Part Number: AM3357
Other Parts Discussed in Thread: CCSTUDIO
I am trying to debug my custom board with code am3357 and we have followed am335x evm board. I am trying to debug uboot, once I done the for spl debug, I try to load uboot elf , but while loading this my board is getting reset. For target configuration I am using the GEL file
//AM335x BeagleBlack GEL file (DDR3)
//v1.0 Jan8,2013 First revision, derived from EVM REV 1.3
//PRCM module definitions
#define PRCM_BASE_ADDR (0x44E00000)
#define CM_PER_EMIF_CLKCTRL (PRCM_BASE_ADDR + 0x028)
#define CM_PER_EMIF_FW_CLKCTRL (PRCM_BASE_ADDR + 0x0D0)
#define CM_AUTOIDLE_DPLL_MPU (PRCM_BASE_ADDR + 0x41C)
#define CM_IDLEST_DPLL_MPU (PRCM_BASE_ADDR + 0x420)
#define CM_CLKSEL_DPLL_MPU (PRCM_BASE_ADDR + 0x42C)
#define CM_AUTOIDLE_DPLL_DDR (PRCM_BASE_ADDR + 0x430)
#define CM_IDLEST_DPLL_DDR (PRCM_BASE_ADDR + 0x434)
#define CM_CLKSEL_DPLL_DDR (PRCM_BASE_ADDR + 0x440)
#define CM_AUTOIDLE_DPLL_DISP (PRCM_BASE_ADDR + 0x444)
#define CM_IDLEST_DPLL_DISP (PRCM_BASE_ADDR + 0x448)
#define CM_CLKSEL_DPLL_DISP (PRCM_BASE_ADDR + 0x454)
#define CM_AUTOIDLE_DPLL_CORE (PRCM_BASE_ADDR + 0x458)
#define CM_IDLEST_DPLL_CORE (PRCM_BASE_ADDR + 0x45C)
#define CM_CLKSEL_DPLL_CORE (PRCM_BASE_ADDR + 0x468)
#define CM_AUTOIDLE_DPLL_PER (PRCM_BASE_ADDR + 0x46C)
#define CM_IDLEST_DPLL_PER (PRCM_BASE_ADDR + 0x470)
#define CM_CLKSEL_DPLL_PER (PRCM_BASE_ADDR + 0x49C)
#define CM_DIV_M4_DPLL_CORE (PRCM_BASE_ADDR + 0x480)
#define CM_DIV_M5_DPLL_CORE (PRCM_BASE_ADDR + 0x484)
#define CM_CLKMODE_DPLL_MPU (PRCM_BASE_ADDR + 0x488)
#define CM_CLKMODE_DPLL_PER (PRCM_BASE_ADDR + 0x48C)
#define CM_CLKMODE_DPLL_CORE (PRCM_BASE_ADDR + 0x490)
#define CM_CLKMODE_DPLL_DDR (PRCM_BASE_ADDR + 0x494)
#define CM_CLKMODE_DPLL_DISP (PRCM_BASE_ADDR + 0x498)
#define CM_DIV_M2_DPLL_DDR (PRCM_BASE_ADDR + 0x4A0)
#define CM_DIV_M2_DPLL_DISP (PRCM_BASE_ADDR + 0x4A4)
#define CM_DIV_M2_DPLL_MPU (PRCM_BASE_ADDR + 0x4A8)
#define CM_DIV_M2_DPLL_PER (PRCM_BASE_ADDR + 0x4AC)
#define CM_DIV_M6_DPLL_CORE (PRCM_BASE_ADDR + 0x4D8)
#define CM_CLKOUT_CTRL (PRCM_BASE_ADDR + 0x700)
//Control module definitions
#define CONTROL_BASE_ADDR (0x44E10000)
#define CONTROL_STATUS (CONTROL_BASE_ADDR + 0x40)
#define CONF_XDMA_EVENT_INTR1 (CONTROL_BASE_ADDR + 0x9b4)
//DDR IO Control Registers
#define DDR_IO_CTRL (CONTROL_BASE_ADDR + 0x0E04)
#define VTP_CTRL_REG (CONTROL_BASE_ADDR + 0x0E0C)
#define DDR_CKE_CTRL (CONTROL_BASE_ADDR + 0x131C)
#define DDR_CMD0_IOCTRL (CONTROL_BASE_ADDR + 0x1404)
#define DDR_CMD1_IOCTRL (CONTROL_BASE_ADDR + 0x1408)
#define DDR_CMD2_IOCTRL (CONTROL_BASE_ADDR + 0x140C)
#define DDR_DATA0_IOCTRL (CONTROL_BASE_ADDR + 0x1440)
#define DDR_DATA1_IOCTRL (CONTROL_BASE_ADDR + 0x1444)
//EMIF4DC module definitions
#define EMIF_BASE_ADDR (0x4C000000)
#define EMIF_STATUS_REG (EMIF_BASE_ADDR + 0x004)
#define EMIF_SDRAM_CONFIG_REG (EMIF_BASE_ADDR + 0x008)
#define EMIF_SDRAM_CONFIG_2_REG (EMIF_BASE_ADDR + 0x00C)
#define EMIF_SDRAM_REF_CTRL_REG (EMIF_BASE_ADDR + 0x010)
#define EMIF_SDRAM_REF_CTRL_SHDW_REG (EMIF_BASE_ADDR + 0x014)
#define EMIF_SDRAM_TIM_1_REG (EMIF_BASE_ADDR + 0x018)
#define EMIF_SDRAM_TIM_1_SHDW_REG (EMIF_BASE_ADDR + 0x01C)
#define EMIF_SDRAM_TIM_2_REG (EMIF_BASE_ADDR + 0x020)
#define EMIF_SDRAM_TIM_2_SHDW_REG (EMIF_BASE_ADDR + 0x024)
#define EMIF_SDRAM_TIM_3_REG (EMIF_BASE_ADDR + 0x028)
#define EMIF_SDRAM_TIM_3_SHDW_REG (EMIF_BASE_ADDR + 0x02C)
#define EMIF_LPDDR2_NVM_TIM_REG (EMIF_BASE_ADDR + 0x030)
#define EMIF_LPDDR2_NVM_TIM_SHDW_REG (EMIF_BASE_ADDR + 0x034)
#define EMIF_PWR_MGMT_CTRL_REG (EMIF_BASE_ADDR + 0x038)
#define EMIF_PWR_MGMT_CTRL_SHDW_REG (EMIF_BASE_ADDR + 0x03C)
#define EMIF_LPDDR2_MODE_REG_DATA_REG (EMIF_BASE_ADDR + 0x040)
#define EMIF_LPDDR2_MODE_REG_CFG_REG (EMIF_BASE_ADDR + 0x050)
#define EMIF_OCP_CONFIG_REG (EMIF_BASE_ADDR + 0x054)
#define EMIF_OCP_CFG_VAL_1_REG (EMIF_BASE_ADDR + 0x058)
#define EMIF_OCP_CFG_VAL_2_REG (EMIF_BASE_ADDR + 0x05C)
#define EMIF_IODFT_TLGC_REG (EMIF_BASE_ADDR + 0x060)
#define EMIF_IODFT_CTRL_MISR_RSLT_REG (EMIF_BASE_ADDR + 0x064)
#define EMIF_IODFT_ADDR_MISR_RSLT_REG (EMIF_BASE_ADDR + 0x068)
#define EMIF_IODFT_DATA_MISR_RSLT_1_REG (EMIF_BASE_ADDR + 0x06C)
#define EMIF_IODFT_DATA_MISR_RSLT_2_REG (EMIF_BASE_ADDR + 0x070)
#define EMIF_IODFT_DATA_MISR_RSLT_3_REG (EMIF_BASE_ADDR + 0x074)
#define EMIF_PERF_CNT_1_REG (EMIF_BASE_ADDR + 0x080)
#define EMIF_PERF_CNT_2_REG (EMIF_BASE_ADDR + 0x084)
#define EMIF_PERF_CNT_CFG_REG (EMIF_BASE_ADDR + 0x088)
#define EMIF_PERF_CNT_SEL_REG (EMIF_BASE_ADDR + 0x08C)
#define EMIF_PERF_CNT_TIM_REG (EMIF_BASE_ADDR + 0x090)
#define EMIF_READ_IDLE_CTRL_REG (EMIF_BASE_ADDR + 0x098)
#define EMIF_READ_IDLE_CTRL_SHDW_REG (EMIF_BASE_ADDR + 0x09C)
