Hi,I am using a customed board with 66AK2H14,Its design refers to the design of K2EVM-HK(TCI6638 evm).7271.66ak2h14_schematics.pdf
- 1 、EVM use a sodimm for DDR3A and 5 K4B4G1646D-BCK0(1600) chips for DDR3B.EVM use ECC.
My customed boaed modify the ddr3 design. I use 4 K4B4G1646D-BCK0 for DDR3A and 4 K4B4G1646D-BCK0 chips for DDR3B.I don't use ECC for DDR3A and DDR3B. page8/page9 of sch
My DDR3A and DDR3B design are same as EVM's DDR3B design except for NO ECC.
I find that EVM's DDR3A is dual RANK design ,but I use single Rank design .
- 2、EVM 's SGMII connect to PHY but my board 's SGMII connect to port0 of a eth switch(Boardcom BCM5389). port7 of BCM5389 connect to PHY. page11/page19/page18 of sch
Now I am doing u-boot in my board. I use ti-processor-sdk-linux-k2hk-evm-04.00.00.04.
I modify ti-processor-sdk-linux-k2hk-evm-04.00.00.04 / board-support /u-boot /board /ti /ks2_evm /ddr3_k2hk.c and ti-processor-sdk-linux-k2hk-evm-04.00.00.04 / board-support /u-boot /arch /arm /mach-keystone/ddr3.c line99 for DDR3A change
* Keystone2: DDR3 initialization
* (C) Copyright 2012-2014
* Texas Instruments Incorporated, <www.ti.com>
* SPDX-License-Identifier: GPL-2.0+
#include <asm/io.h>
#include <common.h>
#include <asm/arch/msmc.h>
#include <asm/arch/ddr3.h>
#include <asm/arch/psc_defs.h>
#include <asm/ti-common/ti-edma3.h>
#define DDR3_EDMA_BLK_SIZE_SHIFT 10
#define DDR3_EDMA_BLK_SIZE (1 << DDR3_EDMA_BLK_SIZE_SHIFT)
#define DDR3_EDMA_BCNT 0x8000
#define DDR3_EDMA_CCNT 1
#define DDR3_EDMA_XF_SIZE (DDR3_EDMA_BLK_SIZE * DDR3_EDMA_BCNT)
#define DDR3_EDMA_SLOT_NUM 1
void ddr3_init_ddrphy(u32 base, struct ddr3_phy_config *phy_cfg)
unsigned int tmp;
while ((__raw_readl(base + KS2_DDRPHY_PGSR0_OFFSET)
& 0x00000001) != 0x00000001)
__raw_writel(phy_cfg->pllcr, base + KS2_DDRPHY_PLLCR_OFFSET);
tmp = __raw_readl(base + KS2_DDRPHY_PGCR1_OFFSET);
tmp &= ~(phy_cfg->pgcr1_mask);
tmp |= phy_cfg->pgcr1_val;
__raw_writel(tmp, base + KS2_DDRPHY_PGCR1_OFFSET);
__raw_writel(phy_cfg->ptr0, base + KS2_DDRPHY_PTR0_OFFSET);
__raw_writel(phy_cfg->ptr1, base + KS2_DDRPHY_PTR1_OFFSET);
__raw_writel(phy_cfg->ptr3, base + KS2_DDRPHY_PTR3_OFFSET);
__raw_writel(phy_cfg->ptr4, base + KS2_DDRPHY_PTR4_OFFSET);
tmp = __raw_readl(base + KS2_DDRPHY_DCR_OFFSET);
tmp &= ~(phy_cfg->dcr_mask);
tmp |= phy_cfg->dcr_val;
__raw_writel(tmp, base + KS2_DDRPHY_DCR_OFFSET);
__raw_writel(phy_cfg->dtpr0, base + KS2_DDRPHY_DTPR0_OFFSET);
__raw_writel(phy_cfg->dtpr1, base + KS2_DDRPHY_DTPR1_OFFSET);
__raw_writel(phy_cfg->dtpr2, base + KS2_DDRPHY_DTPR2_OFFSET);
__raw_writel(phy_cfg->mr0, base + KS2_DDRPHY_MR0_OFFSET);
__raw_writel(phy_cfg->mr1, base + KS2_DDRPHY_MR1_OFFSET);
__raw_writel(phy_cfg->mr2, base + KS2_DDRPHY_MR2_OFFSET);
__raw_writel(phy_cfg->dtcr, base + KS2_DDRPHY_DTCR_OFFSET);
__raw_writel(phy_cfg->pgcr2, base + KS2_DDRPHY_PGCR2_OFFSET);
__raw_writel(phy_cfg->zq0cr1, base + KS2_DDRPHY_ZQ0CR1_OFFSET);
__raw_writel(phy_cfg->zq1cr1, base + KS2_DDRPHY_ZQ1CR1_OFFSET);
__raw_writel(phy_cfg->zq2cr1, base + KS2_DDRPHY_ZQ2CR1_OFFSET);
__raw_writel(phy_cfg->pir_v1, base + KS2_DDRPHY_PIR_OFFSET);
while ((__raw_readl(base + KS2_DDRPHY_PGSR0_OFFSET) & 0x1) != 0x1)
if (cpu_is_k2g()) {
clrsetbits_le32(base + KS2_DDRPHY_DATX8_2_OFFSET,
phy_cfg->datx8_2_mask,
phy_cfg->datx8_2_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_3_OFFSET,
phy_cfg->datx8_3_mask,
phy_cfg->datx8_3_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_4_OFFSET,
phy_cfg->datx8_4_mask,
phy_cfg->datx8_4_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_5_OFFSET,
phy_cfg->datx8_5_mask,
phy_cfg->datx8_5_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_6_OFFSET,
phy_cfg->datx8_6_mask,
phy_cfg->datx8_6_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_7_OFFSET,
phy_cfg->datx8_7_mask,
phy_cfg->datx8_7_val);
clrsetbits_le32(base + KS2_DDRPHY_DATX8_8_OFFSET,
phy_cfg->datx8_8_mask,
phy_cfg->datx8_8_val);
while ((__raw_readl(base + KS2_DDRPHY_PGSR0_OFFSET) & 0x1) != 0x1);
//Modified for close ecc
__raw_writel(0x7C000E80, base + KS2_DDRPHY_DATX8_8_OFFSET);
__raw_writel(phy_cfg->pir_v2, base + KS2_DDRPHY_PIR_OFFSET);
void ddr3_init_ddremif(u32 base, struct ddr3_emif_config *emif_cfg)
__raw_writel(emif_cfg->sdcfg, base + KS2_DDR3_SDCFG_OFFSET);
__raw_writel(emif_cfg->sdtim1, base + KS2_DDR3_SDTIM1_OFFSET);
__raw_writel(emif_cfg->sdtim2, base + KS2_DDR3_SDTIM2_OFFSET);
__raw_writel(emif_cfg->sdtim3, base + KS2_DDR3_SDTIM3_OFFSET);
__raw_writel(emif_cfg->sdtim4, base + KS2_DDR3_SDTIM4_OFFSET);
__raw_writel(emif_cfg->zqcfg, base + KS2_DDR3_ZQCFG_OFFSET);
__raw_writel(emif_cfg->sdrfc, base + KS2_DDR3_SDRFC_OFFSET);
int ddr3_ecc_support_rmw(u32 base)
u32 value = __raw_readl(base + KS2_DDR3_MIDR_OFFSET);
/* Check the DDR3 controller ID reg if the controllers
supports ECC RMW or not */
if (value == 0x40461C02)
return 1;
return 0;
static void ddr3_ecc_config(u32 base, u32 value)
u32 data;
__raw_writel(value, base + KS2_DDR3_ECC_CTRL_OFFSET);
udelay(100000); /* delay required to synchronize across clock domains */
if (value & KS2_DDR3_ECC_EN) {
/* Clear the 1-bit error count */
data = __raw_readl(base + KS2_DDR3_ONE_BIT_ECC_ERR_CNT_OFFSET);
__raw_writel(data, base + KS2_DDR3_ONE_BIT_ECC_ERR_CNT_OFFSET);
/* enable the ECC interrupt */
__raw_writel(KS2_DDR3_1B_ECC_ERR_SYS | KS2_DDR3_2B_ECC_ERR_SYS |
KS2_DDR3_WR_ECC_ERR_SYS,
base + KS2_DDR3_ECC_INT_ENABLE_SET_SYS_OFFSET);
/* Clear the ECC error interrupt status */
base + KS2_DDR3_ECC_INT_STATUS_OFFSET);
