AM5728: Kernel errors
Part Number: AM5728
I'm trying to bring up a custom board based on AM5728. I manage to get to the kernel boot up as shown in my attached log. I even get past the Welcome to Arago message, but there seems to be a somewhat consistent hang. It almost always starts "Starting udev Coldplug all Devices..." , and then throws a "Unable to handle kernel paging request at virtual address", followed by either a "systemd Tainted", "udevadm Tainted" , "systemd-udevd Tainted" or something similar. I'm having this trouble mainly when I'm trying to boot up the full rootfs ("tisdk-rootfs-image-am57xx-evm") whereas when I use the base rootfs ("arago-base-tisdk-image-am57xx-evm") I am able to get to the command line.
The basic steps I've followed are the following. Please let me know if this is the correct approach.
1) Built and installed u-boot with a custom defconfig onto u-boot partition on SD card
2) From the ti-processor-sdk folder I extracted the "tisdk-rootfs-image-am57xx-evm" into the targetNFS
3) Copied in a custom defconfig into the kernel source tree (arch/arm/configs)
4) Copied in a custom DTS file into kernel source tree (arch/arm/boot/dts)
5) Modified the top level Rules.make in ti-processor-sdk folder to use custom defconfig
6) Modified the top level Makefile to make the custom DTS file
7) Ran:
        sudo make clean
        sudo make all
        sudo make install
8) Copied over the targetNFS into the rootfs partition on my SD card
9) Took the custom DTB (corresp. to custom DTS) and renamed it as am57xx-evm-reva3.dtb and dropped into rootfs/boot
Snippet of kernel debug log:
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
         Starting Synchronize System and HW clocks...
[  OK  ] Reached target System Time Synchronized.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Rebuild Hardware Database.
[    8.466556] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[    8.474706] pgd = ccf68000
[    8.477422] [00000000] *pgd=00000000
[    8.481025] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[    8.486357] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
[    8.496024] CPU: 0 PID: 172 Comm: udevadm Tainted: G           O    4.9.28-geed43d1050
[    8.504060] Hardware name: Generic DRA74X (Flattened Device Tree)
[    8.510177] task: ccc50640 task.stack: ccf70000
[    8.514733] PC is at __wake_up_common+0x28/0x94
[    8.519282] LR is at __wake_up+0x40/0x54
[    8.523219] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 60000093
[    8.523219] sp : ccf71ce0  ip : 00000000  fp : ccf71d14
[    8.534745] r10: 00000003  r9 : 00000000  r8 : ccf71d4c
[    8.539989] r7 : c0c0298c  r6 : 00000003  r5 : a0000013  r4 : c0c02988
[    8.546541] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02988
[    8.553095] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    8.560345] Control: 10c5387d  Table: 8cf6806a  DAC: 00000051
[    8.566113] Process udevadm (pid: 172, stack limit = 0xccf70210)
[    8.572143] Stack: (0xccf71ce0 to 0xccf72000)
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] Reserved memory: created CMA memory pool at 0x88400000, size 4 MiB
[    0.000000] OF: reserved mem: initialized node ipu1_cma@88400000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x8a400000, size 4 MiB
[    0.000000] OF: reserved mem: initialized node ipu2_cma@8a400000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x8e400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x8fe00000 to fe600000 for dram barrier
[    0.000000] DRA752 ES2.0
[    0.000000] percpu: Embedded 13 pages/cpu @cfd7c000 s22092 r8192 d22964 u53248
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60352
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=8ae64d44-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 196072K/243712K available (7168K kernel code, 312K rwdata, 2412K rodata, 1024K init, 292K bss, 14872K reserved, 32768K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0800000   (8160 kB)
[    0.000000]       .init : 0xc0b00000 - 0xc0c00000   (1024 kB)
[    0.000000]       .data : 0xc0c00000 - 0xc0c4e360   ( 313 kB)
[    0.000000]        .bss : 0xc0c50000 - 0xc0c992b0   ( 293 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000017] Switching to timer-based delay loop, resolution 162ns
[    0.000323] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000332] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000791] Console: colour dummy device 80x30
[    0.000822] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000829] This ensures that you still see kernel messages. Please
[    0.000835] update your kernel commandline.
[    0.000856] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000871] pid_max: default: 32768 minimum: 301
[    0.000999] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001009] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001878] CPU: Testing write buffer coherency: ok
[    0.002246] /cpus/cpu@0 missing clock-frequency property
[    0.002264] /cpus/cpu@1 missing clock-frequency property
[    0.002278] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002330] Setting up static identity map for 0x80100000 - 0x80100060
[    0.080106] EFI services will not be available.
[    0.170421] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.170517] Brought up 2 CPUs
[    0.170531] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.170540] CPU: All CPU(s) started in HYP mode.
[    0.170546] CPU: Virtualization extensions available.
[    0.171748] devtmpfs: initialized
[    0.200587] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.200861] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.200879] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.202002] pinctrl core: initialized pinctrl subsystem
[    0.203004] NET: Registered protocol family 16
[    0.204135] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.205319] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.316353] omap_hwmod: dcan1: _wait_target_disable failed
[    0.440462] cpuidle: using governor ladder
[    0.470493] cpuidle: using governor menu
[    0.472132] omap_l3_noc 44000000.ocp: L3 debug error: target 2 mod:1 (unclearable)
[    0.472222] omap_l3_noc 44000000.ocp: L3 application error: target 2 mod:1 (unclearable)
[    0.480235] OMAP GPIO hardware version 0.1
[    0.495327] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.516699] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.516712] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.517085] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.517095] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.517628] OMAP DMA hardware revision 0.0
[    0.572187] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.573489] edma 43300000.edma: memcpy is disabled
[    0.578398] edma 43300000.edma: TI EDMA DMA engine driver
[    0.582499] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.582657] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.585235] palmas 0-0058: Irq flag is 0x00000008
[    0.612979] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[    0.616820] vtt_fixed: supplied by smps3
[    0.651332] random: fast init done
[    0.692069] vdd_3v3: supplied by regen1
[    0.692308] aic_dvdd_fixed: supplied by vdd_3v3
[    0.695048] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.695623] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    0.695789] media: Linux media interface: v0.10
[    0.695840] Linux video capture interface: v2.00
[    0.695878] pps_core: LinuxPPS API ver. 1 registered
[    0.695885] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.695907] PTP clock support registered
[    0.695940] EDAC MC: Ver: 3.0.0
[    0.696680] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.696981] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.697262] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.697569] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.697624] omap-mailbox 48844000.mailbox: no available mbox devices found
[    0.697949] Advanced Linux Sound Architecture Driver Initialized.
[    0.698893] clocksource: Switched to clocksource arch_sys_counter
[    0.710088] NET: Registered protocol family 2
[    0.710695] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.710722] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.710760] TCP: Hash tables configured (established 2048 bind 2048)
[    0.710842] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.710868] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.711029] NET: Registered protocol family 1
[    0.711475] RPC: Registered named UNIX socket transport module.
[    0.711484] RPC: Registered udp transport module.
[    0.711491] RPC: Registered tcp transport module.
[    0.711498] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.712474] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.715529] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[    0.722300] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.723024] NFS: Registering the id_resolver key type
[    0.723060] Key type id_resolver registered
[    0.723070] Key type id_legacy registered
[    0.723117] ntfs: driver 2.1.32 [Flags: R/O].
[    0.724531] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.724544] io scheduler noop registered
[    0.724552] io scheduler deadline registered
[    0.724676] io scheduler cfq registered (default)
[    0.728144] pinctrl-single 4a003400.pinmux: please update dts to use #pinctrl-cells = <1>
[    0.728751] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.732535] backlight supply power not found, using dummy regulator
[    0.793375] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.796966] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 299, base_baud = 3000000) is a 8250
[    1.625999] console [ttyS2] enabled
[    1.630404] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 300, base_baud = 3000000) is a 8250
[    1.641043] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    1.647794] [drm] Initialized
[    1.663871] brd: module loaded
[    1.672894] loop: module loaded
[    1.679073] libphy: Fixed MDIO Bus: probed
[    1.738919] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.745047] libphy: 48485000.mdio: probed
[    1.751394] cpsw 48484000.ethernet: Detected MACID = d4:36:39:fc:4b:3e
[    1.758057] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.766527] cpsw 48484000.ethernet: cpsw: Detected MACID = d4:36:39:fc:4b:3f
[    1.775063] mousedev: PS/2 mouse device common for all mice
[    1.781089] i2c /dev entries driver
[    1.786300] gpio-fan gpio_fan: GPIO fan initialized
[    1.796983] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    1.868953] ledtrig-cpu: registered to indicate activity on CPUs
[    1.880392] NET: Registered protocol family 10
[    1.895827] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.902359] NET: Registered protocol family 17
[    1.907011] Key type dns_resolver registered
[    1.911479] omap_voltage_late_init: Voltage driver support not added
[    1.917960] Power Management for TI OMAP4+ devices.
[    1.923097] Registering SWP/SWPB emulation handler
[    1.942604] dmm 4e000000.dmm: initialized all PAT entries
[    1.949154] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[    1.956224] hctosys: unable to open rtc device (rtc0)
[    1.961913] aic_dvdd_fixed: disabling
[    1.965594] vmmcwl_fixed: disabling
[    1.969332] ldousb: disabling
[    1.973318] ALSA device list:
[    1.976296]   No soundcards found.
[    1.980571] Waiting for root device PARTUUID=8ae64d44-02...
[    2.006608] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.049040] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[    2.056238] mmcblk0: mmc0:59b4 NCard 15.0 GiB
[    2.062021]  mmcblk0: p1 p2
[    3.373332] EXT4-fs (mmcblk0p2): recovery complete
[    3.389395] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.397576] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.407142] devtmpfs: mounted
[    3.411625] Freeing unused kernel memory: 1024K (c0b00000 - c0c00000)
[    3.555382] systemd[1]: System time before build time, advancing clock.
[    3.603398] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -ID)
[    3.622092] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.05!
[    3.659544] systemd[1]: Set hostname to <am57xx-evm>.
[    3.899666] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    3.907464] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    3.915208] systemd[1]: sysinit.target: Found dependency on basic.target/start
[    3.922506] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[    3.930036] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
[    3.930045] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    3.930056] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Swap.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on Journal Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Created slice System Slice.
         Starting Journal Service...
         Mounting Temporary Directory...
[  OK  ] Created slice system-getty.slice.
         Starting Create list of required st... nodes for the current kernel...
[  OK  ] Reached target Slices.
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Mounting Debug File System...
         Starting Setup Virtual Console...
         Starting Remount Root and Kernel File Systems...
[    4.674792] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
         Starting Load Kernel Modules...
[    4.709313] cmemk: loading out-of-tree module taints kernel.
[    4.716051] CMEMK module: reference Linux version 4.9.28
         Mounting POSIX Message Queue File System...
[    4.727592] allocated heap buffer 0x40500000 of size 0x100000
[    4.737012] cmemk initialized
[    4.747842] cryptodev: driver 1.8 loaded.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted Temporary Directory.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Setup Virtual Console.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Load Kernel Modules.
         Starting Apply Kernel Variables...
         Mounting Configuration File System...
         Starting Rebuild Hardware Database...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[    5.268718] systemd-journald[94]: Received request to flush runtime journal from PID 1
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Reached target Local File Systems.
         Starting Rebuild Dynamic Linker Cache...
         Starting Rebuild Journal Catalog...
         Starting Create Volatile Files and Directories...
         Starting Load/Save Random Seed...
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Opkg first boot configure...
         Starting Update UTMP about System Boot/Shutdown...
[    8.576518] 1ce0: 00000000 00000001 ccf71e38 c0c02988 a0000013 00000003 00000001 ccf71d4c
[    8.584731] 1d00: ccf71e80 00000000 ccf71d44 ccf71d18 c016eac4 c016e9fc ccf71d4c ccf71d28
[    8.592943] 1d20: c024709c c8c0c1d4 00000003 ccf71d98 cd7a1c38 00000001 ccf71d64 ccf71d48
[    8.601155] 1d40: c016ed18 c016ea90 c8c0c168 c8c0c1d4 00000003 00000000 ccf71d7c ccf71d68
[    8.609366] 1d60: c016efbc c016ece4 c8c0c168 c8c0c1b8 ccf71d94 ccf71d80 c024772c c016efa4
[    8.617577] 1d80: c8c0c168 cdb0ac30 ccf71dbc ccf71d98 c0292680 c02476f8 5954104b 35a46957
[    8.625789] 1da0: cdb0abe0 cdb0ac30 cd7a1bb0 c8c0c000 ccf71ddc ccf71dc0 c02934d0 c02925b4
[    8.634000] 1dc0: cd7a1bb0 c8c0c000 c8c0c070 cd7a1c38 ccf71e1c ccf71de0 c0236c28 c029346c
[    8.642212] 1de0: ccf71e54 00000000 ccf71de8 ccf71de8 ccf71e78 ccf71e78 00000001 00000000
[    8.650424] 1e00: 00000001 ccf71f60 ccf70000 bea23680 ccf71e54 ccf71e20 c0237b88 c0236ba4
[    8.658635] 1e20: ccf71e54 ccf71e30 c0238e3c ccf71e78 ccf71e78 00000001 ccf71f60 00000001
[    8.666845] 1e40: ccf71f60 ccf70000 ccf71e74 ccf71e58 c023956c c0237990 00000001 cd08d000
[    8.675058] 1e60: ccf71e78 00000001 ccf71f24 ccf71e78 c023baf4 c0239508 cd31ccd0 cd7a1c38
[    8.683270] 1e80: 7ecab678 00000006 cd08d05a 7f8395a0 cd3326d0 cd547330 c8c0c000 00000001
[    8.691481] 1ea0: c0292474 00000164 00000000 00000000 00000000 ccf71eb8 0000000e 00000000
[    8.699693] 1ec0: 00000000 00000ff0 000041ed cd08d000 c0c03308 bea23680 00000000 00000001
[    8.707905] 1ee0: ccf70000 bea23680 cd08d000 00000000 c023b830 00000002 ffffff9c 00000001
[    8.716116] 1f00: ffffff9c 00000001 ffffff9c ccf71f60 ffffff9c ffffff9c ccf71f4c ccf71f28
[    8.724327] 1f20: c023bc24 c023ba68 00000000 ccf3fb80 ccf3fb80 00000000 00000001 ccf3fb80
[    8.732538] 1f40: ccf71f94 ccf71f50 c022ac78 c023bbe4 00000000 00000000 ccc49080 fffff000
[    8.740751] 1f60: 00000000 00000000 5954104b 7f8395a0 00000000 b6fdcce8 00000021 c0108024
[    8.748962] 1f80: ccf70000 00000000 ccf71fa4 ccf71f98 c022ae00 c022abe4 00000000 ccf71fa8
[    8.757174] 1fa0: c0107e60 c022adf0 7f8395a0 00000000 bea23680 00000000 00000000 bea236d0
[    8.765385] 1fc0: 7f8395a0 00000000 b6fdcce8 00000021 bea23680 0000004a 7f839540 bea2370c
[    8.773596] 1fe0: 7f66dd9c bea2366c 7f62345c b6e63076 20000030 bea23680 00000000 09000000
[    8.781804] Backtrace:
[    8.784269] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
[    8.791958]  r10:00000000 r9:ccf71e80 r8:ccf71d4c r7:00000001 r6:00000003 r5:a0000013
[    8.799818]  r4:c0c02988
[    8.802361] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
[    8.809787]  r8:00000001 r7:cd7a1c38 r6:ccf71d98 r5:00000003 r4:c8c0c1d4
[    8.816516] [<c016ecd8>] (__wake_up_bit) from [<c016efbc>] (wake_up_bit+0x24/0x28)
[    8.824121] [<c016ef98>] (wake_up_bit) from [<c024772c>] (unlock_new_inode+0x40/0x64)
[    8.831981]  r5:c8c0c1b8 r4:c8c0c168
[    8.835577] [<c02476ec>] (unlock_new_inode) from [<c0292680>] (kernfs_get_inode+0xd8/0x12c)
[    8.843959]  r5:cdb0ac30 r4:c8c0c168
[    8.847551] [<c02925a8>] (kernfs_get_inode) from [<c02934d0>] (kernfs_iop_lookup+0x70/0xa4)
[    8.855936]  r6:c8c0c000 r5:cd7a1bb0 r4:cdb0ac30
[    8.860574] [<c0293460>] (kernfs_iop_lookup) from [<c0236c28>] (lookup_slow+0x90/0x144)
[    8.868611]  r7:cd7a1c38 r6:c8c0c070 r5:c8c0c000 r4:cd7a1bb0
[    8.874294] [<c0236b98>] (lookup_slow) from [<c0237b88>] (walk_component+0x204/0x2d0)
[    8.882156]  r10:bea23680 r9:ccf70000 r8:ccf71f60 r7:00000001 r6:00000000 r5:00000001
[    8.890016]  r4:ccf71e78
[    8.892560] [<c0237984>] (walk_component) from [<c023956c>] (path_lookupat+0x70/0x11c)
[    8.900510]  r9:ccf70000 r8:ccf71f60 r7:00000001 r6:ccf71f60 r5:00000001 r4:ccf71e78
[    8.908287] [<c02394fc>] (path_lookupat) from [<c023baf4>] (filename_lookup+0x98/0xf4)
[    8.916235]  r7:00000001 r6:ccf71e78 r5:cd08d000 r4:00000001
[    8.921919] [<c023ba5c>] (filename_lookup) from [<c023bc24>] (user_path_at_empty+0x4c/0x54)
[    8.930305]  r8:ffffff9c r7:ffffff9c r6:ccf71f60 r5:ffffff9c r4:00000001
[    8.937043] [<c023bbd8>] (user_path_at_empty) from [<c022ac78>] (SyS_faccessat+0xa0/0x20c)
[    8.945340]  r6:ccf3fb80 r5:00000001 r4:00000000
[    8.949979] [<c022abd8>] (SyS_faccessat) from [<c022ae00>] (SyS_access+0x1c/0x20)
[    8.957492]  r10:00000000 r9:ccf70000 r8:c0108024 r7:00000021 r6:b6fdcce8 r5:00000000
[    8.965351]  r4:7f8395a0
[    8.967901] [<c022ade4>] (SyS_access) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
[    8.975590] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
[    8.981709] ---[ end trace ed238ede8e4c56f1 ]---
[    8.986350] note: udevadm[172] exited with preempt_count 2
[    8.996171] Unable to handle kernel paging request at virtual address c0c022cc
[    9.003426] pgd = ccc3c000
[    9.006141] [c0c022cc] *pgd=80c1141e(bad)
[    9.010180] Internal error: Oops: 8000000d [#2] PREEMPT SMP ARM
[    9.016123] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
[    9.025783] CPU: 0 PID: 94 Comm: systemd-journal Tainted: G      D    O    4.9.28-geed43d1050
[    9.034428] Hardware name: Generic DRA74X (Flattened Device Tree)
[    9.040544] task: cd28ddc0 task.stack: ccc58000
[    9.045098] PC is at bit_wait_table+0x1cc/0xc00
[    9.049646] LR is at __wake_up_common+0x58/0x94
[    9.054194] pc : [<c0c022cc>]    lr : [<c016ea48>]    psr: 80070193
[    9.054194] sp : ccc59da8  ip : c8c022c4  fp : ccc59ddc
[    9.065718] r10: 00000003  r9 : 00000000  r8 : ccc59e14
[    9.070962] r7 : c0c023bc  r6 : cdaf6be0  r5 : c0c022cc  r4 : 000a41e1
[    9.077514] r3 : ccc59e14  r2 : 00000000  r1 : 00000003  r0 : c8c022c4
[    9.084067] Flags: Nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    9.091316] Control: 10c5387d  Table: 8cc3c06a  DAC: 00000051
[    9.097082] Process systemd-journal (pid: 94, stack limit = 0xccc58210)
[    9.103722] Stack: (0xccc59da8 to 0xccc5a000)
[    9.108097] 9da0:                   ccc59e04 00000001 c01f087c c0c023b8 80070113 00000003
[    9.116309] 9dc0: 00000001 ccc59e14 00000200 00000055 ccc59e0c ccc59de0 c016eac4 c016e9fc
[    9.124522] 9de0: ccc59e14 c0189d68 ccc59e0c ce3b2cc0 cccbe528 00000040 cccbe528 00000200
[    9.132733] 9e00: ccc59e2c ccc59e10 c016ed18 c016ea90 ccc59e2c ce3b2cc0 00000000 00000000
[    9.140945] 9e20: ccc59e44 ccc59e30 c01d5c9c c016ece4 ccc14c44 cccbe528 ccc59eac ccc59e48
[    9.149157] 9e40: c020418c c01d5c64 00000000 c0c16e30 ccdc0000 ccdc0000 00000029 ccdc002c
[    9.157370] 9e60: ce3b2cc0 cccbe528 b65be000 00000055 ccc3ed90 ccdb86f8 cd3da3b4 00000000
[    9.165582] 9e80: ccc59eac ccc59fb0 cd28ddc0 cd3da380 00000817 b65be000 cd3da3b8 00000055
[    9.173794] 9ea0: ccc59efc ccc59eb0 c0115e40 c02039ec c017d480 bede06a0 ccc59f78 ccc59f78
[    9.182006] 9ec0: 00002000 00000000 00000800 ccc59ed8 c022bd9c c0c08034 00000817 c0115bbc
[    9.190217] 9ee0: b65be000 ccc59fb0 bede27b0 4323668a ccc59fac ccc59f00 c010130c c0115bc8
[    9.198428] 9f00: 17ae55aa 00000107 c0108024 cd8e5e78 00000000 00000000 c0191228 00000000
[    9.206641] 9f20: cccd1a88 cd8e5e78 00000001 00000029 00002000 00000000 ccc59f74 ccc59f48
[    9.214852] 9f40: c022cc48 c026c2fc 00000000 00000000 ccc59f74 cccd1a80 cccd1a80 00000000
[    9.223063] 9f60: 00000000 bede06a0 ccc59fa4 ccc59f78 c022da44 c022cb5c 00000000 00000000
[    9.231274] 9f80: 7f5b25f8 7f57cf0c bede2748 7f58e890 20070010 ffffffff 10c5387d 10c5387d
[    9.239486] 9fa0: 00000000 ccc59fb0 c010cea0 c01012d4 00000153 00000000 00000001 00000001
[    9.247698] 9fc0: 000000d0 b65bdff0 7f5b33c8 beddef70 beddeea8 bede27b0 4323668a 218dff1a
[    9.255909] 9fe0: b6f18000 beddee38 7f58a1e4 7f58e890 20070010 ffffffff 00000000 08000000
[    9.264116] Backtrace:
[    9.266580] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
[    9.274270]  r10:00000055 r9:00000200 r8:ccc59e14 r7:00000001 r6:00000003 r5:80070113
[    9.282129]  r4:c0c023b8
[    9.284672] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
[    9.292099]  r8:00000200 r7:cccbe528 r6:00000040 r5:cccbe528 r4:ce3b2cc0
[    9.298836] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
[    9.306442] [<c01d5c58>] (unlock_page) from [<c020418c>] (handle_mm_fault+0x7ac/0xcd8)
[    9.314389]  r5:cccbe528 r4:ccc14c44
[    9.317982] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
[    9.326106]  r10:00000055 r9:cd3da3b8 r8:b65be000 r7:00000817 r6:cd3da380 r5:cd28ddc0
[    9.333965]  r4:ccc59fb0
[    9.336508] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
[    9.344195]  r10:4323668a r9:bede27b0 r8:ccc59fb0 r7:b65be000 r6:c0115bbc r5:00000817
[    9.352054]  r4:c0c08034
[    9.354598] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
[    9.362021] Exception stack(0xccc59fb0 to 0xccc59ff8)
[    9.367093] 9fa0:                                     00000153 00000000 00000001 00000001
[    9.375305] 9fc0: 000000d0 b65bdff0 7f5b33c8 beddef70 beddeea8 bede27b0 4323668a 218dff1a
[    9.383516] 9fe0: b6f18000 beddee38 7f58a1e4 7f58e890 20070010 ffffffff
[    9.390157]  r8:10c5387d r7:10c5387d r6:ffffffff r5:20070010 r4:7f58e890
[    9.396885] Code: 000f000f c0c022c0 c0c022c0 00050005 (c0c022cc)
[    9.403004] ---[ end trace ed238ede8e4c56f2 ]---
[    9.407640] note: systemd-journal[94] exited with preempt_count 1
  • The software team have been notified. They will respond here.
  • Hello Vishal,
    Please, make the udev service verbose by editing lib/systemd/system/systemd-udev-trigger.service and see which task causes the Oops.
    Change
    [Service]
    Type=oneshot
    RemainAfterExit=yes
    ExecStart=/bin/udevadm trigger --type=subsystems --action=add ; /bin/udevadm trigger --type=devices --action=add
    to
    [Service]
    Type=oneshot
    RemainAfterExit=yes
    StandardOutput=journal+console
    ExecStart=/bin/udevadm --debug trigger --verbose --type=subsystems --action=add ; /bin/udevadm --debug trigger --verbose --type=devices --action=add
    Also check if addr2line will show you some clue in this direction.
    addr2line -f -e /boot/vmlinux-4.9.28-geed43d1050 c016ea18
    Kemal
  • Thank you for your fast reply.
    I have made the change you described in my rootfs partition on the SD card, though I don't see any new information in the logs? I have attached several logs of the same boot process.
    It seems that now, I am also seeing sometimes:
    [  OK  ] Started udev Coldplug all Devices.
    But I am still seeing a similar crash with "systemd-udevd Tainted". One time, I also saw "systemd-timesyn Tainted". I do see the task (ex: "task: ccdcbe80 task.stack: ccdc2000"), but that was there before the modification to the systemd-udev-trigger.service. How do I backtrack what task or portion of the code is causing this?
    I also tried addr2line on /boot/vmlinux-4.9.28-geed43d1050 , but I am getting a reply of:
    ??:0
    I also noticed the vmlinux-version is different than the one you mentioned. Any other tips and help is appreciated!
    Here are the logs:
    [    2.469533] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.727899] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    2.735734] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    2.743499] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    2.750773] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    2.758204] systemd[1]: sysinit.target: Found dependency on dropbear.socket/stop
    [    2.765747] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    2.773199] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    3.277329] cmemk: loading out-of-tree module taints kernel.
    [    3.284134] CMEMK module: reference Linux version 4.9.28
    [    3.294485] allocated heap buffer 0x40500000 of size 0x100000
    [    3.302431] cmemk initialized
    [    3.316827] cryptodev: driver 1.8 loaded.
    [    3.385210] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.139027] systemd-journald[99]: Received request to flush runtime journal from PID 1
    [    7.772453] Unable to handle kernel NULL pointer dereference at virtual address 000009bc
    [    7.778446] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.778450] pgd = c8c08000
    [    7.778455] [00000000] *pgd=00000000
    [    7.778465] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
    [    7.778483] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.778491] CPU: 1 PID: 186 Comm: systemd-udevd Tainted: G           O    4.9.28-geed43d1050 #1
    [    7.778494] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.778497] task: cce85dc0 task.stack: c8c02000
    [    7.778510] PC is at __wake_up_common+0x28/0x94
    [    7.778514] LR is at __wake_up+0x40/0x54
    [    7.778518] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 60030193
    [    7.778518] sp : c8c03d38  ip : 00000000  fp : c8c03d6c
    [    7.778521] r10: 00000003  r9 : 00000000  r8 : c8c03da4
    [    7.778523] r7 : c0c02194  r6 : 00000003  r5 : a0030113  r4 : c0c02190
    [    7.778526] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02190
    [    7.778531] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.778535] Control: 10c5387d  Table: 88c0806a  DAC: 00000051
    [    7.778538] Process systemd-udevd (pid: 186, stack limit = 0xc8c02210)
    [    7.778541] Stack: (0xc8c03d38 to 0xc8c04000)
    [    7.778544] 3d20:                                                       00000000 00000001
    [    7.778550] 3d40: c8c03e24 c0c02190 a0030113 00000003 00000001 c8c03da4 c8c03e44 cd6adc2c
    [    7.778555] 3d60: c8c03d9c c8c03d70 c016eac4 c016e9fc c8c03da4 c0189d68 c8c03d9c ce319e94
    [    7.778559] 3d80: 00000001 cd6ce0d0 000004ee ce319e94 c8c03dbc c8c03da0 c016ed18 c016ea90
    [    7.778563] 3da0: c8c03dbc ce319e94 00000000 00000000 c8c03dd4 c8c03dc0 c01d5c9c c016ece4
    [    7.778568] 3dc0: 00000000 00000001 c8c03e24 c8c03dd8 c01d6eb0 c01d5c64 000006a1 00000000
    [    7.778573] 3de0: ccee1600 000004ee c0201524 000004ee 00000500 c0189d68 00000ceb c8c03e44
    [    7.778577] 3e00: ccc4ea50 00000040 000004ee 000004ed b6b5e000 000004df c8c03e8c c8c03e28
    [    7.778583] 3e20: c0204050 c01d6b7c 8bfb27df 00000055 cd3e7378 ce2fb654 c8c03eac c8c03e48
    [    7.778587] 3e40: c0203e50 ccc4ea50 b6b5f000 00000054 c8c0ada8 c8c2d57c cd3e7374 00000000
    [    7.778592] 3e60: c8c03e8c c8c03fb0 cce85dc0 cd3e7340 00000005 b6b5e6e8 cd3e7378 00000054
    [    7.778596] 3e80: c8c03edc c8c03e90 c0115e40 c02039ec 0000081f b6e342bc cd3e7378 00000055
    [    7.778601] 3ea0: c8c03efc 00000000 00000000 00000100 8c4d36d6 00000005 00000005 c0115fb8
    [    7.778605] 3ec0: b6b5e6e8 c8c03fb0 bea33cec 0000002a c8c03efc c8c03ee0 c011606c c0115bc8
    [    7.778610] 3ee0: c0c08014 00000005 c0115fb8 b6b5e6e8 c8c03fac c8c03f00 c010130c c0115fc4
    [    7.778614] 3f00: c024afac c07cd5f8 c023b830 000a0000 ccfc0000 fffffffe ccfc0000 fffff000
    [    7.778619] 3f20: c0108024 c8c02000 c8c03f4c c8c03f38 c023b7e0 c021c370 fffffffe fffffffe
    [    7.778623] 3f40: c8c03f94 c8c03f50 c022b778 c023b780 c022e700 c022e4d0 c8c03f8c 00020000
    [    7.778628] 3f60: c0140000 00000004 00000100 00000001 7f5f0428 00020000 00000008 00000005
    [    7.778632] 3f80: c0108024 c8c02000 c8c03fa4 7f5b7234 80030010 ffffffff 10c5387d 10c5387d
    [    7.778636] 3fa0: 00000000 c8c03fb0 c010cea0 c01012d4 7f5e4090 7f61d488 ffffffe4 004ed6e8
    [    7.778641] 3fc0: b6b5e6e8 00000000 7f5e4090 7f61d488 b6f4ace8 bea33cec 0000002a 00000000
    [    7.778645] 3fe0: 7f5f05fa bea33ce0 7f5a46f8 7f5b7234 80030010 ffffffff 00000000 00000000
    [    7.778648] Backtrace:
    [    7.778657] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.778662]  r10:cd6adc2c r9:c8c03e44 r8:c8c03da4 r7:00000001 r6:00000003 r5:a0030113
    [    7.778664]  r4:c0c02190
    [    7.778670] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.778674]  r8:ce319e94 r7:000004ee r6:cd6ce0d0 r5:00000001 r4:ce319e94
    [    7.778687] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.778694] [<c01d5c58>] (unlock_page) from [<c01d6eb0>] (filemap_map_pages+0x340/0x348)
    [    7.778697]  r5:00000001 r4:00000000
    [    7.778707] [<c01d6b70>] (filemap_map_pages) from [<c0204050>] (handle_mm_fault+0x670/0xcd8)
    [    7.778712]  r10:000004df r9:b6b5e000 r8:000004ed r7:000004ee r6:00000040 r5:ccc4ea50
    [    7.778714]  r4:c8c03e44
    [    7.778723] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.778727]  r10:00000054 r9:cd3e7378 r8:b6b5e6e8 r7:00000005 r6:cd3e7340 r5:cce85dc0
    [    7.778730]  r4:c8c03fb0
    [    7.778735] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    7.778739]  r10:0000002a r9:bea33cec r8:c8c03fb0 r7:b6b5e6e8 r6:c0115fb8 r5:00000005
    [    7.778742]  r4:00000005
    [    7.778748] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.778751]  r7:b6b5e6e8 r6:c0115fb8 r5:00000005 r4:c0c08014
    [    7.778757] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.778759] Exception stack(0xc8c03fb0 to 0xc8c03ff8)
    [    7.778763] 3fa0:                                     7f5e4090 7f61d488 ffffffe4 004ed6e8
    [    7.778768] 3fc0: b6b5e6e8 00000000 7f5e4090 7f61d488 b6f4ace8 bea33cec 0000002a 00000000
    [    7.778772] 3fe0: 7f5f05fa bea33ce0 7f5a46f8 7f5b7234 80030010 ffffffff
    [    7.778776]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80030010 r4:7f5b7234
    [    7.778782] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    7.778787] ---[ end trace c53dcd1a0173688c ]---
    [    7.778794] note: systemd-udevd[186] exited with preempt_count 3
    [    7.780800] Unable to handle kernel NULL pointer dereference at virtual address 00000044
    [    7.780802] pgd = ccfe8000
    [    7.780805] [00000044] *pgd=00000000
    [    7.780809] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
    [    7.780820] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.780824] CPU: 0 PID: 183 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.780826] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.780828] task: cce85140 task.stack: ccfe2000
    [    7.780832] PC is at __wake_up_common+0x28/0x94
    [    7.780835] LR is at __wake_up+0x40/0x54
    [    7.780839] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 60010193
    [    7.780839] sp : ccfe3d58  ip : 00000044  fp : ccfe3d8c
    [    7.780841] r10: 00000003  r9 : 00000000  r8 : ccfe3dc4
    [    7.780844] r7 : c0c02188  r6 : 00000003  r5 : a0010113  r4 : c0c02184
    [    7.780846] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02184
    [    7.780849] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.780852] Control: 10c5387d  Table: 8cfe806a  DAC: 00000051
    [    7.780854] Process systemd-udevd (pid: 183, stack limit = 0xccfe2210)
    [    7.780856] Stack: (0xccfe3d58 to 0xccfe4000)
    [    7.780860] 3d40:                                                       ccf40790 00000001
    [    7.780865] 3d60: cd3e63b8 c0c02184 a0010113 00000003 00000001 ccfe3dc4 ccfe3e64 cd5ad984
    [    7.780869] 3d80: ccfe3dbc ccfe3d90 c016eac4 c016e9fc ccfe3dc4 c02140bc ccfe3dbc ce3b09bc
    [    7.780874] 3da0: 00000001 cd6467c0 0000001b ce3b09bc ccfe3ddc ccfe3dc0 c016ed18 c016ea90
    [    7.780879] 3dc0: ccfe3ddc ce3b09bc 00000000 00000000 ccfe3df4 ccfe3de0 c01d5c9c c016ece4
    [    7.780883] 3de0: 00000000 00000001 ccfe3e44 ccfe3df8 c01d6eb0 c01d5c64 0000005f 00000000
    [    7.780888] 3e00: cccaf3c0 00000016 00000040 00000016 00000040 cd3e63b8 ccfe3e44 ccfe3e64
    [    7.780892] 3e20: ccf93580 00000040 0000001b 00000014 7f598000 0000000c ccfe3eac ccfe3e48
    [    7.780897] 3e40: c0204050 c01d6b7c 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.780901] 3e60: 00000800 ccf93580 7f59a000 00000054 ccfe9fd0 cce47668 cd3e63b4 00000000
    [    7.780906] 3e80: ccfe3eac ccfe3fb0 cce85140 cd3e6380 80000007 7f598964 cd3e63b8 00000054
    [    7.780910] 3ea0: ccfe3efc ccfe3eb0 c0115e40 c02039ec 00000000 00000000 00000000 00000000
    [    7.780914] 3ec0: 00000000 00000000 00000000 00000008 00000000 c0c08234 00000007 c0115bbc
    [    7.780919] 3ee0: 7f598964 ccfe3fb0 7f5e4008 7f65ae60 ccfe3fac ccfe3f00 c01013cc c0115bc8
    [    7.780923] 3f00: 4a011452 4a111452 4a211452 00000000 00000000 00000000 00000000 00000000
    [    7.780927] 3f20: 00000000 c03cb25c 800f0113 ffffffff ccfe3f7c 00000000 ccfe3fac ccfe3f48
    [    7.780932] 3f40: c010ca78 c01012d4 b6d12288 beffffff 000000b7 ccfe2000 b6d12288 00000051
    [    7.780936] 3f60: 00000000 00000000 00000000 00000000 00000000 ccfe3fac f7d1228b ccfe3f98
    [    7.780941] 3f80: c0155d10 c03cb25c 800f0113 7f598964 80010010 ffffffff 10c5387d 10c5387d
    [    7.780945] 3fa0: 00000000 ccfe3fb0 c010d18c c0101398 00000000 00000000 00000000 b6e33030
    [    7.780950] 3fc0: bea396e4 b6f4ace8 7f65ae60 00000000 7f65a3c4 7f5e4008 7f65ae60 7f5e4014
    [    7.780954] 3fe0: 00000152 bea39088 b6e39d21 7f598964 80010010 ffffffff 8fdee861 8fdeec61
    [    7.780957] Backtrace:
    [    7.780962] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.780968]  r10:cd5ad984 r9:ccfe3e64 r8:ccfe3dc4 r7:00000001 r6:00000003 r5:a0010113
    [    7.780970]  r4:c0c02184
    [    7.780975] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.780980]  r8:ce3b09bc r7:0000001b r6:cd6467c0 r5:00000001 r4:ce3b09bc
    [    7.780987] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.780993] [<c01d5c58>] (unlock_page) from [<c01d6eb0>] (filemap_map_pages+0x340/0x348)
    [    7.780995]  r5:00000001 r4:00000000
    [    7.781001] [<c01d6b70>] (filemap_map_pages) from [<c0204050>] (handle_mm_fault+0x670/0xcd8)
    [    7.781005]  r10:0000000c r9:7f598000 r8:00000014 r7:0000001b r6:00000040 r5:ccf93580
    [    7.781007]  r4:ccfe3e64
    [    7.781012] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.781016]  r10:00000054 r9:cd3e63b8 r8:7f598964 r7:80000007 r6:cd3e6380 r5:cce85140
    [    7.781018]  r4:ccfe3fb0
    [    7.781023] [<c0115bbc>] (do_page_fault) from [<c01013cc>] (do_PrefetchAbort+0x40/0xa8)
    [    7.781027]  r10:7f65ae60 r9:7f5e4008 r8:ccfe3fb0 r7:7f598964 r6:c0115bbc r5:00000007
    [    7.781028]  r4:c0c08234
    [    7.781033] [<c010138c>] (do_PrefetchAbort) from [<c010d18c>] (ret_from_exception+0x0/0x14)
    [    7.781036] Exception stack(0xccfe3fb0 to 0xccfe3ff8)
    [    7.781039] 3fa0:                                     00000000 00000000 00000000 b6e33030
    [    7.781044] 3fc0: bea396e4 b6f4ace8 7f65ae60 00000000 7f65a3c4 7f5e4008 7f65ae60 7f5e4014
    [    7.781048] 3fe0: 00000152 bea39088 b6e39d21 7f598964 80010010 ffffffff
    [    7.781052]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80010010 r4:7f598964
    [    7.781057] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    7.781059] ---[ end trace c53dcd1a0173688d ]---
    [    7.781064] note: systemd-udevd[183] exited with preempt_count 3
    [    7.876833] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.876834] pgd = c0004000
    [    7.876837] [00000000] *pgd=00000000
    [    7.876843] Internal error: Oops: 80000005 [#3] PREEMPT SMP ARM
    [    7.876854] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.876858] CPU: 0 PID: 183 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.876860] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.876862] task: cce85140 task.stack: ccfe2000
    [    7.876866] PC is at 0x0
    [    7.876880] LR is at handle_fasteoi_irq+0x150/0x190
    [    7.876883] pc : [<00000000>]    lr : [<c01842fc>]    psr: 60010193
    [    7.876883] sp : ccfe38e8  ip : ccfe38c8  fp : ccfe3904
    [    7.876885] r10: ccfe3aa0  r9 : ccfe2000  r8 : cd808000
    [    7.876887] r7 : 00000000  r6 : c0c224f0  r5 : cda89a60  r4 : cda89a00
    [    7.876889] r3 : 00000000  r2 : cda89a00  r1 : 00000000  r0 : cda89a10
    [    7.876892] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.876894] Control: 10c5387d  Table: 8cfe806a  DAC: 00000051
    [    7.876896] Process systemd-udevd (pid: 183, stack limit = 0xccfe2210)
