Part Number: TMDSEVM572X
Hi, I am working with AM527x EVM. Recently, I have observed that every time I power-up the evm, within a couple of minutes, the processor gets hot and thermal shutdown is triggered.
root@am57xx-evm:~# omapconf show temp
OMAPCONF (rev v1.73 built Wed Jun 28 18:45:28 EDT 2017)
HW Platform:
Generic DRA74X (Flattened Device Tree)
DRA75X ES2.0 GP Device (STANDARD performance (1.0GHz))
TPS659038 ES2.2
SW Build Details:
Build:
Version: _____ _____ _ _
Kernel:
Version: 4.9.28-geed43d1050
Author: gtbldadm@ubuntu-16
Toolchain: gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11)
Type: #2 SMP PREEMPT
Date: Wed Jun 28 18:16:59 EDT 2017
| Sensor | Temperature (C) | Temperature (F) |
| MPU | 91 | 195 |
| GPU | 82 | 179 |
| CORE | 81 | 177 |
| IVA | 83 | 181 |
| DSPEVE | 83 | 181 |
I tried loading SD card with the default evm image from link below but that also has same result.
I also tried just powering the evm ON and halting the autoboot from u-boot, but that too makes the processor very hot. It seems like a hardware issue. Is there any way I can fix it?
HW Platform:
TPS659038 ES2.2
SW Build Details:
Build:
Kernel:
| MPU | 91 | 195 |
| GPU | 82 | 179 |
| CORE | 81 | 177 |
| IVA | 82 | 179 |
| DSPEVE | 82 | 179 |
omapconf: powerdm_deinit(): cpu not supported!!!
omapconf: clockdm_deinit(): cpu not supported!!!
root@am57xx-evm:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.28-geed43d1050 (gtbldadm@ubuntu-16) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #2 SMP PREEMPT Wed Jun 28 18:16:59 EDT 2017
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt:Machine model: TI AM572x EVM Rev A3
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] On node 0 totalpages: 474368
[ 0.000000] free_area_init_node: node 0, pgdat c104bc00, node_mem_map eeda2000
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 147456 pages, LIFO batch:31
[ 0.000000] HighMem zone: 326912 pages, LIFO batch:31
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 13 pages/cpu @eed34000 s22092 r8192 d22964 u53248
[ 0.000000] pcpu-alloc: s22092 r8192 d22964 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=50e41a45-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1675680K/1897472K available (8192K kernel code, 314K rwdata, 2492K rodata, 2048K init, 296K bss, 33376K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0a00000 (10208 kB)
.init : 0xc0e00000 - 0xc1000000 (2048 kB)
.data : 0xc1000000 - 0xc104e860 ( 315 kB)
.bss : 0xc1050000 - 0xc109a130 ( 297 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000017] Switching to timer-based delay loop, resolution 162ns
[ 0.000316] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000324] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000735] Console: colour dummy device 80x30
[ 0.000752] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000760] This ensures that you still see kernel messages. Please
[ 0.000766] update your kernel commandline.
[ 0.000783] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000796] pid_max: default: 32768 minimum: 301
[ 0.000896] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000907] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001524] CPU: Testing write buffer coherency: ok
[ 0.001735] /cpus/cpu@0 missing clock-frequency property
[ 0.001752] /cpus/cpu@1 missing clock-frequency property
[ 0.001763] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001779] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.080072] EFI services will not be available.
[ 0.170316] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.170403] Brought up 2 CPUs
[ 0.170416] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.170424] CPU: All CPU(s) started in HYP mode.
[ 0.170430] CPU: Virtualization extensions available.
