Part Number: TMDSICE3359
Other Parts Discussed in Thread: TPIC2810, AM3359, TPS65910
I am trying to run emac on linux rt. I am using the following link :
But when ifup eth0 is run the following error is occurring :-ifconfig: SIOCGIFFLAGS: No such device .
I am using iceam335x board and my jumper settings are correct. I am using the pru mode. What is the issue?
Paramesh
The console log is attached here for reference.
paramu@paramu-OptiPlex-3020:~$ minicom -w -s
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB1, 15:31:00
Press CTRL-A Z for help on special keys
[ 6.220126] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.259538] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 6.310366] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.379995] gpio-decoder gpio-decoder: unable to acquire input gpios
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ 6.462912] 0-0041 supply vcc not found, using dummy regulator
[ 6.488626] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.640649] input: gpio-decoder as /devices/platform/gpio-decoder/input/input
0
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Reached target Basic System.
[ OK ] Started System Logging Service.
Starting Print notice about GPLv3 packages...
Starting Telephony service...
[ OK ] Started D-Bus System Message Bus.
[ 7.816153] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 7.892045] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 7.969768] remoteproc remoteproc0: wkup_m3 is available
[ 7.975911] ti-pruss 4a300000.pruss: creating PRU cores and other child platf
orm devices
[ 8.025634] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 8.034822] PM: Cannot get wkup_m3_ipc handle
[ 8.077954] PM: Cannot get wkup_m3_ipc handle
[ 8.078034] remoteproc remoteproc0: powering up wkup_m3
[ 8.102312] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf,
size 224352
[ 8.102788] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 8.102821] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 8.199476] davinci_mdio 4a332400.mdio: davinci mdio revision 1.6
[ 8.199489] libphy: 4a332400.mdio: probed
[ 8.280907] PM: bootloader does not support rtc-only!
[ 8.363067] davinci_mdio 4a332400.mdio: phy[1]: device 4a332400.mdio:01, driv
er TI TLK10X 10/100 Mbps PHY
[ 8.363077] davinci_mdio 4a332400.mdio: phy[3]: device 4a332400.mdio:03, driv
[ 8.370173] remoteproc remoteproc1: 4a334000.pru0 is available
[ 8.370263] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a3260
00/pruss@4a300000/pru@4a334000 probed successfully
[ 8.370695] remoteproc remoteproc2: 4a338000.pru1 is available
[ 8.370769] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a3260
00/pruss@4a300000/pru@4a338000 probed successfully
[ 8.619943] Unable to handle kernel NULL pointer dereference at virtual addre
ss 00000000
[ 8.619951] pgd = ce024000
[ 8.619960] [00000000] *pgd=00000000
[ 8.619971] Internal error: Oops: 805 [#1] PREEMPT ARM
[ 8.620018] Modules linked in: prueth(+) pru_rproc pm33xx pruss wkup_m3_rproc
pruss_intc wkup_m3_ipc omap_aes_driver(+) remoteproc crypto_engine omap_sham ti
_emif_sram pruss_soc_bus gpio_tpic2810 gpio_pca953x gpio_pisosr rtc_omap omap_wd
t ti_am335x_tscadc gpio_decoder input_polldev sch_fq_codel uio_module_drv(O) uio
cryptodev(O)
[ 8.620034] CPU: 0 PID: 154 Comm: systemd-udevd Tainted: G O 4.9
.28-rt16-g786e64041b #1
[ 8.620036] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 8.620041] task: ce0c8d00 task.stack: cf7e2000
[ 8.620063] PC is at memset+0x30/0xe0
[ 8.620069] LR is at 0x0
[ 8.620076] pc : [<c03aa990>] lr : [<00000000>] psr: 200d0113
[ 8.620076] sp : cf7e3c48 ip : 00000000 fp : cf7e3cac
[ 8.620080] r10: ce1a7d90 r9 : ce06e162 r8 : 00000000
[ 8.620084] r7 : 00000000 r6 : ce06e020 r5 : cfda0e40 r4 : ce06e010
[ 8.620088] r3 : 00000000 r2 : 0000ffc0 r1 : 00000000 r0 : 00000000
[ 8.620094] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 8.620099] Control: 10c5387d Table: 8e024019 DAC: 00000051
[ 8.620104] Process systemd-udevd (pid: 154, stack limit = 0xcf7e2208)
[ 8.620109] Stack: (0xcf7e3c48 to 0xcf7e4000)
[ 8.620118] 3c40: ce06e162 bf0a7db0 00000000 ce28b550 cf164
410 c09c9250
[ 8.620128] 3c60: 00000001 00000000 cf7e3c9c ce06e14a cf162a10 ce06e116 fffff
fff cfda0a74
[ 8.620138] 3c80: cf162a18 cf162a10 ffffffed bf0aa6a8 fffffdfb bf0aa6a8 00000
01c 00000000
[ 8.620147] 3ca0: cf7e3ccc cf7e3cb0 c04ff6a0 bf0a74e4 cf162a10 c0c83dd0 c0c83
de0 00000000
[ 8.620157] 3cc0: cf7e3cf4 cf7e3cd0 c04fdf34 c04ff654 cf162a10 bf0aa6a8 cf162
a44 00000000
[ 8.620167] 3ce0: ce436d00 d0c59000 cf7e3d14 cf7e3cf8 c04fe0a0 c04fdd30 00000
000 bf0aa6a8
[ 8.620177] 3d00: c04fdfe0 00000000 cf7e3d3c cf7e3d18 c04fc0d4 c04fdfec cf002
664 cf149c44
[ 8.620186] 3d20: cf002688 bf0aa6a8 ce2e0600 c0c324b8 cf7e3d4c cf7e3d40 c04fd
7b0 c04fc070
[ 8.620196] 3d40: cf7e3d74 cf7e3d50 c04fd2f0 c04fd798 bf0aa394 cf7e3d60 bf0aa
6a8 ffffe000
[ 8.620206] 3d60: bf0aa7c0 ce4360c0 cf7e3d8c cf7e3d78 c04fe5e8 c04fd1ec c0c32
4b8 ffffe000
[ 8.620216] 3d80: cf7e3da4 cf7e3d90 c04ff5fc c04fe574 bf0ae000 ffffe000 cf7e3
db4 cf7e3da8
[ 8.620226] 3da0: bf0ae01c c04ff5c0 cf7e3e34 cf7e3db8 c010172c bf0ae00c ce436
d00 d0c59000
[ 8.620236] 3dc0: cf7e3e14 cf7e3dd0 c01bcf14 c0788da8 cf7e3dfc cf7e3de0 c01ee
42c ffffe000
[ 8.620245] 3de0: 00000001 ce436d00 d0c59000 00000000 ce4360c0 d0c59000 00000
001 0000000d
[ 8.620255] 3e00: ce4360c0 d0c59000 00000001 bf0aa7c0 00000001 bf0aa7c0 ce436
0c0 ce436d00
[ 8.620264] 3e20: d0c59000 ce436d24 cf7e3e5c cf7e3e38 c01b40b8 c01016ec bf0aa
7c0 00000001
[ 8.620274] 3e40: cf7e3f44 00000001 bf0aa7c0 00000001 cf7e3f1c cf7e3e60 c0192
314 c01b405c
[ 8.620283] 3e60: bf0aa7cc 00007fff bf0aa7c0 c018f730 bf000000 c0992650 c0992
628 c0992680
[ 8.620293] 3e80: c099261c c0804180 bf0aa7cc d0c65fb0 bf0aa958 cf7e3f44 bf0aa
808 bf0aa7c0
[ 8.620303] 3ea0: cf7e3eec cf7e3eb0 c0212914 c0212254 d0c59000 00000000 00000
000 00000000
[ 8.620312] 3ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[ 8.620321] 3ee0: 00000000 00000000 00000000 00000000 7fffffff 00000000 00000
011 b6eb9f60
[ 8.620331] 3f00: 0000017b c0107dc4 cf7e2000 00000000 cf7e3fa4 cf7e3f20 c0192
8c8 c0190514
[ 8.620340] 3f20: 7fffffff 00000000 00000003 cf7e3f38 c01d3c30 d0c59000 0000d
000 00000000
[ 8.620350] 3f40: 00000000 d0c59000 0000d000 d0c65c18 d0c65b38 d0c62f14 00006
af0 000079b0
[ 8.620359] 3f60: 00000000 00000000 00000000 00002c48 00000017 00000018 00000
011 0000000e
[ 8.620368] 3f80: 0000000a 00000000 00000000 7f658678 00000000 00000000 00000
000 cf7e3fa8
[ 8.620377] 3fa0: c0107c00 c0192824 7f658678 00000000 00000011 b6eb9f60 00000
000 00000000
[ 8.620387] 3fc0: 7f658678 00000000 00000000 0000017b 7f653094 7f642018 00000
000 7f6579e8
[ 8.620396] 3fe0: bee7c9e0 bee7c9d0 b6eb2be4 b6e049f2 600f0030 00000011 00000
000 00000000
[ 8.620400] Backtrace:
[ 8.620480] [<bf0a74d8>] (prueth_probe [prueth]) from [<c04ff6a0>] (platform_
drv_probe+0x58/0xb8)
[ 8.620492] r10:00000000 r9:0000001c r8:bf0aa6a8 r7:fffffdfb r6:bf0aa6a8 r5:
ffffffed
[ 8.620495] r4:cf162a10
[ 8.620508] [<c04ff648>] (platform_drv_probe) from [<c04fdf34>] (driver_probe
_device+0x210/0x2bc)
[ 8.620515] r7:00000000 r6:c0c83de0 r5:c0c83dd0 r4:cf162a10
[ 8.620525] [<c04fdd24>] (driver_probe_device) from [<c04fe0a0>] (__driver_at
tach+0xc0/0xc4)
[ 8.620534] r9:d0c59000 r8:ce436d00 r7:00000000 r6:cf162a44 r5:bf0aa6a8 r4:c
f162a10
[ 8.620543] [<c04fdfe0>] (__driver_attach) from [<c04fc0d4>] (bus_for_each_de
v+0x70/0xa4)
[ 8.620550] r7:00000000 r6:c04fdfe0 r5:bf0aa6a8 r4:00000000
[ 8.620559] [<c04fc064>] (bus_for_each_dev) from [<c04fd7b0>] (driver_attach+
0x24/0x28)
[ 8.620564] r6:c0c324b8 r5:ce2e0600 r4:bf0aa6a8
[ 8.620573] [<c04fd78c>] (driver_attach) from [<c04fd2f0>] (bus_add_driver+0x
110/0x21c)
[ 8.620583] [<c04fd1e0>] (bus_add_driver) from [<c04fe5e8>] (driver_register+
0x80/0xfc)
[ 8.620590] r7:ce4360c0 r6:bf0aa7c0 r5:ffffe000 r4:bf0aa6a8
[ 8.620599] [<c04fe568>] (driver_register) from [<c04ff5fc>] (__platform_driv
er_register+0x48/0x50)
