Part Number: TCI6630K2L
Other Parts Discussed in Thread: RFSDK
Hello. I was followed RFSDK install guide:
Anyway here are steps to follow:
get MCSDK 3.1.4.7 official release from Texas Instruments web page: MCSDK 3.1.4.7 Release
from mcsdk3.1.4.7, install the ubi files with commands at UBOOT prompt:
setenv serverip <customer_serverip> setenv gatewayip <customer_gatewayip> setenv tftp_root <tftp_root> run get_ubi_net run burn_ubi
install uboot patch for RFSDK2 at UBOOT prompt:
setenv serverip <customer_serverip> setenv gatewayip <customer_gatewayip> setenv tftp_root <tftp_root> setenv name_uboot k2l-evm_u-boot-spi_mcsdk_314_patched.gph get_uboot_net burn_uboot -
power off/on EVM and get UBOOT prompt then verify your UBOOT parameters:
env default -f -a setenv serverip <customer_serverip> setenv netmask <customer_netmask> setenv gatewayip <customer_gatewayip> setenv ipaddr <board_ipaddr> setenv tftp_root <tftp_root> setenv boot ubi setenv debug_options 1 #to allow CCS connection saveenv -
verify version at UBOOT prompt:
ver command returns: U-Boot 2013.01-00001-g04dcae7 (Oct 13 2015 - 09:25:53) boot
- Here i failed -
after Linux boot completed add Linux dtb patches:
How to fix situation?
booting log:
U-Boot SPL 2013.01-00001-g04dcae7 (Oct 13 2015 - 09:25:53)
SF: Detected N25Q128A with page size 64 KiB, total 16 MiB
I2C: ready
DRAM: 2 GiB
Reseting entire DDR3 memory to 0 ...
DRAM: 2 GiB
NAND: 2048 MiB
17:30:51.3: Smart Reflex Class 0 temperature compensation enabled
tps544_init i2c write error
Smart Reflex Class 0 temperature compensation disabled
Net:
17:30:55.6: K2L_EMAC0
Warning: K2L_EMAC0 using MAC address from net device
, K2L_EMAC1, K2L_EMAC2, K2L_EMAC3
Hit any key to stop autoboot: 2
17:30:57. 0
Creating 1 MTD partitions on "nand0":
0x000000180000-0x000080000000 : "mtd=2"
17:30:58.6: UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 262144 bytes (256 KiB)
UBI: logical eraseblock size: 253952 bytes
UBI: smallest flash I/O unit: 4096
UBI: VID header offset: 4096 (aligned 4096)
UBI: data offset: 8192
17:31:35.2: UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 2046 MiB
UBI: number of good PEBs: 8182
UBI: number of bad PEBs: 4
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 5
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 8182
UBI: number of PEBs reserved for bad PEB handling: 81
UBI: max/mean erase counter: 1/0
UBIFS: mounted UBI device 0, volume 0, name "boot"
UBIFS: mounted read-only
UBIFS: file system size: 7872512 bytes (7688 KiB, 7 MiB, 31 LEBs)
UBIFS: journal size: 2285569 bytes (2232 KiB, 2 MiB, 8 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 0 bytes (0 KiB)
Loading file 'securedb.key.bin' to addr 0x0c000000 with size 28 (0x0000001c)...
Done
Loading file 'uImage-k2l-evm.dtb' to addr 0x87000000 with size 46348 (0x0000b50c)...
Done
Loading file 'skern-k2l-evm.bin' to addr 0x0c140000 with size 45056 (0x0000b000)...
Done
Loading file 'uImage-keystone-evm.bin' to addr 0x88000000 with size 4083176 (0x003e4de8)...
17:31:39.7: Done
## installed monitor, freq [199680000], status 0
## Booting kernel from Legacy Image at 88000000 ...
Image Name: Linux-3.10.72-gca334de
Created: 2015-09-30 7:51:42 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4083112 Bytes = 3.9 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 87000000
Booting using the fdt blob at 0x87000000
Loading Kernel Image ...