[ 0.170932] devtmpfs: initialized
[ 0.198311] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.198545] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.198561] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.201923] pinctrl core: initialized pinctrl subsystem
[ 0.202725] NET: Registered protocol family 16
[ 0.203580] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.204568] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.314274] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.440380] cpuidle: using governor ladder
[ 0.470404] cpuidle: using governor menu
[ 0.478413] gpio gpiochip0: (gpio): added GPIO chardev (254:0)
[ 0.478641] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio)
[ 0.480104] OMAP GPIO hardware version 0.1
[ 0.480814] gpio gpiochip1: (gpio): added GPIO chardev (254:1)
[ 0.481031] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio)
[ 0.482821] gpio gpiochip2: (gpio): added GPIO chardev (254:2)
[ 0.483027] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio)
[ 0.484846] gpio gpiochip3: (gpio): added GPIO chardev (254:3)
[ 0.485054] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio)
[ 0.486802] gpio gpiochip4: (gpio): added GPIO chardev (254:4)
[ 0.487007] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio)
[ 0.488786] gpio gpiochip5: (gpio): added GPIO chardev (254:5)
[ 0.488993] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio)
[ 0.490814] gpio gpiochip6: (gpio): added GPIO chardev (254:6)
[ 0.491028] gpiochip_setup_dev: registered GPIOs 192 to 223 on device: gpiochip6 (gpio)
[ 0.492806] gpio gpiochip7: (gpio): added GPIO chardev (254:7)
[ 0.493011] gpiochip_setup_dev: registered GPIOs 224 to 255 on device: gpiochip7 (gpio)
[ 0.494577] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.521019] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.521030] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.521380] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.521390] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.521923] OMAP DMA hardware revision 0.0
[ 0.561637] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.562934] edma 43300000.edma: memcpy is disabled
[ 0.567716] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.568087] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vdd_3v3[0]'
[ 0.568360] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-aic_dvdd[0]'
[ 0.568701] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[ 0.569075] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0)
[ 0.572159] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.572330] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.572478] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.572629] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.572890] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.573063] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.575684] palmas 0-0058: Irq flag is 0x00000008
[ 0.603307] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.607143] vtt_fixed: supplied by smps3
[ 0.641360] random: fast init done
[ 0.682440] vdd_3v3: supplied by regen1
[ 0.682662] aic_dvdd_fixed: supplied by vdd_3v3
[ 0.685060] gpiochip_find_base: found new base at 504
[ 0.685077] gpio gpiochip8: (48070000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8)
[ 0.685305] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip8 (48070000.i2c:tps659038@58:tps659038_gpio)
[ 0.685833] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.686330] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.686905] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.687097] media: Linux media interface: v0.10
[ 0.687143] Linux video capture interface: v2.00
[ 0.687178] pps_core: LinuxPPS API ver. 1 registered
[ 0.687186] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.687206] PTP clock support registered
[ 0.687243] EDAC MC: Ver: 3.0.0
[ 0.687927] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[ 0.688225] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[ 0.688504] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.688786] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.689124] Advanced Linux Sound Architecture Driver Initialized.
[ 0.689940] clocksource: Switched to clocksource arch_sys_counter
[ 0.700684] NET: Registered protocol family 2
[ 0.701180] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.701243] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.701368] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.701414] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.701445] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.701574] NET: Registered protocol family 1
[ 0.701935] RPC: Registered named UNIX socket transport module.
[ 0.701945] RPC: Registered udp transport module.
[ 0.701952] RPC: Registered tcp transport module.
[ 0.701958] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.701968] PCI: CLS 0 bytes, default 64
[ 0.702867] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.705781] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.713323] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.714028] NFS: Registering the id_resolver key type
[ 0.714056] Key type id_resolver registered
[ 0.714064] Key type id_legacy registered
[ 0.714105] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.715264] bounce: pool size: 64 pages
[ 0.715407] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.715418] io scheduler noop registered
[ 0.715426] io scheduler deadline registered
[ 0.715551] io scheduler cfq registered (default)
[ 0.719912] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.720451] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.723699] dra7-pcie 51000000.pcie: GPIO lookup for consumer (null)
[ 0.723707] dra7-pcie 51000000.pcie: using device tree for GPIO lookup
[ 0.723734] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ocp/axi@0/pcie@51000000[0]' - status (0)
[ 0.723854] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.723866] OF: PCI: No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
[ 0.723898] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.723919] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.725320] dra7-pcie 51000000.pcie: phy link never came up
[ 1.725491] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.725504] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.725515] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.725526] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.725560] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[ 1.725583] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 1.725596] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 1.725664] pci 0000:00:00.0: supports D1
[ 1.725671] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.725898] PCI: bus0: Fast back to back transfers disabled