[ 8.620604] r5:ffffe000 r4:c0c324b8
[ 8.620627] [<c04ff5b4>] (__platform_driver_register) from [<bf0ae01c>] (prue
th_driver_init+0x1c/0x24 [prueth])
[ 8.620632] r5:ffffe000 r4:bf0ae000
[ 8.620656] [<bf0ae000>] (prueth_driver_init [prueth]) from [<c010172c>] (do_
one_initcall+0x4c/0x178)
[ 8.620672] [<c01016e0>] (do_one_initcall) from [<c01b40b8>] (do_init_module+
0x68/0x3b0)
[ 8.620682] r10:ce436d24 r9:d0c59000 r8:ce436d00 r7:ce4360c0 r6:bf0aa7c0 r5:
00000001
[ 8.620685] r4:bf0aa7c0
[ 8.620698] [<c01b4050>] (do_init_module) from [<c0192314>] (load_module+0x1e
0c/0x21a0)
[ 8.620705] r7:00000001 r6:bf0aa7c0 r5:00000001 r4:cf7e3f44
[ 8.620714] [<c0190508>] (load_module) from [<c01928c8>] (SyS_finit_module+0x
b0/0xc0)
[ 8.620723] r10:00000000 r9:cf7e2000 r8:c0107dc4 r7:0000017b r6:b6eb9f60 r5:
00000011
[ 8.620726] r4:00000000
[ 8.620740] [<c0192818>] (SyS_finit_module) from [<c0107c00>] (ret_fast_sysca
ll+0x0/0x44)
[ 8.620745] r6:00000000 r5:00000000 r4:7f658678
[ 8.620755] Code: e92d4100 e1a08001 e1a0e001 e2522040 (a8ac410a)
[ 8.620763] ---[ end trace 0000000000000002 ]---
[ 8.673217] Bluetooth: Core ver 2.22
[ 8.673318] NET: Registered protocol family 31
[ 8.673323] Bluetooth: HCI device and connection manager initialized
[ 8.673347] Bluetooth: HCI socket layer initialized
[ 8.673359] Bluetooth: L2CAP socket layer initialized
[ 8.673399] Bluetooth: SCO socket layer initialized
[ 10.781634] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data
may be corrupt. Please run fsck.
[ OK ] Started Telephony service.
[ 15.174090] omap-aes 53500000.aes: will run requests pump with realtime prior
ity
Starting Network Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting uim-sysfs.service...
[ OK ] Started Kernel Logging Service.
Starting Login Service...
[ OK ] Started Network Service.
[ OK ] Found device /dev/ttyS3.
[ OK ] Found device /dev/ttyS0.
[ OK ] Found device /dev/mmcblk0p1.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
libreadline-dev
libreadline6
m4-dev
m4
make
nettle
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Start USB gadget...
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Network Name Resolution...
Starting Simple Network Management Protocol (SNMP) Daemon....
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting Permit User Sessions...
Starting Enable and configure wl18xx bluetooth stack...
[ 20.364012] random: crng init done
[ 20.385954] udc-core: couldn't find an available UDC - added [g_multi] to lis
t of pending drivers
Starting Lightning Fast Webserver With Light System Requirements...
[ OK ] Started Network Name Resolution.
[ OK ] Started Permit User Sessions.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Login Service.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ 21.215513] NET: Registered protocol family 15
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ 22.608437] Initializing XFRM netlink socket
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting thttpd.service...
Starting busybox-udhcpd.service...
[ OK ] Started busybox-udhcpd.service.
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting SYSV: The kdump script provides the support:...
[FAILED] Failed to start SYSV: The kdump script provides the support:.
See 'systemctl status kdump.service' for details.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
Starting parse-ip.service...
[ OK ] Started thermal-zone-init.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS3
Arago 2017.05 am335x-evm ttyS3
am335x-evm login: root
root@am335x-evm:~# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%763860/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:160 errors:0 dropped:0 overruns:0 frame:0
TX packets:160 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:12160 (11.8 KiB) TX bytes:12160 (11.8 KiB)
root@am335x-evm:~# ifup eth0
root@am335x-evm:~# ETH0, PRU
ETH1, PRU
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
3552128 bytes read in 432 ms (7.8 MiB/s)
39304 bytes read in 68 ms (564.5 KiB/s)
Loading Device Tree to 8df1a000, end 8df26987 ... OK
Fixing up ETH0 & ETH1 to PRUSS Ethernet
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.28-rt16-g786e64041b (gtbldadm@ubuntu-16) (gcc v
ersion 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 PREEMPT RT Wed Jun 28 18:10:
09 EDT 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio
n cache
[ 0.000000] OF: fdt:Machine model: TI AM3359 ICE-V2
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x8a800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 64960
[ 0.000000] Kernel command line: console=ttyO3,115200n8 root=PARTUUID=fc5f42d
d-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 198280K/262144K available (7168K kernel code, 290K rwdata
, 2408K rodata, 1024K init, 316K bss, 14712K reserved, 49152K cma-reserved, 0K h
ighmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
[ 0.000000] .init : 0xc0b00000 - 0xc0c00000 (1024 kB)
[ 0.000000] .data : 0xc0c00000 - 0xc0c488e0 ( 291 kB)
[ 0.000000] .bss : 0xc0c488e0 - 0xc0c97960 ( 317 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup
ts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478
484971ns
[ 0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max
_idle_ns: 79635851949 ns
[ 0.000036] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000216] clocksource_probe: no matching clocksources found
[ 0.000388] Console: colour dummy device 80x30
[ 0.000534] WARNING: Your 'console=ttyO3' has been replaced by 'ttyS3'
[ 0.000537] This ensures that you still see kernel messages. Please
[ 0.000539] update your kernel commandline.
[ 0.089122] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089128] pid_max: default: 32768 minimum: 301
[ 0.089257] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089263] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090147] CPU: Testing write buffer coherency: ok
[ 0.090476] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.091679] EFI services will not be available.
[ 0.093070] devtmpfs: initialized
[ 0.106801] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 3
[ 0.107162] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 19112604462750000 ns
[ 0.107192] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.110939] pinctrl core: initialized pinctrl subsystem
[ 0.112269] NET: Registered protocol family 16
[ 0.114691] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.129594] omap_hwmod: debugss: _wait_target_disable failed
[ 0.187372] GPIO line 7 (FET_SWITCH_CTRL) hogged as output/high
[ 0.189709] OMAP GPIO hardware version 0.1
[ 0.195760] GPIO line 100 (PR1_MII_CTRL) hogged as output/high
[ 0.195787] GPIO line 106 (MUX_MII_CTL1) hogged as output/low
[ 0.205220] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.222088] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.225872] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wk
up@44c00000/scm@210000/pinmux@800/i2c0_pins_default, deferring probe
[ 0.226001] media: Linux media interface: v0.10
[ 0.226062] Linux video capture interface: v2.00
[ 0.226106] pps_core: LinuxPPS API ver. 1 registered
[ 0.226114] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[ 0.226140] PTP clock support registered
[ 0.226182] EDAC MC: Ver: 3.0.0
[ 0.227370] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.227717] Advanced Linux Sound Architecture Driver Initialized.
[ 0.229069] clocksource: Switched to clocksource timer1
[ 0.240630] NET: Registered protocol family 2
[ 0.241503] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.241550] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
[ 0.241651] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.241727] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.241765] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.241960] NET: Registered protocol family 1
[ 0.242447] RPC: Registered named UNIX socket transport module.
[ 0.242462] RPC: Registered udp transport module.
[ 0.242469] RPC: Registered tcp transport module.