#define EMIF_IRQ_EOI_REG (EMIF_BASE_ADDR + 0x0A0)
#define EMIF_IRQSTATUS_RAW_SYS_REG (EMIF_BASE_ADDR + 0x0A4)
#define EMIF_IRQSTATUS_SYS_REG (EMIF_BASE_ADDR + 0x0AC)
#define EMIF_IRQENABLE_SET_SYS_REG (EMIF_BASE_ADDR + 0x0B4)
#define EMIF_IRQENABLE_CLR_SYS_REG (EMIF_BASE_ADDR + 0x0BC)
#define EMIF_ZQ_CONFIG_REG (EMIF_BASE_ADDR + 0x0C8)
#define EMIF_TEMP_ALERT_CONFIG_REG (EMIF_BASE_ADDR + 0x0CC)
#define EMIF_OCP_ERR_LOG_REG (EMIF_BASE_ADDR + 0x0D0)
#define EMIF_RDWR_LVL_RMP_WIN_REG (EMIF_BASE_ADDR + 0x0D4)
#define EMIF_RDWR_LVL_RMP_CTRL_REG (EMIF_BASE_ADDR + 0x0D8)
#define EMIF_RDWR_LVL_CTRL_REG (EMIF_BASE_ADDR + 0x0DC)
#define EMIF_DDR_PHY_CTRL_1_REG (EMIF_BASE_ADDR + 0x0E4)
#define EMIF_DDR_PHY_CTRL_1_SHDW_REG (EMIF_BASE_ADDR + 0x0E8)
#define EMIF_DDR_PHY_CTRL_2_REG (EMIF_BASE_ADDR + 0x0EC)
#define EMIF_PRI_COS_MAP_REG (EMIF_BASE_ADDR + 0x100)
#define EMIF_CONNID_COS_1_MAP_REG (EMIF_BASE_ADDR + 0x104)
#define EMIF_CONNID_COS_2_MAP_REG (EMIF_BASE_ADDR + 0x108)
#define EMIF_RD_WR_EXEC_THRSH_REG (EMIF_BASE_ADDR + 0x120)
//DDR PHY registers
#define DDR_PHY_BASE_ADDR (0x44E12000)
//CMD0
#define CMD0_REG_PHY_CTRL_SLAVE_RATIO_0 (0x01C + DDR_PHY_BASE_ADDR)
#define CMD0_REG_PHY_CTRL_SLAVE_FORCE_0 (0x020 + DDR_PHY_BASE_ADDR)
#define CMD0_REG_PHY_CTRL_SLAVE_DELAY_0 (0x024 + DDR_PHY_BASE_ADDR)
#define CMD0_REG_PHY_DLL_LOCK_DIFF_0 (0x028 + DDR_PHY_BASE_ADDR)
#define CMD0_REG_PHY_INVERT_CLKOUT_0 (0x02C + DDR_PHY_BASE_ADDR)
#define CMD0_PHY_REG_STATUS_PHY_CTRL_DLL_LOCK_0 (0x030 + DDR_PHY_BASE_ADDR)
#define CMD0_PHY_REG_STATUS_PHY_CTRL_OF_IN_LOCK_STATE_0 (0x034 + DDR_PHY_BASE_ADDR)
#define CMD0_PHY_REG_STATUS_PHY_CTRL_OF_IN_DELAY_VALUE_0 (0x038 + DDR_PHY_BASE_ADDR)
#define CMD0_PHY_REG_STATUS_PHY_CTRL_OF_OUT_DELAY_VALUE_0 (0x03C + DDR_PHY_BASE_ADDR)
//CMD1
#define CMD1_REG_PHY_CTRL_SLAVE_RATIO_0 (0x050 + DDR_PHY_BASE_ADDR)
#define CMD1_REG_PHY_CTRL_SLAVE_FORCE_0 (0x054 + DDR_PHY_BASE_ADDR)
#define CMD1_REG_PHY_CTRL_SLAVE_DELAY_0 (0x058 + DDR_PHY_BASE_ADDR)
#define CMD1_REG_PHY_DLL_LOCK_DIFF_0 (0x05C + DDR_PHY_BASE_ADDR)
#define CMD1_REG_PHY_INVERT_CLKOUT_0 (0x060 + DDR_PHY_BASE_ADDR)
#define CMD1_PHY_REG_STATUS_PHY_CTRL_DLL_LOCK_0 (0x064 + DDR_PHY_BASE_ADDR)
#define CMD1_PHY_REG_STATUS_PHY_CTRL_OF_IN_LOCK_STATE_0 (0x068 + DDR_PHY_BASE_ADDR)
#define CMD1_PHY_REG_STATUS_PHY_CTRL_OF_IN_DELAY_VALUE_0 (0x06C + DDR_PHY_BASE_ADDR)
#define CMD1_PHY_REG_STATUS_PHY_CTRL_OF_OUT_DELAY_VALUE_0 (0x070 + DDR_PHY_BASE_ADDR)
//CMD2
#define CMD2_REG_PHY_CTRL_SLAVE_RATIO_0 (0x084 + DDR_PHY_BASE_ADDR)
#define CMD2_REG_PHY_CTRL_SLAVE_FORCE_0 (0x088 + DDR_PHY_BASE_ADDR)
#define CMD2_REG_PHY_CTRL_SLAVE_DELAY_0 (0x08C + DDR_PHY_BASE_ADDR)
#define CMD2_REG_PHY_DLL_LOCK_DIFF_0 (0x090 + DDR_PHY_BASE_ADDR)
#define CMD2_REG_PHY_INVERT_CLKOUT_0 (0x094 + DDR_PHY_BASE_ADDR)
#define CMD2_PHY_REG_STATUS_PHY_CTRL_DLL_LOCK_0 (0x098 + DDR_PHY_BASE_ADDR)
#define CMD2_PHY_REG_STATUS_PHY_CTRL_OF_IN_LOCK_STATE_0 (0x09C + DDR_PHY_BASE_ADDR)
#define CMD2_PHY_REG_STATUS_PHY_CTRL_OF_IN_DELAY_VALUE_0 (0x0A0 + DDR_PHY_BASE_ADDR)
#define CMD2_PHY_REG_STATUS_PHY_CTRL_OF_OUT_DELAY_VALUE_0 (0x0A4 + DDR_PHY_BASE_ADDR)
//DATA0
#define DATA0_REG_PHY_DATA_SLICE_IN_USE_0 (0x0B8 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_DIS_CALIB_RST_0 (0x0BC + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RDC_FIFO_RST_ERR_CNT_CLR_0 (0x0C0 + DDR_PHY_BASE_ADDR)
#define DATA0_PHY_RDC_FIFO_RST_ERR_CNT_0 (0x0C4 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RD_DQS_SLAVE_RATIO_0 (0x0C8 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RD_DQS_SLAVE_RATIO_1 (0x0CC + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RD_DQS_SLAVE_FORCE_0 (0x0D0 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RD_DQS_SLAVE_DELAY_0 (0x0D4 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_RD_DQS_SLAVE_DELAY_1 (0x0D8 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DQS_SLAVE_RATIO_0 (0x0DC + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DQS_SLAVE_RATIO_1 (0x0E0 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DQS_SLAVE_FORCE_0 (0x0E4 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DQS_SLAVE_DELAY_0 (0x0E8 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DQS_SLAVE_DELAY_1 (0x0EC + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WRLVL_INIT_RATIO_0 (0x0F0 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WRLVL_INIT_RATIO_1 (0x0F4 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WRLVL_INIT_MODE_0 (0x0F8 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_GATELVL_INIT_RATIO_0 (0x0FC + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_GATELVL_INIT_RATIO_1 (0x100 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_GATELVL_INIT_MODE_0 (0x104 