[ 1.726017] PCI: bus1: Fast back to back transfers enabled
[ 1.726135] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 1.726150] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 1.726164] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.726387] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.726401] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 1.726528] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 1.727357] pwm-backlight backlight: GPIO lookup for consumer enable
[ 1.727364] pwm-backlight backlight: using device tree for GPIO lookup
[ 1.727372] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[ 1.727380] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[ 1.727386] pwm-backlight backlight: using lookup tables for GPIO lookup
[ 1.727394] pwm-backlight backlight: lookup for GPIO enable failed
[ 1.727424] backlight supply power not found, using dummy regulator
[ 1.789601] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.792945] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
[ 2.761594] console [ttyS2] enabled
[ 2.765930] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 302, base_baud = 3000000) is a 8250
[ 2.776682] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 2.783461] [drm] Initialized
[ 2.788345] OMAP DSS rev 6.1
[ 2.791727] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.800165] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.809026] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 2.809033] tpd12s015 encoder: using device tree for GPIO lookup
[ 2.809059] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[0]' - status (0)
[ 2.809074] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 2.809080] tpd12s015 encoder: using device tree for GPIO lookup
[ 2.809114] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[1]' - status (0)
[ 2.809125] tpd12s015 encoder: GPIO lookup for consumer (null)
[ 2.809131] tpd12s015 encoder: using device tree for GPIO lookup
[ 2.809178] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[2]' - status (0)
[ 2.809816] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/connector[0]'
[ 2.810131] panel-dpi display: GPIO lookup for consumer enable
[ 2.810137] panel-dpi display: using device tree for GPIO lookup
[ 2.810162] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/display[0]' - status (0)
[ 2.810174] panel-dpi display: GPIO lookup for consumer reset
[ 2.810180] panel-dpi display: using device tree for GPIO lookup
[ 2.810187] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/display[0]'
[ 2.810194] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/display[0]'
[ 2.810199] panel-dpi display: using lookup tables for GPIO lookup
[ 2.810206] panel-dpi display: lookup for GPIO reset failed
[ 2.810236] display supply vcc not found, using dummy regulator
[ 2.847079] brd: module loaded
[ 2.855369] loop: module loaded
[ 2.859084] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[ 2.868763] libphy: Fixed MDIO Bus: probed
[ 2.929967] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 2.936093] libphy: 48485000.mdio: probed
[ 2.954625] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 2.964367] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[ 2.974566] cpsw 48484000.ethernet: Detected MACID = a4:d5:78:c4:e1:42
[ 2.981253] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.989526] cpsw 48484000.ethernet: cpsw: Detected MACID = a4:d5:78:c4:e1:43
[ 2.997925] mousedev: PS/2 mouse device common for all mice
[ 3.003849] i2c /dev entries driver
[ 3.008965] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_fan[0]' - status (0)
[ 3.010215] gpio-fan gpio_fan: GPIO fan initialized
[ 3.016447] tmp102 0-0048: initialized
[ 3.025255] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
[ 3.025262] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[ 3.025289] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@4809c000[0]' - status (0)
[ 3.025324] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 3.030023] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
[ 3.030029] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[ 3.030038] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[ 3.030067] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[ 3.030074] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[ 3.030081] omap_hsmmc 4809c000.mmc: lookup for GPIO wp failed
[ 3.100132] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer cd
[ 3.100137] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[ 3.100143] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480b4000[0]'
[ 3.100147] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480b4000[0]'
[ 3.100151] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[ 3.100156] omap_hsmmc 480b4000.mmc: lookup for GPIO cd failed
[ 3.100161] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer wp
[ 3.100165] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[ 3.100170] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]'
[ 3.100174] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]'
[ 3.100178] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[ 3.100183] omap_hsmmc 480b4000.mmc: lookup for GPIO wp failed
[ 3.100297] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 3.106679] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 3.190167] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer cd
[ 3.190171] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[ 3.190177] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480ad000[0]'
[ 3.190182] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480ad000[0]'
[ 3.190185] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[ 3.190190] omap_hsmmc 480ad000.mmc: lookup for GPIO cd failed
[ 3.190195] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer wp
[ 3.190199] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[ 3.190204] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480ad000[0]'
[ 3.190208] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480ad000[0]'
[ 3.190212] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[ 3.190216] omap_hsmmc 480ad000.mmc: lookup for GPIO wp failed
[ 3.250246] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led0[0]' - status (0)
[ 3.250334] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0)
[ 3.250410] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0)
[ 3.250491] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led3[0]' - status (0)
[ 3.250842] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.261515] NET: Registered protocol family 10
[ 3.276652] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.283004] NET: Registered protocol family 17
[ 3.287603] Key type dns_resolver registered
[ 3.291992] omap_voltage_late_init: Voltage driver support not added
[ 3.298439] Power Management for TI OMAP4+ devices.
