gdbserver error
I use codeblocks to build the sample code ( from …/TrainingCourse/01_Initialization ), it runs ok in release mode, but when I remote-debug  the same code, there are error messages :
Debugger name and version: GNU gdb (Sourcery G++ Lite 2010q1-202) 7.0.50.20100218-cvs
Connected
In ?? () ()
Temporary breakpoint 2 at 0x8b24: file demo.cpp, line 151.
Error while mapping shared library sections:
At /home/sa/testPrj/amg1/demo.cpp:151
Error accessing memory address 0x0:
In ?? () (/lib/libc.so.6)
Debugger finished with status 0
Need help, thanks
  • Could you provide a few more details such as the build enviroment you are using, the source of the software and the board you are developing on.
    This problem had been solved (almost), thanks.
    After I copied lib files from …..toolchain/arm-none-linux-gnueabi/libc/lib to target nfs/lib, I can debug in codeblocks now. But this error message still showed:
