Part Number: EVMK2H
Tool/software: Linux
I updated my SDK, and flashed my board with new u-boot and tisdk-server-rootfs-image-k2hk-evm.ubi . But some how for any reason i am not getting the login screen.
I am sharing the logs.
U-Boot SPL 2017.01-g9fd60700db (Jun 28 2017 - 20:20:26)
Trying to boot from SPI
U-Boot 2017.01-g9fd60700db (Jun 28 2017 - 20:20:26 -0400)
CPU: 66AK2Hx SR2.0
Model: Texas Instruments Keystone 2 Kepler/Hawking EVM
I2C: ready
DRAM: DDR3A Speed will be configured for 1333 Operation.
Detected SO-DIMM [SQR-SD3T-2G1333SED]
DDR3 speed 1333
DRAM: 2 GiB (includes reported below)
Clear entire DDR3 memory to enable ECC
2 GiB
NAND: 512 MiB
Net: eth0: netcp@2000000
Warning: netcp@slave-1 (eth1) using random MAC address - 4e:a4:ce:89:7d:c2
, eth1: netcp@slave-1
Warning: netcp@slave-2 (eth2) using random MAC address - de:6f:aa:21:00:56
, eth2: netcp@slave-2
Warning: netcp@slave-3 (eth3) using random MAC address - 62:7a:8d:4e:15:b9
, eth3: netcp@slave-3
Hit any key to stop autoboot: 0
ubi0: attaching mtd1
ubi0: scanning is finished
ubi0: attached mtd1 (name "mtd=2", size 510 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4080, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1220237982
ubi0: available PEBs: 0, total reserved PEBs: 4080, PEBs reserved for bad PEB handling: 76
Loading file '/boot/skern-k2hk.bin' to addr 0x87000000...
Done
K2_BM_15.07-53-ge1f885a SoC:k2hk built:17:59:36, Jun 28 2017
## installed monitor @ 0xc5f0000, freq [200000000], status 207552512
Loading file '/boot/zImage' to addr 0x82000000...
Done
Loading file '/boot/k2-fw-initrd.cpio.gz' to addr 0x88080000...
Done
Loading file '/boot/keystone-k2hk-evm.dtb' to addr 0x88000000...
Done
Loading Ramdisk to 8fff3000, end 8ffff3a5 ... OK
Loading Device Tree to 8ffe5000, end 8fff280b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.28-rt16-g786e64041b (gtbldadm@ubuntu-16) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT RT Wed Jun 28 18:18:17 EDT 2017
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt:Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM
[ 0.000000] Switching physical address space to 0x800000000
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp_common_cma_pool@81f800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000820000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node dsp_common_mpm_pool@820000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 64 MiB at 0x000000087bc00000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 13 pages/cpu @de59f000 s22752 r8192 d22304 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 358720
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 1339320K/1441792K available (8192K kernel code, 252K rwdata, 2224K rodata, 2048K init, 324K bss, 28744K reserved, 73728K cma-reserved, 851968K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc103f320 ( 253 kB)
[ 0.000000] .bss : 0xc1041000 - 0xc1092298 ( 325 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000008] Switching to timer-based delay loop, resolution 5ns
[ 0.000180] keystone timer clock @200000000 Hz
[ 0.000388] Console: colour dummy device 80x30
[ 0.000485] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=2000000)
[ 0.000488] pid_max: default: 32768 minimum: 301
[ 0.000576] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000580] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001175] CPU: Testing write buffer coherency: ok
[ 0.001377] /cpus/cpu@0 missing clock-frequency property
[ 0.001411] /cpus/cpu@1 missing clock-frequency property
[ 0.001435] /cpus/cpu@2 missing clock-frequency property
[ 0.001459] /cpus/cpu@3 missing clock-frequency property
[ 0.001467] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001480] Setting up static identity map for 0x80200000 - 0x80200138
[ 0.120202] EFI services will not be available.
[ 0.245104] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.345230] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.445356] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.445512] Brought up 4 CPUs
[ 0.445532] SMP: Total of 4 processors activated (1600.00 BogoMIPS).
[ 0.445538] CPU: All CPU(s) started in HYP mode.
[ 0.445543] CPU: Virtualization extensions available.