    [    7.876898] Stack: (0xccfe38e8 to 0xccfe4000)
    [    7.876903] 38e0:                   c0b5ad7c 00000154 00000000 00000000 ccfe3914 ccfe3908
    [    7.876908] 3900: c017fcdc c01841b8 ccfe393c ccfe3918 c0180264 c017fcbc c0c03414 fa21200c
    [    7.876912] 3920: ccfe3968 fa212000 fa213000 ccfe2000 ccfe3964 ccfe3940 c010150c c018020c
    [    7.876917] 3940: c07cd220 80010113 ffffffff ccfe399c 7f5dd000 ccfe2000 ccfe39c4 ccfe3968
    [    7.876921] 3960: c010cb0c c01014d8 cd3e63b4 00000000 0000003c 0000003b cce47610 ffffffff
    [    7.876926] 3980: ccfe3aa0 c0a14000 7f5dd000 7f585000 ccfe3aa0 ccfe39c4 ccfe39c8 ccfe39b8
    [    7.876930] 39a0: c020224c c07cd220 80010113 ffffffff 00000051 bf000000 ccfe3a44 ccfe39c8
    [    7.876935] 39c0: c020224c c07cd1dc ccfe3a2c 02000200 ffe00000 7f5dcfff 7f5dd000 00000000
    [    7.876939] 39e0: cd3e6380 ccfe9fd0 cce47610 cd3e63b4 ccfe9fd0 00000000 c0c7e884 c0c06190
    [    7.876943] 3a00: ccf93580 00000001 00000000 00000000 00000000 00000000 00000000 ccf93580
    [    7.876947] 3a20: ffffffff ccfe3aa0 00000000 00000000 cd3e63b8 c0991644 ccfe3a64 ccfe3a48
    [    7.876952] 3a40: c02027ac c0202110 00000000 c0991644 ccfe3a7c ccf93580 ccfe3a94 ccfe3a68
    [    7.876956] 3a60: c0202b00 c0202770 00000000 cd3e6380 c016ea1a ccf93580 ccfe3ac8 ccfe2000
    [    7.876960] 3a80: cd3e6380 c016ea1a ccfe3b04 ccfe3a98 c02085ac c0202ab0 60010193 00000000
    [    7.876964] 3aa0: cd3e6380 00000001 00000000 00000000 ffffffff ffffe000 00000000 00000000
    [    7.876969] 3ac0: 00000400 c8c0e000 0000000b ccfe2000 cd3e6380 c016ea1a c0c07768 cd3e6380
    [    7.876973] 3ae0: 00000000 ccfe2000 cd3e6380 cd3e6380 00000000 ccfe2000 ccfe3b1c ccfe3b08
    [    7.876977] 3b00: c012bca8 c02084d0 cce85140 cce8561c ccfe3b44 ccfe3b20 c013223c c012bc6c
    [    7.876982] 3b20: c016ea1a 00000000 ccfe3b44 ccfe3b38 c012e47c 00000001 ccfe3bcc ccfe3b48
    [    7.876986] 3b40: c010c1f8 c0131f84 ccfe2210 0000000b c099163c 00000008 bf000000 ccfe2000
    [    7.876990] 3b60: 00000000 60010193 659915a4 61306131 20313030 62303565 30333032 61316520
    [    7.876994] 3b80: 30303930 35652033 30386239 28203430 63393565 30303034 c0002029 c01d4bfc
    [    7.876999] 3ba0: c09915a4 00000044 ccfe3d08 00000005 cd3e6380 00000044 ccfe2000 00000003
    [    7.877003] 3bc0: ccfe3be4 ccfe3bd0 c011ac58 c010bfb8 ccfe3d08 00000005 ccfe3c34 ccfe3be8
    [    7.877007] 3be0: c0115f04 c011abf8 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.877011] 3c00: 00000000 00000000 00000000 00000005 00000005 c0115fb8 00000044 ccfe3d08
    [    7.877016] 3c20: ccfe2000 00000003 ccfe3c54 ccfe3c38 c011606c c0115bc8 c0c08014 00000005
    [    7.877020] 3c40: c0115fb8 00000044 ccfe3d04 ccfe3c58 c010130c c0115fc4 ffffffff 00000000
    [    7.877024] 3c60: 00000000 00000000 cfd839a4 c0b5abbc 00000001 00000000 024200ca 00000000
    [    7.877029] 3c80: 20010113 00000001 00000081 c0c4c500 00000000 00000000 00000081 024200ca
    [    7.877033] 3ca0: ccf40630 cd3e6380 00000000 c0c0319c ccfe3d94 ccfe3cc0 c01dee7c c01dde24
    [    7.877037] 3cc0: ce356008 0000000e cfd7faa8 ccfe3d00 ccfe3d34 ccfe3ce0 c01e5d38 c01ddcd0
    [    7.877041] 3ce0: 00000000 c016ea18 60010193 ffffffff ccfe3d3c ccfe3dc4 ccfe3d8c ccfe3d08
    [    7.877045] 3d00: c010ca78 c01012d4 c0c02184 00000003 00000001 00000000 c0c02184 a0010113
    [    7.877050] 3d20: 00000003 c0c02188 ccfe3dc4 00000000 00000003 ccfe3d8c 00000044 ccfe3d58
    [    7.877054] 3d40: c016eac4 c016ea18 60010193 ffffffff 00000051 bf000000 ccf40790 00000001
    [    7.877058] 3d60: cd3e63b8 c0c02184 a0010113 00000003 00000001 ccfe3dc4 ccfe3e64 cd5ad984
    [    7.877063] 3d80: ccfe3dbc ccfe3d90 c016eac4 c016e9fc ccfe3dc4 c02140bc ccfe3dbc ce3b09bc
    [    7.877067] 3da0: 00000001 cd6467c0 0000001b ce3b09bc ccfe3ddc ccfe3dc0 c016ed18 c016ea90
    [    7.877071] 3dc0: ccfe3ddc ce3b09bc 00000000 00000000 ccfe3df4 ccfe3de0 c01d5c9c c016ece4
    [    7.877076] 3de0: 00000000 00000001 ccfe3e44 ccfe3df8 c01d6eb0 c01d5c64 0000005f 00000000
    [    7.877080] 3e00: cccaf3c0 00000016 00000040 00000016 00000040 cd3e63b8 ccfe3e44 ccfe3e64
    [    7.877085] 3e20: ccf93580 00000040 0000001b 00000014 7f598000 0000000c ccfe3eac ccfe3e48
    [    7.877089] 3e40: c0204050 c01d6b7c 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.877093] 3e60: 00000800 ccf93580 7f59a000 00000054 ccfe9fd0 cce47668 cd3e63b4 00000000
    [    7.877097] 3e80: ccfe3eac ccfe3fb0 cce85140 cd3e6380 80000007 7f598964 cd3e63b8 00000054
    [    7.877102] 3ea0: ccfe3efc ccfe3eb0 c0115e40 c02039ec 00000000 00000000 00000000 00000000
    [    7.877106] 3ec0: 00000000 00000000 00000000 00000008 00000000 c0c08234 00000007 c0115bbc
    [    7.877110] 3ee0: 7f598964 ccfe3fb0 7f5e4008 7f65ae60 ccfe3fac ccfe3f00 c01013cc c0115bc8
    [    7.877114] 3f00: 4a011452 4a111452 4a211452 00000000 00000000 00000000 00000000 00000000
    [    7.877118] 3f20: 00000000 c03cb25c 800f0113 ffffffff ccfe3f7c 00000000 ccfe3fac ccfe3f48
    [    7.877123] 3f40: c010ca78 c01012d4 b6d12288 beffffff 000000b7 ccfe2000 b6d12288 00000051
    [    7.877127] 3f60: 00000000 00000000 00000000 00000000 00000000 ccfe3fac f7d1228b ccfe3f98
    [    7.877131] 3f80: c0155d10 c03cb25c 800f0113 7f598964 80010010 ffffffff 10c5387d 10c5387d
    [    7.877136] 3fa0: 00000000 ccfe3fb0 c010d18c c0101398 00000000 00000000 00000000 b6e33030
    [    7.877140] 3fc0: bea396e4 b6f4ace8 7f65ae60 00000000 7f65a3c4 7f5e4008 7f65ae60 7f5e4014
    [    7.877144] 3fe0: 00000152 bea39088 b6e39d21 7f598964 80010010 ffffffff 8fdee861 8fdeec61
    [    7.877146] Backtrace:
    [    7.877153] [<c01841ac>] (handle_fasteoi_irq) from [<c017fcdc>] (generic_handle_irq+0x2c/0x3c)
    [    7.877157]  r7:00000000 r6:00000000 r5:00000154 r4:c0b5ad7c
    [    7.877162] [<c017fcb0>] (generic_handle_irq) from [<c0180264>] (__handle_domain_irq+0x64/0xbc)
    [    7.877167] [<c0180200>] (__handle_domain_irq) from [<c010150c>] (gic_handle_irq+0x40/0x7c)
    [    7.877171]  r9:ccfe2000 r8:fa213000 r7:fa212000 r6:ccfe3968 r5:fa21200c r4:c0c03414
    [    7.877176] [<c01014cc>] (gic_handle_irq) from [<c010cb0c>] (__irq_svc+0x6c/0xa8)
    [    7.877179] Exception stack(0xccfe3968 to 0xccfe39b0)
    [    7.877183] 3960:                   cd3e63b4 00000000 0000003c 0000003b cce47610 ffffffff
    [    7.877187] 3980: ccfe3aa0 c0a14000 7f5dd000 7f585000 ccfe3aa0 ccfe39c4 ccfe39c8 ccfe39b8
    [    7.877190] 39a0: c020224c c07cd220 80010113 ffffffff
    [    7.877194]  r9:ccfe2000 r8:7f5dd000 r7:ccfe399c r6:ffffffff r5:80010113 r4:c07cd220
    [    7.877203] [<c07cd1d0>] (_raw_spin_lock) from [<c020224c>] (unmap_page_range+0x148/0x660)
    [    7.877208] [<c0202104>] (unmap_page_range) from [<c02027ac>] (unmap_single_vma+0x48/0x50)
    [    7.877212]  r10:c0991644 r9:cd3e63b8 r8:00000000 r7:00000000 r6:ccfe3aa0 r5:ffffffff
    [    7.877214]  r4:ccf93580
    [    7.877219] [<c0202764>] (unmap_single_vma) from [<c0202b00>] (unmap_vmas+0x5c/0x70)
    [    7.877220]  r4:ccf93580
    [    7.877227] [<c0202aa4>] (unmap_vmas) from [<c02085ac>] (exit_mmap+0xe8/0x1ec)
    [    7.877230]  r8:c016ea1a r7:cd3e6380 r6:ccfe2000 r5:ccfe3ac8 r4:ccf93580
    [    7.877236] [<c02084c4>] (exit_mmap) from [<c012bca8>] (mmput+0x48/0xf4)
    [    7.877239]  r6:ccfe2000 r5:00000000 r4:cd3e6380
    [    7.877249] [<c012bc60>] (mmput) from [<c013223c>] (do_exit+0x2c4/0x9f0)
    [    7.877252]  r5:cce8561c r4:cce85140
    [    7.877256] [<c0131f78>] (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [    7.877258]  r7:00000001
    [    7.877269] [<c010bfac>] (die) from [<c011ac58>] (__do_kernel_fault.part.0+0x6c/0x1ec)
    [    7.877274]  r10:00000003 r9:ccfe2000 r8:00000044 r7:cd3e6380 r6:00000005 r5:ccfe3d08
    [    7.877275]  r4:00000044
    [    7.877281] [<c011abec>] (__do_kernel_fault.part.0) from [<c0115f04>] (do_page_fault+0x348/0x354)
    [    7.877283]  r7:00000005 r4:ccfe3d08
    [    7.877287] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    7.877292]  r10:00000003 r9:ccfe2000 r8:ccfe3d08 r7:00000044 r6:c0115fb8 r5:00000005
    [    7.877293]  r4:00000005
    [    7.877297] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.877300]  r7:00000044 r6:c0115fb8 r5:00000005 r4:c0c08014
    [    7.877304] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    7.877307] Exception stack(0xccfe3d08 to 0xccfe3d50)
    [    7.877311] 3d00:                   c0c02184 00000003 00000001 00000000 c0c02184 a0010113
    [    7.877315] 3d20: 00000003 c0c02188 ccfe3dc4 00000000 00000003 ccfe3d8c 00000044 ccfe3d58
    [    7.877318] 3d40: c016eac4 c016ea18 60010193 ffffffff
    [    7.877322]  r8:ccfe3dc4 r7:ccfe3d3c r6:ffffffff r5:60010193 r4:c016ea18
    [    7.877326] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.877330]  r10:cd5ad984 r9:ccfe3e64 r8:ccfe3dc4 r7:00000001 r6:00000003 r5:a0010113
    [    7.877332]  r4:c0c02184
    [    7.877336] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.877339]  r8:ce3b09bc r7:0000001b r6:cd6467c0 r5:00000001 r4:ce3b09bc
    [    7.877344] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.877350] [<c01d5c58>] (unlock_page) from [<c01d6eb0>] (filemap_map_pages+0x340/0x348)
    [    7.877352]  r5:00000001 r4:00000000
    [    7.877358] [<c01d6b70>] (filemap_map_pages) from [<c0204050>] (handle_mm_fault+0x670/0xcd8)
    [    7.877362]  r10:0000000c r9:7f598000 r8:00000014 r7:0000001b r6:00000040 r5:ccf93580
    [    7.877363]  r4:ccfe3e64
    [    7.877368] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.877372]  r10:00000054 r9:cd3e63b8 r8:7f598964 r7:80000007 r6:cd3e6380 r5:cce85140
    [    7.877374]  r4:ccfe3fb0
    [    7.877378] [<c0115bbc>] (do_page_fault) from [<c01013cc>] (do_PrefetchAbort+0x40/0xa8)
    [    7.877382]  r10:7f65ae60 r9:7f5e4008 r8:ccfe3fb0 r7:7f598964 r6:c0115bbc r5:00000007
    [    7.877383]  r4:c0c08234
    [    7.877388] [<c010138c>] (do_PrefetchAbort) from [<c010d18c>] (ret_from_exception+0x0/0x14)
    [    7.877390] Exception stack(0xccfe3fb0 to 0xccfe3ff8)
    [    7.877394] 3fa0:                                     00000000 00000000 00000000 b6e33030
    [    7.877398] 3fc0: bea396e4 b6f4ace8 7f65ae60 00000000 7f65a3c4 7f5e4008 7f65ae60 7f5e4014
    [    7.877402] 3fe0: 00000152 bea39088 b6e39d21 7f598964 80010010 ffffffff
    [    7.877405]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80010010 r4:7f598964
    [    7.877409] Code: bad PC value
    [    7.877411] ---[ end trace c53dcd1a0173688e ]---
    [    7.877415] Kernel panic - not syncing: Fatal exception in interrupt
    [    7.877425] CPU1: stopping
    [    7.877431] CPU: 1 PID: 186 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.877433] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.877437] Backtrace:
    [    7.877447] [<c010bcec>] (dump_backtrace) from [<c010bfa8>] (show_stack+0x18/0x1c)
    [    7.877451]  r7:c8c03948 r6:60030193 r5:00000000 r4:c0c22310
    [    7.877459] [<c010bf90>] (show_stack) from [<c03cbf20>] (dump_stack+0x8c/0xa0)
    [    7.877465] [<c03cbe94>] (dump_stack) from [<c010f1bc>] (handle_IPI+0x170/0x184)
    [    7.877468]  r7:c8c03948 r6:00000000 r5:00000001 r4:c0b5ad7c
    [    7.877473] [<c010f04c>] (handle_IPI) from [<c0101544>] (gic_handle_irq+0x78/0x7c)
    [    7.877476]  r7:fa212000 r6:c8c03948 r5:fa21200c r4:c0c03414
    [    7.877480] [<c01014cc>] (gic_handle_irq) from [<c010cb0c>] (__irq_svc+0x6c/0xa8)
    [    7.877482] Exception stack(0xc8c03948 to 0xc8c03990)
    [    7.877487] 3940:                   cd3e7374 00000000 00000101 00000100 ccff6610 ffffffff
    [    7.877491] 3960: c8c03a80 c0a14000 7f5dd000 7f585000 c8c03a80 c8c039a4 c8c039a8 c8c03998
    [    7.877494] 3980: c020224c c07cd220 80030113 ffffffff
    [    7.877498]  r9:c8c02000 r8:7f5dd000 r7:c8c0397c r6:ffffffff r5:80030113 r4:c07cd220
    [    7.877504] [<c07cd1d0>] (_raw_spin_lock) from [<c020224c>] (unmap_page_range+0x148/0x660)
    [    7.877509] [<c0202104>] (unmap_page_range) from [<c02027ac>] (unmap_single_vma+0x48/0x50)
    [    7.877513]  r10:c0991644 r9:cd3e7378 r8:00000000 r7:00000000 r6:c8c03a80 r5:ffffffff
    [    7.877514]  r4:ccf4b058
    [    7.877519] [<c0202764>] (unmap_single_vma) from [<c0202b00>] (unmap_vmas+0x5c/0x70)
    [    7.877521]  r4:ccf4b058
    [    7.877526] [<c0202aa4>] (unmap_vmas) from [<c02085ac>] (exit_mmap+0xe8/0x1ec)
    [    7.877529]  r8:c016ea1a r7:cd3e7340 r6:c8c02000 r5:c8c03aa8 r4:ccf4b058
    [    7.877534] [<c02084c4>] (exit_mmap) from [<c012bca8>] (mmput+0x48/0xf4)
    [    7.877537]  r6:c8c02000 r5:00000000 r4:cd3e7340
    [    7.877542] [<c012bc60>] (mmput) from [<c013223c>] (do_exit+0x2c4/0x9f0)
    [    7.877544]  r5:cce8629c r4:cce85dc0
    [    7.877548] [<c0131f78>] (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [    7.877550]  r7:00000001
    [    7.877556] [<c010bfac>] (die) from [<c011ac58>] (__do_kernel_fault.part.0+0x6c/0x1ec)
    [    7.877560]  r10:00000003 r9:c8c02000 r8:00000000 r7:cd3e7340 r6:00000005 r5:c8c03ce8
    [    7.877562]  r4:00000000
    [    7.877567] [<c011abec>] (__do_kernel_fault.part.0) from [<c0115f04>] (do_page_fault+0x348/0x354)
    [    7.877569]  r7:00000005 r4:c8c03ce8
    [    7.877574] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    7.877578]  r10:00000003 r9:c8c02000 r8:c8c03ce8 r7:00000000 r6:c0115fb8 r5:00000005
    [    7.877579]  r4:00000005
    [    7.877584] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.877586]  r7:00000000 r6:c0115fb8 r5:00000005 r4:c0c08014
    [    7.877591] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    7.877592] Exception stack(0xc8c03ce8 to 0xc8c03d30)
    [    7.877597] 3ce0:                   c0c02190 00000003 00000001 00000000 c0c02190 a0030113
    [    7.877601] 3d00: 00000003 c0c02194 c8c03da4 00000000 00000003 c8c03d6c 00000000 c8c03d38
    [    7.877604] 3d20: c016eac4 c016ea18 60030193 ffffffff
    [    7.877607]  r8:c8c03da4 r7:c8c03d1c r6:ffffffff r5:60030193 r4:c016ea18
    [    7.877612] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.877616]  r10:cd6adc2c r9:c8c03e44 r8:c8c03da4 r7:00000001 r6:00000003 r5:a0030113
    [    7.877617]  r4:c0c02190
    [    7.877621] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.877625]  r8:ce319e94 r7:000004ee r6:cd6ce0d0 r5:00000001 r4:ce319e94
    [    7.877630] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.877636] [<c01d5c58>] (unlock_page) from [<c01d6eb0>] (filemap_map_pages+0x340/0x348)
    [    7.877638]  r5:00000001 r4:00000000
    [    7.877643] [<c01d6b70>] (filemap_map_pages) from [<c0204050>] (handle_mm_fault+0x670/0xcd8)
    [    7.877647]  r10:000004df r9:b6b5e000 r8:000004ed r7:000004ee r6:00000040 r5:ccc4ea50
    [    7.877649]  r4:c8c03e44
    [    7.877653] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.877658]  r10:00000054 r9:cd3e7378 r8:b6b5e6e8 r7:00000005 r6:cd3e7340 r5:cce85dc0
    [    7.877659]  r4:c8c03fb0
    [    7.877664] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    7.877668]  r10:0000002a r9:bea33cec r8:c8c03fb0 r7:b6b5e6e8 r6:c0115fb8 r5:00000005
    [    7.877669]  r4:00000005
    [    7.877674] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.877676]  r7:b6b5e6e8 r6:c0115fb8 r5:00000005 r4:c0c08014
    [    7.877681] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.877683] Exception stack(0xc8c03fb0 to 0xc8c03ff8)
    [    7.877686] 3fa0:                                     7f5e4090 7f61d488 ffffffe4 004ed6e8
    [    7.877691] 3fc0: b6b5e6e8 00000000 7f5e4090 7f61d488 b6f4ace8 bea33cec 0000002a 00000000
    [    7.877695] 3fe0: 7f5f05fa bea33ce0 7f5a46f8 7f5b7234 80030010 ffffffff
    [    7.877699]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80030010 r4:7f5b7234
    [   10.292352] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
    [    2.549479] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.800818] systemd[1]: basic.target: Found ordering cycle on basic.target/start
    [    2.808267] systemd[1]: basic.target: Found dependency on sockets.target/start
    [    2.816690] systemd[1]: basic.target: Found dependency on rpcbind.socket/start
    [    2.824008] systemd[1]: basic.target: Found dependency on sysinit.target/start
    [    2.831288] systemd[1]: basic.target: Found dependency on alignment.service/start
    [    2.838806] systemd[1]: basic.target: Found dependency on basic.target/start
    [    2.845925] systemd[1]: basic.target: Breaking ordering cycle by deleting job sockets.target/start
    [ SKIP ] Ordering cycle found, skipping Sockets
    [    3.272779] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.337115] cmemk: loading out-of-tree module taints kernel.
    [    3.343728] CMEMK module: reference Linux version 4.9.28
    [    3.351144] allocated heap buffer 0x40500000 of size 0x100000
    [    3.356952] cmemk initialized
    [    3.364940] cryptodev: driver 1.8 loaded.
    [    4.199063] systemd-journald[114]: Received request to flush runtime journal from PID 1
    [    7.026856] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.027036] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.027042] pgd = ccff4000
    [    7.027049] [00000000] *pgd=00000000
    [    7.027069] Internal error: Oops: 80000005 [#1] PREEMPT SMP ARM
    [    7.027092] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.027104] CPU: 1 PID: 186 Comm: systemd-udevd Tainted: G           O    4.9.28-geed43d1050 #1
    [    7.027108] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.027111] task: ccf7c4c0 task.stack: ccfee000
    [    7.027120] PC is at 0x0
    [    7.027133] LR is at do_DataAbort+0x44/0xc4
    [    7.027137] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    7.027137] sp : ccfeff00  ip : c0c07fc4  fp : ccfeffac
    [    7.027141] r10: 7f701158  r9 : 7f692088  r8 : ccfeffb0
    [    7.027144] r7 : 7f691e70  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    7.027146] r3 : 0000000f  r2 : ccfeffb0  r1 : 0000081f  r0 : 7f691e70
    [    7.027151] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.027155] Control: 10c5387d  Table: 8cff406a  DAC: 00000051
    [    7.027158] Process systemd-udevd (pid: 186, stack limit = 0xccfee210)
    [    7.027161] Stack: (0xccfeff00 to 0xccff0000)
    [    7.027167] ff00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.027173] ff20: 00000000 c03cb25c 800f0113 ffffffff ccfeff7c 00000000 ccfeffac ccfeff48
    [    7.027177] ff40: c010ca78 c01012d4 b6db2288 beffffff 000000ba ccfee000 b6db2288 00000051
    [    7.027182] ff60: 00000000 00000000 00000000 00000000 00000000 ccfeffac f7db228b ccfeff98
    [    7.027187] ff80: c0155d10 c03cb25c 800f0113 b6e38898 200f0030 ffffffff 10c5387d 10c5387d
    [    7.027192] ffa0: 00000000 ccfeffb0 c010cea0 c01012d4 00000000 b6ed17a0 ffffffff 7f689d68
    [    7.027196] ffc0: 7f691e68 b6ed17a4 b6ed179c 7f691e70 00000000 7f692088 7f701158 7f5ed014
    [    7.027200] ffe0: 00000000 beb24040 beb24064 b6e38898 200f0030 ffffffff 00000000 00000000
    [    7.027204] Backtrace:
    [    7.027214] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.027217] Exception stack(0xccfeffb0 to 0xccfefff8)
    [    7.027220] ffa0:                                     00000000 b6ed17a0 ffffffff 7f689d68
    [    7.027226] ffc0: 7f691e68 b6ed17a4 b6ed179c 7f691e70 00000000 7f692088 7f701158 7f5ed014
    [    7.027230] ffe0: 00000000 beb24040 beb24064 b6e38898 200f0030 ffffffff
    [    7.027235]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0030 r4:b6e38898
    [    7.027242] Code: bad PC value
    [    7.027250] ---[ end trace e0a01991478798f8 ]---
    [    7.028838] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.028840] pgd = cce20000
    [    7.028844] [00000000] *pgd=00000000
    [    7.028851] Internal error: Oops: 80000005 [#2] PREEMPT SMP ARM
    [    7.028866] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.028872] CPU: 1 PID: 124 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.028874] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.028877] task: ccc39900 task.stack: cce1e000
    [    7.028880] PC is at 0x0
    [    7.028885] LR is at do_DataAbort+0x44/0xc4
    [    7.028889] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    7.028889] sp : cce1ff00  ip : c0c07fc4  fp : cce1ffac
    [    7.028891] r10: beb24730  r9 : 00000001  r8 : cce1ffb0
    [    7.028894] r7 : 7f5fe580  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    7.028897] r3 : 0000000f  r2 : cce1ffb0  r1 : 0000081f  r0 : 7f5fe580
    [    7.028900] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.028903] Control: 10c5387d  Table: 8ce2006a  DAC: 00000051
    [    7.028905] Process systemd-udevd (pid: 124, stack limit = 0xcce1e210)
    [    7.028908] Stack: (0xcce1ff00 to 0xcce20000)
    [    7.028914] ff00: a26bc5a5 00000107 c0108024 cd42c2d0 00000000 00000000 c0191228 00000000
    [    7.028919] ff20: cd3dab48 cd42c2d0 00000001 00000080 00000080 00000000 cce1ff74 cce1ff48
    [    7.028923] ff40: c022cc48 c026c2fc 00000000 00000000 cce1ff74 cd3dab40 cd3dab40 00000000
    [    7.028928] ff60: 00000000 beb24730 cce1ffa4 cce1ff78 c022da44 c022cb5c 00000000 00000000
    [    7.028933] ff80: 7f5fce18 00000001 beb24518 b6e44494 600f0010 ffffffff 10c5387d 10c5387d
    [    7.028937] ffa0: 00000000 cce1ffb0 c010cea0 c01012d4 7f5fe580 beb24730 00000080 00000000
    [    7.028942] ffc0: 7f5fce18 00000001 beb24518 7f5fd058 00000000 00000001 beb24730 beb247dc
    [    7.028946] ffe0: 7f5fe580 beb244f4 7f5c1aa0 b6e44494 600f0010 ffffffff 06101200 88000600
    [    7.028949] Backtrace:
    [    7.028956] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.028958] Exception stack(0xcce1ffb0 to 0xcce1fff8)
    [    7.028962] ffa0:                                     7f5fe580 beb24730 00000080 00000000
    [    7.028967] ffc0: 7f5fce18 00000001 beb24518 7f5fd058 00000000 00000001 beb24730 beb247dc
    [    7.028971] ffe0: 7f5fe580 beb244f4 7f5c1aa0 b6e44494 600f0010 ffffffff
    [    7.028975]  r8:10c5387d r7:10c5387d r6:ffffffff r5:600f0010 r4:b6e44494
    [    7.028981] Code: bad PC value
    [    7.028985] ---[ end trace e0a01991478798f9 ]---
    [    7.030353] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.030356] pgd = cd3e4000
    [    7.030361] [00000000] *pgd=00000000
    [    7.030367] Internal error: Oops: 80000005 [#3] PREEMPT SMP ARM
    [    7.030381] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.030386] CPU: 1 PID: 1 Comm: systemd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.030388] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.030390] task: cd880000 task.stack: cd866000
    [    7.030394] PC is at 0x0
    [    7.030398] LR is at do_DataAbort+0x44/0xc4
    [    7.030403] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    7.030403] sp : cd867f00  ip : c0c07fc4  fp : cd867fac
    [    7.030405] r10: 00000004  r9 : 00000003  r8 : cd867fb0
    [    7.030408] r7 : 7f786d4c  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    7.030411] r3 : 0000000f  r2 : cd867fb0  r1 : 0000081f  r0 : 7f786d4c
    [    7.030414] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.030418] Control: 10c5387d  Table: 8d3e406a  DAC: 00000051
    [    7.030420] Process systemd (pid: 1, stack limit = 0xcd866210)
    [    7.030423] Stack: (0xcd867f00 to 0xcd868000)
    [    7.030428] 7f00: c024d968 c024d764 cd867f54 cd867f18 c022e600 c024d948 00000020 00000000
    [    7.030432] 7f20: c0149ee4 ccee2788 ccee2780 cd8804c4 c0c51780 cd8804e0 cd880000 00000000
    [    7.030437] 7f40: cd866000 00000000 cd867f64 cd867f58 c022e700 c022e4d0 cd867f8c cd867f68
    [    7.030442] 7f60: c014a058 c022e6fc cd866000 c0108024 cd866000 c0108024 cd867fb0 00000006
    [    7.030446] 7f80: cd867fac cd867f90 c010b888 b6d3bb68 200f0010 ffffffff 10c5387d 10c5387d
    [    7.030451] 7fa0: 00000000 cd867fb0 c010cea0 c01012d4 7f786d4c 00000000 00000003 7f786d4c
    [    7.030455] 7fc0: 7f749f60 00000003 7f786d3c 7f749f80 7f786d5c 00000003 00000004 7f786d40
    [    7.030459] 7fe0: 7f75caf0 beb91720 7f6e6ccc b6d3bb68 200f0010 ffffffff 20020020 6a722060
    [    7.030463] Backtrace:
    [    7.030468] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.030471] Exception stack(0xcd867fb0 to 0xcd867ff8)
    [    7.030475] 7fa0:                                     7f786d4c 00000000 00000003 7f786d4c
    [    7.030479] 7fc0: 7f749f60 00000003 7f786d3c 7f749f80 7f786d5c 00000003 00000004 7f786d40
    [    7.030483] 7fe0: 7f75caf0 beb91720 7f6e6ccc b6d3bb68 200f0010 ffffffff
    [    7.030488]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0010 r4:b6d3bb68
    [    7.030493] Code: bad PC value
    [    7.030497] ---[ end trace e0a01991478798fa ]---
    [    7.031933] systemd: 36 output lines suppressed due to ratelimiting
    [    7.032157] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
    [    7.032157]
    [    7.732504] pgd = c8c0c000
    [    7.735217] [00000000] *pgd=00000000
    [    7.738814] Internal error: Oops: 80000005 [#4] PREEMPT SMP ARM
    [    7.744753] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.754406] CPU: 0 PID: 187 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.763138] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.769253] task: ccf7cb00 task.stack: c8c08000
    [    7.773798] PC is at 0x0
    [    7.776339] LR is at do_DataAbort+0x44/0xc4
    [    7.780537] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    7.780537] sp : c8c09f00  ip : c0c07fc4  fp : c8c09fac
    [    7.792060] r10: 7f702f00  r9 : 7f692088  r8 : c8c09fb0
    [    7.797302] r7 : 7f691e70  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    7.803853] r3 : 0000000f  r2 : c8c09fb0  r1 : 0000081f  r0 : 7f691e70
    [    7.810404] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.817653] Control: 10c5387d  Table: 88c0c06a  DAC: 00000051
    [    7.823419] Process systemd-udevd (pid: 187, stack limit = 0xc8c08210)
    [    7.829970] Stack: (0xc8c09f00 to 0xc8c0a000)
    [    7.834344] 9f00: 53cb1c50 00000000 00000000 00000000 c0996a30 00000000 020a0400 00030100
    [    7.842554] 9f20: 08000000 c03cb25c 800f0113 ffffffff c8c09f7c 00000000 c8c09fac c8c09f48
    [    7.850764] 9f40: c010ca78 c01012d4 b6db2288 beffffff 000000bb c8c08000 b6db2288 00000051
    [    7.858973] 9f60: 00000000 00000000 00000000 00000000 00000000 c8c09fac f7db228b c8c09f98
    [    7.867183] 9f80: c0155d10 c03cb25c 800f0113 b6e38898 200f0030 ffffffff 10c5387d 10c5387d
    [    7.875392] 9fa0: 00000000 c8c09fb0 c010cea0 c01012d4 00000000 b6ed17a0 ffffffff 7f689d68
    [    7.883601] 9fc0: 7f691e68 b6ed17a4 b6ed179c 7f691e70 00000000 7f692088 7f702f00 7f5ed014
    [    7.891811] 9fe0: 00000000 beb24040 beb24064 b6e38898 200f0030 ffffffff 729f9b28 00000000
    [    7.900016] Backtrace:
    [    7.902477] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.909899] Exception stack(0xc8c09fb0 to 0xc8c09ff8)
    [    7.914967] 9fa0:                                     00000000 b6ed17a0 ffffffff 7f689d68
    [    7.923177] 9fc0: 7f691e68 b6ed17a4 b6ed179c 7f691e70 00000000 7f692088 7f702f00 7f5ed014
    [    7.931386] 9fe0: 00000000 beb24040 beb24064 b6e38898 200f0030 ffffffff
    [    7.938026]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0030 r4:b6e38898
    [    7.944754] Code: bad PC value
    [    7.947818] ---[ end trace e0a01991478798fb ]---
    [    7.952463] CPU0: stopping
    [    7.955177] CPU: 0 PID: 187 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.963907] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.970019] Backtrace:
    [    7.972488] [<c010bcec>] (dump_backtrace) from [<c010bfa8>] (show_stack+0x18/0x1c)
    [    7.980086]  r7:c8c09c48 r6:200f0193 r5:00000000 r4:c0c22310
    [    7.985769] [<c010bf90>] (show_stack) from [<c03cbf20>] (dump_stack+0x8c/0xa0)
    [    7.993022] [<c03cbe94>] (dump_stack) from [<c010f1bc>] (handle_IPI+0x170/0x184)
    [    8.000446]  r7:c8c09c48 r6:00000000 r5:00000000 r4:c0b5ad7c
         8.006127] [<c010f04c[ >  t  o8 s.0to08p 1s67ec]o SnMdPar: y fCaiPlUesd
    irt0o 1s5t4op4> ]s e(cogincda_hrayn CdlPUes_
      q+0x78/0x7c)
    4[        8.8.010812862633] ] r7 : fr7a2:f1a20201020 0r60: rc68:cc089cc4098c r485: rf5a2:1fa220102c 0r04c r:4c0:cc0034c0134
     14
    [    8.018261]
    [    8[.0 3 4  3685.]03 4U3n6ab5]l eU tnao blhae ntdol eh kanerdnleel k NerULnLel  poNUiLntL epr oidentreefr erdeenrceefe raetn cvei ratt uvailr atddurael ssa d0dr0ess 00000000
    [ [       88..00449955113]3 ] EExxcceeppttiionon  ststaacck(k0xc8c09c48 to 0xc8c09c90)
    [ [      8 .8.005577119999]]  99cc440:0:                                      ccceb29c4 00000000 00000000 00000009 ccf4c000 0000000b
    [[       8 .80.06868909011]]  IIntnetrernanall e rerrroro:r: O oOposp:s :8 800000000000055  [[##55]]  PPRREEEEMMPPTT  SSMMPP  AARRMM
    8c09ca4 c8c09ca8 c8c09c98
    [ [       88..008833112288]]  99c8c0:80 c: 01c0b11b01d00 dc0 0c70c7cd6c8 400f0113 ffffffff
    [    8.091160]  sch_fq_codel r9[    8  .809.039632642]4 ][ [<<c0c07c7dc6da6a0>0]> ] (_(r_arwaw__ssppiinn__uunnlloocckk__irirq)q )f frroomm  [<[c<c0101bb101d0d0>0>]]  ((aacccct_collect+0x198/0x1b8)
    [[        88..110088445522]]    uuiioo__mmoodduullee__drdrv(v(O)O)_collect) from [<c0132438>] (do_exit+0x4c0/0x9f0)
     uio r[      8. 811.190129042] 4 ]g  dgbdbsserervevrerpprorxoxyy(O(O))00b r4:ccf7cb00
     [<<cc00113311ff7788>>]]  (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [ rr77::ffffffffffffffcc
    ]  cmemk(O)[ [      8 .813.163067407]4 C] PCUP: U:1 1  PIPID:D :1 18800  CCoommmm::  ssyysstteemmdd--uuddeevvdd  TTaaiinntteedd::  GG            DD        OO       4. 49..298.2-g8e-gede4e3d43d1050 #1
    [ [       88..15152626494]9 ]  r 10r1:000:00000000001144  rr99::cccccc55008f8f8 8r r88::0000000000000000 r 7r:7:ccccc5c5080c08c 0r6 :r68:00800005 r5:c8c09eb0
    [[       8. 81.66166525222]]    rr44::0000000000000000
    0 task.stack: ccf1e000
    [[        8.8.17173368698]9]  PPC C iiss  atat 0 0xx00
    [[       8. 18.8152851214]4]  LRL R iiss  ata td do_oD_aDattaAaAbobortr+t+00xx444/0xc4
    3   [   8 .1 98.2199032]90 p3c]  :pc [ :< 00[0<0000000000>00] 0> ]    l r  :l r[ <:c [01<0c011300c13>0]c > ]    p sr :p sr60:0 f60001f09139
      [      8 .81.921990293] 0sp3] :  spc c:f 1ccf1ff00  ip : c0c07fc4  fp : ccf1ffac
    [  [     8. 821.22810208]0 0]  r 1r01:0:77f7f0720f2f0000  r9r9:c:c88cc0088000000  rr88::cc88c0c90e9be0b 0r 7r:700:000000000 r6:c0115fb8 r5:00000005
    [ [      8 .8.22225588000] 0r] r77  :: 7 f76f69191ee7070  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [ [      8 .2384.2830148] r031] :  r03 00:0 000000f0 00 r02f   :r 2c cf1:f fccbf0 1 r1ff b: 00  00r010 :8 10f 00 r0008 1:f  7 fr069 1: e77f06
    9r1ee7fe0t
    chAbort+0x40/0xa8)
    4[       8 .8.225500006767]]    r7r7::0000000000000000  rr66::cc00111155ffbb88  rr55:0:000000000000055  r4r4:c:c00cc008821214
    ARM  Segment none
    1 [       88..22663037067]6 ] CConotntrrool:l: 10 1c50c385378d 7 dT a bTlabe:le 8: cf8c6f688060a6 a   DADCA:C :0 00000000005015
    (__pabt_svc+0x64/0xa0)
    8[       8 8.2.7267666993]3 ]E Exxcceeptptiiono snt acskt(a0ckxc(08cx0c98ce0b90e tbo0  t0oxc 80cx0c89ce0f9e8)f
    t)i
      = 0xccf1e210)
    [ [      8 .82.82888383989] ]9 e9eaa0:0 :        7f691e70 0000081f c8c09fb0 0000000f
    [ [       8.8.330008087474] ]f fff000:0:  00000000000000 000 0000000000000 0cc0 fc1cfff17f4 f7c4cf c1cfff11ff8 1c80 c70c793c9a03 ac0 0c1051151c1c1c ccc cfc1ffe1ffe0 cf0b05 7c033b857
    338
    [[       8 8..313177282282] ]f fff2200: : cccfc1ff1ff4fc4c  cc0b05bad57ca d7ac0 1a605e1625ce 200c 000000000010 00100 000000000000 c0 07c0c97c798748 4 a0948af1 00000001
    [[        8.8.33323203033]3] f fff4400: : cccfcf1f1ff5fc5 ccc cf1cff1ff5f05 0c0 c13308131c38 c1ccf c1ec0f100e 000000 00000000000 0cc0f c1cfff1b0ff 1b0 10c5387d 00000000
    [ [      8 .8.334466887722] ]f fff6600: :c ccfcf1e1e00000 0 7f76f6faf4a4d8 d8cc cf1fcff81fc fc8ccf1 cffc7f18f cf0787c 9c7078c4 9c70847c c901070c 91c0cf0 1ec0c0f10 e000 00000000
    [  [     8 .83.623642048]08 f]f8 0f: fc8c0f:1 fccfaf1c ffcaccf 1cfcff19f0f 9c001 c00b8120bc 82bc6e b3868e39888 98 200f0030 ffffffff 10c5387d 10c5387d
    [[       8 .8.337575585866]]  ffffa0a:0:  000000000000000 0 ccccff1f1ffbfb0 0c c00110c0ecaea0 0c 0c1001102d12d44 0 000000000000000  b6b6eedd1177a0a0 f fffffffffffffff  77ff668899dd6688
    [[        88..339911999944]]  99ffcc00::  77ff669911ee6688  bb66eedd1177aa44  bb66eedd117799cc  77ff669911ee7700  0000000000000000  77ff66992028088 87 7ff707022f0f00 0 7f7f55eded010144
    [ [       88..40484080340]3 f] ffe0fe:0 :00 0000000000000 0be bb2e40b24040 4be0b b24e0b2644 06b46 e3b68e89388 820980 f020030f0 00f3f0f ffffffffff fff 00000000 00000000
    [    8.423149] Backtrace: [ [     8  .482.4524534]43 [4]<c [01<c010120c18>2c]8 (>]d o_(dDatoaA_Dboatrat)Ab ofrrt) omfr o[m< c0[1<c0c0e10a0c>ea]0 (>_]_ (d_a_bdt_abustr_+u0sxr+40x40/0x60)
    [    8.439473] Exception stack(0xccf1ffb0 to 0xccf1fff8)
    [    8.444542] ffa0:                                     00000000 b6ed17a0 ffffffff 7f689d68
    [    8.452752] ffc0: 7f691e68 b6ed17a4 b6ed179c 7f691e70 00000000 7f692088 7f6fa4d8 7f5ed014
    [    8.460961] ffe0: 00000000 beb24040 beb24064 b6e38898 200f0030 ffffffff
    [    8.467600]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0030 r4:b6e38898
    [    8.474328] Code: bad PC value
    [    8.477391] ---[ end trace e0a01991478798fc ]---
    [    8.482722] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    8.490845] pgd = ccfc0000
    [    8.493557] [00000000] *pgd=00000000
    [    8.497152] Internal error: Oops: 80000005 [#6] PREEMPT SMP ARM
    [    8.503092] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    8.512744] CPU: 1 PID: 182 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    8.521475] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    8.527590] task: ccf792c0 task.stack: ccfbc000
    [    8.532134] PC is at 0x0
    [    8.534674] LR is at do_DataAbort+0x44/0xc4
    [    8.538870] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    8.538870] sp : ccfbdf00  ip : c0c07fc4  fp : ccfbdfac
    [    8.550393] r10: 7f6fc258  r9 : 7f6d4e90  r8 : ccfbdfb0
    [    8.555635] r7 : 7f68e01b  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    8.562184] r3 : 0000000f  r2 : ccfbdfb0  r1 : 0000081f  r0 : 7f68e01b
    [    8.568735] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    8.575984] Control: 10c5387d  Table: 8cfc006a  DAC: 00000051
    [    8.581749] Process systemd-udevd (pid: 182, stack limit = 0xccfbc210)
    [    8.588300] Stack: (0xccfbdf00 to 0xccfbe000)
    [    8.592672] df00: 00000000 00000000 ccfbdf74 ccfbdf18 c07c93a0 c01511cc ccfbdef0 c0b57338
    [    8.600882] df20: ccfbdf4c c0b5ad7c a12c40e1 00000001 00000000 c07c9784 a1c48999 00000001
    [    8.609091] df40: ccfbdf5c ccfbdf50 c013381c ccfbc000 00000000 ccfbdfb0 10c5387d 00000000
    [    8.617302] df60: ccfbc000 7f6fc258 ccfbdf8c ccfbdf78 c07c9784 c07c9100 ccfbc000 00000000
    [    8.625512] df80: ccfbdfac ccfbdf90 c010b82c 7f5d6444 600f0010 ffffffff 10c5387d 10c5387d
    [    8.633722] dfa0: 00000000 ccfbdfb0 c010cea0 c01012d4 80000000 b6ed17cc 00000000 00000041
    [    8.641932] dfc0: 7f68dff4 7f68dff8 7f5eab94 7f5eab94 7f68dff4 7f6d4e90 7f6fc258 7f5ed014
    [    8.650141] dfe0: 7f5ebc80 beb24088 7f5d643c 7f5d6444 600f0010 ffffffff 00000000 00000000
    [    8.658346] Backtrace:
    [    8.660805] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    8.668228] Exception stack(0xccfbdfb0 to 0xccfbdff8)
    [    8.673297] dfa0:                                     80000000 b6ed17cc 00000000 00000041
    [    8.681507] dfc0: 7f68dff4 7f68dff8 7f5eab94 7f5eab94 7f68dff4 7f6d4e90 7f6fc258 7f5ed014
    [    8.689715] dfe0: 7f5ebc80 beb24088 7f5d643c 7f5d6444 600f0010 ffffffff
    [    8.696355]  r8:10c5387d r7:10c5387d r6:ffffffff r5:600f0010 r4:7f5d6444
    [    8.703082] Code: bad PC value
    [    8.706145] ---[ end trace e0a01991478798fd ]---
    [    8.711323] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    8.719444] pgd = ccfdc000
    [    8.722156] [00000000] *pgd=00000000
    [    8.725751] Internal error: Oops: 80000005 [#7] PREEMPT SMP ARM
    [    8.731691] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    8.741341] CPU: 1 PID: 184 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    8.750071] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    8.756186] task: ccf78640 task.stack: ccfd8000
    [    8.760730] PC is at 0x0
    [    8.763270] LR is at do_DataAbort+0x44/0xc4
    [    8.767467] pc : [<00000000>]    lr : [<c010130c>]    psr: 600f0193
    [    8.767467] sp : ccfd9f00  ip : c0c07fc4  fp : ccfd9fac
    [    8.778989] r10: 7f6fe368  r9 : 7f6d4e90  r8 : ccfd9fb0
    [    8.784231] r7 : 7f68e01b  r6 : 00000000  r5 : 0000081f  r4 : c0c080b4
    [    8.790780] r3 : 0000000f  r2 : ccfd9fb0  r1 : 0000081f  r0 : 7f68e01b
    [    8.797331] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    8.804579] Control: 10c5387d  Table: 8cfdc06a  DAC: 00000051
    [    8.810344] Process systemd-udevd (pid: 184, stack limit = 0xccfd8210)
    [    8.816894] Stack: (0xccfd9f00 to 0xccfda000)
    [    8.821267] 9f00: 00000000 00000000 ccfd9f74 ccfd9f18 c07c93a0 c01511cc ccfd9ef0 c0b57338
    [    8.829477] 9f20: ccfd9f4c c0b5ad7c a1c6adf6 00000001 00000000 c07c9784 a25e1849 00000001
    [    8.837687] 9f40: ccfd9f5c ccfd9f50 c013381c ccfd8000 00000000 ccfd9fb0 10c5387d 00000000
    [    8.845896] 9f60: ccfd8000 7f6fe368 ccfd9f8c ccfd9f78 c07c9784 c07c9100 ccfd8000 00000000
    [    8.854106] 9f80: ccfd9fac ccfd9f90 c010b82c 7f5d6444 600f0010 ffffffff 10c5387d 10c5387d
    [    8.862316] 9fa0: 00000000 ccfd9fb0 c010cea0 c01012d4 80000000 b6ed17cc 00000000 00000041
    [    8.870524] 9fc0: 7f68dff4 7f68dff8 7f5eab94 7f5eab94 7f68dff4 7f6d4e90 7f6fe368 7f5ed014
    [    8.878733] 9fe0: 7f5ebc80 beb24088 7f5d643c 7f5d6444 600f0010 ffffffff 00000000 00000000
    [    8.886938] Backtrace:
    [    8.889398] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    8.896820] Exception stack(0xccfd9fb0 to 0xccfd9ff8)
    [    8.901889] 9fa0:                                     80000000 b6ed17cc 00000000 00000041
    [    8.910099] 9fc0: 7f68dff4 7f68dff8 7f5eab94 7f5eab94 7f68dff4 7f6d4e90 7f6fe368 7f5ed014
    [    8.918307] 9fe0: 7f5ebc80 beb24088 7f5d643c 7f5d6444 600f0010 ffffffff
    [    8.924946]  r8:10c5387d r7:10c5387d r6:ffffffff r5:600f0010 r4:7f5d6444
    [    8.931673] Code: bad PC value
    [    8.934736] ---[ end trace e0a01991478798fe ]---
    Welcome to Arago 2017.05!
