Part Number: XTCIEVMK2LX
Hi all,
I am using the C:\ti\pdk_keystone2_3_01_04_07\packages\exampleProjects\PA_emacExample_K2L_exampleProject for sending and receiving UDP packets between EVM and PC. I am able to send the packets form EVM to PC and seeing it in Wireshark on PC . But I am unable to receive the UDP packets from PC , I am getting prints in the console as , in that always received packets are showing as 0.
[C66xx_0] 2 Resource entries at 0x800000
******* Ethernet Single Core Example Start *******
QMSS successfully initialized
CPPI successfully initialized
PASS successfully initialized
Ethernet subsystem successfully initialized
Tx setup successfully done
Rx setup successfully done
PASS setup successfully done
CSL_CPSW_getStats before Packet Transmission ...
Stats for block number: 0
Good Frames Received 18
Good Broadcast Frames Received 10
Good Multicast Frames Received 8
PauseRx Frames Received 0
Frames Received with CRC Errors 0
Frames Received with Alignment/Code Errors0
Oversized Frames Received 0
Jabber Frames Received 0
Undersized Frames Received 0
Rx Frame Fragments Received 0
Total Received Bytes in Good Frames 4140
Good Frames Sent 4530
Good Broadcast Frames Sent 53
Good Multicast Frames Sent 75
PauseTx Frames Sent 0
Frames Where Transmission was Deferred 0
Total Frames Sent With Collision 0
Frames Sent with Exactly One Collision 0
Frames Sent with Multiple Colisions 0
Tx Frames Lost Due to Excessive Collisions0
Tx Frames Lost Due to a Late Collision 0
Tx Frames Lost Due to Carrier Sense Loss 0
Total Transmitted Bytes in Good Frames 581281
Total Tx&Rx with Octet Size of 64 12
Total Tx&Rx with Octet Size of 65 to 127 4484
Total Tx&Rx with Octet Size of 128 to 255 26
Total Tx&Rx with Octet Size of 256 to 511 10
Total Tx&Rx with Octet Size of 512 to 1023 8
Total Tx&Rx with Octet Size of >=1024 8
Sum of all Octets Tx or Rx on the Network 585421
Stats for block number: 1
Good Frames Received 4530
Good Broadcast Frames Received 53
Good Multicast Frames Received 75
Total Received Bytes in Good Frames 581281
Good Frames Sent 18
Good Broadcast Frames Sent 10
Good Multicast Frames Sent 8
Total Transmitted Bytes in Good Frames 4140
Stats for block number: 2
Good Frames Received 0
Good Broadcast Frames Received 0
Good Multicast Frames Received 0
Total Received Bytes in Good Frames 0
Good Frames Sent 0
Good Broadcast Frames Sent 0
Good Multicast Frames Sent 0
Total Transmitted Bytes in Good Frames 0
Total Tx&Rx with Octet Size of 64 0
Total Tx&Rx with Octet Size of 65 to 127 0
Total Tx&Rx with Octet Size of 128 to 255 0
Total Tx&Rx with Octet Size of 256 to 511 0
Total Tx&Rx with Octet Size of 512 to 1023 0
Total Tx&Rx with Octet Size of >=1024 0
Sum of all Octets Tx or Rx on the Network 0
Stats for block number: 3
Good Frames Sent 0
Stats for block number: 4
Good Frames Sent 0
Packet Transmission Start ...
Packet Transmission Done.
Wait for all packets to be Received from EMAC port 0...
Port = 0, MAC address = 3c:97:0e:05:8c:de, unicast_type = 0
Port = 1, MAC address = 3c:97:0e:05:8c:de, unicast_type = 0
Port = 2, MAC address = 20:21:22:23:24:25, unicast_type = 0
Port = 3, MAC address = 30:31:32:33:34:35, unicast_type = 0
Port = 4, MAC address = 40:41:42:43:44:45, unicast_type = 0
Packets Sent = 10
Packets Received = 0
Wait for all packets to be Received from EMAC port 1...
Packets Sent = 10
Wait for all packets to be Received from EMAC port 2...
Packets Sent = 10
Wait for all packets to be Received from EMAC port 3...
Packets Sent = 10
Example Done!
PA Stats After Packet Transmission BEGIN ********* ...
--- PA STATS ---
C1 number of packets: 305
C1 number IPv4 packets: 88
C1 number IPv6 packets: 0
C1 number custom packets: 0
C1 number SRIO packets: 0
C1 number llc/snap fail: 0
C1 number table matched: 88
C1 number failed table matched: 88
C1 number Ingress IP frags: 0
C1 number IP depth overflow: 0
C1 number vlan depth overflow: 0
C1 number gre depth overflow: 0
C1 number mpls packets: 0
C1 number of parse fail: 0
C1 number invalid IPv6 opts: 0
C1 number of Egress IP frags: 0
C1 number of silent discard: 0
C1 number of invalid control: 0
C1 number of invalid states: 0
C1 number of system fails: 0
C2 number of packets: 0
C2 number of UDP packets: 0
C2 number of TCP packets: 0
C2 number of custom packets: 0
C2 number of silent discard: 0
C2 number of invalid control: 0
Modify number of command file: 0
CSL_CPSW_getStats after Packet Transmission ...
Good Frames Received 58
Total Received Bytes in Good Frames 9180
Good Frames Sent 4616
Total Transmitted Bytes in Good Frames 592117
Total Tx&Rx with Octet Size of 65 to 127 4610
Sum of all Octets Tx or Rx on the Network 601297
Good Frames Received 4616
Total Received Bytes in Good Frames 592117
Good Frames Sent 28
Total Transmitted Bytes in Good Frames 5400
Total Tx&Rx with Octet Size of 65 to 127 4580
Sum of all Octets Tx or Rx on the Network 597517
Good Frames Sent 10
Total Transmitted Bytes in Good Frames 1260
Total Tx&Rx with Octet Size of 65 to 127 10
Sum of all Octets Tx or Rx on the Network 1260
Good Frames Sent 0
Good Frames Sent 0
******** Ethernet Single Core Example End ********
Pa_addPort returned error -18
Failed to clean up the MAC address
Pa_addIp returned error -18
Core 0 : CPPI CPDMA closed successfully
Core 0 : CPPI exit successful
Instance name: RM_Server
Handle: 0x00802108
Type: Server
Resource Status:
All resources freed successfully
I did the some changes in the code
cpswLpbkMode = CPSW_LOOPBACK_NONE ;
and change the destination and source mac address.
if anybody have already tried this example , plz help me.
Raiman