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_FIFO_WE_SLAVE_RATIO_0 (0x108 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_FIFO_WE_SLAVE_RATIO_1 (0x10C + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_FIFO_WE_IN_FORCE_0 (0x110 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_FIFO_WE_IN_DELAY_0 (0x114 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_FIFO_WE_IN_DELAY_1 (0x118 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_DQ_OFFSET_0 (0x11C + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DATA_SLAVE_RATIO_0 (0x120 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DATA_SLAVE_RATIO_1 (0x124 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DATA_SLAVE_FORCE_0 (0x128 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DATA_SLAVE_DELAY_0 (0x12C + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_WR_DATA_SLAVE_DELAY_1 (0x130 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_USE_RANK0_DELAYS_0 (0x134 + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_DLL_LOCK_DIFF_0 (0x138 + DDR_PHY_BASE_ADDR)
#define DATA0_PHY_REG_STATUS_DLL_LOCK_0 (0x13C + DDR_PHY_BASE_ADDR)
#define DATA0_PHY_REG_STATUS_OF_IN_LOCK_STATE_0 (0x140 + DDR_PHY_BASE_ADDR)
#define DATA0_PHY_REG_STATUS_OF_IN_DELAY_VALUE_0 (0x144 + DDR_PHY_BASE_ADDR)
#define DATA0_PHY_REG_STATUS_OF_OUT_DELAY_VALUE_0 (0x148 + DDR_PHY_BASE_ADDR)
//DATA1
#define DATA1_REG_PHY_DATA_SLICE_IN_USE_0 (0x15C + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_DIS_CALIB_RST_0 (0x160 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RDC_FIFO_RST_ERR_CNT_CLR_0 (0x164 + DDR_PHY_BASE_ADDR)
#define DATA1_PHY_RDC_FIFO_RST_ERR_CNT_0 (0x168 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RD_DQS_SLAVE_RATIO_0 (0x16C + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RD_DQS_SLAVE_RATIO_1 (0x170 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RD_DQS_SLAVE_FORCE_0 (0x174 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RD_DQS_SLAVE_DELAY_0 (0x178 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_RD_DQS_SLAVE_DELAY_1 (0x17C + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DQS_SLAVE_RATIO_0 (0x180 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DQS_SLAVE_RATIO_1 (0x184 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DQS_SLAVE_FORCE_0 (0x188 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DQS_SLAVE_DELAY_0 (0x18C + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DQS_SLAVE_DELAY_1 (0x190 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WRLVL_INIT_RATIO_0 (0x194 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WRLVL_INIT_RATIO_1 (0x198 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WRLVL_INIT_MODE_0 (0x19C + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_GATELVL_INIT_RATIO_0 (0x1A0 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_GATELVL_INIT_RATIO_1 (0x1A4 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_GATELVL_INIT_MODE_0 (0x1A8 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_FIFO_WE_SLAVE_RATIO_0 (0x1AC + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_FIFO_WE_SLAVE_RATIO_1 (0x1B0 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_FIFO_WE_IN_FORCE_0 (0x1B4 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_FIFO_WE_IN_DELAY_0 (0x1B8 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_FIFO_WE_IN_DELAY_1 (0x1BC + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_DQ_OFFSET_0 (0x1C0 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DATA_SLAVE_RATIO_0 (0x1C4 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DATA_SLAVE_RATIO_1 (0x1C8 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DATA_SLAVE_FORCE_0 (0x1CC + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DATA_SLAVE_DELAY_0 (0x1D0 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WR_DATA_SLAVE_DELAY_1 (0x1D4 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_USE_RANK0_DELAYS_0 (0x1D8 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_DLL_LOCK_DIFF_0 (0x1DC + DDR_PHY_BASE_ADDR)
#define DATA1_PHY_REG_STATUS_DLL_LOCK_0 (0x1E0 + DDR_PHY_BASE_ADDR)
#define DATA1_PHY_REG_STATUS_OF_IN_LOCK_STATE_0 (0x1E4 + DDR_PHY_BASE_ADDR)
#define DATA1_PHY_REG_STATUS_OF_IN_DELAY_VALUE_0 (0x1E8 + DDR_PHY_BASE_ADDR)
#define DATA1_PHY_REG_STATUS_OF_OUT_DELAY_VALUE_0 (0x1EC + DDR_PHY_BASE_ADDR)
//FIFO
#define FIFO_WE_OUT0_IO_CONFIG_I_0 (0x338 + DDR_PHY_BASE_ADDR)
#define FIFO_WE_OUT0_IO_CONFIG_SR_0 (0x33C + DDR_PHY_BASE_ADDR)
#define FIFO_WE_OUT1_IO_CONFIG_I_0 (0x340 + DDR_PHY_BASE_ADDR)
#define FIFO_WE_OUT1_IO_CONFIG_SR_0 (0x344 + DDR_PHY_BASE_ADDR)
#define FIFO_WE_IN2_IO_CONFIG_I_0 (0x348 + DDR_PHY_BASE_ADDR)
#define FIFO_WE_IN2_IO_CONFIG_SR_0 (0x34C + DDR_PHY_BASE_ADDR)