    [    2.529499] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.783447] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    2.791279] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    2.799019] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    2.806277] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    2.814859] systemd[1]: sysinit.target: Found dependency on dropbear.socket/stop
    [    2.822328] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    2.829851] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Reached target Swap.
    [  OK  ] Listening on Syslog Socket.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Created slice System Slice.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Reached target Slices.
    [  OK  ] Listening on Journal Socket.
             Starting Load Kernel Modules...
    [    3.357266] cmemk: loading out-of-tree module taints kernel.
    [    3.363941] CMEMK module: reference Linux version 4.9.28
             Mounting POSIX Message Queue File System...
    [    3.373973] allocated heap buffer 0x40500000 of size 0x100000
    [    3.383398] cmemk initialized
    [    3.392220] cryptodev: driver 1.8 loaded.
             Mounting Temporary Directory...
             Mounting Debug File System...
             Starting Journal Service...
             Starting Create list of required st... nodes for the current kernel...
             Starting Setup Virtual Console...
    [  OK  ] Created slice system-getty.slice.
             Starting Remount Root and Kernel File Systems...
    [    3.593490] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Starting Rebuild Hardware Database...
             Starting Create Static Device Nodes in /dev...
             Mounting Configuration File System...
             Starting Apply Kernel Variables...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Mounted Configuration File System.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started Apply Kernel Variables.
    [    4.158597] systemd-journald[104]: Received request to flush runtime journal from PID 1
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Journal Catalog...
             Starting Create Volatile Files and Directories...
             Starting Rebuild Dynamic Linker Cache...
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Opkg first boot configure...
             Starting Network Time Synchronization...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Rebuild Hardware Database.
             Starting udev Coldplug all Devices...
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
             Starting Synchronize System and HW clocks...
    [    6.017812] Unhandled fault: page domain fault (0x01b) at 0x7f6fc420
    [    6.024234] pgd = c9018000
    [    6.026951] [7f6fc420] *pgd=8900d835, *pte=89bf475f, *ppte=89bf4c7f
    [    6.033275] Internal error: : 1b [#1] PREEMPT SMP ARM
    [    6.038349] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.048017] CPU: 1 PID: 198 Comm: systemd-udevd Tainted: G           O    4.9.28-geed43d1050 #1
    [    6.056749] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.062865] task: ccee44c0 task.stack: c9014000
    [    6.067422] PC is at __wake_up_common+0x28/0x94
    [    6.071970] LR is at __wake_up+0x40/0x54
    [    6.075905] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 600f0193
    [    6.075905] sp : c9015d50  ip : 7f6fc420  fp : c9015d84
    [    6.087427] r10: 00000003  r9 : 00000000  r8 : c9015dbc
    [    6.092669] r7 : c0c023bc  r6 : 00000003  r5 : 300f0113  r4 : c0c023b8
    [    6.099219] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c023b8
    [    6.105771] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.113019] Control: 10c5387d  Table: 8901806a  DAC: 00000051
    [    6.118785] Process systemd-udevd (pid: 198, stack limit = 0xc9014210)
    [    6.125335] Stack: (0xc9015d50 to 0xc9016000)
    [    6.129708] 5d40:                                     ce381430 00000001 c9015e64 c0c023b8
    [    6.137919] 5d60: 300f0113 00000003 00000001 c9015dbc ccc501f8 00000055 c9015db4 c9015d88
    [    6.146129] 5d80: c016eac4 c016e9fc c9015dbc c9015d98 c0200584 ce381454 ce381454 8c7ad7dd
    [    6.154340] 5da0: c900b6e0 00000055 c9015dd4 c9015db8 c016ed18 c016ea90 c9015dd4 ce381454
    [    6.162549] 5dc0: 00000000 00000000 c9015dec c9015dd8 c01d5c9c c016ece4 c9015e64 ce381454
    [    6.170759] 5de0: c9015e44 c9015df0 c020167c c01d5c64 c010f8f8 c010f584 0000005f 00000004
    [    6.178968] 5e00: c9015e64 c900b6e0 00000040 000003fb 00000055 ccc501f8 c9015e44 c9015e64
    [    6.187178] 5e20: c900b6e0 00000040 8c7ad7dd 00000055 ccc501f8 00000055 c9015eac c9015e48
    [    6.195388] 5e40: c0203e50 c02013e0 00000000 00000054 c9019fd0 c90237f0 ccc501f4 00000000
    [    6.203597] 5e60: c9015e8c c900b6e0 7f703000 00000055 c9019fd8 c900d40c ccc501f4 00000000
    [    6.211806] 5e80: c9015eac c9015fb0 ccee44c0 ccc501c0 00000817 7f703694 ccc501f8 00000055
    [    6.220017] 5ea0: c9015efc c9015eb0 c0115e40 c02039ec 00000000 80000005 00000005 c0115fb8
    [    6.228227] 5ec0: 7f5fc964 00000000 00000800 00000008 c9015efc c0c08034 00000817 c0115bbc
    [    6.236436] 5ee0: 7f703694 c9015fb0 7f648008 7f75c168 c9015fac c9015f00 c010130c c0115bc8
    [    6.244644] 5f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.252854] 5f20: 00000000 c03cb25c 800f0113 ffffffff c9015f7c 00000000 c9015fac c9015f48
    [    6.261063] 5f40: c010ca78 c01012d4 b6d57288 beffffff 000000c6 c9014000 b6d57288 00000051
    [    6.269272] 5f60: 00000000 00000000 00000000 00000000 00000000 c9015fac f7d5728b c9015f98
    [    6.277480] 5f80: c0155d10 c03cb25c 800f0113 7f5fc390 200f0010 ffffffff 10c5387d 10c5387d
    [    6.285690] 5fa0: 00000000 c9015fb0 c010cea0 c01012d4 7f702d98 b6e767cc 7f703690 7f648014
    [    6.293899] 5fc0: 7f702d98 7f648014 7f75c168 7f75bca0 7f75b1b4 7f648008 7f75c168 7f648014
    [    6.302108] 5fe0: 7f646c80 bef850c0 7f5fc9dc 7f5fc390 200f0010 ffffffff 00000000 00000000
    [    6.310314] Backtrace:
    [    6.312776] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.320463]  r10:00000055 r9:ccc501f8 r8:c9015dbc r7:00000001 r6:00000003 r5:300f0113
    [    6.328322]  r4:c0c023b8
    [    6.330863] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.338287]  r8:00000055 r7:c900b6e0 r6:8c7ad7dd r5:ce381454 r4:ce381454
    [    6.345024] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    6.352629] [<c01d5c58>] (unlock_page) from [<c020167c>] (do_wp_page+0x2a8/0x6f0)
    [    6.360139]  r5:ce381454 r4:c9015e64
    [    6.363728] [<c02013d4>] (do_wp_page) from [<c0203e50>] (handle_mm_fault+0x470/0xcd8)
    [    6.371588]  r10:00000055 r9:ccc501f8 r8:00000055 r7:8c7ad7dd r6:00000040 r5:c900b6e0
    [    6.379446]  r4:c9015e64
    [    6.381991] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    6.390113]  r10:00000055 r9:ccc501f8 r8:7f703694 r7:00000817 r6:ccc501c0 r5:ccee44c0
    [    6.397970]  r4:c9015fb0
    [    6.400513] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.408198]  r10:7f75c168 r9:7f648008 r8:c9015fb0 r7:7f703694 r6:c0115bbc r5:00000817
    [    6.416056]  r4:c0c08034
    [    6.418598] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    6.426019] Exception stack(0xc9015fb0 to 0xc9015ff8)
    [    6.431089] 5fa0:                                     7f702d98 b6e767cc 7f703690 7f648014
    [    6.439298] 5fc0: 7f702d98 7f648014 7f75c168 7f75bca0 7f75b1b4 7f648008 7f75c168 7f648014
    [    6.447507] 5fe0: 7f646c80 bef850c0 7f5fc9dc 7f5fc390 200f0010 ffffffff
    [    6.454145]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0010 r4:7f5fc390
    [    6.460871] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    6.466989] ---[ end trace 9cb85ed981884052 ]---
    [    6.471629] note: systemd-udevd[198] exited with preempt_count 3
    [    6.478771] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    6.486894] pgd = ccde0000
    [    6.489607] [00000000] *pgd=00000000
    [    6.493200] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
    [    6.498530] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.508185] CPU: 1 PID: 104 Comm: systemd-journal Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    6.517091] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.523206] task: cce012c0 task.stack: cccd2000
    [    6.527751] PC is at __wake_up_common+0x28/0x94
    [    6.532297] LR is at __wake_up+0x40/0x54
    [    6.536231] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 60000193
    [    6.536231] sp : cccd3da8  ip : 00000000  fp : cccd3ddc
    [    6.547752] r10: 00000003  r9 : 00000000  r8 : cccd3e14
    [    6.552995] r7 : c0c02a70  r6 : 00000003  r5 : a0000113  r4 : c0c02a6c
    [    6.559546] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02a6c
    [    6.566097] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.573345] Control: 10c5387d  Table: 8cde006a  DAC: 00000051
    [    6.579111] Process systemd-journal (pid: 104, stack limit = 0xcccd2210)
    [    6.585835] Stack: (0xcccd3da8 to 0xcccd4000)
    [    6.590207] 3da0:                   cccd3e04 00000001 c01f087c c0c02a6c a0000113 00000003
    [    6.598417] 3dc0: 00000001 cccd3e14 00000200 00000055 cccd3e0c cccd3de0 c016eac4 c016e9fc
    [    6.606626] 3de0: cccd3e14 c0189d68 cccd3e0c ce1dfaf4 ccc45630 00000040 ccc45630 00000200
    [    6.614837] 3e00: cccd3e2c cccd3e10 c016ed18 c016ea90 cccd3e2c ce1dfaf4 00000000 00000000
    [    6.623045] 3e20: cccd3e44 cccd3e30 c01d5c9c c016ece4 ccc46aac ccc45630 cccd3eac cccd3e48
    [    6.631254] 3e40: c020418c c01d5c64 00000000 c0c16e30 cce0c000 cce0c000 0000004b cce0c02c
    [    6.639463] 3e60: ce1dfaf4 ccc45630 b668e000 00000055 ccde2d98 ccc8b238 cd3e2574 00000000
    [    6.647672] 3e80: cccd3eac cccd3fb0 cce012c0 cd3e2540 00000817 b668e028 cd3e2578 00000055
    [    6.655882] 3ea0: cccd3efc cccd3eb0 c0115e40 c02039ec c017d480 bed806a0 cccd3f78 cccd3f78
    [    6.664092] 3ec0: 00002000 00000000 00000800 cccd3ed8 c022bd9c c0c08034 00000817 c0115bbc
    [    6.672301] 3ee0: b668e028 cccd3fb0 7f6143c8 bed7ef68 cccd3fac cccd3f00 c010130c c0115bc8
    [    6.680509] 3f00: 81a2205c 00000107 c0108024 cd8e5e78 00000000 00000000 c0191228 00000000
    [    6.688719] 3f20: cccc99c8 cd8e5e78 00000001 0000004b 00002000 00000000 cccd3f74 cccd3f48
    [    6.696928] 3f40: c022cc48 c026c2fc 00000000 00000000 cccd3f74 cccc99c0 cccc99c0 00000000
    [    6.705137] 3f60: 00000000 bed806a0 cccd3fa4 cccd3f78 c022da44 c022cb5c 00000000 00000000
    [    6.713347] 3f80: 7f6135f8 7f5ddf0c bed82748 b6e803f4 80000010 ffffffff 10c5387d 10c5387d
    [    6.721555] 3fa0: 00000000 cccd3fb0 c010cea0 c01012d4 b668e028 7f61c5d8 00000023 00000014
    [    6.729765] 3fc0: 00000023 00000000 bed7ee58 7f61c5d0 00000000 7f6143c8 bed7ef68 bed7ef64
    [    6.737974] 3fe0: b668e028 bed7ee00 7f5ee868 b6e803f4 80000010 ffffffff 00000000 00000000
    [    6.746179] Backtrace:
    [    6.748640] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.756328]  r10:00000055 r9:00000200 r8:cccd3e14 r7:00000001 r6:00000003 r5:a0000113
    [    6.764186]  r4:c0c02a6c
    [    6.766727] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.774152]  r8:00000200 r7:ccc45630 r6:00000040 r5:ccc45630 r4:ce1dfaf4
    [    6.780880] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    6.788481] [<c01d5c58>] (unlock_page) from [<c020418c>] (handle_mm_fault+0x7ac/0xcd8)
    [    6.796427]  r5:ccc45630 r4:ccc46aac
    [    6.800015] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    6.808136]  r10:00000055 r9:cd3e2578 r8:b668e028 r7:00000817 r6:cd3e2540 r5:cce012c0
    [    6.815993]  r4:cccd3fb0
    [    6.818534] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.826221]  r10:bed7ef68 r9:7f6143c8 r8:cccd3fb0 r7:b668e028 r6:c0115bbc r5:00000817
    [    6.834079]  r4:c0c08034
    [    6.836620] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    6.844041] Exception stack(0xcccd3fb0 to 0xcccd3ff8)
    [    6.849110] 3fa0:                                     b668e028 7f61c5d8 00000023 00000014
    [    6.857319] 3fc0: 00000023 00000000 bed7ee58 7f61c5d0 00000000 7f6143c8 bed7ef68 bed7ef64
    [    6.865528] 3fe0: b668e028 bed7ee00 7f5ee868 b6e803f4 80000010 ffffffff
    [    6.872166]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80000010 r4:b6e803f4
    [    6.878892] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    6.885007] ---[ end trace 9cb85ed981884053 ]---
    [    6.889641] note: systemd-journal[104] exited with preempt_count 1
    [    6.896012] Unable to handle kernel NULL pointer dereference at virtual address 000000b9
    [    6.904133] pgd = ccfe0000
    [    6.906846] [000000b9] *pgd=00000000
    [    6.910438] Internal error: Oops: 5 [#3] PREEMPT SMP ARM
    [    6.915767] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.925417] CPU: 1 PID: 194 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    6.934148] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.940263] task: ccee0000 task.stack: ccfde000
    [    6.944809] PC is at __wake_up_common+0x28/0x94
    [    6.949355] LR is at __wake_up+0x40/0x54
    [    6.953289] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 600f0193
    [    6.953289] sp : ccfdfd50  ip : 000000b9  fp : ccfdfd84
    [    6.964810] r10: 00000003  r9 : 00000000  r8 : ccfdfdbc
    [    6.970052] r7 : c0c02b54  r6 : 00000003  r5 : a00f0113  r4 : c0c02b50
    [    6.976601] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02b50
    [    6.983152] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.990399] Control: 10c5387d  Table: 8cfe006a  DAC: 00000051
    [    6.996164] Process systemd-udevd (pid: 194, stack limit = 0xccfde210)
    [    7.002713] Stack: (0xccfdfd50 to 0xccfe0000)
    [    7.007085] fd40:                                     8c7747df 00000001 ccfdfd7c c0c02b50
    [    7.015296] fd60: a00f0113 00000003 00000001 ccfdfdbc ccc50c78 00000055 ccfdfdb4 ccfdfd88
    [    7.023505] fd80: c016eac4 c016e9fc ccfdfdbc ccfdfd98 c0200584 ce380c98 ce380c98 8c7767dd
    [    7.031714] fda0: cccc8d10 00000055 ccfdfdd4 ccfdfdb8 c016ed18 c016ea90 ccfdfdd4 ce380c98
    [    7.039923] fdc0: 00000000 00000000 ccfdfdec ccfdfdd8 c01d5c9c c016ece4 ccfdfe64 ce380c98
    [    7.048132] fde0: ccfdfe44 ccfdfdf0 c020167c c01d5c64 c010f8f8 c010f584 ccfdfe2c 00000002
    [    7.056342] fe00: ccfdfe64 cccc8d10 00000040 000003fb 00000055 ccc50c78 ccfdfe44 ccfdfe64
    [    7.064551] fe20: cccc8d10 00000040 8c7767dd 00000055 ccc50c78 00000055 ccfdfeac ccfdfe48
    [    7.072761] fe40: c0203e50 c02013e0 00000000 c0153180 00000400 00000000 00000000 ccee01c0
    [    7.080971] fe60: 64612de2 cccc8d10 7f6ee000 00000055 ccfe1fd8 ccf963b8 ccc50c74 00000000
    [    7.089180] fe80: ccfdfeac ccfdffb0 ccee0000 ccc50c40 00000817 7f6ee40c ccc50c78 00000055
    [    7.097390] fea0: ccfdfefc ccfdfeb0 c0115e40 c02039ec ffffffff cd89c000 ccfdfeec ccfdfec8
    [    7.105599] fec0: c014d1fc 00000000 00000800 00000008 c0151234 c0c08034 00000817 c0115bbc
    [    7.113808] fee0: 7f6ee40c ccfdffb0 7f648008 7f757268 ccfdffac ccfdff00 c010130c c0115bc8
    [    7.122018] ff00: 00000000 00000000 ccfdff74 ccfdff18 c07c93a0 c01511cc ccfdfef0 c0b57338
    [    7.130227] ff20: ccfdff4c c0b5ad7c 63ef2bed 00000001 00000000 c07c9784 64612de2 00000001
    [    7.138436] ff40: ccfdff5c ccfdff50 c013381c ccfde000 00000000 ccfdffb0 10c5387d 00000000
    [    7.146645] ff60: ccfde000 7f757268 ccfdff8c ccfdff78 c07c9784 c07c9100 ccfde000 00000000
    [    7.154855] ff80: ccfdffac ccfdff90 c010b82c 7f5fc390 200f0010 ffffffff 10c5387d 10c5387d
    [    7.163065] ffa0: 00000000 ccfdffb0 c010cea0 c01012d4 7f6ed788 b6e767cc 7f6ee408 7f648014
    [    7.171274] ffc0: 7f6ed788 7f648014 7f757268 7f756ff8 7f7561c4 7f648008 7f757268 7f648014
    [    7.179484] ffe0: 7f646c80 bef850c0 7f5fc9dc 7f5fc390 200f0010 ffffffff 06508000 8800ac00
    [    7.187689] Backtrace:
    [    7.190150] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.197836]  r10:00000055 r9:ccc50c78 r8:ccfdfdbc r7:00000001 r6:00000003 r5:a00f0113
    [    7.205694]  r4:c0c02b50
    [    7.208235] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.215659]  r8:00000055 r7:cccc8d10 r6:8c7767dd r5:ce380c98 r4:ce380c98
    [    7.222387] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.229986] [<c01d5c58>] (unlock_page) from [<c020167c>] (do_wp_page+0x2a8/0x6f0)
    [    7.237496]  r5:ce380c98 r4:ccfdfe64
    [    7.241084] [<c02013d4>] (do_wp_page) from [<c0203e50>] (handle_mm_fault+0x470/0xcd8)
    [    7.248944]  r10:00000055 r9:ccc50c78 r8:00000055 r7:8c7767dd r6:00000040 r5:cccc8d10
    [    7.256801]  r4:ccfdfe64
    [    7.259343] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.267464]  r10:00000055 r9:ccc50c78 r8:7f6ee40c r7:00000817 r6:ccc50c40 r5:ccee0000
    [    7.275321]  r4:ccfdffb0
    [    7.277861] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.285547]  r10:7f757268 r9:7f648008 r8:ccfdffb0 r7:7f6ee40c r6:c0115bbc r5:00000817
    [    7.293404]  r4:c0c08034
    [    7.295945] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.303367] Exception stack(0xccfdffb0 to 0xccfdfff8)
    [    7.308435] ffa0:                                     7f6ed788 b6e767cc 7f6ee408 7f648014
    [    7.316644] ffc0: 7f6ed788 7f648014 7f757268 7f756ff8 7f7561c4 7f648008 7f757268 7f648014
    [    7.324853] ffe0: 7f646c80 bef850c0 7f5fc9dc 7f5fc390 200f0010 ffffffff
    [    7.331492]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0010 r4:7f5fc390
    [    7.338219] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    7.344334] ---[ end trace 9cb85ed981884054 ]---
    [    7.348967] note: systemd-udevd[194] exited with preempt_count 3
    [    7.355203] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    7.363325] pgd = ccffc000
    [    7.366039] [00000000] *pgd=00000000
    [    7.369631] Internal error: Oops: 5 [#4] PREEMPT SMP ARM
    [    7.374960] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.384612] CPU: 1 PID: 196 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.393341] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.399455] task: ccee3840 task.stack: ccff8000
    [    7.404001] PC is at __wake_up_common+0x28/0x94
    [    7.408546] LR is at __wake_up+0x40/0x54
    [    7.412481] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 600f0193
    [    7.412481] sp : ccff9d50  ip : 00000000  fp : ccff9d84
    [    7.424003] r10: 00000003  r9 : 00000000  r8 : ccff9dbc
    [    7.429246] r7 : c0c02c98  r6 : 00000003  r5 : a00f0113  r4 : c0c02c94
    [    7.435796] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02c94
    [    7.442346] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.449594] Control: 10c5387d  Table: 8cffc06a  DAC: 00000051
    [    7.455360] Process systemd-udevd (pid: 196, stack limit = 0xccff8210)
    [    7.461910] Stack: (0xccff9d50 to 0xccffa000)
    [    7.466282] 9d40:                                     ce3768e8 00000001 ccff9e64 c0c02c94
    [    7.474492] 9d60: a00f0113 00000003 00000001 ccff9dbc ccc508f8 00000055 ccff9db4 ccff9d88
    [    7.482701] 9d80: c016eac4 c016e9fc ccff9dbc ccff9d98 c01a9ac4 ce37690c ce37690c 8c2eb7df
    [    7.490909] 9da0: ccfed2c0 00000055 ccff9dd4 ccff9db8 c016ed18 c016ea90 ccff9dd4 ce37690c
    [    7.499117] 9dc0: 00000000 00000000 ccff9dec ccff9dd8 c01d5c9c c016ece4 ccff9e64 ce37690c
    [    7.507326] 9de0: ccff9e44 ccff9df0 c020167c c01d5c64 c010f8f8 c010f584 ccff9e2c 00000005
    [    7.515536] 9e00: ccff9e64 ccfed2c0 00000040 000003fb 00000055 ccc508f8 ccff9e44 ccff9e64
    [    7.523745] 9e20: ccfed2c0 00000040 8c2eb7df 00000055 ccc508f8 00000055 ccff9eac ccff9e48
    [    7.531954] 9e40: c0203e50 c02013e0 00000000 00000000 00000400 00000000 00000000 00000000
    [    7.540163] 9e60: 64f8ba85 ccfed2c0 7f6e8000 00000055 ccffdfd8 ccfef3a0 ccc508f4 00000000
    [    7.548372] 9e80: ccff9eac ccff9fb0 ccee3840 ccc508c0 0000081f 7f6e800b ccc508f8 00000055
    [    7.556580] 9ea0: ccff9efc ccff9eb0 c0115e40 c02039ec ffffffff ccdf8000 ccff9eec ccff9ec8
    [    7.564790] 9ec0: c014d1fc 00000000 00000800 00000000 c0151234 c0c080b4 0000081f c0115bbc
    [    7.572997] 9ee0: 7f6e800b ccff9fb0 7f71fbb0 7f759378 ccff9fac ccff9f00 c010130c c0115bc8
    [    7.581207] 9f00: 00000000 00000000 ccff9f74 ccff9f18 c07c93a0 c01511cc ccff9ef0 c0b57338
    [    7.589415] 9f20: ccff9f4c c0b5ad7c 64621c2a 00000001 00000000 c07c9784 64f8ba85 00000001
    [    7.597624] 9f40: ccff9f5c ccff9f50 c013381c ccff8000 00000000 ccff9fb0 10c5387d 00000000
    [    7.605834] 9f60: ccff8000 7f759378 ccff9f8c ccff9f78 c07c9784 c07c9100 ccff8000 00000000
    [    7.614043] 9f80: ccff9fac ccff9f90 c010b82c 7f631444 600f0010 ffffffff 10c5387d 10c5387d
    [    7.622252] 9fa0: 00000000 ccff9fb0 c010cea0 c01012d4 80000000 b6e767cc 00000000 00000041
    [    7.630461] 9fc0: 7f6e7fe4 7f6e7fe8 7f645b94 7f645b94 7f6e7fe4 7f71fbb0 7f759378 7f648014
    [    7.638670] 9fe0: 7f646c80 bef85088 7f63143c 7f631444 600f0010 ffffffff 00000000 00000000
    [    7.646875] Backtrace:
    [    7.649334] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    7.657021]  r10:00000055 r9:ccc508f8 r8:ccff9dbc r7:00000001 r6:00000003 r5:a00f0113
    [    7.664878]  r4:c0c02c94
    [    7.667418] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    7.674842]  r8:00000055 r7:ccfed2c0 r6:8c2eb7df r5:ce37690c r4:ce37690c
    [    7.681570] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    7.689170] [<c01d5c58>] (unlock_page) from [<c020167c>] (do_wp_page+0x2a8/0x6f0)
    [    7.696679]  r5:ce37690c r4:ccff9e64
    [    7.700267] [<c02013d4>] (do_wp_page) from [<c0203e50>] (handle_mm_fault+0x470/0xcd8)
    [    7.708126]  r10:00000055 r9:ccc508f8 r8:00000055 r7:8c2eb7df r6:00000040 r5:ccfed2c0
    [    7.715983]  r4:ccff9e64
    [    7.718523] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    7.726645]  r10:00000055 r9:ccc508f8 r8:7f6e800b r7:0000081f r6:ccc508c0 r5:ccee3840
    [    7.734502]  r4:ccff9fb0
    [    7.737042] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    7.744728]  r10:7f759378 r9:7f71fbb0 r8:ccff9fb0 r7:7f6e800b r6:c0115bbc r5:0000081f
    [    7.752585]  r4:c0c080b4
    [    7.755125] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.762546] Exception stack(0xccff9fb0 to 0xccff9ff8)
    [    7.767616] 9fa0:                                     80000000 b6e767cc 00000000 00000041
    [    7.775824] 9fc0: 7f6e7fe4 7f6e7fe8 7f645b94 7f645b94 7f6e7fe4 7f71fbb0 7f759378 7f648014
    [    7.784032] 9fe0: 7f646c80 bef85088 7f63143c 7f631444 600f0010 ffffffff
    [    7.790670]  r8:10c5387d r7:10c5387d r6:ffffffff r5:600f0010 r4:7f631444
    [    7.797396] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    7.803511] ---[ end trace 9cb85ed981884055 ]---
    [    7.808143] note: systemd-udevd[196] exited with preempt_count 3
    [    7.814961] Unable to handle kernel NULL pointer dereference at virtual address 00000004
    [    7.823169] Unable to handle kernel paging request at virtual address 708f902f
    [    7.823172] pgd = ccfc4000
    [    7.823175] [708f902f] *pgd=00000000
    [    7.823179] Internal error: Oops: 5 [#5] PREEMPT SMP ARM
    [    7.823190] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.823195] CPU: 1 PID: 192 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.823196] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.823199] task: ccee0c80 task.stack: ccedc000
    [    7.823209] PC is at __percpu_counter_add+0x40/0x118
    [    7.823213] LR is at 0xccedddc8
    [    7.823217] pc : [<c03f5480>]    lr : [<ccedddc8>]    psr: a00f0013
    [    7.823217] sp : ccedddc8  ip : 0f232000  fp : ccedddf4
    [    7.823219] r10: 00000000  r9 : cceddea8  r8 : cceddf5c
    [    7.823222] r7 : 00000000  r6 : c0c1cbc0  r5 : ccea6980  r4 : c0c02ec0
    [    7.823224] r3 : 00000000  r2 : 00000001  r1 : 616c702f  r0 : 00000020
    [    7.823228] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.823230] Control: 10c5387d  Table: 8cfc406a  DAC: 00000051
    [    7.823232] Process systemd-udevd (pid: 192, stack limit = 0xccedc210)
    [    7.823235] Stack: (0xccedddc8 to 0xccede000)
    [    7.823239] ddc0:                   00000001 00000000 ccf76b40 ccea6980 c0c1cbc0 00000001
    [    7.823243] dde0: cceddf5c cceddea8 ccedde1c ccedddf8 c022e8dc c03f544c 00000020 ccedde08
    [    7.823248] de00: c0151234 00000007 cceddea8 cceddf5c cceddea4 ccedde20 c023a320 c022e838
    [    7.823252] de20: ccee0c80 ccee44c0 ccc501c0 ccc50380 00000000 00000001 cceddea4 ccedde48
    [    7.823257] de40: c07c93a0 00000041 ccedc000 00000000 ccedde6c ccedde60 00000000 00000001
    [    7.823262] de60: ccedde94 c07c9bf8 6629e28d 00000001 c0c03414 fa21200c cceddec0 00000007
    [    7.823267] de80: cceddea8 cceddf5c 00000001 c0108024 ccedc000 00000000 cceddf4c cceddea8
    [    7.823271] dea0: c023c57c c023a304 ccedded4 cceddeb8 c026fa2c c016e914 ccf5c400 cd755340
    [    7.823275] dec0: cceddf5c ccea7780 cceddeec ccedded8 c06a2628 c026f98c 00000000 00000ff0
    [    7.823280] dee0: 00000000 cceddee8 ccc38100 ccc38118 00000000 00000400 cceddf3c cceddf08
    [    7.823284] df00: c024afac c07cd5f8 c023b830 000a0101 00020101 000a0101 cd8dc000 00000000
    [    7.823289] df20: fffff000 c0108024 ffffff9c 00000000 00000007 ffffff9c cd8dc000 fffff000
    [    7.823293] df40: cceddf94 cceddf50 c022b70c c023c51c 00000001 59541048 cceddfa4 00020101
    [    7.823298] df60: c0140000 00000002 00000100 00000001 00080101 7f6350e0 00000000 00000005
    [    7.823302] df80: c0108024 ccedc000 cceddfa4 cceddf98 c022b7dc c022b600 00000000 cceddfa8
    [    7.823306] dfa0: c0107e60 c022b7c8 00080101 7f6350e0 7f6350e4 000a0101 00000000 00000000
    [    7.823311] dfc0: 00080101 7f6350e0 00000000 00000005 7f6350e4 00000000 00000003 0000000e
    [    7.823316] dfe0: 00000005 bef85068 b6e86dc3 b6e88366 200f0030 7f6350e4 00000000 00000000
    [    7.823319] Backtrace:
    [    7.823328] [<c03f5440>] (__percpu_counter_add) from [<c022e8dc>] (get_empty_filp+0xb0/0x1c0)
    [    7.823334]  r9:cceddea8 r8:cceddf5c r7:00000001 r6:c0c1cbc0 r5:ccea6980 r4:ccf76b40
    [    7.823340] [<c022e82c>] (get_empty_filp) from [<c023a320>] (path_openat+0x28/0xefc)
    [    7.823343]  r6:cceddf5c r5:cceddea8 r4:00000007
    [    7.823349] [<c023a2f8>] (path_openat) from [<c023c57c>] (do_filp_open+0x6c/0xd0)
    [    7.823353]  r10:00000000 r9:ccedc000 r8:c0108024 r7:00000001 r6:cceddf5c r5:cceddea8
    [    7.823355]  r4:00000007
    [    7.823360] [<c023c510>] (do_filp_open) from [<c022b70c>] (do_sys_open+0x118/0x1c8)
    [    7.823363]  r7:fffff000 r6:cd8dc000 r5:ffffff9c r4:00000007
    [    7.823367] [<c022b5f4>] (do_sys_open) from [<c022b7dc>] (SyS_open+0x20/0x24)
    [    7.823371]  r9:ccedc000 r8:c0108024 r7:00000005 r6:00000000 r5:7f6350e0 r4:00080101
    [    7.823380] [<c022b7bc>] (SyS_open) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    7.823384] Code: e581c004 e5941018 e1a07fc0 ee1dcf90 (e791100c)
    [    7.823387] ---[ end trace 9cb85ed981884056 ]---
    [    7.823391] note: systemd-udevd[192] exited with preempt_count 1
    [    7.824155] Unable to handle kernel paging request at virtual address 708f902f
    [    7.824158] pgd = c0004000
    [    7.824162] [708f902f] *pgd=00000000
    [    7.824165] Internal error: Oops: 5 [#6] PREEMPT SMP ARM
    [    7.824175] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.824179] CPU: 1 PID: 192 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.824181] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.824182] task: ccee0c80 task.stack: ccedc000
    [    7.824188] PC is at __percpu_counter_add+0x40/0x118
    [    7.824191] LR is at 0xcceddae8
    [    7.824194] pc : [<c03f5480>]    lr : [<cceddae8>]    psr: 400f0113
    [    7.824194] sp : cceddae8  ip : 0f232000  fp : cceddb14
    [    7.824196] r10: 00000008  r9 : cd755360  r8 : 00000000
    [    7.824198] r7 : 00000000  r6 : cd7d14c8  r5 : cd755360  r4 : c0c02ec0
    [    7.824200] r3 : ffffffff  r2 : ffffffff  r1 : 616c702f  r0 : 00000020
    [    7.824203] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.824206] Control: 10c5387d  Table: 8cfc406a  DAC: 00000051
    Thanks again,
    Vishal
  • Do you copy that line StandardOutput=journal+console under [Service]?
  • Can you enter setenv optargs S in U-Boot console then type boot? This will let you login to single user mode. Then execute /bin/udevadm --debug trigger --verbose --type=subsystems --action=add ; /bin/udevadm --debug trigger --verbose --type=devices --action=add and see what happens.
  • I tried what you just said and I get the same sort of behaviour, I am still not able to get to the command line. This time I also saw a "systemctl Tainted"  (see 2.txt log). I am starting to think this issue may not be related to udev specifically? Could it have something to do with the:
    [FAILED] Failed to start Synchronize System and HW clocks.
    Logs:
    [    2.709504] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.963756] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    2.971614] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    2.971628] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    2.971638] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    2.971648] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [    3.040355] systemd[1]: Reached target Swap.
    [    3.069193] systemd[1]: Listening on udev Control Socket.
    [    3.297174] cmemk: loading out-of-tree module taints kernel.
    [    3.303853] CMEMK module: reference Linux version 4.9.28
    [    3.313733] allocated heap buffer 0x40500000 of size 0x100000
    [    3.324744] cmemk initialized
             Starting Create list of required st... nodes for the current ker[    3.344215] cryptodev: driver 1.8 loaded.
    nel...
    [    3.345615] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.018415] systemd-journald[106]: Received request to flush runtime journal from PID 1
    See 'systemctl status sync-clocks.service' for details.