static void ddr3_reset_data(u32 base, u32 ddr3_size)
u32 mpax[2];
u32 seg_num;
u32 seg, blks, dst, edma_blks;
struct edma3_slot_config slot;
struct edma3_channel_config edma_channel;
u32 edma_src[DDR3_EDMA_BLK_SIZE/4] __aligned(16) = {0, };
/* Setup an edma to copy the 1k block to the entire DDR */
puts("\nClear entire DDR3 memory to enable ECC\n");
/* save the SES MPAX regs */
if (cpu_is_k2g())
msmc_get_ses_mpax(K2G_MSMC_SEGMENT_ARM, 0, mpax);
else
msmc_get_ses_mpax(K2HKLE_MSMC_SEGMENT_ARM, 0, mpax);
/* setup edma slot 1 configuration */
slot.opt = EDMA3_SLOPT_TRANS_COMP_INT_ENB |
EDMA3_SLOPT_COMP_CODE(0) |
EDMA3_SLOPT_STATIC | EDMA3_SLOPT_AB_SYNC;
slot.bcnt = DDR3_EDMA_BCNT;
slot.acnt = DDR3_EDMA_BLK_SIZE;
slot.ccnt = DDR3_EDMA_CCNT;
slot.src_bidx = 0;
slot.dst_bidx = DDR3_EDMA_BLK_SIZE;
slot.src_cidx = 0;
slot.dst_cidx = 0;
slot.link = EDMA3_PARSET_NULL_LINK;
slot.bcntrld = 0;
edma3_slot_configure(KS2_EDMA0_BASE, DDR3_EDMA_SLOT_NUM, &slot);
/* configure quik edma channel */
edma_channel.slot = DDR3_EDMA_SLOT_NUM;
edma_channel.chnum = 0;
edma_channel.complete_code = 0;
/* event trigger after dst update */
edma_channel.trigger_slot_word = EDMA3_TWORD(dst);
qedma3_start(KS2_EDMA0_BASE, &edma_channel);
/* DDR3 size in segments (4KB seg size) */
seg_num = ddr3_size << (30 - KS2_MSMC_SEG_SIZE_SHIFT);
for (seg = 0; seg < seg_num; seg += KS2_MSMC_MAP_SEG_NUM) {
/* map 2GB 36-bit DDR address to 32-bit DDR address in EMIF
access slave interface so that edma driver can access */
if (cpu_is_k2g()) {
msmc_map_ses_segment(K2G_MSMC_SEGMENT_ARM, 0,
base >> KS2_MSMC_SEG_SIZE_SHIFT,
KS2_MSMC_DST_SEG_BASE + seg,
MPAX_SEG_2G);
} else {
msmc_map_ses_segment(K2HKLE_MSMC_SEGMENT_ARM, 0,
MPAX_SEG_2G);
if ((seg_num - seg) > KS2_MSMC_MAP_SEG_NUM)
edma_blks = KS2_MSMC_MAP_SEG_NUM <<
(KS2_MSMC_SEG_SIZE_SHIFT
- DDR3_EDMA_BLK_SIZE_SHIFT);
else
edma_blks = (seg_num - seg) << (KS2_MSMC_SEG_SIZE_SHIFT
/* Use edma driver to scrub 2GB DDR memory */
for (dst = base, blks = 0; blks < edma_blks;
blks += DDR3_EDMA_BCNT, dst += DDR3_EDMA_XF_SIZE) {
edma3_set_src_addr(KS2_EDMA0_BASE,
edma_channel.slot, (u32)edma_src);
edma3_set_dest_addr(KS2_EDMA0_BASE,
edma_channel.slot, (u32)dst);
while (edma3_check_for_transfer(KS2_EDMA0_BASE,
&edma_channel))
udelay(10);
qedma3_stop(KS2_EDMA0_BASE, &edma_channel);
/* restore the SES MPAX regs */
if (cpu_is_k2g())
msmc_set_ses_mpax(K2G_MSMC_SEGMENT_ARM, 0, mpax);
else
msmc_set_ses_mpax(K2HKLE_MSMC_SEGMENT_ARM, 0, mpax);
static void ddr3_ecc_init_range(u32 base)
u32 ecc_val = KS2_DDR3_ECC_EN;
u32 rmw = ddr3_ecc_support_rmw(base);
if (rmw)
ecc_val |= KS2_DDR3_ECC_RMW_EN;
__raw_writel(0, base + KS2_DDR3_ECC_ADDR_RANGE1_OFFSET);
ddr3_ecc_config(base, ecc_val);
void ddr3_enable_ecc(u32 base, int test)
u32 ecc_val = KS2_DDR3_ECC_ENABLE;
if (test)
ecc_val |= KS2_DDR3_ECC_ADDR_RNG_1_EN;
if (!rmw) {
if (!test)
/* by default, disable ecc when rmw = 0 and no
ecc test */
ecc_val = 0;
} else {
void ddr3_disable_ecc(u32 base)
ddr3_ecc_config(base, 0);
#if defined(CONFIG_SOC_K2HK) || defined(CONFIG_SOC_K2L)
static void cic_init(u32 base)
/* Disable CIC global interrupts */
__raw_writel(0, base + KS2_CIC_GLOBAL_ENABLE);
/* Set to normal mode, no nesting, no priority hold */
__raw_writel(0, base + KS2_CIC_CTRL);
__raw_writel(0, base + KS2_CIC_HOST_CTRL);
/* Enable CIC global interrupts */
__raw_writel(1, base + KS2_CIC_GLOBAL_ENABLE);
static void cic_map_cic_to_gic(u32 base, u32 chan_num, u32 irq_num)
/* Map the system interrupt to a CIC channel */
__raw_writeb(chan_num, base + KS2_CIC_CHAN_MAP(0) + irq_num);
/* Enable CIC system interrupt */
__raw_writel(irq_num, base + KS2_CIC_SYS_ENABLE_IDX_SET);
/* Enable CIC Host interrupt */
__raw_writel(chan_num, base + KS2_CIC_HOST_ENABLE_IDX_SET);
static void ddr3_map_ecc_cic2_irq(u32 base)
cic_init(base);
cic_map_cic_to_gic(base, KS2_CIC2_DDR3_ECC_CHAN_NUM,
KS2_CIC2_DDR3_ECC_IRQ_NUM);
#endif
void ddr3_init_ecc(u32 base, u32 ddr3_size)
if (!ddr3_ecc_support_rmw(base)) {
ddr3_disable_ecc(base);
return;
ddr3_ecc_init_range(base);
ddr3_reset_data(CONFIG_SYS_SDRAM_BASE, ddr3_size);
/* mapping DDR3 ECC system interrupt from CIC2 to GIC */
ddr3_map_ecc_cic2_irq(KS2_CIC2_BASE);
#endif
ddr3_enable_ecc(base, 0);
void ddr3_check_ecc_int(u32 base)
char *env;
int ecc_test = 0;
u32 value = __raw_readl(base + KS2_DDR3_ECC_INT_STATUS_OFFSET);
env = getenv("ecc_test");
if (env)
ecc_test = simple_strtol(env, NULL, 0);
if (value & KS2_DDR3_WR_ECC_ERR_SYS)
puts("DDR3 ECC write error interrupted\n");
if (value & KS2_DDR3_2B_ECC_ERR_SYS) {
puts("DDR3 ECC 2-bit error interrupted\n");
if (!ecc_test) {
puts("Reseting the device ...\n");
reset_cpu(0);
value = __raw_readl(base + KS2_DDR3_ONE_BIT_ECC_ERR_CNT_OFFSET);
if (value) {
printf("1-bit ECC err count: 0x%x\n", value);
KS2_DDR3_ONE_BIT_ECC_ERR_ADDR_LOG_OFFSET);
printf("1-bit ECC err address log: 0x%x\n", value);
void ddr3_reset_ddrphy(void)
u32 tmp;
/* Assert DDR3A PHY reset */
tmp = readl(KS2_DDR3APLLCTL1);
tmp |= KS2_DDR3_PLLCTRL_PHY_RESET;
writel(tmp, KS2_DDR3APLLCTL1);
/* wait 10us to catch the reset */
udelay(10);
/* Release DDR3A PHY reset */
tmp &= ~KS2_DDR3_PLLCTRL_PHY_RESET;
__raw_writel(tmp, KS2_DDR3APLLCTL1);
#ifdef CONFIG_SOC_K2HK
* ddr3_reset_workaround - reset workaround in case if leveling error
* detected for PG 1.0 and 1.1 k2hk SoCs
void ddr3_err_reset_workaround(void)
unsigned int tmp;
unsigned int tmp_a;
unsigned int tmp_b;
* Check for PGSR0 error bits of DDR3 PHY.
