Linux/AM5718: TFTP boot fails
Part Number: AM5718
Other Parts Discussed in Thread: DRA722, PMP, TMP102, TLC59108, BEAGLEBOARD-X15
Tool/software: Linux
We developed a custom board with AM5718 processor and using ti-processor-sdk-linux-am57xx-evm-02.00.01.07. I am facing an issue while tftp booting. Please see my boot log , I am setting static ip and trying tftp boot.
U-Boot SPL 2015.07-00080-g4523775-dirty (Feb 11 2017 - 11:54:05)
DRA722 ES1.0
DRA722 ES1.0
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
ti_i2c_eeprom_init failed 1
U-Boot 2015.07-00080-g4523775-dirty (Feb 11 2017 - 11:54:05 +0530)
CPU  : DRA722 ES1.0
Board: AM571x II2C:   ready
DRAM:  1 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
 **********Auto Negotiation Available******cpsw
Hit any key to stop autoboot:  0
U-Boot#
U-Boot#
U-Boot# tftp 0x82000000 zImage
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.1.1; our IP address is 192.168.1.2
Filename 'zImage'.
Load address: 0x82000000
Loading: #################################################################
         1.9 MiB/s
done
Bytes transferred = 3799992 (39fbb8 hex)
U-Boot# tftp 0x88000000 am57xx-beagle-x15.dtb
Using cpsw device
Filename 'am57xx-beagle-x15.dtb'.
Load address: 0x88000000
         1.8 MiB/s
done
Bytes transferred = 89661 (15e3d hex)
U-Boot# setenv rootpath /home/medha/ti-processor-sdk-linux-am57xx-evm-02.00.01.07/targetNFS
U-Boot# setenv netargs "setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsp}wp91.291.191.1552.f"
U-Boot# run netargs
U-Boot# bootz 0x82000000 - 0x88000000
Kernel image @ 0x82000000 [ 0x000000 - 0x39fbb8 ]
   Loading Device Tree to 8ffe7000, end 8ffffe3c ... OK
Starting Medha kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.13-g8dc6617 (medha@medha) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #95 SMP PREEMPT7
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI AM571x IDK
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] DRA722 ES1.0
[    0.000000] PERCPU: Embedded 11 pages/cpu @eee4d000 s16128 r8192 d20736 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 210514
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.1:/home/medha/ti-processor-sdk-linux-am57xx-evm-02.f
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 649040K/848896K available (7167K kernel code, 322K rwdata, 2440K rodata, 340K init, 259K bss, 19632K reserved, 180224K )
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc096a074   (9609 kB)
[    0.000000]       .init : 0xc096b000 - 0xc09c0000   ( 340 kB)
[    0.000000]       .data : 0xc09c0000 - 0xc0a10ac8   ( 323 kB)
[    0.000000]        .bss : 0xc0a13000 - 0xc0a53fcc   ( 260 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32768 Hz
[    0.000000] clocksource 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000030] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[    0.000030] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000427] Architected cp15 timer(s) running at 6.14MHz (virt).
[    0.000427] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000462] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000472] Switching to timer-based delay loop, resolution 162ns
[    0.000976] Console: colour dummy device 80x30
[    0.000991] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000997] This ensures that you still see kernel messages. Please
[    0.001002] update your kernel commandline.
[    0.001013] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.001026] pid_max: default: 32768 minimum: 301
[    0.001109] Security Framework initialized
[    0.001144] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001153] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001676] Initializing cgroup subsys blkio
[    0.001690] Initializing cgroup subsys memory
[    0.001716] Initializing cgroup subsys devices
[    0.001728] Initializing cgroup subsys freezer
[    0.001740] Initializing cgroup subsys perf_event
[    0.001761] CPU: Testing write buffer coherency: ok
[    0.002018] /cpus/cpu@0 missing clock-frequency property
[    0.002031] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002060] Setting up static identity map for 0x80008380 - 0x800083d8
[    0.040759] Brought up 1 CPUs
[    0.040770] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[    0.040777] CPU: All CPU(s) started in SVC mode.
[    0.041126] devtmpfs: initialized
[    0.064573] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.065391] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.078461] omap_hwmod: tptc0 using broken dt data from edma-controller
[    0.078932] omap_hwmod: tptc1 using broken dt data from edma-controller
[    0.154470] omap_hwmod: dcan2: _wait_target_disable failed
[    0.247996] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.251841] pinctrl core: initialized pinctrl subsystem
[    0.252636] NET: Registered protocol family 16
[    0.253553] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.261628] OMAP GPIO hardware version 0.1
[    0.263728] omap_gpio 48059000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio4_pins_default, deferring pre
[    0.286134] No ATAGs?