#define FIFO_WE_IN3_IO_CONFIG_I_0 (0x350 + DDR_PHY_BASE_ADDR)
#define FIFO_WE_IN3_IO_CONFIG_SR_0 (0x354 + DDR_PHY_BASE_ADDR)
//Leveling
#define DATA0_REG_PHY_WRLVL_NUM_OF_DQ0 (0x35C + DDR_PHY_BASE_ADDR)
#define DATA0_REG_PHY_GATELVL_NUM_OF_DQ0 (0x360 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_WRLVL_NUM_OF_DQ0 (0x364 + DDR_PHY_BASE_ADDR)
#define DATA1_REG_PHY_GATELVL_NUM_OF_DQ0 (0x368 + DDR_PHY_BASE_ADDR)
//Watchdog Timer registers
#define WDT1_BASE_ADDR (0x44E35000)
#define WDT1_WSPR (WDT1_BASE_ADDR + 0x48)
//Read write prototype
#define WR_MEM_32(addr, data) *(unsigned int*)(addr) = (unsigned int)(data)
#define RD_MEM_32(addr) *(unsigned int*)(addr)
#define UWORD32 unsigned int
//Global variables
UWORD32 CLKIN;
//Global Functions
//Watchdog is disabled to eliminate warm resets during debug
Disable_Watchdog()
WR_MEM_32(WDT1_WSPR,0x0000AAAA);
WR_MEM_32(WDT1_WSPR,0x00005555);
//Set the processor to ARM mode and Supervisor mode after a file is loaded, on a
//restart or on a reset
//This will facilitate code loading and debug by putting the processor in a known
//state
AM335xStartState()
CPSR &= ~0x20;
CPSR = (CPSR & ~0x1F) | 0x13;
OnFileLoaded()
AM335xStartState();
OnRestart()
AM335xStartState();
OnReset()
AM335xStartState();
Disable_Watchdog();
OnTargetConnect()
GEL_MapOff();
GEL_MapReset();
GEL_MapAddStr(0x00020000, 0, 0x0000C000, "R", 0); // Boot ROM
GEL_MapAddStr(0x08000000, 0, 0x01000000, "R|W", 0); // 16MB GPMC External/NOR (on GP Daughtercard)
GEL_MapAddStr(0x40020000, 0, 0x0000C000, "R", 0); // Boot ROM (also at 0x20000)
GEL_MapAddStr(0x402F0400, 0, 0x0000FC00, "R|W", 0); // SRAM Internal
GEL_MapAddStr(0x40300000, 0, 0x00010000, "R|W", 0); // OCMC-RAM
GEL_MapAddStr(0x44000000, 0, 0x00400000, "R|W", 0); // L3F CFG Regs
GEL_MapAddStr(0x44800000, 0, 0x00400000, "R|W", 0); // L3S CFG Regs
GEL_MapAddStr(0x44C00000, 0, 0x00400000, "R|W", 0); // L4_WKUP
GEL_MapAddStr(0x46000000, 0, 0x00400000, "R|W", 0); // McASP0 Data
GEL_MapAddStr(0x46400000, 0, 0x00400000, "R|W", 0); // McASP1 Data
GEL_MapAddStr(0x47400000, 0, 0x00005000, "R|W", 0); // USB0/1
GEL_MapAddStr(0x47810000, 0, 0x00010000, "R|W", 0); // MMCHS2
GEL_MapAddStr(0x48000000, 0, 0x01000000, "R|W", 0); // L4 PER
GEL_MapAddStr(0x49000000, 0, 0x00B00000, "R|W", 0); // EDMA
GEL_MapAddStr(0x4A000000, 0, 0x01000000, "R|W", 0); // L4_FAST
GEL_MapAddStr(0x4C000000, 0, 0x01000000, "R|W", 0); // EMIF
GEL_MapAddStr(0x50000000, 0, 0x01000000, "R|W", 0); // GPMC Regs
GEL_MapAddStr(0x56000000, 0, 0x01000000, "R|W", 0); // SGX530
GEL_MapAddStr(0x80000000, 0, 0x40000000, "R|W", 0); // 1GB DDR3 external memory
GEL_MapOn();
AM335xStartState();
AM335x_BeagleBlack_Initialization();
Disable_Watchdog();
//System Initialization
menuitem "AM335x System Initialization"
hotmenu AM335x_BeagleBlack_Initialization()
GEL_TextOut("**** AM335x BeagleBlack Initialization is in progress .......... \n","Output",1,1,1);
ARM_OPP100_Config();
DDR3_EMIF_Config();
GEL_TextOut("**** AM335x BeagleBlack Initialization is Done ****************** \n\n\n","Output",1,1,1);
hotmenu GetInputClockFrequency()
UWORD32 temp;
temp = RD_MEM_32(CONTROL_STATUS) >> 22;
temp = temp & 0x3;
if (temp == 0)
CLKIN = 19; //19.2MHz
GEL_TextOut("Input Clock Read from SYSBOOT[15:14]: 19.2MHz\n","Output",1,1,1);
if (temp == 1)
CLKIN = 24; //24MHz
GEL_TextOut("Input Clock Read from SYSBOOT[15:14]: 24MHz\n","Output",1,1,1);
if (temp == 2)
CLKIN = 25; //25MHz
GEL_TextOut("Input Clock Read from SYSBOOT[15:14]: 25MHz\n","Output",1,1,1);
if (temp == 3)
CLKIN = 26; //26MHz
GEL_TextOut("Input Clock Read from SYSBOOT[15:14]: 26MHz\n","Output",1,1,1);
hotmenu ARM_Turbo_Config()
unsigned int i;
GEL_TextOut("************************************************************************ \n","Output",1,1,1);
GEL_TextOut("**** NOTE: VDD_MPU must be set to 1.26V for Turbo mode to work!!! **** \n","Output",1,1,1);
for(i=0;i<100000;i++);
GEL_TextOut("**** AM335x ALL PLL Config for OPP == Turbo is in progress ......... \n","Output",1,1,1);
GetInputClockFrequency();
if(CLKIN==24)
MPU_PLL_Config( CLKIN, 23, 720, 1);
CORE_PLL_Config( CLKIN, 23, 1000, 10, 8, 4);
// DDR3 400MHz setting
DDR_PLL_Config( CLKIN, 23, 400, 1);
// DDR_PLL_Config( CLKIN, 23, 303, 1);
PER_PLL_Config( CLKIN, 23, 960, 5);
DISP_PLL_Config( CLKIN, 23, 48, 1);
GEL_TextOut(" **** AM335x ALL PLL Config for OPP == Turbo is done ......... \n","Output",1,1,1);
else
GEL_TextOut("**** AM335x PLL Config failed!! Check SYSBOOT[15:14] for proper input freq config \n","Output",1,1,1);
hotmenu ARM_OPP120_Config()
unsigned int i;
GEL_TextOut("**** NOTE: VDD_MPU must be set to 1.2V for OPP120 mode to work!!! **** \n","Output",1,1,1);
