Part Number: AM5728
Tool/software: TI-RTOS
I'm following this wiki page "http://processors.wiki.ti.com/index.php/Linux_IPC_on_AM57xx"
Part Number: AM5728
Ahmed,
That symbol is part of the profiling library.
Can you add following to the configuration just before including the GPIO driver module.
/* Load Profiling package */
var Utils = xdc.loadPackage('ti.utils.profiling');
Other way to solve this might be to remove following flags from compiler options.
--entry_parm=address --exit_hook=ti_utils_exit --exit_parm=address --entry_hook=ti_utils_entry
Hope this resolves your issue.
Regard,s
Rahul
After adding "var Utils = xdc.loadPackage('ti.utils.profiling'); " in cfg file, previous error is gone. Now I've getting following error.
Description: #10099-D configPkg/linker.cmd program will not fit into available memory. run placement with alignment fails for section ".fardata" size 0x4001f4e . Available memory ranges:
Following is my gpio_test_evmAM572x.cfg
Please suggest something.
Thanks.
Following is the content of linker.cmd file generated by above gpio_test_evmAM572x.cfg
* Do not modify this file; it is automatically generated from the template
* linkcmd.xdt in the ti.targets.elf package and will be overwritten.
* put '"'s around paths because, without this, the linker
* considers '-' as minus operator, not a file name character.
-l"/home/ghumman/programming/CCS/beagleX15_dsp_blink_with_ipc/Debug/configPkg/package/cfg/gpio_test_evmAM572x_pe66.oe66"
-l"/home/ghumman/programming/CCS/beagleX15_dsp_blink_with_ipc/src/ipc/ipc.ae66"
-l"/root/ti/ipc_3_46_00_02/packages/ti/pm/lib/debug/ti.pm_null.ae66"
-l"/home/ghumman/programming/CCS/beagleX15_dsp_blink_with_ipc/src/utils/utils.ae66"
-l"/root/ti/ipc_3_46_00_02/packages/ti/deh/lib/debug/ti.deh_vayu.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/board/lib/evmAM572x/c66/release/ti.board.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/drv/spi/lib/c66/release/ti.drv.spi.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/drv/i2c/lib/c66/release/ti.drv.i2c.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/drv/uart/lib/c66/release/ti.drv.uart.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/drv/gpio/lib/am572x/c66/release/ti.drv.gpio.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/csl/lib/am572x/c66/release/ti.csl.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/osal/lib/tirtos/c66/release/ti.osal.ae66"
-l"/root/ti/pdk_am57xx_1_0_7/packages/ti/utils/profiling/lib/c66/release/ti.utils.profiling.ae66"
-l"/root/ti/bios_6_46_05_55/packages/ti/targets/rts6000/lib/ti.targets.rts6000.ae66"
-l"/root/ti/bios_6_46_05_55/packages/ti/targets/rts6000/lib/boot.ae66"
-l"/home/ghumman/programming/CCS/beagleX15_dsp_blink_with_ipc/src/sysbios/sysbios.ae66"
-l"/root/ti/ipc_3_46_00_02/packages/ti/trace/lib/debug/ti.trace.ae66"
--retain="*(xdc.meta)"
--args 0x64
-heap 0x0
-stack 0x8000
MEMORY
L2SRAM (RWX) : org = 0x800000, len = 0x40000
OCMC_RAM1 (RWX) : org = 0x40300000, len = 0x80000
OCMC_RAM2 (RWX) : org = 0x40400000, len = 0x100000
OCMC_RAM3 (RWX) : org = 0x40500000, len = 0x100000
EXT_CODE (RWX) : org = 0x95000000, len = 0x100000
EXT_DATA (RW) : org = 0x95100000, len = 0x100000
EXT_HEAP (RW) : org = 0x95200000, len = 0x300000
TRACE_BUF (RW) : org = 0x9f000000, len = 0x60000
EXC_DATA (RW) : org = 0x9f060000, len = 0x10000
PM_DATA (RWX) : org = 0x9f070000, len = 0x20000
* Linker command file contributions from all loaded packages:
/* Content from xdc.services.global (null): */
/* Content from xdc (null): */
/* Content from xdc.corevers (null): */
/* Content from xdc.shelf (null): */
/* Content from xdc.services.spec (null): */
/* Content from xdc.services.intern.xsr (null): */
/* Content from xdc.services.intern.gen (null): */
/* Content from xdc.services.intern.cmd (null): */
/* Content from xdc.bld (null): */
/* Content from ti.targets (null): */
/* Content from ti.targets.elf (null): */
/* Content from xdc.rov (null): */
/* Content from xdc.services.getset (null): */
/* Content from ti.sdo.ipc.family (null): */
/* Content from ti.catalog.c6000 (null): */
/* Content from ti.catalog (null): */
/* Content from ti.catalog.peripherals.hdvicp2 (null): */
/* Content from xdc.platform (null): */
/* Content from xdc.cfg (null): */
/* Content from ti.catalog.arp32 (null): */
/* Content from ti.catalog.arm.cortexm4 (null): */
/* Content from ti.catalog.arm.cortexa15 (null): */
/* Content from ti.platforms.evmDRA7XX (null): */
/* Content from ti.trace (null): */
/* Content from ti.sysbios.hal (null): */
/* Content from ti.sysbios.interfaces (null): */