    [    5.845020] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    5.853170] pgd = ccf44000
    [    5.855885] [00000000] *pgd=00000000
    [    5.859487] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
    [    5.864820] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    5.874488] CPU: 0 PID: 169 Comm: udevadm Tainted: G           O    4.9.28-geed43d1050 #1
    [    5.882698] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    5.888815] task: ccdf2bc0 task.stack: cce9a000
    [    5.893371] PC is at __wake_up_common+0x28/0x94
    [    5.897918] LR is at __wake_up+0x40/0x54
    [    5.901857] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 60070093
    [    5.901857] sp : cce9bc98  ip : 00000000  fp : cce9bccc
    [    5.913382] r10: 00000003  r9 : 00000000  r8 : cce9bd04
    [    5.918626] r7 : c0c0211c  r6 : 00000003  r5 : a0070013  r4 : c0c02118
    [    5.925179] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02118
    [    5.931733] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    5.938983] Control: 10c5387d  Table: 8cf4406a  DAC: 00000051
    [    5.944750] Process udevadm (pid: 169, stack limit = 0xcce9a210)
    [    5.950778] Stack: (0xcce9bc98 to 0xcce9c000)
    [    5.955151] bc80:                                                       00000000 00000001
    [    5.963364] bca0: cce9bd2c c0c02118 a0070013 00000003 00000001 cce9bd04 cce9be38 00000000
    [    5.971576] bcc0: cce9bcfc cce9bcd0 c016eac4 c016e9fc cce9bd04 cce9bce0 c024709c c8c121d4
    [    5.979788] bce0: 00000003 cce9bd50 cd5a6dd0 00000000 cce9bd1c cce9bd00 c016ed18 c016ea90
    [    5.988001] bd00: c8c12168 c8c121d4 00000003 00000000 cce9bd34 cce9bd20 c016efbc c016ece4
    [    5.996213] bd20: c8c12168 c8c121b8 cce9bd4c cce9bd38 c024772c c016efa4 c8c12168 cd0a8a50
    [    6.004425] bd40: cce9bd74 cce9bd50 c0292680 c02476f8 5954104a 0db53159 cdb8afa0 cd0a8a50
    [    6.012636] bd60: cd7f83b8 cd5b1248 cce9bd94 cce9bd78 c02934d0 c02925b4 cd7f83b8 cd5b1248
    [    6.020848] bd80: cd5b12b8 cd5a6dd0 cce9bdd4 cce9bd98 c0236c28 c029346c cce9be0c 00000000
    [    6.029059] bda0: cce9bda0 cce9bda0 cce9be30 cce9be30 00000000 00000000 00000000 cce9bf10
    [    6.037270] bdc0: 00000000 00000000 cce9be0c cce9bdd8 c0237b88 c0236ba4 cce9be0c cce9bde8
    [    6.045482] bde0: c0238e3c cce9be30 cce9be30 00000000 cce9bf10 00000000 cce9bf10 00000000
    [    6.053694] be00: cce9be2c cce9be10 c023956c c0237990 00000000 ccfb0000 cce9be30 00000000
    [    6.061905] be20: cce9bedc cce9be30 c023baf4 c0239508 cd31dcd0 cd5a6dd0 ea7b3992 00000005
    [    6.070116] be40: ccfb0029 00000000 cd3326d0 cd547330 cd5b1248 00000000 c0292474 00000164
    [    6.078328] be60: 00000000 00000000 00000000 cce9be70 00000000 ccfb0000 cce9bf34 00000ff0
    [    6.086539] be80: c023bb14 ccfb0000 c0c03308 7f7f82d0 00000000 00000000 00000000 00000000
    [    6.094750] bea0: ccfb0000 00000000 c023b830 00000002 ffffff9c 00000000 ffffff9c 00000000
    [    6.102961] bec0: ffffff9c cce9bf10 7f7f82d0 cce9bf40 cce9bf04 cce9bee0 c023bc24 c023ba68
    [    6.111173] bee0: 00000000 00000000 00000000 bed9b640 00000000 ffffff9c cce9bf3c cce9bf08
    [    6.119385] bf00: c02318e0 c023bbe4 00000000 07270adf 59541047 07270adf bed9b640 7f7f82e9
    [    6.127596] bf20: 7f7f92d0 000000c4 c0108024 cce9a000 cce9bfa4 cce9bf40 c0231f2c c0231898
    [    6.135807] bf40: 000037c4 00000000 0000000e 000041ed 00000247 00000000 00000000 00000000
    [    6.144019] bf60: 00000000 00000000 59541047 07270adf 59541047 07270adf 59541047 07270adf
    [    6.152231] bf80: 00001000 00000063 00000000 00000000 cce9a000 7f7f82c6 00000000 cce9bfa8
    [    6.160443] bfa0: c0107e60 c0231f10 7f7f82c6 7f7f82e9 7f7f82d0 bed9b640 bed9b640 00000000
    [    6.168654] bfc0: 7f7f82c6 7f7f82e9 7f7f92d0 000000c4 7f7f82d0 0000001f 7f7f82c1 00000005
    [    6.176866] bfe0: 000000c4 bed9b61c b6e2d837 b6dbcab6 00070030 7f7f82d0 8fdee861 8fdeec61
    [    6.185073] Backtrace:
    [    6.187540] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.195229]  r10:00000000 r9:cce9be38 r8:cce9bd04 r7:00000001 r6:00000003 r5:a0070013
    [    6.203089]  r4:c0c02118
    [    6.205632] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.213059]  r8:00000000 r7:cd5a6dd0 r6:cce9bd50 r5:00000003 r4:c8c121d4
    [    6.219787] [<c016ecd8>] (__wake_up_bit) from [<c016efbc>] (wake_up_bit+0x24/0x28)
    [    6.227393] [<c016ef98>] (wake_up_bit) from [<c024772c>] (unlock_new_inode+0x40/0x64)
    [    6.235254]  r5:c8c121b8 r4:c8c12168
    [    6.238850] [<c02476ec>] (unlock_new_inode) from [<c0292680>] (kernfs_get_inode+0xd8/0x12c)
    [    6.247234]  r5:cd0a8a50 r4:c8c12168
    [    6.250826] [<c02925a8>] (kernfs_get_inode) from [<c02934d0>] (kernfs_iop_lookup+0x70/0xa4)
    [    6.259211]  r6:cd5b1248 r5:cd7f83b8 r4:cd0a8a50
    [    6.263850] [<c0293460>] (kernfs_iop_lookup) from [<c0236c28>] (lookup_slow+0x90/0x144)
    [    6.271885]  r7:cd5a6dd0 r6:cd5b12b8 r5:cd5b1248 r4:cd7f83b8
    [    6.277568] [<c0236b98>] (lookup_slow) from [<c0237b88>] (walk_component+0x204/0x2d0)
    [    6.285430]  r10:00000000 r9:00000000 r8:cce9bf10 r7:00000000 r6:00000000 r5:00000000
    [    6.293290]  r4:cce9be30
    [    6.295833] [<c0237984>] (walk_component) from [<c023956c>] (path_lookupat+0x70/0x11c)
    [    6.303782]  r9:00000000 r8:cce9bf10 r7:00000000 r6:cce9bf10 r5:00000000 r4:cce9be30
    [    6.311560] [<c02394fc>] (path_lookupat) from [<c023baf4>] (filename_lookup+0x98/0xf4)
    [    6.319507]  r7:00000000 r6:cce9be30 r5:ccfb0000 r4:00000000
    [    6.325189] [<c023ba5c>] (filename_lookup) from [<c023bc24>] (user_path_at_empty+0x4c/0x54)
    [    6.333574]  r8:cce9bf40 r7:7f7f82d0 r6:cce9bf10 r5:ffffff9c r4:00000000
    [    6.340307] [<c023bbd8>] (user_path_at_empty) from [<c02318e0>] (vfs_fstatat+0x54/0xa8)
    [    6.348342]  r6:ffffff9c r5:00000000 r4:bed9b640
    [    6.352980] [<c023188c>] (vfs_fstatat) from [<c0231f2c>] (SyS_lstat64+0x28/0x44)
    [    6.360406]  r9:cce9a000 r8:c0108024 r7:000000c4 r6:7f7f92d0 r5:7f7f82e9 r4:bed9b640
    [    6.368189] [<c0231f04>] (SyS_lstat64) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    6.375961]  r4:7f7f82c6
    [    6.378505] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    6.384626] ---[ end trace aebc1b7e20905d9b ]---
    [    6.389263] note: udevadm[169] exited with preempt_count 2
    [    6.395367] Unable to handle kernel paging request at virtual address c8c08214
    [    6.397230] Unable to handle kernel paging request at virtual address c8c08214
    [    6.397233] pgd = ccf44000
    [    6.397240] [c8c08214] *pgd=88c1141e(bad)
    [    6.397246] Internal error: Oops: 8000000d [#2] PREEMPT SMP ARM
    [    6.397263] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.397269] CPU: 0 PID: 78 Comm: mmcqd/0 Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    6.397271] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.397275] task: cd28be80 task.stack: cd3b6000
    [    6.397279] PC is at 0xc8c08214
    [    6.397285] LR is at do_PrefetchAbort+0x40/0xa8
    [    6.397290] pc : [<c8c08214>]    lr : [<c01013cc>]    psr: 20070193
    [    6.397290] sp : cd3b7a88  ip : c0c081c4  fp : cd3b7b34
    [    6.397293] r10: 00000003  r9 : cd3b6000  r8 : cd3b7b38
    [    6.397296] r7 : 00000000  r6 : c8c08214  r5 : 00000005  r4 : c0c08214
    [    6.397299] r3 : 00000005  r2 : cd3b7b38  r1 : 80000005  r0 : 00000000
    [    6.397303] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.397306] Control: 10c5387d  Table: 8cf4406a  DAC: 00000051
    [    6.397308] Process mmcqd/0 (pid: 78, stack limit = 0xcd3b6210)
    [    6.397312] Stack: (0xcd3b7a88 to 0xcd3b8000)
    [    6.397317] 7a80:                   c03c9c9c c010fc54 ffff8d4f cda89a00 cd3b7adc cd3b7aa8
    [    6.397324] 7aa0: c04afb50 c03c9c7c c099d93c 0c9b5671 00000000 00000001 cda89a00 c0c224f0
    [    6.397330] 7ac0: 00000000 cd808000 cd3b6000 c0864f58 cd3b7afc cd3b7ae0 c0180b8c c0183660
    [    6.397336] 7ae0: cd28bf00 00000004 cda89a00 cda89a60 cd3b7b0c cd3b7b00 c0183ad8 c03fa4e4
    [    6.397342] 7b00: cd3b7b1c cd3b7b10 c0183ad8 c0183ac8 cd3b7b3c 00000000 20070193 ffffffff
    [    6.397347] 7b20: cd3b7b6c cd3b7c38 cd3b7c34 cd3b7b38 c010cca4 c0101398 ffffffff 00000037
    [    6.397353] 7b40: cd3b7c38 00000007 c0c08034 00000037 00000000 ffffffff cd3b7c38 cd3b6000
    [    6.397360] 7b60: 00000003 cd3b7c34 c0c07fc4 cd3b7b88 c010130c 00000000 20070193 ffffffff
    [    6.397366] 7b80: 00000051 bf000000 00000002 cd3b6000 cd3b7c2c cd3b7ba0 c010cb0c c01014d8
    [    6.397372] 7ba0: cd3b7ca0 7fffffff 00000002 00000000 7fffffff cd3b7ca0 cd3b7c9c c09fae88
    [    6.397377] 7bc0: 00000002 cd29b400 c0864f58 cd3b7c2c cd3b7bf0 cd3b7bf0 c07ca248 c07cd238
    [    6.397383] 7be0: cd3b7c2c cd3b7bf0 c07ca344 c07cd6ac cd28bf00 cfd80a78 00006e90 cd29b400
    [    6.397389] 7c00: cd29b400 cd3b7c8c cd3b7c8c cd3b7c8c cd3b7c9c c016ea18 60070193 ffffffff
    [    6.397395] 7c20: cd3b7c6c cd3b7cf4 cd3b7cbc cd3b7c38 c010ca78 c01012d4 c0c02b50 00000003
    [    6.397401] 7c40: 00000001 00000000 c0c02b50 80070113 00000003 c0c02b54 cd3b7cf4 00000000
    [    6.397407] 7c60: 00000003 cd3b7cbc ffffffff cd3b7c88 c016eac4 c016ea18 60070193 ffffffff
    [    6.397412] 7c80: 00000051 00000000 c03c9c9c 00000001 c0c79dd8 c0c02b50 80070113 00000003
    [    6.397418] 7ca0: 00000001 cd3b7cf4 cd3fd480 cd3bbc54 cd3b7cec cd3b7cc0 c016eac4 c016e9fc
    [    6.397424] 7cc0: cd3b7cf4 cd3b7cd0 c01e4b10 ce317b90 cd688d40 00000000 00000000 00001000
    [    6.397430] 7ce0: cd3b7d0c cd3b7cf0 c016ed18 c016ea90 00000000 ce317b90 0000000d 00000000
    [    6.397436] 7d00: cd3b7d24 cd3b7d10 c01d73c4 c016ece4 cd688d40 cd688d40 cd3b7d74 cd3b7d28
    [    6.397442] 7d20: c02ac28c c01d7358 00000000 c09a8344 c0c1d604 c081367c 00070113 ffffe000
    [    6.397448] 7d40: 00000006 ce317b90 c0180268 cd3fd480 cd6ed030 00000000 00000000 00000000
    [    6.397454] 7d60: 00000000 00000000 cd3b7dbc cd3b7d78 c02ac6ac c02ac08c c0630838 ce1c0000
    [    6.397460] 7d80: 00000012 00000000 c0c07f34 00000012 cd3b7db4 cd3b7da0 cd3fd480 c03a1ee0
    [    6.397466] 7da0: 00100000 00000000 cd39e9f8 00000000 cd3b7dd4 cd3b7dc0 c03a1edc c02ac660
    [    6.397472] 7dc0: cd3fd480 00100000 cd3b7e0c cd3b7dd8 c03a7bec c03a1e48 00000001 cd3b7e9c
    [    6.397478] 7de0: cd3b7e0c cd39e9f8 00000000 00000000 00000000 cd29b830 00000000 cd3171d0
    [    6.397483] 7e00: cd3b7e2c cd3b7e10 c03a7e50 c03a7b34 cd39e9f8 cd39e9f8 cd3b0000 00000000
    [    6.397489] 7e20: cd3b7e54 cd3b7e30 c03a824c c03a7e40 cd39e9f8 cd29b954 cd074000 cd29b80c
    [    6.397495] 7e40: cd29b830 00000000 cd3b7e64 cd3b7e58 c03a829c c03a823c cd3b7ecc cd3b7e68
    [    6.397501] 7e60: c062b9cc c03a8294 cd3b7e94 cd3b7e78 c03c57dc c03a3e18 c09fcb64 00000000
    [    6.397507] 7e80: 00000000 cd3c0000 00000000 cd3b7e98 cd29b800 00000000 ffffffff 00000000
    [    6.397514] 7ea0: 0a43522c cd074000 cd29b80c cd3171d0 cd29b800 cd3b6000 cd29b800 cd29b400
    [    6.397519] 7ec0: cd3b7f1c cd3b7ed0 c062c7a8 c062b1bc cd3171d0 00000000 00000000 cd3b0000
    [    6.397525] 7ee0: cd3b7f04 cd3b7ef0 c03a8b54 00000000 cd3171d0 00000000 00000000 00000000
    [    6.397531] 7f00: cd3b0000 cd3b6000 cd3171d0 cd29b80c cd3b7f54 cd3b7f20 c062cc7c c062c63c
    [    6.397537] 7f20: ffffe000 cd29b814 00000000 00000000 cd39d0c0 cd3b6000 cd29b80c c062cb9c
    [    6.397543] 7f40: 00000000 00000000 cd3b7fac cd3b7f58 c014bb60 c062cba8 7feffefd 00000000
    [    6.397549] 7f60: eb78d4ea cd29b80c 00000000 00000000 cd3b7f70 cd3b7f70 00000000 00000000
    [    6.397555] 7f80: cd3b7f80 cd3b7f80 cd3b7fac cd39d0c0 c014ba60 00000000 00000000 00000000
    [    6.397561] 7fa0: 00000000 cd3b7fb0 c0107f18 c014ba6c 00000000 00000000 00000000 00000000
    [    6.397567] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.397573] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 fd5fbbfb fbfff9fe
    [    6.397576] Backtrace:
    [    6.397584] [<c010138c>] (do_PrefetchAbort) from [<c010cca4>] (__pabt_svc+0x64/0xa0)
    [    6.397586] Exception stack(0xcd3b7b38 to 0xcd3b7b80)
    [    6.397590] 7b20:                                                       ffffffff 00000037
    [    6.397596] 7b40: cd3b7c38 00000007 c0c08034 00000037 00000000 ffffffff cd3b7c38 cd3b6000
    [    6.397602] 7b60: 00000003 cd3b7c34 c0c07fc4 cd3b7b88 c010130c 00000000 20070193 ffffffff
    [    6.397607]  r8:cd3b7c38 r7:cd3b7b6c r6:ffffffff r5:20070193 r4:00000000
    [    6.397613] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    6.397616] Exception stack(0xcd3b7c38 to 0xcd3b7c80)
    [    6.397620] 7c20:                                                       c0c02b50 00000003
    [    6.397625] 7c40: 00000001 00000000 c0c02b50 80070113 00000003 c0c02b54 cd3b7cf4 00000000
    [    6.397631] 7c60: 00000003 cd3b7cbc ffffffff cd3b7c88 c016eac4 c016ea18 60070193 ffffffff
    [    6.397636]  r8:cd3b7cf4 r7:cd3b7c6c r6:ffffffff r5:60070193 r4:c016ea18
    [    6.397641] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.397646]  r10:cd3bbc54 r9:cd3fd480 r8:cd3b7cf4 r7:00000001 r6:00000003 r5:80070113
    [    6.397649]  r4:c0c02b50
    [    6.397654] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.397659]  r8:00001000 r7:00000000 r6:00000000 r5:cd688d40 r4:ce317b90
    [    6.397673] [<c016ecd8>] (__wake_up_bit) from [<c01d73c4>] (end_page_writeback+0x78/0x80)
    [    6.397682] [<c01d734c>] (end_page_writeback) from [<c02ac28c>] (ext4_finish_bio+0x20c/0x250)
    [    6.397685]  r5:cd688d40 r4:cd688d40
    [    6.397690] [<c02ac080>] (ext4_finish_bio) from [<c02ac6ac>] (ext4_end_bio+0x58/0x12c)
    [    6.397696]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:cd6ed030
    [    6.397698]  r4:cd3fd480
    [    6.397711] [<c02ac654>] (ext4_end_bio) from [<c03a1edc>] (bio_endio+0xa0/0xa4)
    [    6.397717]  r9:00000000 r8:cd39e9f8 r7:00000000 r6:00100000 r5:c03a1ee0 r4:cd3fd480
    [    6.397726] [<c03a1e3c>] (bio_endio) from [<c03a7bec>] (blk_update_request+0xc4/0x30c)
    [    6.397729]  r5:00100000 r4:cd3fd480
    [    6.397736] [<c03a7b28>] (blk_update_request) from [<c03a7e50>] (blk_update_bidi_request+0x1c/0x74)
    [    6.397741]  r10:cd3171d0 r9:00000000 r8:cd29b830 r7:00000000 r6:00000000 r5:00000000
    [    6.397743]  r4:cd39e9f8
    [    6.397750] [<c03a7e34>] (blk_update_bidi_request) from [<c03a824c>] (blk_end_bidi_request+0x1c/0x58)
    [    6.397753]  r7:00000000 r6:cd3b0000 r5:cd39e9f8 r4:cd39e9f8
    [    6.397760] [<c03a8230>] (blk_end_bidi_request) from [<c03a829c>] (blk_end_request+0x14/0x18)
    [    6.397765]  r9:00000000 r8:cd29b830 r7:cd29b80c r6:cd074000 r5:cd29b954 r4:cd39e9f8
    [    6.397774] [<c03a8288>] (blk_end_request) from [<c062b9cc>] (mmc_blk_issue_rw_rq+0x81c/0xacc)
    [    6.397780] [<c062b1b0>] (mmc_blk_issue_rw_rq) from [<c062c7a8>] (mmc_blk_issue_rq+0x178/0x56c)
    [    6.397786]  r10:cd29b400 r9:cd29b800 r8:cd3b6000 r7:cd29b800 r6:cd3171d0 r5:cd29b80c
    [    6.397788]  r4:cd074000
    [    6.397795] [<c062c630>] (mmc_blk_issue_rq) from [<c062cc7c>] (mmc_queue_thread+0xe0/0x190)
    [    6.397800]  r10:cd29b80c r9:cd3171d0 r8:cd3b6000 r7:cd3b0000 r6:00000000 r5:00000000
    [    6.397803]  r4:00000000
    [    6.397814] [<c062cb9c>] (mmc_queue_thread) from [<c014bb60>] (kthread+0x100/0x118)
    [    6.397820]  r10:00000000 r9:00000000 r8:c062cb9c r7:cd29b80c r6:cd3b6000 r5:cd39d0c0
    [    6.397822]  r4:00000000
    [    6.397829] [<c014ba60>] (kthread) from [<c0107f18>] (ret_from_fork+0x14/0x3c)
    [    6.397834]  r8:00000000 r7:00000000 r6:00000000 r5:c014ba60 r4:cd39d0c0
    [    6.397840] Code: c8c08200 00000000 00000000 00000000 (c8c08214)
    [    6.397845] ---[ end trace aebc1b7e20905d9c ]---
    [    6.397852] note: mmcqd/0[78] exited with preempt_count 1
    [    7.206088] pgd = ccdac000
    [    7.208802] [c8c08214] *pgd=88c1141e(bad)
    [    7.212844] Internal error: Oops: 8000000d [#3] PREEMPT SMP ARM
    [    7.218786] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    7.228445] CPU: 1 PID: 106 Comm: systemd-journal Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    7.237352] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.243469] task: ccdf12c0 task.stack: ccdda000
    [    7.248015] PC is at 0xc8c08214
    [    7.251169] LR is at do_PrefetchAbort+0x40/0xa8
    [    7.255716] pc : [<c8c08214>]    lr : [<c01013cc>]    psr: 200f0193
    [    7.255716] sp : ccddbe00  ip : c0c081c4  fp : ccddbeac
    [    7.267241] r10: 00000074  r9 : ccdda000  r8 : ccddbeb0
    [    7.272485] r7 : 00000000  r6 : c8c08214  r5 : 00000005  r4 : c0c08214
    [    7.279038] r3 : 00000005  r2 : ccddbeb0  r1 : 80000005  r0 : 00000000
    [    7.285590] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.292841] Control: 10c5387d  Table: 8cdac06a  DAC: 00000051
    [    7.298608] Process systemd-journal (pid: 106, stack limit = 0xccdda210)
    [    7.305335] Stack: (0xccddbe00 to 0xccddc000)
    [    7.309712] be00: ccddbe2c ccddbe10 c03d6e80 c03d6920 4deddf6b ccddbe34 c0693b6c 00000000
    [    7.317925] be20: ccddbe74 ccddbe38 c017d46c c03d6e64 c099d3fc 00000000 000000ef 00000000
    [    7.326139] be40: 0059689f cce04054 0000002d c0c16e30 cce04000 cce04000 0000003d cce0402c
    [    7.334350] be60: 000000f0 bead06a0 ccddbed4 ccddbe78 c017d5b4 c07cb388 c0c59448 0000002c
    [    7.342563] be80: 00000000 00000019 bead06a0 00000000 600f0193 ffffffff ccddbee4 ccddbfb0
    [    7.350775] bea0: ccddbfac ccddbeb0 c010cca4 c0101398 b6634000 00000817 ccddbfb0 00000007
    [    7.358987] bec0: c0c08034 00000817 00000000 b6634000 ccddbfb0 beacee48 00000074 ccddbfac
    [    7.367198] bee0: c0c07fc4 ccddbf00 c010130c 00000000 600f0193 ffffffff 00000051 bf000000
    [    7.375410] bf00: 7ca9c43f 00000107 c0108024 cd8e5e78 00000000 00000000 c0191228 00000000
    [    7.383622] bf20: cd3fe0c8 cd8e5e78 00000001 0000003d 00002000 00000000 ccddbf74 ccddbf48
    [    7.391834] bf40: c022cc48 c026c2fc 00000000 00000000 ccddbf74 cd3fe0c0 cd3fe0c0 00000000
    [    7.400046] bf60: 00000000 bead06a0 ccddbfa4 ccddbf78 c022da44 c022cb5c 00000000 00000000
    [    7.408258] bf80: 7f5d65f8 7f5a0f0c bead2748 7f5b1028 200f0010 ffffffff 10c5387d 10c5387d
    [    7.416471] bfa0: 00000000 ccddbfb0 c010cea0 c01012d4 00000000 b6634000 beaced68 0000a355
    [    7.424683] bfc0: 7f5d73c8 00000001 00802c70 00000000 beacee58 beacee48 00000074 00000000
    [    7.432895] bfe0: 00000000 beaced28 7f5ae1e4 7f5b1028 200f0010 ffffffff 52098000 48002600
    [    7.441103] Backtrace:
    [    7.443568] [<c010138c>] (do_PrefetchAbort) from [<c010cca4>] (__pabt_svc+0x64/0xa0)
    [    7.451341] Exception stack(0xccddbeb0 to 0xccddbef8)
    [    7.456413] bea0:                                     b6634000 00000817 ccddbfb0 00000007
    [    7.464626] bec0: c0c08034 00000817 00000000 b6634000 ccddbfb0 beacee48 00000074 ccddbfac
    [    7.472836] bee0: c0c07fc4 ccddbf00 c010130c 00000000 600f0193 ffffffff
    [    7.479478]  r8:ccddbfb0 r7:ccddbee4 r6:ffffffff r5:600f0193 r4:00000000
    [    7.486208] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    7.493632] Exception stack(0xccddbfb0 to 0xccddbff8)
    [    7.498702] bfa0:                                     00000000 b6634000 beaced68 0000a355
    [    7.506915] bfc0: 7f5d73c8 00000001 00802c70 00000000 beacee58 beacee48 00000074 00000000
    [    7.515125] bfe0: 00000000 beaced28 7f5ae1e4 7f5b1028 200f0010 ffffffff
    [    7.521767]  r8:10c5387d r7:10c5387d r6:ffffffff r5:200f0010 r4:7f5b1028
    [    7.528496] Code: c8c08200 00000000 00000000 00000000 (c8c08214)
    [    7.534614] ---[ end trace aebc1b7e20905d9d ]---
    [    2.499457] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.751327] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    2.759188] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    2.766888] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    2.774358] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    2.783835] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [    2.830515] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.885990] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.186065] cmemk: loading out-of-tree module taints kernel.
    [    3.192780] CMEMK module: reference Linux version 4.9.28
             [    3.202730] allocated heap buffer 0x40500000 of size 0x100000
    [    3.209091] cmemk initialized
    [    3.225657] cryptodev: driver 1.8 loaded.
    [    3.294361] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.818956] systemd-journald[101]: Received request to flush runtime journal from PID 1
    [  OK  ] Started udev Coldplug all Devices.
    [    6.470069] Unable to handle kernel paging request at virtual address 2d616d64
    [    6.470507] Unable to handle kernel paging request at virtual address 2d616d64
    [    6.470512] pgd = cce80000
    [    6.470517] [2d616d64] *pgd=00000000
    [    6.470527] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
    [    6.470546] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.470554] CPU: 0 PID: 158 Comm: systemctl Tainted: G           O
    [    6.470557] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.470560] task: ccdf9f40 task.stack: cceca000
    [    6.470572] PC is at kmem_cache_alloc+0x38/0x1a4
    [    6.470580] LR is at alloc_buffer_head+0x20/0xa0
    [    6.470584] pc : [<c021cf44>]    lr : [<c025efcc>]    psr: 200f0113
    [    6.470584] sp : ccecb7f0  ip : ccecb818  fp : ccecb814
    [    6.470587] r10: ce357568  r9 : 02400040  r8 : 00001000
    [    6.470590] r7 : ccecb7f0  r6 : cceca000  r5 : 02408040  r4 : 2d616d64
    [    6.470593] r3 : 00000001  r2 : 00000000  r1 : 02408040  r0 : 2d616d64
    [    6.470598] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.470601] Control: 10c5387d  Table: 8ce8006a  DAC: 00000051
    [    6.470604] Process systemctl (pid: 158, stack limit = 0xcceca210)
    [    6.470607] Stack: (0xccecb7f0 to 0xccecc000)
    [    6.470612] b7e0:                                     00000000 00000000 ce357568 00000000
    [    6.470617] b800: 00001000 02400040 ccecb82c ccecb818 c025efcc c021cf18 00000000 00000000
    [    6.470622] b820: ccecb86c ccecb830 c02600a8 c025efb8 00000000 00000000 00001000 02400040
    [    6.470627] b840: fe10d914 00000000 00001000 ce357568 00000001 00190205 00000000 cd448088
    [    6.470632] b860: ccecb8cc ccecb870 c0260438 c0260040 00001000 65027f00 00000000 00000000
    [    6.470637] b880: 00000808 00000000 ffffffe0 00000000 00000020 cd448000 00190205 00000000
    [    6.470642] b8a0: 00000000 ccecb994 ccecb988 00000000 00000001 ccecb958 cd8e1000 cd6e6b50
    [    6.470646] b8c0: ccecb904 ccecb8d0 c02d66d8 c0260264 00001000 00000008 4800b010 ccecbae0
    [    6.470651] b8e0: 00000000 00000000 00000000 00000000 cd6e6b50 00000000 ccecba1c ccecb908
    [    6.470655] b900: c02d713c c02d6638 ccecb94c 00000000 8000b000 cc202100 48c02800 00000000
    [    6.470660] b920: 00000000 00000000 00000000 00000000 00000000 00000000 c0004900 00000002
    [    6.470664] b940: ccecbae0 00000000 0800c000 00000000 00000387 00000000 0000000c 00000078
    [    6.470669] b960: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.470673] b980: 00000000 00000002 cd6e6ad0 00190205 00000000 00000084 ccecb9b4 ccecb9a8
    [    6.470678] b9a0: c03d030c c021cf18 00003884 ce2fb024 cd80b400 00000000 00000000 cd6e6c3c
    [    6.470683] b9c0: 00000084 00000000 ccecba1c ccecb9d8 c0227bf0 c0223ca0 00000084 00000000
    [    6.470688] b9e0: ccecba1c ccecb9f0 c01d5578 c03d0de0 ccecba1c ccecbae0 00000001 cd6e6b50
    [    6.470692] ba00: 00000000 00000000 cd6e6b20 00000000 ccecba84 ccecba20 c02a4a10 c02d70b4
    [    6.470697] ba20: 00000000 ccecba30 c0154fe4 cd80b400 ce2fb024 024213ca ccecba54 ccecba48
    [    6.470701] ba40: c01e6d44 00000000 00000000 ccecba58 00000000 00000000 ccecba64 00000000
    [    6.470706] ba60: 00000001 00000084 00000000 ce2fb024 00000001 00000000 ccecbb64 ccecba88
    [    6.470710] ba80: c02e0954 c02a4648 c02e0538 024000c0 c0c83e54 cd448000 00001000 00000000
    [    6.470715] baa0: 00000000 00000000 c02a4cac cd6e6c3c 0000000c 00000000 ccecbb88 00000011
    [    6.470719] bac0: 00000011 cd6e6b50 00000001 ccecbad8 c01765a0 cd334568 00000095 00000000
    [    6.470724] bae0: 00000000 00000000 00000084 00000011 00000000 c016ea90 ccecbb2c ccecbb08
    [    6.470729] bb00: 024213ca c0619e88 cd29b700 ffffffff c0c4c500 00000000 c0c4c500 00000001
    [    6.470733] bb20: 00000002 00000000 c0631ff4 c06199ac cd29b700 cd29b700 cd6e6b38 00000095
    [    6.470738] bb40: 00000011 c02a3a60 00000011 00000094 cd6e6c40 cd6e6c3c ccecbb74 ccecbb68
    [    6.470742] bb60: c02a3aa4 c02e05dc ccecbbd4 ccecbb78 c01e50a0 c02a3a6c 00000000 ccc54e40
    [    6.470747] bb80: cd6e6c3c 024213ca ce35853c ce2fb014 ccecbb90 ccecbb90 ccecbb98 ccecbb98
    [    6.470751] bba0: ccecbba0 ccecbba0 00000000 00000000 00000094 cd6e6b50 ccc54e40 00000094
    [    6.470756] bbc0: 00000000 ccecbc5c ccecbc34 ccecbbd8 c01d9128 c01e4f08 00000008 ce3903d0
    [    6.470760] bbe0: 0000000c ce3903d0 ccecbc8c ccecbbf8 c01de708 c0118aa4 00000094 00000000
    [    6.470765] bc00: ccf18948 cd6e6c3c ccecbc34 cd6e6b38 ccf18948 ccecbc5c ccf18948 00000094
    [    6.470769] bc20: ce365fb0 00000000 ccecbc54 ccecbc38 c02abedc c01d8e0c 00000000 ccecbca8
    [    6.470774] bc40: 00000015 ccf18948 ccecbc94 ccecbc58 c0200138 c02abeb4 ce365fb0 00000015
    [    6.470778] bc60: 024200ca 00000094 7f6a7000 ce365fb0 00000000 024000c0 ccecbcb4 ccecbcb4
    [    6.470783] bc80: ccf18948 00000000 ccecbcfc ccecbc98 c02042b4 c02000d4 ccecbcac ccecbcb8
    [    6.470787] bca0: ccecbcf0 04c449b4 ccecbce4 ccecbcb8 cd80b400 ccf18948 7f6a7000 00000015
    [    6.470791] bcc0: cce81fd8 00000000 00000000 00000000 ccecbcfc ccecbe20 ccdf9f40 cd3dac40
    [    6.470796] bce0: 00000805 7f6a75a0 cd3dac78 00000015 ccecbd4c ccecbd00 c0115e40 c02039ec
    [    6.470801] bd00: cd6e6c3c ccf18948 ccecbd34 ccecbd18 c0206620 c07cd6ac 00000800 ccf18948
    [    6.470805] bd20: cd6e6c54 00000805 00000805 c0115fb8 7f6a75a0 ccecbe20 cceca000 ccecbe90
    [    6.470810] bd40: ccecbd6c ccecbd50 c011606c c0115bc8 c0c08014 00000805 c0115fb8 7f6a75a0
    [    6.470815] bd60: ccecbe1c ccecbd70 c010130c c0115fc4 00000000 c0117194 7f6a4000 c0c50dd8
    [    6.470819] bd80: 00000800 ccf18948 ccf18948 00000004 ccc54e40 00100873 00004000 ccc54e40
    [    6.470824] bda0: ccecbdcc 00004000 7f6a4000 00000003 ccc54e40 cd3dac40 00000004 00000873
    [    6.470829] bdc0: ccecbe0c ccecbdd0 c0209e34 c0209480 00000091 00000106 00000000 00000000
    [    6.470834] bde0: 00000000 cd3dac78 ccc54e40 7f6a4000 00004000 00000003 0009119c c03c8a24
    [    6.470838] be00: 200f0113 ffffffff ccecbe54 7f6a75a0 ccecbe8c ccecbe20 c010ca78 c01012d4
    [    6.470843] be20: 7f6a75a0 00000a58 00000000 00000055 00000051 ccc36a00 00000000 7f6a7f63
    [    6.470847] be40: 7f6a75a0 ccef4c00 ccecbe90 ccecbe8c 00000000 ccecbe70 c0382678 c03c8a24
    [    6.470851] be60: 200f0113 ffffffff 00000055 bf000000 00000a60 c0382678 ccdc4a80 ccc36a00
    [    6.470856] be80: ccecbf14 ccecbe90 c027cdc0 c0382624 00001812 00000000 ce31ee50 00000005
    [    6.470861] bea0: ccecbe90 7f555554 ccc36a00 fffff000 7f6a75a0 7f612000 00092818 0009119c
    [    6.470865] bec0: 00000000 7f612000 ccef4c00 ccf89540 ccf896c0 cce765c0 ccecbf04 ccecbee8
    [    6.470870] bee0: c0238274 c023809c cd8d9000 c0c1d118 ccc36a00 c0c1cc48 fffffff8 c0c7fd8c
    [    6.470874] bf00: 00000001 cd3dac40 ccecbf3c ccecbf18 c0232ffc c027c654 cd8d9000 ccdf9f40
    [    6.470879] bf20: ffffe000 0000009e ccc36a00 00000000 ccecbf84 ccecbf40 c023429c c0232f7c
    [    6.470883] bf40: c023b830 c0c50dd8 cd3dac78 cce56948 7f7412e0 00000000 0000000b 7f6da420
    [    6.470887] bf60: 7f7412e0 7f6dad6e 0000000b c0108024 cceca000 00000000 ccecbfa4 ccecbf88
    [    6.470892] bf80: c0234604 c0233d74 00000000 00000000 7f7412b0 00000000 00000000 ccecbfa8
    [    6.470896] bfa0: c0107e60 c02345d8 7f7412b0 00000000 7f735a20 7f6da420 7f7412e0 7f737458
    [    6.470902] bfc0: 7f7412b0 00000000 7f6dad6e 0000000b 7f6da420 00000000 be950518 be95045c
    [    6.470906] bfe0: 7f6d5c0c be950214 7f5a194c b6e49f26 20030030 7f735a20 52508000 48102600
    [    6.470909] Backtrace:
    [    6.470917] [<c021cf0c>] (kmem_cache_alloc) from [<c025efcc>] (alloc_buffer_head+0x20/0xa0)
    [    6.470923]  r9:02400040 r8:00001000 r7:00000000 r6:ce357568 r5:00000000 r4:00000000
    [    6.470930] [<c025efac>] (alloc_buffer_head) from [<c02600a8>] (alloc_page_buffers+0x74/0xcc)
    [    6.470933]  r5:00000000 r4:00000000
    [    6.470940] [<c0260034>] (alloc_page_buffers) from [<c0260438>] (__getblk_gfp+0x1e0/0x36c)
    [    6.470945]  r10:cd448088 r9:00000000 r8:00190205 r7:00000001 r6:ce357568 r5:00001000
    [    6.470946]  r4:00000000
    [    6.470956] [<c0260258>] (__getblk_gfp) from [<c02d66d8>] (ext4_get_branch+0xac/0x160)
    [    6.470960]  r10:cd6e6b50 r9:cd8e1000 r8:ccecb958 r7:00000001 r6:00000000 r5:ccecb988
    [    6.470962]  r4:ccecb994
    [    6.470967] [<c02d662c>] (ext4_get_branch) from [<c02d713c>] (ext4_ind_map_blocks+0x94/0x9f8)
    [    6.470971]  r10:00000000 r9:cd6e6b50 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    [    6.470973]  r4:ccecbae0
    [    6.470990] [<c02d70a8>] (ext4_ind_map_blocks) from [<c02a4a10>] (ext4_map_blocks+0x3d4/0x5a0)
    [    6.470994]  r10:00000000 r9:cd6e6b20 r8:00000000 r7:00000000 r6:cd6e6b50 r5:00000001
    [    6.470996]  r4:ccecbae0
    [    6.471008] [<c02a463c>] (ext4_map_blocks) from [<c02e0954>] (ext4_mpage_readpages+0x384/0x7d0)
    [    6.471012]  r10:00000000 r9:00000001 r8:ce2fb024 r7:00000000 r6:00000084 r5:00000001
    [    6.471014]  r4:00000000
    [    6.471020] [<c02e05d0>] (ext4_mpage_readpages) from [<c02a3aa4>] (ext4_readpages+0x44/0x48)
    [    6.471024]  r10:cd6e6c3c r9:cd6e6c40 r8:00000094 r7:00000011 r6:c02a3a60 r5:00000011
    [    6.471026]  r4:00000095
    [    6.471038] [<c02a3a60>] (ext4_readpages) from [<c01e50a0>] (__do_page_cache_readahead+0x1a4/0x26c)
    [    6.471052] [<c01e4efc>] (__do_page_cache_readahead) from [<c01d9128>] (filemap_fault+0x328/0x654)
    [    6.471056]  r10:ccecbc5c r9:00000000 r8:00000094 r7:ccc54e40 r6:cd6e6b50 r5:00000094
    [    6.471058]  r4:00000000
    [    6.471066] [<c01d8e00>] (filemap_fault) from [<c02abedc>] (ext4_filemap_fault+0x34/0x48)
    [    6.471071]  r10:00000000 r9:ce365fb0 r8:00000094 r7:ccf18948 r6:ccecbc5c r5:ccf18948
    [    6.471072]  r4:cd6e6b38
    [    6.471081] [<c02abea8>] (ext4_filemap_fault) from [<c0200138>] (__do_fault+0x70/0xf0)
    [    6.471084]  r7:ccf18948 r6:00000015 r5:ccecbca8 r4:00000000
    [    6.471090] [<c02000c8>] (__do_fault) from [<c02042b4>] (handle_mm_fault+0x8d4/0xcd8)
    [    6.471093]  r6:00000000 r5:ccf18948 r4:ccecbcb4
    [    6.471101] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    6.471106]  r10:00000015 r9:cd3dac78 r8:7f6a75a0 r7:00000805 r6:cd3dac40 r5:ccdf9f40
    [    6.471108]  r4:ccecbe20
    [    6.471113] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    6.471117]  r10:ccecbe90 r9:cceca000 r8:ccecbe20 r7:7f6a75a0 r6:c0115fb8 r5:00000805
    [    6.471119]  r4:00000805
    [    6.471124] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.471128]  r7:7f6a75a0 r6:c0115fb8 r5:00000805 r4:c0c08014
    [    6.471134] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    6.471137] Exception stack(0xccecbe20 to 0xccecbe68)
    [    6.471142] be20: 7f6a75a0 00000a58 00000000 00000055 00000051 ccc36a00 00000000 7f6a7f63
    [    6.471146] be40: 7f6a75a0 ccef4c00 ccecbe90 ccecbe8c 00000000 ccecbe70 c0382678 c03c8a24
    [    6.471149] be60: 200f0113 ffffffff
    [    6.471153]  r8:7f6a75a0 r7:ccecbe54 r6:ffffffff r5:200f0113 r4:c03c8a24
    [    6.471162] [<c0382618>] (padzero) from [<c027cdc0>] (load_elf_binary+0x778/0x1228)
    [    6.471165]  r5:ccc36a00 r4:ccdc4a80
    [    6.471174] [<c027c648>] (load_elf_binary) from [<c0232ffc>] (search_binary_handler+0x8c/0x1ec)
    [    6.471179]  r10:cd3dac40 r9:00000001 r8:c0c7fd8c r7:fffffff8 r6:c0c1cc48 r5:ccc36a00
    [    6.471181]  r4:c0c1d118
    [    6.471187] [<c0232f70>] (search_binary_handler) from [<c023429c>] (do_execveat_common+0x534/0x630)
    [    6.471191]  r9:00000000 r8:ccc36a00 r7:0000009e r6:ffffe000 r5:ccdf9f40 r4:cd8d9000
    [    6.471198] [<c0233d68>] (do_execveat_common) from [<c0234604>] (SyS_execve+0x38/0x40)
    [    6.471202]  r10:00000000 r9:cceca000 r8:c0108024 r7:0000000b r6:7f6dad6e r5:7f7412e0
    [    6.471204]  r4:7f6da420
    [    6.471214] [<c02345cc>] (SyS_execve) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    6.471216]  r5:00000000 r4:7f7412b0
    [    6.471222] Code: e3c6603f e5963004 e2833001 e5863004 (e5943000)
    [    6.471227] ---[ end trace c1fd7a2253735c5a ]---
    [    6.471238] note: systemctl[158] exited with preempt_count 1
    [    6.471367] Unable to handle kernel NULL pointer dereference at virtual address 00000051
    [    6.471370] pgd = c0004000
    [    6.471373] [00000051] *pgd=00000000
    [    6.471377] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
    [    6.471391] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.471395] CPU: 0 PID: 158 Comm: systemctl Tainted: G      D    O
    [    6.471397] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.471399] task: ccdf9f40 task.stack: cceca000
    [    6.471403] PC is at kmem_cache_free+0x1c/0x1e8
    [    6.471413] LR is at sock_destroy_inode+0x34/0x38
    [    6.471416] pc : [<c021c380>]    lr : [<c0693318>]    psr: 800f0113
    [    6.471416] sp : ccecb428  ip : ccecb458  fp : ccecb454
    [    6.471419] r10: 00080060  r9 : cd580088  r8 : 00000001
    [    6.471421] r7 : c086e290  r6 : c086e290  r5 : cd610e00  r4 : 0000004d
    [    6.471424] r3 : c0c03d68  r2 : 00002710  r1 : cd610e00  r0 : 0000004d
    [    6.471427] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.471429] Control: 10c5387d  Table: 8ce8006a  DAC: 00000051
    [    6.471432] Process systemctl (pid: 158, stack limit = 0xcceca210)
    [    6.471434] Stack: (0xccecb428 to 0xccecc000)
    [    6.471438] b420:                   cd610e20 cd610e70 cd610e20 cd610e70 c086e290 c086e290
    [    6.471443] b440: 00000001 cd580088 ccecb46c ccecb458 c0693318 c021c370 cd610e20 cd610e70
    [    6.471447] b460: ccecb484 ccecb470 c0248178 c06932f0 cd610e20 cd610e70 ccecb4a4 ccecb488
    [    6.471452] b480: c02482ac c0248144 cd8c1800 cd610e20 cd610e70 c086e290 ccecb4c4 ccecb4a8
    [    6.471456] b4a0: c02484f8 c02481a0 cd580088 cd610e20 cd5800d8 00080040 ccecb4e4 ccecb4c8
    [    6.471461] b4c0: c0242754 c02483c0 cd580088 00000000 cd580088 00000000 ccecb504 ccecb4e8
    [    6.471465] b4e0: c02440b4 c0242684 cd580088 c09a4d80 cd5800d8 00080040 ccecb53c ccecb508
    [    6.471470] b500: c0244400 c0244008 ccecb52c cd610e20 ccdd53c0 ccdd53c0 cd610e20 cd580088
    [    6.471475] b520: cd863250 00000000 cd610e20 00000008 ccecb57c ccecb540 c022e5f8 c0244184
    [    6.471479] b540: 00000020 00000000 ccecb564 ccdd53c8 ccecb57c ccdfa404 c0c51780 ccdfa420
    [    6.471484] b560: ccdf9f40 cccb7600 cd3dac78 c0991644 ccecb58c ccecb580 c022e700 c022e4d0
    [    6.471489] b580: ccecb5b4 ccecb590 c014a058 c022e6fc ccdf9f40 ccdfa41c cceca000 ccecb5c0
    [    6.471493] b5a0: c021cf46 cd3dac78 ccecb5dc ccecb5b8 c0132290 c0149fa0 c021cf46 00000000
    [    6.471498] b5c0: ccecb5dc ccecb5d0 c012e47c 00000001 ccecb664 ccecb5e0 c010c1f8 c0131f84
    [    6.471502] b5e0: cceca210 0000000b c099163c 00000008 bf000000 cceca000 00000000 600f0113
    [    6.471506] b600: 659915a4 36366333 20663330 36393565 34303033 38326520 30303333 35652031
    [    6.471511] b620: 30333638 28203430 34393565 30303033 c0002029 c01d4bfc c09915a4 2d616d64
    [    6.471516] b640: ccecb7a0 00000005 cd3dac40 2d616d64 cceca000 ce357568 ccecb67c ccecb668
    [    6.471520] b660: c011ac58 c010bfb8 ccecb7a0 00000005 ccecb6cc ccecb680 c0115f04 c011abf8
    [    6.471525] b680: c8801200 00000000 00000000 44009200 c060a000 00000000 80083608 04083008
    [    6.471530] b6a0: 80083a80 00000005 00000005 c0115fb8 2d616d64 ccecb7a0 cceca000 ce357568