GEL_TextOut("**** AM335x ALL PLL Config for OPP == OPP120 is in progress ......... \n","Output",1,1,1);
if(CLKIN==24)
MPU_PLL_Config( CLKIN, 23, 600, 1);
GEL_TextOut(" **** AM335x ALL ADPLL Config for OPP == OPP120 is done ......... \n","Output",1,1,1);
else
hotmenu ARM_OPP100_Config()
GEL_TextOut("**** AM335x ALL PLL Config for OPP == OPP100 is in progress ......... \n","Output",1,1,1);
if(CLKIN==24)
MPU_PLL_Config( CLKIN, 23, 500, 1);
GEL_TextOut("**** AM335x ALL ADPLL Config for OPP == OPP100 is Done ......... \n","Output",1,1,1);
else
hotmenu ARM_OPP50_Config()
GEL_TextOut("\t **** AM335x ALL ADPLL Config for OPP == OPP50 is in Progress ......... \n","Output",1,1,1);
if(CLKIN==24)
MPU_PLL_Config( CLKIN, 23, 275, 1);
CORE_PLL_Config( CLKIN, 23, 50, 1, 1, 1);
PER_PLL_Config( CLKIN, 23, 960, 10);
Bypass_DISP_PLL();
GEL_TextOut("\t **** Subarctic ALL ADPLL Config for OPP == OPP50 IS Done ......... \n","Output",1,1,1);
else
GEL_TextOut("\t **** Subarctic PLL Config failed!! Check SYSBOOT[15:14] for proper input freq config \n","Output",1,1,1);
//PLL Configuration functions
MPU_PLL_Config(UWORD32 CLKIN,UWORD32 N,UWORD32 M,UWORD32 M2)
UWORD32 ref_clk,clk_out = 0;
UWORD32 clkmode,clksel,div_m2,idlest_dpll;
UWORD32 temp,i;
ref_clk = CLKIN/(N+1);
clk_out = (ref_clk*M)/M2;
clkmode=RD_MEM_32(CM_CLKMODE_DPLL_MPU);
clksel= RD_MEM_32(CM_CLKSEL_DPLL_MPU);
div_m2= RD_MEM_32(CM_DIV_M2_DPLL_MPU);
GEL_TextOut("**** Going to Bypass... \n","Output",1,1,1);
//put the DPLL in bypass mode
WR_MEM_32(CM_CLKMODE_DPLL_MPU,0x4);
while(((RD_MEM_32(CM_IDLEST_DPLL_MPU) & 0x101) != 0x00000100)); //wait for bypass status
GEL_TextOut("**** Bypassed, changing values... \n","Output",1,1,1);
//set multiply and divide values
clksel = clksel & (~0x7FFFF);
clksel = clksel | ((M <<0x8) | N);
WR_MEM_32(CM_CLKSEL_DPLL_MPU,clksel);
div_m2 = div_m2 & ~0x1F;
div_m2 = div_m2 | M2;
WR_MEM_32(CM_DIV_M2_DPLL_MPU,div_m2);
GEL_TextOut("**** Locking ARM PLL\n","Output",1,1,1);
//now lock the DPLL
clkmode = clkmode | 0x7; //enables lock mode
WR_MEM_32(CM_CLKMODE_DPLL_MPU,clkmode);
while(((RD_MEM_32(CM_IDLEST_DPLL_MPU) & 0x101) != 0x1)); //wait for lock
CORE_PLL_Config(UWORD32 CLKIN,UWORD32 N,UWORD32 M,UWORD32 M4,UWORD32 M5,UWORD32 M6)
UWORD32 ref_clk,clk_out4,clk_out5,clk_out6;
UWORD32 clkmode,clksel,div_m4,div_m5,div_m6,idlest_dpll;
clk_out4 = (ref_clk*M)/M4; //M4=200MHz
clk_out5 = (ref_clk*M)/M5; //M5=250MHz
clk_out6 = (ref_clk*M)/M6; //M6=500MHz
clkmode=RD_MEM_32(CM_CLKMODE_DPLL_CORE);
clksel= RD_MEM_32(CM_CLKSEL_DPLL_CORE);
div_m4= RD_MEM_32(CM_DIV_M4_DPLL_CORE);
div_m5= RD_MEM_32(CM_DIV_M5_DPLL_CORE);
div_m6= RD_MEM_32(CM_DIV_M6_DPLL_CORE);
//put DPLL in bypass mode
clkmode = (clkmode & 0xfffffff8)|0x00000004;
WR_MEM_32(CM_CLKMODE_DPLL_CORE,clkmode);
while((RD_MEM_32(CM_IDLEST_DPLL_CORE) & 0x00000100 )!=0x00000100); //wait for bypass status
GEL_TextOut("**** Core Bypassed\n","Output",1,1,1);
WR_MEM_32(CM_CLKSEL_DPLL_CORE,clksel);
div_m4= M4; //200MHz
WR_MEM_32(CM_DIV_M4_DPLL_CORE,div_m4);
div_m5= M5; //250MHz
WR_MEM_32(CM_DIV_M5_DPLL_CORE,div_m5);
div_m6= M6; //500MHz
WR_MEM_32(CM_DIV_M6_DPLL_CORE,div_m6);
GEL_TextOut("**** Now locking Core...\n","Output",1,1,1);
//now lock the PLL
clkmode =(clkmode&0xfffffff8)|0x00000007;
while((RD_MEM_32(CM_IDLEST_DPLL_CORE) & 0x00000001 )!=0x00000001);
GEL_TextOut("**** Core locked\n","Output",1,1,1);
DDR_PLL_Config(UWORD32 CLKIN,UWORD32 N,UWORD32 M,UWORD32 M2)
clkmode=RD_MEM_32(CM_CLKMODE_DPLL_DDR);
clksel= RD_MEM_32(CM_CLKSEL_DPLL_DDR);
div_m2= RD_MEM_32(CM_DIV_M2_DPLL_DDR);
clkmode =(clkmode&0xfffffff8)|0x00000004;
WR_MEM_32(CM_CLKMODE_DPLL_DDR,clkmode);
while((RD_MEM_32(CM_IDLEST_DPLL_DDR) & 0x00000100 )!=0x00000100);
GEL_TextOut("**** DDR DPLL Bypassed\n","Output",1,1,1);
WR_MEM_32(CM_CLKSEL_DPLL_DDR,clksel);
div_m2 = RD_MEM_32(CM_DIV_M2_DPLL_DDR);
div_m2 = (div_m2&0xFFFFFFE0) | M2;
WR_MEM_32(CM_DIV_M2_DPLL_DDR,div_m2);
while((RD_MEM_32(CM_IDLEST_DPLL_DDR) & 0x00000001 )!=0x00000001);
GEL_TextOut("**** DDR DPLL Locked\n","Output",1,1,1);
PER_PLL_Config(UWORD32 CLKIN,UWORD32 N,UWORD32 M,UWORD32 M2)
clkmode=RD_MEM_32(CM_CLKMODE_DPLL_PER);
clksel= RD_MEM_32(CM_CLKSEL_DPLL_PER);
div_m2= RD_MEM_32(CM_DIV_M2_DPLL_PER);
WR_MEM_32(CM_CLKMODE_DPLL_PER,clkmode);
while((RD_MEM_32(CM_IDLEST_DPLL_PER) & 0x00000100 )!=0x00000100);
GEL_TextOut("**** PER DPLL Bypassed\n","Output",1,1,1);
clksel = clksel & (~0xFF0FFFFF);
clksel = clksel | 0x04000000; //SD divider = 4 for both OPP100 and OPP50
WR_MEM_32(CM_CLKSEL_DPLL_PER,clksel);
div_m2= 0xFFFFFF80 | M2;
WR_MEM_32(CM_DIV_M2_DPLL_PER,div_m2);
while((RD_MEM_32(CM_IDLEST_DPLL_PER) & 0x00000001 )!=0x00000001);
GEL_TextOut("**** PER DPLL Locked\n","Output",1,1,1);
DISP_PLL_Config(UWORD32 CLKIN,UWORD32 N,UWORD32 M,UWORD32 M2)