[ 3.303540] Registering SWP/SWPB emulation handler
[ 3.317458] dmm 4e000000.dmm: initialized all PAT entries
[ 3.351013] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.357656] [drm] No driver support for vblank timestamp query.
[ 3.365635] [drm] Enabling DMM ywrap scrolling
[ 3.391792] mmc1: new DDR MMC card at address 0001
[ 3.392122] mmcblk1: mmc1:0001 S10004 3.56 GiB
[ 3.392256] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[ 3.392382] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[ 3.392910] mmcblk1: p1 p2 p3
[ 3.407651] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.438622] Console: switching to colour frame buffer device 100x30
[ 3.440469] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[ 3.445427] mmcblk0: mmc0:59b4 USD00 14.7 GiB
[ 3.449893] mmcblk0: p1 p2
[ 3.493262] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 3.532477] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER1[0]' - status (0)
[ 3.532504] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER2[0]' - status (0)
[ 3.532528] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER3[0]' - status (0)
[ 3.532552] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER4[0]' - status (0)
[ 3.532575] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER5[0]' - status (0)
[ 3.533195] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 3.540181] hctosys: unable to open rtc device (rtc0)
[ 3.545791] aic_dvdd_fixed: disabling
[ 3.549470] vmmcwl_fixed: disabling
[ 3.553162] ldousb: disabling
[ 3.556419] ALSA device list:
[ 3.559397] No soundcards found.
[ 3.652631] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.660804] VFS: Mounted root (ext4 filesystem) on device 179:50.
[ 3.669677] devtmpfs: mounted
[ 3.673782] Freeing unused kernel memory: 2048K (c0e00000 - c1000000)
[ 3.848291] systemd[1]: System time before build time, advancing clock.
[ 3.890032] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.908460] systemd[1]: Detected architecture arm.
[ 3.940475] systemd[1]: Set hostname to <am57xx-evm>.
[ 3.949672] systemd[1]: Initializing machine ID from random generator.
[ 4.332763] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 4.340605] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 4.348305] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 4.355609] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 4.363081] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
[ 4.370293] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 4.792720] cmemk: loading out-of-tree module taints kernel.
[ 4.799092] CMEMK module: reference Linux version 4.9.28
[ 4.805104] allocated heap buffer 0x40500000 of size 0x100000
[ 4.813590] cmemk initialized
[ 4.825274] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.830972] cryptodev: driver 1.8 loaded.
[ 6.062748] systemd-journald[129]: Received request to flush runtime journal from PID 1
[ 7.251739] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ 7.259612] remoteproc remoteproc0: 58820000.ipu is available
[ 7.289422] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 7.321653] remoteproc remoteproc1: 55020000.ipu is available
[ 7.328970] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 7.340629] remoteproc remoteproc2: 40800000.dsp is available
[ 7.350158] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 7.380798] remoteproc remoteproc3: 41000000.dsp is available
[ 7.463799] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@48070000/tlv320aic3104@18[0]'
[ 7.530807] rtc rtc1: 48070000.i2c:tps659: dev (253:1)
[ 7.530818] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
[ 7.544876] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 7.561413] omap-des 480a5000.des: will run requests pump with realtime priority
[ 7.570522] rtc-ds1307 2-006f: SET TIME!
