Tool/software: Linux
We are working on our first custom board with AM3352. It is based on Beagle Bone Black and added some other peripherals. I hard code EERPOM values, rebuild U-boot and download u-boot successfully to the board from UART. But the board hangs after "Starting Kernel...". SD on the board is not working. All code is running in SDRAM. I use the latest SDK 4.0.0.04 from TI website. I changed device tree several time but no luck. Later I delete everything in the device tree but only keep UART0, Ethernet 0 and I2C0. It is still the same.
CCCCC
U-Boot SPL 2017.01-00319-g7752743-dirty (Aug 09 2017 - 18:12:32)
name tag: A335BONE
eeprom name: A335BNLT
name tag: A335BONE
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus are properly configured
Trying to boot from UART
CCm - CRC mode, 4981(SOH)/0(STX)/0(CAN) packets, 5 retries
Loaded 637068 bytes
boot_from_devices: return 0
U-Boot 2017.01-00319-g7752743-dirty (Aug 09 2017 - 18:12:32 -0500)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Card did not respond to voltage select!
** Bad device mmc 0 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: name tag: A335BONE
cpsw, usb_ether
Hit any key to stop autoboot: 0
## Error: "bootcmd_nand0" not defined
starting USB...
USB0: Port not available.
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.2.2 (1065 ms)
Using cpsw device
TFTP from server 192.168.2.1; our IP address is 192.168.2.2
Filename 'zImage'.
Load address: 0x82000000
Loading: #################################################################
2.7 MiB/s
done
Bytes transferred = 3269680 (31e430 hex)
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-e8-eb-11-2c-7e-cf
Using cpsw device
Filename 'pxelinux.cfg/01-e8-eb-11-2c-7e-cf'.
Load address: 0x80100000
Loading: *
TFTP error: 'File not found' (1)
Not retrying...
Retrieving file: pxelinux.cfg/C0A80202
Using cpsw device
Filename 'pxelinux.cfg/C0A80202'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A8020'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A802'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A80'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A8'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C'.
Loading: *
Not retrying...
Retrieving file: pxelinux.cfg/default-arm-am33xx
Using cpsw device
Filename 'pxelinux.cfg/default-arm-am33xx'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/default-arm'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/default'.
Loading: *
Not retrying...
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.2.2 (4 ms)
Using cpsw device
Filename 'boot.scr.uimg'.
Load address: 0x80000000
Loading: *
Not retrying...
BOOTP broadcast 1
DHCP client bound to address 192.168.2.2 (5 ms)
Using cpsw device
Loading: *
Not retrying...
=> tftp 0x88000000 am335x-boneblack.dtb
Using cpsw device
Filename 'am335x-boneblack.dtb'.
Load address: 0x88000000
Loading: ##
1.2 MiB/s
done
Bytes transferred = 27984 (6d50 hex)
=> tftp 0x82000000 zImage
Using cpsw device
Filename 'zImage'.
2.7 MiB/s
done
=> bootz 0x82000000 - 0x88000000
Loading Device Tree to 8fff6000, end 8ffffd4f ... OK
Starting kernel ...
Mingshu