[    0.286160] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.286168] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.288592] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.288601] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.289162] OMAP DMA hardware revision 0.0
[    0.328039] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.330766] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.335563] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.335751] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.335905] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.336055] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.336325] vgaarb: loaded
[    0.336682] SCSI subsystem initialized
[    0.337091] usbcore: registered new interface driver usbfs
[    0.337150] usbcore: registered new interface driver hub
[    0.337213] usbcore: registered new device driver usb
[    0.339102] palmas 0-0058: IRQ missing: skipping irq request
[    0.351089] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[    0.391537] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.391718] media: Linux media interface: v0.10
[    0.391776] Linux video capture interface: v2.00
[    0.391819] pps_core: LinuxPPS API ver. 1 registered
[    0.391826] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.391852] PTP clock support registered
[    0.392496] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.392782] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.393072] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.393142] omap-mailbox: probe of 48842000.mailbox failed with error -22
[    0.393367] Advanced Linux Sound Architecture Driver Initialized.
[    0.393979] Switched to clocksource arch_sys_counter
[    0.403496] missing cooling_device property
[    0.403508] failed to build thermal zone board_thermal: -2
[    0.403609] NET: Registered protocol family 2
[    0.404240] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.404303] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.404428] TCP: Hash tables configured (established 8192 bind 8192)
[    0.404479] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.404510] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.404659] NET: Registered protocol family 1
[    0.404901] RPC: Registered named UNIX socket transport module.
[    0.404910] RPC: Registered udp transport module.
[    0.404916] RPC: Registered tcp transport module.
[    0.404923] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.405879] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[    0.405910] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.407800] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.407870] audit: initializing netlink subsys (disabled)
[    0.407902] audit: type=2000 audit(0.390:1): initialized
[    0.414971] VFS: Disk quotas dquot_6.6.0
[    0.415139] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.417152] NFS: Registering the id_resolver key type
[    0.417193] Key type id_resolver registered
[    0.417200] Key type id_legacy registered
[    0.417253] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.419537] NET: Registered protocol family 38
[    0.419613] bounce: pool size: 64 pages
[    0.419626] io scheduler noop registered
[    0.419638] io scheduler deadline registered
[    0.419675] io scheduler cfq registered (default)
[    0.421797] ldo4: supplied by evm_3v3_sd
[    0.424347] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[    0.424467] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[    0.429127] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    0.429140] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    0.429150] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.429160] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.429280] pci 0000:00:00.0: IOMMU is currently not supported for PCI
[    0.429544] PCI: bus0: Fast back to back transfers disabled
[    0.429939] pci 0000:01:00.0: IOMMU is currently not supported for PCI
[    0.430303] PCI: bus1: Fast back to back transfers disabled
[    0.430436] pci 0000:00:00.0: BAR 8: assigned [mem 0x20400000-0x20ffffff]
[    0.430447] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.430460] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.430472] pci 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.430485] pci 0000:01:00.0: BAR 0: assigned [mem 0x20800000-0x20ffffff]
[    0.430503] pci 0000:01:00.0: BAR 3: assigned [mem 0x20400000-0x20403fff]
[    0.430521] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    0.430538] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.430548] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    0.430559] pci 0000:00:00.0:   bridge window [mem 0x20400000-0x20ffffff]
[    0.432369] ldo5: supplied by evm_3v3_sd
[    0.432903] OMAP DSS rev 6.1
[    0.433170] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    0.437729] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.440676] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 267, base_baud = 3000000) is a 8250
[    1.463932] console [ttyS0] enabled
[    1.468118] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 268, base_baud = 3000000) is a 8250
[    1.477614] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 269, base_baud = 3000000) is a 8250