* Check for WLERR, QSGERR, WLAERR,
* RDERR, WDERR, REERR, WEERR error to see if they are set or not
tmp_a = __raw_readl(KS2_DDR3A_DDRPHYC + KS2_DDRPHY_PGSR0_OFFSET);
tmp_b = __raw_readl(KS2_DDR3B_DDRPHYC + KS2_DDRPHY_PGSR0_OFFSET);
if (((tmp_a & 0x0FE00000) != 0) || ((tmp_b & 0x0FE00000) != 0)) {
printf("DDR Leveling Error Detected!\n");
printf("DDR3A PGSR0 = 0x%x\n", tmp_a);
printf("DDR3B PGSR0 = 0x%x\n", tmp_b);
* Write Keys to KICK registers to enable writes to registers
* in boot config space
__raw_writel(KS2_KICK0_MAGIC, KS2_KICK0);
__raw_writel(KS2_KICK1_MAGIC, KS2_KICK1);
* Move DDR3A Module out of reset isolation by setting
* MDCTL23[12] = 0
tmp_a = __raw_readl(KS2_PSC_BASE +
PSC_REG_MDCTL(KS2_LPSC_EMIF4F_DDR3A));
tmp_a = PSC_REG_MDCTL_SET_RESET_ISO(tmp_a, 0);
__raw_writel(tmp_a, KS2_PSC_BASE +
* Move DDR3B Module out of reset isolation by setting
* MDCTL24[12] = 0
tmp_b = __raw_readl(KS2_PSC_BASE +
PSC_REG_MDCTL(KS2_LPSC_EMIF4F_DDR3B));
tmp_b = PSC_REG_MDCTL_SET_RESET_ISO(tmp_b, 0);
__raw_writel(tmp_b, KS2_PSC_BASE +
* Write 0x5A69 Key to RSTCTRL[15:0] to unlock writes
* to RSTCTRL and RSTCFG
tmp = __raw_readl(KS2_RSTCTRL);
tmp &= KS2_RSTCTRL_MASK;
tmp |= KS2_RSTCTRL_KEY;
__raw_writel(tmp, KS2_RSTCTRL);
* Set PLL Controller to drive hard reset on SW trigger by
* setting RSTCFG[13] = 0
tmp = __raw_readl(KS2_RSTCTRL_RSCFG);
tmp &= ~KS2_RSTYPE_PLL_SOFT;
__raw_writel(tmp, KS2_RSTCTRL_RSCFG);
reset_cpu(0);
#endif
#include <common.h>
#include "ddr3_cfg.h"
#include <asm/arch/hardware.h>
struct pll_init_data ddr3a_333 = DDR3_PLL_333(A);
struct pll_init_data ddr3a_400 = DDR3_PLL_400(A);
struct ddr3_phy_config ddr3phy_1600_2g = {
.pllcr = 0x0001C000ul,
.pgcr1_mask = (IODDRM_MASK | ZCKSEL_MASK),
.pgcr1_val = ((1 << 2) | (1 << 7) | (1 << 23)),
.ptr0 = 0x42C21590ul,
.ptr1 = 0xD05612C0ul,
.ptr2 = 0, /* not set in gel */
.ptr3 = 0x0D861A80ul,
.ptr4 = 0x0C827100ul,
.dcr_mask = (PDQ_MASK | MPRDQ_MASK | BYTEMASK_MASK),
.dcr_val = ((1 << 10)),
.dtpr0 = 0x9D9CBB66ul,
.dtpr1 = 0x32868400ul,
.dtpr2 = 0x5002D200ul,
.mr0 = 0x00001C70ul,
.mr1 = 0x00000006ul,
.mr2 = 0x00000018ul,
.dtcr = 0x710035C7ul,
.pgcr2 = 0x00F07A12ul,
.zq0cr1 = 0x0001005Dul,
.zq1cr1 = 0x0001005Bul,
.zq2cr1 = 0x0001005Bul,
.pir_v1 = 0x00000033ul,
.datx8_2_mask = 0x00000001ul,
.datx8_2_val = 0x7C000E81ul,
.datx8_3_mask = 0x00000001ul,
.datx8_3_val = 0x7C000E81ul,
.datx8_4_mask = 0x00000001ul,
.datx8_4_val = 0x7C000E81ul,
.datx8_5_mask = 0x00000001ul,
.datx8_5_val = 0x7C000E81ul,
.datx8_6_mask = 0x00000001ul,
.datx8_6_val = 0x7C000E81ul,
.datx8_7_mask = 0x00000001ul,
.datx8_7_val = 0x7C000E81ul,
.datx8_8_mask = 0x00000001ul,
.datx8_8_val = 0x7C000E80ul,
.pir_v2 = 0x0000FF81ul,
struct ddr3_emif_config ddr3_1600_2g = {
.sdcfg = 0x6200CE62ul,
.sdtim1 = 0x166C9875ul,
.sdtim2 = 0x00001D4Aul,
.sdtim3 = 0x435DFF53ul,
.sdtim4 = 0x543F0CFFul,
.zqcfg = 0x70073200ul,
.sdrfc = 0x00001869ul,
u32 ddr3_init(void)
u32 ddr3_size;
struct ddr3_spd_cb spd_cb;
u32 value = 0;
char DDR3_name[] = {"4 K4BG1646D-1600"};
/* if (ddr3_get_dimm_params_from_spd(&spd_cb)) {
printf("Sorry, I don't know how to configure DDR3A.\n"
"Bye :(\n");
for (;;)
value = __raw_readl(KS2_DDR3A_DDRPHYC + KS2_DDRPHY_PGSR0_OFFSET);
printf("DDR3 status: 0x%x\n", value);
memcpy(&spd_cb.dimm_name,DDR3_name,30);
memcpy(&spd_cb.emif_cfg,&ddr3_1600_2g,sizeof(struct ddr3_emif_config));
memcpy(&spd_cb.phy_cfg,&ddr3phy_1600_2g,sizeof(struct ddr3_phy_config));
spd_cb.ddrspdclock = 1600;
spd_cb.ddr_size_gbyte = 2;
printf("Detected [%s]\n",spd_cb.dimm_name);
if ((cpu_revision() > 1) ||
(__raw_readl(KS2_RSTCTRL_RSTYPE) & 0x1)) {
printf("DDR3 speed %d\n", spd_cb.ddrspdclock);
if (spd_cb.ddrspdclock == 1600)
init_pll(&ddr3a_400);
else
init_pll(&ddr3a_333);
if (cpu_revision() > 0) {
if (cpu_revision() > 1) {
/* PG 2.0 */
/* Reset DDR3A PHY after PLL enabled */
ddr3_reset_ddrphy();
spd_cb.phy_cfg.zq0cr1 |= 0x10000;
spd_cb.phy_cfg.zq1cr1 |= 0x10000;
spd_cb.phy_cfg.zq2cr1 |= 0x10000;
ddr3_init_ddrphy(KS2_DDR3A_DDRPHYC, &spd_cb.phy_cfg);
ddr3_init_ddremif(KS2_DDR3A_EMIF_CTRL_BASE, &spd_cb.emif_cfg);
ddr3_size = spd_cb.ddr_size_gbyte;
} else {
spd_cb.emif_cfg.sdcfg |= 0x1000;
ddr3_size = spd_cb.ddr_size_gbyte / 2;
printf("DRAM: %d GiB (includes reported below)\n", ddr3_size);
/* Apply the workaround for PG 1.0 and 1.1 Silicons */
if (cpu_revision() <= 1)
ddr3_err_reset_workaround();
//tj
printf("ddr3_init parameter input done\n");
return ddr3_size;
I modify ti-processor-sdk-linux-k2hk-evm-04.00.00.04 / board-support /u-boot /arch /arm /dts / keystone-k2hk-netcp.dtsi line 169and line174 for eth change. Idtsi file can upload,I change .dtsi to .c
* Device Tree Source for Keystone 2 Hawking Netcp driver
* Copyright 2015 Texas Instruments, Inc.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
qmss: qmss@2a40000 {
compatible = "ti,keystone-navigator-qmss";
dma-coherent;
#address-cells = <1>;
#size-cells = <1>;
clocks = <&chipclk13>;
ranges;
queue-range = <0 0x4000>;
linkram0 = <0x100000 0x8000>;
linkram1 = <0x0 0x10000>;
qmgrs {
#size-cells = <1>;
ranges;
qmgr0 {
managed-queues = <0 0x2000>;
reg = <0x2a40000 0x20000>,
<0x2a06000 0x400>,
<0x2a02000 0x1000>,
<0x2a03000 0x1000>,
<0x23a80000 0x20000>,
<0x2a80000 0x20000>;
reg-names = "peek", "status", "config",
"region", "push", "pop";
qmgr1 {
managed-queues = <0x2000 0x2000>;
reg = <0x2a60000 0x20000>,
<0x2a06400 0x400>,
<0x2a04000 0x1000>,
<0x2a05000 0x1000>,
<0x23aa0000 0x20000>,
<0x2aa0000 0x20000>;
queue-pools {
qpend {
qpend-0 {
qrange = <658 8>;
interrupts =<0 40 0xf04 0 41 0xf04 0 42 0xf04
0 43 0xf04 0 44 0xf04 0 45 0xf04
0 46 0xf04 0 47 0xf04>;
qpend-1 {
qrange = <8704 16>;
interrupts = <0 48 0xf04 0 49 0xf04 0 50 0xf04
0 51 0xf04 0 52 0xf04 0 53 0xf04
0 54 0xf04 0 55 0xf04 0 56 0xf04
0 57 0xf04 0 58 0xf04 0 59 0xf04
0 60 0xf04 0 61 0xf04 0 62 0xf04
0 63 0xf04>;
qalloc-by-id;
qpend-2 {
qrange = <8720 16>;
interrupts = <0 64 0xf04 0 65 0xf04 0 66 0xf04
0 59 0xf04 0 68 0xf04 0 69 0xf04
0 70 0xf04 0 71 0xf04 0 72 0xf04
0 73 0xf04 0 74 0xf04 0 75 0xf04
0 76 0xf04 0 77 0xf04 0 78 0xf04
0 79 0xf04>;
general-purpose {
gp-0 {
qrange = <4000 64>;
netcp-tx {
qrange = <640 9>;
qalloc-by-id;
netcpx-tx {
qrange = <8752 8>;
qalloc-by-id;
descriptor-regions {
#size-cells = <1>;
ranges;
region-12 {
id = <12>;
region-spec = <8192 128>; /* num_desc desc_size */
link-index = <0x4000>;
}; /* qmss */
knav_dmas: knav_dmas@0 {
compatible = "ti,keystone-navigator-dma";
clocks = <&papllclk>;
#size-cells = <1>;
ranges;
ti,navigator-cloud-address = <0x23a80000 0x23a90000
0x23aa0000 0x23ab0000>;
dma_gbe: dma_gbe@0 {
reg = <0x2004000 0x100>,
<0x2004400 0x120>,
<0x2004800 0x300>,
<0x2004c00 0x120>,
<0x2005000 0x400>;
reg-names = "global", "txchan", "rxchan",
"txsched", "rxflow";
dma_srio: dma_srio@0 {
reg = <0x2901000 0x020>,
<0x2901400 0x200>,
<0x2901800 0x200>,
<0x2901c00 0x200>,
<0x2902000 0x280>;
netcp: netcp@2000000 {
reg = <0x2620110 0x8>;
reg-names = "efuse";
compatible = "ti,netcp-1.0";
#size-cells = <1>;
/* NetCP address range */
ranges = <0 0x2000000 0x100000>;
clocks = <&papllclk>, <&clkcpgmac>, <&chipclk12>;
dma-coherent;
ti,navigator-dmas = <&dma_gbe 22>,
<&dma_gbe 23>,
<&dma_gbe 8>;
ti,navigator-dma-names = "netrx0", "netrx1", "nettx";
netcp-devices {
ranges;
#size-cells = <1>;
gbe@90000 { /* ETHSS */
#size-cells = <1>;
label = "netcp-gbe";
compatible = "ti,netcp-gbe";
reg = <0x90000 0x300>, <0x90400 0x400>, <0x90800 0x700>;
/* enable-ale; */
tx-queue = <648>;
tx-channel = "nettx";
interfaces {
gbe0: interface-0 {
slave-port = <0>;
link-interface = <0>;
phy-handle = <ðphy0>;
gbe1: interface-1 {
slave-port = <1>;
phy-handle = <ðphy1>;
secondary-slave-ports {
port-2 {
slave-port = <2>;
link-interface = <2>;
port-3 {
slave-port = <3>;
netcp-interfaces {
interface-0 {
rx-channel = "netrx0";
rx-pool = <1024 12>;
tx-pool = <1024 12>;
rx-queue-depth = <128 128 0 0>;
rx-buffer-size = <1518 4096 0 0>;
rx-queue = <8704>;
tx-completion-queue = <8706>;
efuse-mac = <1>;
netcp-gbe = <&gbe0>;
interface-1 {
rx-channel = "netrx1";
rx-queue = <8705>;
tx-completion-queue = <8707>;
efuse-mac = <0>;
local-mac-address = [02 18 31 7e 3e 6f];
netcp-gbe = <&gbe1>;
Besides,I add #define DEBUG 1 in ti-processor-sdk-linux-k2hk-evm-04.00.00.04 / board-support /u-boot /include /common.h line98,so I can see debug information in u-boot console.
