Linux/AM5728: Dsptop fails
Part Number: AM5728
Other Parts Discussed in Thread: TLV320AIC3104
Tool/software: Linux
I am trying to run PSDK 4.00.00.00 Linux image (http://software-dl.ti.com/processor-sdk-linux/esd/AM57X/latest/exports/am57xx-evm-linux-04.00.00.04.img.zip ) on AM5728EVM.
When I try running dsptop on the target, I get the following error
dsptop internal error: Fatal: : Can not open debugss module device_name sysfs entry for reading
This is even after insmod of /lib/modules/4.9.28-geed43d1050/extra/debugss_kmodule.ko on the target. Can you please help?
Please note we are able to run opencl examples with dsp acceleration enabled successfully.
dmesg logs for the target is attached
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.28-geed43d1050 (gtbldadm@ubuntu-16) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #2 SMP PREEMPT Wed Jun 28 18:16:59 EDT 2017
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt:Machine model: TI AM572x EVM Rev A3
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[    0.000000] On node 0 totalpages: 474368
[    0.000000] free_area_init_node: node 0, pgdat c104bc00, node_mem_map eeda2000
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 147456 pages, LIFO batch:31
[    0.000000]   HighMem zone: 326912 pages, LIFO batch:31
[    0.000000] DRA752 ES2.0
[    0.000000] percpu: Embedded 13 pages/cpu @eed34000 s22092 r8192 d22964 u53248
[    0.000000] pcpu-alloc: s22092 r8192 d22964 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 472640
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=50e41a45-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1675680K/1897472K available (8192K kernel code, 314K rwdata, 2492K rodata, 2048K init, 296K bss, 33376K reserved, 188416K cma-reserved, 1283072K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0a00000   (10208 kB)
                     .init : 0xc0e00000 - 0xc1000000   (2048 kB)
                     .data : 0xc1000000 - 0xc104e860   ( 315 kB)
                      .bss : 0xc1050000 - 0xc109a130   ( 297 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000016] Switching to timer-based delay loop, resolution 162ns
[    0.000322] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000330] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000742] Console: colour dummy device 80x30
[    0.000759] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000766] This ensures that you still see kernel messages. Please
[    0.000772] update your kernel commandline.
[    0.000789] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000802] pid_max: default: 32768 minimum: 301
[    0.000903] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000914] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001519] CPU: Testing write buffer coherency: ok
[    0.001729] /cpus/cpu@0 missing clock-frequency property
[    0.001745] /cpus/cpu@1 missing clock-frequency property
[    0.001756] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001773] Setting up static identity map for 0x80200000 - 0x80200060
[    0.080066] EFI services will not be available.
[    0.170310] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.170397] Brought up 2 CPUs
[    0.170411] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.170418] CPU: All CPU(s) started in HYP mode.
[    0.170425] CPU: Virtualization extensions available.
[    0.170930] devtmpfs: initialized
[    0.198228] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.198462] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.198479] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.201838] pinctrl core: initialized pinctrl subsystem
[    0.202638] NET: Registered protocol family 16
[    0.203495] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.204453] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.314665] omap_hwmod: dcan1: _wait_target_disable failed
[    0.440365] cpuidle: using governor ladder
[    0.470391] cpuidle: using governor menu
[    0.478380] gpio gpiochip0: (gpio): added GPIO chardev (254:0)
[    0.478607] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio)
[    0.480063] OMAP GPIO hardware version 0.1
[    0.480771] gpio gpiochip1: (gpio): added GPIO chardev (254:1)
[    0.480986] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio)
[    0.482783] gpio gpiochip2: (gpio): added GPIO chardev (254:2)
[    0.482990] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio)
[    0.484808] gpio gpiochip3: (gpio): added GPIO chardev (254:3)
[    0.485015] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio)
[    0.486758] gpio gpiochip4: (gpio): added GPIO chardev (254:4)
[    0.486963] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio)
[    0.488744] gpio gpiochip5: (gpio): added GPIO chardev (254:5)
[    0.488951] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio)
[    0.490775] gpio gpiochip6: (gpio): added GPIO chardev (254:6)
[    0.490987] gpiochip_setup_dev: registered GPIOs 192 to 223 on device: gpiochip6 (gpio)
[    0.492769] gpio gpiochip7: (gpio): added GPIO chardev (254:7)
[    0.492971] gpiochip_setup_dev: registered GPIOs 224 to 255 on device: gpiochip7 (gpio)
[    0.494538] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.520916] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.520926] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.521272] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.521282] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.521812] OMAP DMA hardware revision 0.0
[    0.571595] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.572891] edma 43300000.edma: memcpy is disabled
[    0.577657] edma 43300000.edma: TI EDMA DMA engine driver
[    0.578026] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vdd_3v3[0]'
[    0.578300] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-aic_dvdd[0]'
[    0.578639] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[    0.579016] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0)
[    0.582084] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.582254] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.582401] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.582549] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.582807] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.582980] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.585607] palmas 0-0058: Irq flag is 0x00000008
[    0.612620] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[    0.616372] vtt_fixed: supplied by smps3
[    0.661924] random: fast init done
[    0.692345] vdd_3v3: supplied by regen1
[    0.692565] aic_dvdd_fixed: supplied by vdd_3v3
[    0.694956] gpiochip_find_base: found new base at 504
[    0.694973] gpio gpiochip8: (48070000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8)
[    0.695201] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip8 (48070000.i2c:tps659038@58:tps659038_gpio)
[    0.695731] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.696226] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.696796] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    0.696987] media: Linux media interface: v0.10
[    0.697033] Linux video capture interface: v2.00
[    0.697068] pps_core: LinuxPPS API ver. 1 registered
[    0.697075] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.697096] PTP clock support registered
[    0.697134] EDAC MC: Ver: 3.0.0
[    0.697823] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.698118] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.698398] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.698678] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.699018] Advanced Linux Sound Architecture Driver Initialized.
[    0.699831] clocksource: Switched to clocksource arch_sys_counter
[    0.710574] NET: Registered protocol family 2
[    0.711067] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.711131] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.711256] TCP: Hash tables configured (established 8192 bind 8192)
[    0.711302] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.711332] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.711461] NET: Registered protocol family 1
[    0.711801] RPC: Registered named UNIX socket transport module.
[    0.711810] RPC: Registered udp transport module.
[    0.711817] RPC: Registered tcp transport module.
[    0.711824] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.711834] PCI: CLS 0 bytes, default 64
[    0.712740] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.715632] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.723138] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.723844] NFS: Registering the id_resolver key type
[    0.723868] Key type id_resolver registered
[    0.723876] Key type id_legacy registered
[    0.723917] ntfs: driver 2.1.32 [Flags: R/O].