    [    6.471535] b6c0: ccecb6ec ccecb6d0 c011606c c0115bc8 c0c08014 00000005 c0115fb8 2d616d64
    [    6.471539] b6e0: ccecb79c ccecb6f0 c010130c c0115fc4 ffffffff 00000001 80084400 00000000
    [    6.471543] b700: cfd839a4 c0b5abbc 00000001 00000000 02420848 00000000 200f0113 00000001
    [    6.471548] b720: 00000081 c0c4c500 00000000 00000000 00000081 02420848 cd448174 00190205
    [    6.471553] b740: 00000000 c0c0319c ccecb82c ccecb758 00003885 ce357568 cd80b400 00000000
    [    6.471557] b760: 00000000 cd448174 00190205 02493ee0 ccecb7c4 ccecb780 c0227bf0 c021cf44
    [    6.471562] b780: 200f0113 ffffffff ccecb7d4 00001000 ccecb814 ccecb7a0 c010ca78 c01012d4
    [    6.471566] b7a0: 2d616d64 02408040 00000000 00000001 2d616d64 02408040 cceca000 ccecb7f0
    [    6.471571] b7c0: 00001000 02400040 ce357568 ccecb814 ccecb818 ccecb7f0 c025efcc c021cf44
    [    6.471575] b7e0: 200f0113 ffffffff 00000051 bf000000 00000000 00000000 ce357568 00000000
    [    6.471580] b800: 00001000 02400040 ccecb82c ccecb818 c025efcc c021cf18 00000000 00000000
    [    6.471584] b820: ccecb86c ccecb830 c02600a8 c025efb8 00000000 00000000 00001000 02400040
    [    6.471589] b840: fe10d914 00000000 00001000 ce357568 00000001 00190205 00000000 cd448088
    [    6.471593] b860: ccecb8cc ccecb870 c0260438 c0260040 00001000 65027f00 00000000 00000000
    [    6.471598] b880: 00000808 00000000 ffffffe0 00000000 00000020 cd448000 00190205 00000000
    [    6.471603] b8a0: 00000000 ccecb994 ccecb988 00000000 00000001 ccecb958 cd8e1000 cd6e6b50
    [    6.471607] b8c0: ccecb904 ccecb8d0 c02d66d8 c0260264 00001000 00000008 4800b010 ccecbae0
    [    6.471612] b8e0: 00000000 00000000 00000000 00000000 cd6e6b50 00000000 ccecba1c ccecb908
    [    6.471616] b900: c02d713c c02d6638 ccecb94c 00000000 8000b000 cc202100 48c02800 00000000
    [    6.471621] b920: 00000000 00000000 00000000 00000000 00000000 00000000 c0004900 00000002
    [    6.471625] b940: ccecbae0 00000000 0800c000 00000000 00000387 00000000 0000000c 00000078
    [    6.471630] b960: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.471634] b980: 00000000 00000002 cd6e6ad0 00190205 00000000 00000084 ccecb9b4 ccecb9a8
    [    6.471639] b9a0: c03d030c c021cf18 00003884 ce2fb024 cd80b400 00000000 00000000 cd6e6c3c
    [    6.471643] b9c0: 00000084 00000000 ccecba1c ccecb9d8 c0227bf0 c0223ca0 00000084 00000000
    [    6.471648] b9e0: ccecba1c ccecb9f0 c01d5578 c03d0de0 ccecba1c ccecbae0 00000001 cd6e6b50
    [    6.471652] ba00: 00000000 00000000 cd6e6b20 00000000 ccecba84 ccecba20 c02a4a10 c02d70b4
    [    6.471657] ba20: 00000000 ccecba30 c0154fe4 cd80b400 ce2fb024 024213ca ccecba54 ccecba48
    [    6.471661] ba40: c01e6d44 00000000 00000000 ccecba58 00000000 00000000 ccecba64 00000000
    [    6.471667] ba60: 00000001 00000084 00000000 ce2fb024 00000001 00000000 ccecbb64 ccecba88
    [    6.471671] ba80: c02e0954 c02a4648 c02e0538 024000c0 c0c83e54 cd448000 00001000 00000000
    [    6.471676] baa0: 00000000 00000000 c02a4cac cd6e6c3c 0000000c 00000000 ccecbb88 00000011
    [    6.471680] bac0: 00000011 cd6e6b50 00000001 ccecbad8 c01765a0 cd334568 00000095 00000000
    [    6.471685] bae0: 00000000 00000000 00000084 00000011 00000000 c016ea90 ccecbb2c ccecbb08
    [    6.471690] bb00: 024213ca c0619e88 cd29b700 ffffffff c0c4c500 00000000 c0c4c500 00000001
    [    6.471694] bb20: 00000002 00000000 c0631ff4 c06199ac cd29b700 cd29b700 cd6e6b38 00000095
    [    6.471699] bb40: 00000011 c02a3a60 00000011 00000094 cd6e6c40 cd6e6c3c ccecbb74 ccecbb68
    [    6.471703] bb60: c02a3aa4 c02e05dc ccecbbd4 ccecbb78 c01e50a0 c02a3a6c 00000000 ccc54e40
    [    6.471707] bb80: cd6e6c3c 024213ca ce35853c ce2fb014 ccecbb90 ccecbb90 ccecbb98 ccecbb98
    [    6.471712] bba0: ccecbba0 ccecbba0 00000000 00000000 00000094 cd6e6b50 ccc54e40 00000094
    [    6.471717] bbc0: 00000000 ccecbc5c ccecbc34 ccecbbd8 c01d9128 c01e4f08 00000008 ce3903d0
    [    6.471721] bbe0: 0000000c ce3903d0 ccecbc8c ccecbbf8 c01de708 c0118aa4 00000094 00000000
    [    6.471726] bc00: ccf18948 cd6e6c3c ccecbc34 cd6e6b38 ccf18948 ccecbc5c ccf18948 00000094
    [    6.471731] bc20: ce365fb0 00000000 ccecbc54 ccecbc38 c02abedc c01d8e0c 00000000 ccecbca8
    [    6.471736] bc40: 00000015 ccf18948 ccecbc94 ccecbc58 c0200138 c02abeb4 ce365fb0 00000015
    [    6.471740] bc60: 024200ca 00000094 7f6a7000 ce365fb0 00000000 024000c0 ccecbcb4 ccecbcb4
    [    6.471745] bc80: ccf18948 00000000 ccecbcfc ccecbc98 c02042b4 c02000d4 ccecbcac ccecbcb8
    [    6.471749] bca0: ccecbcf0 04c449b4 ccecbce4 ccecbcb8 cd80b400 ccf18948 7f6a7000 00000015
    [    6.471754] bcc0: cce81fd8 00000000 00000000 00000000 ccecbcfc ccecbe20 ccdf9f40 cd3dac40
    [    6.471758] bce0: 00000805 7f6a75a0 cd3dac78 00000015 ccecbd4c ccecbd00 c0115e40 c02039ec
    [    6.471763] bd00: cd6e6c3c ccf18948 ccecbd34 ccecbd18 c0206620 c07cd6ac 00000800 ccf18948
    [    6.471767] bd20: cd6e6c54 00000805 00000805 c0115fb8 7f6a75a0 ccecbe20 cceca000 ccecbe90
    [    6.471772] bd40: ccecbd6c ccecbd50 c011606c c0115bc8 c0c08014 00000805 c0115fb8 7f6a75a0
    [    6.471777] bd60: ccecbe1c ccecbd70 c010130c c0115fc4 00000000 c0117194 7f6a4000 c0c50dd8
    [    6.471781] bd80: 00000800 ccf18948 ccf18948 00000004 ccc54e40 00100873 00004000 ccc54e40
    [    6.471786] bda0: ccecbdcc 00004000 7f6a4000 00000003 ccc54e40 cd3dac40 00000004 00000873
    [    6.471790] bdc0: ccecbe0c ccecbdd0 c0209e34 c0209480 00000091 00000106 00000000 00000000
    [    6.471794] bde0: 00000000 cd3dac78 ccc54e40 7f6a4000 00004000 00000003 0009119c c03c8a24
    [    6.471799] be00: 200f0113 ffffffff ccecbe54 7f6a75a0 ccecbe8c ccecbe20 c010ca78 c01012d4
    [    6.471803] be20: 7f6a75a0 00000a58 00000000 00000055 00000051 ccc36a00 00000000 7f6a7f63
    [    6.471808] be40: 7f6a75a0 ccef4c00 ccecbe90 ccecbe8c 00000000 ccecbe70 c0382678 c03c8a24
    [    6.471812] be60: 200f0113 ffffffff 00000055 bf000000 00000a60 c0382678 ccdc4a80 ccc36a00
    [    6.471817] be80: ccecbf14 ccecbe90 c027cdc0 c0382624 00001812 00000000 ce31ee50 00000005
    [    6.471821] bea0: ccecbe90 7f555554 ccc36a00 fffff000 7f6a75a0 7f612000 00092818 0009119c
    [    6.471826] bec0: 00000000 7f612000 ccef4c00 ccf89540 ccf896c0 cce765c0 ccecbf04 ccecbee8
    [    6.471830] bee0: c0238274 c023809c cd8d9000 c0c1d118 ccc36a00 c0c1cc48 fffffff8 c0c7fd8c
    [    6.471835] bf00: 00000001 cd3dac40 ccecbf3c ccecbf18 c0232ffc c027c654 cd8d9000 ccdf9f40
    [    6.471840] bf20: ffffe000 0000009e ccc36a00 00000000 ccecbf84 ccecbf40 c023429c c0232f7c
    [    6.471844] bf40: c023b830 c0c50dd8 cd3dac78 cce56948 7f7412e0 00000000 0000000b 7f6da420
    [    6.471848] bf60: 7f7412e0 7f6dad6e 0000000b c0108024 cceca000 00000000 ccecbfa4 ccecbf88
    [    6.471853] bf80: c0234604 c0233d74 00000000 00000000 7f7412b0 00000000 00000000 ccecbfa8
    [    6.471858] bfa0: c0107e60 c02345d8 7f7412b0 00000000 7f735a20 7f6da420 7f7412e0 7f737458
    [    6.471862] bfc0: 7f7412b0 00000000 7f6dad6e 0000000b 7f6da420 00000000 be950518 be95045c
    [    6.471867] bfe0: 7f6d5c0c be950214 7f5a194c b6e49f26 20030030 7f735a20 52508000 48102600
    [    6.471870] Backtrace:
    [    6.471876] [<c021c364>] (kmem_cache_free) from [<c0693318>] (sock_destroy_inode+0x34/0x38)
    [    6.471881]  r9:cd580088 r8:00000001 r7:c086e290 r6:c086e290 r5:cd610e70 r4:cd610e20
    [    6.471889] [<c06932e4>] (sock_destroy_inode) from [<c0248178>] (destroy_inode+0x40/0x5c)
    [    6.471891]  r5:cd610e70 r4:cd610e20
    [    6.471896] [<c0248138>] (destroy_inode) from [<c02482ac>] (evict+0x118/0x16c)
    [    6.471899]  r5:cd610e70 r4:cd610e20
    [    6.471904] [<c0248194>] (evict) from [<c02484f8>] (iput+0x144/0x1d0)
    [    6.471908]  r7:c086e290 r6:cd610e70 r5:cd610e20 r4:cd8c1800
    [    6.471918] [<c02483b4>] (iput) from [<c0242754>] (dentry_unlink_inode+0xdc/0x150)
    [    6.471921]  r7:00080040 r6:cd5800d8 r5:cd610e20 r4:cd580088
    [    6.471928] [<c0242678>] (dentry_unlink_inode) from [<c02440b4>] (__dentry_kill+0xb8/0x17c)
    [    6.471930]  r5:00000000 r4:cd580088
    [    6.471936] [<c0243ffc>] (__dentry_kill) from [<c0244400>] (dput+0x288/0x2c0)
    [    6.471940]  r7:00080040 r6:cd5800d8 r5:c09a4d80 r4:cd580088
    [    6.471946] [<c0244178>] (dput) from [<c022e5f8>] (__fput+0x134/0x1dc)
    [    6.471950]  r10:00000008 r9:cd610e20 r8:00000000 r7:cd863250 r6:cd580088 r5:cd610e20
    [    6.471952]  r4:ccdd53c0
    [    6.471957] [<c022e4c4>] (__fput) from [<c022e700>] (____fput+0x10/0x14)
    [    6.471962]  r10:c0991644 r9:cd3dac78 r8:cccb7600 r7:ccdf9f40 r6:ccdfa420 r5:c0c51780
    [    6.471964]  r4:ccdfa404
    [    6.471973] [<c022e6f0>] (____fput) from [<c014a058>] (task_work_run+0xc4/0xe4)
    [    6.471983] [<c0149f94>] (task_work_run) from [<c0132290>] (do_exit+0x318/0x9f0)
    [    6.471986]  r9:cd3dac78 r8:c021cf46 r7:ccecb5c0 r6:cceca000 r5:ccdfa41c r4:ccdf9f40
    [    6.471991] [<c0131f78>] (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [    6.471993]  r7:00000001
    [    6.472005] [<c010bfac>] (die) from [<c011ac58>] (__do_kernel_fault.part.0+0x6c/0x1ec)
    [    6.472009]  r10:ce357568 r9:cceca000 r8:2d616d64 r7:cd3dac40 r6:00000005 r5:ccecb7a0
    [    6.472011]  r4:2d616d64
    [    6.472017] [<c011abec>] (__do_kernel_fault.part.0) from [<c0115f04>] (do_page_fault+0x348/0x354)
    [    6.472020]  r7:00000005 r4:ccecb7a0
    [    6.472024] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    6.472028]  r10:ce357568 r9:cceca000 r8:ccecb7a0 r7:2d616d64 r6:c0115fb8 r5:00000005
    [    6.472031]  r4:00000005
    [    6.472035] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.472038]  r7:2d616d64 r6:c0115fb8 r5:00000005 r4:c0c08014
    [    6.472043] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    6.472044] Exception stack(0xccecb7a0 to 0xccecb7e8)
    [    6.472050] b7a0: 2d616d64 02408040 00000000 00000001 2d616d64 02408040 cceca000 ccecb7f0
    [    6.472054] b7c0: 00001000 02400040 ce357568 ccecb814 ccecb818 ccecb7f0 c025efcc c021cf44
    [    6.472057] b7e0: 200f0113 ffffffff
    [    6.472061]  r8:00001000 r7:ccecb7d4 r6:ffffffff r5:200f0113 r4:c021cf44
    [    6.472067] [<c021cf0c>] (kmem_cache_alloc) from [<c025efcc>] (alloc_buffer_head+0x20/0xa0)
    [    6.472071]  r9:02400040 r8:00001000 r7:00000000 r6:ce357568 r5:00000000 r4:00000000
    [    6.472077] [<c025efac>] (alloc_buffer_head) from [<c02600a8>] (alloc_page_buffers+0x74/0xcc)
    [    6.472080]  r5:00000000 r4:00000000
    [    6.472085] [<c0260034>] (alloc_page_buffers) from [<c0260438>] (__getblk_gfp+0x1e0/0x36c)
    [    6.472090]  r10:cd448088 r9:00000000 r8:00190205 r7:00000001 r6:ce357568 r5:00001000
    [    6.472092]  r4:00000000
    [    6.472097] [<c0260258>] (__getblk_gfp) from [<c02d66d8>] (ext4_get_branch+0xac/0x160)
    [    6.472101]  r10:cd6e6b50 r9:cd8e1000 r8:ccecb958 r7:00000001 r6:00000000 r5:ccecb988
    [    6.472104]  r4:ccecb994
    [    6.472108] [<c02d662c>] (ext4_get_branch) from [<c02d713c>] (ext4_ind_map_blocks+0x94/0x9f8)
    [    6.472112]  r10:00000000 r9:cd6e6b50 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    [    6.472114]  r4:ccecbae0
    [    6.472120] [<c02d70a8>] (ext4_ind_map_blocks) from [<c02a4a10>] (ext4_map_blocks+0x3d4/0x5a0)
    [    6.472124]  r10:00000000 r9:cd6e6b20 r8:00000000 r7:00000000 r6:cd6e6b50 r5:00000001
    [    6.472126]  r4:ccecbae0
    [    6.472132] [<c02a463c>] (ext4_map_blocks) from [<c02e0954>] (ext4_mpage_readpages+0x384/0x7d0)
    [    6.472136]  r10:00000000 r9:00000001 r8:ce2fb024 r7:00000000 r6:00000084 r5:00000001
    [    6.472138]  r4:00000000
    [    6.472144] [<c02e05d0>] (ext4_mpage_readpages) from [<c02a3aa4>] (ext4_readpages+0x44/0x48)
    [    6.472148]  r10:cd6e6c3c r9:cd6e6c40 r8:00000094 r7:00000011 r6:c02a3a60 r5:00000011
    [    6.472150]  r4:00000095
    [    6.472156] [<c02a3a60>] (ext4_readpages) from [<c01e50a0>] (__do_page_cache_readahead+0x1a4/0x26c)
    [    6.472164] [<c01e4efc>] (__do_page_cache_readahead) from [<c01d9128>] (filemap_fault+0x328/0x654)
    [    6.472168]  r10:ccecbc5c r9:00000000 r8:00000094 r7:ccc54e40 r6:cd6e6b50 r5:00000094
    [    6.472169]  r4:00000000
    [    6.472176] [<c01d8e00>] (filemap_fault) from [<c02abedc>] (ext4_filemap_fault+0x34/0x48)
    [    6.472180]  r10:00000000 r9:ce365fb0 r8:00000094 r7:ccf18948 r6:ccecbc5c r5:ccf18948
    [    6.472182]  r4:cd6e6b38
    [    6.472189] [<c02abea8>] (ext4_filemap_fault) from [<c0200138>] (__do_fault+0x70/0xf0)
    [    6.472192]  r7:ccf18948 r6:00000015 r5:ccecbca8 r4:00000000
    [    6.472197] [<c02000c8>] (__do_fault) from [<c02042b4>] (handle_mm_fault+0x8d4/0xcd8)
    [    6.472200]  r6:00000000 r5:ccf18948 r4:ccecbcb4
    [    6.472206] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    6.472210]  r10:00000015 r9:cd3dac78 r8:7f6a75a0 r7:00000805 r6:cd3dac40 r5:ccdf9f40
    [    6.472212]  r4:ccecbe20
    [    6.472217] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [    6.472222]  r10:ccecbe90 r9:cceca000 r8:ccecbe20 r7:7f6a75a0 r6:c0115fb8 r5:00000805
    [    6.472224]  r4:00000805
    [    6.472228] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.472231]  r7:7f6a75a0 r6:c0115fb8 r5:00000805 r4:c0c08014
    [    6.472235] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [    6.472237] Exception stack(0xccecbe20 to 0xccecbe68)
    [    6.472242] be20: 7f6a75a0 00000a58 00000000 00000055 00000051 ccc36a00 00000000 7f6a7f63
    [    6.472247] be40: 7f6a75a0 ccef4c00 ccecbe90 ccecbe8c 00000000 ccecbe70 c0382678 c03c8a24
    [    6.472250] be60: 200f0113 ffffffff
    [    6.472254]  r8:7f6a75a0 r7:ccecbe54 r6:ffffffff r5:200f0113 r4:c03c8a24
    [    6.472259] [<c0382618>] (padzero) from [<c027cdc0>] (load_elf_binary+0x778/0x1228)
    [    6.472262]  r5:ccc36a00 r4:ccdc4a80
    [    6.472268] [<c027c648>] (load_elf_binary) from [<c0232ffc>] (search_binary_handler+0x8c/0x1ec)
    [    6.472272]  r10:cd3dac40 r9:00000001 r8:c0c7fd8c r7:fffffff8 r6:c0c1cc48 r5:ccc36a00
    [    6.472274]  r4:c0c1d118
    [    6.472281] [<c0232f70>] (search_binary_handler) from [<c023429c>] (do_execveat_common+0x534/0x630)
    [    6.472285]  r9:00000000 r8:ccc36a00 r7:0000009e r6:ffffe000 r5:ccdf9f40 r4:cd8d9000
    [    6.472291] [<c0233d68>] (do_execveat_common) from [<c0234604>] (SyS_execve+0x38/0x40)
    [    6.472295]  r10:00000000 r9:cceca000 r8:c0108024 r7:0000000b r6:7f6dad6e r5:7f7412e0
    [    6.472297]  r4:7f6da420
    [    6.472303] [<c02345cc>] (SyS_execve) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    6.472306]  r5:00000000 r4:7f7412b0
    [    6.472311] Code: e24dd008 e1a04000 e1a05001 e1a00000 (e5903004)
    [    6.472315] ---[ end trace c1fd7a2253735c5b ]---
    [    6.472317] Fixing recursive fault but reboot is needed!
    [    6.472422] Unable to handle kernel paging request at virtual address 76656433
    [    6.472425] pgd = cd3dc000
    [    6.472429] [76656433] *pgd=00000000
    [    6.472432] Internal error: Oops: 5 [#3] PREEMPT SMP ARM
    [    6.472445] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.472450] CPU: 0 PID: 1 Comm: systemd Tainted: G      D    O
    [    6.472451] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.472454] task: cd880000 task.stack: cd866000
    [    6.472458] PC is at kmem_cache_free+0x1c/0x1e8
    [    6.472466] LR is at ep_unregister_pollwait.constprop.1+0x70/0x80
    [    6.472470] pc : [<c021c380>]    lr : [<c026fb38>]    psr: 60000013
    [    6.472470] sp : cd867e98  ip : cd867ec8  fp : cd867ec4
    [    6.472472] r10: 0000001f  r9 : 00000100  r8 : 00000200
    [    6.472474] r7 : ccc7e3a4  r6 : c0c03374  r5 : ccc00258  r4 : 7665642f
    [    6.472477] r3 : 00000000  r2 : 00000000  r1 : ccc00258  r0 : 7665642f
    [    6.472480] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.472483] Control: 10c5387d  Table: 8d3dc06a  DAC: 00000051
    [    6.472486] Process systemd (pid: 1, stack limit = 0xcd866210)
    [    6.472488] Stack: (0xcd867e98 to 0xcd868000)
    [    6.472491] 7e80:                                                       cd867f50 00000000
    [    6.472497] 7ea0: ccc00258 ccc7e380 c0c03374 ccc7e3a4 00000200 00000100 cd867eec cd867ec8
    [    6.472501] 7ec0: c026fb38 c021c370 ccc7e380 cd3f9900 ccdd5198 00000002 ccc01300 00000000
    [    6.472505] 7ee0: cd867f0c cd867ef0 c026fb6c c026fad4 ccc01300 ccdd5180 ccdd5180 00000002
    [    6.472510] 7f00: cd867fa4 cd867f10 c0270b7c c026fb54 cd867f44 cd867f20 c0191228 c03d74a4
    [    6.472515] 7f20: 00000000 1ba13c51 cd867f60 cd867f88 b6ec515c 00000107 cd867f5c cd867f48
    [    6.472520] 7f40: c019127c c0191200 00000000 cd3f9904 cd3f9900 00000000 c0195220 c0191258
    [    6.472525] 7f60: 00000006 00000051 b6ec515c 00000107 c0108024 be9506b4 00000008 00000000
    [    6.472529] 7f80: 7f72f110 00000001 000000fb c0108024 cd866000 00000000 00000000 cd867fa8
    [    6.472533] 7fa0: c0107e60 c02706f0 00000000 7f72f110 00000004 00000002 0000001f 00000000
    [    6.472538] 7fc0: 00000000 7f72f110 00000001 000000fb 7f6d8198 00000000 be9509a0 00000001
    [    6.472543] 7fe0: 7f6d5f90 be9508fc 7f66e15c b6e6d3d6 20000030 00000004 28020030 6a722020
    [    6.472546] Backtrace:
    [    6.472551] [<c021c364>] (kmem_cache_free) from [<c026fb38>] (ep_unregister_pollwait.constprop.1+0x70/0x80)
    [    6.472557]  r9:00000100 r8:00000200 r7:ccc7e3a4 r6:c0c03374 r5:ccc7e380 r4:ccc00258
    [    6.472563] [<c026fac8>] (ep_unregister_pollwait.constprop.1) from [<c026fb6c>] (ep_remove+0x24/0xd4)
    [    6.472567]  r9:00000000 r8:ccc01300 r7:00000002 r6:ccdd5198 r5:cd3f9900 r4:ccc7e380
    [    6.472573] [<c026fb48>] (ep_remove) from [<c0270b7c>] (SyS_epoll_ctl+0x498/0xac0)
    [    6.472577]  r7:00000002 r6:ccdd5180 r5:ccdd5180 r4:ccc01300
    [    6.472583] [<c02706e4>] (SyS_epoll_ctl) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    6.472587]  r10:00000000 r9:cd866000 r8:c0108024 r7:000000fb r6:00000001 r5:7f72f110
    [    6.472589]  r4:00000000
    [    6.472593] Code: e24dd008 e1a04000 e1a05001 e1a00000 (e5903004)
    [    6.472597] ---[ end trace c1fd7a2253735c5c ]---
    [    9.353362] pgd = ccf2c000
    [    9.356076] [2d616d64] *pgd=00000000
    [    9.359678] Internal error: Oops: 5 [#4] PREEMPT SMP ARM
    [    9.365006] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    9.374657] CPU: 1 PID: 177 Comm: systemd-udevd Tainted: G      D    O
    [    9.381644] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.387759] task: cd28ddc0 task.stack: cccca000
    [    9.392304] PC is at kmem_cache_alloc+0x38/0x1a4
    [    9.396937] LR is at alloc_buffer_head+0x20/0xa0
    [    9.401569] pc : [<c021cf44>]    lr : [<c025efcc>]    psr: 200f0113
    [    9.401569] sp : ccccb980  ip : ccccb9a8  fp : ccccb9a4
    [    9.413093] r10: ce2fb120  r9 : 02400040  r8 : 00001000
    [    9.418334] r7 : ccccb980  r6 : cccca000  r5 : 02408040  r4 : 2d616d64
    [    9.424885] r3 : 00000001  r2 : 00000000  r1 : 02408040  r0 : 2d616d64
    [    9.431437] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    9.438597] Control: 10c5387d  Table: 8cf2c06a  DAC: 00000051
    [    9.444362] Process systemd-udevd (pid: 177, stack limit = 0xcccca210)
    [    9.450912] Stack: (0xccccb980 to 0xccccc000)
    [    9.455286] b980: 00000000 00000000 ce2fb120 00000000 00001000 02400040 ccccb9bc ccccb9a8
    [    9.463497] b9a0: c025efcc c021cf18 00000000 00000000 ccccb9fc ccccb9c0 c02600a8 c025efb8
    [    9.471707] b9c0: cd28ddc0 00000000 00001000 02400040 c07ca068 00000000 00001000 ce2fb120
    [    9.479917] b9e0: 00000001 00000653 00000000 cd448088 ccccba5c ccccba00 c0260438 c0260040
    [    9.488128] ba00: 00001000 cb8a8000 ccccba5c ccccba18 00000808 00000000 ffffffe0 ccccbae8
    [    9.496339] ba20: 00000020 cd448000 00000653 00000000 ccccba5c ccccbb30 ccccbb24 cd6d5b80
    [    9.504548] ba40: 00000001 ccccbaec cd8e1000 cd6255f0 ccccba94 ccccba60 c02d66d8 c0260264
    [    9.512757] ba60: 00001000 00000008 80000193 ccccbc70 00000000 00000000 00000000 00000000
    [    9.520967] ba80: cd6255f0 00000000 ccccbbac ccccba98 c02d713c c02d6638 ccccbadc 00000000
    [    9.529177] baa0: ccec6d80 00000000 ccccbb4c ccccbab8 c01de708 c0118aa4 c01551a0 c0154e2c
    [    9.537386] bac0: ccccbae4 ccccbad0 ccec6d80 00000003 ccccbc70 00000000 0007b26d 00000000
    [    9.545596] bae0: 0000032e 00000400 0000000d 00000000 000000d1 cfd80a78 00000000 02ed66c1
    [    9.553805] bb00: 00000000 ccdfeac0 ccccbb34 ccccbb18 00000000 00000013 cd625574 000005c0
    [    9.562015] bb20: 00000000 cb8a7000 00000653 cd6d5b80 c03d030c c021cf18 00003f98 ce373960
    [    9.570225] bb40: cd80b400 00000000 00000000 cd6256dc 000004dd 00000000 ccccbbac ccccbb68
    [    9.578435] bb60: c0227bf0 c0223ca0 000004dd 00000000 ccccbbac ccccbb80 c01d5578 c03d0de0
    [    9.586644] bb80: ccccbbac ccccbc70 00000001 cd6255f0 00000000 00000000 cd6255c0 00000000
    [    9.594853] bba0: ccccbc14 ccccbbb0 c02a4a10 c02d70b4 00000000 cfd80a40 ccccbbb8 cd80b400
    [    9.603062] bbc0: ce373960 024213ca ccccbbe4 ccccbbd8 c01e6d44 00000000 00000000 ccccbbe8
    [    9.611271] bbe0: 00000000 00000000 ccccbbf4 00000000 00000001 000004dd 00000000 ce373960
    [    9.619479] bc00: 00000001 00000000 ccccbcf4 ccccbc18 c02e0954 c02a4648 c02e0538 024000c0
    [    9.627689] bc20: c0c83e54 cd448000 00001000 00000000 00000000 00000000 c02a4cac cd6256dc
    [    9.635898] bc40: 0000000c 00000000 ccccbd18 00000020 00000020 cd6255f0 00000001 00000000
    [    9.644108] bc60: ccccbd24 00000000 000004fd 00000000 00000000 00000000 000004dd 00000020
    [    9.652318] bc80: 00000000 ccccbdc0 ccccbcb4 ccccbc98 024213ca c01ff6e8 ce38ca70 ce38ca4c
    [    9.660527] bca0: c0c4c500 00000000 c0c4c500 00000001 00000002 00000000 c01dee7c c01dde24
    [    9.668736] bcc0: ce35f65c 0000000e cd6255d8 000004fc 00000020 c02a3a60 00000020 000006a0
    [    9.676945] bce0: cd6256e0 cd6256dc ccccbd04 ccccbcf8 c02a3aa4 c02e05dc ccccbd64 ccccbd08
    [    9.685155] bd00: c01e50a0 c02a3a6c 00000000 ccc54d80 cd6256dc 024213ca ce34c404 ce3739bc
    [    9.693364] bd20: ccccbd20 ccccbd20 ccccbd28 ccccbd28 ccccbd30 ccccbd30 00000000 00000000
    [    9.701573] bd40: 000004ed cd6255f0 ccc54d80 000004ed 00000000 ccccbdec ccccbdc4 ccccbd68
    [    9.709783] bd60: c01d9128 c01e4f08 00000008 ce35f758 ccccbd94 ccccbd80 ccccbda4 ccccbd88
    [    9.717992] bd80: ce36f748 ce36f748 000004ed 00000000 ccf038f0 cd6256dc ccccbdbc cd6255d8
    [    9.726202] bda0: ccf038f0 ccccbdec ce38ca4c 000004ed b6b77000 000004e6 ccccbde4 ccccbdc8
    [    9.734411] bdc0: c02abedc c01d8e0c 00000000 ccccbe40 00000054 ce38ca4c ccccbe24 ccccbde8
    [    9.742619] bde0: c0200138 c02abeb4 ccf038f0 00000054 024200ca 000004ed b6b77000 00000000
    [    9.750829] be00: 00000000 ccccbe10 c01dda7c ccccbe44 ccf038f0 00000040 ccccbe8c ccccbe28
    [    9.759038] be20: c02040e4 c02000d4 00000000 00000000 b668a000 ce38ca4c ccccbeac ccccbe48
    [    9.767248] be40: c02040bc ccf038f0 b6b77000 00000054 ccf2eda8 00000000 00000000 00000000
    [    9.775457] be60: ccccbe8c ccccbfb0 cd28ddc0 cce08540 00000005 b6b776e8 cce08578 00000054
    [    9.783666] be80: ccccbedc ccccbe90 c0115e40 c02039ec 00000017 b668a038 cce08578 00000054
    [    9.791874] bea0: ccccbefc ccccbeb0 00000000 c0177678 2b835b43 00000005 00000005 c0115fb8
    [    9.800084] bec0: b6b776e8 ccccbfb0 bed77cec 0000002a ccccbefc ccccbee0 c011606c c0115bc8
    [    9.808293] bee0: c0c08014 00000005 c0115fb8 b6b776e8 ccccbfac ccccbf00 c010130c c0115fc4
    [    9.816502] bf00: c024afac c07cd5f8 c023b830 000a0000 cd8de000 fffffffe cd8de000 fffff000
    [    9.824711] bf20: c0108024 cccca000 ccccbf4c ccccbf38 c023b7e0 c021c370 fffffffe fffffffe
    [    9.832922] bf40: ccccbf94 ccccbf50 c022b778 c023b780 00000180 c0108024 cccca000 00020000
    [    9.841131] bf60: cccc0000 00000004 00000100 00000001 7f669d20 00020000 00000008 00000005
    [    9.849340] bf80: c0108024 cccca000 ccccbfa4 7f637234 80010010 ffffffff 10c5387d 10c5387d
    [    9.857550] bfa0: 00000000 ccccbfb0 c010cea0 c01012d4 7f664090 7f6775f0 ffffffe4 004ed6e8
    [    9.865759] bfc0: b6b776e8 00000000 7f664090 7f6775f0 b6f63ce8 bed77cec 0000002a 00000000
    [    9.873968] bfe0: 7f665568 bed77ce0 7f6246f8 7f637234 80010010 ffffffff 8fdee861 8fdeec61
    [    9.882174] Backtrace:
    [    9.884635] [<c021cf0c>] (kmem_cache_alloc) from [<c025efcc>] (alloc_buffer_head+0x20/0xa0)
    [    9.893021]  r9:02400040 r8:00001000 r7:00000000 r6:ce2fb120 r5:00000000 r4:00000000
    [    9.900795] [<c025efac>] (alloc_buffer_head) from [<c02600a8>] (alloc_page_buffers+0x74/0xcc)
    [    9.909351]  r5:00000000 r4:00000000
    [    9.912939] [<c0260034>] (alloc_page_buffers) from [<c0260438>] (__getblk_gfp+0x1e0/0x36c)
    [    9.921236]  r10:cd448088 r9:00000000 r8:00000653 r7:00000001 r6:ce2fb120 r5:00001000
    [    9.929095]  r4:00000000
    [    9.931637] [<c0260258>] (__getblk_gfp) from [<c02d66d8>] (ext4_get_branch+0xac/0x160)
    [    9.939584]  r10:cd6255f0 r9:cd8e1000 r8:ccccbaec r7:00000001 r6:cd6d5b80 r5:ccccbb24
    [    9.947441]  r4:ccccbb30
    [    9.949982] [<c02d662c>] (ext4_get_branch) from [<c02d713c>] (ext4_ind_map_blocks+0x94/0x9f8)
    [    9.958540]  r10:00000000 r9:cd6255f0 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    [    9.966397]  r4:ccccbc70
    [    9.968938] [<c02d70a8>] (ext4_ind_map_blocks) from [<c02a4a10>] (ext4_map_blocks+0x3d4/0x5a0)
    [    9.977584]  r10:00000000 r9:cd6255c0 r8:00000000 r7:00000000 r6:cd6255f0 r5:00000001
    [    9.985440]  r4:ccccbc70
    [    9.987983] [<c02a463c>] (ext4_map_blocks) from [<c02e0954>] (ext4_mpage_readpages+0x384/0x7d0)
    [    9.996714]  r10:00000000 r9:00000001 r8:ce373960 r7:00000000 r6:000004dd r5:00000001
    [   10.004572]  r4:00000000
    [   10.007115] [<c02e05d0>] (ext4_mpage_readpages) from [<c02a3aa4>] (ext4_readpages+0x44/0x48)
    [   10.015585]  r10:cd6256dc r9:cd6256e0 r8:000006a0 r7:00000020 r6:c02a3a60 r5:00000020
    [   10.023443]  r4:000004fc
    [   10.025987] [<c02a3a60>] (ext4_readpages) from [<c01e50a0>] (__do_page_cache_readahead+0x1a4/0x26c)
    [   10.035072] [<c01e4efc>] (__do_page_cache_readahead) from [<c01d9128>] (filemap_fault+0x328/0x654)
    [   10.044065]  r10:ccccbdec r9:00000000 r8:000004ed r7:ccc54d80 r6:cd6255f0 r5:000004ed
    [   10.051923]  r4:00000000
    [   10.054466] [<c01d8e00>] (filemap_fault) from [<c02abedc>] (ext4_filemap_fault+0x34/0x48)
    [   10.062676]  r10:000004e6 r9:b6b77000 r8:000004ed r7:ce38ca4c r6:ccccbdec r5:ccf038f0
    [   10.070533]  r4:cd6255d8
    [   10.073075] [<c02abea8>] (ext4_filemap_fault) from [<c0200138>] (__do_fault+0x70/0xf0)
    [   10.081022]  r7:ce38ca4c r6:00000054 r5:ccccbe40 r4:00000000
    [   10.086703] [<c02000c8>] (__do_fault) from [<c02040e4>] (handle_mm_fault+0x704/0xcd8)
    [   10.094562]  r6:00000040 r5:ccf038f0 r4:ccccbe44
    [   10.099196] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [   10.107318]  r10:00000054 r9:cce08578 r8:b6b776e8 r7:00000005 r6:cce08540 r5:cd28ddc0
    [   10.115176]  r4:ccccbfb0
    [   10.117717] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [   10.126100]  r10:0000002a r9:bed77cec r8:ccccbfb0 r7:b6b776e8 r6:c0115fb8 r5:00000005
    [   10.133957]  r4:00000005
    [   10.136499] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [   10.144794]  r7:b6b776e8 r6:c0115fb8 r5:00000005 r4:c0c08014
    [   10.150473] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [   10.157895] Exception stack(0xccccbfb0 to 0xccccbff8)
    [   10.162963] bfa0:                                     7f664090 7f6775f0 ffffffe4 004ed6e8
    [   10.171173] bfc0: b6b776e8 00000000 7f664090 7f6775f0 b6f63ce8 bed77cec 0000002a 00000000
    [   10.179381] bfe0: 7f665568 bed77ce0 7f6246f8 7f637234 80010010 ffffffff
    [   10.186021]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80010010 r4:7f637234
    [   10.192747] Code: e3c6603f e5963004 e2833001 e5863004 (e5943000)
    [   10.198875] ---[ end trace c1fd7a2253735c5d ]---
    [   10.203510] note: systemd-udevd[177] exited with preempt_count 1
    [   10.209575] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [   10.217696] pgd = ccf2c000
    [   10.220409] [00000000] *pgd=00000000
    [   10.224003] Internal error: Oops: 80000005 [#5] PREEMPT SMP ARM
    [   10.229943] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   10.239594] CPU: 1 PID: 177 Comm: systemd-udevd Tainted: G      D    O
    [   10.246581] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.252696] task: cd28ddc0 task.stack: cccca000
    [   10.257242] PC is at 0x0
    [   10.259784] LR is at notifier_call_chain+0x4c/0x8c
    [   10.264592] pc : [<00000000>]    lr : [<c014d1fc>]    psr: a00f0193
    [   10.264592] sp : ccccb630  ip : c0c0725c  fp : ccccb654
    [   10.276114] r10: 00000001  r9 : 00000001  r8 : 00000000
    [   10.281355] r7 : 00000000  r6 : 00000002  r5 : cd3ba000  r4 : ffffffff
    [   10.287904] r3 : 00000000  r2 : cd3ba000  r1 : 00000002  r0 : c0c0725c
    [   10.294456] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   10.301704] Control: 10c5387d  Table: 8cf2c06a  DAC: 00000051
    [   10.307470] Process systemd-udevd (pid: 177, stack limit = 0xcccca210)
    [   10.314020] Stack: (0xccccb630 to 0xccccc000)
    [   10.318391] b620:                                     c0c50088 00000002 cd3ba000 00000000
    [   10.326601] b640: cce08540 00000001 ccccb67c ccccb658 c014d4f0 c014d1bc 00000000 c0b5ba40
    [   10.334811] b660: c0c03224 cd3ba018 cd28ddc0 cd28be80 ccccb6dc ccccb680 c010d254 c014d4c0
    [   10.343021] b680: 00000006 c0c16e30 c0c53f10 00000000 81a440b3 00000001 c017e97c c07c9a0c
    [   10.351230] b6a0: 6089348f 00000002 00000000 00000000 c0c7685e cccca000 0000000b 00002a20
    [   10.359439] b6c0: 00000001 c021cf46 c0c07768 c0991644 ccccb6f4 ccccb6e0 c07c9a0c c07c9100
    [   10.367649] b6e0: cce21680 0000000b ccccb704 ccccb6f8 c07c9a44 c07c99ec ccccb714 ccccb708
    [   10.375859] b700: c07c9a70 c07c9a34 ccccb724 ccccb718 c07cd6f8 c07c9a54 ccccb744 ccccb728
    [   10.384068] b720: c01b10d0 c07cd6ac cd28ddc0 0000000b cccca000 00000001 ccccb76c ccccb748
    [   10.392277] b740: c0132438 c01b0f44 c021cf46 00000000 ccccb76c ccccb760 c012e47c 00000001
    [   10.400486] b760: ccccb7f4 ccccb770 c010c1f8 c0131f84 cccca210 0000000b c099163c 00000008
    [   10.408696] b780: bf000000 cccca000 00000000 600f0113 659915a4 36366333 20663330 36393565
    [   10.416906] b7a0: 34303033 38326520 30303333 35652031 30333638 28203430 34393565 30303033
    [   10.425115] b7c0: c0002029 c01d4bfc c09915a4 2d616d64 ccccb930 00000005 cce08540 2d616d64
    [   10.433324] b7e0: cccca000 ce2fb120 ccccb80c ccccb7f8 c011ac58 c010bfb8 ccccb930 00000005
    [   10.441533] b800: ccccb85c ccccb810 c0115f04 c011abf8 79634a90 00000001 00000000 00000000
    [   10.449742] b820: c015c638 cd28c4c0 cd28c540 cfd8da78 cd28de40 00000005 00000005 c0115fb8
    [   10.457952] b840: 2d616d64 ccccb930 cccca000 ce2fb120 ccccb87c ccccb860 c011606c c0115bc8
    [   10.466161] b860: c0c08014 00000005 c0115fb8 2d616d64 ccccb92c ccccb880 c010130c c0115fc4
    [   10.474371] b880: ffffffff 00000001 00000000 00000000 cfd909a4 c0b5abbc 00000001 00000000
    [   10.482580] b8a0: 02420848 00000000 200f0113 00000001 00000081 c0c4c500 00000000 00000019
    [   10.490789] b8c0: ce2fb120 0000000e cfd8caa8 ccccb900 ccccb934 ccccb8e0 c01e5d38 c01ddcd0
    [   10.498998] b8e0: 00000000 00000002 ccccb934 c080d0d4 c01e5a30 c0225808 00000653 00000003
    [   10.507207] b900: ccccb900 ccccb900 c0227bf0 c021cf44 200f0113 ffffffff ccccb964 00001000
    [   10.515416] b920: ccccb9a4 ccccb930 c010ca78 c01012d4 2d616d64 02408040 00000000 00000001
    [   10.523626] b940: 2d616d64 02408040 cccca000 ccccb980 00001000 02400040 ce2fb120 ccccb9a4
    [   10.531835] b960: ccccb9a8 ccccb980 c025efcc c021cf44 200f0113 ffffffff 00000051 bf000000
    [   10.540044] b980: 00000000 00000000 ce2fb120 00000000 00001000 02400040 ccccb9bc ccccb9a8
    [   10.548254] b9a0: c025efcc c021cf18 00000000 00000000 ccccb9fc ccccb9c0 c02600a8 c025efb8
    [   10.556464] b9c0: cd28ddc0 00000000 00001000 02400040 c07ca068 00000000 00001000 ce2fb120
    [   10.564674] b9e0: 00000001 00000653 00000000 cd448088 ccccba5c ccccba00 c0260438 c0260040
    [   10.572884] ba00: 00001000 cb8a8000 ccccba5c ccccba18 00000808 00000000 ffffffe0 ccccbae8
    [   10.581092] ba20: 00000020 cd448000 00000653 00000000 ccccba5c ccccbb30 ccccbb24 cd6d5b80
    [   10.589301] ba40: 00000001 ccccbaec cd8e1000 cd6255f0 ccccba94 ccccba60 c02d66d8 c0260264
    [   10.597510] ba60: 00001000 00000008 80000193 ccccbc70 00000000 00000000 00000000 00000000
    [   10.605719] ba80: cd6255f0 00000000 ccccbbac ccccba98 c02d713c c02d6638 ccccbadc 00000000
    [   10.613928] baa0: ccec6d80 00000000 ccccbb4c ccccbab8 c01de708 c0118aa4 c01551a0 c0154e2c
    [   10.622137] bac0: ccccbae4 ccccbad0 ccec6d80 00000003 ccccbc70 00000000 0007b26d 00000000
    [   10.630347] bae0: 0000032e 00000400 0000000d 00000000 000000d1 cfd80a78 00000000 02ed66c1
    [   10.638556] bb00: 00000000 ccdfeac0 ccccbb34 ccccbb18 00000000 00000013 cd625574 000005c0
    [   10.646765] bb20: 00000000 cb8a7000 00000653 cd6d5b80 c03d030c c021cf18 00003f98 ce373960
    [   10.654975] bb40: cd80b400 00000000 00000000 cd6256dc 000004dd 00000000 ccccbbac ccccbb68
    [   10.663184] bb60: c0227bf0 c0223ca0 000004dd 00000000 ccccbbac ccccbb80 c01d5578 c03d0de0
    [   10.671394] bb80: ccccbbac ccccbc70 00000001 cd6255f0 00000000 00000000 cd6255c0 00000000
    [   10.679602] bba0: ccccbc14 ccccbbb0 c02a4a10 c02d70b4 00000000 cfd80a40 ccccbbb8 cd80b400
    [   10.687812] bbc0: ce373960 024213ca ccccbbe4 ccccbbd8 c01e6d44 00000000 00000000 ccccbbe8
    [   10.696021] bbe0: 00000000 00000000 ccccbbf4 00000000 00000001 000004dd 00000000 ce373960
    [   10.704231] bc00: 00000001 00000000 ccccbcf4 ccccbc18 c02e0954 c02a4648 c02e0538 024000c0
    [   10.712440] bc20: c0c83e54 cd448000 00001000 00000000 00000000 00000000 c02a4cac cd6256dc
    [   10.720648] bc40: 0000000c 00000000 ccccbd18 00000020 00000020 cd6255f0 00000001 00000000
    [   10.728857] bc60: ccccbd24 00000000 000004fd 00000000 00000000 00000000 000004dd 00000020
    [   10.737066] bc80: 00000000 ccccbdc0 ccccbcb4 ccccbc98 024213ca c01ff6e8 ce38ca70 ce38ca4c
    [   10.745276] bca0: c0c4c500 00000000 c0c4c500 00000001 00000002 00000000 c01dee7c c01dde24
    [   10.753485] bcc0: ce35f65c 0000000e cd6255d8 000004fc 00000020 c02a3a60 00000020 000006a0
    [   10.761694] bce0: cd6256e0 cd6256dc ccccbd04 ccccbcf8 c02a3aa4 c02e05dc ccccbd64 ccccbd08
    [   10.769904] bd00: c01e50a0 c02a3a6c 00000000 ccc54d80 cd6256dc 024213ca ce34c404 ce3739bc
    [   10.778113] bd20: ccccbd20 ccccbd20 ccccbd28 ccccbd28 ccccbd30 ccccbd30 00000000 00000000
    [   10.786322] bd40: 000004ed cd6255f0 ccc54d80 000004ed 00000000 ccccbdec ccccbdc4 ccccbd68
    [   10.794531] bd60: c01d9128 c01e4f08 00000008 ce35f758 ccccbd94 ccccbd80 ccccbda4 ccccbd88
    [   10.802741] bd80: ce36f748 ce36f748 000004ed 00000000 ccf038f0 cd6256dc ccccbdbc cd6255d8
    [   10.810950] bda0: ccf038f0 ccccbdec ce38ca4c 000004ed b6b77000 000004e6 ccccbde4 ccccbdc8
    [   10.819160] bdc0: c02abedc c01d8e0c 00000000 ccccbe40 00000054 ce38ca4c ccccbe24 ccccbde8
    [   10.827370] bde0: c0200138 c02abeb4 ccf038f0 00000054 024200ca 000004ed b6b77000 00000000
    [   10.835578] be00: 00000000 ccccbe10 c01dda7c ccccbe44 ccf038f0 00000040 ccccbe8c ccccbe28
    [   10.843787] be20: c02040e4 c02000d4 00000000 00000000 b668a000 ce38ca4c ccccbeac ccccbe48
    [   10.851996] be40: c02040bc ccf038f0 b6b77000 00000054 ccf2eda8 00000000 00000000 00000000
    [   10.860205] be60: ccccbe8c ccccbfb0 cd28ddc0 cce08540 00000005 b6b776e8 cce08578 00000054
    [   10.868414] be80: ccccbedc ccccbe90 c0115e40 c02039ec 00000017 b668a038 cce08578 00000054
    [   10.876623] bea0: ccccbefc ccccbeb0 00000000 c0177678 2b835b43 00000005 00000005 c0115fb8
    [   10.884832] bec0: b6b776e8 ccccbfb0 bed77cec 0000002a ccccbefc ccccbee0 c011606c c0115bc8
    [   10.893041] bee0: c0c08014 00000005 c0115fb8 b6b776e8 ccccbfac ccccbf00 c010130c c0115fc4
