Hi all:
Because we want to change own capture lenses,
Anyone knows the format of CamPrm in SFM_POSE.bin.
It can obtain the better FCW results, thanks!
Josh
Hi all:
Josh
its format is [9 + 12 * N] float values. Nis total number frames to be processed. where first 9 elements are intrinsic parameter(k[3x3]), and next 12 elements [P[3x4]] is the extrinsic parameter for each captured frames. All values are 32 bit float.
You can trace this file read as well in the code, and you can find that these values are read and provided to SFM algorithm interface.
Deepak Poddar
Hi Deepak:
Thanks for your reply!
Can I get intrinsic and extrinsic parameters for SFM_POSE.bin using TI's tools(vision_sdk/tools/camera_calibration_tools)?
What kind of calibration rule does TI follow? We want to know the detail meaning of the intrinsic(9) and extrinsic(12) parameters.
Josh
Please refer the link for more details about intrinsic and extrinsic parameters.
Intrinsic parameter is fixed camera property. intrinsic[9] = [fx,0,cx,0,fy,cy,0,0,1]. I believe this can be found from camera calibration tool. However I will check this internally and will let you know.
Secondly extrinsic parameter is related to pose of the camera. Pose is related to camera position in world co-ordinate. Extrinsic[12] = [r11,r12,r13,t1,r21,r22,r23,t2,r31,r32,r33,t3]. where [t1,t2,t3] are translation parameters, and [r11-r33] are rotation parameters. Extrinsic parameter can found using external sensor mounted to car, e.g. IMU. Or this also can be found using sophisticated computer vision algorithm e.g. solvePnP. solvePnP information can be found in same opencv link shared above.
Can you please let us know more about your project/company ? That will help us in providing better support to you.
Deepak Poddar
You can not use vision sdk calibration tool to find intrinsic parameters. Typically these intrinsic parameters are given by camera manufacturer.
Deepak Poddar
This used in forward collision warning algorithm, which is front camera ADAS algorithm. This algorithm is not related to surround view.
Forward collision warning algorithm, finds the distance of detected object's distance from driving car where camera is installed.
Deepak Poddar