GEL_TextOut("**** DISP PLL Config is in progress .......... \n","Output",1,1,1);
clkmode=RD_MEM_32(CM_CLKMODE_DPLL_DISP);
clksel= RD_MEM_32(CM_CLKSEL_DPLL_DISP);
div_m2= RD_MEM_32(CM_DIV_M2_DPLL_DISP);
WR_MEM_32(CM_CLKMODE_DPLL_DISP,clkmode);
while((RD_MEM_32(CM_IDLEST_DPLL_DISP) & 0x00000100 )!=0x00000100);
WR_MEM_32(CM_CLKSEL_DPLL_DISP,clksel);
div_m2= 0xFFFFFFE0 | M2;
WR_MEM_32(CM_DIV_M2_DPLL_DISP,div_m2);
while((RD_MEM_32(CM_IDLEST_DPLL_DISP) & 0x00000001 )!=0x00000001);
GEL_TextOut("**** DISP PLL Config is DONE .......... \n","Output",1,1,1);
Bypass_DISP_PLL()
UWORD32 clkmode;
GEL_TextOut("DISP PLL Bypass is in progress ....... \n","Output",1,1,1);
GEL_TextOut("DISP PLL Bypass is complete. \n","Output",1,1,1);
// DDR Configuration Section
//DDR3=400MHz
//OPP100
//DDR3 PHY parameters
// DDR3 400MHz settings
#define CMD_PHY_CTRL_SLAVE_RATIO 0x80
#define CMD_PHY_INVERT_CLKOUT 0x0
#define DATA_PHY_RD_DQS_SLAVE_RATIO 0x3B
#define DATA_PHY_FIFO_WE_SLAVE_RATIO 0x9D //RD DQS GATE
#define DATA_PHY_WR_DQS_SLAVE_RATIO 0x3E
#define DATA_PHY_WR_DATA_SLAVE_RATIO 0x77 //WRITE DATA
#define DDR_IOCTRL_VALUE (0x18B)
//EMIF parameters
// DDR3 400MHz settings -- Needs modified
#define ALLOPP_DDR3_READ_LATENCY 0x07 //RD_Latency = (CL + 2) - 1
//400MHz settings for 4Gb device -- Needs modified
#define ALLOPP_DDR3_SDRAM_TIMING1 0x0AAAd4DB
#define ALLOPP_DDR3_SDRAM_TIMING2 0x266B7FDA
#define ALLOPP_DDR3_SDRAM_TIMING3 0x501F867F
//#define ALLOPP_DDR3_SDRAM_TIMING1 0x0224419b
//#define ALLOPP_DDR3_SDRAM_TIMING2 0x4e2c7fda
//#define ALLOPP_DDR3_SDRAM_TIMING3 0x501F82bF
#define ALLOPP_DDR3_SDRAM_CONFIG 0x61C053B2 //0x61C04BB2 //termination = 1 (RZQ/4)
//dynamic ODT = 2 (RZQ/2)
//SDRAM drive = 0 (RZQ/6)
//CWL = 0 (CAS write latency = 5)
//CL = 2 (CAS latency = 5)
//ROWSIZE = 7 (16 row bits)
//PAGESIZE = 2 (10 column bits)
#define ALLOPP_DDR3_REF_CTRL 0x00000C30 //400 * 7.8us = 0xC30
#define ALLOPP_DDR3_ZQ_CONFIG 0x50074BE4
menuitem "AM335x DDR Configuration";
hotmenu DDR3_EMIF_Config()
UWORD32 i=0;
GEL_TextOut("**** AM335x DDR3 EMIF and PHY configuration is in progress......... \n","Output",1,1,1);
EMIF_PRCM_CLK_ENABLE();
GEL_TextOut("DDR PHY Configuration in progress \n","Output",1,1,1);
VTP_Enable();
PHY_Config_CMD();
PHY_Config_DATA();
GEL_TextOut("Setting IO control registers....... \n","Output",1,1,1,i);
WR_MEM_32(DDR_CMD0_IOCTRL,DDR_IOCTRL_VALUE);
WR_MEM_32(DDR_CMD1_IOCTRL,DDR_IOCTRL_VALUE);
WR_MEM_32(DDR_CMD2_IOCTRL,DDR_IOCTRL_VALUE);
WR_MEM_32(DDR_DATA0_IOCTRL,DDR_IOCTRL_VALUE);
WR_MEM_32(DDR_DATA1_IOCTRL,DDR_IOCTRL_VALUE);
//IO to work for DDR3
WR_MEM_32(DDR_IO_CTRL, RD_MEM_32(DDR_IO_CTRL) & ~0x10000000 );
//CKE controlled by EMIF/DDR_PHY
WR_MEM_32(DDR_CKE_CTRL, RD_MEM_32(DDR_CKE_CTRL) | 0x00000001);
GEL_TextOut("EMIF Timing register configuration is in progress ....... \n","Output",1,1,1);
WR_MEM_32(EMIF_DDR_PHY_CTRL_1_REG, ALLOPP_DDR3_READ_LATENCY);
WR_MEM_32(EMIF_DDR_PHY_CTRL_1_SHDW_REG, ALLOPP_DDR3_READ_LATENCY);
WR_MEM_32(EMIF_DDR_PHY_CTRL_2_REG, ALLOPP_DDR3_READ_LATENCY);
WR_MEM_32(EMIF_SDRAM_TIM_1_REG,ALLOPP_DDR3_SDRAM_TIMING1);
WR_MEM_32(EMIF_SDRAM_TIM_1_SHDW_REG,ALLOPP_DDR3_SDRAM_TIMING1);
WR_MEM_32(EMIF_SDRAM_TIM_2_REG,ALLOPP_DDR3_SDRAM_TIMING2);
WR_MEM_32(EMIF_SDRAM_TIM_2_SHDW_REG,ALLOPP_DDR3_SDRAM_TIMING2);
WR_MEM_32(EMIF_SDRAM_TIM_3_REG,ALLOPP_DDR3_SDRAM_TIMING3);
WR_MEM_32(EMIF_SDRAM_TIM_3_SHDW_REG,ALLOPP_DDR3_SDRAM_TIMING3);
WR_MEM_32(EMIF_SDRAM_REF_CTRL_REG,ALLOPP_DDR3_REF_CTRL);
WR_MEM_32(EMIF_SDRAM_REF_CTRL_SHDW_REG,ALLOPP_DDR3_REF_CTRL);
WR_MEM_32(EMIF_ZQ_CONFIG_REG,ALLOPP_DDR3_ZQ_CONFIG);
WR_MEM_32(EMIF_SDRAM_CONFIG_REG, ALLOPP_DDR3_SDRAM_CONFIG);
GEL_TextOut("EMIF Timing register configuration is done ....... \n","Output",1,1,1);
if((RD_MEM_32(EMIF_STATUS_REG) & 0x4) == 0x4)
GEL_TextOut("PHY is READY!!\n","Output",1,1,1);
GEL_TextOut("DDR PHY Configuration done \n","Output",1,1,1);
PHY_Config_CMD()
UWORD32 i=0;
for(i=0;i<3;i++)
GEL_TextOut("DDR PHY CMD%d Register configuration is in progress ....... \n","Output",1,1,1,i);
WR_MEM_32(CMD0_REG_PHY_CTRL_SLAVE_RATIO_0 + (i*0x34),CMD_PHY_CTRL_SLAVE_RATIO);
WR_MEM_32(CMD0_REG_PHY_INVERT_CLKOUT_0 + (i*0x34),CMD_PHY_INVERT_CLKOUT);
PHY_Config_DATA()
UWORD32 i;
for(i=0;i<2;i++)
GEL_TextOut("DDR PHY DATA%d Register configuration is in progress ....... \n","Output",1,1,1,i);
WR_MEM_32(DATA0_REG_PHY_RD_DQS_SLAVE_RATIO_0 + (i*0xA4),DATA_PHY_RD_DQS_SLAVE_RATIO);
WR_MEM_32(DATA0_REG_PHY_WR_DQS_SLAVE_RATIO_0 + (i*0xA4),DATA_PHY_WR_DQS_SLAVE_RATIO);
WR_MEM_32(DATA0_REG_PHY_FIFO_WE_SLAVE_RATIO_0 + (i*0xA4),DATA_PHY_FIFO_WE_SLAVE_RATIO);
WR_MEM_32(DATA0_REG_PHY_WR_DATA_SLAVE_RATIO_0 + (i*0xA4),DATA_PHY_WR_DATA_SLAVE_RATIO);