    [   10.901251] bf00: c024afac c07cd5f8 c023b830 000a0000 cd8de000 fffffffe cd8de000 fffff000
    [   10.909459] bf20: c0108024 cccca000 ccccbf4c ccccbf38 c023b7e0 c021c370 fffffffe fffffffe
    [   10.917668] bf40: ccccbf94 ccccbf50 c022b778 c023b780 00000180 c0108024 cccca000 00020000
    [   10.925877] bf60: cccc0000 00000004 00000100 00000001 7f669d20 00020000 00000008 00000005
    [   10.934086] bf80: c0108024 cccca000 ccccbfa4 7f637234 80010010 ffffffff 10c5387d 10c5387d
    [   10.942295] bfa0: 00000000 ccccbfb0 c010cea0 c01012d4 7f664090 7f6775f0 ffffffe4 004ed6e8
    [   10.950505] bfc0: b6b776e8 00000000 7f664090 7f6775f0 b6f63ce8 bed77cec 0000002a 00000000
    [   10.958713] bfe0: 7f665568 bed77ce0 7f6246f8 7f637234 80010010 ffffffff 8fdee861 8fdeec61
    [   10.966919] Backtrace:
    [   10.969380] [<c014d1b0>] (notifier_call_chain) from [<c014d4f0>] (atomic_notifier_call_chain+0x3c/0x50)
    [   10.978812]  r9:00000001 r8:cce08540 r7:00000000 r6:cd3ba000 r5:00000002 r4:c0c50088
    [   10.986585] [<c014d4b4>] (atomic_notifier_call_chain) from [<c010d254>] (__switch_to+0x34/0x40)
    [   10.995315]  r6:cd28be80 r5:cd28ddc0 r4:cd3ba018
    [   10.999957] [<c07c90f4>] (__schedule) from [<c07c9a0c>] (preempt_schedule_common+0x2c/0x48)
    [   11.008342]  r10:c0991644 r9:c0c07768 r8:c021cf46 r7:00000001 r6:00002a20 r5:0000000b
    [   11.016200]  r4:cccca000
    [   11.018743] [<c07c99e0>] (preempt_schedule_common) from [<c07c9a44>] (preempt_schedule.part.7+0x1c/0x20)
    [   11.028258]  r5:0000000b r4:cce21680
    [   11.031846] [<c07c9a28>] (preempt_schedule.part.7) from [<c07c9a70>] (preempt_schedule+0x28/0x2c)
    [   11.040754] [<c07c9a48>] (preempt_schedule) from [<c07cd6f8>] (_raw_spin_unlock_irq+0x58/0x5c)
    [   11.049403] [<c07cd6a0>] (_raw_spin_unlock_irq) from [<c01b10d0>] (acct_collect+0x198/0x1b8)
    [   11.057874] [<c01b0f38>] (acct_collect) from [<c0132438>] (do_exit+0x4c0/0x9f0)
    [   11.065210]  r7:00000001 r6:cccca000 r5:0000000b r4:cd28ddc0
    [   11.070890] [<c0131f78>] (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [   11.077440]  r7:00000001
    [   11.079982] [<c010bfac>] (die) from [<c011ac58>] (__do_kernel_fault.part.0+0x6c/0x1ec)
    [   11.087931]  r10:ce2fb120 r9:cccca000 r8:2d616d64 r7:cce08540 r6:00000005 r5:ccccb930
    [   11.095789]  r4:2d616d64
    [   11.098330] [<c011abec>] (__do_kernel_fault.part.0) from [<c0115f04>] (do_page_fault+0x348/0x354)
    [   11.107235]  r7:00000005 r4:ccccb930
    [   11.110822] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [   11.119206]  r10:ce2fb120 r9:cccca000 r8:ccccb930 r7:2d616d64 r6:c0115fb8 r5:00000005
    [   11.127064]  r4:00000005
    [   11.129604] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [   11.137899]  r7:2d616d64 r6:c0115fb8 r5:00000005 r4:c0c08014
    [   11.143578] [<c01012c8>] (do_DataAbort) from [<c010ca78>] (__dabt_svc+0x58/0x80)
    [   11.151000] Exception stack(0xccccb930 to 0xccccb978)
    [   11.156069] b920:                                     2d616d64 02408040 00000000 00000001
    [   11.164278] b940: 2d616d64 02408040 cccca000 ccccb980 00001000 02400040 ce2fb120 ccccb9a4
    [   11.172487] b960: ccccb9a8 ccccb980 c025efcc c021cf44 200f0113 ffffffff
    [   11.179125]  r8:00001000 r7:ccccb964 r6:ffffffff r5:200f0113 r4:c021cf44
    [   11.185853] [<c021cf0c>] (kmem_cache_alloc) from [<c025efcc>] (alloc_buffer_head+0x20/0xa0)
    [   11.194236]  r9:02400040 r8:00001000 r7:00000000 r6:ce2fb120 r5:00000000 r4:00000000
    [   11.202009] [<c025efac>] (alloc_buffer_head) from [<c02600a8>] (alloc_page_buffers+0x74/0xcc)
    [   11.210564]  r5:00000000 r4:00000000
    [   11.214151] [<c0260034>] (alloc_page_buffers) from [<c0260438>] (__getblk_gfp+0x1e0/0x36c)
    [   11.222447]  r10:cd448088 r9:00000000 r8:00000653 r7:00000001 r6:ce2fb120 r5:00001000
    [   11.230305]  r4:00000000
    [   11.232845] [<c0260258>] (__getblk_gfp) from [<c02d66d8>] (ext4_get_branch+0xac/0x160)
    [   11.240792]  r10:cd6255f0 r9:cd8e1000 r8:ccccbaec r7:00000001 r6:cd6d5b80 r5:ccccbb24
    [   11.248650]  r4:ccccbb30
    [   11.251190] [<c02d662c>] (ext4_get_branch) from [<c02d713c>] (ext4_ind_map_blocks+0x94/0x9f8)
    [   11.259748]  r10:00000000 r9:cd6255f0 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    [   11.267606]  r4:ccccbc70
    [   11.270147] [<c02d70a8>] (ext4_ind_map_blocks) from [<c02a4a10>] (ext4_map_blocks+0x3d4/0x5a0)
    [   11.278792]  r10:00000000 r9:cd6255c0 r8:00000000 r7:00000000 r6:cd6255f0 r5:00000001
    [   11.286650]  r4:ccccbc70
    [   11.289191] [<c02a463c>] (ext4_map_blocks) from [<c02e0954>] (ext4_mpage_readpages+0x384/0x7d0)
    [   11.297924]  r10:00000000 r9:00000001 r8:ce373960 r7:00000000 r6:000004dd r5:00000001
    [   11.305782]  r4:00000000
    [   11.308323] [<c02e05d0>] (ext4_mpage_readpages) from [<c02a3aa4>] (ext4_readpages+0x44/0x48)
    [   11.316794]  r10:cd6256dc r9:cd6256e0 r8:000006a0 r7:00000020 r6:c02a3a60 r5:00000020
    [   11.324651]  r4:000004fc
    [   11.327193] [<c02a3a60>] (ext4_readpages) from [<c01e50a0>] (__do_page_cache_readahead+0x1a4/0x26c)
    [   11.336277] [<c01e4efc>] (__do_page_cache_readahead) from [<c01d9128>] (filemap_fault+0x328/0x654)
    [   11.345271]  r10:ccccbdec r9:00000000 r8:000004ed r7:ccc54d80 r6:cd6255f0 r5:000004ed
    [   11.353129]  r4:00000000
    [   11.355672] [<c01d8e00>] (filemap_fault) from [<c02abedc>] (ext4_filemap_fault+0x34/0x48)
    [   11.363881]  r10:000004e6 r9:b6b77000 r8:000004ed r7:ce38ca4c r6:ccccbdec r5:ccf038f0
    [   11.371739]  r4:cd6255d8
    [   11.374281] [<c02abea8>] (ext4_filemap_fault) from [<c0200138>] (__do_fault+0x70/0xf0)
    [   11.382228]  r7:ce38ca4c r6:00000054 r5:ccccbe40 r4:00000000
    [   11.387908] [<c02000c8>] (__do_fault) from [<c02040e4>] (handle_mm_fault+0x704/0xcd8)
    [   11.395767]  r6:00000040 r5:ccf038f0 r4:ccccbe44
    [   11.400402] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [   11.408523]  r10:00000054 r9:cce08578 r8:b6b776e8 r7:00000005 r6:cce08540 r5:cd28ddc0
    [   11.416381]  r4:ccccbfb0
    [   11.418921] [<c0115bbc>] (do_page_fault) from [<c011606c>] (do_translation_fault+0xb4/0xb8)
    [   11.427305]  r10:0000002a r9:bed77cec r8:ccccbfb0 r7:b6b776e8 r6:c0115fb8 r5:00000005
    [   11.435163]  r4:00000005
    [   11.437703] [<c0115fb8>] (do_translation_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [   11.445999]  r7:b6b776e8 r6:c0115fb8 r5:00000005 r4:c0c08014
    [   11.451679] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [   11.459100] Exception stack(0xccccbfb0 to 0xccccbff8)
    [   11.464169] bfa0:                                     7f664090 7f6775f0 ffffffe4 004ed6e8
    [   11.472379] bfc0: b6b776e8 00000000 7f664090 7f6775f0 b6f63ce8 bed77cec 0000002a 00000000
    [   11.480588] bfe0: 7f665568 bed77ce0 7f6246f8 7f637234 80010010 ffffffff
    [   11.487226]  r8:10c5387d r7:10c5387d r6:ffffffff r5:80010010 r4:7f637234
    [   11.493952] Code: bad PC value
    [   11.497015] ---[ end trace c1fd7a2253735c5e ]---
    [   11.501646] Fixing recursive fault but reboot is needed!
    Vishal
  • Hi Kemal,
    I think I am now able to see the udevadm verbose messages after enabling earlyprintk with:
    setenv optargs debug earlyprintk=${console},keep loglevel=7 log_buf_len=16000 initcall_debug time
    Now I am noticing the most common occurrence is typically:
    [  OK  ] Started Rebuild Hardware Database.
             Starting udev Coldplug all Devices...
    [    7.728688] udevadm[153]: calling: trigger
    [    7.761106] udevadm[153]:   device-enumerator: scanning /sys/bus
    [    7.841641] udevadm[155]: calling: trigger
    [    7.871675] udevadm[155]: device-enumerator: scan all dirs
    [    7.901716] udevadm[155]:   device-enumerator: scanning /sys/bus
    [    7.978328] udevadm[155]:   device-enumerator: scanning /sys/class
    [    8.096665] Unable to handle kernel NULL pointer dereference at virtual address 00000004
    In one instance it also kept outputting the following (see 1.txt for full log):
    [    6.628239] systemd-journal: 26 output lines suppressed due to ratelimiting
    [    7.707130] omap_i2c 48070000.i2c: controller timed out
    [    8.827136] omap_i2c 48070000.i2c: controller timed out
    [    9.947133] omap_i2c 48070000.i2c: controller timed out
    [   11.067147] omap_i2c 48070000.i2c: controller timed out
    [   12.187133] omap_i2c 48070000.i2c: controller timed out
    [   13.307133] omap_i2c 48070000.i2c: controller timed out
    [   13.337129] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   14.427135] omap_i2c 48070000.i2c: controller timed out
    [   15.547133] omap_i2c 48070000.i2c: controller timed out
    [   16.587187] systemd-udevd[124]: maximum number (12) of children reached
    [   16.667148] omap_i2c 48070000.i2c: controller timed out
    [   17.787133] omap_i2c 48070000.i2c: controller timed out
    [   18.907132] omap_i2c 48070000.i2c: controller timed out
    [   20.027136] omap_i2c 48070000.i2c: controller timed out
    I have also attached several other logs for the same boot test:
    Welcome to Arago 2017.05!
    [    2.339550] systemd-sysv-ge: 187 output lines suppressed due to ratelimiting
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [  OK  ] Reached target Swap.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Journal Socket.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Listening on Syslog Socket.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Created slice System Slice.
             Starting Create list of required st... nodes for the current kernel...
             Mounting POSIX Message Queue File System...
             Mounting Debug File System...
    [  OK  ] Reached target Slices.
             Mounting Temporary Directory...
             Starting Setup Virtual Console...
             Starting Remount Root and Kernel File Systems...
    [    3.182702] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Created slice system-serial\x2dgetty.slice.
             Starting Load Kernel Modules...
    [    3.247768] cmemk: loading out-of-tree module taints kernel.
    [    3.254522] CMEMK module: reference Linux version 4.9.28
    [  OK  ] Created slice system-getty.slice.
    [    3.262608] allocated heap buffer 0x40500000 of size 0x100000
    [    3.272709] cmemk initialized
             [    3.291324] cryptodev: driver 1.8 loaded.
    Starting Journal Service...
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Journal Service.
             Starting Apply Kernel Variables...
             Mounting Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Rebuild Hardware Database...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Configuration File System.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /var/volatile...
             Mounting /media/ram...
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
             Starting Rebuild Journal Catalog...
             Starting Rebuild Dynamic Linker Cache...
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Volatile Files and Directories.
    [  OK  ] Started Rebuild Journal Catalog.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Time Synchronization...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [    5.985557] udevadm[153]: calling: trigger
    [    6.010995] udevadm[153]:   device-enumerator: scanning /sys/bus
    [    6.119119] udevadm[163]: calling: trigger
    [    6.125348] udevadm[163]: device-enumerator: scan all dirs
    [    6.150901] udevadm[163]:   device-enumerator: scanning /sys/bus
    [    6.181686] udevadm[163]:   device-enumerator: scanning /sys/class
    [    6.448773] Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP ARM
    [    6.456222] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.465901] CPU: 1 PID: 113 Comm: systemd-journal Tainted: G           O    4.9.28-geed43d1050
    [    6.474637] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.480755] task: cd28c4c0 task.stack: ccdf4000
    [    6.485317] PC is at read_wb_reg+0x1d0/0x334
    [    6.489608] LR is at do_DataAbort+0x44/0xc4
    [    6.493810] pc : [<c0110714>]    lr : [<c010130c>]    psr: a00f01b3
    [    6.493810] sp : ccdf5f00  ip : c0c07fc4  fp : 00000000
    [    6.505337] r10: 00000020  r9 : c024d948  r8 : ccdf5fb0
    [    6.510582] r7 : c022e600  r6 : ccdf5f18  r5 : 00000817  r4 : ccdf5f54
    [    6.517136] r3 : c024d764  r2 : b67c6000  r1 : 00000817  r0 : c024d968
    [    6.523691] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment none
    [    6.531117] Control: 10c5387d  Table: 8cde806a  DAC: 00000051
    [    6.536886] Process systemd-journal (pid: 113, stack limit = 0xccdf4210)
    [    6.543614] Stack: (0xccdf5f00 to 0xccdf6000)
    [    6.547992] 5f00: c024d968 c024d764 ccdf5f54 ccdf5f18 c022e600 c024d948 00000020 00000000
    [    6.556206] 5f20: c0149ee4 c9026188 c9026180 cd28c984 c0c51780 cd28c9a0 cd28c4c0 00000000
    [    6.564421] 5f40: ccdf4000 00000000 ccdf5f64 ccdf5f58 c022e700 c022e4d0 ccdf5f8c ccdf5f68
    [    6.572635] 5f60: c014a058 c022e6fc ccdf4000 c0108024 ccdf4000 c0108024 ccdf5fb0 00000006
    [    6.580849] 5f80: ccdf5fac ccdf5f90 c010b888 b6e034c4 200f0010 ffffffff 10c5387d 10c5387d
    [    6.589063] 5fa0: 00000000 ccdf5fb0 c010cea0 c01012d4 b67c5f50 bea0de00 00000160 00000000
    [    6.597276] 5fc0: 000001a0 b67c5f10 7f5e53c8 bea0df18 00000060 bea0e7b0 068c48e2 e7093354
    [    6.605490] 5fe0: b67c5fd0 bea0dd0c 7f5c08b4 b6e034c4 200f0010 ffffffff 00000000 00000000
    [    6.613699] Backtrace: no frame pointer
    [    6.617572] Code: 0eda ee10 a800 e89d (0ed9) ee10
    [    6.622385] ---[ end trace d7e71fc271410948 ]---
    [   20.057128] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [   20.064033] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   21.147134] omap_i2c 48070000.i2c: controller timed out
    [   22.267147] omap_i2c 48070000.i2c: controller timed out
    [   23.387134] omap_i2c 48070000.i2c: controller timed out
    [   24.507133] omap_i2c 48070000.i2c: controller timed out
    [   25.627136] omap_i2c 48070000.i2c: controller timed out
    [   26.747133] omap_i2c 48070000.i2c: controller timed out
    [   26.777129] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   26.827139] Unable to handle kernel paging request at virtual address d7e35e48
    [   26.834392] pgd = cce58000
    [   26.837109] [d7e35e48] *pgd=00000000
    [   26.840707] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
    [   26.846039] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   26.855704] CPU: 1 PID: 124 Comm: systemd-udevd Tainted: G      D    O    4.9.28-geed43d1050
    [   26.864263] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   26.870380] task: cd28abc0 task.stack: cce52000
    [   26.874933] PC is at kmem_cache_free+0x7c/0x1e8
    [   26.879488] LR is at kfree_skbmem+0x90/0x98
    [   26.883689] pc : [<c021c3e0>]    lr : [<c069a278>]    psr: 600f0013
    [   26.883689] sp : cce53d30  ip : cce53d60  fp : cce53d5c
    [   26.895215] r10: 00000000  r9 : 000000b5  r8 : ce304558
    [   26.900460] r7 : cce53d30  r6 : cce52000  r5 : c9026300  r4 : c8c03e44
    [   26.907014] r3 : c8c03e48  r2 : 0f232000  r1 : 00051156  r0 : c8c03e44
    [   26.913568] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   26.920732] Control: 10c5387d  Table: 8ce5806a  DAC: 00000051
    [   26.926500] Process systemd-udevd (pid: 124, stack limit = 0xcce52210)
    [   26.933053] Stack: (0xcce53d30 to 0xcce54000)
    [   26.937428] 3d20:                                     c069a810 c069a6a0 c9026300 cd3f8d2c
    [   26.945642] 3d40: ccdcc000 cd5b8380 cd3f8d2c 000000b5 cce53d6c cce53d60 c069a278 c021c370
    [   26.953856] 3d60: cce53d84 cce53d70 c069a8b4 c069a1f4 cd3f8b00 cd3f8d2c cce53e0c cce53d88
    [   26.962070] 3d80: c074e86c c069a88c cce53dc4 00000003 ffffffe0 fffffe00 000000b5 cce52000
    [   26.970284] 3da0: 00000000 00000000 00000000 c9026300 c0c44c00 00000000 00000007 cce53e48
    [   26.978497] 3dc0: c0c53f10 fffffff5 00000000 00000000 00000000 00000000 ffffffff ffffffff
    [   26.986712] 3de0: c0693a08 cce53f48 00000000 00000000 cd5b8380 cce53e28 cce52000 00004000
    [   26.994925] 3e00: cce53e1c cce53e10 c06935cc c074e470 cce53f34 cce53e20 c0693c64 c06935bc
    [   27.003138] 3e20: 00000000 00000000 cce53e54 cce53e38 00000040 cce53ea0 ccebb800 00000001
    [   27.011352] 3e40: c9026248 00000000 bedce534 00000085 7f5d105c 00000008 bedcee84 00000027
    [   27.019565] 3e60: 7f5cf944 00000001 00000040 00000000 cd8e5e78 00000002 00000000 00000005
    [   27.027778] 3e80: cce53f3c cce53e90 c022d00c c026c2fc 00000000 00000000 cce53f4c 00000000
    [   27.035991] 3ea0: 00000001 00000000 00000000 cce53f00 00000000 00000004 c9026240 00000000
    [   27.044204] 3ec0: 00000000 00000000 00000000 00000000 00000000 00000000 bedcedc0 00000004
    [   27.052417] 3ee0: bedcfee2 0000000d bedcedd4 00000007 bedcee84 00000027 7f5cf944 00000001
    [   27.060630] 3f00: cce53f1c cce53f10 c024aa18 bedce4f8 00004000 cd5b8380 00000128 c0108024
    [   27.068844] 3f20: cce52000 00000000 cce53f94 cce53f38 c0694a24 c0693a78 00000000 00000000
    [   27.077056] 3f40: 00000000 fffffff7 00000000 00000000 00000001 00000000 00000000 cce53e68
    [   27.085269] 3f60: 00000000 00000000 00000000 00000000 00004000 00000000 00000092 7f5de08c
    [   27.093483] 3f80: bedce4f8 bedce514 cce53fa4 cce53f98 c0694a60 c06949e8 00000000 cce53fa8
    [   27.101697] 3fa0: c0107e60 c0694a5c 7f5de08c bedce4f8 00000005 bedce4f8 00004000 00000004
    [   27.109909] 3fc0: 7f5de08c bedce4f8 bedce514 00000128 bedce534 00000000 7f5ca8cc 7f5c9498
    [   27.118123] 3fe0: 00000000 bedce4e4 7f5a5f8c b6ee9a08 600f0030 00000005 52598080 48102601
    [   27.126332] Backtrace:
    [   27.128800] [<c021c364>] (kmem_cache_free) from [<c069a278>] (kfree_skbmem+0x90/0x98)
    [   27.136666]  r9:000000b5 r8:cd3f8d2c r7:cd5b8380 r6:ccdcc000 r5:cd3f8d2c r4:c9026300
    [   27.144444] [<c069a1e8>] (kfree_skbmem) from [<c069a8b4>] (kfree_skb+0x34/0x68)
    [   27.151791] [<c069a880>] (kfree_skb) from [<c074e86c>] (unix_dgram_sendmsg+0x408/0x648)
    [   27.159827]  r5:cd3f8d2c r4:cd3f8b00
    [   27.163424] [<c074e464>] (unix_dgram_sendmsg) from [<c06935cc>] (sock_sendmsg+0x1c/0x2c)
    [   27.171551]  r10:00004000 r9:cce52000 r8:cce53e28 r7:cd5b8380 r6:00000000 r5:00000000
    [   27.179410]  r4:cce53f48
    [   27.181957] [<c06935b0>] (sock_sendmsg) from [<c0693c64>] (___sys_sendmsg+0x1f8/0x208)
    [   27.189912] [<c0693a6c>] (___sys_sendmsg) from [<c0694a24>] (__sys_sendmsg+0x48/0x74)
    [   27.197776]  r10:00000000 r9:cce52000 r8:c0108024 r7:00000128 r6:cd5b8380 r5:00004000
    [   27.205637]  r4:bedce4f8
    [   27.208185] [<c06949dc>] (__sys_sendmsg) from [<c0694a60>] (SyS_sendmsg+0x10/0x14)
    [   27.215786]  r6:bedce514 r5:bedce4f8 r4:7f5de08c
    [   27.220429] [<c0694a50>] (SyS_sendmsg) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [   27.228207] Code: e5863004 e5943000 ee1d2f90 e2833004 (e7939002)
    [   27.234327] ---[ end trace d7e71fc271410949 ]---
    [   27.238963] note: systemd-udevd[124] exited with preempt_count 1
    [   27.377104] INFO: rcu_preempt detected stalls on CPUs/tasks:
    [   27.382807]  0-...: (0 ticks this GP) idle=d95/140000000000000/0 softirq=1158/1158 fqs=1021
    [   27.391279]  (detected by 1, t=2102 jiffies, g=-60, c=-61, q=942)
    [   27.397408] Task dump for CPU 0:
    [   27.400647] udevadm         R  running task        0   163      1 0x00000002
    [   27.407741] Backtrace:
    [   27.410208] [<cd5483ac>] (0xcd5483ac) from [<cd230c10>] (0xcd230c10)
    [   27.416591] Backtrace aborted due to bad frame pointer <cd07b029>
    [   27.867134] omap_i2c 48070000.i2c: controller timed out
    [   28.987123] omap_i2c 48070000.i2c: controller timed out
    [   30.107124] omap_i2c 48070000.i2c: controller timed out
    [   31.227125] omap_i2c 48070000.i2c: controller timed out
    [   32.347123] omap_i2c 48070000.i2c: controller timed out
    [   33.467138] omap_i2c 48070000.i2c: controller timed out
    [   33.497138] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [   33.504043] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   34.587124] omap_i2c 48070000.i2c: controller timed out
    [   35.707123] omap_i2c 48070000.i2c: controller timed out
    [   36.827125] omap_i2c 48070000.i2c: controller timed out
    [   37.947123] omap_i2c 48070000.i2c: controller timed out
    [   39.067138] omap_i2c 48070000.i2c: controller timed out
    [   40.187124] omap_i2c 48070000.i2c: controller timed out
    [   40.217151] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   41.307123] omap_i2c 48070000.i2c: controller timed out
    [   42.427124] omap_i2c 48070000.i2c: controller timed out
    [   43.547123] omap_i2c 48070000.i2c: controller timed out
    [   44.667138] omap_i2c 48070000.i2c: controller timed out
    [   45.787123] omap_i2c 48070000.i2c: controller timed out
    [   46.907123] omap_i2c 48070000.i2c: controller timed out
    [   46.937139] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [   46.944044] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   48.027125] omap_i2c 48070000.i2c: controller timed out
    [   49.147123] omap_i2c 48070000.i2c: controller timed out
    [   50.267138] omap_i2c 48070000.i2c: controller timed out
    [   51.387123] omap_i2c 48070000.i2c: controller timed out
    [   52.507123] omap_i2c 48070000.i2c: controller timed out
    [   53.627124] omap_i2c 48070000.i2c: controller timed out
    [   53.657137] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   54.747122] omap_i2c 48070000.i2c: controller timed out
    [   55.867137] omap_i2c 48070000.i2c: controller timed out
    [   56.987123] omap_i2c 48070000.i2c: controller timed out
    [   58.107122] omap_i2c 48070000.i2c: controller timed out
    [   59.227124] omap_i2c 48070000.i2c: controller timed out
    [   60.347123] omap_i2c 48070000.i2c: controller timed out
    [   60.377139] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [   60.384044] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   61.467138] omap_i2c 48070000.i2c: controller timed out
    [   62.587124] omap_i2c 48070000.i2c: controller timed out
    [   63.707123] omap_i2c 48070000.i2c: controller timed out
    [   64.827125] omap_i2c 48070000.i2c: controller timed out
    [   65.947123] omap_i2c 48070000.i2c: controller timed out
    [   67.067138] omap_i2c 48070000.i2c: controller timed out
    [   67.097138] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   68.187124] omap_i2c 48070000.i2c: controller timed out
    [   69.307123] omap_i2c 48070000.i2c: controller timed out
    [   70.427125] omap_i2c 48070000.i2c: controller timed out
    [   71.547122] omap_i2c 48070000.i2c: controller timed out
    [   72.667138] omap_i2c 48070000.i2c: controller timed out
    [   73.787124] omap_i2c 48070000.i2c: controller timed out
    [   73.817151] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [   73.824055] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   74.907123] omap_i2c 48070000.i2c: controller timed out
    [   76.027125] omap_i2c 48070000.i2c: controller timed out
    [   77.147123] omap_i2c 48070000.i2c: controller timed out
    [   78.267138] omap_i2c 48070000.i2c: controller timed out
    [   79.387123] omap_i2c 48070000.i2c: controller timed out
    [   80.507122] omap_i2c 48070000.i2c: controller timed out
    [   80.537137] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   81.627124] omap_i2c 48070000.i2c: controller timed out
    [   82.747123] omap_i2c 48070000.i2c: controller timed out
    [   83.867138] omap_i2c 48070000.i2c: controller timed out                             +-----------------------------+
    [   84.987123] omap_i2c 48070000.i2c: controller timed out                             |                             |
    [   86.107123] omap_i2c 48070000.i2c: controller timed out                             |  Cannot open /dev/ttyUSB0!  |
    [   87.227124] omap_i2c 48070000.i2c: controller timed out                             |                             |
    [   87.257137] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]          +-----------------------------+
    [   87.264041] cpufreq: __target_index: Failed to change cpu frequency: -110
    [   88.347122] omap_i2c 48070000.i2c: controller timed out
    [   89.467138] omap_i2c 48070000.i2c: controller timed out
    [   90.427104] INFO: rcu_preempt detected stalls on CPUs/tasks:
    [   90.432801]  0-...: (0 ticks this GP) idle=d95/140000000000000/0 softirq=1158/1158 fqs=4172
    [   90.441272]  (detected by 1, t=8407 jiffies, g=-60, c=-61, q=942)
    [   90.447399] Task dump for CPU 0:
    [   90.450638] udevadm         R  running task        0   163      1 0x00000002
    [   90.457731] Backtrace:
    [   90.460198] [<cd5483ac>] (0xcd5483ac) from [<cd230c10>] (0xcd230c10)
    [   90.466579] Backtrace aborted due to bad frame pointer <cd07b029>
    [   90.587134] omap_i2c 48070000.i2c: controller timed out
    [   91.707132] omap_i2c 48070000.i2c: controller timed out
    [   92.827137] omap_i2c 48070000.i2c: controller timed out
    [   93.947134] omap_i2c 48070000.i2c: controller timed out
    [   93.977129] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [   95.067148] omap_i2c 48070000.i2c: controller timed out
    [   96.187133] omap_i2c 48070000.i2c: controller timed out
    [   97.307132] omap_i2c 48070000.i2c: controller timed out
    [   98.427136] omap_i2c 48070000.i2c: controller timed out
    [   99.547132] omap_i2c 48070000.i2c: controller timed out
    [  100.667147] omap_i2c 48070000.i2c: controller timed out
    [  100.697128] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [  100.704033] cpufreq: __target_index: Failed to change cpu frequency: -110
    [  101.787134] omap_i2c 48070000.i2c: controller timed out
    [  102.907132] omap_i2c 48070000.i2c: controller timed out
    [  104.027136] omap_i2c 48070000.i2c: controller timed out
    [  105.147133] omap_i2c 48070000.i2c: controller timed out
    [  106.267147] omap_i2c 48070000.i2c: controller timed out
    [  107.387134] omap_i2c 48070000.i2c: controller timed out
    [  107.417142] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [  108.507133] omap_i2c 48070000.i2c: controller timed out
    [  109.627135] omap_i2c 48070000.i2c: controller timed out
    [  110.747132] omap_i2c 48070000.i2c: controller timed out
    [  111.867147] omap_i2c 48070000.i2c: controller timed out
    [  112.987133] omap_i2c 48070000.i2c: controller timed out
    [  114.107132] omap_i2c 48070000.i2c: controller timed out
    [  114.137128] cpu cpu0: vdd failed for 1060000uV[min 850000uV max 1500000uV]
    [  114.144032] cpufreq: __target_index: Failed to change cpu frequency: -110
    [  115.227136] omap_i2c 48070000.i2c: controller timed out
    [  116.347133] omap_i2c 48070000.i2c: controller timed out
    [  117.467147] omap_i2c 48070000.i2c: controller timed out
    [  118.587132] omap_i2c 48070000.i2c: controller timed out
    [  119.707133] omap_i2c 48070000.i2c: controller timed out
    [  120.827136] omap_i2c 48070000.i2c: controller timed out
    [  120.857127] cpu cpu0: vdd failed for 1183000uV[min 950000uV max 1500000uV]
    [  121.947133] omap_i2c 48070000.i2c: controller timed out
    [  123.067147] omap_i2c 48070000.i2c: controller timed out
    [    2.860440] systemd-sysv-ge: 187 output lines suppressed due to ratelimiting
    [    3.626562] cmemk: loading out-of-tree module taints kernel.
    [    3.633364] CMEMK module: reference Linux version 4.9.28
    [    3.640764] allocated heap buffer 0x40500000 of size 0x100000
    [    3.651756] cmemk initialized
    [    3.659934] cryptodev: driver 1.8 loaded.
    [    3.829645] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    2.291180] systemd-sysv-ge: 187 output lines suppressed due to ratelimiting
    [    3.158127] cmemk: loading out-of-tree module taints kernel.
    [    3.164976] CMEMK module: reference Linux version 4.9.28
    [    3.175359] allocated heap buffer 0x40500000 of size 0x100000
    [    3.188055] cmemk initialized
    [    3.202884] cryptodev: driver 1.8 loaded.
    [    3.252730] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.926630] udevadm[153]: calling: trigger
    [    5.951006] udevadm[153]:   device-enumerator: scanning /sys/bus
    [    6.074894] udevadm[163]: calling: trigger
    [    6.101110] udevadm[163]: device-enumerator: scan all dirs
    [    9.797019] Unable to handle kernel paging request at virtual address ff7f9004
    [    9.804283] pgd = c0004000
    [    9.807000] [ff7f9004] *pgd=8dbcd811, *pte=00000000, *ppte=00000000
    [    9.813321] Internal error: Oops: 807 [#1] PREEMPT SMP ARM
    [    9.818828] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    9.828496] CPU: -59 PID: 0 Comm:  Tainted: G           O    4.9.28-geed43d1050 #1
    [    9.836096] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.842213] task: cf334d0c task.stack:   (null)
    [    9.846769] PC is at __dabt_svc+0xc/0x80
    [    9.850711] LR is at atomic_notifier_call_chain+0x44/0x50
    [    9.856132] pc : [<c010ca2c>]    lr : [<c014d4f8>]    psr: 60000193
    [    9.856132] sp : ff7f9004  ip : cce5dc68  fp : 752f7665
    [    9.867658] r10: 64752f63  r9 : 72732f74  r8 : 69672f2e
    [    9.872902] r7 : 2e3d454c  r6 : 49465f45  r5 : 444f430a  r4 : 333d5954
    [    9.879455] r3 : 00000000  r2 : 00000000  r1 : 00000002  r0 : c0c5018c
    [    9.886009] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    9.893260] Control: 10c5387d  Table: 8ce7406a  DAC: 00000051
    [    9.899027] Process  (pid: 0, stack limit = 0x00000210)
    [    9.904272] Stack: (0xff7f9004 to 0x00002000)
    [    9.908643] Backtrace: invalid frame pointer 0x752f7665
    [    9.913905] Code: e320f000 e24dd04c e31d0004 024dd004 (e88d1ffe)
    [    9.920025] ---[ end trace 2e4f2f77a560c586 ]---
    [    9.924661] Kernel panic - not syncing: Fatal exception in interrupt
    [    9.931043] Unable to handle kernel paging request at virtual address 1f7f8db4
    [    9.938293] pgd = c0004000
    [    9.941007] [1f7f8db4] *pgd=00000000
    [    9.944600] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
    [    9.949930] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    9.959590] CPU: -59 PID: 0 Comm:  Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    9.967188] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.973305] task: cf334d0c task.stack:   (null)
    [    9.977865] PC is at _clear_bit+0x20/0x38
    [    9.981893] LR is at smp_send_stop+0x3c/0xd4
    [    9.986179] pc : [<c03c8a78>]    lr : [<c010f250>]    psr: 60000193
    [    9.986179] sp : ff7f8db8  ip : 00000000  fp : ff7f8ddc
    [    9.997703] r10: c0991644  r9 : c0c07768  r8 : c010ca2e
    [   10.002947] r7 : 00000001  r6 : c010ca30  r5 : c0c0302c  r4 : ff7f8dbc
    [   10.009500] r3 : 00000020  r2 : 00000001  r1 : 1f7f8db4  r0 : 07fffffe
    [   10.016053] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   10.023303] Control: 10c5387d  Table: 8ce7406a  DAC: 00000051
    [   10.029070] Process  (pid: 0, stack limit = 0x00000210)
    [   10.034314] Stack: (0xff7f8db8 to 0x00002000)
    [   10.038684] Backtrace: invalid frame pointer 0xff7f8ddc
    [   10.043944] Code: e1a002a0 e0811100 f591f000 e1a03312 (e1912f9f)
    [   10.050061] ---[ end trace 2e4f2f77a560c587 ]---
    [   10.054695] Kernel panic - not syncing: Fatal exception in interrupt
    [   10.061074] Unable to handle kernel paging request at virtual address 1f7f8b4c
    [   10.068323] pgd = c0004000
    [   10.071035] [1f7f8b4c] *pgd=00000000
    [   10.074628] Internal error: Oops: 5 [#3] PREEMPT SMP ARM
    [   10.079958] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   10.089616] CPU: -59 PID: 0 Comm:  Tainted: G      D    O    4.9.28-geed43d1050 #1
    [   10.097214] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.103329] task: cf334d0c task.stack:   (null)
    [   10.107877] PC is at _clear_bit+0x20/0x38
    [   10.111900] LR is at smp_send_stop+0x3c/0xd4
    [   10.116186] pc : [<c03c8a78>]    lr : [<c010f250>]    psr: 60000193
    [   10.116186] sp : ff7f8b50  ip : 00000000  fp : ff7f8b74
    [   10.127710] r10: c0991644  r9 : c0c07768  r8 : c03c8a7a
    [   10.132954] r7 : 00000001  r6 : c03c8a7c  r5 : c0c0302c  r4 : ff7f8b54
    [   10.139506] r3 : 00000020  r2 : 00000001  r1 : 1f7f8b4c  r0 : 07fffffe
    [   10.146059] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   10.153308] Control: 10c5387d  Table: 8ce7406a  DAC: 00000051
    [   10.159075] Process  (pid: 0, stack limit = 0x00000210)
    [   10.164318] Stack: (0xff7f8b50 to 0x00002000)
    [   10.168689] Backtrace: invalid frame pointer 0xff7f8b74
    [   10.173948] Code: e1a002a0 e0811100 f591f000 e1a03312 (e1912f9f)
    [   10.180065] ---[ end trace 2e4f2f77a560c588 ]---
    [   10.184698] Kernel panic - not syncing: Fatal exception in interrupt
    [   10.191078] Unable to handle kernel paging request at virtual address 1f7f88e4
    [   10.198327] pgd = c0004000
    [   10.201041] [1f7f88e4] *pgd=00000000
    [   10.204635] Internal error: Oops: 5 [#4] PREEMPT SMP ARM
    [   10.209964] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   10.219621] CPU: -59 PID: 0 Comm:  Tainted: G      D    O    4.9.28-geed43d1050 #1
    [   10.227219] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.233336] task: cf334d0c task.stack:   (null)
    [   10.237884] PC is at _clear_bit+0x20/0x38
    [   10.241908] LR is at smp_send_stop+0x3c/0xd4
    [   10.246194] pc : [<c03c8a78>]    lr : [<c010f250>]    psr: 60000193
    [   10.246194] sp : ff7f88e8  ip : 00000000  fp : ff7f890c
    [   10.257718] r10: c0991644  r9 : c0c07768  r8 : c03c8a7a
    [   10.262961] r7 : 00000001  r6 : c03c8a7c  r5 : c0c0302c  r4 : ff7f88ec
    [   10.269512] r3 : 00000020  r2 : 00000001  r1 : 1f7f88e4  r0 : 07fffffe
    [   10.276064] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   10.283313] Control: 10c5387d  Table: 8ce7406a  DAC: 00000051
    [   10.289079] Process  (pid: 0, stack limit = 0x00000210)
    [   10.294323] Stack: (0xff7f88e8 to 0x00002000)
    [   10.298694] Backtrace: invalid frame pointer 0xff7f890c
    [   10.303955] Code: e1a002a0 e0811100 f591f000 e1a03312 (e1912f9f)
    [   10.310071] ---[ end trace 2e4f2f77a560c589 ]---
    [   10.314704] Kernel panic - not syncing: Fatal exception in interrupt
    [   10.321082] Unable to handle kernel paging request at virtual address 1f7f867c
    [   10.328331] pgd = c0004000
    [   10.331043] [1f7f867c] *pgd=00000000
    [   10.334637] Internal error: Oops: 5 [#5] PREEMPT SMP ARM
    [   10.339966] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   10.349623] CPU: -59 PID: 0 Comm:  Tainted: G      D    O    4.9.28-geed43d1050 #1
    [   10.357221] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.363337] task: cf334d0c task.stack:   (null)
    [   10.367886] PC is at _clear_bit+0x20/0x38
    [   10.371910] LR is at smp_send_stop+0x3c/0xd4
    [   10.376195] pc : [<c03c8a78>]    lr : [<c010f250>]    psr: 60000193
    [   10.376195] sp : ff7f8680  ip : 00000000  fp : ff7f86a4
    [   10.387718] r10: c0991644  r9 : c0c07768  r8 : c03c8a7a
    [   10.392962] r7 : 00000001  r6 : c03c8a7c  r5 : c0c0302c  r4 : ff7f8684
    [   10.399513] r3 : 00000020  r2 : 00000001  r1 : 1f7f867c  r0 : 07fffffe
    [   10.406065] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   10.413317] Control: 10c5387d  Table: 8ce7406a  DAC: 00000051
    [   10.419083] Process  (pid: 0, stack limit = 0x00000210)
    [   10.424326] Stack: (0xff7f8680 to 0x00002000)
    [   10.428697] Backtrace: invalid frame pointer 0xff7f86a4
    [   10.433958] Code: e1a002a0 e0811100 f591f000 e1a03312 (e1912f9f)
    [   10.440074] ---[ end trace 2e4f2f77a560c58a ]---
    [   10.444707] Kernel panic - not syncing: Fatal exception in interrupt
    [   10.451086] Unable to handle kernel paging request at virtual address 1f7f8414
    [    2.442187] systemd-sysv-ge: 187 output lines suppressed due to ratelimiting
    [    2.886280] cmemk: loading out-of-tree module taints kernel.
