I have a AM4376 based custom board. It has LEDs on GPIO lines.
I want to control these LEDs from user space .
Could you please guide us , how to achieve the above[any reference]
Thanks in advance.
Thanks in advance.
Hi Kemal R. Shakir,
Thank you for your reply
I am using the GPIO4_9 .
I am attaching the .dts file
Could you please help to resolve the issue
Thanks in advance.
* Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/* AM437x GP EVM */
/dts-v1/;
#include "am4372.dtsi"
#include <dt-bindings/pinctrl/am43xx.h>
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/gpio/gpio.h>
model = "TI AM437x GP EVM";
compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43";
aliases {
/* display0 = &lcd0; */
serial5 = &uart5;
evm_v3_3d: fixedregulator-v3_3d {
compatible = "regulator-fixed";
regulator-name = "evm_v3_3d";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
enable-active-high;
vtt_fixed: fixedregulator-vtt {
regulator-name = "vtt_fixed";
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
regulator-always-on;
regulator-boot-on;
enable-active-high;
gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>;
vmmcwl_fixed: fixedregulator-mmcwl {
regulator-name = "vmmcwl_fixed";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
gpio = <&gpio1 20 GPIO_ACTIVE_HIGH>;
enable-active-high;
/* lcd_bl: backlight {
compatible = "pwm-backlight";
pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>;
brightness-levels = <0 51 53 56 62 75 101 152 255>;
default-brightness-level = <8>;
matrix_keypad: matrix_keypad@0 {
compatible = "gpio-matrix-keypad";
debounce-delay-ms = <5>;
col-scan-delay-us = <2>;
pinctrl-names = "default", "sleep";
pinctrl-0 = <&matrix_keypad_default>;
pinctrl-1 = <&matrix_keypad_sleep>;
linux,wakeup;
row-gpios = <&gpio0 3 GPIO_ACTIVE_HIGH /* Bank0, pin3 */
&gpio4 3 GPIO_ACTIVE_HIGH /* Bank4, pin3 */
&gpio4 2 GPIO_ACTIVE_HIGH>; /* Bank4, pin2 */
col-gpios = <&gpio3 19 GPIO_ACTIVE_HIGH /* Bank3, pin19 */
&gpio3 20 GPIO_ACTIVE_HIGH>; /* Bank3, pin20 */
linux,keymap = <0x00000201 /* P1 */
0x00010202 /* P2 */
0x01000067 /* UP */
0x0101006a /* RIGHT */
0x02000069 /* LEFT */
0x0201006c>; /* DOWN */
/* lcd0: display {
compatible = "osddisplays,osd057T0559-34ts", "panel-dpi";
label = "lcd";
backlight = <&lcd_bl>;
panel-timing {
clock-frequency = <33000000>;
hactive = <800>;
vactive = <480>;
hfront-porch = <210>;
hback-porch = <16>;
hsync-len = <30>;
vback-porch = <10>;
vfront-porch = <22>;
vsync-len = <13>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
port {
lcd_in: endpoint {
remote-endpoint = <&dpi_out>;
/* fixed 12MHz oscillator */
refclk: oscillator {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <12000000>;
/* fixed 32k external oscillator clock */
clk_32k_rtc: clk_32k_rtc {
#clock-cells = <0>;
clock-frequency = <32768>;
sound0: sound@0 {
compatible = "simple-audio-card";
simple-audio-card,name = "AM437x-GP-EVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line In";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound0_master>;
simple-audio-card,frame-master = <&sound0_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp1>;
system-clock-frequency = <12000000>;
sound0_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
audio_mstrclk: mclk_osc {
#clock-cells = <0>;
&am43xx_pinmux {
pinctrl-0 = <&wlan_pins_default &ddr3_vtt_toggle_default &unused_pins &debugss_pins>;
pinctrl-1 = <&wlan_pins_sleep>;
ddr3_vtt_toggle_default: ddr_vtt_toggle_default {
pinctrl-single,pins = <
0x25C (DS0_PULL_UP_DOWN_EN | PIN_OUTPUT_PULLUP | DS0_FORCE_OFF_MODE | MUX_MODE7) /* spi0_cs0.gpio5_7 */
i2c0_pins: i2c0_pins {
0x188 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */
0x18c (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */
i2c1_pins_default: i2c1_pins_default {
0x15c (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_cs0.i2c1_scl */
0x158 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_d1.i2c1_sda */
i2c1_pins_sleep: i2c1_pins_sleep {
0x15c (PIN_INPUT_PULLUP | MUX_MODE7)
0x158 (PIN_INPUT_PULLUP | MUX_MODE7)
mmc1_pins: pinmux_mmc1_pins {
0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
0x0f0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
0x0f4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
0x0f8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
0x0fc (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */
mmc1_sleep_pins: pinmux_mmc1_sleep_pins {
0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x104 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x0f0 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x0f4 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x0f8 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x0fc (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x160 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
ecap0_pins_default: backlight_pins_default {
0x164 MUX_MODE0 /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */
ecap0_pins_sleep: backlight_pins_sleep {
0x164 (PIN_INPUT_PULLDOWN | MUX_MODE7)
pixcir_ts_pins_default: pixcir_ts_pins_default {
0x264 (PIN_INPUT_PULLUP | MUX_MODE7) /* spi2_d0.gpio3_22 */
pixcir_ts_pins_sleep: pixcir_ts_pins_sleep {
0x264 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* spi2_d0.gpio3_22 */