[    1.487108] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 270, base_baud = 3000000) is a 8250
[    1.497012] [drm] Initialized drm 1.1.0 20060810
[    1.509941] brd: module loaded
[    1.517056] loop: module loaded
[    1.521581] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    1.528394] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.537014] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    1.547237] scsi host0: ahci
[    1.550400] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 307
[    1.558828] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.566798] libphy: Fixed MDIO Bus: probed
[    1.571378] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.578479] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.584352] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[    1.590209] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
[    1.596235] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.2.15-k
[    1.603313] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.608986] igb 0000:01:00.0: enabling device (0140 -> 0142)
[    1.626309] CTRL_CORE_MAC_ID_SW_3  5cf821
[    1.630336] CTRL_CORE_MAC_ID_SW_2  40fb99
[    1.654061] pps pps0: new PPS source ptp0
[    1.658092] igb 0000:01:00.0: added PHC on eth0
[    1.662641] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[    1.669564] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 5c:f8:21:40:fb:99
[    1.676747] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[    1.681908] igb 0000:01:00.0: Using legacy interrupts. 1 rx queue(s), 1 tx queue(s)
[    1.734009] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.740132] davinci_mdio 48485000.mdio: detected phy mask fffffdff
[    1.748678] libphy: 48485000.mdio: probed
[    1.752709] davinci_mdio 48485000.mdio: phy[9]: device 48485000.mdio:09, driver unknown
[    1.761303] CTRL_CORE_MAC_ID_SW_1  5cf821
[    1.765377] CTRL_CORE_MAC_ID_SW_0  40fb98
[    1.769401] mac addr[i] 5c
[    1.772116] mac addr[i] f8
[    1.774885] mac addr[i] 21
[    1.777600] mac addr[i] 40
[    1.780313] mac addr[i] fb
[    1.783026] mac addr[i] 98
[    1.785784] cpsw 48484000.ethernet: Missing slave[1] phy_id property
[    1.792166] CTRL_CORE_MAC_ID_SW_1  5cf821
[    1.796236] CTRL_CORE_MAC_ID_SW_0  40fb98
[    1.800260] mac addr[i] 5c
[    1.802973] mac addr[i] f8
[    1.805703] mac addr[i] 21
[    1.808416] mac addr[i] 40
[    1.811131] mac addr[i] fb
[    1.813843] mac addr[i] 98
[    1.816590] cpsw 48484000.ethernet: Detected MACID = 5c:f8:21:40:fb:98
[    1.825804] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.832367] ehci-pci: EHCI PCI platform driver
[    1.836922] ehci-omap: OMAP-EHCI Host Controller driver
[    1.842352] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.848590] ohci-pci: OHCI PCI platform driver
[    1.853166] usbcore: registered new interface driver usb-storage
[    1.859300] usbcore: registered new interface driver usbtest
[    1.865988] mousedev: PS/2 mouse device common for all mice
[    1.872080] RTC date time get
[    1.875428] rtc-ds1307 0-0068: rtc core: registered ds1307 as rtc0
[    1.881824] rtc-ds1307 0-0068: 56 bytes nvram
[    1.886282] i2c /dev entries driver
[    1.891431] tmp102 0-0049: initialized
[    1.896658] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    1.914017] ata1: SATA link down (SStatus 0 SControl 300)
[    1.934592] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    1.940975] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    1.947410] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[    1.954123] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[    1.961298] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[    2.004301] ledtrig-cpu: registered to indicate activity on CPUs
[    2.010652] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    2.017253] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    2.023446] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    2.030293] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    2.037758] usbcore: registered new interface driver usbhid
[    2.043356] usbhid: USB HID core driver
[    2.048067] extcon-usb-gpio extcon_usb1: failed to get ID GPIO
[    2.054107] extcon-usb-gpio extcon_usb2: failed to get ID GPIO
[    2.061656] oprofile: using timer interrupt.
[    2.066312] Initializing XFRM netlink socket
[    2.070628] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.078730] NET: Registered protocol family 17
[    2.083219] NET: Registered protocol family 15
[    2.087825] Key type dns_resolver registered
[    2.092210] mmc0: new high speed SDHC card at address e624
[    2.097856] omap_voltage_late_init: Voltage driver support not added
[    2.104586] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[    2.109573] Power Management for TI OMAP4+ devices.
[    2.114876] ThumbEE CPU extension supported.
[    2.119234]  mmcblk0: p1 p2
[    2.122340] Registering SWP/SWPB emulation handler
[    2.132115] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.139731] dmm 4e000000.dmm: initialized all PAT entries
[    2.161737] tlc59108 0-0040: Successfully initialized tlc59108
[    2.185735] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.192379] [drm] No driver support for vblank timestamp query.