When I do U-boot ,the u-boot console print:
[17:34:13.277] initcall: 0c042ed1
[17:34:13.277]
[17:34:13.294] U-Boot 2017.01-00319-gf3ebc3d-dirty (Aug 16 2017 - 15:44:43 +0800)
[17:34:13.294]
[17:34:13.294] initcall: 0c00dde5
[17:34:13.294] U-Boot code: 0C000000 -> 0C06A880 BSS: -> 0C0CBE98
[17:34:13.294] initcall: 0c00104d
[17:34:13.294] CPU: 66AK2Hx SR2.0
[17:34:13.310] initcall: 0c00260d
[17:34:13.310] initcall: 0c00e225
[17:34:13.310] Model: Texas Instruments Keystone 2 Kepler/Hawking EVM
[17:34:13.310] initcall: 0c00de15
[17:34:13.310] I2C: ready
[17:34:13.310] initcall: 0c00de05
[17:34:13.310] DRAM: initcall: 0c002315
[17:34:13.327] DDR3 status: 0xb000001a
[17:34:13.327] Detected [4 K4BG1646D-1600]
[17:34:13.327] DDR3 speed 1600
[17:34:13.327] DRAM: 2 GiB (includes reported below)
[17:34:13.341] DDR3 status: 0xb0000fff
[17:34:13.341] ddr3_init parameter input done
[17:34:13.341]
[17:34:13.437] Clear entire DDR3 memory to enable ECC
[17:34:13.437] initcall: 0c00dff9
[17:34:13.743] Monitor len: 000CBE98
[17:34:13.743] Ram size: 40000000
[17:34:13.743] Ram top: C0000000
[17:34:13.743] initcall: 0c00dc91
[17:34:13.757] initcall: 0c00dd9d
[17:34:13.757] TLB table from bfff0000 to bfff4000
[17:34:13.757] initcall: 0c00df29
[17:34:13.757] initcall: 0c00dd5d
[17:34:13.757] Reserving 815k for U-Boot at: bff24000
[17:34:13.757] initcall: 0c00dd39
[17:34:13.757] Reserving 33024k for malloc() at: bdee4000
[17:34:13.773] initcall: 0c00dee9
[17:34:13.773] Reserving 88 Bytes for Board Info at: bdee3fa8
[17:34:13.773] initcall: 0c00df2d
[17:34:13.773] initcall: 0c00dd11
[17:34:13.773] Reserving 200 Bytes for Global Data at: bdee3ee0
[17:34:13.789] initcall: 0c00dcc1
[17:34:13.789] Reserving 33728 Bytes for FDT at: bdedbb20
[17:34:13.789] initcall: 0c00df21
[17:34:13.789] initcall: 0c00e061
[17:34:13.789] initcall: 0c00dfdd
[17:34:13.789] initcall: 0c00df39
[17:34:13.789]
[17:34:13.789] RAM Configuration:
[17:34:13.789] Bank #0: 80000000 1 GiB
[17:34:13.805] Bank #1: 0 0 Bytes
[17:34:13.805]
[17:34:13.805] DRAM: 1 GiB
[17:34:13.805] initcall: 0c00dcad
[17:34:13.805] New Stack Pointer is: bdedbb00
[17:34:13.805] initcall: 0c00debd
[17:34:13.805] initcall: 0c00de65
[17:34:13.805] Relocation Offset is: b3f24000
[17:34:13.805] Relocating to bff24000, new gd at bdee3ee0, sp at bdedbb00
[17:34:13.821] initcall: bff321ff
[17:34:13.821] initcall: bff320a1
[17:34:13.821] initcall: 0c00e1f1 (relocated to bff321f1)
[17:34:13.837] initcall: 0c00e1c9 (relocated to bff321c9)
[17:34:13.837] efi_runtime_relocate: Relocating to offset=bff24000
[17:34:13.837] efi_runtime_relocate: Setting bff8e730 to bff8e788
[17:34:13.853] efi_runtime_relocate: Setting bff8e73c to bff6cc40
[17:34:13.853] efi_runtime_relocate: Setting bff8e744 to bff6cc4c
[17:34:13.853] efi_runtime_relocate: Setting bff8e74c to bff6cc4c
[17:34:13.853] efi_runtime_relocate: Setting bff8e750 to bff8e7a0
[17:34:13.869] efi_runtime_relocate: Setting bff8e754 to bff6c1b0
[17:34:13.869] efi_runtime_relocate: Setting bff8e75c to bff8e760
[17:34:13.869] efi_runtime_relocate: Setting bff8e7b8 to bff60e25
[17:34:13.869] efi_runtime_relocate: Setting bff8e7bc to bff8e705
[17:34:13.885] efi_runtime_relocate: Setting bff8e7c0 to bff8e6fd
[17:34:13.885] efi_runtime_relocate: Setting bff8e7c4 to bff8e6fd
[17:34:13.885] efi_runtime_relocate: Setting bff8e7c8 to bff60f61
[17:34:13.901] efi_runtime_relocate: Setting bff8e7cc to bff8e70d
[17:34:13.901] efi_runtime_relocate: Setting bff8e7d0 to bff8e705
[17:34:13.901] efi_runtime_relocate: Setting bff8e7d4 to bff8e705
[17:34:13.901] efi_runtime_relocate: Setting bff8e7d8 to bff8e705
[17:34:13.917] efi_runtime_relocate: Setting bff8e7dc to bff8e705
[17:34:13.917] efi_runtime_relocate: Setting bff8e7e0 to bff60e2d
[17:34:13.917] initcall: 0c00e1fb (relocated to bff321fb)
[17:34:13.933] initcall: 0c00e19d (relocated to bff3219d)
[17:34:13.933] Pre-reloc malloc() used 0x10c bytes (0 KB)
[17:34:13.933] using memory 0xbdee4000-0xbff24000 for malloc()
[17:34:13.933] initcall: 0c00e0b5 (relocated to bff320b5)
[17:34:13.981] initcall: 0c00e09d (relocated to bff3209d)
[17:34:13.997] initcall: 0c00e18b (relocated to bff3218b)
[17:34:13.997] uclass_find_device_by_seq: 0 -1
[17:34:13.997] uclass_find_device_by_seq: 0 0
[17:34:13.997] - -1 -1
[17:34:13.997] - not found
[17:34:13.997] bind node chosen
[17:34:13.997] Device 'chosen' has no compatible string
[17:34:14.013] bind node aliases
[17:34:14.013] Device 'aliases' has no compatible string
[17:34:14.013] bind node memory
[17:34:14.013] Device 'memory' has no compatible string
[17:34:14.013] bind node interrupt-controller
[17:34:14.013] - attempt to match compatible string 'arm,cortex-a15-gic'
[17:34:14.029] No match for node 'interrupt-controller'
[17:34:14.029] bind node timer
[17:34:14.029] - attempt to match compatible string 'arm,armv7-timer'
[17:34:14.029] No match for node 'timer'
[17:34:14.045] bind node pmu
[17:34:14.045] - attempt to match compatible string 'arm,cortex-a15-pmu'
[17:34:14.045] No match for node 'pmu'
[17:34:14.045] bind node soc
[17:34:14.045] - attempt to match compatible string 'ti,keystone'
[17:34:14.061] - attempt to match compatible string 'simple-bus'
[17:34:14.061] - found match at 'generic_simple_bus'
[17:34:14.061] fdtdec_get_int_array: ranges
[17:34:14.061] get_prop_check_min_len: ranges
[17:34:14.061] bind node pll-controller@02310000
[17:34:14.077] - attempt to match compatible string 'ti,keystone-pllctrl'
[17:34:14.077] - attempt to match compatible string 'syscon'
[17:34:14.077] No match for node 'pll-controller@02310000'
[17:34:14.077] bind node device-state-control@02620000
[17:34:14.093] - attempt to match compatible string 'ti,keystone-devctrl'
[17:34:14.093] - attempt to match compatible string 'syscon'
[17:34:14.093] No match for node 'device-state-control@02620000'
[17:34:14.109] bind node reset-controller
[17:34:14.109] - attempt to match compatible string 'ti,keystone-reset'
[17:34:14.109] No match for node 'reset-controller'
[17:34:14.109] bind node clocks
[17:34:14.109] Device 'clocks' has no compatible string
[17:34:14.125] bind node serial@02530c00
[17:34:14.125] - attempt to match compatible string 'ns16550a'
[17:34:14.125] - found match at 'ns16550_serial'
[17:34:14.125] Looking for 'serial' at 17116, name serial@02530c00
[17:34:14.141] - serial0, /soc/serial@02530c00
[17:34:14.141] Found seq 0
[17:34:14.141] Bound device serial@02530c00 to soc
[17:34:14.141] bind node serial@02531000
[17:34:14.141] - attempt to match compatible string 'ns16550a'
[17:34:14.157] - found match at 'ns16550_serial'