[    0.725080] bounce: pool size: 64 pages
[    0.725223] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.725232] io scheduler noop registered
[    0.725241] io scheduler deadline registered
[    0.725367] io scheduler cfq registered (default)
[    0.729722] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
[    0.730265] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.733503] dra7-pcie 51000000.pcie: GPIO lookup for consumer (null)
[    0.733511] dra7-pcie 51000000.pcie: using device tree for GPIO lookup
[    0.733538] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ocp/axi@0/pcie@51000000[0]' - status (0)
[    0.733657] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[    0.733670] OF: PCI:   No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
[    0.733703] OF: PCI:    IO 0x20003000..0x20012fff -> 0x00000000
[    0.733724] OF: PCI:   MEM 0x20013000..0x2fffffff -> 0x20013000
[    1.735120] dra7-pcie 51000000.pcie: phy link never came up
[    1.735289] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    1.735303] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.735314] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.735324] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    1.735359] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[    1.735382] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[    1.735395] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[    1.735464] pci 0000:00:00.0: supports D1
[    1.735471] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    1.735698] PCI: bus0: Fast back to back transfers disabled
[    1.735816] PCI: bus1: Fast back to back transfers enabled
[    1.735932] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    1.735948] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    1.735961] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.736180] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    1.736193] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[    1.736320] aer 0000:00:00.0:pcie002: service driver aer loaded
[    1.737151] pwm-backlight backlight: GPIO lookup for consumer enable
[    1.737158] pwm-backlight backlight: using device tree for GPIO lookup
[    1.737166] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[    1.737173] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[    1.737179] pwm-backlight backlight: using lookup tables for GPIO lookup
[    1.737187] pwm-backlight backlight: lookup for GPIO enable failed
[    1.737216] backlight supply power not found, using dummy regulator
[    1.799469] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    1.802820] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
[    2.771456] console [ttyS2] enabled
[    2.775793] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 302, base_baud = 3000000) is a 8250
[    2.786543] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    2.793319] [drm] Initialized
[    2.798174] OMAP DSS rev 6.1
[    2.801552] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    2.809892] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[    2.818727] tpd12s015 encoder: GPIO lookup for consumer (null)
[    2.818734] tpd12s015 encoder: using device tree for GPIO lookup
[    2.818760] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[0]' - status (0)
[    2.818775] tpd12s015 encoder: GPIO lookup for consumer (null)
[    2.818781] tpd12s015 encoder: using device tree for GPIO lookup
[    2.818816] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[1]' - status (0)
[    2.818828] tpd12s015 encoder: GPIO lookup for consumer (null)
[    2.818834] tpd12s015 encoder: using device tree for GPIO lookup
[    2.818880] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder[2]' - status (0)
[    2.819543] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/connector[0]'
[    2.819813] panel-dpi display: GPIO lookup for consumer enable
[    2.819865] panel-dpi display: using device tree for GPIO lookup
[    2.819891] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/display[0]' - status (0)
[    2.819904] panel-dpi display: GPIO lookup for consumer reset
[    2.819910] panel-dpi display: using device tree for GPIO lookup
[    2.819917] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/display[0]'
[    2.819924] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/display[0]'
[    2.819930] panel-dpi display: using lookup tables for GPIO lookup
[    2.819937] panel-dpi display: lookup for GPIO reset failed
[    2.819966] display supply vcc not found, using dummy regulator
[    2.997159] brd: module loaded
[    3.015444] loop: module loaded
[    3.019159] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[    3.028862] libphy: Fixed MDIO Bus: probed
[    3.089858] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    3.095984] libphy: 48485000.mdio: probed
[    3.104078] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[    3.113816] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[    3.124041] cpsw 48484000.ethernet: Detected MACID = fc:0f:4b:7a:4f:fc
[    3.130727] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    3.138998] cpsw 48484000.ethernet: cpsw: Detected MACID = fc:0f:4b:7a:4f:fd
[    3.147398] mousedev: PS/2 mouse device common for all mice
[    3.153333] i2c /dev entries driver
[    3.158445] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_fan[0]' - status (0)
[    3.159682] gpio-fan gpio_fan: GPIO fan initialized
[    3.165939] tmp102 0-0048: initialized
[    3.174769] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer cd
[    3.174777] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    3.174803] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@4809c000[0]' - status (0)
[    3.174840] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    3.179484] omap_hsmmc 4809c000.mmc: GPIO lookup for consumer wp
[    3.179490] omap_hsmmc 4809c000.mmc: using device tree for GPIO lookup
[    3.179498] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[    3.179505] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[    3.179511] omap_hsmmc 4809c000.mmc: using lookup tables for GPIO lookup
[    3.179518] omap_hsmmc 4809c000.mmc: lookup for GPIO wp failed
[    3.250009] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer cd
[    3.250014] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    3.250020] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480b4000[0]'
[    3.250025] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480b4000[0]'
[    3.250029] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    3.250034] omap_hsmmc 480b4000.mmc: lookup for GPIO cd failed
[    3.250039] omap_hsmmc 480b4000.mmc: GPIO lookup for consumer wp
[    3.250043] omap_hsmmc 480b4000.mmc: using device tree for GPIO lookup
[    3.250048] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]'
[    3.250052] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]'
[    3.250056] omap_hsmmc 480b4000.mmc: using lookup tables for GPIO lookup
[    3.250060] omap_hsmmc 480b4000.mmc: lookup for GPIO wp failed
[    3.250172] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    3.256551] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    3.340054] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer cd
[    3.340059] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[    3.340064] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@480ad000[0]'
[    3.340069] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@480ad000[0]'
[    3.340074] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[    3.340078] omap_hsmmc 480ad000.mmc: lookup for GPIO cd failed
[    3.340084] omap_hsmmc 480ad000.mmc: GPIO lookup for consumer wp
[    3.340087] omap_hsmmc 480ad000.mmc: using device tree for GPIO lookup
[    3.340092] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480ad000[0]'
[    3.340096] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480ad000[0]'
[    3.340100] omap_hsmmc 480ad000.mmc: using lookup tables for GPIO lookup
[    3.340104] omap_hsmmc 480ad000.mmc: lookup for GPIO wp failed
[    3.400131] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led0[0]' - status (0)
[    3.400216] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0)
[    3.400295] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0)
[    3.400376] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led3[0]' - status (0)
[    3.400739] ledtrig-cpu: registered to indicate activity on CPUs
[    3.411439] NET: Registered protocol family 10
[    3.426564] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.432908] NET: Registered protocol family 17
[    3.437512] Key type dns_resolver registered
[    3.441905] omap_voltage_late_init: Voltage driver support not added
[    3.448348] Power Management for TI OMAP4+ devices.
[    3.453446] Registering SWP/SWPB emulation handler
[    3.467277] dmm 4e000000.dmm: initialized all PAT entries
[    3.510874] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.517515] [drm] No driver support for vblank timestamp query.
[    3.525494] [drm] Enabling DMM ywrap scrolling
[    3.543383] mmc1: new DDR MMC card at address 0001
[    3.543727] mmcblk1: mmc1:0001 S10004 3.56 GiB
[    3.543883] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[    3.544026] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[    3.544608]  mmcblk1: p1 p2 p3
[    3.557382] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.592183] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[    3.592475] mmcblk0: mmc0:59b4 USDU1 59.0 GiB
[    3.593604]  mmcblk0: p1 p2
[    3.598484] Console: switching to colour frame buffer device 100x30
[    3.653096] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    3.691243] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER1[0]' - status (0)
[    3.691271] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER2[0]' - status (0)
[    3.691296] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER3[0]' - status (0)
[    3.691320] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER4[0]' - status (0)
[    3.691342] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/USER5[0]' - status (0)
[    3.691978] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[    3.698915] hctosys: unable to open rtc device (rtc0)
[    3.704539] aic_dvdd_fixed: disabling
[    3.708217] vmmcwl_fixed: disabling
[    3.711903] ldousb: disabling
[    3.715140] ALSA device list:
[    3.718118]   No soundcards found.
[    3.752914] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.761087] VFS: Mounted root (ext4 filesystem) on device 179:50.
[    3.770851] devtmpfs: mounted
[    3.774917] Freeing unused kernel memory: 2048K (c0e00000 - c1000000)
[    3.936666] systemd[1]: System time before build time, advancing clock.
[    3.974351] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    3.992801] systemd[1]: Detected architecture arm.
[    4.030791] systemd[1]: Set hostname to <am57xx-evm>.