[    2.201568] [drm] Enabling DMM ywrap scrolling
[    2.247656] Console: switching to colour frame buffer device 100x37
[    2.257369] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    2.263314] omapdrm omapdrm.0: registered panic notifier
[    2.294181] omapwb-m2m: Device registered as video10
[    2.299170] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    2.497881] mmc1: MAN_BKOPS_EN bit is not set
[    2.514009] mmc1: new MMC card at address 0001
[    2.524009] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.534009] mmcblk1boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
[    2.544006] mmcblk1boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
[    2.566813]  mmcblk1: p1 p2
[    2.733606] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.739312] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.747284] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[    2.756083] xhci-hcd xhci-hcd.0.auto: irq 421, io mem 0x48890000
[    2.762281] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.769117] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.776384] usb usb1: Product: xHCI Host Controller
[    2.781282] usb usb1: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
[    2.787500] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.792937] hub 1-0:1.0: USB hub found
[    2.796772] hub 1-0:1.0: 1 port detected
[    2.801046] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.806772] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.814573] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.822822] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    2.829658] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.836925] usb usb2: Product: xHCI Host Controller
[    2.841823] usb usb2: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
[    2.848042] usb usb2: SerialNumber: xhci-hcd.0.auto
[    2.853455] hub 2-0:1.0: USB hub found
[    2.857283] hub 2-0:1.0: 1 port detected
[    3.113995] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.174021] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.194288] usb 2-1: New USB device found, idVendor=0451, idProduct=8140
[    3.201020] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.230729] hub 2-1:1.0: USB hub found
[    3.244039] hub 2-1:1.0: 4 ports detected
[    3.274297] usb 1-1: New USB device found, idVendor=0451, idProduct=8142
[    3.281030] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    3.303983] usb 1-1: SerialNumber: C8050859EE46
[    3.314129] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.319818] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    3.327748] hub 1-1:1.0: USB hub found
[    3.331824] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[    3.340590] hub 1-1:1.0: 4 ports detected
[    3.344758] xhci-hcd xhci-hcd.1.auto: irq 422, io mem 0x488d0000
[    3.350943] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.357842] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.366277] usb usb3: Product: xHCI Host Controller
[    3.371178] usb usb3: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
[    3.377403] usb usb3: SerialNumber: xhci-hcd.1.auto
[    3.382797] hub 3-0:1.0: USB hub found
[    3.386629] hub 3-0:1.0: 1 port detected
[    3.390880] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.396614] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    3.404431] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.412677] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    3.419599] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.426869] usb usb4: Product: xHCI Host Controller
[    3.431767] usb usb4: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
[    3.437987] usb usb4: SerialNumber: xhci-hcd.1.auto
[    3.443397] hub 4-0:1.0: USB hub found
[    3.447228] hub 4-0:1.0: 1 port detected
[    3.451743] RTC date time get
[    3.454931] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
[    3.462213] fdt: not creating '/sys/firmware/fdt': CRC check failed
[    3.480354] ldo2: disabling
[    3.483456] aic_dvdd_fixed: disabling
[    3.487328] vdd_3v3: disabling
[    3.490593] ALSA device list:
[    3.493571]   No soundcards found.
[   98.544059] VFS: Unable to mount root fs via NFS, trying floppy.
[   98.550396] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
[   98.557698] Please append a correct "root=" boot option; here are the available partitions:
[   98.566128] 0100            8096 ram0  (driver?)
[   98.570775] 0101            8096 ram1  (driver?)
[   98.575473] 0102            8096 ram2  (driver?)
[   98.580119] 0103            8096 ram3  (driver?)
[   98.584800] 0104            8096 ram4  (driver?)
[   98.589445] 0105            8096 ram5  (driver?)
[   98.594123] 0106            8096 ram6  (driver?)
[   98.598770] 0107            8096 ram7  (driver?)
[   98.603414] 0108            8096 ram8  (driver?)
[   98.608101] 0109            8096 ram9  (driver?)
[   98.612744] 010a            8096 ram10  (driver?)
[   98.617491] 010b            8096 ram11  (driver?)
[   98.622221] 010c            8096 ram12  (driver?)
[   98.626966] 010d            8096 ram13  (driver?)
[   98.631697] 010e            8096 ram14  (driver?)
[   98.636441] 010f            8096 ram15  (driver?)
[   98.641178] b300         3872256 mmcblk0  driver: mmcblk
[   98.646535]   b301           72261 mmcblk0p1 00000000-01
[   98.651875]   b302         3791340 mmcblk0p2 00000000-02
[   98.657232] b308         3776512 mmcblk1  driver: mmcblk
[   98.662576]   b309           71680 mmcblk1p1 7582adab-01
[   98.667929]   b30a         3687424 mmcblk1p2 7582adab-02
[   98.673269] b318           16384 mmcblk1boot1  (driver?)
[   98.678624] b310           16384 mmcblk1boot0  (driver?)
[   98.683964] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[   98.692264] drm_kms_helper: panic occurred, switching back to text console
[   98.699199] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
  • The software team have been notified. They will respond here.
  • Hi Ganesh,
    Could you share your boot args? I suspect that the Linux kernel is unable to mount the partition because it does not know how to access the file system.