hotmenu EMIF_PRCM_CLK_ENABLE()
GEL_TextOut("EMIF PRCM is in progress ....... \n","Output",1,1,1);
/* Enable EMIF4 clocks*/
WR_MEM_32(CM_PER_EMIF_CLKCTRL,0x02);
/* Poll if module is functional */
while(RD_MEM_32(CM_PER_EMIF_CLKCTRL)!= 0x02);
GEL_TextOut("EMIF PRCM Done \n","Output",1,1,1);
//VTP_Enable() routine *
VTP_Enable()
//clear the register
WR_MEM_32(VTP_CTRL_REG ,0x0);
//set filter bits to 011b
WR_MEM_32(VTP_CTRL_REG ,0x6);
//Write 1 to enable VTP
WR_MEM_32(VTP_CTRL_REG ,(RD_MEM_32(VTP_CTRL_REG) | 0x00000040));
//Write 0 to CLRZ bit
WR_MEM_32(VTP_CTRL_REG ,(RD_MEM_32(VTP_CTRL_REG) & 0xFFFFFFFE));
//Write 1 to CLRZ bit
WR_MEM_32(VTP_CTRL_REG ,(RD_MEM_32(VTP_CTRL_REG) | 0x00000001));
//Check for VTP ready bit
GEL_TextOut("Waiting for VTP Ready ....... \n","Output",1,1,1);
while((RD_MEM_32(VTP_CTRL_REG) & 0x00000020) != 0x00000020);
GEL_TextOut("VTP is Ready! \n","Output",1,1,1);
//simple DDR test
#define NO_LOOP_CNT 250
#define DDR_START_ADDR 0x80000000
menuitem "AM335x DDR Tests"
hotmenu DDR_DataTransferCheck()
unsigned int temp_reg_rd = 0;
unsigned int temp_reg_wr = 0xA5A5A5A5;
unsigned int i=0;
unsigned int error=0;
GEL_TextOut("Try Accessing DDR memory....Write data\n");
for (i=0;i<NO_LOOP_CNT; i++)
*((UWORD32 *)DDR_START_ADDR + (i)) = temp_reg_wr;
//GEL_TextOut("Data Written is :: %x \n",,,,,(unsigned int *)i);
GEL_TextOut("Data written at :: %x \n",,,,,(unsigned int *)DDR_START_ADDR + (i));
temp_reg_rd = *((UWORD32 *)DDR_START_ADDR + (i));
// GEL_TextOut("Data Read is :: %x \n",,,,,(unsigned int *)temp_reg_rd);
if(temp_reg_rd != 0xA5A5A5A5)
//GEL_TextOut("Data check failed at :: %x \n",,,,,(unsigned int *)DDR_START_ADDR + (i));
error++;
else
//GEL_TextOut("Data check passed at :: %x \n",,,,,(unsigned int *)DDR_START_ADDR + (i));
GEL_TextOut("No of Failed locations are :: %x \n",,,,,(unsigned int *)error);
if(error != 0)
GEL_TextOut("Data Integrity check Failed ");
else {
GEL_TextOut("Data Integrity check Passed\n");
//EDMA tests for DDR
#define TPCC_BASE_ADDR 0x49000000
#define INT_SRAM_BASE_ADDR 0x00300000
#define DDR_BASE_ADDR 0x80000000
#define DMA_SIZE 512 /*Words*/
#define L3_OFFSET_ADDR 0x40000000
#define CPU_OFFSET_ADDR 0x40000000
#define CM_PER_TPTC0_CLKCTRL (PRCM_BASE_ADDR +0x0024)
#define CM_PER_TPCC_CLKCTRL (PRCM_BASE_ADDR +0x00BC)
#define CM_PER_TPTC1_CLKCTRL (PRCM_BASE_ADDR +0x00FC)
#define CM_PER_TPTC2_CLKCTRL (PRCM_BASE_ADDR +0x0100)
hotmenu EDMA()
unsigned int pattern=0;
unsigned int queuqePri=0;
unsigned int TPTC0_MMU_MAP=0;
GEL_TextOut("\n\nThis EDMA test consists of 8 tests.\n");
EdmaPrcm();
memWrite(DDR_BASE_ADDR, 0x100, 0);
memWrite(0x40300000, 0x100, 0);
/*DDR ->Internal SRAM EDMA data Transfer */
GEL_TextOut("\nTest 1\n");
pattern=0xAAAAAAAA;
queuqePri=0;
memWrite(DDR_BASE_ADDR, DMA_SIZE, pattern);
edmaConfigure(DDR_BASE_ADDR, (INT_SRAM_BASE_ADDR+L3_OFFSET_ADDR), DMA_SIZE, queuqePri);
compare((INT_SRAM_BASE_ADDR+CPU_OFFSET_ADDR), DMA_SIZE, pattern);
GEL_TextOut("\n");
/*Internal SRAM->DDR EDMA data Transfer */
memWrite(((INT_SRAM_BASE_ADDR+CPU_OFFSET_ADDR)+4*DMA_SIZE), DMA_SIZE, pattern);
edmaConfigure(((INT_SRAM_BASE_ADDR+L3_OFFSET_ADDR)+4*DMA_SIZE), (DDR_BASE_ADDR+4*DMA_SIZE), DMA_SIZE, queuqePri);
compare((DDR_BASE_ADDR+4*DMA_SIZE), DMA_SIZE, pattern);
GEL_TextOut("\n");
GEL_TextOut("\nTest 2\n");
pattern=0x55555555;
queuqePri=1;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 3\n");
pattern=0x00FF00FF;
queuqePri=2;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 4\n");
pattern=0x80808080;
queuqePri=3;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 5\n");
pattern=0xCCCCCCCC;
queuqePri=4;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 6\n");
pattern=0xA0A0A0A0;
queuqePri=5;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 7\n");
pattern=0x12345678;
queuqePri=6;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("\nTest 8\n");
pattern=0xAA55AA55;
queuqePri=7;
GEL_TextOut("\n");
GEL_TextOut("\n");
GEL_TextOut("Test is complete\n");
edmaConfigure(unsigned int srcAddr, unsigned DstAddr, unsigned short dmaSize, unsigned int QUEPRI)
GEL_TextOut("\EDMA Transfer Start for QUEPRI %x\n",,,,,QUEPRI);
WR_MEM_32(TPCC_BASE_ADDR +0x0284, (QUEPRI&0x7));
WR_MEM_32(TPCC_BASE_ADDR +0x0340, 0x00000001);
WR_MEM_32(TPCC_BASE_ADDR +0x0240, 0x00000000);
WR_MEM_32(TPCC_BASE_ADDR +0x0100, 0x00000000);
WR_MEM_32(TPCC_BASE_ADDR +0x4000, 0x00100200);
WR_MEM_32(TPCC_BASE_ADDR +0x4004, srcAddr);
WR_MEM_32(TPCC_BASE_ADDR +0x400C, DstAddr);
WR_MEM_32(TPCC_BASE_ADDR +0x4008, 0x00010000 | (dmaSize * 4)); /* byte len */
WR_MEM_32(TPCC_BASE_ADDR +0x401C, 0x00000001);
WR_MEM_32(TPCC_BASE_ADDR +0x4010, 0x00000000);
WR_MEM_32(TPCC_BASE_ADDR +0x4018, 0x00000000);
