Some question on Arago Filesystems
i'm quite new to arago, openembedded and his flavours.
I'm trying to learn how to do the usual basic operation we do with a repository and a package manager.
So, I installed the three arago git repositories, and started building arago-base-image: it went fine. But then started my problems:
1) I'm trying to replicate the second video showed in: http://arago-project.org/wiki/index.php/Arago_Demo (nearly the last minute), but it doesn't work:
root@dm365-evm:~# opkg install strace
Collected errors:
 * Cannot find package strace.
root@dm365-evm:~# opkg update
Downloading http://feeds.arago-
project.org/feeds/live/ipk/armv5te/Packages.gz
Inflating http://feeds.arago-project.org/feeds/live/ipk/armv5te/Packages.gz
Updated list of available packages in /var/lib/opkg/armv5te
Downloading http://feeds.arago-project.org/feeds/live/ipk/arago/Packages.gz
Inflating http://feeds.arago-project.org/feeds/live/ipk/arago/Packages.gz
Updated list of available packages in /var/lib/opkg/arago
Downloading http://feeds.arago-project.org/feeds/live/ipk/all/Packages.gz
Inflating http://feeds.arago-project.org/feeds/live/ipk/all/Packages.gz
Updated list of available packages in /var/lib/opkg/no-arch
Collected errors:
And in fact strace isn't present in /var/lib/opkg packages file:
root@dm365-evm:~# grep strace /var/lib/opkg/armv5te
root@dm365-evm:~# grep strace /var/lib/opkg/arago
root@dm365-evm:~# grep strace /var/lib/opkg/no-arch
root@dm365-evm:~#
2) How can I search through the arago packages repository? For example, though dosfstool are present (and already installed) in the repos, I'm not able to search them:
root@dm365-evm:~# egrep -e '^Package:' /var/lib/opkg/*  | grep dosfstool
/var/lib/opkg/armv5te:Package: dosfstools-dbg
/var/lib/opkg/armv5te:Package: dosfstools-dev
/var/lib/opkg/armv5te:Package: dosfstools-doc
root@dm365-evm:~# opkg search dosfstools
root@dm365-evm:~#
3) Comtemporary, I'm trying to build an image that includes more software (in particular I started withvim and python), but it complaints about some file not found:
... [snip] ...
NOTE: Running task 861 of 2022 (ID: 1454, /mnt/lavoro/gigavision/oe/arago-oe-dev/recipes/tcltk/tcl_8.5.8.bb, do_install)
ERROR: function do_install failed
ERROR: log data follows (/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/temp/log.do_install.13316)
| NOTE: make DESTDIR=/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image install
| Making directory /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib
| Making directory /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/bin
| Installing libtcl8.5.so to /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib/
| mv "/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib"/libtcl8.5.so "/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib"/libtcl8.5.so.0
| ln -sf libtcl8.5.so.0 "/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib"/libtcl8.5.so
| ln -sf "/mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib"/libtcl8.5.so.0 ./
| Installing tclsh as /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/bin/tclsh8.5
| Installing tclConfig.sh to /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib/
| Installing libtclstub8.5.a to /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/image/usr/lib/
| Installing message catalogs
| /lib/ld-linux.so.3: No such file or directory
| make: *** [install-msgs] Error 255
| FATAL: oe_runmake failed
NOTE: Task failed: /mnt/lavoro/gigavision/oe/arago-tmp/work/armv5te-none-linux-gnueabi/tcl-8.5.8-r7/temp/log.do_install.13316
ERROR: TaskFailed event exception, aborting
ERROR: Build of /mnt/lavoro/gigavision/oe/arago-oe-dev/recipes/tcltk/tcl_8.5.8.bb do_install failed
ERROR: Task 1454 (/mnt/lavoro/gigavision/oe/arago-oe-dev/recipes/tcltk/tcl_8.5.8.bb, do_install) failed
NOTE: Tasks Summary: Attempted 860 tasks of which 860 didn't need to be rerun and 1 failed.
ERROR: '/mnt/lavoro/gigavision/oe/arago-oe-dev/recipes/tcltk/tcl_8.5.8.bb' failed
Following there's the log file cited above (log.do_install.13316):
