Linux/AM3354: USB Camera Issue in AM335x
Part Number: AM3354
Tool/software: Linux
When tried to capture image from camera it fails returning X I/O Error to user space console and uvcvideo: Failed to resubmit video URB (-1). , uvcvideo: Failed to resubmit video URB (-71). is returned in kernel log(dmesg).
musb_host_rx 1774: Rx interrupt with no errors or packet!
    The error messages 1 and 71 correspond to "operation not permitted" and Eproto error.
    For more info look at the error code source :
    www.virtsync.com/c-error-codes-include-errno
    Description about the error :
    www.kernel.org/.../error-codes.html
    Also, have you checked this post which describes setting up USB camera in AM335x?
    e2e.ti.com/.../223368
    Prabhuraj
    BlackPepper technologies
    I would like to add to previous response that you can find more details about USB Request Block, or URB at:
    /linux/Documentations/usb/UBR.txt file
    The error message "Failed to resubmit video URB (-1)" is printed by function uvc_video_complete in /linux/drivers/media/usb/uvc/uvc_video.c file where you can add debug messages for further investigation.
    BR
    Tsvetolin Shulev
    Can you also share the dmesg logs while this error is coming? Which application are you trying to run to test the USB camera?
    thanks,
    Prabhuraj
    BlackPepper Technologies
  • We are using luvcview-0.2.6 for testing the Camera, We had shared the dmesg log in our first post. any how i will add the same for you again.
    Running lucview on AM335x will require you to have dependent packages.
    Are you taking care of packages like sdl, uvcdynctrl etc.. ?
    Have a look at the below link and ensure that you meet the environment dependency.
    github.com/.../luvcview
    Prabhuraj
    We have downloaded and compiled the same source from the link you shared.
    N.Krishnakanth
