AM5728: Building IPC examples
Part Number: AM5728
Hi ,
4.0 Release Notes introduction can build ipu without using CCS,and I get the answer on E2E.
What is the specific tool chain for building the project?
And your documents are built using CCS. Do you have documentation on building projects outside CCS?
How to build simple ipu and pru examples without using CCS?
Your example is by modifying the firmware in the /lib/firmware directory and then executing the program.
Do I need to modify the firmware when I communicate with the slave core?
How should I load the program into ipu or pru above?
Thanks !