[ 0.242476] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.243406] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter
s available
[ 0.245886] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.254441] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.255499] NFS: Registering the id_resolver key type
[ 0.255545] Key type id_resolver registered
[ 0.255554] Key type id_legacy registered
[ 0.255604] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.257599] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
47)
[ 0.257621] io scheduler noop registered
[ 0.257629] io scheduler deadline registered
[ 0.257808] io scheduler cfq registered (default)
[ 0.258669] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl
-cells = <1>
[ 0.259292] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.329015] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.332568] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 158, base_baud =
3000000) is a 8250
[ 0.927409] console [ttyS3] enabled
[ 0.932827] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 0.939633] [drm] Initialized
[ 0.957098] brd: module loaded
[ 0.967208] loop: module loaded
[ 0.973555] m25p80 spi1.0: found s25fl064k, expected w25q64
[ 0.979229] m25p80 spi1.0: s25fl064k (8192 Kbytes)
[ 0.984084] 4 ofpart partitions found on MTD device spi1.0
[ 0.989594] Creating 4 MTD partitions on "spi1.0":
[ 0.994413] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 1.001217] 0x000000080000-0x000000180000 : "u-boot"
[ 1.007501] 0x000000180000-0x0000001a0000 : "u-boot-env"
[ 1.014154] 0x0000001a0000-0x000000800000 : "misc"
[ 1.021272] libphy: Fixed MDIO Bus: probed
[ 1.027628] mousedev: PS/2 mouse device common for all mice
[ 1.033815] i2c /dev entries driver
[ 1.043619] NET: Registered protocol family 10
[ 1.049687] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.056487] NET: Registered protocol family 17
[ 1.061231] Key type dns_resolver registered
[ 1.065763] omap_voltage_late_init: Voltage driver support not added
[ 1.109352] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.117490] vrtc: supplied by vbat
[ 1.124664] vio: supplied by vbat
[ 1.129508] vdd1: supplied by vbat
[ 1.134762] vdd2: supplied by vbat
[ 1.141495] vdig1: supplied by vbat
[ 1.146364] vdig2: supplied by vbat
[ 1.151225] vpll: supplied by vbat
[ 1.156003] vdac: supplied by vbat
[ 1.160795] vaux1: supplied by vbat
[ 1.165660] vaux2: supplied by vbat
[ 1.170520] vaux33: supplied by vbat
[ 1.175488] vmmc: supplied by vbat
[ 1.179807] random: fast init done
[ 1.183705] vbb: supplied by vbat
[ 1.188533] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.249724] hctosys: unable to open rtc device (rtc0)
[ 1.255565] ALSA device list:
[ 1.261385] No soundcards found.
[ 1.268635] Waiting for root device PARTUUID=fc5f42dd-02...
[ 1.296353] mmc0: host does not support reading read-only switch, assuming wr
ite-enable
[ 1.306366] mmc0: new high speed SDHC card at address 0007
[ 1.312638] mmcblk0: mmc0:0007 SS08G 7.21 GiB
[ 1.318759] mmcblk0: p1 p2
[ 1.616759] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[ 1.624980] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.635197] devtmpfs: mounted
[ 1.639791] Freeing unused kernel memory: 1024K (c0b00000 - c0c00000)
[ 1.999641] systemd[1]: System time before build time, advancing clock.
[ 2.090971] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SEL
INUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +
XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.109781] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.05!
[ 2.150722] systemd[1]: Set hostname to <am335x-evm>.
[ 2.490480] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown
lvalue 'ExecStopPre' in section 'Service'
[ 2.784821] systemd[1]: alignment.service: Found ordering cycle on alignment.
service/start
[ 2.793194] systemd[1]: alignment.service: Found dependency on sysinit.target
/start
[ 2.800929] systemd[1]: alignment.service: Found dependency on alignment.serv
ice/start
[ 2.808902] systemd[1]: alignment.service: Breaking ordering cycle by deletin
g job alignment.service/start
[ 2.818620] systemd[1]: alignment.service: Job alignment.service/start delete
d to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 2.864859] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Reached target Swap.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice System Slice.
[ OK ] Reached target Slices.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on udev Kernel Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket.
Starting Load Kernel Modules...
[ 3.467717] cryptodev: loading out-of-tree module taints kernel.
Mounting Temporary Directory...
[ 3.482269] cryptodev: driver 1.8 loaded.
Mounting Debug File System...
Starting Journal Service...
Starting Remount Root and Kernel File Systems...
Starting Create Static Device Nodes in /dev...
[ 3.682705] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting Setup Virtual Console...
Mounting POSIX Message Queue File System...
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Journal Service.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Setup Virtual Console.
Starting udev Kernel Device Manager...
Starting udev Coldplug all Devices...
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Mounting /media/ram...
Starting Apply Kernel Variables...
Mounting Configuration File System...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Configuration File System.
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Apply Kernel Variables.
[ 4.765660] systemd-journald[104]: Received request to flush runtime journal
from PID 1
[ OK ] Reached target Local File Systems.
Starting Load/Save Random Seed...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Load/Save Random Seed.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 6.290427] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.411883] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.490824] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.500258] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 6.555988] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 6.576785] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 7.138506] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 7.240098] 0-0041 supply vcc not found, using dummy regulator
[ 7.292763] input: gpio-decoder as /devices/platform/gpio-decoder/input/input
0
[ 8.627010] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 8.786911] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 8.806287] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 8.812061] omap-aes 53500000.aes: will run requests pump with realtime prior
ity
[ 8.830138] remoteproc remoteproc0: wkup_m3 is available
[ 8.959014] ti-pruss 4a300000.pruss: creating PRU cores and other child platf
orm devices
[ 9.049235] davinci_mdio 4a332400.mdio: davinci mdio revision 1.6
[ 9.049245] libphy: 4a332400.mdio: probed
[ 9.208985] Bluetooth: Core ver 2.22
[ 9.274793] davinci_mdio 4a332400.mdio: phy[1]: device 4a332400.mdio:01, driv
[ 9.274803] davinci_mdio 4a332400.mdio: phy[3]: device 4a332400.mdio:03, driv
[ 9.281318] remoteproc remoteproc1: 4a334000.pru0 is available
[ 9.281412] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a3260
[ 9.285196] NET: Registered protocol family 31
[ 9.285204] Bluetooth: HCI device and connection manager initialized
[ 9.285233] Bluetooth: HCI socket layer initialized
[ 9.285246] Bluetooth: L2CAP socket layer initialized
[ 9.285293] Bluetooth: SCO socket layer initialized
[ 9.305480] remoteproc remoteproc2: 4a338000.pru1 is available