/* cpsw_default: cpsw_default { */
/* pinctrl-single,pins = < */
/* /* Slave 1 */
/* 0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txen.rgmii1_txen */
/* 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxdv.rgmii1_rxctl */
/* 0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txd1.rgmii1_txd3 */
/* 0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txd0.rgmii1_txd2 */
/* 0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txd1.rgmii1_txd1 */
/* 0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txd0.rgmii1_txd0 */
/* 0x12c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) */ /* mii1_txclk.rmii1_tclk */
/* 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxclk.rmii1_rclk */
/* 0x134 (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxd1.rgmii1_rxd3 */
/* 0x138 (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxd0.rgmii1_rxd2 */
/* 0x13c (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxd1.rgmii1_rxd1 */
/* 0x140 (PIN_INPUT_PULLDOWN | MUX_MODE2) */ /* mii1_rxd0.rgmii1_rxd0 */
/* cpsw_sleep: cpsw_sleep { */
/* /* Slave 1 reset value */
/* 0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x134 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */
/* 0x138 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */
/* 0x13c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */
/* 0x140 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */
/* mymii1_pins_default: mymii1_pins_default { */
/* /* Slave 2 */
/* /* 0x78 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (A3) gpmc_be1n.gmii2_col */
/* /* 0x84 ( PIN_INPUT_PULLUP | MUX_MODE8 ) */ /* (F10) gpmc_csn2.gmii2_crs */
/* 0x74 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x74 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x40 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1) */ /* (C3) gpmc_a0.gmii2_txen */
/* 0x44 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (C5) gpmc_a1.gmii2_rxdv */
/* 0x58 ( PIN_INPUT_PULLDOWN | MUX_MODE1) */ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x58 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1 )*/ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x5c ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (F6) gpmc_a7.gmii2_rxclk */
/* 0x54 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1) */ /* (E7) gpmc_a5.gmii2_txd0 */
/* 0x50 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1) */ /* (D7) gpmc_a4.gmii2_txd1 */
/* 0x4c ( PIN_OUTPUT_PULLDOWN | MUX_MODE1) */ /* (A4) gpmc_a3.gmii2_txd2 */
/* 0x48 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1) */ /* (C6) gpmc_a2.gmii2_txd3 */
/* 0x6c ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (D8) gpmc_a11.gmii2_rxd0 */
/* 0x68 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (G8) gpmc_a10.gmii2_rxd1 */
/* 0x64 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (B4) gpmc_a9.gmii2_rxd2 */
/* 0x60 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (F7) gpmc_a8.gmii2_rxd3 */
/* Slave 1*/
/* 0x108 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) */ /* (D16) mii1_col.gmii1_col */
/* 0x10c ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) */ /* (B14) mii1_crs.gmii1_crs */
/* 0x110 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) */ /* (B13) mii1_rx_er.gmii1_rxer */
0x114 ( PIN_OUTPUT_PULLDOWN| MUX_MODE0) /* (A13) mii1_tx_en.gmii1_txen */
0x118 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (A15) mii1_rx_dv.gmii1_rxdv */
0x12c ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (D14) mii1_tx_clk.gmii1_txclk */
/* 0x12c ( PIN_OUTPUT_PULLDOWN | MUX_MODE0) */ /* (D14) mii1_tx_clk.gmii1_txclk */
0x130 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (D13) mii1_rx_clk.gmii1_rxclk */
0x128 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (B15) mii1_txd0.gmii1_txd0 */
0x124 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (A14) mii1_txd1.gmii1_txd1 */
0x120 ( PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (C13) mii1_txd2.gmii1_txd2 */
0x11c ( PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (C16) mii1_txd3.gmii1_txd3 */
0x140 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (F17) mii1_rxd0.gmii1_rxd0 */
0x13c ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (B16) mii1_rxd1.gmii1_rxd1 */
0x138 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (E16) mii1_rxd2.gmii1_rxd2 */
0x134 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (C14) mii1 */
/* Slave 2 */
/* 0x74 ( PIN_INPUT_PULLUP | MUX_MODE1 )*/ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x58 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) */ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x5c ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (F6) gpmc_a7.gmii2_rxclk */
/* 0x54 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1)*/ /* (E7) gpmc_a5.gmii2_txd0 */
/* 0x50 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1)*/ /* (D7) gpmc_a4.gmii2_txd1 */
/* 0x4c ( PIN_OUTPUT_PULLDOWN | MUX_MODE1)*/ /* (A4) gpmc_a3.gmii2_txd2 */
/* 0x48 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1)*/ /* (C6) gpmc_a2.gmii2_txd3 */
/* 0x6c ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (D8) gpmc_a11.gmii2_rxd0 */
/* 0x68 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (G8) gpmc_a10.gmii2_rxd1 */
