hawkboard boot using uImage
Other Parts Discussed in Thread: OMAP-L138, DA8XX, PMP
i am trying to boot the hawkboard using uImage kernel download from page as below
http://code.google.com/p/hawkboard/downloads/list
see following boot log
hawkboard.org > tftp c0700000 uImage_v1
TFTP from server 10.212.11.215; our IP address is 10.212.11.241
Filename 'uImage_v1'.
Load address: 0xc0700000
Loading: #################################################################
done
Bytes transferred = 1934036 (1d82d4 hex)
hawkboard.org > printenv
bootargs=mem=128M console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0xc1180000,4M
ip=dhcp
bootcmd=
bootdelay=3
baudrate=115200
ethaddr=0a:c1:a8:12:fa:c0
bootfile=uImage_v1
stdin=serial
stdout=serial
stderr=serial
ver=U-Boot 2009.01-dirty (Nov 26 2009 - 02:15:00)
filesize=1D82D4
fileaddr=C0700000
ipaddr=10.212.11.241
serverip=10.212.11.215
Environment size: 339/131068 bytes
hawkboard.org > setenv bootfile uImage
hawkboard.org > saveenv
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x0 -- 100% complete.
Writing to Nand... done
hawkboard.org >
ip=dhcp
bootcmd=
bootdelay=3
baudrate=115200
stdin=serial
stdout=serial
stderr=serial
filesize=1D82D4
fileaddr=C0700000
bootfile=uImage
Environment size: 336/131068 bytes
hawkboard.org > tftp c1180000 ramdisk_v1.gz
Filename 'ramdisk_v1.gz'.
Load address: 0xc1180000
done
Bytes transferred = 3071942 (2edfc6 hex)
hawkboard.org > setenv bootargs "mem=128M console=ttyS2,115200n8 root=/dev/ram0
rw initrd=0xc1180000,4M"
hawkboard.org > bootm c0700000
## Booting kernel from Legacy Image at c0700000 ...
   Image Name:   Linux-2.6.32-rc6-00079-g55996fd-
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1933972 Bytes =  1.8 MB
   Load Address: c0008000
   Entry Point:  c0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.32-rc6-00079-g55996fd-dirty (root@khasim-laptop) (gcc version
4.3.3 (Sourcery G++ Lite 2009q1-203) ) #2 PREEMPT Thu Nov 26 02:14:24 IST 2009
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: OMAPL 138 Hawkboard.org
Memory policy: ECC disabled, Data cache writeback
DaVinci da850/omap-l138 variant 0x0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: mem=128M console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0x
c1180000,4M
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 121556KB available (3684K code, 272K data, 148K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 149.50 BogoMIPS (lpj=747520)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 144 gpio irqs
regulator: core version 0.5
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource timer0_1
musb_hdrc: version 6.0, cppi4.1-dma, (host+peripheral), debug=0
Waiting for USB PHY clock good...
musb_hdrc: USB OTG mode controller at fee00000 using DMA, IRQ 58
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 4096K
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 245
io scheduler noop registered
io scheduler anticipatory registered (default)
da8xx_lcdc da8xx_lcdc.0: GLCD: Found VGA_Monitor panel
Console: switching to colour frame buffer device 80x30
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a 16550A
serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a 16550A
serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a 16550A
console [ttyS2] enabled
brd: module loaded
ahci ahci: forcing PORTS_IMPL to 0x1
ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci
ata1: SATA max UDMA/133 irq 67
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xa1 (Micron NAND 128MiB 1,8V 8-bit
Bad block table not found for chip 0
Scanning device for bad blocks
Bad eraseblock 215 at 0x000001ae0000
Bad eraseblock 305 at 0x000002620000
Bad eraseblock 355 at 0x000002c60000
Bad eraseblock 371 at 0x000002e60000
Bad eraseblock 756 at 0x000005e80000
Bad eraseblock 819 at 0x000006660000
Bad eraseblock 859 at 0x000006b60000
Bad eraseblock 892 at 0x000006f80000
Bad eraseblock 961 at 0x000007820000
Bad eraseblock 967 at 0x0000078e0000
Creating 5 MTD partitions on "davinci_nand.1":
0x000000000000-0x000000020000 : "u-boot env"
0x000000020000-0x000000040000 : "UBL"
0x000000040000-0x0000000c0000 : "u-boot"
0x000000200000-0x000000400000 : "kernel"
0x000000400000-0x000008000000 : "filesystem"
davinci_nand davinci_nand.1: controller rev. 2.5
console [netcon0] enabled
netconsole: network logging started
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci ohci.0: DA8xx OHCI
ohci ohci.0: new USB bus registered, assigned bus number 2
ohci ohci.0: irq 59, io mem 0x01e25000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 22:5c:74:b4:38:10
usb0: HOST MAC 1e:3c:2d:71:a1:bc
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
watchdog watchdog: heartbeat 60 sec
cpuidle: using governor ladder
cpuidle: using governor menu
davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI tlv320aic3x
asoc: tlv320aic3x <-> davinci-i2s mapping ok
ALSA device list:
  #0: DA850/OMAP-L138 EVM (tlv320aic3x)
TCP cubic registered
NET: Registered protocol family 17
Clocks: disable unused emac
Clocks: disable unused spi1
davinci_emac_probe: using random MAC addr: ca:28:76:5b:c7:1f
emac-mii: probed
ata1: SATA link down (SStatus 0 SControl 300)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 148K
INIT: version 2.86 booting
Starting udevend_request: I/O error, dev mtdblock0, sector 0
Buffer I/O error on device mtdblock0, logical block 0
end_request: I/O error, dev mtdblock0, sector 8
Buffer I/O error on device mtdblock0, logical block 1
end_request: I/O error, dev mtdblock0, sector 16
Buffer I/O error on device mtdblock0, logical block 2
end_request: I/O error, dev mtdblock0, sector 24
Buffer I/O error on device mtdblock0, logical block 3
end_request: I/O error, dev mtdblock2, sector 0
end_request: I/O error, dev mtdblock2, sector 8
Buffer I/O error on device mtdblock2, logical block 1
end_request: I/O error, dev mtdblock2, sector 16
Buffer I/O error on device mtdblock2, logical block 2
end_request: I/O error, dev mtdblock2, sector 24
Buffer I/O error on device mtdblock2, logical block 3
end_request: I/O error, dev mtdblock3, sector 0
Buffer I/O error on device mtdblock3, logical block 0
end_request: I/O error, dev mtdblock3, sector 8
end_request: I/O error, dev mtdblock3, sector 16
end_request: I/O error, dev mtdblock3, sector 24
end_request: I/O error, dev mtdblock1, sector 0
end_request: I/O error, dev mtdblock1, sector 8
end_request: I/O error, dev mtdblock1, sector 16
end_request: I/O error, dev mtdblock1, sector 24
end_request: I/O error, dev mtdblock4, sector 0
end_request: I/O error, dev mtdblock4, sector 8
end_request: I/O error, dev mtdblock4, sector 16
end_request: I/O error, dev mtdblock4, sector 24
hawkboard is not proceed further
can tell me right processor for booting kernel on hawkboard ?????