17:31:40.9: OK
OK
Using Device Tree in place at 87000000, end 8700e50b
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.10.72-gca334de (gtbldadm@ubuntu-12) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 SMP Wed Sep 30 03:51:28 EDT 2015
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c7387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: KeyStone2, model: Texas Instruments Keystone 2 SoC
[ 0.000000] switching to high address space at 0x800000000
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c143b000 s11264 r8192 d13312 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 391696
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=2,4096
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1536MB = 1536MB total
[ 0.000000] Memory: 1534808k/1534808k available, 38056k reserved, 794624K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0733c1c (7344 kB)
[ 0.000000] .init : 0xc0734000 - 0xc0786c00 ( 331 kB)
[ 0.000000] .data : 0xc0788000 - 0xc07ea618 ( 394 kB)
[ 0.000000] .bss : 0xc07ea618 - 0xc081c2bc ( 200 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ipc irq: irqchip registered, range 512-539
[ 0.000000] Generic PLL clk (983040000 Hz), parent (122880000 Hz),postdiv = 2, mult = 15, prediv = 0
[ 0.000000] Main PLL clk (1198080000 Hz), parent (122880000 Hz),postdiv = 2, mult = 38, prediv = 1
[ 0.000000] Generic PLL clk (1198080000 Hz), parent (122880000 Hz),postdiv = 2, mult = 38, prediv = 1
[ 0.000000] Generic PLL clk (400000000 Hz), parent (100000000 Hz),postdiv = 4, mult = 15, prediv = 0
[ 0.000000] Architected local timer running at 199.68MHz (phys).
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: ARM arch timer >56 bits at 199680kHz, resolution 641/128ns
[ 0.000000] keystone timer clock @199680000 MHz
[ 0.000000] sched_clock: 32
17:31:42.0: bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[ 0.000000] Console: colour dummy device 80x30
[ 51.532869] Calibrating delay loop (skipped), value calculated using timer frequency.. 399.36 BogoMIPS (lpj=1996800)
[ 51.532878] pid_max: default: 4096 minimum: 301
[ 51.533013] Mount-cache hash table entries: 512
[ 51.540466] CPU: Testing write buffer coherency: ok
[ 51.540645] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 51.540656] psci: probing function IDs from device-tree
[ 51.540668] Setting up static identity map for 0xc05117a0 - 0xc05117f8
[ 51.542416] CPU1: Booted secondary processor
[ 51.542442] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 51.542513] Brought up 2 CPUs
[ 51.542526] SMP: Total of 2 processors activated (798.72 BogoMIPS).
[ 51.542530] CPU: All CPU(s) started in SVC mode.
[ 51.542961] devtmpfs: initialized
[ 51.554985] NET: Registered protocol family 16
[ 51.555822] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 51.566389] No ATAGs?
[ 51.566408] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 51.566415] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 51.576201] bio: create slab <bio-0> at 0
[ 51.576915] vgaarb: loaded
[ 51.577246] SCSI subsystem initialized
[ 51.577885] usbcore: registered new interface driver usbfs
[ 51.577969] usbcore: registered new interface driver hub
[ 51.578081] usbcore: registered new device driver usb
[ 51.579304] pps_core: LinuxPPS API ver. 1 registered
[ 51.579310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 51.579381] PTP clock support registered
[ 51.579531] keystone-hwqueue hwqueue.36: qmgr start queue 0, number of queues 8192
[ 51.579611] keystone-hwqueue hwqueue.36: added qmgr start queue 0, num of queues 8192, reg_peek f0040000, reg_status f0006000, reg_config f0008000, reg_region f000a000, reg_push f0080000, reg_pop f00c0000
[ 51.580343] keystone-hwqueue hwqueue.36: qos: sched port @8096, drop sched @8000
[ 51.581328] keystone-hwqueue hwqueue.36: qos: sched port @6496, drop sched @6400
[ 51.582292] keystone-hwqueue hwqueue.36: added pool pool-rio: 128 descriptors of size 256
[ 51.582302] keystone-hwqueue hwqueue.36: added pool pool-xge: 1024 descriptors of size 128
[ 51.582310] keystone-hwqueue hwqueue.36: added pool pool-crypto: 1024 descriptors of size 128
[ 51.582319] keystone-hwqueue hwqueue.36: added pool pool-net: 11264 descriptors of size 128
[ 51.582327] keystone-hwqueue hwqueue.36: added pool pool-udma: 1440 descriptors of size 256
[ 51.583466] keystone-hwqueue hwqueue.36: registered queues 0-8191
[ 51.583741] keystone-hwqueue hwqueue.36: qos version 0x200010b, magic valid
[ 51.584226] keystone-hwqueue hwqueue.36: qos version 0x200010b, magic valid
[ 51.590576] keystone-pktdma 2a08000.pktdma: registered 24 logical channels, flows 32, tx chans: 32, rx chans: 32, loopback
[ 51.595257] keystone-pktdma 26186000.pktdma: registered 32 logical channels, flows 128, tx chans: 21, rx chans: 91
[ 51.595402] Switching to clocksource arch_sys_counter
[ 51.613972] NET: Registered protocol family 2
[ 51.614445] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 51.614552] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 51.614660] TCP: Hash tables configured (established 8192 bind 8192)
[ 51.614702] TCP: reno registered
[ 51.614711] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 51.614734] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 51.614899] NET: Registered protocol family 1
[ 51.615054] RPC: Registered named UNIX socket transport module.
