using an ADV7280 to capture analog video and using VIP0 Port A (8-Bit) to capture it. Currently, I'm setting up the ADV7280 in user space before loading the VPSS firmware.
I can configure the VPSS firmware to create a Capture -> Null link, and once those links are created and started, I can see that we are receiving video data due to a periodic printout with capture stats. I configure, create, and start these links in the file In src_bios6/main_app/src/main_m3vpss.c. The code is essentially this (Light editing of code):
UInt32 cameraId; UInt32 captureId; CaptureLink_CreateParams capturePrm; NullLink_CreateParams nullPrm; CaptureLink_VipInstParams *pCaptureInstPrm; CaptureLink_OutParams *pCaptureOutPrm; System_linkControl( SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES, NULL, 0, TRUE ); System_linkControl( SYSTEM_LINK_ID_M3VPSS, SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL, &systemVid_encDecIvaChMapTbl, sizeof(SystemVideo_Ivahd2ChMap_Tbl), TRUE ); /* Link Ids */ captureId = SYSTEM_LINK_ID_CAPTURE; nullId = SYSTEM_VPSS_LINK_ID_NULL_0; /* Cature Link params */ CaptureLink_CreateParams_Init(&capturePrm); capturePrm.numVipInst = 1; capturePrm.tilerEnable = FALSE; capturePrm.numBufsPerCh = 10; capturePrm.outQueParams[0].nextLink = nullId; pCaptureInstPrm = &capturePrm.vipInst[0]; pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP0_PORTA; pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_DUMMY; pCaptureInstPrm->standard = SYSTEM_STD_D1; pCaptureInstPrm->numOutput = 1; pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P; pCaptureOutPrm = &pCaptureInstPrm->outParams[0]; pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV; pCaptureOutPrm->scEnable = FALSE; pCaptureOutPrm->scOutWidth = 720; // used only if pCaptureOutPrm->scEnable is TRUE pCaptureOutPrm->scOutHeight = 240; // used only if pCaptureOutPrm->scEnable is TRUE pCaptureOutPrm->outQueId = 0; pCaptureOutPrm->frameSkipMask = 0; /* * Capture NULL Link */ nullPrm.numInQue = 1; nullPrm.inQueParams[0].prevLinkId = captureId; nullPrm.inQueParams[0].prevLinkQueId = 0; Vps_printf("capture link create time - %u ms\r\n", Utils_getCurTimeInMsec()); System_linkCreate(captureId, &capturePrm, sizeof(capturePrm)); Vps_printf("others link create time - %u ms\r\n", Utils_getCurTimeInMsec()); Vps_printf("null link create time - %u ms\r\n", Utils_getCurTimeInMsec()); System_linkCreate(nullId, &nullPrm, sizeof(nullPrm)); Vps_printf("null link create time - %u ms\r\n", Utils_getCurTimeInMsec()); System_linkStart( captureId );
Upon loading, I get a periodic print that outputs stats about the capture. If I disable the ADV7280 chip via an I2C command, the stats indicate that frames are no longer coming in, if I re-enable the chip, the stats indicate that frames are now coming in.
Currently, our system sets up all the MCFW links on the host side in a custom use case. I'm trying to setup the capture & null link under our custom use case on the host and I'm not seeing any frames being captured. Here is the code from the host side. I have edited this snippet to remove non-capture related code:
static uint32_t g_cap_id; static uint32_t g_null_id; CaptureLink_CreateParams capturePrm; NullLink_CreateParams nullPrm; CaptureLink_VipInstParams *pCaptureInstPrm; CaptureLink_OutParams *pCaptureOutPrm; /* * Configure Capture Path */ OSA_printf("\n********* Entered Capture -> Encode -> Out (A8) ********\n"); vcapDecParams.videoIfMode = DEVICE_CAPT_VIDEO_IF_MODE_8BIT; vcapDecParams.videoDataFormat = VF_YUV422P; vcapDecParams.standard = VSYS_STD_AUTO_DETECT; vcapDecParams.videoCaptureMode = DEVICE_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC; vcapDecParams.videoSystem = DEVICE_VIDEO_DECODER_VIDEO_SYSTEM_AUTO_DETECT; vcapDecParams.videoCropEnable = FALSE; Vcap_configVideoDecoder( &vcapDecParams, 1 ); /* * Setup Link IDs */ g_cap_id = SYSTEM_LINK_ID_CAPTURE; g_null_id = SYSTEM_VPSS_LINK_ID_NULL_0; /* * Setup CaptureLink */ CaptureLink_CreateParams_Init(&capturePrm); capturePrm.numVipInst = 1; capturePrm.tilerEnable = FALSE; capturePrm.numBufsPerCh = 10; capturePrm.outQueParams[0].nextLink = g_null_id; pCaptureInstPrm = &capturePrm.vipInst[0]; pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP0_PORTA; pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_DUMMY; pCaptureInstPrm->standard = SYSTEM_STD_D1; pCaptureInstPrm->numOutput = 1; pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P; pCaptureOutPrm = &pCaptureInstPrm->outParams[0]; pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV; pCaptureOutPrm->scEnable = FALSE; pCaptureOutPrm->scOutWidth = 720; // used only if pCaptureOutPrm->scEnable is TRUE pCaptureOutPrm->scOutHeight = 240; // used only if pCaptureOutPrm->scEnable is TRUE pCaptureOutPrm->outQueId = 0; pCaptureOutPrm->frameSkipMask = 0; nullPrm.numInQue = 1; nullPrm.inQueParams[0].prevLinkId = g_cap_id; nullPrm.inQueParams[0].prevLinkQueId = 0; /* * Reset M3VPSS & Set Enc/Dec Channel Map */ System_linkControl(SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,NULL,0,TRUE); System_linkControl(SYSTEM_LINK_ID_M3VPSS, SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL, &systemVid_encDecIvaChMapTbl, sizeof(SystemVideo_Ivahd2ChMap_Tbl),TRUE); //CREATE OSA_printf("############# CREATE CAPTURE LINK #################\n"); System_linkCreate(g_cap_id, &capturePrm, sizeof(capturePrm)); System_linkCreate(g_null_id, &nullPrm, sizeof(nullPrm)); System_linkStart(g_cap_id);
Note: The System_linkStart on the Host example typically would happen when I call the Vcap_start from a different part of code, but for the example, I'll have it get called here instead.
Could anyone tell me why when I startup capture from VPSS, I appear to capture frames without any issues, while when I start it from the A8 Host it appears that I don't get any frame capture? I'm wondering if somehow the VIP0 interface is being configured differently between the two, but I'm not sure how to check.