[ 9.305582] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a3260
[ 9.569696] Unable to handle kernel NULL pointer dereference at virtual addre
ss 00000000
[ 9.569704] pgd = cf7f4000
[ 9.569713] [00000000] *pgd=00000000
[ 9.569726] Internal error: Oops: 805 [#1] PREEMPT ARM
[ 9.569771] Modules linked in: prueth(+) pru_rproc bluetooth pruss pruss_intc
wkup_m3_rproc wkup_m3_ipc(+) remoteproc omap_aes_driver ti_emif_sram omap_sham
crypto_engine pruss_soc_bus gpio_pca953x gpio_tpic2810 gpio_pisosr rtc_omap omap
_wdt ti_am335x_tscadc gpio_decoder input_polldev sch_fq_codel uio_module_drv(O)
uio cryptodev(O)
[ 9.569786] CPU: 0 PID: 160 Comm: systemd-udevd Tainted: G O 4.9
[ 9.569789] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 9.569794] task: ce090680 task.stack: ce026000
[ 9.569816] PC is at memset+0x30/0xe0
[ 9.569822] LR is at 0x0
[ 9.569828] pc : [<c03aa990>] lr : [<00000000>] psr: 200f0113
[ 9.569828] sp : ce027c48 ip : 00000000 fp : ce027cac
[ 9.569832] r10: ce0a3850 r9 : ce52f762 r8 : 00000000
[ 9.569836] r7 : 00000000 r6 : ce52f620 r5 : cfda0e40 r4 : ce52f610
[ 9.569840] r3 : 00000000 r2 : 0000ffc0 r1 : 00000000 r0 : 00000000
[ 9.569846] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 9.569851] Control: 10c5387d Table: 8f7f4019 DAC: 00000051
[ 9.569855] Process systemd-udevd (pid: 160, stack limit = 0xce026208)
[ 9.569860] Stack: (0xce027c48 to 0xce028000)
[ 9.569870] 7c40: ce52f762 bf109db0 00000000 ce4ed410 cf164
410 c09c9250
[ 9.569880] 7c60: 00000001 00000000 ce027c9c ce52f74a cf162a10 ce52f716 fffff
fff cfda0a74
[ 9.569889] 7c80: cf162a18 cf162a10 ffffffed bf10c6a8 fffffdfb bf10c6a8 00000
01b 00000000
[ 9.569899] 7ca0: ce027ccc ce027cb0 c04ff6a0 bf1094e4 cf162a10 c0c83dd0 c0c83
de0 00000000
[ 9.569909] 7cc0: ce027cf4 ce027cd0 c04fdf34 c04ff654 cf162a10 bf10c6a8 cf162
a44 00000000
[ 9.569918] 7ce0: ce3a9f80 d0c93000 ce027d14 ce027cf8 c04fe0a0 c04fdd30 00000
000 bf10c6a8
[ 9.569928] 7d00: c04fdfe0 00000000 ce027d3c ce027d18 c04fc0d4 c04fdfec cf002
664 cf149c44
[ 9.569938] 7d20: cf002688 bf10c6a8 ce1ff280 c0c324b8 ce027d4c ce027d40 c04fd
7b0 c04fc070
[ 9.569948] 7d40: ce027d74 ce027d50 c04fd2f0 c04fd798 bf10c394 ce027d60 bf10c
6a8 ffffe000
[ 9.569958] 7d60: bf10c7c0 ce4ffdc0 ce027d8c ce027d78 c04fe5e8 c04fd1ec c0c32
4b8 ffffe000
[ 9.569968] 7d80: ce027da4 ce027d90 c04ff5fc c04fe574 bf110000 ffffe000 ce027
db4 ce027da8
[ 9.569977] 7da0: bf11001c c04ff5c0 ce027e34 ce027db8 c010172c bf11000c 00400
03e d0c93000
[ 9.569987] 7dc0: ce027e14 cffa13c4 ce026000 ce3a9300 cf001e40 cffa13c4 ce026
000 ce3a9280
[ 9.569997] 7de0: cf001e40 0000acf0 d0c93000 ce3a9fa4 ce027e2c ce027e00 c01fa
ea4 c01faa44
[ 9.570007] 7e00: 00000001 d0c93000 00000001 bf10c7c0 00000001 bf10c7c0 ce4ff
dc0 ce3a9f80
[ 9.570016] 7e20: d0c93000 ce3a9fa4 ce027e5c ce027e38 c01b40b8 c01016ec bf10c
7c0 00000001
[ 9.570026] 7e40: ce027f44 00000001 bf10c7c0 00000001 ce027f1c ce027e60 c0192
314 c01b405c
[ 9.570035] 7e60: bf10c7cc 00007fff bf10c7c0 c018f730 bf000000 c0992650 c0992
628 c0992680
[ 9.570045] 7e80: c099261c c0804180 bf10c7cc d0c9ffb0 bf10c958 ce027f44 bf10c
808 bf10c7c0
[ 9.570055] 7ea0: ce027eec ce027eb0 c0212914 c0212254 d0c93000 00000000 00000
000 00000000
[ 9.570064] 7ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[ 9.570073] 7ee0: 00000000 00000000 00000000 00000000 7fffffff 00000000 00000
011 b6ea2f60
[ 9.570082] 7f00: 0000017b c0107dc4 ce026000 00000000 ce027fa4 ce027f20 c0192
8c8 c0190514
[ 9.570092] 7f20: 7fffffff 00000000 00000003 ce027f38 c01d3c30 d0c93000 0000d
000 00000000
[ 9.570101] 7f40: 00000000 d0c93000 0000d000 d0c9fc18 d0c9fb38 d0c9cf14 00006
af0 000079b0
[ 9.570110] 7f60: 00000000 00000000 00000000 00002c48 00000017 00000018 00000
011 0000000e
[ 9.570120] 7f80: 0000000a 00000000 00000000 7f5f9870 00000000 00000000 00000
000 ce027fa8
[ 9.570129] 7fa0: c0107c00 c0192824 7f5f9870 00000000 00000011 b6ea2f60 00000
000 00000000
[ 9.570139] 7fc0: 7f5f9870 00000000 00000000 0000017b 7f5f6094 7f5e5018 00000
000 7f5fc918
[ 9.570148] 7fe0: bea6c9e0 bea6c9d0 b6e9bbe4 b6ded9f2 600f0030 00000011 00000
000 00000000
[ 9.570152] Backtrace:
[ 9.570231] [<bf1094d8>] (prueth_probe [prueth]) from [<c04ff6a0>] (platform_
[ 9.570242] r10:00000000 r9:0000001b r8:bf10c6a8 r7:fffffdfb r6:bf10c6a8 r5:
ffffffed
[ 9.570245] r4:cf162a10
[ 9.570257] [<c04ff648>] (platform_drv_probe) from [<c04fdf34>] (driver_probe
[ 9.570264] r7:00000000 r6:c0c83de0 r5:c0c83dd0 r4:cf162a10
[ 9.570274] [<c04fdd24>] (driver_probe_device) from [<c04fe0a0>] (__driver_at
tach+0xc0/0xc4)
[ 9.570283] r9:d0c93000 r8:ce3a9f80 r7:00000000 r6:cf162a44 r5:bf10c6a8 r4:c
f162a10
[ 9.570292] [<c04fdfe0>] (__driver_attach) from [<c04fc0d4>] (bus_for_each_de
v+0x70/0xa4)
[ 9.570299] r7:00000000 r6:c04fdfe0 r5:bf10c6a8 r4:00000000
[ 9.570308] [<c04fc064>] (bus_for_each_dev) from [<c04fd7b0>] (driver_attach+
0x24/0x28)
[ 9.570313] r6:c0c324b8 r5:ce1ff280 r4:bf10c6a8
[ 9.570322] [<c04fd78c>] (driver_attach) from [<c04fd2f0>] (bus_add_driver+0x
110/0x21c)
[ 9.570331] [<c04fd1e0>] (bus_add_driver) from [<c04fe5e8>] (driver_register+
0x80/0xfc)
[ 9.570338] r7:ce4ffdc0 r6:bf10c7c0 r5:ffffe000 r4:bf10c6a8
[ 9.570348] [<c04fe568>] (driver_register) from [<c04ff5fc>] (__platform_driv
[ 9.570352] r5:ffffe000 r4:c0c324b8
[ 9.570376] [<c04ff5b4>] (__platform_driver_register) from [<bf11001c>] (prue
[ 9.570381] r5:ffffe000 r4:bf110000
[ 9.570405] [<bf110000>] (prueth_driver_init [prueth]) from [<c010172c>] (do_
[ 9.570421] [<c01016e0>] (do_one_initcall) from [<c01b40b8>] (do_init_module+
0x68/0x3b0)
[ 9.570430] r10:ce3a9fa4 r9:d0c93000 r8:ce3a9f80 r7:ce4ffdc0 r6:bf10c7c0 r5:
00000001
[ 9.570433] r4:bf10c7c0
[ 9.570446] [<c01b4050>] (do_init_module) from [<c0192314>] (load_module+0x1e
0c/0x21a0)
[ 9.570453] r7:00000001 r6:bf10c7c0 r5:00000001 r4:ce027f44
[ 9.570462] [<c0190508>] (load_module) from [<c01928c8>] (SyS_finit_module+0x
b0/0xc0)
[ 9.570471] r10:00000000 r9:ce026000 r8:c0107dc4 r7:0000017b r6:b6ea2f60 r5:
00000011
[ 9.570474] r4:00000000
[ 9.570487] [<c0192818>] (SyS_finit_module) from [<c0107c00>] (ret_fast_sysca
ll+0x0/0x44)
[ 9.570493] r6:00000000 r5:00000000 r4:7f5f9870
[ 9.570503] Code: e92d4100 e1a08001 e1a0e001 e2522040 (a8ac410a)
[ 9.570510] ---[ end trace 0000000000000002 ]---
[ 11.147594] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data
[ 16.699371] remoteproc remoteproc0: powering up wkup_m3
[ 16.785502]Starting Network Service...
remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224352
[ 16.878235] remoteproc remoteproc0: remote processor wkup_m3 is now
up
[ 16.878275] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
autoconf
binutils
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
libreadline-dev
libreadline6
m4-dev
m4
make
nettle
swig-dev
swig
[ 21.060203] random: crng init done
[ 21.121357] udc-core: couldn't find an available UDC - added [g_multi] to lis
[ 21.834193] NET: Registered protocol family 15
[ 22.511674] Initializing XFRM netlink socket
_____ _____ _ _
|___| |___|
root@am335x-evm:~# cd /
root@am335x-evm:/# ls
bin etc lib opt sbin tmp www
boot home media proc srv usr
dev include mnt run sys var
root@am335x-evm:/# cd usr
root@am335x-evm:/usr# ls
arm-linux-gnueabi include sbin
bin lib share
games libexec src
root@am335x-evm:/usr# cd bin
root@am335x-evm:/usr/bin# ls
2to3 lzgrep
AES_256 lzless
CameraSystemConfigTest lzma
CameraSystemIQFrameTest.py lzmadec
CameraSystemReadStreamTest lzmainfo
CameraSystemSaveStreamTest lzmore
CameraSystemTest m4
CameraSystemTest.py make
Certificate_gen makeconv
Certificate_info makepqg
DFTTest mangle