[ 0.445996] devtmpfs: initialized
[ 0.456597] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.456800] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.456814] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.457941] pinctrl core: initialized pinctrl subsystem
[ 0.458630] NET: Registered protocol family 16
[ 0.459643] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.460754] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.460763] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.468187] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.468389] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.468594] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.468800] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.469001] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.469207] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.469410] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.469611] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.484471] vgaarb: loaded
[ 0.485975] pps_core: LinuxPPS API ver. 1 registered
[ 0.485982] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.486000] PTP clock support registered
[ 0.486028] EDAC MC: Ver: 3.0.0
[ 0.487380] clocksource: Switched to clocksource arch_sys_counter
[ 0.495838] NET: Registered protocol family 2
[ 0.496302] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.496339] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[ 0.496471] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.496514] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.496543] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.496695] NET: Registered protocol family 1
[ 0.497009] RPC: Registered named UNIX socket transport module.
[ 0.497016] RPC: Registered udp transport module.
[ 0.497022] RPC: Registered tcp transport module.
[ 0.497027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.497231] Trying to unpack rootfs image as initramfs...
[ 0.500549] Freeing initrd memory: 52K (cfff3000 - d0000000)
[ 0.500730] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.501382] platform alarmtimer: set dma_pfn_offset00780000
[ 0.502356] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.509200] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.509873] NFS: Registering the id_resolver key type
[ 0.509905] Key type id_resolver registered
[ 0.509912] Key type id_legacy registered
[ 0.509948] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.511055] bounce: pool size: 64 pages
[ 0.511184] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.511193] io scheduler noop registered
[ 0.511200] io scheduler deadline registered
[ 0.511311] io scheduler cfq registered (default)
[ 0.511555] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28
[ 0.512148] ti,keystone-serdes 232a000.phy: init fw ks2_gbe_serdes.bin: version 3.3.0.2c
[ 0.517589] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192
[ 0.517723] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek f0fa0000, reg_status f096d000, reg_config f096f000, reg_region f0971000, reg_push f0fe0000, reg_pop f1020000
[ 0.517734] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192
[ 0.517849] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek f1060000, reg_status f0973400, reg_config f0975000, reg_region f0977000, reg_push f10a0000, reg_pop f10e0000
[ 0.518008] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_acc48.bin downloaded for PDSP
[ 0.520822] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
[ 0.520954] keystone-navigator-dma soc:knav_dmas@0: DMA dma_xgbe registered 48 logical channels, flows 32, tx chans: 16, rx chans: 16
[ 0.572916] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.573003] platform serial8250: set dma_pfn_offset00780000
[ 0.575407] console [ttyS0] disabled
[ 0.575456] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 12500000) is a TI DA8xx/66AK2x
[ 1.414476] console [ttyS0] enabled
[ 1.418734] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 12500000) is a TI DA8xx/66AK2x
[ 1.441808] [drm] Initialized
[ 1.455084] brd: module loaded
[ 1.463323] loop: module loaded
[ 1.467482] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[ 1.476507] spi_davinci 21000400.spi: DMA is not supported (-19)
[ 1.483272] m25p80 spi0.0: n25q128a11 (16384 Kbytes)
[ 1.488274] 2 ofpart partitions found on MTD device spi0.0
[ 1.493777] Creating 2 MTD partitions on "spi0.0":
[ 1.498586] 0x000000000000-0x000000100000 : "u-boot-spl"
[ 1.504846] 0x000000100000-0x000001000000 : "misc"
[ 1.510545] spi_davinci 21000400.spi: Controller at 0xf0fdb400
[ 1.516661] spi_davinci 21000600.spi: DMA is not supported (-19)
[ 1.523051] spi_davinci 21000600.spi: Controller at 0xf0fdd600
[ 1.529175] spi_davinci 21000800.spi: DMA is not supported (-19)
[ 1.535541] spi_davinci 21000800.spi: Controller at 0xf101c800
[ 1.541821] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
[ 1.548087] libphy: Fixed MDIO Bus: probed
[ 1.607421] davinci_mdio 2090300.mdio: davinci mdio revision 1.5
[ 1.613448] libphy: 2090300.mdio: probed
[ 1.618171] davinci_mdio 2090300.mdio: phy[0]: device 2090300.mdio:00, driver Marvell 88E1111
[ 1.626730] davinci_mdio 2090300.mdio: phy[1]: device 2090300.mdio:01, driver Marvell 88E1111
[ 1.635894] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
[ 2.151970] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
[ 2.672321] netcp-1.0 2620110.netcp: cpts: overflow check period 350 (jiffies)
[ 2.679590] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:600000000 calc_mult:3579139413 calc_shift:31 error:-1 nsec/sec
[ 2.690330] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.3
[ 2.696793] netcp-1.0 2620110.netcp: ALE Table size 1024