    [    2.892978] CMEMK module: reference Linux version 4.9.28
    [    2.900816] allocated heap buffer 0x40500000 of size 0x100000
    [    2.911834] cmemk initialized
    [    2.919741] cryptodev: driver 1.8 loaded.
    [    2.947493] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.733511] udevadm[147]: calling: trigger
    [    5.761000] udevadm[147]:   device-enumerator: scanning /sys/bus
    [    5.850941] udevadm[157]: calling: trigger
    [    5.863709] udevadm[157]: device-enumerator: scan all dirs
    [    5.890830] udevadm[157]:   device-enumerator: scanning /sys/bus
    [    5.953024] udevadm[157]:   device-enumerator: scanning /sys/class
    [    6.161711] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    6.169857] pgd = ccf98000
    [    6.172573] [00000000] *pgd=00000000
    [    6.176175] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
    [    6.178025] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [    6.178028] pgd = ccc34000
    [    6.178032] [00000000] *pgd=00000000
    [    6.195917] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.205582] CPU: 1 PID: 157 Comm: udevadm Tainted: G           O    4.9.28-geed43d1050 #1
    [    6.213793] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.219909] task: ccf68640 task.stack: ccf00000
    [    6.224467] PC is at __wake_up_common+0x28/0x94
    [    6.229015] LR is at __wake_up+0x40/0x54
    [    6.232954] pc : [<c016ea18>]    lr : [<c016eac4>]    psr: 600d0093
    [    6.232954] sp : ccf01cf0  ip : 00000000  fp : ccf01d24
    [    6.244479] r10: 00000003  r9 : 00000000  r8 : ccf01d5c
    [    6.249722] r7 : c0c02668  r6 : 00000003  r5 : a00d0013  r4 : c0c02664
    [    6.256274] r3 : 00000000  r2 : 00000001  r1 : 00000003  r0 : c0c02664
    [    6.262828] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.270079] Control: 10c5387d  Table: 8cf9806a  DAC: 00000051
    [    6.275846] Process udevadm (pid: 157, stack limit = 0xccf00210)
    [    6.281875] Stack: (0xccf01cf0 to 0xccf02000)
    [    6.286250] 1ce0:                                     ccf01d24 00000001 c0243708 c0c02664
    [    6.294463] 1d00: a00d0013 00000003 00000001 ccf01d5c ccf01e90 00000000 ccf01d54 ccf01d28
    [    6.302675] 1d20: c016eac4 c016e9fc ccf01d5c ccf01d38 c024709c c8c0341c 00000003 ccf01da8
    [    6.310887] 1d40: cd5a6660 00004000 ccf01d74 ccf01d58 c016ed18 c016ea90 c8c033b0 c8c0341c
    [    6.319100] 1d60: 00000003 00000000 ccf01d8c ccf01d78 c016efbc c016ece4 c8c033b0 c8c03400
    [    6.327311] 1d80: ccf01da4 ccf01d90 c024772c c016efa4 c8c033b0 cd0fdc30 ccf01dcc ccf01da8
    [    6.335522] 1da0: c0292680 c02476f8 5954104a 376e461c cd8cf2d0 cd0fdc30 cd7d62a8 cd5b0f78
    [    6.343733] 1dc0: ccf01dec ccf01dd0 c02934d0 c02925b4 cd7d62a8 cd5b0f78 cd5b0fe8 cd5a6660
    [    6.351945] 1de0: ccf01e2c ccf01df0 c0236c28 c029346c ccf01e64 00000000 ccf01df8 ccf01df8
    [    6.360157] 1e00: ccf01e88 ccf01e88 00000000 00000000 00004000 ccf01f70 7f865960 00000063
    [    6.368368] 1e20: ccf01e64 ccf01e30 c0237b88 c0236ba4 ccf01e64 ccf01e40 c0238e3c ccf01e88
    [    6.376581] 1e40: ccf01e88 00000000 ccf01f70 00004000 ccf01f70 7f865960 ccf01e84 ccf01e68
    [    6.384793] 1e60: c023956c c0237990 00004000 cccea000 ccf01e88 00004000 ccf01f34 ccf01e88
    [    6.393005] 1e80: c023baf4 c0239508 cd315250 cd5a6660 bd190bd8 00000005 cccea01f ccf01ea8
    [    6.401216] 1ea0: cd3326d0 cd547550 cd5b0f78 00004000 c0292474 00000164 00000000 00000000
    [    6.409428] 1ec0: 00000000 ccf01ec8 ccc3eb58 00000011 00000002 00000ff0 00000000 cccea000
    [    6.417640] 1ee0: c0c03308 bee6a740 ccf01f6c 00004000 7f865960 00000063 cccea000 00000000
    [    6.425853] 1f00: c023b830 00000002 ffffff9c 00004000 ffffff9c 00004000 ffffff9c ccf01f70
    [    6.434064] 1f20: bee6a740 ccf01f6c ccf01f5c ccf01f38 c023bc24 c023ba68 00000000 fffffffe
    [    6.442276] 1f40: ccf01f94 00000064 00004000 ffffff9c ccf01fa4 ccf01f60 c0231de8 c023bbe4
    [    6.450487] 1f60: ccf01f6c 00000004 00000100 00000000 7f865858 00020000 00000008 00000064
    [    6.458698] 1f80: 7f865960 00000063 0000014c c0108024 ccf00000 00000000 00000000 ccf01fa8
    [    6.466909] 1fa0: c0107e60 c0231da8 00000064 7f865960 ffffff9c bee6a740 7f865960 00000063
    [    6.475122] 1fc0: 00000064 7f865960 00000063 0000014c bee6a6e0 7f6900a8 bee6a740 bee6a714
    [    6.483333] 1fe0: 7f686f94 bee6a6b4 7f6691a0 b6e78268 200d0030 ffffff9c 00000000 00000000
    [    6.491541] Backtrace:
    [    6.494005] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.501696]  r10:00000000 r9:ccf01e90 r8:ccf01d5c r7:00000001 r6:00000003 r5:a00d0013
    [    6.509556]  r4:c0c02664
    [    6.512100] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.519527]  r8:00004000 r7:cd5a6660 r6:ccf01da8 r5:00000003 r4:c8c0341c
    [    6.526256] [<c016ecd8>] (__wake_up_bit) from [<c016efbc>] (wake_up_bit+0x24/0x28)
    [    6.533860] [<c016ef98>] (wake_up_bit) from [<c024772c>] (unlock_new_inode+0x40/0x64)
    [    6.541720]  r5:c8c03400 r4:c8c033b0
    [    6.545316] [<c02476ec>] (unlock_new_inode) from [<c0292680>] (kernfs_get_inode+0xd8/0x12c)
    [    6.553700]  r5:cd0fdc30 r4:c8c033b0
    [    6.557291] [<c02925a8>] (kernfs_get_inode) from [<c02934d0>] (kernfs_iop_lookup+0x70/0xa4)
    [    6.565676]  r6:cd5b0f78 r5:cd7d62a8 r4:cd0fdc30
    [    6.570313] [<c0293460>] (kernfs_iop_lookup) from [<c0236c28>] (lookup_slow+0x90/0x144)
    [    6.578350]  r7:cd5a6660 r6:cd5b0fe8 r5:cd5b0f78 r4:cd7d62a8
    [    6.584033] [<c0236b98>] (lookup_slow) from [<c0237b88>] (walk_component+0x204/0x2d0)
    [    6.591896]  r10:00000063 r9:7f865960 r8:ccf01f70 r7:00004000 r6:00000000 r5:00000000
    [    6.599756]  r4:ccf01e88
    [    6.602299] [<c0237984>] (walk_component) from [<c023956c>] (path_lookupat+0x70/0x11c)
    [    6.610248]  r9:7f865960 r8:ccf01f70 r7:00004000 r6:ccf01f70 r5:00000000 r4:ccf01e88
    [    6.618025] [<c02394fc>] (path_lookupat) from [<c023baf4>] (filename_lookup+0x98/0xf4)
    [    6.625973]  r7:00004000 r6:ccf01e88 r5:cccea000 r4:00004000
    [    6.631655] [<c023ba5c>] (filename_lookup) from [<c023bc24>] (user_path_at_empty+0x4c/0x54)
    [    6.640041]  r8:ccf01f6c r7:bee6a740 r6:ccf01f70 r5:ffffff9c r4:00004000
    [    6.646773] [<c023bbd8>] (user_path_at_empty) from [<c0231de8>] (SyS_readlinkat+0x4c/0x100)
    [    6.655157]  r6:ffffff9c r5:00004000 r4:00000064
    [    6.659800] [<c0231d9c>] (SyS_readlinkat) from [<c0107e60>] (ret_fast_syscall+0x0/0x3c)
    [    6.667838]  r10:00000000 r9:ccf00000 r8:c0108024 r7:0000014c r6:00000063 r5:7f865960
    [    6.675698]  r4:00000064
    [    6.678241] Code: e1a0a001 e50b2030 e1a09003 e59b8004 (e59c4000)
    [    6.684360] ---[ end trace 46548e0ea6dd6d03 ]---
    [    6.684364] Internal error: Oops: 80000005 [#2] PREEMPT SMP ARM
    [    6.684382] Modules linked in: sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)
    [    6.684387] CPU: 0 PID: 110 Comm: systemd-journal Tainted: G      D    O    4.9.28-geed43d1050 #1
    [    6.684389] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.684392] task: cd3a5dc0 task.stack: ccdfe000
    [    6.684397] PC is at 0x0
    [    6.684403] LR is at __wake_up_common+0x58/0x94
    [    6.684408] pc : [<00000000>]    lr : [<c016ea48>]    psr: 200f0193
    [    6.684408] sp : ccdffda8  ip : c08124f4  fp : ccdffddc
    [    6.684411] r10: 00000003  r9 : 00000000  r8 : ccdffe14
    [    6.684414] r7 : c0c023f8  r6 : 00000000  r5 : 00000000  r4 : fffffff4
    [    6.684417] r3 : ccdffe14  r2 : 00000000  r1 : 00000003  r0 : c08124f4
    [    6.684421] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    6.684424] Control: 10c5387d  Table: 8cc3406a  DAC: 00000051
    [    6.684427] Process systemd-journal (pid: 110, stack limit = 0xccdfe210)
    [    6.684430] Stack: (0xccdffda8 to 0xcce00000)
    [    6.684436] fda0:                   ccdffe04 00000001 c01f087c c0c023f4 200f0113 00000003
    [    6.684443] fdc0: 00000001 ccdffe14 00000200 00000055 ccdffe0c ccdffde0 c016eac4 c016e9fc
    [    6.684449] fde0: ccdffe14 c0189d68 ccdffe0c ce1e3628 ccc4d948 00000040 ccc4d948 00000200
    [    6.684455] fe00: ccdffe2c ccdffe10 c016ed18 c016ea90 ccdffe2c ce1e3628 00000000 00000000
    [    6.684461] fe20: ccdffe44 ccdffe30 c01d5c9c c016ece4 cccddc34 ccc4d948 ccdffeac ccdffe48
    [    6.684468] fe40: c020418c c01d5c64 00000000 ccdffe58 c0284cb4 c01b8f30 ccfc6100 00000000
    [    6.684473] fe60: ce1e3628 ccc4d948 b67db000 00000055 ccc36d98 ccc5576c ccc3cc74 00000000
    [    6.684480] fe80: ccdffeac ccdfffb0 cd3a5dc0 ccc3cc40 00000817 b67db000 ccc3cc78 00000055
    [    6.684486] fea0: ccdffefc ccdffeb0 c0115e40 c02039ec ccdffedc ccdffec0 c03d72e8 c07cd1dc
    [    6.684492] fec0: cd69faa0 c09a4d80 00000800 c09a4d80 cd3153c0 c0c08034 00000817 c0115bbc
    [    6.684498] fee0: b67db000 ccdfffb0 bed2c7b0 2b6217db ccdfffac ccdfff00 c010130c c0115bc8
    [    6.684504] ff00: c024d968 c024d764 ccdfff54 ccdfff18 c022e600 c024d948 00000020 00000000
    [    6.684510] ff20: c0149ee4 ccfcd848 ccfcd840 cd3a6284 c0c51780 cd3a62a0 cd3a5dc0 00000000
    [    6.684516] ff40: ccdfe000 00000000 ccdfff64 ccdfff58 c022e700 c022e4d0 ccdfff8c ccdfff68
    [    6.684522] ff60: c014a058 c022e6fc ccdfe000 c0108024 ccdfe000 c0108024 ccdfffb0 00000006
    [    6.684528] ff80: ccdfffac ccdfff90 c010b888 b6e08520 000f0010 ffffffff 10c5387d 10c5387d
    [    6.684534] ffa0: 00000000 ccdfffb0 c010cea0 c01012d4 b67daeb0 bed2bee0 00000160 00000014
    [    6.684540] ffc0: 000001a0 b67dae70 7f68c3c8 bed2bf18 ffffffe0 bed2c7b0 2b6217db fde8a772
    [    6.684546] ffe0: b67db010 bed2bd0c 7f6678b4 b6e08520 000f0010 ffffffff 64100000 c3002000
    [    6.684549] Backtrace:
    [    6.684556] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [    6.684562]  r10:00000055 r9:00000200 r8:ccdffe14 r7:00000001 r6:00000003 r5:200f0113
    [    6.684565]  r4:c0c023f4
    [    6.684571] [<c016ea84>] (__wake_up) from [<c016ed18>] (__wake_up_bit+0x40/0x48)
    [    6.684577]  r8:00000200 r7:ccc4d948 r6:00000040 r5:ccc4d948 r4:ce1e3628
    [    6.684592] [<c016ecd8>] (__wake_up_bit) from [<c01d5c9c>] (unlock_page+0x44/0x48)
    [    6.684604] [<c01d5c58>] (unlock_page) from [<c020418c>] (handle_mm_fault+0x7ac/0xcd8)
    [    6.684607]  r5:ccc4d948 r4:cccddc34
    [    6.684616] [<c02039e0>] (handle_mm_fault) from [<c0115e40>] (do_page_fault+0x284/0x354)
    [    6.684622]  r10:00000055 r9:ccc3cc78 r8:b67db000 r7:00000817 r6:ccc3cc40 r5:cd3a5dc0
    [    6.684625]  r4:ccdfffb0
    [    6.684631] [<c0115bbc>] (do_page_fault) from [<c010130c>] (do_DataAbort+0x44/0xc4)
    [    6.684637]  r10:2b6217db r9:bed2c7b0 r8:ccdfffb0 r7:b67db000 r6:c0115bbc r5:00000817
    [    6.684639]  r4:c0c08034
    [    6.684646] [<c01012c8>] (do_DataAbort) from [<c010cea0>] (__dabt_usr+0x40/0x60)
    [    6.684649] Exception stack(0xccdfffb0 to 0xccdffff8)
    [    6.684654] ffa0:                                     b67daeb0 bed2bee0 00000160 00000014
    [    6.684660] ffc0: 000001a0 b67dae70 7f68c3c8 bed2bf18 ffffffe0 bed2c7b0 2b6217db fde8a772
    [    6.684665] ffe0: b67db010 bed2bd0c 7f6678b4 b6e08520 000f0010 ffffffff
    [    6.684669]  r8:10c5387d r7:10c5387d r6:ffffffff r5:000f0010 r4:b6e08520
    [    6.684674] Code: bad PC value
    [    6.684678] ---[ end trace 46548e0ea6dd6d04 ]---
    [    6.684689] note: systemd-journal[110] exited with preempt_count 1
    [    6.687370] systemd-journal: 26 output lines suppressed due to ratelimiting
    [    7.094455] note: udevadm[157] exited with preempt_count 2
  • Hi Kemal,
    I was able to get more info from udev by adding a --verbose to the ExecStart line in systemd-udev-trigger.service. It was not there by default.
    Typically what I'm seeing now is
    [    5.748436] udevadm[151]: Found container virtualization none
    [    5.791120] udevadm[151]: calling: trigger
    [    5.821022] udevadm[151]:   device-enumerator: scanning /sys/bus
    [    5.851205] udevadm[151]: /sys/bus/clockevents
    [    5.880585] udevadm[151]: /sys/bus/clocksource
    [    5.920533] udevadm[151]: /sys/bus/container
    [    5.950615] udevadm[151]: /sys/bus/cpu
    [    5.980525] udevadm[151]: /sys/bus/edac
    [    6.010465] udevadm[151]: /sys/bus/event_source
    [    6.040485] [    6.148456] Unable to handle kernel paging request at virtual address 5954104a
    udevadm[151]: /sys/bus/gpio
    [    6.156867] pgd = ccfe4000
    [    6.162326] [5954104a] *pgd=00000000[    6.162933] Unable to handle kernel paging request at virtual address 02180020
    [    6.162937] pgd = ccecc000
    [    6.162940] [02180020] *pgd=00000000
    [    6.162957] Internal error: Oops: 80000005 [#1] PREEMPT SMP ARM
    [    6.162961] Modules linked in:
    [    6.162966]  sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cryptodev(O) cmemk(O)[    6.162991] CPU: 0 PID: 139 Comm: ldconfig Tainted: G           O    4.9.28-geed43d1050 #1
    From several runs of this, it always prints:
    [    5.930488] udevadm[151]: Found container virtualization none
    and then prints a few of the /sys/bus/* lines and then either crashes with the kernel paging request fail or just hangs with no message.
    Comparing this with my SD card with the base rootfs, I never see the "virtualization none" line and udevadm finishes successfully. What could be the cause of the "virtualization none" message?
  • The Oops occurs on net/sched/sch_fq_codel.ko FQ controlled delay packet scheduling algorithm module loading. Regarding Synchronize System and HW clocks and omap_i2c 48070000.i2c: controller timed out messages. Do you have crystal oscillator and properly configured tps659038 on that board?
  • How do you know the Oops occurs on sch_fq_codel.ko? What is this responsible for, and what could be causing it to Oops? I saw that this kernel module was also on the base rootfs on another SD card which did boot on my custom board. The HW clocks failure message was also on this base rootfs and it continued to boot.
    Regarding your question, the RTC chip is on board (same as EVM) but the i2c line is disabled in the linux device tree. Could this i2c/RTC clock issue be related to the crash?
    Could the difference in SD card cause this sort of kernel issue?
    Thanks again, I really appreciate your help.
  • Can you append nomodule to the optargs and see if there any Oops?
  • Hi Kemal,
    I appended nomodule to optargs, but same sort of failures are occurring. Sometimes I don't get any kernel oops, but simply hangs after the HW clock fail message or in the middle of udevadm messages. I've attached some updated logs. What is the main difference between arago-base-tisdk-image-am57xx-evm and tisdk-rootfs-image-am57xx-evm that could be causing this sort of kernel Oops? How am I able to get to the command line on the same hardware with a different rootfs?
    Could it be a memory virtualization related issue? The main difference between the AM5728 EVM and our custom board is that ours has 256 MB of RAM, and we have done EMIF configurations through u-boot.
    I am wondering if there is some memory overlap issues. Do you have any resources on RAM usage, for example: how much memory the kernel takes, where the temporary rootfs is placed, and if there are any other protected areas of the RAM that the kernel uses?
    Logs (both have been ran with nomodule):
    [    2.253878] systemd-sysv-ge: 187 output lines suppressed due to ratelimiting
    [    3.009795] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
             Starting Opkg first boot configure...
    ti_log_1.txt
    Thanks again for your consistent replies,
  • Hi Kemal,
    Just another update, I created a new SD card following the create-sdcard.sh script and then simply copied over my u-boot files, kernel and device tree. Now the boot process seems to progress significantly past udev and I am also able to access the rescue mode terminal using the optargs S, command you mentioned.
    However I am still getting faults after I leave the rescue mode terminal. I have attached an updated log. I noticed the "Kernel BUG at c0154638", how can I track this down? I don't always get this BUG, sometimes it will behave like so:
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2# exit
    [   13.779934] cmemk: disagrees about version of symbol module_layout
    [   13.791072] cryptodev: disagrees about version of symbol module_layout
    [   13.798119] gdbserverproxy: disagrees about version of symbol module_layout
    [   13.806990] uio: disagrees about version of symbol module_layout
    [   14.164355] net eth1: initializing cpsw version 1.15 (0)
    [   14.194677] net eth0: initialized cpsw ale version 1.4
    [   14.194684] net eth0: ALE Table size 1024
    [   14.197572] net eth1: phy "/ocp/ethernet@48484000/mdio@48485000/ethernet-phy@2" not found on slave 1
    [   14.205875] bluetooth: disagrees about version of symbol module_layout
    [   14.215275] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   14.280025] net eth0: initializing cpsw version 1.15 (0)
    [   14.282865] net eth0: phy "/ocp/ethernet@48484000/mdio@48485000/ethernet-phy@1" not found on slave 0
    [   14.287707] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   14.592511] xfrm_algo: disagrees about version of symbol module_layout
    [   14.720819] Unable to handle kernel paging request at virtual address 72617770
    [   14.728102] pgd = cb250000
    [   14.730817] [72617770] *pgd=00000000
    [   14.734422] Unable to handle kernel paging request at virtual address 65687420
    [   14.741672] pgd = cb250000
    [   14.744389] [65687420] *pgd=00000000
    [   14.747986] Unable to handle kernel paging request at virtual address 65687420
    [   14.755237] pgd = cb250000
    [   14.757951] [65687420] *pgd=00000000
    [   14.761553] Unable to handle kernel paging request at virtual address 65687420
    [   14.768804] pgd = cb250000
    [   14.771517] [65687420] *pgd=00000000
    [   14.775112] Unable to handle kernel paging request at virtual address 65687420
    [   14.782362] pgd = cb250000
    [   14.785075] [65687420] *pgd=00000000
    [   14.788671] Unable to handle kernel paging request at virtual address 65687420
    [   14.795924] pgd = cb250000
    [   14.798637] [65687420] *pgd=00000000
    [   14.802232] Unable to handle kernel paging request at virtual address 65687420
    [   14.809482] pgd = cb250000
    [   14.812195] [65687420] *pgd=00000000
    [   14.815788] Unable to handle kernel paging request at virtual address 65687420
    [   14.820948] Unable to handle kernel paging request at virtual address 72617770
    [   14.820952] pgd = cce38000
    [   14.820957] [72617770] *pgd=00000000
    [   14.836572] pgd = cb250000
    [   14.839284] [65687420] *pgd=00000000
    [   14.842876] Unable to handle kernel paging request at virtual address 65687420
    [   14.850125] pgd = cb250000
    [   14.852836] [65687420] *pgd=00000000
    [    3.059498] systemd[1]: Set hostname to <am57xx-evm>.
    [    3.317624] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    3.326572] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    3.334306] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    3.341756] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    3.351250] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [    3.400540] systemd[1]: Listening on Journal Socket.
    [    3.436812] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.613090] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.704509] cmemk: disagrees about version of symbol module_layout
    [    3.714226] cryptodev: disagrees about version of symbol module_layout
    [    3.726115] gdbserverproxy: disagrees about version of symbol module_layout
    [    3.744225] uio: disagrees about version of symbol module_layout
    [    4.187893] sch_fq_codel: disagrees about version of symbol module_layout
    [    4.711142] systemd-journald[111]: Received request to flush runtime journal from PID 1
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target System Initialization.
    [    5.349705] rtc_palmas: disagrees about version of symbol module_layout
    [    5.359273] extcon_core: disagrees about version of symbol module_layout
    [    5.375518] extcon_core: disagrees about version of symbol module_layout
    [    5.384822] crypto_engine: disagrees about version of symbol module_layout
    [    5.406463] crypto_engine: disagrees about version of symbol module_layout
    [    5.427334] pixcir_i2c_ts: disagrees about version of symbol module_layout
    [    5.446174] pixcir_i2c_ts: disagrees about version of symbol module_layout
    [    5.483509] rtc_omap: disagrees about version of symbol module_layout
    [    5.516819] rtc_omap: disagrees about version of symbol module_layout
    [    5.520784] extcon_core: disagrees about version of symbol module_layout
    [    5.537470] ti_vpdma: disagrees about version of symbol module_layout
    [    5.550787] extcon_core: disagrees about version of symbol module_layout
    [    5.594383] ti_vpdma: disagrees about version of symbol module_layout
    [  OK  ] Started Rescue Shell.
    [    5.647375] rtc_palmas: disagrees about version of symbol module_layout
             Starting LSB: Unmount all network filesystems...
    [    5.745862] omap_wdt: disagrees about version of symbol module_layout
    [    5.757813] omap_sham: disagrees about version of symbol module_layout
    [    5.773916] omap_sham: disagrees about version of symbol module_layout
    [    5.784764] crypto_engine: disagrees about version of symbol module_layout
    [    5.787579] crypto_engine: disagrees about version of symbol module_layout
    [    5.817657] remoteproc: disagrees about version of symbol module_layout
    [    5.818550] remoteproc: disagrees about version of symbol module_layout
    [    5.819158] pvrsrvkm: disagrees about version of symbol module_layout
    [    5.842578] crypto_engine: disagrees about version of symbol module_layout
    [    5.850278] remoteproc: disagrees about version of symbol module_layout
    [    5.854127] pvrsrvkm: disagrees about version of symbol module_layout
    [    5.856924] remoteproc: disagrees about version of symbol module_layout
    [    5.875190] crypto_engine: disagrees about version of symbol module_layout
    [    5.965782] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
    [    5.996370] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
    [  OK  ] Started LSB: Unmount all network filesystems.
    [    6.246593] omap_wdt: disagrees about version of symbol module_layout
    [    6.420366] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Created slice system-systemd\x2dbacklight.slice.
             Starting Load/Save Screen Backlight...htness of backlight:backlight...
    [  OK  ] Reached target Rescue Mode.
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
    [  OK  ] Started Update UTMP about System Runlevel Changes.
    Welcome to rescue mode! After logging in, type "journalctl -xb" Press Enter for maintenance
    (or press Control-D to continue):
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2# cd /.
    sh-3.2# ls
    bin      etc      lib      opt      sbin     tmp      www
    boot     home     media    proc     srv      usr
    dev      include  mnt      run      sys      var
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2#
    sh-3.2# exit
    [   26.457110] cmemk: disagrees about version of symbol module_layout
    [   26.464804] cryptodev: disagrees about version of symbol module_layout
    [   26.479487] gdbserverproxy: disagrees about version of symbol module_layout
    [   26.487008] uio: disagrees about version of symbol module_layout
    [   26.793445] bluetooth: disagrees about version of symbol module_layout
    [   26.936487] net eth1: initializing cpsw version 1.15 (0)
    [   26.979104] net eth0: initialized cpsw ale version 1.4
    [   26.984286] net eth0: ALE Table size 1024
    [   27.044750] net eth1: phy "/ocp/ethernet@48484000/mdio@48485000/ethernet-phy@2" not found on slave 1
    [   27.125672] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   27.167818] net eth0: initializing cpsw version 1.15 (0)
    [   27.195647] net eth0: phy "/ocp/ethernet@48484000/mdio@48485000/ethernet-phy@1" not found on slave 0
    [   27.227852] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   27.570699] xfrm_algo: disagrees about version of symbol module_layout
    [   27.687293] ------------[ cut here ]------------
    [   27.691947] Kernel BUG at c0154638 [verbose debug info unavailable]
    [   27.698238] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
    [   27.704092] Modules linked in:
    [   27.707166] CPU: 0 PID: 550 Comm: find Not tainted 4.9.28-geed43d1050 #1
    [   27.713892] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   27.720007] task: cadd0640 task.stack: cac4c000
    [   27.724563] PC is at select_fallback_rq+0x180/0x1b0
    [   27.729459] LR is at select_fallback_rq+0xc0/0x1b0
    [   27.734267] pc : [<c0154638>]    lr : [<c0154578>]    psr: 60070193
    [   27.734267] sp : cac4dcf8  ip : 00000000  fp : cac4dd2c
    [   27.745791] r10: c0c0314c  r9 : 00000002  r8 : c0c03038
    [   27.751032] r7 : c0c0302c  r6 : cd3a12c0  r5 : cd3a1568  r4 : 00000002
    [   27.757583] r3 : 00000002  r2 : 00000002  r1 : 00000002  r0 : 00000002
    [   27.764136] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   27.771384] Control: 10c5387d  Table: 8ad8006a  DAC: 00000051
    [   27.777150] Process find (pid: 550, stack limit = 0xcac4c210)
    [   27.782915] Stack: (0xcac4dcf8 to 0xcac4e000)
    [   27.787287] dce0:                                                       cd6fb4c8 00000000
    [   27.795496] dd00: cac4dd2c cd3a12c0 cd3a17a0 80070193 00000000 00000000 cd3a1568 00000001
    [   27.803705] dd20: cac4dd64 cac4dd30 c0155094 c01544c4 cd78a5a0 00000001 cd163af0 cd3c7e24
    [   27.811914] dd40: c016f048 00000000 cd29b6cc 00000000 00000000 00000001 cac4dd74 cac4dd68
    [   27.820123] dd60: c01551a0 c0154e2c cac4dd8c cac4dd78 c016f05c c0155198 cd29b6c0 c016f048
    [   27.828333] dd80: cac4ddc4 cac4dd90 c016ea48 c016f054 c0a14000 00000001 b6f82000 cd29b6c8
    [   27.836542] dda0: a0070193 00000001 00000001 00000000 cda89a00 20660000 cac4ddf4 cac4ddc8
    [   27.844751] ddc0: c016eac4 c016e9fc 00000000 000892fb c0c4ba80 cd29b834 cd29b8a4 cd29b400
    [   27.852960] dde0: 00000000 00000000 cac4de04 cac4ddf8 c0619ea8 c016ea90 cac4de2c cac4de08
    [   27.861170] de00: c0619a74 c0619e88 cd29b700 ffffffff cd29b834 00000000 00000000 cda89a00
    [   27.869379] de20: cac4de4c cac4de30 c0631ff4 c06199ac cd29b700 cd29b700 337f0133 00000000
    [   27.877588] de40: cac4de64 cac4de50 c063205c c0631f98 00000001 cd29b700 cac4dea4 cac4de68
    [   27.885797] de60: c0632304 c0632004 00000001 00000000 c09fd278 c0c02d00 ccfb3f78 cd313300
    [   27.894006] de80: cda89a00 00000000 cac4def4 00000154 cda89a00 c0c1a27d cac4deec cac4dea8
    [   27.902214] dea0: c0180ab4 c0632258 cac4deec cac4deb8 c04afb50 c099d950 c099d93c c099d914
    [   27.910423] dec0: 00000000 cda89a00 cda89a00 c0c224f0 00000000 cd808000 bedc48f8 00000016
    [   27.918633] dee0: cac4df0c cac4def0 c0180b5c c0180a0c cd6fb4c8 00000000 cda89a00 cda89a60
    [   27.926842] df00: cac4df2c cac4df10 c0180bd8 c0180b44 cda89a00 cda89a60 c0c224f0 00000000
    [   27.935052] df20: cac4df4c cac4df30 c018426c c0180ba4 c0b5ad7c 00000154 00000000 00000000
    [   27.943260] df40: cac4df5c cac4df50 c017fcdc c01841b8 cac4df84 cac4df60 c0180264 c017fcbc
    [   27.951469] df60: c0c03414 fa21200c cac4dfb0 fa212000 fa213000 bedc48f8 cac4dfac cac4df88
    [   27.959678] df80: c010150c c018020c b6eb9830 60070030 ffffffff 10c5387d 10c5387d bedc48f8
    [   27.967887] dfa0: 00000000 cac4dfb0 c010cf14 c01014d8 b6f9e59b b6eb8774 bedc48c8 00000000
    [   27.976096] dfc0: 00000073 bedc49e0 00000000 bedc4420 ffffffff bedc48f8 00000016 bedc44a0
    [   27.984305] dfe0: ffffffff bedc4400 b6eb8d3d b6eb9830 60070030 ffffffff 00000000 00000000
    [   27.992512] Backtrace:
    [   27.994977] [<c01544b8>] (select_fallback_rq) from [<c0155094>] (try_to_wake_up+0x274/0x2b0)
    [   28.003449]  r10:00000001 r9:cd3a1568 r8:00000000 r7:00000000 r6:80070193 r5:cd3a17a0
    [   28.011307]  r4:cd3a12c0
    [   28.013850] [<c0154e20>] (try_to_wake_up) from [<c01551a0>] (default_wake_function+0x14/0x18)
    [   28.022408]  r10:00000001 r9:00000000 r8:00000000 r7:cd29b6cc r6:00000000 r5:c016f048
    [   28.030265]  r4:cd3c7e24
    [   28.032809] [<c015518c>] (default_wake_function) from [<c016f05c>] (autoremove_wake_function+0x14/0x3c)
    [   28.042240] [<c016f048>] (autoremove_wake_function) from [<c016ea48>] (__wake_up_common+0x58/0x94)
    [   28.051233]  r5:c016f048 r4:cd29b6c0
    [   28.054820] [<c016e9f0>] (__wake_up_common) from [<c016eac4>] (__wake_up+0x40/0x54)
    [   28.062506]  r10:20660000 r9:cda89a00 r8:00000000 r7:00000001 r6:00000001 r5:a0070193
    [   28.070363]  r4:cd29b6c8
    [   28.072909] [<c016ea84>] (__wake_up) from [<c0619ea8>] (mmc_wait_data_done+0x2c/0x30)
    [   28.080768]  r8:00000000 r7:00000000 r6:cd29b400 r5:cd29b8a4 r4:cd29b834
    [   28.087497] [<c0619e7c>] (mmc_wait_data_done) from [<c0619a74>] (mmc_request_done+0xd4/0x174)
    [   28.096059] [<c06199a0>] (mmc_request_done) from [<c0631ff4>] (omap_hsmmc_request_done+0x68/0x6c)
    [   28.104965]  r9:cda89a00 r8:00000000 r7:00000000 r6:cd29b834 r5:ffffffff r4:cd29b700
    [   28.112741] [<c0631f8c>] (omap_hsmmc_request_done) from [<c063205c>] (omap_hsmmc_cmd_done+0x64/0xfc)
    [   28.121908]  r7:00000000 r6:337f0133 r5:cd29b700 r4:cd29b700
    [   28.127589] [<c0631ff8>] (omap_hsmmc_cmd_done) from [<c0632304>] (omap_hsmmc_irq+0xb8/0x32c)
    [   28.136057]  r5:cd29b700 r4:00000001
    [   28.139646] [<c063224c>] (omap_hsmmc_irq) from [<c0180ab4>] (__handle_irq_event_percpu+0xb4/0x138)
    [   28.148640]  r10:c0c1a27d r9:cda89a00 r8:00000154 r7:cac4def4 r6:00000000 r5:cda89a00
    [   28.156497]  r4:cd313300
    [   28.159038] [<c0180a00>] (__handle_irq_event_percpu) from [<c0180b5c>] (handle_irq_event_percpu+0x24/0x60)
    [   28.168731]  r10:00000016 r9:bedc48f8 r8:cd808000 r7:00000000 r6:c0c224f0 r5:cda89a00
    [   28.176587]  r4:cda89a00
    [   28.179128] [<c0180b38>] (handle_irq_event_percpu) from [<c0180bd8>] (handle_irq_event+0x40/0x64)
    [   28.188032]  r5:cda89a60 r4:cda89a00
    [   28.191621] [<c0180b98>] (handle_irq_event) from [<c018426c>] (handle_fasteoi_irq+0xc0/0x190)
    [   28.200178]  r7:00000000 r6:c0c224f0 r5:cda89a60 r4:cda89a00
    [   28.205860] [<c01841ac>] (handle_fasteoi_irq) from [<c017fcdc>] (generic_handle_irq+0x2c/0x3c)
    [   28.214504]  r7:00000000 r6:00000000 r5:00000154 r4:c0b5ad7c
    [   28.220185] [<c017fcb0>] (generic_handle_irq) from [<c0180264>] (__handle_domain_irq+0x64/0xbc)
    [   28.228919] [<c0180200>] (__handle_domain_irq) from [<c010150c>] (gic_handle_irq+0x40/0x7c)
    [   28.237301]  r9:bedc48f8 r8:fa213000 r7:fa212000 r6:cac4dfb0 r5:fa21200c r4:c0c03414
    [   28.245075] [<c01014cc>] (gic_handle_irq) from [<c010cf14>] (__irq_usr+0x54/0x80)
    [   28.252585] Exception stack(0xcac4dfb0 to 0xcac4dff8)
    [   28.257654] dfa0:                                     b6f9e59b b6eb8774 bedc48c8 00000000
    [   28.265863] dfc0: 00000073 bedc49e0 00000000 bedc4420 ffffffff bedc48f8 00000016 bedc44a0
    [   28.274071] dfe0: ffffffff bedc4400 b6eb8d3d b6eb9830 60070030 ffffffff
    [   28.280711]  r9:bedc48f8 r8:10c5387d r7:10c5387d r6:ffffffff r5:60070030 r4:b6eb9830
    [   28.288485] Code: 0a000007 3a000002 e3590002 1affffca (e7f001f2)
    [   28.294604] ---[ e------[ cut here ]------------
    [   28.294610] Kernel BUG at c0154638 [verbose debug[   28.294613] Internal error: Oops - BUG: 0 [#2] PREEMPT SMP ARM
    ble]
    [   28.294618] Modules linked in:
    [   28.294622] CPU: 1 PID: 576 Com[   28.294625] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   28.294627] task: cd3a3e80 task.stack: cad60000
    ened Device Tree)
    [   28.294633] PC is at select_fallback_rq+0x180/0x[   28.294637] LR is at select_fallback_rq+0xc0/0x1b0
    [   28.294642] pc : [<c0154638>]    lr : [<c0154578>] [   28.294644] r10: c0c0314c  r9 : 00000002  r8 : c0c03038
    r: 600f0093
    [   28.294642] sp : cad61878  ip : 00000000  fp : cad618ac
    [   28.294647] r7 : c0c0302c  r6 : cd3a1900  r5 : cd3a1ba8 [   28.294649] r3 : 00000002  r2 : 00000002  r1 : 00000002  r0 : 00000002
    [   28.294652] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segme[   28.294656] Control: 10c5387d  Table: 8aec006a  DAC: 00000051
    RM  Segment none
    [   28.294658] Process snmpd (pid: 576, stack limit = 0xcad60210)[   28.294661] Stack: (0xcad61878 to 0xcad62000)
    it = 0xcad60210)
    [   28.294665] 1860:                             [   28.294670] 1880: cad618ac cd3a1900 cd3a1de0 a00f0093 00000000 00000001 cd3a1ba8 cdac7500
    [   28.294675] 18a0: cad618e4 cad618b0 c0155094 c01544c4 cad618e4 cad618c0 c015c290 cd31c09c
    [   28.294680] 18c0: cfd92100 cfd8d800 cad60000 00000002 c0b572c4 cdac7500 cad618f4 cad618e8
    [   28.294684] 18e0: c01550e8 c0154e2c cad6191c cad618f8 c01434bc c01550dc c01997a8 c063a768
    [   28.294689] 1900: 1109d7b0 cd31c09c cfd92100 cd31c09c cad61964 cad61920 c0143694 c0143444
    [   28.294693] 1920: 00000000 00000000 c0b572c4 cad61920 00000022 00000001 c03c42f4 00000002
    [   28.294698] 1940: cdac7500 cd31c0ac cdac7500 00000000 cad61db8 cad619d0 cad6198c cad61968
    [   28.294702] 1960: c0143c04 c0143510 c014622c c0192030 cd3d8bc8 00000000 cd31c09c 00000002
    [   28.294707] 1980: cad619bc cad61990 c0146338 c0143b68 cad619cc 600f0093 c03a44fc cd3d8bc8
    [   28.294711] 19a0: 00000001 cd31c000 600f0013 cad61da8 cad619cc cad619c0 c03a521c c01462ec
    [   28.294716] 19c0: cad61a0c cad619d0 c03a923c c03a51e8 cad619d0 cad619d0 cad619d8 cad619d8
    [   28.294721] 19e0: cd3d8bc8 00000002 00000002 00000000 7fffffff c07ca068 cd369c00 c974e600
    [   28.294725] 1a00: cad61a2c cad61a10 c07c9088 c03a9030 00000002 00000002 cad61a7c c0c027a8
    [   28.294730] 1a20: cad61a44 cad61a30 c07ca080 c07c904c cad61a70 00000002 cad61a6c cad61a48
    [   28.294734] 1a40: c07c9cd4 c07ca074 cd3a3e80 00000002 cbbc4ac0 c0c027a8 c07ca068 cd369c00
    [   28.294738] 1a60: cad61ab4 cad61a70 c07c9e14 c07c9c58 cbbc4ac0 00000002 00000000 00000000
    [   28.294743] 1a80: cd3a3e80 c016efc0 c0c027ac c0c027ac cad61ac4 00000000 cbbc4ac0 cbbc4ac0
    [   28.294747] 1aa0: 00000001 cad61b70 cad61ac4 cad61ab8 c025e4b4 c07c9da0 cad61ae4 cad61ac8
    [   28.294752] 1ac0: c0263820 c025e494 00000000 cad61b70 cad61bac cad61ba0 cad61b1c cad61ae8
    [   28.294757] 1ae0: c02d66f4 c0263780 00001000 00000008 c03c6e14 cad61cf8 00000000 00000000
    [   28.294761] 1b00: 00000000 00000000 c974e600 00000000 cad61c34 cad61b20 c02d713c c02d6638
    [   28.294766] 1b20: cad61b64 00000001 cad61b4c cad61b38 c03a47c0 c03c6cc8 cd31c000 caf436c0
    [   28.294770] 1b40: cad61bcc cad61b50 c03a678c c03ac394 cd2f90f0 00000002 cad61cf8 c08221fc
    [   28.294775] 1b60: cd31c044 00000000 000003ff cd30f800 0000000c 00000000 c03a4d30 c03a4a60
    [   28.294780] 1b80: cd3d8e80 000001c4 cd3d8e80 00000204 cad61bcc cad61ba0 c03a8490 c0189d68
    [   28.294784] 1ba0: c974e580 003582a0 00000000 00000003 ffffffff caf436c0 00000000 00000001
    [   28.294789] 1bc0: 000082e1 ce30bbe4 cd80b400 00000000 00000000 c974e6ec 0000000c 00000000
    [   28.294793] 1be0: cad61c34 cad61bf0 c0227bf0 c0223ca0 0000000c 00000000 cad61c34 cad61c08
    [   28.294798] 1c00: c01d5578 c03d0de0 cad61c34 cad61cf8 00000001 c974e600 00000000 00000000