[ 51.615060] RPC: Registered udp transport module.
[ 51.615064] RPC: Registered tcp transport module.
[ 51.615068] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 51.615492] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 51.690926] bounce pool size: 64 pages
[ 51.698471] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 51.698646] NTFS driver 2.1.30 [Flags: R/O].
[ 51.698903] jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
[ 51.699222] msgmni has been set to 1477
[ 51.700213] NET: Registered protocol family 38
[ 51.700426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 51.700433] io scheduler noop registered
[ 51.700438] io scheduler deadline registered
[ 51.700559] io scheduler cfq registered (default)
[ 51.701712] keystone-udma udma0.37: registered udma device udma0
[ 51.758633] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 51.760110] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 309) is a 16550A
[ 52.446070] console [ttyS0] enabled
[ 52.450194] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 312) is a 16550A
[ 52.460226] loop: module loaded
[ 52.463485] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[ 52.471932] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[ 52.478896] ONFI param page 0 valid
[ 52.482367] ONFI flash detected
[ 52.485509] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xa5 (Micron MT29F16G08ADBCAH4), 2048MiB, page size: 4096, OOB size: 224
[ 52.497630] Bad block table found at page 524224, version 0x01
[ 52.504111] Bad block table found at page 524160, version 0x01
[ 52.510373] 3 ofpart partitions found on MTD device 30000000.nand
[ 52.516460] Creating 3 MTD partitions on "30000000.nand":
[ 52.521834] 0x000000000000-0x000000100000 : "u-boot"
[ 52.527462] 0x000000100000-0x000000180000 : "params"
[ 52.532991] 0x000000180000-0x000080000000 : "ubifs"
[ 52.538890] davinci_nand 30000000.nand: controller rev. 2.5
[ 52.545093] spi_davinci 21000400.spi: master is unqueued, this is deprecated
[ 52.552402] m25p80 spi32766.0: found n25q128a11, expected n25q128
[ 52.558486] m25p80 spi32766.0: n25q128a11 (16384 Kbytes)
[ 52.563782] 2 ofpart partitions found on MTD device spi32766.0
[ 52.569597] Creating 2 MTD partitions on "spi32766.0":
[ 52.574711] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 52.580584] 0x000000080000-0x000001000000 : "test"
[ 52.586253] spi_davinci 21000400.spi: Controller at 0xf00a4400
[ 52.592357] spi_davinci 21000600.spi: master is unqueued, this is deprecated
[ 52.599486] spi_davinci 21000600.spi: Controller at 0xf00a6600
[ 52.606493] tun: Universal TUN/TAP device driver, 1.6
[ 52.611521] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 52.665412] davinci_mdio 26200f00.mdio: davinci mdio revision 1.7
[ 52.671478] libphy: 26200f00.mdio: probed
[ 52.676069] davinci_mdio 26200f00.mdio: phy[0]: device 26200f00.mdio:00, driver Marvell 88E1510
[ 52.684733] davinci_mdio 26200f00.mdio: phy[1]: device 26200f00.mdio:01, driver Marvell 88E1510
[ 52.693717] keystone-netcp 26000000.netcp: number of serdeses 2
[ 52.699634] keystone-netcp 26000000.netcp: Missing cpts_clock_mult property in the DT.
[ 52.707525] keystone-netcp 26000000.netcp: Missing cpts_clock_shift property in the DT.
[ 52.715501] keystone-netcp 26000000.netcp: Missing cpts_clock_div property in the DT.