    Also see the linked below thread with the similar problem:
    e2e.ti.com/.../160824
    e2e.ti.com/.../33053
    BR
    Tsvetolin Shulev
  • My booatgrs are:
    arch=arm
    args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
    autoload=no
    baudrate=115200
    board=BeagleBoard-X15
    board-name=am57xx-evm
    board_name=BeagleBoard-X15
    bootargs=console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.1:/home/medha/ti-processor-sdk-linux-am57xx-evm-02.00.01.07/targetNFS,nolock r2
    bootcmd=if test ${dofastboot} -eq 1; then echo Boot fastboot requested, resetting dofastboot ...;setenv dofastboot 0; saveenv;echo Booting int;
    bootdelay=1
    bootdir=/boot
    bootenv=uEnv.txt
    bootfile=zImage
    bootm_size=0x10000000
    bootpart=0:2
    bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
    cpu=armv7
    dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-o1
    dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw raw 0x80 0x81
    dfu_alt_info_ram=kernel ram 0x80200000 0x4000000;fdt ram 0x80f80000 0x80000;ramdisk ram 0x81000000 0x4000000
    dfu_bufsiz=0x10000
    dofastboot=0
    eth1addr=74:da:ea:0c:dc:a3
    ethact=cpsw
    ethaddr=74:da:ea:0c:dc:a2
    fdt_addr_r=0x88000000
    fdtaddr=0x88000000
    fdtfile=am57xx-beagle-x15.dtb
    fileaddr=88000000
    filesize=15e3d
    findfdt=if test $board_name = omap5_uevm; then setenv fdtfile omap5-uevm.dtb; fi; if test $board_name = dra7xx; then setenv fdtfile dra7-evm.d
    finduuid=part uuid mmc 0:2 uuid
    gateway=192.168.1.1
    hostname=medha
    importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
    ipaddr=192.168.1.2
    kernel_addr_r=0x82000000
    loadaddr=0x82000000
    loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}
    loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr
    loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};
    loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
    mmcargs=part uuid mmc 0:2 uuid
    mmcboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${b;
    mmcdev=0
    mmcrootfstype=ext4 rootwait
    netargs=setenv bootargs console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.1:/home/medha/ti-processor-sdk-linux-am57xx-evm-02.00.01.07/ta2
    netboot=echo Booting from network ...; setenv autoload no; dhcp; run netloadimage; run netloadfdt; run netargs; bootz ${loadaddr} - ${fdtaddr}
    netloadfdt=tftp ${fdtaddr} ${fdtfile}
    netloadimage=tftp ${loadaddr} ${bootfile}
    nfshost=192.168.1.1
    nfsopts=nolock
    partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}
    ramdisk_addr_r=0x88080000
    rdaddr=0x88080000
    rootpath=/home/medha/ti-processor-sdk-linux-am57xx-evm-02.00.01.07/targetNFS
    scsidevs=0
    serverip=192.168.1.1
    soc=omap5
    static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
    stderr=serial
    stdin=serial
    stdout=serial
    usbtty=cdc_acm
    vendor=ti
    ver=U-Boot 2015.07-00080-g4523775-dirty (Feb 11 2017 - 11:54:05 +0530)
    vram=16M
    I am using below commands in u-boot to boot from tftp:
    setenv netargs "setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=192.168.1.2"
    run netargs
    I have set static ip but again I am h=getting DHCP and RARP requests:
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.1:/home/medha/ti-processor-sdk-linux-am57xx-evm-02.2
    [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
    [ 0.000980] Console: colour dummy device 80x30
    [ 0.000996] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.001001] This ensures that you still see kernel messages. Please
    [ 0.001007] update your kernel commandline.
    [ 0.001018] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [ 0.001030] pid_max: default: 32768 minimum: 301
    [ 0.001112] Security Framework initialized
    [ 0.001148] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001158] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001684] Initializing cgroup subsys blkio
    [ 0.001699] Initializing cgroup subsys memory
    [ 0.001725] Initializing cgroup subsys devices
    [ 0.001736] Initializing cgroup subsys freezer
    [ 0.001748] Initializing cgroup subsys perf_event
    [ 0.001769] CPU: Testing write buffer coherency: ok
    [ 0.002025] /cpus/cpu@0 missing clock-frequency property
    [ 0.002038] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [ 0.002067] Setting up static identity map for 0x80008380 - 0x800083d8
    [ 0.040760] Brought up 1 CPUs
    [ 0.040771] SMP: Total of 1 processors activated (12.29 BogoMIPS).
    [ 0.041132] devtmpfs: initialized
    [ 0.064681] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [ 0.065496] omap_hwmod: l3_main_2 using broken dt data from ocp
    [ 0.078574] omap_hwmod: tptc0 using broken dt data from edma-controller
    [ 0.079048] omap_hwmod: tptc1 using broken dt data from edma-controller
    [ 0.154528] omap_hwmod: dcan2: _wait_target_disable failed
    [ 0.248092] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.251939] pinctrl core: initialized pinctrl subsystem
    [ 0.252734] NET: Registered protocol family 16
    [ 0.253692] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.261817] OMAP GPIO hardware version 0.1
    [ 0.263914] omap_gpio 48059000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio4_pins_default, deferring pre
    [ 0.286296] No ATAGs?