[ 7.571134] rtc-ds1307 2-006f: read: 80 00 00 09 01 01 01
[ 7.571140] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=0
[ 7.571750] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[ 7.571756] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[ 7.572110] rtc-ds1307 2-006f: mcp794xx_read_alarm, sec=0 min=0 hour=0 wday=0 mday=1 mon=0 enabled=0 polarity=0 irq=0 match=0
[ 7.572403] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[ 7.572409] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[ 7.572414] rtc rtc0: alarm rollover: year
[ 7.572704] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[ 7.572709] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[ 7.572876] rtc rtc0: mcp7941x: dev (253:0)
[ 7.572888] rtc-ds1307 2-006f: rtc core: registered mcp7941x as rtc0
[ 7.583643] pixcir_ts 4-005c: GPIO lookup for consumer attb
[ 7.583647] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 7.583654] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583673] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[ 7.583685] pixcir_ts 4-005c: GPIO lookup for consumer reset
[ 7.583689] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 7.583695] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583709] of_get_named_gpiod_flags: parsed 'reset-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[ 7.583720] pixcir_ts 4-005c: GPIO lookup for consumer wake
[ 7.583723] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 7.583728] of_get_named_gpiod_flags: can't parse 'wake-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583732] of_get_named_gpiod_flags: can't parse 'wake-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583736] pixcir_ts 4-005c: using lookup tables for GPIO lookup
[ 7.583741] pixcir_ts 4-005c: lookup for GPIO wake failed
[ 7.583744] pixcir_ts 4-005c: GPIO lookup for consumer enable
[ 7.583748] pixcir_ts 4-005c: using device tree for GPIO lookup
[ 7.583753] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583757] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[ 7.583760] pixcir_ts 4-005c: using lookup tables for GPIO lookup
[ 7.583763] pixcir_ts 4-005c: lookup for GPIO enable failed
[ 7.587201] rtc-ds1307 2-006f: got IRQ 472
[ 7.587216] rtc-ds1307 2-006f: 64 bytes nvram
[ 7.598628] remoteproc remoteproc1: powering up 55020000.ipu
[ 7.598638] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743164
[ 7.598708] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 7.682866] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[ 7.682874] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 7.682882] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 7.682888] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 7.682893] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[ 7.682898] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: lookup for GPIO id failed
[ 7.682903] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[ 7.682907] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 7.682912] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 7.682970] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0)
[ 7.702327] rtc rtc2: 48838000.rtc: dev (253:2)
[ 7.702337] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
[ 7.732502] pixcir_ts 4-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
[ 7.732506] pixcir_ts 4-005c: Failed to set IDLE mode
[ 7.732591] pixcir_ts: probe of 4-005c failed with error -121
[ 7.732684] mt9t11x 4-003c: input-clock-freq: 32000000
[ 7.732690] mt9t11x 4-003c: pixel-clock-freq: 96000000
[ 7.732696] mt9t11x 4-003c: GPIO lookup for consumer reset
[ 7.732700] mt9t11x 4-003c: using device tree for GPIO lookup
[ 7.732764] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 7.732777] mt9t11x 4-003c: GPIO lookup for consumer powerdown
[ 7.732779] mt9t11x 4-003c: using device tree for GPIO lookup
[ 7.732796] of_get_named_gpiod_flags: parsed 'powerdown-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 7.732805] mt9t11x 4-003c: GPIO lookup for consumer oscen
[ 7.732809] mt9t11x 4-003c: using device tree for GPIO lookup
[ 7.732823] of_get_named_gpiod_flags: parsed 'oscen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 7.732832] mt9t11x 4-003c: GPIO lookup for consumer bufen
[ 7.732835] mt9t11x 4-003c: using device tree for GPIO lookup
[ 7.732849] of_get_named_gpiod_flags: parsed 'bufen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 7.732857] mt9t11x 4-003c: GPIO lookup for consumer camen
[ 7.732860] mt9t11x 4-003c: using device tree for GPIO lookup
[ 7.732874] of_get_named_gpiod_flags: parsed 'camen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[ 7.763156] mt9t11x 4-003c: Product ID error ffffff87
[ 7.800379] remoteproc remoteproc0: powering up 58820000.ipu
[ 7.800392] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4872056
[ 7.800470] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 7.800688] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 7.800706] remoteproc remoteproc1: registered virtio0 (type 7)
[ 7.800710] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 7.804106] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 7.805205] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x66
[ 7.810962] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 7.810983] remoteproc remoteproc0: registered virtio1 (type 7)
[ 7.810989] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 7.817961] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x32
[ 7.818084] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x33
[ 7.818286] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 7.818445] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 8.016703] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 8.141216] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 8.150913] vpe 489d0000.vpe: Device registered as /dev/video0
[ 8.170025] vip 48990000.vip: VPDMA firmware loaded
[ 8.415317] SCSI subsystem initialized
[ 8.464939] libata version 3.00 loaded.