[ 52.724235] keystone-netcp 26000000.netcp: cpsw serdes 0 config done lanes(mask) 0x3
[ 52.732671] keystone-netcp 26000000.netcp: cpsw serdes 1 config done lanes(mask) 0x0
[ 52.741304] keystone-netcp 26000000.netcp: Created interface "eth0"
[ 52.747561] keystone-netcp 26000000.netcp: dma_chan_name nettx0
[ 52.754287] keystone-netcp 26000000.netcp: Created interface "eth1"
[ 52.760585] keystone-netcp 26000000.netcp: dma_chan_name nettx1
[ 52.767326] keystone-netcp 26000000.netcp: Created interface "eth2"
[ 52.773571] keystone-netcp 26000000.netcp: dma_chan_name nettx2
[ 52.780307] keystone-netcp 26000000.netcp: Created interface "eth3"
[ 52.786567] keystone-netcp 26000000.netcp: dma_chan_name nettx3
[ 52.792649] keystone-netcp 26000000.netcp: pdsp 0 firmware: keystone/pa_in0_pdsp0.fw
[ 52.800480] keystone-netcp 26000000.netcp: pdsp 1 firmware: keystone/pa_in0_pdsp1.fw
[ 52.808215] keystone-netcp 26000000.netcp: pdsp 2 firmware: keystone/pa_in1_pdsp0.fw
[ 52.815947] keystone-netcp 26000000.netcp: pdsp 3 firmware: keystone/pa_in1_pdsp1.fw
[ 52.823658] keystone-netcp 26000000.netcp: pdsp 4 firmware: keystone/pa_in2_pdsp0.fw
[ 52.831381] keystone-netcp 26000000.netcp: pdsp 5 firmware: keystone/pa_in3_pdsp0.fw
[ 52.839101] keystone-netcp 26000000.netcp: pdsp 6 firmware: keystone/pa_in4_pdsp0.fw
[ 52.846819] keystone-netcp 26000000.netcp: pdsp 7 firmware: keystone/pa_in4_pdsp1.fw
[ 52.854530] keystone-netcp 26000000.netcp: pdsp 8 firmware: keystone/pa_post_pdsp0.fw
[ 52.862335] keystone-netcp 26000000.netcp: pdsp 9 firmware: keystone/pa_post_pdsp1.fw
[ 52.870140] keystone-netcp 26000000.netcp: pdsp 10 firmware: keystone/pa_eg0_pdsp0.fw
[ 52.877946] keystone-netcp 26000000.netcp: pdsp 11 firmware: keystone/pa_eg0_pdsp1.fw
[ 52.885750] keystone-netcp 26000000.netcp: pdsp 12 firmware: keystone/pa_eg0_pdsp2.fw
[ 52.893547] keystone-netcp 26000000.netcp: pdsp 13 firmware: keystone/pa_eg1_pdsp0.fw
[ 52.901351] keystone-netcp 26000000.netcp: pdsp 14 firmware: keystone/pa_eg2_pdsp0.fw
[ 52.909596] keystone-netcp 26000000.netcp: could not find interface 2 node in device tree
[ 52.917748] keystone-netcp 26000000.netcp: Attach of module keystone-qos declined with -19
[ 52.925987] keystone-netcp 26000000.netcp: could not find interface 3 node in device tree
[ 52.934130] keystone-netcp 26000000.netcp: Attach of module keystone-qos declined with -19
[ 52.942384] keystone-netcp 26000000.netcp: Attach of module keystone-sa declined with -19
[ 52.950536] keystone-netcp 26000000.netcp: Attach of module keystone-sa declined with -19
[ 52.959689] dwc3 2690000.dwc3: no usb2 phy configured
[ 52.964728] platform 2690000.dwc3: Driver dwc3 requests probe deferral
[ 52.971816] usbcore: registered new interface driver usb-storage
[ 52.978252] mousedev: PS/2 mouse device common for all mice
[ 52.984008] i2c /dev entries driver
[ 52.988165] watchdog 22f0080.wdt: heartbeat 60 sec
[ 52.995002] keystone-crypto 26080000.crypto: crypto accelerator enabled
[ 53.001960] usbcore: registered new interface driver usbhid
[ 53.007605] usbhid: USB HID core driver
[ 53.011785] remoteproc0: 2620844.dsp0 is available
[ 53.016654] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 53.025686] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 53.036018] remoteproc0: no firmware found
[ 53.040313] rproc-user 2620844.dsp0: registered misc device dsp0
[ 53.046539] remoteproc1: 2620848.dsp1 is available
[ 53.051394] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 53.060363] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 53.070705] remoteproc1: no firmware found
[ 53.074992] rproc-user 2620848.dsp1: registered misc device dsp1
[ 53.081213] remoteproc2: 262084c.dsp2 is available