/* 0x64 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (B4) gpmc_a9.gmii2_rxd2 */
/* 0x60 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (F7) gpmc_a8.gmii2_rxd3 */
/* Slave 2 */
/* 0x74 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x40 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1)*/ /* (C3) gpmc_a0.gmii2_txen */
/* 0x44 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (C5) gpmc_a1.gmii2_rxdv */
/* 0x58 ( PIN_INPUT_PULLDOWN | MUX_MODE1 )*/ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x78 ( PIN_INPUT | MUX_MODE1 ) */ /* (A3) gpmc_be1n.gmii2_col */
/* 0x84 ( PIN_INPUT | MUX_MODE8 ) */ /* (F10) gpmc_csn2.gmii2_crs */
/* 0x74 ( PIN_INPUT | MUX_MODE1 ) */ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x40 ( PIN_OUTPUT | MUX_MODE1 ) */ /* (C3) gpmc_a0.gmii2_txen */
/* 0x44 ( PIN_INPUT | MUX_MODE1 ) */ /* (C5) gpmc_a1.gmii2_rxdv */
/* 0x58 ( PIN_INPUT | MUX_MODE1 ) */ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x5c ( PIN_INPUT | MUX_MODE1 ) */ /* (F6) gpmc_a7.gmii2_rxclk */
/* 0x54 ( PIN_OUTPUT | MUX_MODE1 ) */ /* (E7) gpmc_a5.gmii2_txd0 */
/* 0x50 ( PIN_OUTPUT | MUX_MODE1 ) */ /* (D7) gpmc_a4.gmii2_txd1 */
/* 0x4c ( PIN_OUTPUT | MUX_MODE1 ) */ /* (A4) gpmc_a3.gmii2_txd2 */
/* 0x48 ( PIN_OUTPUT | MUX_MODE1 ) */ /* (C6) gpmc_a2.gmii2_txd3 */
/* 0x6c ( PIN_INPUT | MUX_MODE1 ) */ /* (D8) gpmc_a11.gmii2_rxd0 */
/* 0x68 ( PIN_INPUT | MUX_MODE1 ) */ /* (G8) gpmc_a10.gmii2_rxd1 */
/* 0x64 ( PIN_INPUT | MUX_MODE1 ) */ /* (B4) gpmc_a9.gmii2_rxd2 */
/* 0x60 ( PIN_INPUT | MUX_MODE1 ) */ /* (F7) gpmc_a8.gmii2_rxd3 */
/* mymii1_pins_sleep: mymii1_pins_sleep { */
/* 0x78 ( )*/ /* (A3) gpmc_be1n.gmii2_col */
/* 0x84 ( )*/ /* (F10) gpmc_csn2.gmii2_crs */
/* 0x74 ( )*/ /* (B3) gpmc_wpn.gmii2_rxer */
/* 0x40 ( )*/ /* (C3) gpmc_a0.gmii2_txen */
/* 0x44 ( )*/ /* (C5) gpmc_a1.gmii2_rxdv */
/* 0x58 ( )*/ /* (E8) gpmc_a6.gmii2_txclk */
/* 0x5c ( )*/ /* (F6) gpmc_a7.gmii2_rxclk */
/* 0x54 ( )*/ /* (E7) gpmc_a5.gmii2_txd0 */
/* 0x50 ( )*/ /* (D7) gpmc_a4.gmii2_txd1 */
/* 0x4c ( )*/ /* (A4) gpmc_a3.gmii2_txd2 */
/* 0x48 ( )*/ /* (C6) gpmc_a2.gmii2_txd3 */
/* 0x6c ( )*/ /* (D8) gpmc_a11.gmii2_rxd0 */
/* 0x68 ( )*/ /* (G8) gpmc_a10.gmii2_rxd1 */
/* 0x64 ( )*/ /* (B4) gpmc_a9.gmii2_rxd2 */
/* 0x60 ( )*/ /* (F7) gpmc_a8.gmii2_rxd3 */
mymii2_pins_default: mymii2_pins_default {
/* 0x108 ( PIN_INPUT | MUX_MODE0 ) */ /* (D16) mii1_col.gmii1_col */
/* 0x10c ( PIN_INPUT | MUX_MODE0 ) */ /* (B14) mii1_crs.gmii1_crs */
0x110 ( PIN_INPUT | MUX_MODE0 ) /* (B13) mii1_rx_er.gmii1_rxer */
0x114 ( PIN_OUTPUT | MUX_MODE0 ) /* (A13) mii1_tx_en.gmii1_txen */
0x118 ( PIN_INPUT | MUX_MODE0 ) /* (A15) mii1_rx_dv.gmii1_rxdv */
0x12c ( PIN_INPUT | MUX_MODE0 ) /* (D14) mii1_tx_clk.gmii1_txclk */
0x130 ( PIN_INPUT | MUX_MODE0 ) /* (D13) mii1_rx_clk.gmii1_rxclk */
0x128 ( PIN_OUTPUT | MUX_MODE0 ) /* (B15) mii1_txd0.gmii1_txd0 */
0x124 ( PIN_OUTPUT | MUX_MODE0 ) /* (A14) mii1_txd1.gmii1_txd1 */
0x120 ( PIN_OUTPUT | MUX_MODE0 ) /* (C13) mii1_txd2.gmii1_txd2 */
0x11c ( PIN_OUTPUT | MUX_MODE0 ) /* (C16) mii1_txd3.gmii1_txd3 */
0x140 ( PIN_INPUT | MUX_MODE0 ) /* (F17) mii1_rxd0.gmii1_rxd0 */
0x13c ( PIN_INPUT | MUX_MODE0 ) /* (B16) mii1_rxd1.gmii1_rxd1 */
0x138 ( PIN_INPUT | MUX_MODE0 ) /* (E16) mii1_rxd2.gmii1_rxd2 */
0x134 ( PIN_INPUT | MUX_MODE0 ) /* (C14) mii1_rxd3.gmii1_rxd3 */
/* Optional sleep pin settings. Must manually enter values in the below skeleton. */
/* mymii2_pins_sleep: mymii2_pins_sleep { */
/* 0x108 ( )*/ /* (D16) mii1_col.gmii1_col */
/* 0x10c ( )*/ /* (B14) mii1_crs.gmii1_crs */
/* 0x110 ( )*/ /* (B13) mii1_rx_er.gmii1_rxer */
/* 0x114 ( )*/ /* (A13) mii1_tx_en.gmii1_txen */
/* 0x118 ( )*/ /* (A15) mii1_rx_dv.gmii1_rxdv */
/* 0x12c ( )*/ /* (D14) mii1_tx_clk.gmii1_txclk */
/* 0x130 ( )*/ /* (D13) mii1_rx_clk.gmii1_rxclk */
/* 0x128 ( )*/ /* (B15) mii1_txd0.gmii1_txd0 */
/* 0x124 ( )*/ /* (A14) mii1_txd1.gmii1_txd1 */
/* 0x120 ( )*/ /* (C13) mii1_txd2.gmii1_txd2 */
/* 0x11c ( )*/ /* (C16) mii1_txd3.gmii1_txd3 */
/* 0x140 ( )*/ /* (F17) mii1_rxd0.gmii1_rxd0 */
/* 0x13c ( )*/ /* (B16) mii1_rxd1.gmii1_rxd1 */
/* 0x138 ( )*/ /* (E16) mii1_rxd2.gmii1_rxd2 */
/* 0x134 ( )*/ /* (C14) mii1_rxd3.gmii1_rxd3 */
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */
0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */
davinci_mdio_sleep: davinci_mdio_sleep {
/* MDIO reset value */
0x148 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x14c (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
nand_flash_x8_default: nand_flash_x8_default {
0x0 (PIN_INPUT | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */
0x4 (PIN_INPUT | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */
0x8 (PIN_INPUT | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */
0xc (PIN_INPUT | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */
0x10 (PIN_INPUT | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */
0x14 (PIN_INPUT | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */
0x18 (PIN_INPUT | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */
0x1c (PIN_INPUT | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */
0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */
/* 0x74 (PIN_OUTPUT_PULLUP | MUX_MODE7) */ /* gpmc_wpn.gpmc_wpn */
0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */
0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */
0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */
0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */
0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */
nand_flash_x8_sleep: nand_flash_x8_sleep {
0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpmc_ad0 */
0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpmc_ad1 */
0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpmc_ad2 */
0xc (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpmc_ad3 */
0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpmc_ad4 */
0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpmc_ad5 */
0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpmc_ad6 */
0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpmc_ad7 */
0x70 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_wait0.gpmc_wait0 */
/* 0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_wpn.gpmc_wpn */
0x7c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_csn0.gpmc_csn0 */
0x90 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_advn_ale.gpmc_advn_ale */
0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_oen_ren.gpmc_oen_ren */
0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wen.gpmc_wen */
0x9c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_be0n_cle.gpmc_be0n_cle */
/* dss_pins: dss_pins { */
/* 0x020 (PIN_OUTPUT_PULLUP | MUX_MODE1) */ /*gpmc ad 8 -> DSS DATA 23 */
/* 0x024 (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x028 (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x02c (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x030 (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x034 (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x038 (PIN_OUTPUT_PULLUP | MUX_MODE1) */
/* 0x03c (PIN_OUTPUT_PULLUP | MUX_MODE1) */ /*gpmc ad 15 -> DSS DATA 16 */
/* 0x0a0 (PIN_OUTPUT_PULLUP | MUX_MODE0) */ /* DSS DATA 0 */
/* 0x0a4 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0a8 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0ac (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0b0 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0b4 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0b8 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0bc (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0c0 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0c4 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0c8 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0cc (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0d0 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0d4 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0d8 (PIN_OUTPUT_PULLUP | MUX_MODE0) */
/* 0x0dc (PIN_OUTPUT_PULLUP | MUX_MODE0) *//* DSS DATA 15 */
/* 0x0e0 (PIN_OUTPUT_PULLUP | MUX_MODE0) */ /* DSS VSYNC */
/* 0x0e4 (PIN_OUTPUT_PULLUP | MUX_MODE0) */ /* DSS HSYNC */
/* 0x0e8 (PIN_OUTPUT_PULLUP | MUX_MODE0) */ /* DSS PCLK */
/* 0x0ec (PIN_OUTPUT_PULLUP | MUX_MODE0) */ /* DSS AC BIAS EN */
gpio4_pins: gpio4_pins {
0x1d4 ( PIN_INPUT | MUX_MODE7) /* (AD25) cam1_hd.xdma_event_intr4 */
display_mux_pins: display_mux_pins {
/* GPIO 5_8 to select LCD / HDMI */
0x238 (PIN_OUTPUT_PULLUP | MUX_MODE7)
dcan0_default: dcan0_default_pins {
0x178 (PIN_OUTPUT | MUX_MODE2) /* uart1_ctsn.d_can0_tx */
0x17c (PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_rtsn.d_can0_rx */
dcan0_sleep: dcan0_sleep_pins {
0x178 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_ctsn.gpio0_12 */
0x17c (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_rtsn.gpio0_13 */
dcan1_default: dcan1_default_pins {
0x180 (PIN_OUTPUT | MUX_MODE2) /* uart1_rxd.d_can1_tx */
0x184 (PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_txd.d_can1_rx */
dcan1_sleep: dcan1_sleep_pins {
0x180 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_rxd.gpio0_14 */
0x184 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_txd.gpio0_15 */
vpfe0_pins_default: vpfe0_pins_default {
0x1B0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_hd mode 0*/
0x1B4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_vd mode 0*/
0x1C0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_pclk mode 0*/
0x1C4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data8 mode 0*/
0x1C8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data9 mode 0*/
0x208 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data0 mode 0*/
0x20C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data1 mode 0*/
0x210 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data2 mode 0*/
0x214 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data3 mode 0*/
0x218 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data4 mode 0*/
0x21C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data5 mode 0*/
0x220 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data6 mode 0*/
0x224 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data7 mode 0*/
vpfe0_pins_sleep: vpfe0_pins_sleep {
0x1B0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_hd mode 0*/
0x1B4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_vd mode 0*/