[    4.326818] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    4.334658] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    4.342404] systemd[1]: sysinit.target: Found dependency on basic.target/start
[    4.349661] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[    4.357133] systemd[1]: sysinit.target: Found dependency on rpcbind.socket/start
[    4.364606] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    4.372073] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[    4.949168] cmemk: loading out-of-tree module taints kernel.
[    4.955608] CMEMK module: reference Linux version 4.9.28
[    4.964225] allocated heap buffer 0x40500000 of size 0x100000
[    4.970134] cmemk initialized
[    4.985118] cryptodev: driver 1.8 loaded.
[    4.989525] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.910119] systemd-journald[125]: Received request to flush runtime journal from PID 1
[    6.298331] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[    6.331818] remoteproc remoteproc0: 58820000.ipu is available
[    6.382276] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    6.403855] remoteproc remoteproc1: 55020000.ipu is available
[    6.437464] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    6.527711] remoteproc remoteproc2: 40800000.dsp is available
[    6.566030] remoteproc remoteproc0: powering up 58820000.ipu
[    6.566040] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4872056
[    6.566136] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[    6.583521] virtio_rpmsg_bus virtio0: rpmsg host is online
[    6.583544] remoteproc remoteproc0: registered virtio0 (type 7)
[    6.583549] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[    6.590036] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[    6.590165] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[    6.590348] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[    6.590451] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[    6.601855] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@48070000/tlv320aic3104@18[0]'
[    6.642743] rtc-ds1307 2-006f: SET TIME!
[    6.643847] rtc-ds1307 2-006f: read: 80 00 00 09 01 01 01
[    6.643853] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=0
[    6.644608] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[    6.644614] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[    6.645006] rtc-ds1307 2-006f: mcp794xx_read_alarm, sec=0 min=0 hour=0 wday=0 mday=1 mon=0 enabled=0 polarity=0 irq=0 match=0
[    6.645328] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[    6.645334] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[    6.645340] rtc rtc0: alarm rollover: year
[    6.645641] rtc-ds1307 2-006f: read: 80 00 00 0a 01 01 01
[    6.645648] rtc-ds1307 2-006f: read secs=0, mins=0, hours=0, mday=1, mon=0, year=101, wday=1
[    6.645651] rtc rtc1: 48070000.i2c:tps659: dev (253:1)
[    6.645656] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
[    6.646025] rtc rtc0: mcp7941x: dev (253:0)
[    6.646035] rtc-ds1307 2-006f: rtc core: registered mcp7941x as rtc0
[    6.650026] remoteproc remoteproc1: powering up 55020000.ipu
[    6.650034] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743164
[    6.650100] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    6.657405] rtc-ds1307 2-006f: got IRQ 472
[    6.657421] rtc-ds1307 2-006f: 64 bytes nvram
[    6.675504] pixcir_ts 4-005c: GPIO lookup for consumer attb
[    6.675508] pixcir_ts 4-005c: using device tree for GPIO lookup
[    6.675515] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675533] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[    6.675545] pixcir_ts 4-005c: GPIO lookup for consumer reset
[    6.675548] pixcir_ts 4-005c: using device tree for GPIO lookup
[    6.675553] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675567] of_get_named_gpiod_flags: parsed 'reset-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[    6.675576] pixcir_ts 4-005c: GPIO lookup for consumer wake
[    6.675580] pixcir_ts 4-005c: using device tree for GPIO lookup
[    6.675583] of_get_named_gpiod_flags: can't parse 'wake-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675587] of_get_named_gpiod_flags: can't parse 'wake-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675590] pixcir_ts 4-005c: using lookup tables for GPIO lookup
[    6.675594] pixcir_ts 4-005c: lookup for GPIO wake failed
[    6.675597] pixcir_ts 4-005c: GPIO lookup for consumer enable
[    6.675600] pixcir_ts 4-005c: using device tree for GPIO lookup
[    6.675603] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675606] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.675609] pixcir_ts 4-005c: using lookup tables for GPIO lookup
[    6.675612] pixcir_ts 4-005c: lookup for GPIO enable failed
[    6.689898] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[    6.689903] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.689909] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[    6.689913] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[    6.689917] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[    6.689921] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: lookup for GPIO id failed
[    6.689925] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[    6.689928] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.689932] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[    6.689983] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0)
[    6.796696] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.796709] remoteproc remoteproc1: registered virtio1 (type 7)
[    6.796713] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[    6.804700] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[    6.805575] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[    6.820663] input: pixcir_tangoc as /devices/platform/44000000.ocp/4807c000.i2c/i2c-4/4-005c/input/input1
[    6.821508] mt9t11x 4-003c: input-clock-freq: 32000000
[    6.821513] mt9t11x 4-003c: pixel-clock-freq: 96000000
[    6.821519] mt9t11x 4-003c: GPIO lookup for consumer reset
[    6.821522] mt9t11x 4-003c: using device tree for GPIO lookup
[    6.821583] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.821594] mt9t11x 4-003c: GPIO lookup for consumer powerdown
[    6.821597] mt9t11x 4-003c: using device tree for GPIO lookup
[    6.821615] of_get_named_gpiod_flags: parsed 'powerdown-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.821626] mt9t11x 4-003c: GPIO lookup for consumer oscen
[    6.821629] mt9t11x 4-003c: using device tree for GPIO lookup
[    6.821646] of_get_named_gpiod_flags: parsed 'oscen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.821654] mt9t11x 4-003c: GPIO lookup for consumer bufen
[    6.821658] mt9t11x 4-003c: using device tree for GPIO lookup
[    6.821672] of_get_named_gpiod_flags: parsed 'bufen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.821680] mt9t11x 4-003c: GPIO lookup for consumer camen
[    6.821683] mt9t11x 4-003c: using device tree for GPIO lookup
[    6.821698] of_get_named_gpiod_flags: parsed 'camen-gpios' property of node '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.847804] mt9t11x 4-003c: Product ID error ffffff87
[    7.015628] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    7.028705] omap-des 480a5000.des: will run requests pump with realtime priority
[    7.079801] rtc rtc2: 48838000.rtc: dev (253:2)
[    7.079814] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
[    7.108240] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    7.115695] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[    7.140087] vpe 489d0000.vpe: Device registered as /dev/video0
[    7.146754] remoteproc remoteproc3: 41000000.dsp is available
[    7.184440] vip 48990000.vip: loading firmware vpdma-1b8.bin
[    7.210395] vip 48990000.vip: VPDMA firmware loaded
[    7.582276] SCSI subsystem initialized
[    7.604848] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    7.612038] FAT-fs (mmcblk1p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    7.615886] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    7.642856] FAT-fs (mmcblk1p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    7.686728] libata version 3.00 loaded.
