I'm trying to get the the sample camera app working for EVM Rev G board... does anyone know where to go to access the Microsoft Shared Sources? I googled but I'm not coming up with anything productive.
Insert your original WinCE 6.0 installation disk (or executable if you downloaded it) and run setup. Select the "modify" option and in the setup screen it should give you an option for "Shared Source" (the option will be in between CE 6.0 tools and CE 6.0 operating system on the setup page). Select that and install.
Word of caution: I ran into a problem first time I did this (I might have selected some other option that I should not have) and then Platform Builder stopped recognizing the ARM option and I had to completely reinstall WinCE/PB. My suggestion would be to select the default "Shared Source" option and not change anything else. Also make sure that you do the "CE update check" tool to make sure the later updates/QFEs did not get overwritten.
Also check if MSDN has any more information on this.
Good luck...
