Is the source code and complete project of UBL for CCS on DM365 available?
Shahrad,
Yes. You can find it in flash_utils.tar.gz/flash-utils-davinci.tar.gz (flash_utils\DM36x\CCS\UBL).
If you check the UBL.pjt, you will find the source files location as below.
[Source Files]
Source="..\..\..\Common\arch\arm926ejs\src\boot.c"
Source="..\..\..\Common\arch\arm926ejs\src\selfcopy.c"
Source="..\..\..\Common\drivers\src\nand.c"
Source="..\..\..\Common\drivers\src\nor.c"
Source="..\..\..\Common\gnu\src\debug.c"
Source="..\..\..\Common\gnu\src\uart.c"
Source="..\..\..\Common\src\util.c"
Source="..\..\..\Common\ubl\src\nandboot.c"
Source="..\..\..\Common\ubl\src\norboot.c"
Source="..\..\..\Common\ubl\src\uartboot.c"
Source="..\..\..\Common\ubl\src\ubl.c"
Source="..\..\Common\src\device.c"
Source="..\..\Common\src\device_nand.c"
Source="UBL.cmd"
If you meet problem when building ubl in ccs3.3, pls check http://processors.wiki.ti.com/index.php/How_to_update_CCS_ARM_cgtools_to_build_the_DM365_ubl_in_CCS_3.3.