[    7.738519] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[    7.799470] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[    7.810922] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    7.822962] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    7.849912] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    7.914976] scsi host0: ahci
[    7.918714] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 346
[    7.943840] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    7.955825] omap-aes 4b500000.aes: will run requests pump with realtime priority
[    8.009264] remoteproc remoteproc2: powering up 40800000.dsp
[    8.016058] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21891524
[    8.037197] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    8.042303] omap-aes 4b700000.aes: will run requests pump with realtime priority
[    8.044340] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    8.097940] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound0[0]'
[    8.097945] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound0[0]'
[    8.101501] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    8.161384] remoteproc remoteproc3: powering up 41000000.dsp
[    8.161394] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 21891524
[    8.168058] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[    8.168091] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[    8.168139] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[    8.272642] ata1: SATA link down (SStatus 0 SControl 300)
[    8.317757] net eth1: initializing cpsw version 1.15 (0)
[    8.317764] net eth0: initialized cpsw ale version 1.4
[    8.317767] net eth0: ALE Table size 1024
[    8.524099] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=-1)
[    8.559587] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    8.567264] net eth0: initializing cpsw version 1.15 (0)
[    8.651904] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[    8.657791] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[    8.663725] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[    8.749886] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=-1)
[    8.795229] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[    8.817733] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.860829] virtio_rpmsg_bus virtio3: rpmsg host is online
[    8.860906] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[    8.873738] virtio_rpmsg_bus virtio2: rpmsg host is online
[    8.873761] remoteproc remoteproc3: registered virtio2 (type 7)
[    8.873766] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[    8.874594] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[    8.920786] Bluetooth: Core ver 2.22
[    8.920821] NET: Registered protocol family 31
[    8.920824] Bluetooth: HCI device and connection manager initialized
[    8.920834] Bluetooth: HCI socket layer initialized
[    8.920843] Bluetooth: L2CAP socket layer initialized
[    8.920874] Bluetooth: SCO socket layer initialized
[    9.169868] remoteproc remoteproc2: registered virtio3 (type 7)
[    9.175819] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[    9.268220] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service rpc_example_2 with src 1024 dst 101
[    9.318866] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 8
[    9.332788] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
[    9.349289] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
[    9.351517] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[    9.352212] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
[    9.352569] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
[    9.354794] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[    9.355270] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
[    9.460818] remoteproc remoteproc4: 4b234000.pru0 is available
[    9.460873] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b234000 probed successfully
[    9.461173] remoteproc remoteproc5: 4b238000.pru1 is available
[    9.461206] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b238000 probed successfully
[    9.461492] remoteproc remoteproc6: 4b2b4000.pru0 is available
[    9.461529] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b4000 probed successfully
[    9.461812] remoteproc remoteproc7: 4b2b8000.pru1 is available
[    9.461843] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b8000 probed successfully
[    9.470020] NET: Registered protocol family 43
[    9.530426] usbcore: registered new interface driver usbfs
[    9.530489] usbcore: registered new interface driver hub
[    9.530549] usbcore: registered new device driver usb
[    9.547614] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.547634] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    9.549152] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[    9.549191] xhci-hcd xhci-hcd.1.auto: irq 475, io mem 0x48890000
[    9.552906] hub 1-0:1.0: USB hub found
[    9.553157] hub 1-0:1.0: 1 port detected
[    9.553653] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    9.553667] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    9.553751] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.555004] hub 2-0:1.0: USB hub found
[    9.555415] hub 2-0:1.0: 1 port detected
[    9.908267] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
[    9.908611] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4
[    9.930032] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    9.985537] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9
[   10.003891] hub 2-1:1.0: USB hub found
[   10.021752] hub 2-1:1.0: 4 ports detected
[   10.099877] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[   10.291239] hub 1-1:1.0: USB hub found
[   10.298131] hub 1-1:1.0: 4 ports detected
[   10.820854] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[   10.827433] NET: Registered protocol family 15
[   10.923772] Initializing XFRM netlink socket
[   11.046115] random: crng init done
[   11.928462] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   11.938006] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   19.047598] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
[   19.061390] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
[   19.074999] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[   19.088599] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
Ridhim
  • Hi Ridhim,
    I just tested this with my AM572x IDK, running latest TISDK (kernel 4.9.28) and dsptop works fine.
    Yordan
  • Hi Yordan,
    Thanks for your response.
    I am using AM5728 EVM with the latest PSDK (4.00.00.00) and the kernel version is 4.9.28.
    I have attached the boot logs for your reference. Can you please let me know what could be the problem?
    U-Boot SPL 2017.01-g9fd60700db (Jun 28 2017 - 19:55:57)
    DRA752-GP ES2.0
    Trying to boot from MMC1
    reading uboot.env
    ** Unable to read "uboot.env" from mmc0:1 **
    Using default environment
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    U-Boot 2017.01-g9fd60700db (Jun 28 2017 - 19:55:57 -0400)
    CPU  : DRA752-GP ES2.0
    Model: TI AM572x EVM Rev A3
    Board: AM572x EVM REV A.3A
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    reading uboot.env
    SCSI:  SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    cpsw
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    reading boot.scr
    ** Unable to read file boot.scr **
    reading uEnv.txt
    574 bytes read in 5 ms (111.3 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    3725624 bytes read in 269 ms (13.2 MiB/s)
    103304 bytes read in 80 ms (1.2 MiB/s)
       Loading Device Tree to 8ffe3000, end 8ffff387 ... OK
    Starting kernel ...
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc0a00000   (10208 kB)
    [    0.000000]       .init : 0xc0e00000 - 0xc1000000   (2048 kB)
    [    0.000000]       .data : 0xc1000000 - 0xc104e860   ( 315 kB)
    [    0.000000]        .bss : 0xc1050000 - 0xc109a130   ( 297 kB)
    [    0.000316] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000324] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000737] Console: colour dummy device 80x30
    [    0.000755] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000762] This ensures that you still see kernel messages. Please
    [    0.000768] update your kernel commandline.
    [    0.000785] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [    0.000799] pid_max: default: 32768 minimum: 301
    [    0.000898] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000909] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001516] CPU: Testing write buffer coherency: ok
    [    0.001726] /cpus/cpu@0 missing clock-frequency property
    [    0.001743] /cpus/cpu@1 missing clock-frequency property
    [    0.001754] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001771] Setting up static identity map for 0x80200000 - 0x80200060
    [    0.080070] EFI services will not be available.
    [    0.170319] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.170406] Brought up 2 CPUs
    [    0.170420] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [    0.170427] CPU: All CPU(s) started in HYP mode.
    [    0.170433] CPU: Virtualization extensions available.
    [    0.170941] devtmpfs: initialized
    [    0.198023] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.198257] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.198273] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.201638] pinctrl core: initialized pinctrl subsystem
    [    0.202433] NET: Registered protocol family 16
    [    0.203285] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.204232] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.313919] omap_hwmod: dcan1: _wait_target_disable failed
    [    0.440369] cpuidle: using governor ladder
    [    0.470395] cpuidle: using governor menu
    [    0.480105] OMAP GPIO hardware version 0.1
    [    0.494609] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [    0.521054] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.521065] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.521417] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.521427] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.521956] OMAP DMA hardware revision 0.0
    [    0.571628] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.572921] edma 43300000.edma: memcpy is disabled
    [    0.577699] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.582136] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.582304] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.582452] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.582601] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.582857] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.583030] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.585656] palmas 0-0058: Irq flag is 0x00000008
    [    0.612474] palmas 0-0058: Muxing GPIO 2d, PWM 0, LED 0
    [    0.616240] vtt_fixed: supplied by smps3
    [    0.662110] random: fast init done
    [    0.692396] vdd_3v3: supplied by regen1
    [    0.692617] aic_dvdd_fixed: supplied by vdd_3v3
    [    0.695786] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.696280] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.696849] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.697039] media: Linux media interface: v0.10
    [    0.697085] Linux video capture interface: v2.00
    [    0.697120] pps_core: LinuxPPS API ver. 1 registered
    [    0.697128] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.697149] PTP clock support registered
    [    0.697187] EDAC MC: Ver: 3.0.0
    [    0.697878] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
    [    0.698177] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
    [    0.698460] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.698741] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.699079] Advanced Linux Sound Architecture Driver Initialized.
    [    0.699892] clocksource: Switched to clocksource arch_sys_counter
    [    0.710610] NET: Registered protocol family 2
    [    0.711108] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.711172] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.711297] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.711344] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.711375] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.711505] NET: Registered protocol family 1
    [    0.711869] RPC: Registered named UNIX socket transport module.
    [    0.711878] RPC: Registered udp transport module.