[17:34:14.157] Looking for 'serial' at 17272, name serial@02531000
[17:34:14.157] - serial0, /soc/serial@02530c00
[17:34:14.157] - spi0, /soc/spi@21000400
[17:34:14.157] - spi1, /soc/spi@21000600
[17:34:14.173] - spi2, /soc/spi@21000800
[17:34:14.173] Not found
[17:34:14.173] Bound device serial@02531000 to soc
[17:34:14.173] bind node i2c@2530000
[17:34:14.173] - attempt to match compatible string 'ti,davinci-i2c'
[17:34:14.189] No match for node 'i2c@2530000'
[17:34:14.189] bind node i2c@2530400
[17:34:14.189] - attempt to match compatible string 'ti,davinci-i2c'
[17:34:14.189] No match for node 'i2c@2530400'
[17:34:14.189] bind node i2c@2530800
[17:34:14.205] No match for node 'i2c@2530800'
[17:34:14.205] bind node spi@21000400
[17:34:14.205] - attempt to match compatible string 'ti,dm6441-spi'
[17:34:14.205] - found match at 'davinci_spi'
[17:34:14.221] Looking for 'spi' at 17952, name spi@21000400
[17:34:14.221] - serial0, /soc/serial@02530c00
[17:34:14.221] - spi0, /soc/spi@21000400
[17:34:14.221] Found seq 0
[17:34:14.221] bind node n25q128a11@0
[17:34:14.221] - attempt to match compatible string 'Micron,n25q128a11'
[17:34:14.237] - attempt to match compatible string 'spi-flash'
[17:34:14.237] - found match at 'spi_flash_std'
[17:34:14.237] fdtdec_get_int: reg: 0x0 (0)
[17:34:14.237] fdtdec_get_int: spi-max-frequency: 0x337f980 (54000000)
[17:34:14.253] fdtdec_get_bool: spi-cpol
[17:34:14.253] fdtdec_get_bool: spi-cpha
[17:34:14.253] fdtdec_get_bool: spi-cs-high
[17:34:14.253] fdtdec_get_bool: spi-3wire
[17:34:14.253] fdtdec_get_bool: spi-half-duplex
[17:34:14.253] fdtdec_get_uint: spi-tx-bus-width: (not found)
[17:34:14.269] fdtdec_get_uint: spi-rx-bus-width: (not found)
[17:34:14.269] Bound device n25q128a11@0 to spi@21000400
[17:34:14.269] Bound device spi@21000400 to soc
[17:34:14.269] bind node spi@21000600
[17:34:14.286] - attempt to match compatible string 'ti,dm6441-spi'
[17:34:14.286] - found match at 'davinci_spi'
[17:34:14.286] Looking for 'spi' at 18424, name spi@21000600
[17:34:14.286] - serial0, /soc/serial@02530c00
[17:34:14.301] - spi0, /soc/spi@21000400
[17:34:14.301] - spi1, /soc/spi@21000600
[17:34:14.301] Found seq 1
[17:34:14.301] Bound device spi@21000600 to soc
[17:34:14.301] bind node spi@21000800
[17:34:14.301] - attempt to match compatible string 'ti,dm6441-spi'
[17:34:14.317] - found match at 'davinci_spi'
[17:34:14.317] Looking for 'spi' at 18600, name spi@21000800
[17:34:14.317] - serial0, /soc/serial@02530c00
[17:34:14.317] - spi0, /soc/spi@21000400
[17:34:14.317] - spi1, /soc/spi@21000600
[17:34:14.338] - spi2, /soc/spi@21000800
[17:34:14.338] Found seq 2
[17:34:14.338] Bound device spi@21000800 to soc
[17:34:14.338] bind node usb_phy@2620738
[17:34:14.338] - attempt to match compatible string 'ti,keystone-usbphy'
[17:34:14.338] No match for node 'usb_phy@2620738'
[17:34:14.371] bind node usb@2680000
[17:34:14.371] - attempt to match compatible string 'ti,keystone-dwc3'
[17:34:14.371] No match for node 'usb@2680000'
[17:34:14.371] bind node wdt@022f0080
[17:34:14.371] - attempt to match compatible string 'ti,keystone-wdt'
[17:34:14.371] - attempt to match compatible string 'ti,davinci-wdt'
[17:34:14.371] No match for node 'wdt@022f0080'
[17:34:14.371] bind node timer@22f0000
[17:34:14.371] - attempt to match compatible string 'ti,keystone-timer'
[17:34:14.381] No match for node 'timer@22f0000'
[17:34:14.381] bind node gpio@260bf00
[17:34:14.381] - attempt to match compatible string 'ti,keystone-gpio'
[17:34:14.381] No match for node 'gpio@260bf00'
[17:34:14.397] bind node aemif@21000A00
[17:34:14.397] - attempt to match compatible string 'ti,keystone-aemif'
[17:34:14.397] - attempt to match compatible string 'ti,davinci-aemif'
[17:34:14.397] No match for node 'aemif@21000A00'
[17:34:14.414] bind node keystone_irq@26202a0
[17:34:14.414] - attempt to match compatible string 'ti,keystone-irq'
[17:34:14.414] No match for node 'keystone_irq@26202a0'
[17:34:14.414] - ignoring disabled device
[17:34:14.414] bind node keystone_dsp_gpio@02620240
[17:34:14.429] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.429] No match for node 'keystone_dsp_gpio@02620240'
[17:34:14.429] bind node keystone_dsp_gpio@2620244
[17:34:14.445] No match for node 'keystone_dsp_gpio@2620244'
[17:34:14.445] bind node keystone_dsp_gpio@2620248
[17:34:14.445] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.461] No match for node 'keystone_dsp_gpio@2620248'
[17:34:14.461] bind node keystone_dsp_gpio@262024c
[17:34:14.461] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.461] No match for node 'keystone_dsp_gpio@262024c'
[17:34:14.477] bind node keystone_dsp_gpio@2620250
[17:34:14.477] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.477] No match for node 'keystone_dsp_gpio@2620250'
[17:34:14.477] bind node keystone_dsp_gpio@2620254
[17:34:14.493] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.493] No match for node 'keystone_dsp_gpio@2620254'
[17:34:14.493] bind node keystone_dsp_gpio@2620258
[17:34:14.509] No match for node 'keystone_dsp_gpio@2620258'
[17:34:14.509] bind node keystone_dsp_gpio@262025c
[17:34:14.509] - attempt to match compatible string 'ti,keystone-dsp-gpio'
[17:34:14.525] No match for node 'keystone_dsp_gpio@262025c'
[17:34:14.525] - ignoring disabled device
[17:34:14.525] bind node rapidio@2900000
[17:34:14.525] - attempt to match compatible string 'ti,keystone-rapidio'
[17:34:14.541] - found match at 'rio_keystone'
[17:34:14.541] Bound device rapidio@2900000 to soc
[17:34:14.541] bind node qmss@2a40000
[17:34:14.541] - attempt to match compatible string 'ti,keystone-navigator-qmss'
[17:34:14.541] No match for node 'qmss@2a40000'
[17:34:14.557] bind node knav_dmas@0
[17:34:14.557] - attempt to match compatible string 'ti,keystone-navigator-dma'
[17:34:14.557] No match for node 'knav_dmas@0'
[17:34:14.557] bind node netcp@2000000
[17:34:14.573] - attempt to match compatible string 'ti,netcp-1.0'
[17:34:14.573] - found match at 'eth_ks2'
[17:34:14.573] Looking for 'eth' at 26120, name netcp@2000000
[17:34:14.573] - serial0, /soc/serial@02530c00
[17:34:14.573] - spi0, /soc/spi@21000400
[17:34:14.589] - spi1, /soc/spi@21000600
[17:34:14.589] - spi2, /soc/spi@21000800
[17:34:14.589] Not found
[17:34:14.589] Bound device netcp@2000000 to soc
[17:34:14.589] Bound device soc to root_driver
[17:34:14.589] bind node cpus
[17:34:14.605] Device 'cpus' has no compatible string
[17:34:14.605] bind node leds
[17:34:14.605] - attempt to match compatible string 'gpio-leds'
[17:34:14.605] No match for node 'leds'