WR_MEM_32(TPCC_BASE_ADDR +0x4014, 0x0000ffff);
WR_MEM_32(TPCC_BASE_ADDR +0x1060, 0x00000001);
WR_MEM_32(TPCC_BASE_ADDR +0x1010, 0x00000001);
while( (RD_MEM_32(TPCC_BASE_ADDR+0x1068)&0x1) !=1 ) {}
WR_MEM_32(TPCC_BASE_ADDR+0x1070, 0x1);
GEL_TextOut("\EDMA Transfer Complete for QUEPRI %x\n",,,,,QUEPRI);
memWrite(unsigned int Addr, unsigned int size, unsigned int initData)
unsigned int len=0;
for(len=0; len<size; len++) {
WR_MEM_32(Addr+4*len, (initData+len));
GEL_TextOut("Write is completed Starting @%x\n",,,,,Addr);
compare(unsigned int Addr, unsigned int size, unsigned int initData)
unsigned int len=0, fail=0;
if( RD_MEM_32(Addr+4*len) != (initData+len) ) {
GEL_TextOut("\nFailed@%x\tExpected=%x \tRead=%x\n",,,,,(Addr+4*len),(initData+len),RD_MEM_32(Addr+4*len) );
fail++;
if(fail==0) {
GEL_TextOut("Test Case Passed for Destination Addr=%x\n",,,,,Addr);
EdmaPrcm() {
WR_MEM_32(CM_PER_TPCC_CLKCTRL, 2); // it was L3
WR_MEM_32(CM_PER_TPTC0_CLKCTRL , 2);
WR_MEM_32(CM_PER_TPTC1_CLKCTRL , 2);
WR_MEM_32(CM_PER_TPTC2_CLKCTRL , 2);
// SYS_CLKOUT2 Configuration Section
menuitem "SYS_CLKOUT2"
hotmenu OSC_32KHz()
set_CLKOUT2(0);
hotmenu L3_CLK()
set_CLKOUT2(1);
//DDR needs to be enabled
hotmenu DDR_PHY_Clock()
set_CLKOUT2(2);
hotmenu PER_Clock()
set_CLKOUT2(3);
hotmenu LCD_Clock()
set_CLKOUT2(4);
set_CLKOUT2(UWORD32 mode)
unsigned int temp;
unsigned int divider = 2; //change here if you want to pick a different divider
WR_MEM_32(CONF_XDMA_EVENT_INTR1,0x3); // Set Pinmux to mode 3 (and rest to zero)
WR_MEM_32(CM_CLKOUT_CTRL, (divider-1) << 3); //Set divider (which is set above)
temp = RD_MEM_32(CM_CLKOUT_CTRL);
temp = (temp & ~(0x7) ) | mode;
WR_MEM_32(CM_CLKOUT_CTRL,temp);
enable_SYS_CLKOUT2();
if(mode == 0)
GEL_TextOut(" **** SYS_CLKOUT2 = 32khz Crystal (divided by %d)\n",,,,,(unsigned int *)(divider));
else if (mode == 1)
GEL_TextOut(" **** SYS_CLKOUT2 = L3 (From Core PLL) (divided by %d)\n",,,,,(unsigned int *)(divider));
else if (mode == 2)
GEL_TextOut(" **** SYS_CLKOUT2 = DDR PHY CLK (divided by %d)\n",,,,,(unsigned int *)(divider));
else if (mode == 3)
GEL_TextOut(" **** SYS_CLKOUT2 = Per PLL Clock (192 Mhz)(divided by %d)\n",,,,,(unsigned int *)(divider));
else
GEL_TextOut(" **** SYS_CLKOUT2 = LCD Pixel Clock (divided by %d)\n",,,,,(unsigned int *)(divider));
unsigned int temp;
temp = temp | 0x80;
menuitem "Status"
hotmenu Device_Type()
unsigned int temp;
temp = RD_MEM_32(CONTROL_STATUS);
temp = (temp & 0x700) >> 8;
if (temp == 0)
GEL_TextOut(" **** Device Type: Test\n","Output",1,1,1);
else if (temp == 1)
GEL_TextOut(" **** Device Type: EMU\n","Output",1,1,1);
else if (temp == 2)
GEL_TextOut(" **** Device Type: HS\n","Output",1,1,1);
else if (temp == 3)
GEL_TextOut(" **** Device Type: GP\n","Output",1,1,1);
else
GEL_TextOut(" **** Device Type: INVALID\n","Output",1,1,1);
//DS0
menuitem "DeepSleep0"
hotmenu EMIF_PRCM_CLK_DISABLE()
GEL_TextOut("EMIF PRCM DISABLE is in progress ....... \n","Output",1,1,1);
/* Disable EMIF4 clocks*/
WR_MEM_32(CM_PER_EMIF_CLKCTRL,0x0);
/* Poll if module is disabled */
while(RD_MEM_32(CM_PER_EMIF_CLKCTRL)!= 0x30000);
GEL_TextOut("EMIF PRCM is Disabled \n","Output",1,1,1);
hotmenu Enter_DS0()
unsigned int temp;
unsigned int i;
EMIF_PRCM_CLK_ENABLE();//Enabled EMIF
//DDR2_EMIF_Config();
//WR_MEM_32((0x80000000),0x12345678);
//cmd_DDR2_EMIF_Config(0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0);
WR_MEM_32((0x44e10e04),0x10000000); //MDDR SEL
//WR_MEM_32((0x44e10e04),0x00000000); //DDR2 SEL
//WR_MEM_32((0x44e10e0C),0x00010100); //Disable VTP with N & P = 0x1
//WR_MEM_32((0x44e10e0C),0x0010107); //Disable VTP with N & P = 0x1
WR_MEM_32((0x4c000e14),0x00000000); //Disable Internal VREF
//power down the PHYs from the EMIF controller
WR_MEM_32((0x4c0000e4),0x00100000); //Configure DYN PD
WR_MEM_32((0x4c0000e8),0x00100000); //Configure DYN PD
//WR_MEM_32((0x4c0000ec),0x00100000); //Configure DYN PD
//WR_MEM_32((0x4c000008),0x40805332); //disable ODT
// for(i=0;i<5000;i++)
//PUDIS for DATA
//Weak Pull down for DQ, DM and DQS
WR_MEM_32((0x44e11440),0x3FF00003);
WR_MEM_32((0x44e11444),0x3FF00003);
WR_MEM_32((0x44e11404),0xFFE0018b);
WR_MEM_32((0x44e11408),0xFFE0018b);
WR_MEM_32((0x44e1140C),0xFFa0098B);
//Put DDR in Self Refresh
WR_MEM_32((0x4c000038),0x000002a0);
WR_MEM_32((0x4c00003C),0x000002a0); //write to shadow register
//Control CKE from Control Module
WR_MEM_32((0x44e1131c),0x00000001); //disable CKE from control module
//WR_MEM_32((0x44e10e0C),0x000); //Disable VTP with N & P = 0x1
//Disable EMIF
EMIF_PRCM_CLK_DISABLE();
WR_MEM_32((0x44e10470),0x00026a75); //OSC0_CLK/VTP_CLK gating
hotmenu Exit_DS0()
unsigned int temp;
unsigned int i;
Please help me with this regard.
Sachin