[ 53.086079] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 53.095000] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 53.105362] remoteproc2: no firmware found
[ 53.109669] rproc-user 262084c.dsp2: registered misc device dsp2
17:31:43.1: [ 53.115878] remoteproc3: 2620850.dsp3 is available
[ 53.120732] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 53.129665] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 53.140014] remoteproc3: no firmware found
[ 53.144299] rproc-user 2620850.dsp3: registered misc device dsp3
[ 53.150309] rproc-user dspmem.38: kick gpio
[ 53.154592] rproc-user dspmem.38: registered misc device dspmem
[ 53.160824] oprofile: using arm/armv7-ca15
[ 53.165012] ipip: IPv4 over IPv4 tunneling driver
[ 53.170106] gre: GRE over IPv4 demultiplexor driver
[ 53.174964] ip_gre: GRE over IPv4 tunneling driver
[ 53.180519] TCP: cubic registered
[ 53.183815] Initializing XFRM netlink socket
[ 53.188519] NET: Registered protocol family 10
[ 53.193983] NET: Registered protocol family 17
[ 53.198429] NET: Registered protocol family 15
[ 53.202898] Bridge firewalling registered
[ 53.206899] 8021q: 802.1Q VLAN Support v1.8
[ 53.212749] sctp: Hash tables configured (established 65536 bind 65536)
[ 53.219566] NET: Registered protocol family 41
[ 53.224118] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 53.231773] Registering SWP/SWPB emulation handler
[ 53.438484] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 53.443958] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 53.451998] xhci-hcd xhci-hcd.0.auto: irq 425, io mem 0x02690000
[ 53.458052] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 53.464811] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 53.472008] usb usb1: Product: xHCI Host Controller
[ 53.476868] usb usb1: Manufacturer: Linux 3.10.72-gca334de xhci-hcd
[ 53.483106] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 53.488392] hub 1-0:1.0: USB hub found
[ 53.492128] hub 1-0:1.0: 1 port detected
[ 53.496222] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 53.501688] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 53.509388] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 53.516153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 53.523345] usb usb2: Product: xHCI Host Controller
[ 53.528204] usb usb2: Manufacturer: Linux 3.10.72-gca334de xhci-hcd
[ 53.534443] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 53.539734] hub 2-0:1.0: USB hub found
[ 53.543471] hub 2-0:1.0: 1 port detected
[ 53.547812] UBI: attaching mtd2 to ubi0
17:31:49.0: [ 59.044586] UBI: scanning is finished
[ 59.057409] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 81, need 156
[ 59.071457] UBI: attached mtd2 (name "ubifs", size 2046 MiB) to ubi0
[ 59.077798] UBI: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 59.084556] UBI: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 59.091237] UBI: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 59.098092] UBI: good PEBs: 8182, bad PEBs: 4, corrupted PEBs: 0
[ 59.104069] UBI: user volume: 5, internal volumes: 1, max. volumes count: 128
[ 59.111179] UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 280811223
[ 59.120105] UBI: available PEBs: 0, total reserved PEBs: 8182, PEBs reserved for bad PEB handling: 81
[ 59.129446] UBI: background thread "ubi_bgt0d" started, PID 1302
[ 59.137985] UBIFS: parse sync
[ 59.145145] UBIFS: background thread "ubifs_bgt0_2" started, PID 1305
[ 59.183811] UBIFS error (pid 1): ubifs_read_node: bad node type (255 but expected 9)
[ 59.191530] UBIFS error (pid 1): ubifs_read_node: bad node at LEB 852:166520, LEB mapping status 0
[ 59.200456] Not a node, first 24 bytes:
[ 59.204101] 00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................