DMLParseTest mapscrn
Data2DCodecTest matrix_browser
DeviceTest md5sum
DownloaderTest media-ctl
EGLWLInputEventExample memInfo.sh
EGLWLMockNavigation mem_util
Gen_publickey memsize
LayerManagerControl memtester
LensCalibrationTest.py mesg
NNET.DAT mesg.util-linux
SGX metaflac
SHA1_test mhz
SerialNumber microcom
SimplePeopleTracking mkfifo
Switches.sh mmc
UVCStreamerTest modeprint
Voxel14RegisterTest modetest
[ modutil
[[ mouse-dpi-tool
aclocal mpicalc
aclocal-1.15 mpris-proxy
aconnect ms_print
addbuiltin msgattrib
addr2line msgcat
agentxtrap msgcmp
alsaloop msgcomm
alsamixer msgconv
alsatplg msgen
alsaucm msgexec
amidi msgfilter
amixer msgfmt
aplay msggrep
aplaymidi msginit
ar msgmerge
arecord msgunfmt
arecordmidi msguniq
arm-linux-gnueabihf-addr2line msleep
arm-linux-gnueabihf-ar mtdev-test
arm-linux-gnueabihf-as multi-touch-viewer
arm-linux-gnueabihf-c++filt multinit
arm-linux-gnueabihf-cpp name_from_fd
arm-linux-gnueabihf-dwp namei
arm-linux-gnueabihf-elfedit nanosleep
arm-linux-gnueabihf-g++ nbench
arm-linux-gnueabihf-gcc nc
arm-linux-gnueabihf-gcc-ar ncurses5-config
arm-linux-gnueabihf-gcc-nm ncursesw5-config
arm-linux-gnueabihf-gcc-ranlib net-snmp-cert
arm-linux-gnueabihf-gprof net-snmp-config
arm-linux-gnueabihf-ld net-snmp-create-v3-user
arm-linux-gnueabihf-ld.bfd nettle-hash
arm-linux-gnueabihf-ld.gold nettle-lfib-stream
arm-linux-gnueabihf-nm nettle-pbkdf2
arm-linux-gnueabihf-objcopy networkSettings.sh
arm-linux-gnueabihf-objdump newgidmap
arm-linux-gnueabihf-ranlib newgrp
arm-linux-gnueabihf-readelf newgrp.shadow
arm-linux-gnueabihf-size newuidmap
arm-linux-gnueabihf-strings nm
arm-linux-gnueabihf-strip node
arm-unknown-linux-gnueabi-pkg-config nohup
as nonspr10
aseqdump nosetests
aseqnet nosetests-2.7
aserver npm
atob nsenter
attr nslookup
autoconf obex-client-tool
autoheader obex-server-tool
autom4te obexctl
automake objcopy
automake-1.15 objdump
autopoint ocount
autoreconf ocspclnt
autoscan ocspresp
autoupdate od
awk oidcalc
baddbdir omapconf
barcode_zbar op-check-perfevents
basename opannotate
bashbug oparchive
bc openclose
bccmd opencv_annotation
bltest opencv_createsamples
bluemoon opencv_traincascade
bluetooth-player opencv_waldboost_detector
bluetoothctl openssl
bsdcat openssl_aes256_encdec.sh
btmgmt openssl_display_cert.sh
btmon openssl_gen_cert.sh
btoa openssl_gen_pubkey.sh
bunzip2 openssl_gen_sha1hash.sh
bunzip2.bzip2 openssl_perf.sh
burn-neon openssl_start_server.sh
burn-neona8 openvt
busctl openvt.kbd
bw_file_rd operf
bw_mem opgprof
bw_mmap_rd ophelp
bw_pipe opimport
bw_tcp opjitconv
bw_unix opkg
bzcat opkg-check-config
bzcat.bzip2 opreport
bzcmp optimize-benchmark.sh
bzdiff orc-bugreport
bzegrep orcc
bzfgrep p7content
bzgrep p7env
bzip2 p7sign
bzip2recover p7verify
bzless pacat
bzmore pacmd
c++ pactl
c++filt padsp
c_rehash pamon
cairo-trace pango-view
cal paplay
calibrator par_mem
callgrind_annotate par_ops
callgrind_control parec
candump parecord
canecho passwd
cansend passwd.shadow
cansequence pasuspender
captoinfo patch
cc pcitest
ccache-swig pcitest.sh
certcgi pcre-config
certutil perf
cg_annotate perl
cg_diff perl5.22.1
cg_merge pg
cgclassify pgrep
cgcreate pgrep.procps
cgdelete phc2sys
cgexec php
cgget php-cgi
cgset pi_stress
cgsnapshot pip_stress
chacl pk11gcmtest
chage pk11mode
checkmk pk12util
chfn pk1sign
chfn.shadow pkcs1-conv
chktest pkg-config
chromium pkgdata
chrt pki
chrt.util-linux pkill
chsh pkill.procps
chsh.shadow pkix-errcodes
chvt pm_suspend.sh
chvt.kbd pmap
ciptool pmap.procps
cjpeg pmc
clear pmqtest
clear.ncurses posix-smp-demo-linux-armv7
cmp powertop_01.sh
cmsutil powertop_sanity.sh
col pp
colcrt printf
colrm prlimit
column proptest
conflict protoc
cpp pruss_uio_test
cpuburn psfaddtable
cpucycle psfgettable
cpufreq_01.sh psfstriptable
cpufreq_02.sh psfxtable
cpufreq_03.sh psplash
cpufreq_04.sh psplash-default
cpufreq_05.sh psplash-write
cpufreq_06.sh ptp4l
cpufreq_07.sh ptpd2
cpufreq_08.sh ptsematest
cpufreq_09.sh pulseaudio
cpufreq_sanity.sh pvrsrvctl
cpuhotplug_00.sh pwdecrypt
cpuhotplug_01.sh pwdx
cpuhotplug_02.sh pwdx.procps
cpuhotplug_03.sh pydoc
cpuhotplug_04.sh python
cpuhotplug_05.sh python-config
cpuhotplug_06.sh python2
cpuhotplug_07.sh python2-config
cpuhotplug_08.sh python2.7
cpuhotplug_99.sh python2.7-config
cpuhotplug_sanity.sh python3
cpuidle_01.sh python3-config
cpuidle_02.sh python3.5
cpuidle_03.sh python3.5-config
cpuidle_killer python3.5m
cpuidle_sanity.sh python3.5m-config
cpuloadgen qt5
cputopology_01.sh qtwebbrowser
cputopology_02.sh random
cputopology_03.sh ranlib
cputopology_04.sh rctest
cputopology_sanity.sh rdjpgcom
crlutil rds-ctl
crmftest readelf
cset readlink
curl realpath
cut recode-sr-latin
cx18-ctl refresh_screen
cyclictest remtest
dbclient rename
dbtest renice
dbus-binding-tool renice.util-linux
dbus-cleanup-sockets reset
dbus-daemon reset.ncurses
dbus-launch resize
dbus-monitor rev
dbus-run-session rfcomm
dbus-send rngtest
dbus-test-tool rsaperf
dbus-update-activation-environment rt-migrate-test
dbus-uuidgen runAACDec.sh
dc runAudioCapture.sh
dc.bc runBarcodeRoi.sh
deallocvt runDhrystone
deallocvt.kbd runH264Dec.sh
decode_tm6000 runLinpack
derb runLmComBandwidth.sh
derdump runLmComLatency.sh
dertimetest runLmDDRBandwidth.sh
detect_barcode runLmMemoryLatency.sh
devmem2 runMatrixShutdown.sh
dhrystone runMpeg4AacDec.sh
diff runMpeg4Dec.sh
digest runNBench.sh
dirname runOGLES2ChameleonMan.sh
disk runOGLES2Coverflow.sh
djpeg runOGLES2ExampleUI.sh
dpkg-deb runOGLES2Navigation.sh
dristat runRefreshMatrix.sh
drmdevice runSimplePeopleTracking.sh
drmsl runSystemShutdown.sh
drmstat runUsbBonnie.sh
du runWeston
dumpkeys runWhetstone
dumpleases rwmem
dvb-fe-tool sbcdec
dvb-format-convert sbcenc
dvbv5-scan sbcinfo
dvbv5-zap scp
dwp screenshot
easy3_install script
easy_install-3.5 scriptreplay
ecperf sdptool
eglinfo sdrtest
eject secmodtest
eject.util-linux selfserv
elfedit sendme
encode_keychange seq
encodeinttest serialcheck
enough setarch
env setclockspeed.sh
esdcompat setfacl
eth1_nat.sh setfattr
eth1_up.sh setfont
eu-ar setgovernor.sh
eu-elfcmp setkeycodes
eu-elflint setleds
eu-findtextrel setmetamode
eu-make-debug-archive setsid
eu-objdump setsid.util-linux
eu-ranlib setterm
eu-strings setversion
eu-unstrip setvtrgb
event_rpcgen.py sexp-conv
eventdump sg
evtest sha1sum
execltp sha256sum
expiry sha3sum
expr shlibsign
extract showconsolefont
f2py showkey
faillog shuf
fallocate signaltest
fbtest signlibs.sh
fc-cache signtool
fc-cat signver
fc-list sigwaittest
fc-match simple-ivi-share
fc-pattern size
fc-query skill
fc-scan skill.procps
fc-validate slabtop
ffsb slsh
fgconsole smtpd.py
fgconsole.kbd sndfile-resample
fileop snice
find snice.procps
findmnt snmp-bridge-mib
fipstest snmpbulkget
fixproc snmpbulkwalk
flac snmpcheck
flex snmpconf
flex++ snmpdelta
flock snmpdf
flock.util-linux snmpget
flushdisk snmpgetnext
free snmpinform
free.procps snmpnetstat
freetype-config snmpset
fuser snmpstatus
g++ snmptable
g-ir-annotation-tool snmptest
g-ir-compiler snmptranslate
g-ir-compiler-wrapper snmptrap
g-ir-generate snmpusm
g-ir-scanner snmpvacm
g-ir-scanner-lddwrapper snmpwalk
g-ir-scanner-qemuwrapper sort
g-ir-scanner-wrapper speaker-test
gadget-init.sh ssh
gatttool ssltap
gawk strace
gawk-4.1.3 strace-log-merge
gcc stream
gconf-merge-tree stream_c
gconftool-2 stress
gcore strings
gdb strip
gdbserver strsclnt
gdk-pixbuf-csource suspend_01.sh
gdk-pixbuf-pixdata suspend_02.sh
genbrk suspend_03.sh
gencfu suspend_04.sh
gencnval suspend_05.sh
gendict suspend_sanity.sh
genrb svsematest
getclient swig
getfacl switch-config
getfattr symkeyutil
getkeycodes sysSettings.sh