    [ 0.286322] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [ 0.286330] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [ 0.288764] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [ 0.288774] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [ 0.289333] OMAP DMA hardware revision 0.0
    [ 0.328055] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
    [ 0.330783] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
    [ 0.335609] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [ 0.335796] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [ 0.335949] omap-iommu 58882000.mmu: 58882000.mmu registered
    [ 0.336100] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.336374] vgaarb: loaded
    [ 0.336730] SCSI subsystem initialized
    [ 0.337137] usbcore: registered new interface driver usbfs
    [ 0.337196] usbcore: registered new interface driver hub
    [ 0.337261] usbcore: registered new device driver usb
    [ 0.339150] palmas 0-0058: IRQ missing: skipping irq request
    [ 0.351083] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
    [ 0.391543] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [ 0.391722] media: Linux media interface: v0.10
    [ 0.391781] Linux video capture interface: v2.00
    [ 0.391825] pps_core: LinuxPPS API ver. 1 registered
    [ 0.391832] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.391857] PTP clock support registered
    [ 0.392508] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
    [ 0.392795] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
    [ 0.393085] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [ 0.393156] omap-mailbox: probe of 48842000.mailbox failed with error -22
    [ 0.393378] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.394017] Switched to clocksource arch_sys_counter
    [ 0.403516] missing cooling_device property
    [ 0.403527] failed to build thermal zone board_thermal: -2
    [ 0.403630] NET: Registered protocol family 2
    [ 0.404258] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.404322] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.404446] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.404497] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.404528] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.404674] NET: Registered protocol family 1
    [ 0.404915] RPC: Registered named UNIX socket transport module.
    [ 0.404923] RPC: Registered udp transport module.
    [ 0.404930] RPC: Registered tcp transport module.
    [ 0.404936] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.405936] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
    [ 0.405967] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [ 0.407856] futex hash table entries: 256 (order: 2, 16384 bytes)
    [ 0.407924] audit: initializing netlink subsys (disabled)
    [ 0.407955] audit: type=2000 audit(0.390:1): initialized
    [ 0.415015] VFS: Disk quotas dquot_6.6.0
    [ 0.415183] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 0.417194] NFS: Registering the id_resolver key type
    [ 0.417226] Key type id_resolver registered
    [ 0.417233] Key type id_legacy registered
    [ 0.417285] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
    [ 0.419566] NET: Registered protocol family 38
    [ 0.419643] bounce: pool size: 64 pages
    [ 0.419657] io scheduler noop registered
    [ 0.419668] io scheduler deadline registered
    [ 0.419708] io scheduler cfq registered (default)
    [ 0.421835] ldo4: supplied by evm_3v3_sd
    [ 0.424383] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
    [ 0.424503] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
    [ 0.432785] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [ 0.432797] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
    [ 0.432808] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [ 0.432818] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 0.432938] pci 0000:00:00.0: IOMMU is currently not supported for PCI
    [ 0.433199] PCI: bus0: Fast back to back transfers disabled
    [ 0.433594] pci 0000:01:00.0: IOMMU is currently not supported for PCI
    [ 0.433957] PCI: bus1: Fast back to back transfers disabled
    [ 0.434149] pci 0000:00:00.0: BAR 8: assigned [mem 0x20400000-0x20ffffff]
    [ 0.434162] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [ 0.434175] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [ 0.434188] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
    [ 0.434201] pci 0000:01:00.0: BAR 0: assigned [mem 0x20800000-0x20ffffff]
    [ 0.434220] pci 0000:01:00.0: BAR 3: assigned [mem 0x20400000-0x20403fff]
    [ 0.434237] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
    [ 0.434255] pci 0000:00:00.0: PCI bridge to [bus 01]
    [ 0.434265] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
    [ 0.434276] pci 0000:00:00.0: bridge window [mem 0x20400000-0x20ffffff]
    [ 0.436093] ldo5: supplied by evm_3v3_sd
    [ 0.436628] OMAP DSS rev 6.1
    [ 0.436893] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [ 0.441377] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 0.444461] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 267, base_baud = 3000000) is a 8250
    [ 1.467650] console [ttyS0] enabled
    [ 1.471818] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 268, base_baud = 3000000) is a 8250
    [ 1.481311] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 269, base_baud = 3000000) is a 8250
    [ 1.490805] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 270, base_baud = 3000000) is a 8250
    [ 1.500706] [drm] Initialized drm 1.1.0 20060810
    [ 1.513586] brd: module loaded
    [ 1.520655] loop: module loaded
    [ 1.525237] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [ 1.531989] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [ 1.540623] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [ 1.550842] scsi host0: ahci
    [ 1.554055] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 307
    [ 1.562445] mtdoops: mtd device (mtddev=name/number) must be supplied
    [ 1.570401] libphy: Fixed MDIO Bus: probed
    [ 1.574991] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
    [ 1.582068] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [ 1.587943] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
    [ 1.593799] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
    [ 1.599825] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.2.15-k
    [ 1.606918] igb: Copyright (c) 2007-2014 Intel Corporation.