0x1C0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_pclk mode 0*/
0x1C4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data8 mode 0*/
0x1C8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data9 mode 0*/
0x208 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data0 mode 0*/
0x20C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data1 mode 0*/
0x210 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data2 mode 0*/
0x214 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data3 mode 0*/
0x218 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data4 mode 0*/
0x21C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data5 mode 0*/
0x220 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data6 mode 0*/
0x224 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data7 mode 0*/
vpfe1_pins_default: vpfe1_pins_default {
0x1CC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data9 mode 0*/
0x1D0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data8 mode 0*/
/* 0x1D4 (PIN_INPUT_PULLUP | MUX_MODE0) */ /* cam1_hd mode 0*/
0x1D8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_vd mode 0*/
0x1DC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_pclk mode 0*/
0x1E8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data0 mode 0*/
0x1EC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data1 mode 0*/
0x1F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data2 mode 0*/
0x1F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data3 mode 0*/
0x1F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data4 mode 0*/
0x1FC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data5 mode 0*/
/* 0x200 (PIN_INPUT_PULLUP | MUX_MODE0) */ /* cam1_data6 mode 0*/
/* 0x204 (PIN_INPUT_PULLUP | MUX_MODE0)*/ /* cam1_data7 mode 0*/
vpfe1_pins_sleep: vpfe1_pins_sleep {
0x1CC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data9 mode 0*/
0x1D0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data8 mode 0*/
/* 0x1D4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) */ /* cam1_hd mode 0*/
0x1D8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_vd mode 0*/
0x1DC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_pclk mode 0*/
0x1E8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data0 mode 0*/
0x1EC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data1 mode 0*/
0x1F0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data2 mode 0*/
0x1F4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data3 mode 0*/
0x1F8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data4 mode 0*/
0x1FC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data5 mode 0*/
/* 0x200 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) */ /* cam1_data6 mode 0*/
/* 0x204 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)*/ /* cam1_data7 mode 0*/
mmc3_pins_default: pinmux_mmc3_pins_default {
0x8c (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_clk.mmc2_clk */
0x88 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_csn3.mmc2_cmd */
/* 0x44 (PIN_INPUT_PULLUP | MUX_MODE3) */ /* gpmc_a1.mmc2_dat0 */
/* 0x48 (PIN_INPUT_PULLUP | MUX_MODE3) */ /* gpmc_a2.mmc2_dat1 */
/* 0x4c (PIN_INPUT_PULLUP | MUX_MODE3) */ /* gpmc_a3.mmc2_dat2 */
/* 0x78 (PIN_INPUT_PULLUP | MUX_MODE3) */ /* gpmc_be1n.mmc2_dat3 */
mmc3_pins_sleep: pinmux_mmc3_pins_sleep {
0x8c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_clk.mmc2_clk */
0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn3.mmc2_cmd */
/* 0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a1.mmc2_dat0 */
/* 0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a2.mmc2_dat1 */
/* 0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a3.mmc2_dat2 */
/* 0x78 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_be1n.mmc2_dat3 */
wlan_pins_default: pinmux_wlan_pins_default {
/* 0x50 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a4.gpio1_20 WL_EN */
/* 0x5c (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) */ /* gpmc_a7.gpio1_23 WL_IRQ*/
/* 0x40 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a0.gpio1_16 BT_EN*/
wlan_pins_sleep: pinmux_wlan_pins_sleep {
/* 0x40 (PIN_OUTPUT_PULLUP | MUX_MODE7) */ /* gpmc_a0.gpio1_16 BT_EN*/
uart1_pins: uart1_pins {
0x1e8 ( PIN_INPUT | MUX_MODE1 ) /* (AB20) cam1_data0.uart1_rxd */
0x1ec ( PIN_OUTPUT| MUX_MODE1 ) /* (AC21) cam1_data1.uart1_txd */
0x1f0 ( PIN_INPUT | MUX_MODE1 ) /* (AD21) cam1_data2.uart1_ctsn */
0x1f4 ( PIN_OUTPUT | MUX_MODE1 ) /* (AE22) cam1_data3.uart1_rtsn */
0x200 ( PIN_INPUT | MUX_MODE1 ) /* (AD23) cam1_data6.uart1_dcdn */
0x1fc ( PIN_INPUT | MUX_MODE1 ) /* (AE23) cam1_data5.uart1_dsrn */
0x204 ( PIN_OUTPUT| MUX_MODE1 ) /* (AE24) cam1_data7.uart1_dtrn */
0x1f8 ( PIN_INPUT | MUX_MODE1 ) /* (AD22) cam1_data4.uart1_rin */
/* uart1_pins: uart1_pins { */
/* 0x1e8 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (AB20) cam1_data0.uart1_rxd */
/* 0x1ec ( PIN_OUTPUT_PULLDOWN| MUX_MODE1 ) */ /* (AC21) cam1_data1.uart1_txd */
/* 0x1f0 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (AD21) cam1_data2.uart1_ctsn */
/* 0x1f4 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1 )*/ /* (AE22) cam1_data3.uart1_rtsn */
/* 0x200 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (AD23) cam1_data6.uart1_dcdn */