    [    0.711885] RPC: Registered tcp transport module.
    [    0.711892] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.712808] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.715702] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.723247] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.723951] NFS: Registering the id_resolver key type
    [    0.723974] Key type id_resolver registered
    [    0.723981] Key type id_legacy registered
    [    0.724023] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.725185] bounce: pool size: 64 pages
    [    0.725329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    0.725339] io scheduler noop registered
    [    0.725347] io scheduler deadline registered
    [    0.725473] io scheduler cfq registered (default)
    [    0.729843] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
    [    0.730381] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.733770] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
    [    0.733782] OF: PCI:   No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
    [    0.733816] OF: PCI:    IO 0x20003000..0x20012fff -> 0x00000000
    [    0.733836] OF: PCI:   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    1.735235] dra7-pcie 51000000.pcie: phy link never came up
    [    1.735404] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [    1.735418] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.735429] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    1.735439] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    1.735814] PCI: bus0: Fast back to back transfers disabled
    [    1.735932] PCI: bus1: Fast back to back transfers enabled
    [    1.736050] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    1.736066] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    1.736080] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.736298] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [    1.737330] backlight supply power not found, using dummy regulator
    [    1.799529] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    1.802908] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 301, base_baud = 3000000) is a 8250
    [    2.771538] console [ttyS2] enabled
    [    2.775879] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 302, base_baud = 3000000) is a 8250
    [    2.786622] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    2.793401] [drm] Initialized
    [    2.798286] OMAP DSS rev 6.1
    [    2.801661] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    2.809998] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
    [    2.820064] display supply vcc not found, using dummy regulator
    [    2.997223] brd: module loaded
    [    3.015517] loop: module loaded
    [    3.019235] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
    [    3.028940] libphy: Fixed MDIO Bus: probed
    [    3.089920] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    3.096045] libphy: 48485000.mdio: probed
    [    3.104430] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
    [    3.114170] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
    [    3.124395] cpsw 48484000.ethernet: Detected MACID = fc:0f:4b:7a:4f:fc
    [    3.131081] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [    3.139346] cpsw 48484000.ethernet: cpsw: Detected MACID = fc:0f:4b:7a:4f:fd
    [    3.147751] mousedev: PS/2 mouse device common for all mice
    [    3.153688] i2c /dev entries driver
    [    3.159942] gpio-fan gpio_fan: GPIO fan initialized
    [    3.166169] tmp102 0-0048: initialized
    [    3.175062] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    3.250235] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    3.256615] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    3.400799] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.411506] NET: Registered protocol family 10
    [    3.426628] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.432975] NET: Registered protocol family 17
    [    3.437582] Key type dns_resolver registered
    [    3.441975] omap_voltage_late_init: Voltage driver support not added
    [    3.448418] Power Management for TI OMAP4+ devices.
    [    3.453525] Registering SWP/SWPB emulation handler
    [    3.467312] dmm 4e000000.dmm: initialized all PAT entries
    [    3.500953] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.507594] [drm] No driver support for vblank timestamp query.
    [    3.515389] [drm] Enabling DMM ywrap scrolling
    [    3.553436] mmc1: new DDR MMC card at address 0001
    [    3.553803] mmcblk1: mmc1:0001 S10004 3.56 GiB
    [    3.553967] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
    [    3.554132] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
    [    3.554725]  mmcblk1: p1 p2 p3
    [    3.557676] mmc0: host does not support reading read-only switch, assuming write-enable
    [    3.588551] Console: switching to colour frame buffer device 100x30
    [    3.592375] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
    [    3.605836] mmcblk0: mmc0:59b4 USDU1 59.0 GiB
    [    3.612670]  mmcblk0: p1 p2
    [    3.643233] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    3.692098] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    3.699039] hctosys: unable to open rtc device (rtc0)
    [    3.704685] aic_dvdd_fixed: disabling
    [    3.708364] vmmcwl_fixed: disabling
    [    3.712045] ldousb: disabling
    [    3.715279] ALSA device list:
    [    3.718257]   No soundcards found.
    [    3.750887] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.759031] VFS: Mounted root (ext4 filesystem) on device 179:50.
    [    3.769584] devtmpfs: mounted
    [    3.773677] Freeing unused kernel memory: 2048K (c0e00000 - c1000000)
    [    3.937509] systemd[1]: System time before build time, advancing clock.
    [    3.978184] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    3.996621] systemd[1]: Detected architecture arm.
    Welcome to Arago 2017.05!
    [    4.030839] systemd[1]: Set hostname to <am57xx-evm>.
    [    4.322593] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    4.330420] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    4.338116] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    4.345584] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    4.355085] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [    4.402131] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    4.431268] systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Reached target Swap.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Reached target Slices.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on Journal Socket.
             Mounting Temporary Directory...
             Starting Setup Virtual Console...
             Starting Remount Root and Kernel File Systems...
    [    4.992811] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
             Starting Journal Service...
             Starting Create Static Device Nodes in /dev...
             Starting Load Kernel Modules...
             [    5.113032] cmemk: loading out-of-tree module taints kernel.
    Mounting POSIX Message Queue File System...
    [    5.121174] CMEMK module: reference Linux version 4.9.28
    [    5.129390] allocated heap buffer 0x40500000 of size 0x100000
    [    5.135320] cmemk initialized
             Mounting Debug File System...
    [    5.149557] cryptodev: driver 1.8 loaded.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started Load Kernel Modules.
             Starting Apply Kernel Variables...
             Mounting Configuration File System...
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /var/volatile...
             Mounting /media/ram...
             Starting udev Coldplug all Devices...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Mounted Configuration File System.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Apply Kernel Variables.
    [    5.850536] systemd-journald[120]: Received request to flush runtime journal from PID 1
    [  OK  ] Reached target Local File Systems.
             Starting Load/Save Random Seed...
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Load/Save Random Seed.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
             Starting Synchronize System and HW clocks...
    [    6.240474] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
    [    6.248350] remoteproc remoteproc0: 58820000.ipu is available
    [[    6.294167] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    6.309003] remoteproc remoteproc1: 55020000.ipu is available
    FAILED] Failed to start Synchronize System and HW clocks.
    [    6.317936] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    6.330612] remoteproc remoteproc2: 40800000.dsp is available
    [    6.337646] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [    6.348655] remoteproc remoteproc3: 41000000.dsp is available
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Reached target System Initialization.
    [    6.514696] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
    [    6.542436] remoteproc remoteproc1: powering up 55020000.ipu
    [    6.552031] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743164
    [    6.552097] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    6.560608] rtc-ds1307 2-006f: SET TIME!
    [    6.562740] remoteproc remoteproc0: powering up 58820000.ipu
    [    6.562749] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4872056
    [    6.562840] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
    [    6.563067] rtc-ds1307 2-006f: rtc core: registered mcp7941x as rtc0
    [    6.580726] rtc-ds1307 2-006f: 64 bytes nvram
    [    6.607176] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.607201] remoteproc remoteproc0: registered virtio0 (type 7)
    [    6.607206] remoteproc remoteproc0: remote processor 58820000.ipu is now up
    [    6.608539] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
    [    6.608699] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
    [    6.608864] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
    [    6.608988] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
    [    6.757603] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.757620] remoteproc remoteproc1: registered virtio1 (type 7)
    [    6.757624] remoteproc remoteproc1: remote processor 55020000.ipu is now up
    [    6.761164] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
    [    6.761599] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
    [    6.795454] input: pixcir_tangoc as /devices/platform/44000000.ocp/4807c000.i2c/i2c-4/4-005c/input/input1
    [    6.802301] mt9t11x 4-003c: input-clock-freq: 32000000
    [    6.802307] mt9t11x 4-003c: pixel-clock-freq: 96000000
    [    6.835336] mt9t11x 4-003c: Product ID error ffffff87
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [    6.914186] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    6.921100] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    6.934748] omap-des 480a5000.des: will run requests pump with realtime priority
    [  OK  ] Reached target Sockets.