getstats systemd-cat
gettextize systemd-cgls
getversion systemd-cgtop
git systemd-delta
git-receive-pack systemd-detect-virt
git-shell systemd-nspawn
git-upload-archive systemd-path
git-upload-pack systemd-resolve
gles1test1 systemd-run
gles2test1 systemd-socket-activate
glib-compile-resources systemd-stdio-bridge
glib-genmarshal tabs
glib-gettextize tail
glib-mkenums tailf
glsltest1_fragshaderA.txt taskInfo.sh
glsltest1_fragshaderB.txt taskset
glsltest1_vertshader.txt tcpsvd
gnu-configize tee
google-chrome telnet
gpasswd test
gprof tests_cryptodev
groups tftp
groups.shadow thermal_00.sh
gsettings-data-convert thermal_01.sh
gsettings-schema-convert thermal_02.sh
gst-device-monitor-1.0 thermal_03.sh
gst-discoverer-1.0 thermal_04.sh
gst-inspect-1.0 thermal_05.sh
gst-launch-1.0 thermal_06.sh
gst-play-1.0 thermal_sanity.sh
gst-stats-1.0 tic
gst-typefind-1.0 time
hackbench timedatectl
hash timeout
hciattach timestamping
hciconfig timing_o
hcidump tjbench
hcitool tkmib
head tlb
heat_cpu tload
hello toe
hex2hcd top
hexdump top.procps
hexdump.util-linux touchpad-edge-detector
hostnamectl tput
htop tr
httpserv trace
hwstamp_ctl trace-cmd
icss_emacMainTest_am335x.out traceroute
icu-config traptoemail
icuinfo truncate
id tset
idle tstclnt
iecset tty
ifnames uconv
igawk udpsvd
infocmp uevent_reader
infotocap uim
input-events uio_int_test
input-kbd uio_mem_test
input-recv uio_test_pru0.bin
input-send uio_test_pru1.bin
ionice ul
iozone uname26
ipcmk unicode_start
ipcrm unicode_stop
ipcs uniq
iperf unlink
ipf-mod.pl unlzma
iptables-xml unshare
isosize unxz
ivtv-ctl unzip
jpegtran update-alternatives
kbd_mode updatedraw
kbdinfo uptime
kbdrate uptime.procps
killall usb-devices
kms-steal-crtc usbhid-dump
kms-universal-planes users
kmscube utils_sanity.sh
kmsprint utmpdump
kmstest utmpdump.util-linux
kmstest.kms++ uudecode
kmstest.libdrm uuencode
kselftests uvc-gadget
l2ping v4l2-compliance
l2test v4l2-ctl
last v4l2-sysfs-path
last.util-linux valgrind
lastb valgrind-di-server
lastb.util-linux valgrind-listener
lastlog vbltest
lat_connect vfychain
lat_ctx vfyserv
lat_fcntl vgdb
lat_fifo vlock
lat_fs vmstat
lat_http w
lat_mem_rd wall
lat_mmap wall.util-linux
lat_ops warnonpm.sh
lat_pagefault wayland-scanner
lat_pipe wc
lat_proc wcap-decode
lat_rpc wdctl
lat_select weston
lat_sem weston-calibrator
lat_sig weston-clickdot
lat_syscall weston-cliptest
lat_tcp weston-dnd
lat_udp weston-editor
lat_unix weston-eventdemo
lat_unix_connect weston-flower
layer-add-surfaces weston-fullscreen
ld weston-image
ld.bfd weston-info
ld.gold weston-launch
less weston-multi-resource
libevdev-tweak-device weston-presentation-shm
libinput-debug-events weston-resizor
libinput-list-devices weston-scaler
libpng-config weston-simple-damage
libpng16-config weston-simple-dmabuf-v4l
libtool weston-simple-egl
libtoolize weston-simple-shm
linpack weston-simple-touch
linux32 weston-smoke
linux64 weston-stacking
listsuites weston-start
lm_line weston-subsurfaces
lmbench weston-terminal
lmbench-run weston-transformed
lmdd wget
lmhttp whereis
loadkeys whetstone
loadunimap which
localectl who
logger whoami
logger.util-linux wlconf
logname write
look wrjpgcom
loop_o xargs
lsattr xgettext
lsblk xml2-config
lscgroup xmlcatalog
lsinput xmllint
lsipc xz
lslocks xzcat
lslogins xzcmp
lsns xzdec
lsof xzdiff
lssubsys xzegrep
lsusb xzfgrep
lsusb.py xzgrep
lzcat xzless
lzcmp xzmore
lzdiff yavta
lzegrep yes
lzfgrep
root@am335x-evm:/usr/bin# chmod +x icss_emacMainTest_am335x.out
root@am335x-evm:/usr/bin# ./ icss_emacMainTest_am335x.out
-sh: ./: is a directory
root@am335x-evm:/usr/bin# icss_emacMainTest_am335x.out
Segmentation fault (core dumped)
root@am335x-evm:/usr/bin# ./icss_emacMainTest_am335x.out
root@am335x-evm:/usr/bin# cd
2to3 lzgrep
AES_256 lzless
CameraSystemTest m4
DFTTest mangle
DeviceTest md5sum
SGX metaflac
SHA1_test mhz
Switches.sh mmc
[ modutil
[[ mouse-dpi-tool
aclocal mpicalc
aconnect ms_print
addr2line msgcat
agentxtrap msgcmp
alsaloop msgcomm
alsamixer msgconv
alsatplg msgen
alsaucm msgexec
amidi msgfilter
amixer msgfmt
aplay msggrep
aplaymidi msginit
ar msgmerge
arecord msgunfmt
arecordmidi msguniq
as nonspr10
aseqdump nosetests
aserver npm
atob nsenter
attr nslookup
autom4te obexctl
automake objcopy
autopoint ocount
autoreconf ocspclnt
autoscan ocspresp
autoupdate od
awk oidcalc
baddbdir omapconf
basename opannotate
bashbug oparchive
bc openclose
burn-neona8 openvt
busctl openvt.kbd
bw_file_rd operf
bw_mem opgprof
bw_mmap_rd ophelp
bw_pipe opimport
bw_tcp opjitconv
bw_unix opkg
bzegrep orcc
bzfgrep p7content
bzgrep p7env
bzip2 p7sign
bzless pacat
bzmore pacmd
c++ pactl
c++filt padsp
c_rehash pamon
cal paplay
calibrator par_mem
candump parecord
canecho passwd
captoinfo patch
cc pcitest
certcgi pcre-config
certutil perf
cg_annotate perl
cg_diff perl5.22.1
cg_merge pg
cgclassify pgrep
cgdelete phc2sys
cgexec php
cgget php-cgi
cgset pi_stress
chacl pk11gcmtest
chage pk11mode
checkmk pk12util
chfn pk1sign
chktest pkg-config
chromium pkgdata
chrt pki
chsh pkill.procps
chvt pm_suspend.sh
chvt.kbd pmap
ciptool pmap.procps
cjpeg pmc
clear pmqtest
cmp powertop_01.sh
col pp
colcrt printf
colrm prlimit
column proptest
conflict protoc
cpp pruss_uio_test
cpuburn psfaddtable
cpufreq_06.sh ptp4l
cpufreq_07.sh ptpd2
cpuloadgen qt5
crlutil rds-ctl
crmftest readelf
cset readlink
curl realpath
cut recode-sr-latin
cyclictest remtest
dbclient rename
dbtest renice
dbus-launch resize
dbus-monitor rev
dbus-send rngtest
diff runMpeg4Dec.sh
digest runNBench.sh
du runWeston
dumpleases rwmem
dvb-fe-tool sbcdec
dvbv5-scan sbcinfo
dvbv5-zap scp
dwp screenshot
ecperf sdptool
eglinfo sdrtest
eject secmodtest
elfedit sendme
enough setarch
esdcompat setfacl
eth1_up.sh setfont
eu-elflint setleds
eu-ranlib setterm
eu-unstrip setvtrgb
eventdump sg
evtest sha1sum
execltp sha256sum
expiry sha3sum
expr shlibsign
f2py showkey
faillog shuf
fbtest signlibs.sh
fc-cache signtool
fc-cat signver
fc-list sigwaittest
fc-pattern size
fc-query skill
fc-validate slabtop
ffsb slsh
fgconsole smtpd.py
fileop snice
find snice.procps
flac snmpcheck
flex snmpconf
flex++ snmpdelta
flock snmpdf
free snmpinform
fuser snmpstatus
g++ snmptable
gadget-init.sh ssh
gatttool ssltap
gawk strace
gcc stream
gconftool-2 stress
gcore strings
gdb strip
gdbserver strsclnt
genrb svsematest
getclient swig
getfattr symkeyutil
git systemd-delta
glib-mkenums tailf
gnu-configize tee
gpasswd test
groups tftp
gst-stats-1.0 tic
hash timeout
hciconfig timing_o
hcidump tjbench
hcitool tkmib
head tlb
heat_cpu tload
hello toe
hex2hcd top
hexdump top.procps
hostnamectl tput
htop tr
httpserv trace
icuinfo truncate
id tset
idle tstclnt
iecset tty
ifnames uconv
igawk udpsvd
infotocap uim
ionice ul
iozone uname26
ipcmk unicode_start
ipcrm unicode_stop
ipcs uniq
iperf unlink
ipf-mod.pl unlzma
isosize unxz
ivtv-ctl unzip
kbd_mode updatedraw
kbdinfo uptime
killall usb-devices
kmsprint utmpdump
l2test v4l2-ctl
lastlog vbltest
lat_ctx vfyserv
lat_fcntl vgdb
lat_fifo vlock
lat_fs vmstat
lat_http w
lat_mem_rd wall
lat_ops warnonpm.sh
lat_pipe wc
lat_rpc wdctl
lat_select weston
lat_tcp weston-dnd
ld weston-image
ld.bfd weston-info
lmdd wget
lmhttp whereis
loadkeys whetstone
loadunimap which
localectl who
logger whoami
logname write
look wrjpgcom
loop_o xargs
lsattr xgettext
lsblk xml2-config
lscgroup xmlcatalog
lsinput xmllint
lsipc xz
lslocks xzcat
lslogins xzcmp
lsns xzdec
lsof xzdiff
lssubsys xzegrep
lsusb xzfgrep
lsusb.py xzgrep
lzcat xzless
lzcmp xzmore
lzdiff yavta
lzegrep yes
lzfgrep
root@am335x-evm:/usr/bi 0
reading boot.scr
reading uEnv.txt
Scanning mmc 0:1...
Starting kernel ...