[ 2.703100] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
[ 2.710285] netcp-1.0 2620110.netcp: pa_clk_rate(163840000 HZ),mult(25000),shift(12)
[ 2.719686] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 0
[ 2.727899] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 1
[ 2.736107] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 2
[ 2.744316] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 3
[ 2.752525] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 4
[ 2.760734] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.03:0x03000203 on pdsp 5
[ 2.769647] netcp-1.0 2620110.netcp: module(netcp-pa2) not used for device
[ 2.776816] mousedev: PS/2 mouse device common for all mice
[ 2.782663] i2c /dev entries driver
[ 2.790338] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
[ 2.796715] nand: Micron MT29F4G08ABBDAHC
[ 2.800738] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 2.808644] Bad block table found at page 262080, version 0x01
[ 2.815020] Bad block table found at page 262016, version 0x01
[ 2.821207] 3 ofpart partitions found on MTD device 30000000.nand
[ 2.827321] Creating 3 MTD partitions on "30000000.nand":
[ 2.832739] 0x000000000000-0x000000100000 : "u-boot"
[ 2.838644] 0x000000100000-0x000000180000 : "params"
[ 2.844572] 0x000000180000-0x000020000000 : "ubifs"
[ 2.854496] davinci_nand 30000000.nand: controller rev. 2.5
[ 2.860846] NET: Registered protocol family 10
[ 2.866232] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.872669] NET: Registered protocol family 17
[ 2.877283] Key type dns_resolver registered
[ 2.881683] Registering SWP/SWPB emulation handler
[ 2.892130] ubi0: attaching mtd4
[ 3.207392] (NULL net_device): Link is Down
[ 3.211590] (NULL net_device): Link is Down
[ 5.047545] ubi0: scanning is finished
[ 5.062079] ubi0: attached mtd4 (name "ubifs", size 510 MiB)
[ 5.067772] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.074672] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.081484] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.088471] ubi0: good PEBs: 4080, bad PEBs: 4, corrupted PEBs: 0
[ 5.094584] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 5.101832] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1220237982
[ 5.111000] ubi0: available PEBs: 0, total reserved PEBs: 4080, PEBs reserved for bad PEB handling: 76
[ 5.120356] ubi0: background thread "ubi_bgt0d" started, PID 118
[ 5.120529] hctosys: unable to open rtc device (rtc0)
[ 5.143140] UBIFS: parse sync
[ 5.146784] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 120
[ 5.211265] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 5.218692] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 5.228646] UBIFS (ubi0:0): FS size: 506507264 bytes (483 MiB, 3989 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 5.239384] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 5.245238] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 37C80A12-EE78-4F7E-924B-9C7DEA609604, small LPT model
[ 5.257743] VFS: Mounted root (ubifs filesystem) on device 0:14.
[ 5.265412] devtmpfs: mounted
[ 5.269729] Freeing unused kernel memory: 2048K (c0e00000 - c1000000)
[ 5.499574] systemd[1]: System time before build time, advancing clock.
[ 5.556691] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.583956] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.592797] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 5.611817] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.05!
[ 5.648609] systemd[1]: Set hostname to <k2hk-evm>.
[ 5.659354] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.666009] systemd[1]: Initializing machine ID from random generator.
[ 6.551625] systemd[1]: Installed transient /etc/machine-id file.
[ 6.664992] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 6.699467] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 6.722358] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 6.791886] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.856332] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.863226] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.870317] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.118109] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.157612] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.198229] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.237612] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.270557] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
Starting Create list of required st... nodes for the current kernel...
[ OK ] Created slice system-getty.slice.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
Starting Setup Virtual Console...
[ OK ] Listening on udev Control Socket.
Starting Load Kernel Modules...
[ 7.506234] cmemk: loading out-of-tree module taints kernel.
[ 7.512645] CMEMK module: reference Linux version 4.9.28
[ 7.518398] allocated heap buffer 0xc100000 of size 0x480000
[ 7.524094] cmemk initialized
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.543985] cryptodev: driver 1.8 loaded.
Mounting POSIX Message Queue File System...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 7.607730] NET: Registered protocol family 43
[ OK ] Reached targe[ 7.620100] uio_module_drv soc:mpax: registered misc device mpax
t Paths.
[ 7.627661] uio_module_drv soc:edma3: registered misc device edma3
[ 7.634739] uio_module_drv soc:secmgr: registered misc device secmgr
[ 7.641346] uio_module_drv soc:qmss: registered misc device qmss
[ 7.655987] uio_module_drv soc:hyperlink0: registered misc device hyperlink0
[ 7.663827] uio_module_drv soc:hyperlink1: registered misc device hyperlink1
[ OK 7.671480] uio_module_drv soc:srio: registered misc device srio
m] Created slice system-serial\x2dgetty.slice.