[17:34:14.621] initcall: 0c00e17f (relocated to bff3217f)
[17:34:14.621] initcall: 0c002351 (relocated to bff26351)
[17:34:14.621] initcall: 0c03dabd (relocated to bff61abd)
[17:34:14.621] efi_add_memory_map: 0x80000000 0x40000 7 no
[17:34:14.637] efi_add_memory_map: 0x0 0x0 7 no
[17:34:14.637] efi_add_memory_map: 0xbcedb000 0x3125 2 no
[17:34:14.637] efi_add_memory_map: 0xbff8e000 0x1 5 no
[17:34:14.637] initcall: 0c014f35 (relocated to bff38f35)
[17:34:14.637] initcall: 0c00e175 (relocated to bff32175)
[17:34:14.653] uclass_find_device_by_seq: 0 -1
[17:34:14.653] uclass_find_device_by_seq: 0 0
[17:34:14.653] - -1 -1
[17:34:14.653] - not found
[17:34:14.669] - 0 -1
[17:34:14.669] - -1 -1
[17:34:14.669] - not found
[17:34:14.669] OF: ** translation for device serial@02530c00 **
[17:34:14.669] OF: bus is default (na=1, ns=1) on soc
[17:34:14.685] OF: translating address: 000c5302
[17:34:14.685] OF: parent bus is default (na=1, ns=1) on
[17:34:14.685] OF: no ranges, 1:1 translation
[17:34:14.701] OF: parent translation for: 00000000
[17:34:14.701] OF: with offset: 38996992
[17:34:14.701] OF: one level translation: 000c5302
[17:34:14.701] OF: reached root node
[17:34:14.701] fdtdec_get_int: reg-offset: (not found)
[17:34:14.701] fdtdec_get_int: reg-shift: 0x2 (2)
[17:34:14.717] fdtdec_get_int: clock-frequency: (not found)
[17:34:14.717] initcall: 0c00e161 (relocated to bff32161)
[17:34:14.717] Now running in RAM - U-Boot at: bff24000
[17:34:14.717] initcall: 0c00e0b9 (relocated to bff320b9)
[17:34:14.733] initcall: 0c00e14d (relocated to bff3214d)
[17:34:14.733] NAND: 512 MiB
[17:34:14.733] initcall: 0c00e105 (relocated to bff32105)
[17:34:14.733] fdtdec_get_config_int: load-environment
[17:34:14.733] *** Warning - bad CRC, using default environment
[17:34:15.134]
[17:34:15.134] Destroy Hash Table: bff8771c table = 00000000
[17:34:15.150] Create Hash Table: N=508
[17:34:15.150] DELETE CANDIDATE: "bootargs"
[17:34:15.150] hdelete: DELETE key "bootargs"
[17:34:15.150] DELETE ERROR ##############################
[17:34:15.150] INSERT: table bff8771c, filled 1/509 rv bdf2d628 ==> name="bootcmd" value="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern"
[17:34:15.182] INSERT: table bff8771c, filled 2/509 rv bdf2ee38 ==> name="bootdelay" value="2"
[17:34:15.182] INSERT: table bff8771c, filled 3/509 rv bdf2dd80 ==> name="baudrate" value="115200"
[17:34:15.198] INSERT: table bff8771c, filled 4/509 rv bdf2de5c ==> name="arch" value="arm"
[17:34:15.198] INSERT: table bff8771c, filled 5/509 rv bdf2e6e0 ==> name="cpu" value="armv7"
[17:34:15.214] INSERT: table bff8771c, filled 6/509 rv bdf2e460 ==> name="board" value="ks2_evm"
[17:34:15.214] INSERT: table bff8771c, filled 7/509 rv bdf2e26c ==> name="board_name" value="ks2_evm"
[17:34:15.230] INSERT: table bff8771c, filled 8/509 rv bdf2cc8c ==> name="vendor" value="ti"
[17:34:15.230] INSERT: table bff8771c, filled 9/509 rv bdf2e4c4 ==> name="soc" value="keystone"
[17:34:15.246] INSERT: table bff8771c, filled 10/509 rv bdf2ebf4 ==> name="loadaddr" value="0x82000000"
[17:34:15.262] INSERT: table bff8771c, filled 11/509 rv bdf2d90c ==> name="kernel_addr_r" value="0x82000000"
[17:34:15.262] INSERT: table bff8771c, filled 12/509 rv bdf2dfc4 ==> name="fdtaddr" value="0x88000000"
[17:34:15.278] INSERT: table bff8771c, filled 13/509 rv bdf2ea78 ==> name="fdt_addr_r" value="0x88000000"
[17:34:15.278] INSERT: table bff8771c, filled 14/509 rv bdf2d178 ==> name="rdaddr" value="0x88080000"
[17:34:15.294] INSERT: table bff8771c, filled 15/509 rv bdf2d060 ==> name="ramdisk_addr_r" value="0x88080000"
[17:34:15.294] INSERT: table bff8771c, filled 16/509 rv bdf2df88 ==> name="scriptaddr" value="0x80000000"
[17:34:15.310] INSERT: table bff8771c, filled 17/509 rv bdf2e474 ==> name="pxefile_addr_r" value="0x80100000"
[17:34:15.326] INSERT: table bff8771c, filled 18/509 rv bdf2d7e0 ==> name="bootm_size" value="0x10000000"
[17:34:15.326] INSERT: table bff8771c, filled 19/509 rv bdf2dce0 ==> name="boot_fdt" value="try"
[17:34:15.342] INSERT: table bff8771c, filled 20/509 rv bdf2d68c ==> name="name_fw_rd" value="k2-fw-initrd.cpio.gz"
[17:34:15.342] INSERT: table bff8771c, filled 21/509 rv bdf2cfd4 ==> name="set_rd_spec" value="setenv rd_spec ${rdaddr}:${filesize}"
[17:34:15.358] INSERT: table bff8771c, filled 22/509 rv bdf2da4c ==> name="init_fw_rd_net" value="dhcp ${rdaddr} ${tftp_root}/${name_fw_rd}; run set_rd_spec"
[17:34:15.374] INSERT: table bff8771c, filled 23/509 rv bdf2f2ac ==> name="init_fw_rd_nfs" value="nfs ${rdaddr} ${nfs_root}/boot/${name_fw_rd}; run set_rd_spec"
[17:34:15.390] INSERT: table bff8771c, filled 24/509 rv bdf2e348 ==> name="init_fw_rd_ramfs" value="setenv rd_spec -"
[17:34:15.390] INSERT: table bff8771c, filled 25/509 rv bdf2d3e4 ==> name="init_fw_rd_ubi" value="ubifsload ${rdaddr} ${bootdir}/${name_fw_rd}; run set_rd_spec"
[17:34:15.406] INSERT: table bff8771c, filled 26/509 rv bdf2f298 ==> name="boot" value="ubi"
[17:34:15.422] INSERT: table bff8771c, filled 27/509 rv bdf2eac8 ==> name="args_ubi" value="setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048"
[17:34:15.438] INSERT: table bff8771c, filled 28/509 rv bdf2d7b8 ==> name="name_fdt" value="keystone-k2hk-evm.dtb"
[17:34:15.438] INSERT: table bff8771c, filled 29/509 rv bdf2e3e8 ==> name="name_mon" value="skern-k2hk.bin"
[17:34:15.454] INSERT: table bff8771c, filled 30/509 rv bdf2d8d0 ==> name="name_ubi" value="k2hk-evm-ubifs.ubi"
[17:34:15.470] INSERT: table bff8771c, filled 31/509 rv bdf2e258 ==> name="name_uboot" value="u-boot-spi-k2hk-evm.gph"
[17:34:15.470] INSERT: table bff8771c, filled 32/509 rv bdf2e35c ==> name="name_fs" value="arago-console-image-k2hk-evm.cpio.gz"
[17:34:15.486] INSERT: table bff8771c, filled 33/509 rv bdf2e2a8 ==> name="bootdir" value="/boot"
[17:34:15.502] INSERT: table bff8771c, filled 34/509 rv bdf2d6b4 ==> name="tftp_root" value="/"
[17:34:15.502] INSERT: table bff8771c, filled 35/509 rv bdf2e410 ==> name="nfs_root" value="/export"
[17:34:15.518] INSERT: table bff8771c, filled 36/509 rv bdf2da60 ==> name="mem_lpae" value="1"
[17:34:15.518] INSERT: table bff8771c, filled 37/509 rv bdf2eaf0 ==> name="addr_ubi" value="0x82000000"
[17:34:15.534] INSERT: table bff8771c, filled 38/509 rv bdf2dbb4 ==> name="addr_secdb_key" value="0xc000000"
[17:34:15.534] INSERT: table bff8771c, filled 39/509 rv bdf2e294 ==> name="name_kern" value="zImage"
[17:34:15.550] INSERT: table bff8771c, filled 40/509 rv bdf2ea14 ==> name="addr_mon" value="0x87000000"
[17:34:15.550] INSERT: table bff8771c, filled 41/509 rv bdf2ece4 ==> name="addr_non_sec_mon" value="0x0c087fc0"