    [    6.950508] vpe 489d0000.vpe: Device registered as /dev/video0
    [  OK  ] Reached target Basic System.
    [    6.983442] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
    [  OK  ] Started System Logging Service.
    [  OK  ] Started D-Bus System Message Bus.
    [    7.178797] SCSI subsystem initialized
    [    7.208741] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [    7.227882] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    7.239003] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    7.244857] vip 48990000.vip: VPDMA firmware loaded
    [    7.299795] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [    7.308761] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [    7.322581] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    7.336171] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [    7.360084] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
    [    7.379994] scsi host0: ahci
    [    7.383748] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 346
    [    7.615693] remoteproc remoteproc2: powering up 40800000.dsp
    [    7.622134] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21891524
    [    7.639581] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [    7.645467] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    7.651372] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    7.715262] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    7.726592] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
    [    7.731361] ata1: SATA link down (SStatus 0 SControl 300)
    [    7.732182] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [    7.788588] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    7.799986] omap-aes 4b700000.aes: will run requests pump with realtime priority
    [    7.801845] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.801863] remoteproc remoteproc2: registered virtio2 (type 7)
    [    7.801867] remoteproc remoteproc2: remote processor 40800000.dsp is now up
    [    7.803384] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
    [    7.822133] remoteproc remoteproc3: powering up 41000000.dsp
    [    7.822141] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 21891524
    [    7.828822] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    [    7.828856] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [    7.828902] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [    7.885534] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    7.885556] remoteproc remoteproc3: registered virtio3 (type 7)
    [    7.885560] remoteproc remoteproc3: remote processor 41000000.dsp is now up
    [    7.888200] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
    [    8.291492] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    8.320954] FAT-fs (mmcblk1p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    8.360309] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    8.367861] FAT-fs (mmcblk1p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
             Starting TI MultiCore Tools Daemon...
             Starting Telephony service...
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Login Service...
             Starting Network Service...
             Starting Print notice about GPLv3 packages...
    [    8.656039] Bluetooth: Core ver 2.22
    [    8.662187] NET: Registered protocol family 31
             [    8.672418] Bluetooth: HCI device and connection manager initialized
    Starting uim-sysfs.service...
    [    8.687329] Bluetooth: HCI socket layer initialized
    [    8.687340] Bluetooth: L2CAP socket layer initialized
    [    8.687370] Bluetooth: SCO socket layer initialized
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Started Kernel Logging Service.
    [    8.754733] net eth1: initializing cpsw version 1.15 (0)
    [    8.805068] net eth0: initialized cpsw ale version 1.4
    [    8.827100] net eth0: ALE Table size 1024
    [  OK  ] Started Network Service.
    [  OK  ] Started TI MultiCore Tools Daemon.
    [  OK  ] Started Save/Restore Sound Card State.
    [    8.967543] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service rpc_example_2 with src 1024 dst 101
    [    8.997919] ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
    [    8.998098] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=-1)
    [    9.000089] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
    [    9.000899] irq: no irq domain found for /ocp/pruss_soc_bus@4b226000/pruss@4b200000/intc@4b220000 !
    [    9.001545] ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
    [    9.003502] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
    [    9.004294] irq: no irq domain found for /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/intc@4b2a0000 !
    [    9.039009] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [    9.059599] net eth0: initializing cpsw version 1.15 (0)
    [    9.093236] NET: Registered protocol family 43
    [    9.124189] remoteproc remoteproc4: 4b234000.pru0 is available
    [    9.124230] pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b234000 probed successfully
    [    9.124482] remoteproc remoteproc5: 4b238000.pru1 is available
    [    9.124514] pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b226000/pruss@4b200000/pru@4b238000 probed successfully
    [    9.124747] remoteproc remoteproc6: 4b2b4000.pru0 is available
    [    9.124787] pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b4000 probed successfully
    [    9.125024] remoteproc remoteproc7: 4b2b8000.pru1 is available
    [    9.125054] pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss_soc_bus@4b2a6000/pruss@4b280000/pru@4b2b8000 probed successfully
    [    9.173741] usbcore: registered new interface driver usbfs
    [    9.173786] usbcore: registered new interface driver hub
    [    9.173861] usbcore: registered new device driver usb
    [    9.187983] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    9.188002] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    9.200237] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
    [    9.200284] xhci-hcd xhci-hcd.1.auto: irq 475, io mem 0x48890000
    [    9.202435] hub 1-0:1.0: USB hub found
    [    9.202674] hub 1-0:1.0: 1 port detected
    [    9.202982] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    9.202994] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    9.203050] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    9.203898] hub 2-0:1.0: USB hub found
    [    9.204110] hub 2-0:1.0: 1 port detected
    [    9.243561] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=-1)
    [    9.263846] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    9.580398] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [    9.635231] hub 2-1:1.0: USB hub found
    [    9.635469] hub 2-1:1.0: 4 ports detected
    [    9.760018] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    9.971282] hub 1-1:1.0: USB hub found
    [    9.971688] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started Telephony service.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [   10.023940] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
             Starting Load/Save Screen Backlight...htness of backlight:backlight...
    [  OK  ] Reached target Network.
             Starting Network Name Resolution...
             Starting Permit User Sessions...
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [   10.024411] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 8
    [   10.024479] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
    [   10.024852] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4
    [   10.038464] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Enable and configure wl18xx bluetooth stack...
             Starting Lightning Fast Webserver With Light System Requirements...
    [  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Login Service.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Lightning Fast Webserver With Light System Requirements.
    [   10.329945] usb 1-1.3: new low-speed USB device number 3 using xhci-hcd
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [   10.442937] NET: Registered protocol family 15
    [   10.554223] Initializing XFRM netlink socket
    [  OK  ] Started Simple Network Management Protocol (S[   10.574330] input: Dell Dell USB Keyboard as /devices/platform/44000000.ocp/48880000.omap_dwc3_1/48890000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2003.0001/input/input2
    NMP) Daemon..
    [   10.660957] hid-generic 0003:413C:2003.0001: input: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input0
    [   10.675880] usbcore: registered new interface driver usbhid
    [   10.683451] usbhid: USB HID core driver
    [  OK  ] Started uim-sysfs.service.
             Starting rc.pvr.service...
    [   10.984934] random: crng init done
    [   11.012460] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting telnetd.service...
             Starting tiipclad-daemon.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started tiipclad-daemon.service.
             Starting thttpd.service...
    [  OK  ] Started thttpd.service.
             Starting rng-tools.service...
    [  OK  ] Started rng-tools.service.
             Starting SYSV: The kdump script provides the support:...
    [FAILED] Failed to start SYSV: The kdump script provides the support:.
    See 'systemctl status kdump.service' for details.
             Starting gdbserverproxy.service...
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            binutils-dev
            binutils
            bison-dev
            bison
            cpp-symlinks
            cpp
            dosfstools
            g++-symlinks
            g++
            gawk-dev
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbc6x
            gdbserver
            gstreamer1.0-libav
            hidapi
            libcairo-perf-utils
            libgmp10
            libidn11
            libmpc3
            libmpfr4
            libreadline-dev
            libreadline6
            m4-dev
            m4
            make
            nettle
            parted
            swig-dev
            swig
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [   12.408526] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   12.416509] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  OK  ] Started gdbserverproxy.service.