/* 0x1fc ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (AE23) cam1_data5.uart1_dsrn */
/* 0x204 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1 ) */ /* (AE24) cam1_data7.uart1_dtrn */
/* 0x1f8 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (AD22) cam1_data4.uart1_rin */
/* uart2_pins: uart2_pins {
/* 0x150 ( PIN_INPUT | MUX_MODE1 ) */ /* (P23) spi0_sclk.uart2_rxd */
/* 0x154 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1 ) */ /* (T22) spi0_d0.uart2_txd */
/* 0xc0 ( PIN_INPUT_PULLUP | MUX_MODE6 ) */ /* (A19) dss_data8.uart2_ctsn */
/* 0xc4 ( PIN_OUTPUT_PULLDOWN | MUX_MODE6 ) */ /* (B19) dss_data9.uart2_rtsn */
/* uart2_pins: uart2_pins { */
/* 0x150 ( PIN_INPUT_PULLUP | MUX_MODE1 ) */ /* (P23) spi0_sclk.uart2_rxd */
/* /* 0x150 ( PIN_INPUT | MUX_MODE1 ) */ /* (P23) spi0_sclk.uart2_rxd */
/* 0x154 ( PIN_OUTPUT_PULLDOWN | MUX_MODE1 ) /* (T22) spi0_d0.uart2_txd */
/* 0x154 ( PIN_OUTPUT_PULLUP | MUX_MODE1 ) */ /* (T22) spi0_d0.uart2_txd */
0x150 ( PIN_INPUT | MUX_MODE1 ) /* (P23) spi0_sclk.uart2_rxd */
0x154 ( PIN_OUTPUT | MUX_MODE1 ) /* (T22) spi0_d0.uart2_txd */
/* 0x150 ( PIN_INPUT | MUX_MODE1 ) /* (P23) spi0_sclk.uart2_rxd */
/* 0x154 ( PIN_OUTPUT | MUX_MODE1 ) /* (T22) spi0_d0.uart2_txd */
/* /* 0xc0 ( PIN_INPUT_PULLUP | MUX_MODE6 ) */ /* (A19) dss_data8.uart2_ctsn */
/* /* 0xc4 ( PIN_OUTPUT_PULLDOWN | MUX_MODE6 ) */ /* (B19) dss_data9.uart2_rtsn */
uart3_pins: uart3_pins {
0x228 (PIN_INPUT | MUX_MODE0) /* uart3_rxd.uart3_rxd */
0x22c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_txd.uart3_txd */
0x230 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart3_ctsn.uart3_ctsn */
0x234 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_rtsn.uart3_rtsn */
uart5_pins: uart5_pins {
/*0xd8 ( PIN_INPUT_PULLUP | MUX_MODE4 ) */ /* (C17) dss_data14.uart5_rxd */
/*0x144 (PIN_OUTPUT_PULLDOWN | MUX_MODE3 ) */ /* (A16) rmii1_ref_clk.uart5_txd */
0xd8 ( PIN_INPUT | MUX_MODE4 ) /* (C17) dss_data14.uart5_rxd */
0x144 (PIN_OUTPUT | MUX_MODE3 ) /* (A16) rmii1_ref_clk.uart5_txd */
mcasp1_pins: mcasp1_pins {
/* 0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) */ /* mii1_col.mcasp1_axr2 */
/* 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) */ /* mii1_crs.mcasp1_aclkx */
/* 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) */ /* mii1_rxerr.mcasp1_fsx */
/* 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) */ /* rmii1_ref_clk.mcasp1_axr3 */
mcasp1_sleep_pins: mcasp1_sleep_pins {
/* 0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
gpio0_pins: gpio0_pins {
0x26c (PIN_OUTPUT | MUX_MODE9) /* spi2_cs0.gpio0_23 SEL_eMMCorNANDn */
emmc_pins_default: emmc_pins_default {
0x00 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
0x04 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
0x08 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
0x0c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
0x10 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
0x14 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
0x18 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
0x1c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
0x80 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
/* 0x84 (PIN_INPUT_PULLUP | MUX_MODE2) */ /* gpmc_csn2.mmc1_cmd */
emmc_pins_sleep: emmc_pins_sleep {
0x00 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpio1_0 */
0x04 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpio1_1 */
0x08 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpio1_2 */
0x0c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpio1_3 */
0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */
0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */
0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */
0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */
0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.gpio1_30 */
/* 0x84 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_csn2.gpio1_31 */
uart0_pins_default: uart0_pins_default {
0x168 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0)
0x16C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0)
0x170 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */
0x174 (PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
uart0_pins_sleep: uart0_pins_sleep {
0x168 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)
0x16C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)
0x174 (PIN_INPUT_PULLDOWN | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
matrix_keypad_default: matrix_keypad_default {
0x1a4 (PIN_OUTPUT | MUX_MODE7)
0x1a8 (PIN_OUTPUT | MUX_MODE7)
0x1ac (PIN_INPUT | PULL_DISABLE | MUX_MODE9) /* mcasp0_ahclkx.gpio0_3 */
/* 0x154 (PIN_INPUT_PULLDOWN | MUX_MODE0) */
matrix_keypad_sleep: matrix_keypad_sleep {
0x1a4 (PULL_UP | MUX_MODE7)
0x1a8 (PULL_UP | MUX_MODE7)
unused_pins: unused_pins {
/* 0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
/* 0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
0x6C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.mmc1_clk */
/* 0x84 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */ /* gpmc_csn2.mmc1_cmd */
/* 0x150 (PIN_INPUT_PULLDOWN | MUX_MODE7) */