    [ 1.612578] igb 0000:01:00.0: enabling device (0140 -> 0142)
    [ 1.629901] CTRL_CORE_MAC_ID_SW_3 5cf821
    [ 1.633928] CTRL_CORE_MAC_ID_SW_2 40fb99
    [ 1.657641] pps pps0: new PPS source ptp0
    [ 1.661672] igb 0000:01:00.0: added PHC on eth0
    [ 1.666243] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
    [ 1.673150] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 5c:f8:21:40:fb:99
    [ 1.680333] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
    [ 1.685506] igb 0000:01:00.0: Using legacy interrupts. 1 rx queue(s), 1 tx queue(s)
    [ 1.744044] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [ 1.750168] davinci_mdio 48485000.mdio: detected phy mask fffffdff
    [ 1.758664] libphy: 48485000.mdio: probed
    [ 1.762696] davinci_mdio 48485000.mdio: phy[9]: device 48485000.mdio:09, driver unknown
    [ 1.771288] CTRL_CORE_MAC_ID_SW_1 5cf821
    [ 1.775363] CTRL_CORE_MAC_ID_SW_0 40fb98
    [ 1.779387] mac addr[i] 5c
    [ 1.782101] mac addr[i] f8
    [ 1.784870] mac addr[i] 21
    [ 1.787586] mac addr[i] 40
    [ 1.790300] mac addr[i] fb
    [ 1.793013] mac addr[i] 98
    [ 1.795781] cpsw 48484000.ethernet: Missing slave[1] phy_id property
    [ 1.802163] CTRL_CORE_MAC_ID_SW_1 5cf821
    [ 1.806224] CTRL_CORE_MAC_ID_SW_0 40fb98
    [ 1.810248] mac addr[i] 5c
    [ 1.812961] mac addr[i] f8
    [ 1.815706] mac addr[i] 21
    [ 1.818422] mac addr[i] 40
    [ 1.821135] mac addr[i] fb
    [ 1.823848] mac addr[i] 98
    [ 1.826582] cpsw 48484000.ethernet: Detected MACID = 5c:f8:21:40:fb:98
    [ 1.835826] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 1.842387] ehci-pci: EHCI PCI platform driver
    [ 1.846923] ehci-omap: OMAP-EHCI Host Controller driver
    [ 1.852354] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 1.858612] ohci-pci: OHCI PCI platform driver
    [ 1.863190] usbcore: registered new interface driver usb-storage
    [ 1.869307] usbcore: registered new interface driver usbtest
    [ 1.876012] mousedev: PS/2 mouse device common for all mice
    [ 1.882096] RTC date time get
    [ 1.885437] rtc-ds1307 0-0068: rtc core: registered ds1307 as rtc0
    [ 1.891835] rtc-ds1307 0-0068: 56 bytes nvram
    [ 1.896302] i2c /dev entries driver
    [ 1.901444] tmp102 0-0049: initialized
    [ 1.906651] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [ 1.914049] ata1: SATA link down (SStatus 0 SControl 300)
    [ 1.944604] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [ 1.950987] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [ 1.957421] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
    [ 1.964132] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
    [ 1.971306] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
    [ 2.014333] ledtrig-cpu: registered to indicate activity on CPUs
    [ 2.020683] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [ 2.027286] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [ 2.033475] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [ 2.040328] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [ 2.047826] usbcore: registered new interface driver usbhid
    [ 2.053421] usbhid: USB HID core driver
    [ 2.058100] extcon-usb-gpio extcon_usb1: failed to get ID GPIO
    [ 2.064141] extcon-usb-gpio extcon_usb2: failed to get ID GPIO
    [ 2.071702] oprofile: using timer interrupt.
