I`m just trying to build IPC example (ex02_messageq) with the latest ProcSDK RTOS(04_00_00_04). ProcSDK has been installed to its default path (C:\ti) and I`ve configured the required path like this in C:\ti\ipc_3_46_00_02\products.mak:
# # Copyright (c) 2012-2015 Texas Instruments Incorporated - http://www.ti.com # # Redistribution and use in source and binary forms, with or without # modification, are permitted provided that the following conditions # are met: # # * Redistributions of source code must retain the above copyright # notice, this list of conditions and the following disclaimer. # # * Redistributions in binary form must reproduce the above copyright # notice, this list of conditions and the following disclaimer in the # documentation and/or other materials provided with the distribution. # # * Neither the name of Texas Instruments Incorporated nor the names of # its contributors may be used to endorse or promote products derived # from this software without specific prior written permission. # # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, # THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR # PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR # CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, # EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, # PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; # OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, # WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR # OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, # EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. # # ======== products.mak ======== # # Note that these variables can be explicitly set here or on the command line. # If you want to use variables in the environment, see the GNU make manual's # -e option: http://www.gnu.org/software/make/manual/make.html#Environment # Optional: recommended to install all dependent components in one folder. # DEPOT = C:\ti # Platform to build for # Supported platforms (choose one): # OMAPL138, OMAP54XX, DRA7XX, 66AK2G, 66AK2E, TCI6630, TCI6636, TCI6638, # TDA3XX # # Note, this is used for Linux, QNX and BIOS builds # PLATFORM = DRA7XX # Destination when installing the built binaries # # Note, this is used for Linux (if you use ipc-linux.mak to run the # configure command), QNX and BIOS. # DESTDIR = #################### IPC Linux #################### # Set up required cross compiler path for IPC Linux configuration and build # TOOLCHAIN_LONGNAME = arm-none-linux-gnueabi TOOLCHAIN_INSTALL_DIR = $(DEPOT)/_your_arm_code_gen_install_ TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)- # Path to Linux Kernel - needed to build the IPC user libraries # KERNEL_INSTALL_DIR = # Optional: Specify the Address Family for RPMSG. This value is specified # either from the Linux kernel specified by KERNEL_INSTALL_DIR above, or # the make variable AF_RPMSG below. Do not use both. # AF_RPMSG = # Optional: Path to DRM Library # DRM_PREFIX = # Optional: Path to TI Linux Utils product # CMEM_INSTALL_DIR = #################### IPC QNX #################### # Path to QNX tools installation # QNX_INSTALL_DIR = # Optional: Any additional compile options # QNX_CFLAGS = #################### IPC Bios #################### # Path to required dependencies for IPC BIOS builds # XDC_INSTALL_DIR = $(DEPOT)/xdctools_3_32_01_22_core BIOS_INSTALL_DIR = $(DEPOT)/bios_6_46_05_55 # Do you want to build SMP-enabled libraries (if supported for your target)? # Set to either 0 (disabled) or 1 (enabled) # BIOS_SMPENABLED=1 # Path to various cgtools # ti.targets.elf.C64P = ti.targets.elf.C64P_big_endian = ti.targets.elf.C64T = ti.targets.elf.C66 ="$(DEPOT)/ti-cgt-c6000_8.1.3" ti.targets.elf.C66_big_endian ="$(DEPOT)/ti-cgt-c6000_8.1.3" ti.targets.elf.C674 = ti.targets.arm.elf.Arm9 = ti.targets.arm.elf.A8F = ti.targets.arm.elf.A8Fnv = ti.targets.arm.elf.M3 = ti.targets.arm.elf.M4 = ti.targets.arm.elf.M4F = ti.targets.arp32.elf.ARP32 = ti.targets.arp32.elf.ARP32_far = gnu.targets.arm.A8F = gnu.targets.arm.A15F ="$(DEPOT)/ccsv7/tools/compiler/gcc-arm-none-eabi-4_9-2015q3"
And I invoked the following commands on my console:
cd C:\ti\ipc_3_46_00_02\examples\DRA7XX_bios_elf\ex02_messageq gmake clean gmake all
And then, I saw an error in host side example:
# Making bin/debug/app_host.xa15fg ...
"C:\ti/ccsv7/tools/compiler/gcc-arm-none-eabi-4_9-2015q3"/bin/arm-none-eabi-gcc -o bin/debug/app_host.xa15fg -g -ggdb -mfloat-abi=hard -nostartfiles -Wl,-static -Wl,--gc-sections -Wl,-Map=bin/debug/obj/app_host.xa15fg.map bin/debug/obj/MainHost.oa15fg bin/debug/obj/App.oa15fg -Wl,-T,bin/debug/configuro/linker.cmd \
-lgcc -lc -lm -lnosys -LC:\ti/bios_6_46_05_55/packages/gnu/targets/arm/libs/install-native/arm-none-eabi/lib/fpu
C:\ti\ipc_3_46_00_02\examples\DRA7XX_bios_elf\ex02_messageq\host\bin\debug\configuro\package\cfg\Host_pa15fg.src\sysbios\sysbios.aa15fg(gnu_ReentSupport.o): In function `ti_sysbios_rts_gnu_ReentSupport_Module_startup__E':
C:/ti/bios_6_46_05_55/packages/ti/sysbios/rts/gnu/ReentSupport.c:83: undefined reference to `ti_sysbios_rts_gnu_ReentSupport_checkIfCorrectLibrary'
collect2.exe: error: ld returned 1 exit status
gmake.exe[2]: *** [bin/debug/app_host.xa15fg] Error 1
Please note DSP1/2 apps seem to be built successfully... Any suggestion for this issue
Naoki
