Part Number: TCI6638K2K
Tool/software: TI-RTOS
I try to get a simplified version of the GateMP example to run but get this output:
Core 0 Trace...
2 Resource entries at 0x810000
***************** RM Shared Server Test *****************
Core 0: ProcID 1
Core 0: Wait for IPC attach count = 1
Core 0 : Creating RM startup task...
Core 0 : Starting BIOS...
registering rpmsg-proto:rpmsg-proto service on 61 with HOST
ti.sdo.ipc.GateMP: line 1160: assertion failure: A_noHeap: Region has no heap
xdc.runtime.Error.raise: terminating execution
Any idea? I have attached the cfg and c files
* rm_shared_test.c
* Multicore Resource Manager test that uses the RM shared server to
* request resources from multiple cores.
* Copyright (c) 2012-2013, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Standard Includes */
#include <string.h>
/* XDC Includes */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
/* IPC Includes */
#include <ti/ipc/MultiProc.h>
#include <ti/ipc/Ipc.h>
#include <ti/ipc/GateMP.h>
/* BIOS Includes */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* CSL Includes */
#include <ti/csl/csl_chip.h>
********************** RM Shared Test Symbols ************************
#define SYSINIT 0
#define NUM_CORES 2
/* GateMP names used to synchronize the RM test tasks */
#define RM_SERVER_GATE_NAME "rmServerGate"
#define RM_CLIENT_GATE_NAME "rmClientGate"
********************** Global Variables ******************************
/* DSP core number according to DNUM */
uint16_t coreNum;
/* Task to configure application transport code for RM */
Task_Handle rmStartupTskHandle;
/* GateMPs used to synchronize tests between the two RM test tasks */
GateMP_Handle serverGate = NULL;
GateMP_Handle clientGate = NULL;
/* GateMP keys */
IArg serverKey;
IArg clientKey;
void rmStartupTsk(UArg arg0, UArg arg1)
Int status;
GateMP_Params gateParams;
int cnt = 10;
if (coreNum == SYSINIT) {
GateMP_Params_init(&gateParams);
gateParams.name = RM_SERVER_GATE_NAME;
/* Disable local protection since only concerned with sync'ing cores */
gateParams.localProtect = GateMP_LocalProtect_NONE;
serverGate = GateMP_create(&gateParams);
System_printf("Core %d: Gate RM_SERVER_GATE_NAME opened\n", coreNum);
serverKey = GateMP_enter(serverGate);
do {
if (cnt == 10) {
System_printf("Core %d: Wait for RM_CLIENT_GATE_NAME\n", coreNum);
cnt = 10;
else {
cnt++;
status = GateMP_open(RM_CLIENT_GATE_NAME, &clientGate);
* Sleep for 1 clock tick to avoid inundating remote processor
* with interrupts if open failed
if (status < 0) {
Task_sleep(1);
} while (status < 0);
System_printf("Core %d: Gate RM_CLIENT_GATE_NAME opened\n", coreNum);
else {
Task_sleep(100);
gateParams.name = RM_CLIENT_GATE_NAME;
clientGate = GateMP_create(&gateParams);
clientKey = GateMP_enter(clientGate);
do {
if (cnt == 10) {
System_printf("Core %d: Wait for RM_SERVER_GATE_NAME\n", coreNum);
cnt = 10;
else {
cnt++;
status = GateMP_open(RM_SERVER_GATE_NAME, &serverGate);
if (status < 0) {
Task_sleep(1);
int main(Int argc, Char* argv[])
Task_Params taskParams;
int status;
int count = 0;
System_printf ("*********************************************************\n");
System_printf ("***************** RM Shared Server Test *****************\n");
coreNum = CSL_chipReadReg(CSL_CHIP_DNUM);
System_printf ("Core %d: ProcID %d\n", coreNum, MultiProc_self());
/* Initialize the heap in shared memory. Using IPC module to do that */
#if 0
System_printf("Core %d: Starting IPC...\n", coreNum);
status = Ipc_start();
if (status < 0) {
System_abort("Ipc_start failed\n");
#endif
do {
count++;
status = Ipc_attach(MultiProc_getId("CORE1"));
} while (status == Ipc_E_NOTREADY);
System_printf ("Core %d: Wait for IPC attach count = %d\n", coreNum, count);
else {
do {
count++;
status = Ipc_attach(MultiProc_getId("CORE0"));
/* Create the RM startup task */
System_printf("Core %d : Creating RM startup task...\n", coreNum);
Task_Params_init (&taskParams);
rmStartupTskHandle = Task_create (rmStartupTsk, &taskParams, NULL);
System_printf("Core %d : Starting BIOS...\n", coreNum);
BIOS_start();
return (0);
Lawrence