Starting Remount Root and Kernel File Systems...
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Reached target Swap.
Mounting Temporary Directory...
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
Mounting Debug File System...
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Rebuild Hardware Database...
Mounting Configuration File System...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[FAILED] Failed to mount /media/ram.
See 'systemctl status media-ram.mount' for details.
[DEPEND] Dependency failed for Local File Systems.
[ OK ] Started udev Kernel Device Manager.
[ 8.921842] systemd-journald[180]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Timers.
[ OK ] Reached target Login Prompts.
Starting Network Service...
[ OK ] Closed Syslog Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Emergency Shell.
[ OK ] Reached target Emergency Mode.
[ 9.151687] random: fast init done
Starting Rebuild Journal Catalog...
Starting Commit a transient machine-id on disk...
Starting Rebuild Dynamic Linker Cache...
Starting Load/Save Random Seed...
[ OK ] Started Network Service.
[ OK ] Started Flush Journal to Persistent Storage.
[FAILED] Failed to start Rebuild Journal Catalog.
See 'systemctl status systemd-journal-catalog-update.service' for details.
[FAILED] Failed to start Commit a transient machine-id on disk.
See 'systemctl status systemd-machine-id-commit.service' for details.
[ OK ] Started Load/Save Random Seed.
Starting Create Volatile Files and Directories...
[ OK ] Reached target Network.
[FAILED] Failed to start Create Volatile Files and Directories.
See 'systemctl status systemd-tmpfiles-setup.service' for details.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
[ OK ] Started Network Time Synchronization.
[FAILED] Failed to start Rebuild Hardware Database.
See 'systemctl status systemd-hwdb-update.service' for details.
[FAILED] Failed to start Rebuild Dynamic Linker Cache.
See 'systemctl status ldconfig.service' for details.
Starting Update is Completed...
Starting udev Coldplug all Devices...
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[FAILED] Failed to start Update is Completed.
See 'systemctl status systemd-update-done.service' for details.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 11.745048] keystone-rproc 10800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 11.762577] remoteproc remoteproc0: 10800000.dsp is available
[ 11.796483] keystone-rproc 11800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 11.809721] remoteproc remoteproc1: 11800000.dsp is available
[ 11.835679] davinci-wdt 22f0080.wdt: heartbeat 60 sec
[ 11.853054] keystone-rproc 12800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 11.865798] remoteproc remoteproc2: 12800000.dsp is available
[ 11.892981] keystone-rproc 13800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 11.906913] remoteproc remoteproc3: 13800000.dsp is available
[ 11.939060] keystone-rproc 14800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 11.953892] remoteproc remoteproc4: 14800000.dsp is available
[ 11.999759] keystone-rproc 15800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 12.014262] remoteproc remoteproc5: 15800000.dsp is available
[ 12.047567] keystone-rproc 16800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 12.067712] remoteproc remoteproc6: 16800000.dsp is available
[ 12.089518] keystone-rproc 17800000.dsp: assigned reserved memory node dsp_common_cma_pool@81f800000
[ 12.098958] remoteproc remoteproc7: 17800000.dsp is available
[ OK ] Found device /dev/ttyS0.
[ OK ] Started udev Coldplug all Dev[ 12.164800] 2620738.usb_phy supply vcc not found, using dummy regulator
ices.
[ 12.174594] keystone-dsp-mem a0000000.dspmem: registered misc device dspmem
Welcome to emerg[ 12.608116] netcp-1.0 2620110.netcp eth1: Link is Down
Press Enter for maintenance
(or press Control-D to continue): [ 12.633926] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.848120] netcp-1.0 2620110.netcp eth0: Link is Down
[ 12.856924] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.903992] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
[ 13.949612] usbcore: registered new interface driver usbfs
[ 13.955671] usbcore: registered new interface driver hub
[ 13.961528] usbcore: registered new device driver usb
[ 13.986164] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 13.991694] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 13.999926] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x02010010
[ 14.008754] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000
[ 14.015400] hub 1-0:1.0: USB hub found
[ 14.019192] hub 1-0:1.0: 1 port detected
[ 14.023488] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 14.029007] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 14.036765] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.045529] hub 2-0:1.0: USB hub found
[ 14.049319] hub 2-0:1.0: 1 port detected
sh-3.2#
sh-3.2#