09 EDT 2017
n cache
es: 64960
ighmem)
ts
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478
484971ns
[ 0.000028] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max
[ 0.000035] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000209] clocksource_probe: no matching clocksources found
[ 0.000380] Console: colour dummy device 80x30
[ 0.000527] WARNING: Your 'console=ttyO3' has been replaced by 'ttyS3'
[ 0.000530] This ensures that you still see kernel messages. Please
[ 0.000531] update your kernel commandline.
[ 0.089118] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089125] pid_max: default: 32768 minimum: 301
[ 0.089253] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089259] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090138] CPU: Testing write buffer coherency: ok
[ 0.090465] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.091670] EFI services will not be available.
[ 0.093049] devtmpfs: initialized
[ 0.106791] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 3
[ 0.107152] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
[ 0.107181] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.110898] pinctrl core: initialized pinctrl subsystem
[ 0.112232] NET: Registered protocol family 16
[ 0.114651] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.129548] omap_hwmod: debugss: _wait_target_disable failed
[ 0.187295] GPIO line 7 (FET_SWITCH_CTRL) hogged as output/high
[ 0.189628] OMAP GPIO hardware version 0.1
[ 0.195707] GPIO line 100 (PR1_MII_CTRL) hogged as output/high
[ 0.195733] GPIO line 106 (MUX_MII_CTL1) hogged as output/low
[ 0.205166] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.222007] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.225799] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wk
[ 0.225928] media: Linux media interface: v0.10
[ 0.225987] Linux video capture interface: v2.00
[ 0.226032] pps_core: LinuxPPS API ver. 1 registered
[ 0.226041] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
[ 0.226066] PTP clock support registered
[ 0.226108] EDAC MC: Ver: 3.0.0
[ 0.227294] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.227640] Advanced Linux Sound Architecture Driver Initialized.
[ 0.228994] clocksource: Switched to clocksource timer1
[ 0.240562] NET: Registered protocol family 2
[ 0.241439] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.241488] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
[ 0.241589] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.241660] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.241698] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.241891] NET: Registered protocol family 1
[ 0.242381] RPC: Registered named UNIX socket transport module.
[ 0.242398] RPC: Registered udp transport module.
[ 0.242406] RPC: Registered tcp transport module.
[ 0.242412] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.243351] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter
s available
[ 0.245822] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.254384] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.255442] NFS: Registering the id_resolver key type
[ 0.255487] Key type id_resolver registered
[ 0.255496] Key type id_legacy registered
[ 0.255548] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.257531] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
47)
[ 0.257553] io scheduler noop registered
[ 0.257562] io scheduler deadline registered
[ 0.257739] io scheduler cfq registered (default)
[ 0.258603] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl
-cells = <1>
[ 0.259210] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.328935] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.332485] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 158, base_baud =
3000000) is a 8250
[ 0.927340] console [ttyS3] enabled
[ 0.932768] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 0.939572] [drm] Initialized
[ 0.957058] brd: module loaded
[ 0.967189] loop: module loaded
[ 0.973484] m25p80 spi1.0: found s25fl064k, expected w25q64
[ 0.979156] m25p80 spi1.0: s25fl064k (8192 Kbytes)
[ 0.984008] 4 ofpart partitions found on MTD device spi1.0
[ 0.989518] Creating 4 MTD partitions on "spi1.0":
[ 0.994338] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 1.001145] 0x000000080000-0x000000180000 : "u-boot"
[ 1.007437] 0x000000180000-0x0000001a0000 : "u-boot-env"
[ 1.014105] 0x0000001a0000-0x000000800000 : "misc"
[ 1.021232] libphy: Fixed MDIO Bus: probed
[ 1.027587] mousedev: PS/2 mouse device common for all mice
[ 1.033785] i2c /dev entries driver
[ 1.043576] NET: Registered protocol family 10
[ 1.049640] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.056439] NET: Registered protocol family 17
[ 1.061229] Key type dns_resolver registered
[ 1.065762] omap_voltage_late_init: Voltage driver support not added
[ 1.109273] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.117411] vrtc: supplied by vbat
[ 1.124588] vio: supplied by vbat
[ 1.129425] vdd1: supplied by vbat
[ 1.134667] vdd2: supplied by vbat
[ 1.141410] vdig1: supplied by vbat
[ 1.146279] vdig2: supplied by vbat
[ 1.151141] vpll: supplied by vbat
[ 1.155926] vdac: supplied by vbat
[ 1.160721] vaux1: supplied by vbat
[ 1.165586] vaux2: supplied by vbat
[ 1.170452] vaux33: supplied by vbat
[ 1.175418] vmmc: supplied by vbat
[ 1.179760] random: fast init done
[ 1.183590] vbb: supplied by vbat
[ 1.188421] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.249638] hctosys: unable to open rtc device (rtc0)
[ 1.255480] ALSA device list:
[ 1.261311] No soundcards found.
[ 1.268548] Waiting for root device PARTUUID=fc5f42dd-02...
[ 1.296281] mmc0: host does not support reading read-only switch, assuming wr
ite-enable
[ 1.306298] mmc0: new high speed SDHC card at address 0007
[ 1.312567] mmcblk0: mmc0:0007 SS08G 7.21 GiB
[ 1.318679] mmcblk0: p1 p2
[ 4.940863] EXT4-fs (mmcblk0p2): recovery complete
[ 4.966071] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[ 4.974279] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.984521] devtmpfs: mounted
[ 4.989123] Freeing unused kernel memory: 1024K (c0b00000 - c0c00000)
[ 5.319961] systemd[1]: System time before build time, advancing clock.
[ 5.411031] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SEL
[ 5.429808] systemd[1]: Detected architecture arm.
[ 5.470643] systemd[1]: Set hostname to <am335x-evm>.
[ 5.775527] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown
[ 6.069616] systemd[1]: sysinit.target: Found ordering cycle on sysinit.targe
t/start
[ 6.077449] systemd[1]: sysinit.target: Found dependency on alignment.service
/start
[ 6.085174] systemd[1]: sysinit.target: Found dependency on sysinit.target/st
art
[ 6.092630] systemd[1]: sysinit.target: Breaking ordering cycle by deleting j
[ 6.102091] systemd[1]: alignment.service: Job alignment.service/start delete
d to break ordering cycle starting with sysinit.target/start
[ 6.154868] systemd[1]: Listening on Journal Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.[ 6.51
5669] cryptodev: loading out-of-tree module taints kernel.
[ 6.526010] cryptodev: driver 1.8 loaded.
[ 6.788358] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.962202] systemd-journald[116]: Received request to flush runtime journal
from PID 1
[ 9.413384] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 9.596479] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 9.673044] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 9.684536] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 9.747506] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 9.920133] gpio-decoder gpio-decoder: unable to acquire input gpios
[ 9.928015] 0-0041 supply vcc not found, using dummy regulator
[ 10.000125] input: gpio-decoder as /devices/platform/gpio-decoder/input/input
0
[ 11.157219] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 11.250006] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.340254] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 11.411486] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.418579] remoteproc remoteproc0: wkup_m3 is available
[ 11.419689] PM: Cannot get wkup_m3_ipc handle
[ 11.423571] omap-aes 53500000.aes: will run requests pump with realtime prior
ity
[ 11.444169] ti-pruss 4a300000.pruss: creating PRU cores and other child platf
orm devices
[ 11.473843] PM: Cannot get wkup_m3_ipc handle
[ 11.500589] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.501092] PM: Cannot get wkup_m3_ipc handle