    [ 2.076365] Initializing XFRM netlink socket
    [ 2.080682] mmc0: host does not support reading read-only switch, assuming write-enable
    [ 2.088782] NET: Registered protocol family 17
    [ 2.093272] NET: Registered protocol family 15
    [ 2.097899] Key type dns_resolver registered
    [ 2.102282] mmc0: new high speed SDHC card at address e624
    [ 2.107966] omap_voltage_late_init: Voltage driver support not added
    [ 2.114694] mmcblk0: mmc0:e624 SU04G 3.69 GiB
    [ 2.119680] Power Management for TI OMAP4+ devices.
    [ 2.124984] ThumbEE CPU extension supported.
    [ 2.129340] mmcblk0: p1 p2
    [ 2.132449] Registering SWP/SWPB emulation handler
    [ 2.142224] dmm 4e000000.dmm: workaround for errata i878 in use
    [ 2.149847] dmm 4e000000.dmm: initialized all PAT entries
    [ 2.171839] tlc59108 0-0040: Successfully initialized tlc59108
    [ 2.195768] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 2.202414] [drm] No driver support for vblank timestamp query.
    [ 2.211619] [drm] Enabling DMM ywrap scrolling
    [ 2.257690] Console: switching to colour frame buffer device 100x37
    [ 2.267406] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [ 2.273351] omapdrm omapdrm.0: registered panic notifier
    [ 2.304219] omapwb-m2m: Device registered as video10
    [ 2.309208] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [ 2.507917] mmc1: MAN_BKOPS_EN bit is not set
    [ 2.524047] mmc1: new MMC card at address 0001
    [ 2.534047] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
    [ 2.544047] mmcblk1boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
    [ 2.554043] mmcblk1boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
    [ 2.576849] mmcblk1: p1 p2
    [ 2.743636] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 2.749348] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [ 2.757322] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [ 2.766122] xhci-hcd xhci-hcd.0.auto: irq 421, io mem 0x48890000
    [ 2.772321] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 2.779156] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 2.786424] usb usb1: Product: xHCI Host Controller
    [ 2.791322] usb usb1: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [ 2.797541] usb usb1: SerialNumber: xhci-hcd.0.auto
    [ 2.802977] hub 1-0:1.0: USB hub found
    [ 2.806813] hub 1-0:1.0: 1 port detected
    [ 2.811087] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 2.816811] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [ 2.824610] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 2.832857] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [ 2.839693] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 2.846960] usb usb2: Product: xHCI Host Controller
    [ 2.851857] usb usb2: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [ 2.858076] usb usb2: SerialNumber: xhci-hcd.0.auto
    [ 2.863490] hub 2-0:1.0: USB hub found
    [ 2.867317] hub 2-0:1.0: 1 port detected
    [ 3.124032] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [ 3.184059] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [ 3.204323] usb 2-1: New USB device found, idVendor=0451, idProduct=8140
    [ 3.211055] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 3.240763] hub 2-1:1.0: USB hub found
    [ 3.254077] hub 2-1:1.0: 4 ports detected
    [ 3.284334] usb 1-1: New USB device found, idVendor=0451, idProduct=8142
    [ 3.291066] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [ 3.314020] usb 1-1: SerialNumber: C8050859EE46
    [ 3.324172] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 3.329859] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [ 3.337789] hub 1-1:1.0: USB hub found
    [ 3.341864] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [ 3.350629] hub 1-1:1.0: 4 ports detected
    [ 3.354796] xhci-hcd xhci-hcd.1.auto: irq 422, io mem 0x488d0000
    [ 3.360983] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [ 3.367882] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 3.376316] usb usb3: Product: xHCI Host Controller
    [ 3.381216] usb usb3: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [ 3.387441] usb usb3: SerialNumber: xhci-hcd.1.auto
    [ 3.392841] hub 3-0:1.0: USB hub found
    [ 3.396674] hub 3-0:1.0: 1 port detected
    [ 3.400928] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 3.406661] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [ 3.414476] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 3.422725] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
    [ 3.429648] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 3.436919] usb usb4: Product: xHCI Host Controller
    [ 3.441818] usb usb4: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [ 3.448038] usb usb4: SerialNumber: xhci-hcd.1.auto
    [ 3.453449] hub 4-0:1.0: USB hub found
    [ 3.457280] hub 4-0:1.0: 1 port detected
    [ 3.461797] RTC date time get
    [ 3.464985] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
    [ 3.472273] fdt: not creating '/sys/firmware/fdt': CRC check failed
    [ 3.707902] net eth1: initializing cpsw version 1.15 (0)
    [ 3.796673] net eth1: phy found : id is : 0x20005c90
    [ 3.801764] libphy: PHY not found
    [ 3.805198] net eth1: phy not found on slave 1
    [ 5.799201] cpsw 48484000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
    [ 5.824026] Sending DHCP and RARP requests ...
    What is wrong with my u-boot variables, I should get static address from u-boot