/* Content from xdc.runtime (null): */
/* Content from ti.sysbios.knl (null): */
/* Content from ti.sysbios (null): */
/* Content from ti.sysbios.family.c64p (ti/sysbios/family/c64p/linkcmd.xdt): */
/* Content from ti.sysbios.family.c66 (ti/sysbios/family/c66/linkcmd.xdt): */
ti_sysbios_family_c66_Cache_l1dSize = 32768;
ti_sysbios_family_c66_Cache_l1pSize = 32768;
ti_sysbios_family_c66_Cache_l2Size = 0;
/* Content from ti.sysbios.rts (ti/sysbios/rts/linkcmd.xdt): */
/* Content from ti.sysbios.rts.ti (ti/sysbios/rts/ti/linkcmd.xdt): */
/* Content from ti.sysbios.timers.dmtimer (null): */
/* Content from ti.sysbios.family (null): */
/* Content from ti.targets.rts6000 (null): */
/* Content from ti.utils.profiling (null): */
/* Content from ti.osal (null): */
/* Content from ti.csl (null): */
/* Content from ti.drv.gpio (null): */
/* Content from ti.drv.uart (null): */
/* Content from ti.drv.i2c (null): */
/* Content from ti.drv.spi (null): */
/* Content from ti.board (null): */
/* Content from ti.deh (null): */
/* Content from ti.sysbios.gates (null): */
/* Content from ti.sysbios.heaps (null): */
/* Content from xdc.runtime.knl (null): */
/* Content from ti.sdo.utils (null): */
/* Content from ti.sdo.ipc.interfaces (null): */
/* Content from ti.sysbios.syncs (null): */
/* Content from ti.sysbios.family.c62 (null): */
/* Content from ti.sysbios.xdcruntime (null): */
/* Content from ti.pm (null): */
/* Content from ti.sysbios.family.shared.vayu (null): */
/* Content from ti.sysbios.utils (null): */
/* Content from ti.ipc.remoteproc (ti/ipc/remoteproc/linkcmd.xdt): */
* Set entry point to the HWI reset vector 0 to automatically satisfy
* any alignment constraints for the boot vector.
-eti_sysbios_family_c64p_Hwi0
* We just modified the entry point, so suppress "entry point symbol other
* than _c_int00 specified" warning.
--diag_suppress=10063
/* Content from ti.sdo.ipc.family.vayu (null): */
/* Content from ti.sdo.ipc.notifyDrivers (null): */
/* Content from ti.sdo.ipc (ti/sdo/ipc/linkcmd.xdt): */
SECTIONS
ti_sdo_ipc_init: load > EXT_DATA, type = NOINIT
/* Content from ti.ipc.ipcmgr (null): */
/* Content from ti.ipc.transports (null): */
/* Content from ti.ipc.rpmsg (null): */
/* Content from ti.ipc.family.vayu (null): */
/* Content from ti.ipc.namesrv (null): */
/* Content from ti.sdo.ipc.heaps (null): */
/* Content from ti.sdo.ipc.gates (null): */
/* Content from configPkg (null): */
/* Content from xdc.services.io (null): */
/* Content from ti.sdo.ipc.family.ti81xx (null): */
* symbolic aliases for static instance objects
xdc_runtime_Startup__EXECFXN__C = 1;
xdc_runtime_Startup__RESETFXN__C = 1;
SECTIONS
.text: load >> EXT_CODE
.ti.decompress: load > EXT_CODE
.stack: load > EXT_DATA
GROUP: load > EXT_DATA
.bss:
.neardata:
.rodata:
.cinit: load > EXT_DATA
.pinit: load >> EXT_DATA
.init_array: load > EXT_DATA
.const: load >> EXT_DATA
.data: load >> EXT_DATA
.fardata: load >> EXT_DATA
.switch: load >> EXT_DATA
.sysmem: load > EXT_DATA
.far: load >> EXT_DATA
.args: load > EXT_DATA align = 0x4, fill = 0 {_argsize = 0x64; }
.cio: load >> EXT_DATA
.ti.handler_table: load > EXT_DATA
.c6xabi.exidx: load > EXT_DATA
.c6xabi.extab: load >> EXT_DATA
systemHeap: load > EXT_DATA
.tracebuf: load > TRACE_BUF
.errorbuf: load > EXC_DATA
.resource_table: load > 0x95000000, type = NOINIT
.vecs: load > EXT_CODE
xdc.meta: load > EXT_DATA, type = COPY
Ahmed,
Please attach source and configuration files into E2E rather than copy pasting it into the forum. The formatting of the text is lost and things are difficult to parse and follow. I have done this with your last 2 post, please use the Rich Formatting feature and attach the files in the forum.
The same build issue is discussed here so check this post for resolution:
https://e2e.ti.com/support/development_tools/compiler/f/343/t/576965?pi317851=2
Hope this helps.
Rahul
Sorry about that. I'm attaching the files now. I did follow this post(https://e2e.ti.com/support/development_tools/compiler/f/343/t/576965?pi317851=2). Once I added following three lines at the end of gpio_test_evmAM572x.cfg,
Memory.defaultHeapInstance = Program.global.heap0;
Program.sectMap["systemHeap"] = Program.platform.stackMemory;
Program.sectMap[".fardata:benchmarking"] = "DDR3";
the error changes to:
#10099-D configPkg/linker.cmd program will not fit into available memory. run placement with alignment fails for section ".fardata:benchmarking" size 0x4000000
#10265 configPkg/linker.cmd no valid memory range(null) available for placement of ".fardata:benchmarking"
Following screenshots show my CSS General Settings.