0x190 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x194 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x198 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x19C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x1A0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x23C (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x240 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x244 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x248 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x24C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x250 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x254 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x258 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x260 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
0x268 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x270 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x278 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x27C (PIN_INPUT | PULL_DISABLE)
0x2C8 (PIN_INPUT_PULLDOWN)
0x2D4 (PIN_INPUT_PULLDOWN)
0x2D8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2DC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2E0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2E4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2E8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2EC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x2FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x300 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x304 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x308 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x30C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x310 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x314 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x318 (PIN_INPUT_PULLDOWN | MUX_MODE7)
debugss_pins: pinmux_debugss_pins {
0x290 (PIN_INPUT_PULLDOWN)
0x294 (PIN_INPUT_PULLDOWN)
0x298 (PIN_INPUT_PULLDOWN)
0x29C (PIN_INPUT_PULLDOWN)
0x2A0 (PIN_INPUT_PULLDOWN)
0x2A4 (PIN_INPUT_PULLDOWN)
0x2A8 (PIN_INPUT_PULLDOWN)
&i2c0 {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&i2c0_pins>;
clock-frequency = <100000>;
tps65218: tps65218@24 {
reg = <0x24>;
compatible = "ti,tps65218";
interrupts = <GIC_SPI 7 IRQ_TYPE_NONE>; /* NMIn */
interrupt-controller;
#interrupt-cells = <2>;
dcdc1: regulator-dcdc1 {
compatible = "ti,tps65218-dcdc1";
regulator-name = "vdd_core";
regulator-min-microvolt = <912000>;
regulator-max-microvolt = <1144000>;
regulator-boot-on;
dcdc2: regulator-dcdc2 {
compatible = "ti,tps65218-dcdc2";
regulator-name = "vdd_mpu";
regulator-max-microvolt = <1378000>;
regulator-boot-on;
dcdc3: regulator-dcdc3 {
compatible = "ti,tps65218-dcdc3";
regulator-name = "vdcdc3";
regulator-boot-on;
regulator-state-mem {
regulator-on-in-suspend;
regulator-state-disk {
regulator-off-in-suspend;
dcdc5: regulator-dcdc5 {
compatible = "ti,tps65218-dcdc5";
regulator-name = "v1_0bat";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
dcdc6: regulator-dcdc6 {
compatible = "ti,tps65218-dcdc6";
regulator-name = "v1_8bat";
regulator-boot-on;
ldo1: regulator-ldo1 {
compatible = "ti,tps65218-ldo1";
regulator-boot-on;
ov2659@30 {
compatible = "ovti,ov2659";
reg = <0x30>;
clocks = <&audio_mstrclk>;
clock-names = "xvclk";
port {
ov2659_0: endpoint {
remote-endpoint = <&vpfe1_ep>;
link-frequencies = /bits/ 64 <70000000>;
&i2c1 {
status = "okay";
pinctrl-0 = <&i2c1_pins_default>;
pinctrl-1 = <&i2c1_pins_sleep>;
pixcir_ts@5c {
compatible = "pixcir,pixcir_tangoc";
pinctrl-0 = <&pixcir_ts_pins_default>;
pinctrl-1 = <&pixcir_ts_pins_sleep>;
reg = <0x5c>;
interrupt-parent = <&gpio3>;
interrupts = <22 0>;
attb-gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>;
* 0x264 represents the offset of padconf register of
* gpio3_22 from am43xx_pinmux base.
interrupts-extended = <&gpio3 22 IRQ_TYPE_NONE>,
<&am43xx_pinmux 0x264>;
interrupt-names = "tsc", "wakeup";
touchscreen-size-x = <1024>;
touchscreen-size-y = <600>;
wakeup-source;
ov2659@30 {
reg = <0x30>;
port {
ov2659_1: endpoint {
remote-endpoint = <&vpfe0_ep>;
tlv320aic3106: tlv320aic3106@1b {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x1b>;
status = "okay";
/* Regulators */
IOVDD-supply = <&evm_v3_3d>; /* V3_3D -> <tps63031> EN: V1_8D -> VBAT */
AVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
DRVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
DVDD-supply = <&ldo1>; /* V1_8D -> LDO1 */
&epwmss0 {
status = "okay";
&tscadc {
status = "okay";
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
&ecap0 {
status = "okay";
pinctrl-0 = <&ecap0_pins_default>;
pinctrl-1 = <&ecap0_pins_sleep>;
&gpio0 {
pinctrl-0 = <&gpio0_pins>;
status = "okay";
p23 {
gpio-hog;
gpios = <23 GPIO_ACTIVE_HIGH>;
/* SelEMMCorNAND selects between eMMC and NAND:
* Low: NAND
* High: eMMC
* When changing this line make sure the newly
* selected device node is enabled and the previously
* selected device node is disabled.
output-low;
line-name = "SelEMMCorNAND";
&gpio1 {
status = "okay";
&gpio3 {
status = "okay";
&gpio4 {
pinctrl-0 = <&gpio4_pins>;
status = "okay";
&gpio5 {
pinctrl-0 = <&display_mux_pins>;
status = "okay";
ti,no-reset-on-init;
p8 {
* SelLCDorHDMI selects between display and audio paths:
* Low: HDMI display with audio via HDMI
* High: LCD display with analog audio via aic3111 codec
