I am trying to program the EMMC using uniflash according the procedure described in processors.wiki.ti.com/index.php/Sitara_Linux_Program_the_eMMC_on_Beaglebone_Black
and processors.wiki.ti.com/index.php/Sitara_Uniflash_Quick_Start_Guide
During the programming sequence i get the error message "missing environment variable: pxeuuid"
and after that the error messages that the pxelinux.cfg file can't be loaded
See attached log file
Does somebode have a idea what the cause can be of this error?
Kind Regards
Ronny
U-Boot SPL 2016.05-00319-gcf14e63-dirty (Sep 28 2017 - 14:16:23)
Trying to boot from USB eth
Using default environment
usb_ether
Error: usb_ether address not set.
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC 60:64:05:6f:11:dc
HOST MAC de:ad:be:af:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
DHCP client bound to address 192.168.2.2 (5808 ms)
Using usb_ether device
TFTP from server 192.168.2.1; our IP address is 192.168.2.2
Filename 'u-boot-restore.img'.
Load address: 0x807fffc0
Loading: #############################
1000 KiB/s
done
Bytes transferred = 415860 (65874 hex)
U-Boot 2016.05-00319-gcf14e63-dirty (Sep 28 2017 - 14:16:23 +0200)
CPU : AM335X-GP rev 2.1
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Card did not respond to voltage select!
** Bad device mmc 0 **
<ethaddr> not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
SD/MMC found on device 1
** File not found /boot/zImage **
## Error: "bootcmd_nand0" not defined
starting USB...
USB0: Port not available.
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
DHCP client bound to address 192.168.2.2 (5820 ms)
Filename 'zImage'.
Load address: 0x82000000
Loading: #################################################################
943.4 KiB/s
done
Bytes transferred = 6624056 (651338 hex)
Retrieving file: pxelinux.cfg/01-60-64-05-6f-11-de
RNDIS ready
Filename 'pxelinux.cfg/01-60-64-05-6f-11-de'.
Load address: 0x80100000
Loading: *
TFTP error: 'File not found or No Access' (1)
Not retrying...
Retrieving file: pxelinux.cfg/C0A80202
RNDIS ready
Filename 'pxelinux.cfg/C0A80202'.
Loading: *
Not retrying...
RNDIS ready
Filename 'pxelinux.cfg/C0A8020'.
Loading: *
Not retrying...
RNDIS ready
Filename 'pxelinux.cfg/C0A802'.
Loading: *
usb_ether
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
DHCP client bound to address 192.168.2.2 (5823 ms)
1017.6 KiB/s
done
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
Scanning mmc 1:1...
starting USB...
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
DHCP client bound to address 192.168.2.2 (5806 ms)
Filename 'zImage'.
938.5 KiB/s
done
RNDIS ready
Loading: *
Not retrying...
RNDIS ready
Loading: *
Not retrying...
RNDIS ready
Loading: *
Not retrying...
RNDIS ready
Loading: *
Not retrying...
RNDIS ready
Filename 'pxelinux.cfg/C0A80'.
Loading: *
Not retrying...
RNDIS ready
Filename 'pxelinux.cfg/C0A8'.
Loading: *