[17:34:15.566] INSERT: table bff8771c, filled 42/509 rv bdf2cc28 ==> name="addr_load_sec_bm" value="0x0c08c000"
[17:34:15.582] INSERT: table bff8771c, filled 43/509 rv bdf2cb60 ==> name="run_mon" value="mon_install ${addr_mon}"
[17:34:15.582] INSERT: table bff8771c, filled 44/509 rv bdf2d164 ==> name="run_mon_hs" value="mon_install ${addr_non_sec_mon} ${addr_load_sec_bm}"
[17:34:15.598] INSERT: table bff8771c, filled 45/509 rv bdf2d984 ==> name="run_kern" value="bootz ${loadaddr} ${rd_spec} ${fdtaddr}"
[17:34:15.613] INSERT: table bff8771c, filled 46/509 rv bdf2cf70 ==> name="init_net" value="run args_all args_net"
[17:34:15.613] INSERT: table bff8771c, filled 47/509 rv bdf2d074 ==> name="init_nfs" value="setenv autoload no; dhcp; run args_all args_net"
[17:34:15.630] INSERT: table bff8771c, filled 48/509 rv bdf2e884 ==> name="init_ubi" value="run args_all args_ubi; ubi part ubifs; ubifsmount ubi:rootfs;"
[17:34:15.646] INSERT: table bff8771c, filled 49/509 rv bdf2ec44 ==> name="get_fdt_net" value="dhcp ${fdtaddr} ${tftp_root}/${name_fdt}"
[17:34:15.662] INSERT: table bff8771c, filled 50/509 rv bdf2cd7c ==> name="get_fdt_nfs" value="nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt}"
[17:34:15.662] INSERT: table bff8771c, filled 51/509 rv bdf2e5dc ==> name="get_fdt_ubi" value="ubifsload ${fdtaddr} ${bootdir}/${name_fdt}"
[17:34:15.678] INSERT: table bff8771c, filled 52/509 rv bdf2ed20 ==> name="get_kern_net" value="dhcp ${loadaddr} ${tftp_root}/${name_kern}"
[17:34:15.694] INSERT: table bff8771c, filled 53/509 rv bdf2d600 ==> name="get_kern_nfs" value="nfs ${loadaddr} ${nfs_root}/boot/${name_kern}"
[17:34:15.710] INSERT: table bff8771c, filled 54/509 rv bdf2db8c ==> name="get_kern_ubi" value="ubifsload ${loadaddr} ${bootdir}/${name_kern}"
[17:34:15.710] INSERT: table bff8771c, filled 55/509 rv bdf2e500 ==> name="get_mon_net" value="dhcp ${addr_mon} ${tftp_root}/${name_mon}"
[17:34:15.725] INSERT: table bff8771c, filled 56/509 rv bdf2d894 ==> name="get_mon_nfs" value="nfs ${addr_mon} ${nfs_root}/boot/${name_mon}"
[17:34:15.742] INSERT: table bff8771c, filled 57/509 rv bdf2e640 ==> name="get_mon_ubi" value="ubifsload ${addr_mon} ${bootdir}/${name_mon}"
[17:34:15.758] INSERT: table bff8771c, filled 58/509 rv bdf2e85c ==> name="get_fit_net" value="dhcp ${fit_loadaddr} ${tftp_root}/${fit_bootfile}"
[17:34:15.773] INSERT: table bff8771c, filled 59/509 rv bdf2d538 ==> name="get_fit_nfs" value="nfs ${fit_loadaddr} ${nfs_root}/boot/${fit_bootfile}"
[17:34:15.773] INSERT: table bff8771c, filled 60/509 rv bdf2e9d8 ==> name="get_fit_ubi" value="ubifsload ${fit_loadaddr} ${bootdir}/${fit_bootfile}"
[17:34:15.790] INSERT: table bff8771c, filled 61/509 rv bdf2cc64 ==> name="get_fit_mmc" value="load mmc ${bootpart} ${fit_loadaddr} ${bootdir}/${fit_bootfile}"
[17:34:15.806] INSERT: table bff8771c, filled 62/509 rv bdf2eed8 ==> name="get_uboot_net" value="dhcp ${loadaddr} ${tftp_root}/${name_uboot}"
[17:34:15.821] INSERT: table bff8771c, filled 63/509 rv bdf2cebc ==> name="get_uboot_nfs" value="nfs ${loadaddr} ${nfs_root}/boot/${name_uboot}"
[17:34:15.837] INSERT: table bff8771c, filled 64/509 rv bdf2d038 ==> name="burn_uboot_spi" value="sf probe; sf erase 0 0x90000; sf write ${loadaddr} 0 ${filesize}"
[17:34:15.837] INSERT: table bff8771c, filled 65/509 rv bdf2ed5c ==> name="burn_uboot_nand" value="nand erase 0 0x100000; nand write ${loadaddr} 0 ${filesize}"
[17:34:15.854] INSERT: table bff8771c, filled 66/509 rv bdf2d7cc ==> name="args_all" value="setenv bootargs console=ttyS0,115200n8 rootwait=1"
[17:34:15.870] INSERT: table bff8771c, filled 67/509 rv bdf2d1b4 ==> name="args_net" value="setenv bootargs ${bootargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp"
[17:34:15.885] INSERT: table bff8771c, filled 68/509 rv bdf2eff0 ==> name="nfs_options" value="v3,tcp,rsize=4096,wsize=4096"
[17:34:15.902] INSERT: table bff8771c, filled 69/509 rv bdf2d678 ==> name="get_fdt_ramfs" value="dhcp ${fdtaddr} ${tftp_root}/${name_fdt}"
[17:34:15.918] INSERT: table bff8771c, filled 70/509 rv bdf2e118 ==> name="get_kern_ramfs" value="dhcp ${loadaddr} ${tftp_root}/${name_kern}"
[17:34:15.918] INSERT: table bff8771c, filled 71/509 rv bdf2d9d4 ==> name="get_mon_ramfs" value="dhcp ${addr_mon} ${tftp_root}/${name_mon}"
[17:34:15.934] INSERT: table bff8771c, filled 72/509 rv bdf2e104 ==> name="get_fit_ramfs" value="dhcp ${fit_loadaddr} ${tftp_root}/${fit_bootfile}"
[17:34:15.950] INSERT: table bff8771c, filled 73/509 rv bdf2cb10 ==> name="get_fs_ramfs" value="dhcp ${rdaddr} ${tftp_root}/${name_fs}"
[17:34:15.965] INSERT: table bff8771c, filled 74/509 rv bdf2ee24 ==> name="get_ubi_net" value="dhcp ${addr_ubi} ${tftp_root}/${name_ubi}"
[17:34:15.965] INSERT: table bff8771c, filled 75/509 rv bdf2e99c ==> name="get_ubi_nfs" value="nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi}"
[17:34:15.981] INSERT: table bff8771c, filled 76/509 rv bdf2d2a4 ==> name="burn_ubi" value="nand erase.part ubifs; nand write ${addr_ubi} ubifs ${filesize}"
[17:34:15.998] INSERT: table bff8771c, filled 77/509 rv bdf2cffc ==> name="init_ramfs" value="run args_all args_ramfs get_fs_ramfs"
[17:34:16.014] INSERT: table bff8771c, filled 78/509 rv bdf2d240 ==> name="args_ramfs" value="setenv bootargs ${bootargs} rdinit=/sbin/init rw root=/dev/ram0 initrd=0x808080000,80M"
[17:34:16.030] INSERT: table bff8771c, filled 79/509 rv bdf2e4ec ==> name="no_post" value="1"
[17:34:16.030] INSERT: table bff8771c, filled 80/509 rv bdf2d588 ==> name="mtdparts" value="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)"
[17:34:16.045] INSERT: free(data = bdf2bd08)
[17:34:16.045] INSERT: done
[17:34:16.045] Initial value for argc=3
[17:34:16.062] Final value for argc=3
[17:34:16.062] initcall: 0c00e205 (relocated to bff32205)
[17:34:16.062] initcall: 0c014f49 (relocated to bff38f49)
[17:34:16.062] initcall: 0c00e0fb (relocated to bff320fb)
[17:34:16.129] initcall: 0c0130f9 (relocated to bff370f9)
[17:34:16.129] Initial value for argc=3
[17:34:16.129] Final value for argc=3
[17:34:16.142] Initial value for argc=3
[17:34:16.142] Final value for argc=3
[17:34:16.142] initcall: 0c002231 (relocated to bff26231)
[17:34:16.142] initcall: 0c000c89 (relocated to bff24c89)
[17:34:16.142] initcall: 0c00e0f1 (relocated to bff320f1)
[17:34:16.157] initcall: 0c00e0d9 (relocated to bff320d9)
[17:34:16.157] initcall: 0c00e0c5 (relocated to bff320c5)
[17:34:16.157] Net: uclass_find_device_by_seq: 0 -1
[17:34:16.157] uclass_find_device_by_seq: 0 0
[17:34:16.177] - -1 -1