[ 8.467498] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 8.513862] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 8.524613] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 8.534061] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 8.560275] scsi host0: ahci
[ 8.565183] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 346
[ 8.580421] remoteproc remoteproc2: powering up 40800000.dsp
[ 8.580430] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21891524
[ 8.587044] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 8.587073] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 8.587110] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 8.631046] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 8.637555] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.637578] remoteproc remoteproc2: registered virtio2 (type 7)
[ 8.637581] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 8.638263] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 8.726445] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 8.745211] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 8.757626] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 8.770798] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 8.820272] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 8.826453] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 8.883805] FAT-fs (mmcblk1p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.895898] FAT-fs (mmcblk1p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.897041] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.967269] remoteproc remoteproc3: powering up 41000000.dsp
[ 8.974138] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 21891524
[ 9.001262] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound0[0]'
[ 9.001267] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound0[0]'
[ 9.019759] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 9.025647] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 9.031562] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 9.039821] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 9.052663] ata1: SATA link down (SStatus 0 SControl 300)
[ 9.060181] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 9.060197] remoteproc remoteproc3: registered virtio3 (type 7)
[ 9.060201] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[ 9.060258] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 9.855822] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
[ 9.872710] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
[ 9.873622] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
[ 9.874147] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 4
[ 9.874219] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service rpc_example_2 with src 1024 dst 101
[ 9.874906] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: published functions = 9
[ 9.876270] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 8
[ 9.909605] NET: Registered protocol family 43
[ 9.972896] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[ 9.982753] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[ 9.995864] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 10.005727] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[ 10.015823] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[ 10.049789] usbcore: registered new interface driver usbfs
[ 10.051190] remoteproc remoteproc4: 4b234000.pru0 is available
[ 10.051231] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b234000 probed successfully
[ 10.051499] remoteproc remoteproc5: 4b238000.pru1 is available
[ 10.051535] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b238000 probed successfully
[ 10.051789] remoteproc remoteproc6: 4b2b4000.pru0 is available
[ 10.051824] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b4000 probed successfully
[ 10.052083] remoteproc remoteproc7: 4b2b8000.pru1 is available
[ 10.052125] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b8000 probed successfully
[ 10.145907] usbcore: registered new interface driver hub
[ 10.154901] usbcore: registered new device driver usb
[ 10.183787] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 10.189670] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 10.198687] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[ 10.208013] xhci-hcd xhci-hcd.1.auto: irq 475, io mem 0x48890000
[ 10.215050] hub 1-0:1.0: USB hub found
[ 10.219382] hub 1-0:1.0: 1 port detected
[ 10.224748] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 10.234595] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 10.242364] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 10.251590] hub 2-0:1.0: USB hub found
[ 10.255390] hub 2-0:1.0: 1 port detected
[ 10.589959] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 10.788004] hub 1-1:1.0: USB hub found
[ 10.792084] hub 1-1:1.0: 4 ports detected
[ 10.900034] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 10.946582] hub 2-1:1.0: USB hub found
[ 10.951578] hub 2-1:1.0: 4 ports detected
[ 11.334759] net eth1: initializing cpsw version 1.15 (0)
[ 11.349810] net eth0: initialized cpsw ale version 1.4
[ 11.355595] net eth0: ALE Table size 1024
[ 11.508044] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=-1)
[ 11.576272] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.647263] net eth0: initializing cpsw version 1.15 (0)
[ 11.660978] Bluetooth: Core ver 2.22
[ 11.661026] NET: Registered protocol family 31
[ 11.661030] Bluetooth: HCI device and connection manager initialized
[ 11.661043] Bluetooth: HCI socket layer initialized
[ 11.661054] Bluetooth: L2CAP socket layer initialized
[ 11.661085] Bluetooth: SCO socket layer initialized
[ 11.926878] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=-1)
[ 11.976022] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.077098] NET: Registered protocol family 15
[ 12.196941] Initializing XFRM netlink socket
[ 12.466813] random: crng init done
[ 13.029750] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ 14.088596] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 14.096703] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.047373] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
[ 19.060280] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 19.077299] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
[ 19.090169] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 28.709986] rtc-ds1307 2-006f: write secs=32, mins=31, hours=18, mday=16, mon=7, year=117, wday=3
[ 28.709997] rtc-ds1307 2-006f: write: b2 31 18 0c 16 08 17
[ 28.710587] rtc-ds1307 2-006f: read: b2 31 18 2c 16 08 17
[ 28.710598] rtc-ds1307 2-006f: read secs=32, mins=31, hours=18, mday=16, mon=7, year=117, wday=3
Jimit