             Starting matrix-gui-2.0.service...
    [  OK  ] Started matrix-gui-2.0.service.
             Starting thermal-zone-init.service...
    [  OK  ] Started thermal-zone-init.service.
    [  OK  ] Reached target Multi-User System.
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Started Update UTMP about System Runlevel Changes.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am57xx-evm ttyS2
    Arago 2017.05 am57xx-evm ttyS2
    am57xx-evm login: root
    root@am57xx-evm:~# cd /lib/modules/4.9.28-geed43d1050/extra
    root@am57xx-evm:/lib/modules/4.9.28-geed43d1050/extra# ls
    bc_example.ko       debugss_kmodule.ko  gdbserverproxy.ko
    cmemk.ko            driver              pvrsrvkm.ko
    cryptodev.ko        galcore.ko          uio_module_drv.ko
    root@am57xx-evm:/lib/modules/4.9.28-geed43d1050/extra# insmod debugss_kmodule.ko
    root@am57xx-evm:/lib/modules/4.9.28-geed43d1050/extra# dsptop
    dsptop internal error: Fatal: : Can not open debugss module device_name sysfs entry for reading
    root@am57xx-evm:/lib/modules/4.9.28-geed43d1050/extra# lsmod
    Module                  Size  Used by
    debugss_kmodule         6912  0
    bc_example              7326  0
    sha512_generic          9967  0
    sha512_arm             12252  0
    sha256_generic         10178  0
    sha1_generic            2864  0
    sha1_arm_neon           6261  0
    sha1_arm                3862  1 sha1_arm_neon
    md5                     2219  0
    cbc                     2388  0
    usbhid                 19929  0
    xfrm_user              23037  2
    xfrm4_tunnel            2040  0
    ipcomp                  2473  0
    xfrm_ipcomp             4695  1 ipcomp
    esp4                    6401  0
    ah4                     5665  0
    af_key                 27691  0
    xfrm_algo               6989  5 xfrm_user,esp4,ah4,af_key,xfrm_ipcomp
    xhci_plat_hcd           6475  0
    xhci_hcd              109037  1 xhci_plat_hcd
    usbcore               200102  3 usbhid,xhci_plat_hcd,xhci_hcd
    pru_rproc              10520  0
    pruss_intc              7227  1 pru_rproc
    rpmsg_proto             6799  0
    dwc3                   71637  0
    pruss                   9774  1 pru_rproc
    rpmsg_rpc              20026  0
    udc_core               19514  1 dwc3
    usb_common              4737  3 udc_core,usbcore,dwc3
    bluetooth             335515  2
    omap_aes_driver        19101  0
    snd_soc_simple_card     5844  0
    snd_soc_simple_card_utils     5095  1 snd_soc_simple_card
    snd_soc_omap_hdmi_audio     4737  0
    ahci_platform           3474  0
    libahci_platform        8821  1 ahci_platform
    pvrsrvkm              409225  5 bc_example
    libahci                28679  2 ahci_platform,libahci_platform
    libata                206117  3 ahci_platform,libahci_platform,libahci
    omap_sham              21538  0
    pruss_soc_bus           4207  0
    omap_wdt                4634  0
    ti_vip                 40133  0
    scsi_mod              133717  1 libata
    rtc_omap                9662  0
    snd_soc_tlv320aic3x    48324  1
    dwc3_omap               5196  0
    omap_des               11525  0
    ti_vpe                 18826  0
    ti_sc                  24305  2 ti_vpe,ti_vip
    ti_csc                  2351  2 ti_vpe,ti_vip
    ti_vpdma               15166  2 ti_vpe,ti_vip
    des_generic            17608  1 omap_des
    crypto_engine           6458  2 omap_des,omap_aes_driver
    mt9t11x                14536  0
    pixcir_i2c_ts           6716  0
    extcon_palmas           5917  0
    rtc_ds1307             14224  0
    extcon_core            16771  3 dwc3_omap,extcon_palmas,dwc3
    rtc_palmas              5322  0
    omap_remoteproc        12473  0
    virtio_rpmsg_bus        9802  2 rpmsg_rpc,rpmsg_proto
    rpmsg_core              7252  3 rpmsg_rpc,rpmsg_proto,virtio_rpmsg_bus
    remoteproc             29043  4 pru_rproc,rpmsg_rpc,omap_remoteproc,rpmsg_proto
    sch_fq_codel            9039  3
    uio_module_drv          7417  0
    uio                     9137  1 uio_module_drv
    gdbserverproxy          4667  0
    cryptodev              37839  2
    cmemk                  35483  2
    Ridhim
  • Sure, I'll have a look and update.
    Yordan
  • How are you booting your board? Can you create a new SD Card containing the prebuilt images & filesystem from the latest TISDK (ti-processor-sdk-linux-am57xx-evm-04.00.00.04) and try the dsptop command?
    Yordan
  • Hello Yordan,
    Sorry for the delayed response. As per your suggestion I created a new SD card on windows using the image found here:
    software-dl.ti.com/.../index_FDS.html
    I am still getting the same error when trying to run dsptop.
    Ridhim
  • Hello Yordan,
    Just a reminder to let you know that we are still waiting for the response.
    Thank you
    Ridhim
  • Hi Ridhim,
    I tested again on AM572x EVM as well. Here is the result:
    dsptop - Elapsed Time 00:04:41
    Moving Average Mode
    Average DSP Usage: 0.00% Accuracy 100.00%
    External Mem Code/Data 163840 KB Total, 0.0% Used
    Internal Mem Data 1024 KB Total, 0.0% Used
    DSP %USAGE RUN TIME+ IDLE TIME+
    DSP_0 0.00 00:00:00.000 00:00:02.918
    DSP_1 0.00 00:00:00.000 00:00:02.973
    This is when I am running the Vector Application from the TI SDK.
    The lsmod output is:
    root@am57xx-evm:~# lsmod
    Module Size Used by
    xhci_plat_hcd 5247 0
    xhci_hcd 109138 1 xhci_plat_hcd
    rpmsg_proto 7597 0
    rpmsg_pru 4962 0
    rpmsg_rpc 19668 0
    usbcore 194665 2 xhci_plat_hcd,xhci_hcd
    dwc3 64055 0
    virtio_rpmsg_bus 13080 3 rpmsg_pru,rpmsg_rpc,rpmsg_proto
    udc_core 12063 1 dwc3
    cbc 2324 0
    drbg 13425 1
    bc_example 7186 0
    xfrm_user 23228 2
    xfrm4_tunnel 2040 0
    ipcomp 2473 0
    esp4 6465 0
    ah4 5665 0
    af_key 27563 0
    xfrm_algo 6970 5 ah4,esp4,af_key,xfrm_user,xfrm_ipcomp
    bluetooth 325678 2
    pru_rproc 11732 4
    pruss_intc 7227 5 pru_rproc
    snd_soc_simple_card 7760 0
    ti_vip 39918 0
    ecb 1909 0
    sha512_generic 9903 0
    sha512_arm 12079 0
    sha256_generic 9503 1
    hmac 2735 1
    pvrsrvkm 412372 5 bc_example
    md5 1897 0
    extcon_palmas 6347 0
    ahci_platform 3218 0
    omap_aes_driver 19230 0
    libahci 27891 2 libahci_platform,ahci_platform
    sha1_generic 2621 0
    ti_vpe 19292 0
    ti_sc 24714 2 ti_vip,ti_vpe
    libata 196388 3 libahci,libahci_platform,ahci_platform
    ti_csc 2313 2 ti_vip,ti_vpe
    pruss 11186 1 pru_rproc
    ti_vpdma 15166 2 ti_vip,ti_vpe
    omap_sham 21089 0
    omap_wdt 4570 0
    snd_soc_tlv320aic3x 48260 1
    scsi_mod 129717 1 libata
    rtc_omap 8272 0
    rtc_palmas 5187 0
    dwc3_omap 5054 0
    extcon 13943 3 dwc3,extcon_palmas,dwc3_omap
    rtc_ds1307 11278 0
    omap_des 11446 0
    pixcir_i2c_ts 6570 0
    omap_rng 4835 0
    mt9t11x 14769 1
    rng_core 8011 1 omap_rng
    debugss_kmodule 6848 0
    omap_remoteproc 12389 4
    remoteproc 27121 5 omap_remoteproc,pruss,pru_rproc,rpmsg_rpc,rpmsg_proto
    virtio 7580 2 remoteproc,virtio_rpmsg_bus
    virtio_ring 12291 2 remoteproc,virtio_rpmsg_bus
    sch_fq_codel 8251 3
    uio_module_drv 7353 0
    uio 9329 1 uio_module_drv
    gdbserverproxy 4671 0
    cryptodev 37405 2
    cmemk 35174 2
    root@am57xx-evm:~#
    Do you have any modifications on the EVM and therefore the linux kernel? Can you tried with a kernel image that you've build yourself, using the tisdk_am57xx-evm_defconfig?