gpio-hog;
gpios = <8 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "SelLCDorHDMI";
&mmc1 {
status = "okay";
vmmc-supply = <&evm_v3_3d>;
bus-width = <4>;
pinctrl-0 = <&mmc1_pins>;
pinctrl-1 = <&mmc1_sleep_pins>;
cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
/* eMMC sits on mmc2 */
&mmc2 {
* When enabling eMMC, disable GPMC/NAND and set
* SelEMMCorNAND to output-high
status = "disabled";
bus-width = <8>;
pinctrl-0 = <&emmc_pins_default>;
pinctrl-1 = <&emmc_pins_sleep>;
ti,non-removable;
&mmc3 {
status = "okay";
/* these are on the crossbar and are outlined in the
xbar-event-map element */
dmas = <&edma_xbar 30 0 1>,
<&edma_xbar 31 0 2>;
dma-names = "tx", "rx";
vmmc-supply = <&vmmcwl_fixed>;
bus-width = <4>;
pinctrl-0 = <&mmc3_pins_default>;
pinctrl-1 = <&mmc3_pins_sleep>;
cap-power-off-card;
keep-power-in-suspend;
ti,non-removable;
#address-cells = <1>;
#size-cells = <0>;
wlcore: wlcore@0 {
compatible = "ti,wl1835";
reg = <2>;
interrupt-parent = <&gpio1>;
interrupts = <23 IRQ_TYPE_LEVEL_HIGH>;
&uart3 {
status = "okay";
pinctrl-0 = <&uart3_pins>;
&uart1 {
status = "okay";
pinctrl-0 = <&uart1_pins>;
&uart2 {
status = "okay";
pinctrl-0 = <&uart2_pins>;
&uart5 {
status = "okay";
pinctrl-0 = <&uart5_pins>;
&usb2_phy1 {
status = "okay";
&usb1 {
dr_mode = "otg";
status = "okay";
&usb2_phy2 {
status = "okay";
&usb2 {
dr_mode = "host";
status = "okay";
&mac {
slaves = <1>;
/* pinctrl-names = "default", "sleep"; */
pinctrl-0 = <&cpsw_default>;
/* pinctrl-1 = <&cpsw_sleep>; */
status = "okay";
&davinci_mdio {
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
status = "okay";
&cpsw_emac0 {
/* phy_id = <&davinci_mdio>, <0>; */
/* phy_id = <&davinci_mdio>, <3>; */
phy_id = <&davinci_mdio>, <2>;
/*phy-mode = "rgmii"; */
phy-mode = "mii";
/* &cpsw_emac1 { */
/* phy_id = <&davinci_mdio>, <2>; */
/* phy-mode = "mii"; */
&elm {
status = "okay";
&gpmc {
* When enabling GPMC, disable eMMC and set
* SelEMMCorNAND to output-low
status = "okay";
pinctrl-0 = <&nand_flash_x8_default>;
pinctrl-1 = <&nand_flash_x8_sleep>;
ranges = <0 0 0x08000000 0x01000000>; /* CS0 space. Min partition = 16MB */
nand@0,0 {
compatible = "ti,omap2-nand";
reg = <0 0 4>; /* device IO registers */
interrupt-parent = <&gpmc>;
interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
<1 IRQ_TYPE_NONE>; /* termcount */
rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */
ti,nand-ecc-opt = "bch16";
ti,elm-id = <&elm>;
nand-bus-width = <8>;
gpmc,device-width = <1>;
gpmc,sync-clk-ps = <0>;
gpmc,cs-on-ns = <0>;
gpmc,cs-rd-off-ns = <40>;
gpmc,cs-wr-off-ns = <40>;
gpmc,adv-on-ns = <0>;
gpmc,adv-rd-off-ns = <25>;
gpmc,adv-wr-off-ns = <25>;
gpmc,we-on-ns = <0>;
gpmc,we-off-ns = <20>;
gpmc,oe-on-ns = <3>;
gpmc,oe-off-ns = <30>;
gpmc,access-ns = <30>;
gpmc,rd-cycle-ns = <40>;
gpmc,wr-cycle-ns = <40>;
gpmc,bus-turnaround-ns = <0>;
gpmc,cycle2cycle-delay-ns = <0>;
gpmc,clk-activation-ns = <0>;
gpmc,wr-access-ns = <40>;
gpmc,wr-data-mux-bus-ns = <0>;
/* MTD partition table */
/* All SPL-* partitions are sized to minimal length
* which can be independently programmable. For
* NAND flash this is equal to size of erase-block */
#size-cells = <1>;
partition@0 {
label = "NAND.SPL";
reg = <0x00000000 0x00040000>;
partition@1 {
label = "NAND.SPL.backup1";
reg = <0x00040000 0x00040000>;
partition@2 {
label = "NAND.SPL.backup2";
reg = <0x00080000 0x00040000>;
partition@3 {
label = "NAND.SPL.backup3";
reg = <0x000c0000 0x00040000>;
partition@4 {
label = "NAND.u-boot-spl-os";
reg = <0x00100000 0x00080000>;
partition@5 {
label = "NAND.u-boot";
reg = <0x00180000 0x00100000>;
partition@6 {
label = "NAND.u-boot-env";
reg = <0x00280000 0x00040000>;
partition@7 {
label = "NAND.u-boot-env.backup1";
reg = <0x002c0000 0x00040000>;
partition@8 {
label = "NAND.kernel";
reg = <0x00300000 0x00700000>;
partition@9 {
label = "NAND.file-system";
reg = <0x00a00000 0x1f600000>;
&uart0 {
status = "okay";
pinctrl-0 = <&uart0_pins_default>;
pinctrl-1 = <&uart0_pins_sleep>;
/* &dss {
status = "ok";
pinctrl-0 = <&dss_pins>;
port {
dpi_out: endpoint@0 {
remote-endpoint = <&lcd_in>;
data-lines = <24>;
&dcan0 {
pinctrl-0 = <&dcan0_default>;
pinctrl-1 = <&dcan0_sleep>;
status = "okay";
&dcan1 {
pinctrl-0 = <&dcan1_default>;
pinctrl-1 = <&dcan1_sleep>;
status = "okay";
&vpfe0 {
status = "okay";
pinctrl-0 = <&vpfe0_pins_default>;
pinctrl-1 = <&vpfe0_pins_sleep>;
port {
vpfe0_ep: endpoint {
remote-endpoint = <&ov2659_1>;
ti,am437x-vpfe-interface = <0>;
bus-width = <8>;
hsync-active = <0>;
vsync-active = <0>;
&vpfe1 {
status = "okay";
pinctrl-0 = <&vpfe1_pins_default>;
pinctrl-1 = <&vpfe1_pins_sleep>;
port {
vpfe1_ep: endpoint {
remote-endpoint = <&ov2659_0>;
bus-width = <8>;
hsync-active = <0>;
vsync-active = <0>;
&mcasp1 {
pinctrl-0 = <&mcasp1_pins>;
pinctrl-1 = <&mcasp1_sleep_pins>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializers */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 1 2
tx-num-evt = <32>;
rx-num-evt = <32>;
&rtc {
clocks = <&clk_32k_rtc>, <&clk_32768_ck>;
clock-names = "ext-clk", "int-clk";
system-power-controller;
status = "okay";
&wkup_m3_ipc {
ti,set-io-isolation;
ti,scale-data-fw = "am43x-evm-scale-data.bin";
&sgx {
status = "okay";
&cpu {
cpu0-supply = <&dcdc2>;