[17:34:16.177] - not found
[17:34:16.177] fdtdec_get_int: slave-port: 0x0 (0)
[17:34:16.177] fdtdec_get_int: slave-port: 0x1 (1)
[17:34:16.177] Looking for 'eth' at 26720, name interface-1
[17:34:16.177] - serial0, /soc/serial@02530c00
[17:34:16.189] - spi0, /soc/spi@21000400
[17:34:16.189] - spi1, /soc/spi@21000600
[17:34:16.189] - spi2, /soc/spi@21000800
[17:34:16.189] Not found
[17:34:16.189] Bound device netcp@slave-1 to netcp@2000000
[17:34:16.189] fdtdec_get_int: slave-port: 0x2 (2)
[17:34:16.205] Looking for 'eth' at 26852, name port-2
[17:34:16.205] - serial0, /soc/serial@02530c00
[17:34:16.205] - spi0, /soc/spi@21000400
[17:34:16.205] - spi1, /soc/spi@21000600
[17:34:16.205] - spi2, /soc/spi@21000800
[17:34:16.205] Not found
[17:34:16.221] Bound device netcp@slave-2 to netcp@2000000
[17:34:16.221] fdtdec_get_int: slave-port: 0x3 (3)
[17:34:16.221] Looking for 'eth' at 26900, name port-3
[17:34:16.221] - serial0, /soc/serial@02530c00
[17:34:16.221] - spi0, /soc/spi@21000400
[17:34:16.238] - spi1, /soc/spi@21000600
[17:34:16.238] - spi2, /soc/spi@21000800
[17:34:16.238] Not found
[17:34:16.238] Bound device netcp@slave-3 to netcp@2000000
[17:34:16.238] fdtdec_get_int: slave-port: 0x0 (0)
[17:34:16.238] fdtdec_get_int_array_count: ti,navigator-dmas
[17:34:16.253] fdtdec_get_int: link-interface: 0x0 (0)
[17:34:16.253] fdtdec_lookup_phandle: phy-handle
[17:34:16.253] fdtdec_get_int: reg: 0x0 (0)
[17:34:16.285] fdtdec_get_addr_size_fixed: reg: addr=02090300
[17:34:16.302] OF: ** translation for device netcp@2000000 **
[17:34:16.302] OF: bus is default (na=1, ns=1) on soc
[17:34:16.317] OF: translating address: 10016202
[17:34:16.317] OF: parent bus is default (na=1, ns=1) on
[17:34:16.334] OF: no ranges, 1:1 translation
[17:34:16.334] OF: parent translation for: 00000000
[17:34:16.334] OF: with offset: 39977232
[17:34:16.334] OF: one level translation: 10016202
[17:34:16.334] OF: reached root node
[17:34:16.334] Initial value for argc=3
[17:34:16.350] Final value for argc=3
[17:34:16.350] uclass_find_device_by_seq: 0 0
[17:34:16.350] - -1 0
[17:34:16.350] - found
[17:34:16.350]
[17:34:16.350] Warning: netcp@2000000 using MAC address from ROM
[17:34:16.366] eth0: netcp@2000000uclass_find_device_by_seq: 0 -1
[17:34:16.366] uclass_find_device_by_seq: 0 0
[17:34:16.366] - -1 0
[17:34:16.366] - found
[17:34:16.366] uclass_find_device_by_seq: 0 1
[17:34:16.366] - -1 -1
[17:34:16.382] - -1 -1
[17:34:16.382] - not found
[17:34:16.382] fdtdec_get_int: slave-port: 0x1 (1)
[17:34:16.429] fdtdec_get_int_array_count: ti,navigator-dmas
[17:34:16.445] fdtdec_get_int: link-interface: 0x0 (0)
[17:34:16.445] fdtdec_lookup_phandle: phy-handle
[17:34:16.445] fdtdec_get_int: reg: 0x1 (1)
[17:34:16.479] fdtdec_get_addr_size_fixed: reg: addr=02090300
[17:34:16.494] fdtdec_get_addr_size_fixed: reg: addr=02620110
[17:34:16.494]
[17:34:16.494] Warning: netcp@slave-1 (eth1) using random MAC address - b6:93:c0:cf:56:2e
[17:34:16.512] , eth1: netcp@slave-1uclass_find_device_by_seq: 0 -1
[17:34:16.512] uclass_find_device_by_seq: 0 0
[17:34:16.512] - -1 0
[17:34:16.512] - found
[17:34:16.512] uclass_find_device_by_seq: 0 1
[17:34:16.512] - -1 1
[17:34:16.526] - found
[17:34:16.526] uclass_find_device_by_seq: 0 2
[17:34:16.526] - -1 0
[17:34:16.526] - -1 1
[17:34:16.526] - -1 -1
[17:34:16.526] - not found
[17:34:16.526] fdtdec_get_int: slave-port: 0x2 (2)
[17:34:16.589] fdtdec_get_int_array_count: ti,navigator-dmas
[17:34:16.589] fdtdec_get_int: link-interface: 0x2 (2)
[17:34:16.589] fdtdec_lookup_phandle: phy-handle
[17:34:16.589] fdtdec_get_addr_size_fixed: reg: addr=02620110
[17:34:16.606]
[17:34:16.606] Warning: netcp@slave-2 (eth2) using random MAC address - 92:85:c8:f5:c6:cc
[17:34:16.606] , eth2: netcp@slave-2uclass_find_device_by_seq: 0 -1
[17:34:16.621] uclass_find_device_by_seq: 0 0
[17:34:16.621] - -1 0
[17:34:16.621] - found
[17:34:16.621] uclass_find_device_by_seq: 0 1
[17:34:16.621] - -1 1
[17:34:16.621] uclass_find_device_by_seq: 0 2
[17:34:16.637] - -1 0
[17:34:16.637] - -1 1
[17:34:16.637] - -1 2
[17:34:16.637] - found
[17:34:16.637] uclass_find_device_by_seq: 0 3
[17:34:16.637] - -1 -1
[17:34:16.637] - not found
[17:34:16.637] fdtdec_get_int: slave-port: 0x3 (3)
[17:34:16.702] fdtdec_get_int_array_count: ti,navigator-dmas
[17:34:16.702] fdtdec_get_int: link-interface: 0x2 (2)
[17:34:16.702] fdtdec_lookup_phandle: phy-handle
[17:34:16.717] fdtdec_get_addr_size_fixed: reg: addr=02620110
[17:34:16.717]
[17:34:16.717] Warning: netcp@slave-3 (eth3) using random MAC address - 6a:4c:2e:bb:75:4a
[17:34:16.733] , eth3: netcp@slave-3
[17:34:16.733] initcall: 0c00e0bd (relocated to bff320bd)
[17:34:16.733] Initial value for argc=3
[17:34:16.733] Final value for argc=3
[17:34:16.733] fdtdec_get_config_int: bootdelay
[17:34:16.733] ### main_loop entered: bootdelay=2
[17:34:16.750]
[17:34:16.750] fdtdec_get_config_int: kernel-offset
[17:34:16.750] fdtdec_get_config_int: rootdisk-offset
[17:34:16.766] fdtdec_get_config_string: bootcmd
[17:34:16.781] fdtdec_get_config_int: bootsecure
[17:34:16.781] ### main_loop: bootcmd="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern"
[17:34:16.798] Hit any key to stop autoboot: 2 0
Q1 The ddr3 is not recognized correctly. I use 4 K4B4G1646 chip,ddr3 should be 2GiByte.The printed information show just 1GiByte.
Should I change which parts of the u-boot code to configure DDR3A?
Q2 When I input DHCP in uboot console , console show :
[17:34:17.773] =>
[17:34:17.773] =>
[17:34:17.773] =>
[17:34:17.773] =>
[17:34:18.269] =>
[17:34:18.269] =>
[17:34:18.269] =>
[17:34:18.269] => dhcpdhcp
[17:34:34.669] Unknown command 'dhcpdhcp' - try 'help'
[17:34:34.685] =>
[17:34:34.685] Unknown command 'dhcpdhcp' - try 'help'
[17:34:34.685] => dhcp
[17:34:37.565] Initial value for argc=3
[17:34:37.565] Final value for argc=3
[17:34:37.565] Trying netcp@2000000
[17:34:37.565]
[17:34:37.565] <NULL> Waiting for SGMII auto negotiation to complete. done
[17:34:37.581] BOOTP broadcast 1
[17:34:37.581] data abort
[17:34:37.597] pc : [<bff4be24>] lr : [<bff4b3ab>]
[17:34:37.597] reloc pc : [<0c027e24>] lr : [<0c0273ab>]
[17:34:37.597] sp : bdedb8e0 ip : 000000ff fp : bffed1d0
[17:34:37.597] r10: bffed1ec r9 : bdee3ee0 r8 : 0000000e
[17:34:37.597] r7 : 0000012c r6 : 00000156 r5 : bffed6c0 r4 : 00000000
[17:34:37.613] r3 : 00000001 r2 : ffffffff r1 : e59ff098 r0 : ea000047
[17:34:37.613] Flags: nzCv IRQs off FIQs off Mode SVC_32
[17:34:37.613] Resetting CPU ...
[17:34:37.613]
[17:34:37.613] resetting ...
[17:34:37.725]
I don't kown Why ?
please help me .