    [   28.294802] 1c20: c974e5d0 00000000 cad61c9c cad61c38 c02a4a10 c02d70b4 00000000 cad61d28
    [   28.294807] 1c40: 00000002 cd80b400 ce30bbe4 024213ca cad61c6c cad61c60 c01e6d44 00000000
    [   28.294811] 1c60: 00000000 cad61c70 00000000 00000000 cad61c7c 00000000 00000001 0000000c
    [   28.294816] 1c80: 00000000 ce30bbe4 00000001 00000000 cad61d7c cad61ca0 c02e0954 c02a4648
    [   28.294820] 1ca0: c02e0538 024000c0 c0c83e54 cd548000 00001000 00000000 00000000 00000000
    [   28.294825] 1cc0: c02a4cac c974e6ec 0000000c 00000000 cad61da0 00000005 00000005 c974e600
    [   28.294829] 1ce0: 00000001 cd3d8e80 cd3d8e80 00000000 00000011 00000000 00000000 00000000
    [   28.294834] 1d00: 0000000c 00000005 00000000 600b0013 cad61d34 cad61d20 024213ca c062cd38
    [   28.294838] 1d20: cd3d8e80 00000000 c0c4c500 00000000 c0c4c500 00000001 00000002 00000000
    [   28.294842] 1d40: cad61d40 cad61d40 00000081 ffffe000 00000008 00000011 00000005 c02a3a60
    [   28.294847] 1d60: 00000005 00000010 c974e6f0 c974e6ec cad61d8c cad61d80 c02a3aa4 c02e05dc
    [   28.294852] 1d80: cad61dec cad61d90 c01e50a0 c02a3a6c c02c9a94 cae91180 c974e6ec 024213ca
    [   28.294856] 1da0: ce30bf34 ce30bc1c cad61da8 cad61da8 cad61db0 cad61db0 cad61db8 cad61db8
    [   28.294861] 1dc0: 00000000 cae911e8 0000000c c974e6ec cae91180 00000020 00000010 00000001
    [   28.294865] 1de0: cad61e2c cad61df0 c01e52a4 c01e4f08 00000010 00000000 00000000 c974e600
    [   28.294870] 1e00: cad61e2c cae911e8 c974e6ec cae91180 ce30bac4 00000004 cad61ee8 cad61f00
    [   28.294874] 1e20: cad61e54 cad61e30 c01e5408 c01e5174 00000004 00000001 00000000 024000c0
    [   28.294879] 1e40: cae91180 c974e6ec cad61ed4 cad61e58 c01d8a4c c01e5394 00000004 00000001
    [   28.294883] 1e60: cd80b400 00080001 00000005 cae911e8 00000000 00000003 cad61f00 00000000
    [   28.294888] 1e80: cad60000 00000000 c974e600 ccfcddc0 00000817 000d706c ccfcddf8 00000055
    [   28.294893] 1ea0: cad61efc cad61eb0 c0115d1c cae91180 00000000 00004000 00000000 cad61f78
    [   28.294897] 1ec0: 00001000 00000000 cad61f44 cad61ed8 c022be30 c01d83d4 00001000 cad61ee8
    [   28.294901] 1ee0: 000acb98 00001000 00000000 00000000 00001000 cad61ee0 00000001 cad61f08
    [   28.294906] 1f00: cae91180 00000000 00004000 00000000 00000000 00000000 00000000 00000000
    [   28.294910] 1f20: 00001000 cae91180 000acb98 cad61f78 00000000 00001000 cad61f74 cad61f48
    [   28.294915] 1f40: c022cbe0 c022bd74 00000000 00000000 cad61f74 cae91180 cae91180 00004000
    [   28.294920] 1f60: 00000000 000acb98 cad61fa4 cad61f78 c022da44 c022cb5c 00004000 00000000
    [   28.294924] 1f80: 000b5f68 b6a22c14 beb24bc8 00000003 c0108024 cad60000 00000000 cad61fa8
    [   28.294929] 1fa0: c0107e60 c022da0c 000b5f68 b6a22c14 00000005 000acb98 00001000 00000000
    [   28.294933] 1fc0: 000b5f68 b6a22c14 beb24bc8 00000003 beb24bc9 00000080 00000007 b6fc479c
    [   28.294937] 1fe0: 00000000 beb24b54 b69881e7 b69c2f86 000f0030 00000005 00000000 00000000
    [   28.294941] Backtrace:
    [   28.294948] [<c01544b8>][   28.294953]  r10:cdac7500 r9:cd3a1ba8 r8:00000001 r7:00000000 r6:a00f0093 r5:cd3a1de0
    0x2b0)
    [   28.294956]  r4:cd3a1900
    [   28.294963] [<c0154e20>] [   28.294967]  r10:cdac7500 r9:c0b572c4 r8:00000002 r7:cad60000 r6:cfd8d800 r5:cfd92100
    [   28.294969]  r4:cd31c09c
    [   28.294981] [<c01550d0>] [   28.294987] [<c0143438>] (insert_work) from [<c0143694>] (__queue_work+0x190/0x3ec)
    [   28.294990]  r6:cd31c09c r5:cfd92100 r4:cd31c09c
    [   28.294997] [<c0143504>] (__queue_work) from [<c0[   28.295001]  r10:cad619d0 r9:cad61db8 r8:00000000 r7:cdac7500 r6:cd31c0ac r5:cdac7500
    x17c)
    [   28.295003]  r4:00000002
    [   28.295010] [<c0143b5c>] [   28.295013]  r6:00000002 r5:cd31c09c r4:00000000
    rom [<c0146338>] (mod_delayed_work_on+0x58/0x70)
    [   28.295021] [<c01462e0>] (mod_delayed_work_on) fr[   28.295025]  r8:cad61da8 r7:600f0013 r6:cd31c000 r5:00000001 r4:cd3d8bc8
    _queue_async+0x40/0x44)
    [   28.295032] [<c03a51dc>] (blk_run_queue_async) from [<c03a923c>] (blk_flu[   28.295043] [<c03a9024>] (blk_flush_plug_list) from [<c07c9088>] (io_schedule_timeout+0x48/0xb4)
    [   28.295047]  r10:c974e600 r9:cd369c00 r8:c07ca068 r7:7fffffff r6:00000000 r5:00000002
    0x48/0xb4)
    [   28.295049]  r4:00000002
    [   28.295055] [<c07c9040>] [   28.295059]  r7:c0c027a8 r6:cad61a7c r5:00000002 r4:00000002
    0>] (bit_wait_io+0x18/0x64)
    [   28.295065] [<c07ca068>] (bit_wait_io) from [<c07c9cd4>] (__w[   28.295068]  r5:00000002 r4:cad61a70
    ) from [<c07c9cd4>] (__wait_on_bit+0x88/0xc0)
    [   28.295074] [<c07c9c4c>] (__wait_on_b[   28.295078]  r9:cd369c00 r8:c07ca068 r7:c0c027a8 r6:cbbc4ac0 r5:00000002 r4:cd3a3e80
    x80/0x88)
    [   28.295088] [<c07c9d94>] (out_of_line_wait_on_bit) from [<c025e4b4>] (__wait_on_buffe[   28.295092]  r8:cad61b70 r7:00000001 r6:cbbc4ac0 r5:cbbc4ac0 r4:00000000
    ait_on_buffer+0x2c/0x30)
    [   28.295099] [<c025e488>] (__wait_on_buffer) from [<c0263820>] (bh_submit_[   28.295106] [<c0263774>] (bh_submit_read) from [<c02d66f4>] (ext4_get_branch+0xc8/0x160)
    [   28.295108]  r5:cad61ba0 r4:cad61bac
    [   28.295113] [<c02d662c>] (ext4_get_br[   28.295117]  r10:00000000 r9:c974e600 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    /0x9f8)
    [   28.295119]  r4:cad61cf8
    [   28.295128] [<c02d70a8>] [   28.295133]  r10:00000000 r9:c974e5d0 r8:00000000 r7:00000000 r6:c974e600 r5:00000001
    4/0x5a0)
    [   28.295135]  r4:cad61cf8
    [   28.295142] [<c02a463c>] [   28.295146]  r10:00000000 r9:00000001 r8:ce30bbe4 r7:00000000 r6:0000000c r5:00000001
    84/0x7d0)
    [   28.295148]  r4:00000000
    [   28.295153] [<c02e05d0>] [   28.295158]  r10:c974e6ec r9:c974e6f0 r8:00000010 r7:00000005 r6:c02a3a60 r5:00000005
    /0x48)
    [   28.295160]  r4:00000011
    [   28.295170] [<c02a3a60>] [   28.295176] [<c01e4efc>] (__do_page_cache_readahead) from [<c01e52a4>] (ondemand_readahead+0x13c/0x2[   28.295181]  r10:00000001 r9:00000010 r8:00000020 r7:cae91180 r6:c974c
    head+0x13c/0x220)
    [   28.295182]  r4:cae911e8
     r9:00000010 r8:00000020 r7:cae91180 r6:c974e6ec r5:0000000c
    [   28.295188] [<c01e5168>] [   28.295193]  r10:cad61f00 r9:cad61ee8 r8:00000004 r7:ce30bac4 r6:cae91180 r5:c974e6ec
    ahead+0x80/0x84)
    [   28.295195]  r4:cae911e8
    [   28.295204] [<c01e5388>] [   28.295207]  r6:c974e6ec r5:cae91180 r4:024000c0
    ead) from [<c01d8a4c>] (generic_file_read_iter+0x684/0x944)
    [   28.295215] [<c01d83c8>] (generic_file_read_iter)[   28.295219]  r10:00000000 r9:00001000 r8:cad61f78 r7:00000000 r6:00004000 r5:00000000
    x118)
    [   28.295222]  r4:cae91180
    [   28.295227] [<c022bd68>] [   28.295230]  r9:00001000 r8:00000000 r7:cad61f78 r6:000acb98 r5:cae91180 r4:00[   28.295235] [<c022cb50>] (vfs_read) from [<c022da44>] (SyS_read+0x44/0x98)
    :00001000
    [   28.295239]  r8:000acb98 r7:00000000 r6:00004000 r5:cae91180 r4:cae91180
    [   28.295247] [<c022da00>] (SyS_read) from [<c0107e60>] (ret_fast_syscall+0[   28.295251]  r9:cad60000 r8:c0108024 r7:00000003 r6:beb24bc8 r5:b6a22c14 r4:000b5f[   28.295256] Code: 0a000007 3a000002 e35
    a22c14 r4:000b5f68
    [   28.295260] ---[ end trace aa6cc8a3f5645735 ]---
    ffca (e7f001f2)
    [   28.295271] note: snmpd[576] exited with preempt_[   28.295304] ------------[ cut here ]------------
    count 3
    [   28.295306] Kernel BUG at c0154638 [verbose debug[   28.295309] Internal error: Oops - BUG: 0 [#3] PREEMPT SMP ARM
    ble]
    [   28.295312] Modules linked in:
    [   28.295316] CPU: 1 PID: 576 Com[   28.295318] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   28.295320] task: cd3a3e80 task.stack: cad60000
    ened Device Tree)
    [   28.295324] PC is at select_fallback_rq+0x180/0x[   28.295328] LR is at select_fallback_rq+0xc0/0x1b0
    [   28.295333] pc : [<c0154638>]    lr : [<c0154578>] [   28.295335] r10: c0c0314c  r9 : 00000002  r8 : c0c03038
    r: 600f0193
    [   28.295333] sp : cad61478  ip : 00000000  fp : cad614ac
    [   28.295338] r7 : c0c0302c  r6 : cd3a3200  r5 : cd3a34a8 [   28.295340] r3 : 00000002  r2 : 00000002  r1 : 00000002  r0 : 00000002
    [   28.295343] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segme[   28.295346] Control: 10c5387d  Table: 8aec006a  DAC: 00000051
    RM  Segment none
    [   28.295348] Process snmpd (pid: 576, stack limit = 0xcad60210)[   28.295351] Stack: (0xcad61478 to 0xcad62000)
    it = 0xcad60210)
    [   28.295354] 1460:                             [   28.295360] 1480: c017c330 cd3a3200 cd3a36e0 a00f0193 00000000 00000001 cd3a34a8 c0193868
    [   28.295364] 14a0: cad614e4 cad614b0 c0155094 c01544c4 c0c7685e ccfd7f20 cfd8c58c cfd8c540
    [   28.295369] 14c0: ccfd7f20 cfd8c580 00000000 cfd8c58c 00000005 c0193868 cad614f4 cad614e8
    [   28.295373] 14e0: c01550e8 c0154e2c cad61504 cad614f8 c0193890 c01550dc cad6154c cad61508
    [   28.295378] 1500: c0194078 c0193874 96010e5f 00000006 c099ea18 c0c1a2a9 96010e5f 00000006
    [   28.295382] 1520: c03d4ca4 cfd8c540 00000003 ffffffff cfd8c554 cfd8c5d8 cfd8c5f8 cfd8c5b8
    [   28.295387] 1540: cad615a4 cad61550 c01942f0 c0193f68 cfd8c5f8 00000001 96010e5f 00000006
    [   28.295391] 1560: cad61594 7fffffff c03d3df4 c03d3c9c 96010e5f 00000006 cad615c4 cd806300
    [   28.295396] 1580: c0c03414 00000013 cd845480 cd808000 cad60000 c0991644 cad615b4 cad615a8
    [   28.295400] 15a0: c063a520 c0194250 cad615d4 cad615b8 c0184c10 c063a4f4 c0b5ad7c 00000013
    [   28.295405] 15c0: 00000000 00000000 cad615e4 cad615d8 c017fcdc c0184ba0 cad6160c cad615e8
    [   28.295410] 15e0: c0180264 c017fcbc c0c03414 fa21200c cad61638 fa212000 fa213000 cad60000
    [   28.295414] 1600: cad61634 cad61610 c010150c c018020c c07cd6c8 400f0013 ffffffff cad6166c
    [   28.295419] 1620: c015463a cad60000 cad61694 cad61638 c010cb0c c01014d8 caddef04 00000012
    [   28.295423] 1640: 00000012 000001fd cce5f8c0 0000000b 000020f0 00000001 c015463a c0c07768
    [   28.295428] 1660: c0991644 cad61694 cad61698 cad61688 c01b10d0 c07cd6c8 400f0013 ffffffff
    [   28.295432] 1680: 00000051 bf000000 cad616b4 cad61698 c01b10d0 c07cd6ac cd3a3e80 0000000b
    [   28.295436] 16a0: cad60000 00000001 cad616dc cad616b8 c0132438 c01b0f44 c015463a 00000000
    [   28.295441] 16c0: cad616dc cad616d0 c012e47c 00000001 cad61764 cad616e0 c010c1f8 c0131f84
    [   28.295445] 16e0: cad60210 0000000b c099163c 00000008 bf000000 cad60000 00000000 600f0093
    [   28.295450] 1700: 30ffffff 30303061 20373030 30306133 32303030 35336520 30303039 61312032
    [   28.295454] 1720: 66666666 28206163 30663765 32663130 ca002029 cad61740 c0163e9c 00000004
    [   28.295458] 1740: e7f001f2 c0154638 cad61828 00000000 c010cbf8 cad60000 cad61774 cad61768
    [   28.295463] 1760: c010c430 c010bfb8 cad61824 cad61778 c0101190 c010c41c 00000006 00000006
    [   28.295467] 1780: 00000004 00000000 00030001 c0154638 00000001 00000000 c015b2d4 00000001
    [   28.295472] 17a0: cfd8da78 71b49340 00000006 00000001 cfd8da40 cd3a1980 cad61864 cad617c8
    [   28.295476] 17c0: c0164cf8 c015c378 cd3a3f00 00000001 cd3a3f00 cfd8da78 00000001 00000000
    [   28.295481] 17e0: cad6187c cad617f0 c01612dc c015f968 00000008 00000000 cad6181c cad61808
    [   28.295485] 1800: c015b2d4 c015463c 00000000 c010d0d8 00000000 e7100000 cad618ac cad61828
    [   28.295490] 1820: c010cbf8 c0101030 00000002 00000002 00000002 00000002 00000002 cd3a1ba8
    [   28.295494] 1840: cd3a1900 c0c0302c c0c03038 00000002 c0c0314c cad618ac 00000000 cad61878
    [   28.295499] 1860: c0154578 c0154638 600f0093 ffffffff 00000051 bf000000 c0162944 00000001
    [   28.295503] 1880: cad618ac cd3a1900 cd3a1de0 a00f0093 00000000 00000001 cd3a1ba8 cdac7500
    [   28.295508] 18a0: cad618e4 cad618b0 c0155094 c01544c4 cad618e4 cad618c0 c015c290 cd31c09c
    [   28.295512] 18c0: cfd92100 cfd8d800 cad60000 00000002 c0b572c4 cdac7500 cad618f4 cad618e8
    [   28.295516] 18e0: c01550e8 c0154e2c cad6191c cad618f8 c01434bc c01550dc c01997a8 c063a768
    [   28.295521] 1900: 1109d7b0 cd31c09c cfd92100 cd31c09c cad61964 cad61920 c0143694 c0143444
    [   28.295525] 1920: 00000000 00000000 c0b572c4 cad61920 00000022 00000001 c03c42f4 00000002
    [   28.295529] 1940: cdac7500 cd31c0ac cdac7500 00000000 cad61db8 cad619d0 cad6198c cad61968
    [   28.295534] 1960: c0143c04 c0143510 c014622c c0192030 cd3d8bc8 00000000 cd31c09c 00000002
    [   28.295538] 1980: cad619bc cad61990 c0146338 c0143b68 cad619cc 600f0093 c03a44fc cd3d8bc8
    [   28.295543] 19a0: 00000001 cd31c000 600f0013 cad61da8 cad619cc cad619c0 c03a521c c01462ec
    [   28.295547] 19c0: cad61a0c cad619d0 c03a923c c03a51e8 cad619d0 cad619d0 cad619d8 cad619d8
    [   28.295552] 19e0: cd3d8bc8 00000002 00000002 00000000 7fffffff c07ca068 cd369c00 c974e600
    [   28.295556] 1a00: cad61a2c cad61a10 c07c9088 c03a9030 00000002 00000002 cad61a7c c0c027a8
    [   28.295560] 1a20: cad61a44 cad61a30 c07ca080 c07c904c cad61a70 00000002 cad61a6c cad61a48
    [   28.295565] 1a40: c07c9cd4 c07ca074 cd3a3e80 00000002 cbbc4ac0 c0c027a8 c07ca068 cd369c00
    [   28.295569] 1a60: cad61ab4 cad61a70 c07c9e14 c07c9c58 cbbc4ac0 00000002 00000000 00000000
    [   28.295574] 1a80: cd3a3e80 c016efc0 c0c027ac c0c027ac cad61ac4 00000000 cbbc4ac0 cbbc4ac0
    [   28.295578] 1aa0: 00000001 cad61b70 cad61ac4 cad61ab8 c025e4b4 c07c9da0 cad61ae4 cad61ac8
    [   28.295583] 1ac0: c0263820 c025e494 00000000 cad61b70 cad61bac cad61ba0 cad61b1c cad61ae8
    [   28.295587] 1ae0: c02d66f4 c0263780 00001000 00000008 c03c6e14 cad61cf8 00000000 00000000
    [   28.295592] 1b00: 00000000 00000000 c974e600 00000000 cad61c34 cad61b20 c02d713c c02d6638
    [   28.295596] 1b20: cad61b64 00000001 cad61b4c cad61b38 c03a47c0 c03c6cc8 cd31c000 caf436c0
    [   28.295600] 1b40: cad61bcc cad61b50 c03a678c c03ac394 cd2f90f0 00000002 cad61cf8 c08221fc
    [   28.295605] 1b60: cd31c044 00000000 000003ff cd30f800 0000000c 00000000 c03a4d30 c03a4a60
    [   28.295609] 1b80: cd3d8e80 000001c4 cd3d8e80 00000204 cad61bcc cad61ba0 c03a8490 c0189d68
    [   28.295614] 1ba0: c974e580 003582a0 00000000 00000003 ffffffff caf436c0 00000000 00000001
    [   28.295618] 1bc0: 000082e1 ce30bbe4 cd80b400 00000000 00000000 c974e6ec 0000000c 00000000
    [   28.295622] 1be0: cad61c34 cad61bf0 c0227bf0 c0223ca0 0000000c 00000000 cad61c34 cad61c08
    [   28.295627] 1c00: c01d5578 c03d0de0 cad61c34 cad61cf8 00000001 c974e600 00000000 00000000
    [   28.295631] 1c20: c974e5d0 00000000 cad61c9c cad61c38 c02a4a10 c02d70b4 00000000 cad61d28
    [   28.295636] 1c40: 00000002 cd80b400 ce30bbe4 024213ca cad61c6c cad61c60 c01e6d44 00000000
    [   28.295639] 1c60: 00000000 cad61c70 00000000 00000000 cad61c7c 00000000 00000001 0000000c
    [   28.295644] 1c80: 00000000 ce30bbe4 00000001 00000000 cad61d7c cad61ca0 c02e0954 c02a4648
    [   28.295648] 1ca0: c02e0538 024000c0 c0c83e54 cd548000 00001000 00000000 00000000 00000000
    [   28.295653] 1cc0: c02a4cac c974e6ec 0000000c 00000000 cad61da0 00000005 00000005 c974e600
    [   28.295658] 1ce0: 00000001 cd3d8e80 cd3d8e80 00000000 00000011 00000000 00000000 00000000
    [   28.295663] 1d00: 0000000c 00000005 00000000 600b0013 cad61d34 cad61d20 024213ca c062cd38
    [   28.295666] 1d20: cd3d8e80 00000000 c0c4c500 00000000 c0c4c500 00000001 00000002 00000000
    [   28.295671] 1d40: cad61d40 cad61d40 00000081 ffffe000 00000008 00000011 00000005 c02a3a60
    [   28.295676] 1d60: 00000005 00000010 c974e6f0 c974e6ec cad61d8c cad61d80 c02a3aa4 c02e05dc
    [   28.295680] 1d80: cad61dec cad61d90 c01e50a0 c02a3a6c c02c9a94 cae91180 c974e6ec 024213ca
    [   28.295685] 1da0: ce30bf34 ce30bc1c cad61da8 cad61da8 cad61db0 cad61db0 cad61db8 cad61db8
    [   28.295689] 1dc0: 00000000 cae911e8 0000000c c974e6ec cae91180 00000020 00000010 00000001
    [   28.295693] 1de0: cad61e2c cad61df0 c01e52a4 c01e4f08 00000010 00000000 00000000 c974e600
    [   28.295698] 1e00: cad61e2c cae911e8 c974e6ec cae91180 ce30bac4 00000004 cad61ee8 cad61f00
    [   28.295702] 1e20: cad61e54 cad61e30 c01e5408 c01e5174 00000004 00000001 00000000 024000c0
    [   28.295706] 1e40: cae91180 c974e6ec cad61ed4 cad61e58 c01d8a4c c01e5394 00000004 00000001
    [   28.295711] 1e60: cd80b400 00080001 00000005 cae911e8 00000000 00000003 cad61f00 00000000
    [   28.295715] 1e80: cad60000 00000000 c974e600 ccfcddc0 00000817 000d706c ccfcddf8 00000055
    [   28.295720] 1ea0: cad61efc cad61eb0 c0115d1c cae91180 00000000 00004000 00000000 cad61f78
    [   28.295724] 1ec0: 00001000 00000000 cad61f44 cad61ed8 c022be30 c01d83d4 00001000 cad61ee8
    [   28.295728] 1ee0: 000acb98 00001000 00000000 00000000 00001000 cad61ee0 00000001 cad61f08
    [   28.295733] 1f00: cae91180 00000000 00004000 00000000 00000000 00000000 00000000 00000000
    [   28.295737] 1f20: 00001000 cae91180 000acb98 cad61f78 00000000 00001000 cad61f74 cad61f48
    [   28.295742] 1f40: c022cbe0 c022bd74 00000000 00000000 cad61f74 cae91180 cae91180 00004000
    [   28.295746] 1f60: 00000000 000acb98 cad61fa4 cad61f78 c022da44 c022cb5c 00004000 00000000
    [   28.295751] 1f80: 000b5f68 b6a22c14 beb24bc8 00000003 c0108024 cad60000 00000000 cad61fa8
    [   28.295755] 1fa0: c0107e60 c022da0c 000b5f68 b6a22c14 00000005 000acb98 00001000 00000000
    [   28.295760] 1fc0: 000b5f68 b6a22c14 beb24bc8 00000003 beb24bc9 00000080 00000007 b6fc479c
    [   28.295764] 1fe0: 00000000 beb24b54 b69881e7 b69c2f86 000f0030 00000005 00000000 00000000
    [   28.295767] Backtrace:
    [   28.295774] [<c01544b8>][   28.295779]  r10:c0193868 r9:cd3a34a8 r8:00000001 r7:00000000 r6:a00f0193 r5:cd3a36e0
    0x2b0)
    [   28.295781]  r4:cd3a3200
    [   28.295787] [<c0154e20>] [   28.295792]  r10:c0193868 r9:00000005 r8:cfd8c58c r7:00000000 r6:cfd8c580 r5:ccfd7f20
    [   28.295794]  r4:cfd8c540
    [   28.295801] [<c01550d0>] [   28.295806] [<c0193868>] (hrtimer_wakeup) from [<c0194078>] (__hrtimer_run_queues+0x11c/[   28.295811] [<c0193f5c>] (__hrtimer_run_queues) from [<c01942f0>] (hrtimer_interr3
    xac/0x1fc)
    [   28.295817]  r4:cfd8c540
     r9:cfd8c5f8 r8:cfd8c5d8 r7:cfd8c554 r6:ffffffff r5:00000003
    [   28.295825] [<c0194244>] [   28.295830]  r10:c0991644 r9:cad60000 r8:cd808000 r7:cd845480 r6:00000013 r5:c0c03414
    s+0x38/0x40)
    [   28.295832]  r4:cd806300
    [   28.295839] [<c063a4e8>] [   28.295844] [<c0184b94>] (handle_percpu_devid_irq) from [<c017fcdc>] (generic_handle_irq+0x2c/0x3c)
    x13c)
    [   28.295847]  r7:00000000 r6:00000000 r5:00000013 r4:c0b5ad7c
    [   28.295852] [<c017fcb0>] (generic_handle_irq) from [<c0180264[   28.295856] [<c0180200>] (__handle_domain_irq) from [<c010150c>] (gic_handle_irq+0x40/0x7c)
    bc)
    [   28.295860]  r9:cad60000 r8:fa213000 r7:fa212000 r6:cad61638 r5:fa21200c r4:c0c03414
    /0x7c)
    [   28.295865] [<c01014cc>] (gic_handle_irq) from [<c010cb0c>] (__irq_svc+0x6c/0xa8)
    14
    [   28.295868] Exception stack(0xcad61638 to 0xcad61680)
    [   28.295871] 1620:                                     [   28.295876] 1640: 00000012 000001fd cce5f8c0 0000000b 000020f0 00000001 c015463a c0c07768
    [   28.295880] 1660: c0991644 cad61694 cad61698 cad61688 c01b10d0 c07cd6c8 400f0013 ffffffff
    [   28.295884]  r9:cad60000 r8:c015463a r7:cad6166c r6:ffffffff r5:400f0013 r4:c07cd6c8
    ffff
    [   28.295896] [<c07cd6a0>] (_raw_spin_unlock_irq) from [<c01b10d0>] (acct_collect+0x198[   28.295908] [<c01b0f38>] (acct_collect) from [<c0132438>] (do_exit+0x4c0/0x9f0)
    0x198/0x1b8)
    [   28.295912]  r7:00000001 r6:cad60000 r5:0000000b r4:cd3a3e80
    _exit+0x4c0/0x9f0)
    [   28.295916] [<c0131f78>] (do_exit) from [<c010c1f8>] (die+0x2[   28.295918]  r7:00000001
    (do_exit) from [<c010c1f8>] (die+0x24c/0x464)
    [   28.295922] [<c010bfac>] [   28.295926]  r10:cad60000 r9:c010cbf8 r8:00000000 r7:cad61828 r6:c0154638 r5[   28.295928]  r4:00000004
     r9:c010cbf8 r8:00000000 r7:cad61828 r6:c0154638 r5:e7f001f2
    [   28.295933] [<c010c410>] [   28.295937] [<c0101024>] (do_undefinstr) from [<c010cbf8>] (__und_svc_finish+0x0/0x48)
    [   28.295940] Exception stack(0xcad61828 to 0xcad61870)
    [   28.295944] 1820:                   00000002 00000002 [   28.295949] 1840: cd3a1900 c0c0302c c0c03038 00000002 c0c0314c cad618ac 00000000 cad61878
    [   28.295952] 1860: c0154578 c0154638 600f0093 ffffffff
    [   28.295955]  r8:e7100000 r7:00000000 r6:c010d0d8 r5:00[   28.295962] [<c01544b8>] (select_fallback_rq) from [<c0155094>] (try_to_w[   28.295966]  r10:cdac7500 r9:cd3a1ba8 r8:00000001 r7:00000000 r6:a00
    0x2b0)
    [   28.295968]  r4:cd3a1900
    [   28.295974] [<c0154e20>] [   28.295978]  r10:cdac7500 r9:c0b572c4 r8:00000002 r7:cad60000 r6:cfd8d800 r5:cfd92100
    [   28.295980]  r4:cd31c09c
    [   28.295986] [<c01550d0>] [   28.295993] [<c0143438>] (insert_work) from [<c0143694>] (__queue_work+0x190/0x3ec)
    [   28.295996]  r6:cd31c09c r5:cfd92100 r4:cd31c09c
    [   28.296002] [<c0143504>] (__queue_work) from [<c0[   28.296006]  r10:cad619d0 r9:cad61db8 r8:00000000 r7:cdac7500 r6:cd31c0ac r5:cdac7500
    x17c)
    [   28.296008]  r4:00000002
    [   28.296014] [<c0143b5c>] [   28.296017]  r6:00000002 r5:cd31c09c r4:00000000
    [   28.296022] [<c01462e0>] (mod_delayed_work_on) fr[   28.296025]  r8:cad61da8 r7:600f0013 r6:cd31c000 r5:00000001 r4:cd3d8bc8
    [   28.296030] [<c03a51dc>] (blk_run_queue_async) from [<c03a923c>] (blk_flu[   28.296036] [<c03a9024>] (blk_flush_plug_list) from [<c07c9088>] (io_schedule_timeout+0x48/0xb4)
    [   28.296040]  r10:c974e600 r9:cd369c00 r8:c07ca068 r7:7fffffff r6:00000000 r5:00000002
    0x48/0xb4)
    [   28.296042]  r4:00000002
    [   28.296048] [<c07c9040>] [   28.296051]  r7:c0c027a8 r6:cad61a7c r5:00000002 r4:00000002
    [   28.296056] [<c07ca068>] (bit_wait_io) from [<c07c9cd4>] (__w[   28.296059]  r5:00000002 r4:cad61a70
    [   28.296065] [<c07c9c4c>] (__wait_on_b[   28.296069]  r9:cd369c00 r8:c07ca068 r7:c0c027a8 r6:cbbc4ac0 r5:00000002 r4:cd3a3e80
    x80/0x88)
    [   28.296075] [<c07c9d94>] (out_of_line_wait_on_bit) from [<c025e4b4>] (__wait_on_buffe[   28.296079]  r8:cad61b70 r7:00000001 r6:cbbc4ac0 r5:cbbc4ac0 r4:00000000
    [   28.296084] [<c025e488>] (__wait_on_buffer) from [<c0263820>] (bh_submit_[   28.296090] [<c0263774>] (bh_submit_read) from [<c02d66f4>] (ext4_get_branch+0xc8/0x160)
    [   28.296093]  r5:cad61ba0 r4:cad61bac
    [   28.296098] [<c02d662c>] (ext4_get_br[   28.296101]  r10:00000000 r9:c974e600 r8:00000000 r7:00000000 r6:00000000 r5:00000000
    /0x9f8)
    [   28.296103]  r4:cad61cf8
    [   28.296108] [<c02d70a8>] [   28.296113]  r10:00000000 r9:c974e5d0 r8:00000000 r7:00000000 r6:c974e600 r5:00000001
    4/0x5a0)
    [   28.296115]  r4:cad61cf8
    [   28.296121] [<c02a463c>] [   28.296125]  r10:00000000 r9:00000001 r8:ce30bbe4 r7:00000000 r6:0000000c r5:00000001
    84/0x7d0)
    [   28.296127]  r4:00000000
    [   28.296133] [<c02e05d0>] [   28.296137]  r10:c974e6ec r9:c974e6f0 r8:00000010 r7:00000005 r6:c02a3a60 r5:00000005
    /0x48)
    [   28.296139]  r4:00000011
    [   28.296145] [<c02a3a60>] [   28.296151] [<c01e4efc>] (__do_page_cache_readahead) from [<c01e52a4>] (ondemand_readahead+0x13c/0x2[   28.296156]  r10:00000001 r9:00000010 r8:00000020 r7:cae91180 r6:c974c
    head+0x13c/0x220)
    [   28.296158]  r4:cae911e8
    [   28.296164] [<c01e5168>] [   28.296168]  r10:cad61f00 r9:cad61ee8 r8:00000004 r7:ce30bac4 r6:cae91180 r5:c974e6ec
    ahead+0x80/0x84)
    [   28.296170]  r4:cae911e8
    [   28.296176] [<c01e5388>] [   28.296179]  r6:c974e6ec r5:cae91180 r4:024000c0
    [   28.296184] [<c01d83c8>] (generic_file_read_iter)[   28.296189]  r10:00000000 r9:00001000 r8:cad61f78 r7:00000000 r6:00004000 r5:00000000
    x118)
    [   28.296191]  r4:cae91180
    [   28.296195] [<c022bd68>] [   28.296199]  r9:00001000 r8:00000000 r7:cad61f78 r6:000acb98 r5:cae91180 r4:00[   28.296203] [<c022cb50>] (vfs_read) from [<c022da44>] (SyS_read+0x44/0x98)
    :00001000
    [   28.296207]  r8:000acb98 r7:00000000 r6:00004000 r5:cae91180 r4:cae91180
    [   28.296213] [<c022da00>] (SyS_read) from [<c0107e60>] (ret_fast_syscall+0[   28.296217]  r9:cad60000 r8:c0108024 r7:00000003 r6:beb24bc8 r5:b6a22c14 r4:000b5f[   28.296221] Code: 0a000007 3a000002 e35
    a22c14 r4:000b5f68
    [   28.296224] ---[ end trace aa6cc8a3f5645736 ]---
    ffca (e7f001f2)
    [   28.296229] Kernel panic - not syncing: Fatal exc[   28.296229] Kernel panic - not syncing: Fatal exception in interrupt
    [   30.912540] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
    Thanks again,
  • See "disagrees about version of symbol module_layout" message. Your modules are build against different kernel version or different kernel configuration. Can you first fix this?
  • Hi Kemal,
    I have fixed the version symbol issue by reinstalling the external modules it seems.
    Now I am getting somewhat consistent page faults or hangs while the IPU is loading. The typical logs look like the following. Sometimes I also get a message about failing to allocate DMA memory.
    [    5.669441] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@88400000
    [    5.689786] remoteproc remoteproc0: 58820000.ipu is available
    [    5.693597] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@8a400000
    [    5.693701] remoteproc remoteproc1: 55020000.ipu is available
    [  OK  ] Reached target Basic System.
             Starting Telephony service...
    [    5.854137] remoteproc remoteproc1: powering up 55020000.ipu
    [    5.895131] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743164
    [    5.895268] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    5.470399] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    5.492297] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    5.495564] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    5.495762] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [    5.496354] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    5.496499] omap-aes 4b700000.aes: will run requests pump with realtime priority
    [    5.555027] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@88400000
    [    5.555129] remoteproc remoteproc0: 58820000.ipu is available
    [    5.555976] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@8a400000
    [    5.556973] remoteproc remoteproc1: 55020000.ipu is available
    [    5.767918] remoteproc remoteproc1: powering up 55020000.ipu
    [    5.767942] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743164
    [    5.768101] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [    5.824580] remoteproc remoteproc0: powering up 58820000.ipu
    [    5.824599] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4872056
    [    5.824767] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
             Starting Print notice about GPLv3 packages...
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    5.989367] omap-rproc 55020000.ipu: failed to allocate dma memory: len 0x600000
             Starting uim-sysfs.service...
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Telephony se[    6.050486] remoteproc remoteproc1: Failed to process resources: -12
    rvice...
             Starting Login Service...
    I suspect these issues are related to the changes I've made to the CMA and CMEM memory pools in the linux device tree (had to move location into valid physical region in RAM, and make the reserved memory smaller since there is only 256 MB of RAM). I came across SPRAC60, and it seems that I need to rebuild the resource tables in the IPU image in order to use them (this is something I have not yet done). Is this the correct approach? Please let me know if there are more resources or commands I can run in the rescue terminal to debug.
    Welcome to Arago 2017.05!
    [    2.819519] systemd[1]: Set hostname to <am57xx-evm>.
    [    3.100231] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
    [    3.108031] systemd[1]: sockets.target: Found dependency on avahi-daemon.socket/start
    [    3.115954] systemd[1]: sockets.target: Found dependency on sysinit.target/start
    [    3.123475] systemd[1]: sockets.target: Found dependency on alignment.service/start
    [    3.131282] systemd[1]: sockets.target: Found dependency on basic.target/start
    [    3.131292] systemd[1]: sockets.target: Found dependency on sockets.target/start
    [    3.131305] systemd[1]: sockets.target: Breaking ordering cycle by deleting job avahi-daemon.socket/start
    [ SKIP ] Ordering cycle found, skipping Avah...S/DNS-SD Stack Activation Socket
    [ SKIP ] Ordering cycle found, skipping dropbear.socket
    [ SKIP ] Ordering cycle found, skipping RPCbind Server Activation Socket
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [  OK  ] Created slice System Slice.
    [  OK  ] Listening on Journal Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Listening on udev Control Socket.
             Mounting POSIX Message Queue File System...
             Mounting Debug File System...
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Reached target Slices.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Reached target Swap.
             Mounting Temporary Directory...
             Starting Remount Root and Kernel File Systems...
    [    3.684460] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Listening on Network Service Netlink Socket.
             Starting Setup Virtual Console...
             Starting Create list of required st... nodes for the current kernel...
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Reached target Remote File Systems.
             Starting Load Kernel Modules...
    [    3.867160] cmemk: loading out-of-tree module taints kernel.
    [    3.873930] CMEMK module: reference Linux version 4.9.28
    [  OK  ] Listening on /dev/initctl Compatibility Named[    3.881179] allocated heap buffer 0x40500000 of size 0x100000
     Pipe.
    [    3.892174] cmemk initialized
    [    3.899831] cryptodev: driver 1.8 loaded.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Listening on Syslog Socket.
             Starting Journal Service...
    [  OK  ] Reached target Paths.
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
             Starting Apply Kernel Variables...
             Mounting Configuration File System...
             Starting Create Static Device Nodes in /dev...
             Starting udev Coldplug all Devices...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Mounted Configuration File System.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [    4.823095] systemd-journald[113]: Received request to flush runtime journal from PID 1
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Load/Save Random Seed.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [    5.531022] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
    [    5.558430] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    5.566118] omap-des 480a5000.des: will run requests pump with realtime priority
    [    5.638392] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
    [    5.705459] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    5.731345] vpe 489d0000.vpe: Device registered as /dev/video0
    [    5.769012] pixcir_ts 4-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
    [    5.769017] pixcir_ts 4-005c: Failed to set IDLE mode
    [    5.769443] pixcir_ts: probe of 4-005c failed with error -121
    [  OK  ] Reached target Sockets.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [    5.932274] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    5.951903] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
             Starting TI MultiCore Tools Daemon...
    [  OK  ] Started Kernel Logging Service.
    [  OK  ] Started D-Bus System Message Bus.
    [    6.112917] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    6.129200] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [    6.206335] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    6.224060] omap-aes 4b700000.aes: will run requests pump with realtime priority
    [    6.256385] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@88400000
    [    6.271062] remoteproc remoteproc0: 58820000.ipu is available
    [    6.330294] [drm] Initialized pvr 1.14.3699939 20110701 on minor 0
    [    6.353238] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@8a400000
    [    6.353417] remoteproc remoteproc1: 55020000.ipu is available
    [    6.476926] Unable to handle kernel paging request at virtual address 33747864
    [    2.539557] systemd[1]: Set hostname to <am57xx-evm>.
    [    2.780238] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    2.788036] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    2.795774] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    2.803050] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    2.810609] systemd[1]: sysinit.target: Found dependency on avahi-daemon.socket/start
    [    2.818477] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    2.825930] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [    3.445590] cmemk: loading out-of-tree module taints kernel.
    [    3.452305] CMEMK module: reference Linux version 4.9.28
    [    3.458618] allocated heap buffer 0x40500000 of size 0x100000
             [    3.467822] cmemk initialized
    [    3.482716] cryptodev: driver 1.8 loaded.
    [    3.633690] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.363618] systemd-journald[101]: Received request to flush runtime journal from PID 1
    [    4.892700] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    4.927504] omap-des 480a5000.des: will run requests pump with realtime priority
    [    4.938191] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
    [    5.033909] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
    [    5.119323] pixcir_ts 4-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
    [    5.119329] pixcir_ts 4-005c: Failed to set IDLE mode
    [    5.119518] pixcir_ts: probe of 4-005c failed with error -121
    [    5.216542] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [    5.269574] vpe 489d0000.vpe: Device registered as /dev/video0
    [    5.318743] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    5.375904] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Started Daily Cleanup of Temporary Directorie[    5.522929] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    s.
    [    5.556654] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [    5.599205] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activati[    5.611675] omap-aes 4b700000.aes: will run requests pump with realtime priority
    on Socket.
    [    5.645028] [drm] Initialized pvr 1.14.3699939 20110701 on minor 0
    Vishal
  • SPRAC60 is okay. Just follow the steps on that pdf.
  • Hi Kemal,
    I am trying to follow SPRAC60, but I believe I need to rebuild the "dra7-ipu2-fw.xem4.ipumm-fw" file as that is the image on the ipu2 that needs modification (currently not planning to use dsp and ipu1). I need these to be modified to enable ducatijpegdec and ducatih264enc.
    I found instructions on how to rebuild the ipumm firmware, but I need some guidance on where to make resource table modifications to accommodate the modified CMA and CMEM pools in the device tree. I believe that a configuration file needs to be modified to let it know that a custom resource table is to be used, and then a ti_ipc_remoteproc_ResourceTable struct needs to be defined with the modifications. Which specific source files need these modifications?
    Vishal
  • Please, check this thread.