    Yordan
    Is this issue still present?
    Could you leaborate on the questions bellow?
    Also have you done any modifications to the root fs?
    Yordan
  • Hi,I have the same question also,i havenot change anything   on rootfs,“”dsptop internal error: Fatal: : Can not open debugss module device_name sysfs entry for reading“” , is there any suggetsions?
  • Have yo tried migrating to latest TISDK 04.01.00.06?
    Yordan
  • yeah, i got the latest sdk, can you give some debug suggestions ?
  • yeah,i got the latest sdk , can you give some debug suggetstions ?
  • Ok, I managed to reproduce the problem with the latest SDK. For some reason the debugss was removed.
    Add the following in arhc/arm/boot/dts/am57xx-beagle-x15-common.dtsi:
    sound0_master: simple-audio-card,codec {
    sound-dai = <&tlv320aic3104>;
    clocks = <&clkout2_clk>;
    + debugss: debugss {
    + compatible = "ti,dra7xx-debugss";
    + clocks = <&sys_clkin1>;
    + clock-names = "sysclockin1";
    Yordan
  •  Ok, thanks,can i make it by replacing zImage-am57xx-evm.bin and  am57xx-evm-reva3.dtb ? i tried this method , but i got the same error ?
  • Here is the output of ls /boot on my AM572x EVM running latest TI SDK:
    root@am57xx-evm:/boot# ls
    am571x-idk-lcd-osd101t2045.dtb devicetree-uImage-am57xx-beagle-x15.dtb
    am571x-idk-lcd-osd101t2587.dtb devicetree-uImage-am57xx-evm-cam-mt9t111.dtb
    am571x-idk-pru-excl-uio.dtb devicetree-uImage-am57xx-evm-cam-ov10635.dtb
    am571x-idk.dtb devicetree-uImage-am57xx-evm-reva3-cam-mt9t111.dtb
    am572x-evm-jailhouse.dtb devicetree-uImage-am57xx-evm-reva3-cam-ov10635.dtb
    am572x-idk-jailhouse.dtb devicetree-uImage-am57xx-evm-reva3.dtb
    am572x-idk-lcd-osd101t2045-jh.dtb devicetree-uImage-am57xx-evm.dtb
    am572x-idk-lcd-osd101t2045.dtb devicetree-uImage-am57xx-evm.dtb.old
    am572x-idk-lcd-osd101t2587-jh.dtb devicetree-zImage-am571x-idk-lcd-osd101t2045.dtb
    am572x-idk-lcd-osd101t2587.dtb devicetree-zImage-am571x-idk-lcd-osd101t2587.dtb
    am572x-idk-pru-excl-uio.dtb devicetree-zImage-am571x-idk-pru-excl-uio.dtb
    am572x-idk.dtb devicetree-zImage-am571x-idk.dtb
    am57xx-beagle-x15-revb1.dtb devicetree-zImage-am572x-evm-jailhouse.dtb
    am57xx-beagle-x15.dtb devicetree-zImage-am572x-idk-jailhouse.dtb
    am57xx-evm-cam-mt9t111.dtb devicetree-zImage-am572x-idk-lcd-osd101t2045-jh.dtb
    am57xx-evm-cam-ov10635.dtb devicetree-zImage-am572x-idk-lcd-osd101t2045.dtb
    am57xx-evm-reva3-cam-mt9t111.dtb devicetree-zImage-am572x-idk-lcd-osd101t2587-jh.dtb
    am57xx-evm-reva3-cam-ov10635.dtb devicetree-zImage-am572x-idk-lcd-osd101t2587.dtb
    am57xx-evm-reva3.dtb devicetree-zImage-am572x-idk-pru-excl-uio.dtb
    am57xx-evm.dtb devicetree-zImage-am572x-idk.dtb
    devicetree-uImage-am571x-idk-lcd-osd101t2045.dtb devicetree-zImage-am57xx-beagle-x15-revb1.dtb
    devicetree-uImage-am571x-idk-lcd-osd101t2587.dtb devicetree-zImage-am57xx-beagle-x15.dtb
    devicetree-uImage-am571x-idk-pru-excl-uio.dtb devicetree-zImage-am57xx-evm-cam-mt9t111.dtb
    devicetree-uImage-am571x-idk.dtb devicetree-zImage-am57xx-evm-cam-ov10635.dtb
    devicetree-uImage-am572x-evm-jailhouse.dtb devicetree-zImage-am57xx-evm-reva3-cam-mt9t111.dtb
    devicetree-uImage-am572x-idk-jailhouse.dtb devicetree-zImage-am57xx-evm-reva3-cam-ov10635.dtb
    devicetree-uImage-am572x-idk-lcd-osd101t2045-jh.dtb devicetree-zImage-am57xx-evm-reva3.dtb
    devicetree-uImage-am572x-idk-lcd-osd101t2045.dtb devicetree-zImage-am57xx-evm.dtb.old
    devicetree-uImage-am572x-idk-lcd-osd101t2587-jh.dtb uImage
    devicetree-uImage-am572x-idk-lcd-osd101t2587.dtb uImage-4.9.41-rt23-gc038d21a22
    devicetree-uImage-am572x-idk-pru-excl-uio.dtb vmlinux-4.9.41-rt23-gc038d21a22
    devicetree-uImage-am572x-idk.dtb zImage
    devicetree-uImage-am57xx-beagle-x15-revb1.dtb zImage-4.9.41-rt23-gc038d21a22
    I've added the above changes in arch/arm/boot/dts/am57xx-beagle-x15-common.dtsi and compiled the kernel. Then copied the newly built am57xx-evm.dtb on bootable sd card using the following command:
    sudo cp <path_to_linux_kernel>/arch/arm/boot/dts/am57xx-evm.dtb /media/ykovachev/rootfs/boot/devicetree-uImage-am57xx-evm.dtb
    And that was it. I didn't need to change the kernel image.
    Yordan
  • ok,i will try the sd card mode , i used the tftp boot mode using  zImage-am57xx-evm.bin and dtb  am57xx-evm-reva3.dtb .
  • At last , it works . I cp rename arch/arm/boot/dts/am57xx-evm.dtb to my tftpboot am57xx-evm-reva3.dtb
  • Please click the "This resolved my issue" button, to close the thread.
    Yordan
  • cause it is not my first post thread ,sorry i have no idea to close it.