[ 11.537987] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.546501] davinci_mdio 4a332400.mdio: davinci mdio revision 1.6
[ 11.546512] libphy: 4a332400.mdio: probed
[ 11.611747] PM: Cannot get wkup_m3_ipc handle
[ 11.659796] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.660563] davinci_mdio 4a332400.mdio: phy[1]: device 4a332400.mdio:01, driv
[ 11.660572] davinci_mdio 4a332400.mdio: phy[3]: device 4a332400.mdio:03, driv
[ 11.661450] PM: Cannot get wkup_m3_ipc handle
[ 11.667922] remoteproc remoteproc1: 4a334000.pru0 is available
[ 11.668018] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a3260
[ 11.668338] remoteproc remoteproc2: 4a338000.pru1 is available
[ 11.668411] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a3260
[ 11.679586] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.680104] PM: Cannot get wkup_m3_ipc handle
[ 11.712673] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 11.929738] Unable to handle kernel NULL pointer dereference at virtual addre
ss 00000000
[ 11.929747] pgd = ca114000
[ 11.929757] [00000000] *pgd=00000000
[ 11.929768] Internal error: Oops: 805 [#1] PREEMPT ARM
[ 11.929814] Modules linked in: prueth(+) pru_rproc pruss pruss_intc pm33xx wk
up_m3_rproc(+) wkup_m3_ipc omap_aes_driver remoteproc omap_sham pruss_soc_bus cr
ypto_engine ti_emif_sram gpio_tpic2810 gpio_pca953x gpio_pisosr rtc_omap omap_wd
cryptodev(O)
[ 11.929830] CPU: 0 PID: 164 Comm: systemd-udevd Tainted: G O 4.9
[ 11.929833] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 11.929837] task: cf661a00 task.stack: ca110000
[ 11.929860] PC is at memset+0x30/0xe0
[ 11.929866] LR is at 0x0
[ 11.929872] pc : [<c03aa990>] lr : [<00000000>] psr: 200f0113
[ 11.929872] sp : ca111c48 ip : 00000000 fp : ca111cac
[ 11.929876] r10: cf646a90 r9 : ca1e7b62 r8 : 00000000
[ 11.929880] r7 : 00000000 r6 : ca1e7a20 r5 : cfda0e40 r4 : ca1e7a10
[ 11.929884] r3 : 00000000 r2 : 0000ffc0 r1 : 00000000 r0 : 00000000
[ 11.929891] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 11.929895] Control: 10c5387d Table: 8a114019 DAC: 00000051
[ 11.929900] Process systemd-udevd (pid: 164, stack limit = 0xca110208)
[ 11.929905] Stack: (0xca111c48 to 0xca112000)
[ 11.929915] 1c40: ca1e7b62 bf0a7db0 00000000 ca2cda00 cf164
410 c09c9250
[ 11.929925] 1c60: 00000001 00000000 ca111c9c ca1e7b4a cf162a10 ca1e7b16 fffff
fff cfda0a74
[ 11.929934] 1c80: cf162a18 cf162a10 ffffffed bf0aa6a8 fffffdfb bf0aa6a8 00000
01f 00000000
[ 11.929944] 1ca0: ca111ccc ca111cb0 c04ff6a0 bf0a74e4 cf162a10 c0c83dd0 c0c83
de0 00000000
[ 11.929954] 1cc0: ca111cf4 ca111cd0 c04fdf34 c04ff654 cf162a10 bf0aa6a8 cf162
a44 00000000
[ 11.929964] 1ce0: ca24ad00 d0c2d000 ca111d14 ca111cf8 c04fe0a0 c04fdd30 00000
000 bf0aa6a8
[ 11.929973] 1d00: c04fdfe0 00000000 ca111d3c ca111d18 c04fc0d4 c04fdfec cf002
664 cf149c44
[ 11.929983] 1d20: cf002688 bf0aa6a8 ca30dc00 c0c324b8 ca111d4c ca111d40 c04fd
7b0 c04fc070
[ 11.929993] 1d40: ca111d74 ca111d50 c04fd2f0 c04fd798 bf0aa394 ca111d60 bf0aa
6a8 ffffe000
[ 11.930003] 1d60: bf0aa7c0 ca07c000 ca111d8c ca111d78 c04fe5e8 c04fd1ec c0c32
4b8 ffffe000
[ 11.930013] 1d80: ca111da4 ca111d90 c04ff5fc c04fe574 bf0ae000 ffffe000 ca111
db4 ca111da8
[ 11.930022] 1da0: bf0ae01c c04ff5c0 ca111e34 ca111db8 c010172c bf0ae00c 00400
03e d0c2d000
[ 11.930032] 1dc0: ca111e14 cff10d04 ca110000 ca379d80 cf001e40 cff10d04 ca110
000 ca379900
[ 11.930042] 1de0: cf001e40 0000ab96 d0c2d000 ca24ad24 ca111e2c ca111e00 c01fa
ea4 c01faa44
[ 11.930052] 1e00: 00000001 d0c2d000 00000001 bf0aa7c0 00000001 bf0aa7c0 ca07c
000 ca24ad00
[ 11.930061] 1e20: d0c2d000 ca24ad24 ca111e5c ca111e38 c01b40b8 c01016ec bf0aa
7c0 00000001
[ 11.930071] 1e40: ca111f44 00000001 bf0aa7c0 00000001 ca111f1c ca111e60 c0192
314 c01b405c
[ 11.930081] 1e60: bf0aa7cc 00007fff bf0aa7c0 c018f730 bf000000 c0992650 c0992
628 c0992680
[ 11.930090] 1e80: c099261c c0804180 bf0aa7cc d0c39fb0 bf0aa958 ca111f44 bf0aa
808 bf0aa7c0
[ 11.930100] 1ea0: ca111eec ca111eb0 c0212914 c0212254 d0c2d000 00000000 00000
000 00000000
[ 11.930109] 1ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[ 11.930118] 1ee0: 00000000 00000000 00000000 00000000 7fffffff 00000000 00000
011 b6f1cf60
[ 11.930128] 1f00: 0000017b c0107dc4 ca110000 00000000 ca111fa4 ca111f20 c0192
8c8 c0190514
[ 11.930137] 1f20: 7fffffff 00000000 00000003 ca111f38 c01d3c30 d0c2d000 0000d
000 00000000
[ 11.930147] 1f40: 00000000 d0c2d000 0000d000 d0c39c18 d0c39b38 d0c36f14 00006
af0 000079b0
[ 11.930156] 1f60: 00000000 00000000 00000000 00002c48 00000017 00000018 00000
011 0000000e
[ 11.930165] 1f80: 0000000a 00000000 00000000 7f654178 00000000 00000000 00000
000 ca111fa8
[ 11.930174] 1fa0: c0107c00 c0192824 7f654178 00000000 00000011 b6f1cf60 00000
000 00000000
[ 11.930184] 1fc0: 7f654178 00000000 00000000 0000017b 7f649094 7f638018 00000
000 7f653c70
[ 11.930193] 1fe0: be8ee9e0 be8ee9d0 b6f15be4 b6e679f2 600f0030 00000011 eecff
ed7 df7e4ede
[ 11.930197] Backtrace:
[ 11.930276] [<bf0a74d8>] (prueth_probe [prueth]) from [<c04ff6a0>] (platform_
[ 11.930287] r10:00000000 r9:0000001f r8:bf0aa6a8 r7:fffffdfb r6:bf0aa6a8 r5:
ffffffed
[ 11.930290] r4:cf162a10
[ 11.930303] [<c04ff648>] (platform_drv_probe) from [<c04fdf34>] (driver_probe
[ 11.930310] r7:00000000 r6:c0c83de0 r5:c0c83dd0 r4:cf162a10
[ 11.930319] [<c04fdd24>] (driver_probe_device) from [<c04fe0a0>] (__driver_at
tach+0xc0/0xc4)
[ 11.930329] r9:d0c2d000 r8:ca24ad00 r7:00000000 r6:cf162a44 r5:bf0aa6a8 r4:c
f162a10
[ 11.930338] [<c04fdfe0>] (__driver_attach) from [<c04fc0d4>] (bus_for_each_de
v+0x70/0xa4)
[ 11.930344] r7:00000000 r6:c04fdfe0 r5:bf0aa6a8 r4:00000000
[ 11.930353] [<c04fc064>] (bus_for_each_dev) from [<c04fd7b0>] (driver_attach+
0x24/0x28)
[ 11.930358] r6:c0c324b8 r5:ca30dc00 r4:bf0aa6a8
[ 11.930367] [<c04fd78c>] (driver_attach) from [<c04fd2f0>] (bus_add_driver+0x
110/0x21c)
[ 11.930377] [<c04fd1e0>] (bus_add_driver) from [<c04fe5e8>] (driver_register+
0x80/0xfc)
[ 11.930384] r7:ca07c000 r6:bf0aa7c0 r5:ffffe000 r4:bf0aa6a8
[ 11.930393] [<c04fe568>] (driver_register) from [<c04ff5fc>] (__platform_driv
[ 11.930398] r5:ffffe000 r4:c0c324b8
[ 11.930422] [<c04ff5b4>] (__platform_driver_register) from [<bf0ae01c>] (prue
[ 11.930426] r5:ffffe000 r4:bf0ae000
[ 11.930451] [<bf0ae000>] (prueth_driver_init [prueth]) from [<c010172c>] (do_
[ 11.930467] [<c01016e0>] (do_one_initcall) from [<c01b40b8>] (do_init_module+
0x68/0x3b0)
[ 11.930476] r10:ca24ad24 r9:d0c2d000 r8:ca24ad00 r7:ca07c000 r6:bf0aa7c0 r5:
00000001
[ 11.930479] r4:bf0aa7c0
[ 11.930492] [<c01b4050>] (do_init_module) from [<c0192314>] (load_module+0x1e
0c/0x21a0)
[ 11.930498] r7:00000001 r6:bf0aa7c0 r5:00000001 r4:ca111f44
[ 11.930508] [<c0190508>] (load_module) from [<c01928c8>] (SyS_finit_module+0x
b0/0xc0)
[ 11.930516] r10:00000000 r9:ca110000 r8:c0107dc4 r7:0000017b r6:b6f1cf60 r5:
00000011
[ 11.930519] r4:00000000
[ 11.930533] [<c0192818>] (SyS_finit_module) from [<c0107c00>] (ret_fast_sysca
ll+0x0/0x44)
[ 11.930538] r6:00000000 r5:00000000 r4:7f654178
[ 11.930548] Code: e92d4100 e1a08001 e1a0e001 e2522040 (a8ac410a)
[ 11.930556] ---[ end trace 0000000000000002 ]---
[ 14.990549] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data
[ 18.915522] PM: Cannot get wkup_m3_ipc handle
[ 18.934621] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 19.416105] PM: Cannot get wkup_m3_ipc handle
[ 19.458376] PM: Cannot get wkup_m3_ipc handle
Starting Telephony service...[ 19.463076] remoteproc remoteproc0: powering up
wkup_m3
[ 19.523494] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf,
size 224352
[ 19.575364] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 19.575417] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 20.033424] Bluetooth: Core ver 2.22
[ 20.058610] NET: Registered protocol family 31
[ 20.082504] Bluetooth: HCI device and connection manager initialized
[ 20.088937] Bluetooth: HCI socket layer initialized
[ 20.135448] Bluetooth: L2CAP socket layer initialized
[ 20.164939] Bluetooth: SCO socket layer initialized
[ 20.660283] random: crng init done
autoconf
binutils
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
libreadline-dev
libreadline6
m4-dev
m4
make
nettle
swig-dev
swig
[ 23.864229] udc-core: couldn't find an available UDC - added [g_multi] to lis
[ 24.603716] NET: Registered protocol family 15
[ 25.302916] Initializing XFRM netlink socket
_____ _____ _ _
|___| |___|
ifconfig: SIOCGIFFLAGS: No such device
root@am335x-evm:~#