[ 59.217101] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.72-gca334de #1
[ 59.223879] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[ 59.232386] [<c0011abc>] (show_stack+0x10/0x14) from [<c020706c>] (ubifs_read_node+0x210/0x27c)
[ 59.241061] [<c020706c>] (ubifs_read_node+0x210/0x27c) from [<c020f634>] (dbg_old_index_check_init+0x64/0xa4)
[ 59.250945] [<c020f634>] (dbg_old_index_check_init+0x64/0xa4) from [<c02034b0>] (ubifs_mount+0xcdc/0x162c)
[ 59.260570] [<c02034b0>] (ubifs_mount+0xcdc/0x162c) from [<c00d3c84>] (mount_fs+0x14/0xc4)
[ 59.268811] [<c00d3c84>] (mount_fs+0x14/0xc4) from [<c00eb2e8>] (vfs_kern_mount+0x4c/0xc0)
[ 59.277051] [<c00eb2e8>] (vfs_kern_mount+0x4c/0xc0) from [<c00ed2b0>] (do_mount+0x1b0/0x8b4)
[ 59.285463] [<c00ed2b0>] (do_mount+0x1b0/0x8b4) from [<c00eda38>] (SyS_mount+0x84/0xb8)
[ 59.293437] [<c00eda38>] (SyS_mount+0x84/0xb8) from [<c0734f20>] (mount_block_root+0xfc/0x230)
[ 59.302023] [<c0734f20>] (mount_block_root+0xfc/0x230) from [<c07351f4>] (prepare_namespace+0x8c/0x18c)
[ 59.311387] [<c07351f4>] (prepare_namespace+0x8c/0x18c) from [<c0734c48>] (kernel_init_freeable+0x180/0x1c8)
[ 59.321186] [<c0734c48>] (kernel_init_freeable+0x180/0x1c8) from [<c050024c>] (kernel_init+0x8/0xe4)
[ 59.330293] [<c050024c>] (kernel_init+0x8/0xe4) from [<c000dc38>] (ret_from_fork+0x14/0x3c)
[ 59.338624] UBIFS: background thread "ubifs_bgt0_2" stops
[ 59.344275] List of all partitions:
[ 59.347765] 1f00 1024 mtdblock0 (driver?)
[ 59.352799] 1f01 512 mtdblock1 (driver?)
[ 59.357847] 1f02 2095616 mtdblock2 (driver?)
[ 59.362878] 1f03 512 mtdblock3 (driver?)
[ 59.367914] 1f04 15872 mtdblock4 (driver?)
[ 59.372944] No filesystem could mount root, tried: ubifs
[ 59.378332] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 59.386563] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.72-gca334de #1
[ 59.393330] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[ 59.401828] [<c0011abc>] (show_stack+0x10/0x14) from [<c050653c>] (panic+0x90/0x1ec)
[ 59.409542] [<c050653c>] (panic+0x90/0x1ec) from [<c0735018>] (mount_block_root+0x1f4/0x230)
[ 59.417947] [<c0735018>] (mount_block_root+0x1f4/0x230) from [<c07351f4>] (prepare_namespace+0x8c/0x18c)
[ 59.427392] [<c07351f4>] (prepare_namespace+0x8c/0x18c) from [<c0734c48>] (kernel_init_freeable+0x180/0x1c8)
[ 59.437183] [<c0734c48>] (kernel_init_freeable+0x180/0x1c8) from [<c050024c>] (kernel_init+0x8/0xe4)
[ 59.446282] [<c050024c>] (kernel_init+0x8/0xe4) from [<c000dc38>] (ret_from_fork+0x14/0x3c)
[ 59.454599] CPU0: stopping
[ 59.457292] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.72-gca334de #1
[ 59.464059] [<c00159c0>] (unwind_backtrace+0x0/0xf8) from [<c0011abc>] (show_stack+0x10/0x14)
[ 59.472553] [<c0011abc>] (show_stack+0x10/0x14) from [<c0013ccc>] (handle_IPI+0xfc/0x130)
[ 59.480698] [<c0013ccc>] (handle_IPI+0xfc/0x130) from [<c000854c>] (gic_handle_irq+0x54/0x5c)
[ 59.489191] [<c000854c>] (gic_handle_irq+0x54/0x5c) from [<c050ca40>] (__irq_svc+0x40/0x50)
[ 59.497506] Exception stack(0xc0789f68 to 0xc0789fb0)
[ 59.502535] 9f60: c143b918 00000000 00002132 00000000 c0788000 c0788000
[ 59.510678] 9f80: c0790458 c0788000 c05144a0 c07e6cad c07e7490 00000000 00000000 c0789fb0
[ 59.518819] 9fa0: c000ed88 c000ed8c 60000113 ffffffff
[ 59.523850] [<c050ca40>] (__irq_svc+0x40/0x50) from [<c000ed8c>] (arch_cpu_idle+0x28/0x30)
[ 59.532084] [<c000ed8c>] (arch_cpu_idle+0x28/0x30) from [<c0058618>] (cpu_startup_entry+0x50/0x1b4)
[ 59.541097] [<c0058618>] (cpu_startup_entry+0x50/0x1b4) from [<c0734a70>] (start_kernel+0x300/0x358)
[ 59.550194] [<c0734a70>] (start_kernel+0x300/0x358) from [<80008084>] (0x80008084)
