Linux/AM3351: Cannot open LCD framebuffer
Part Number: AM3351
Other Parts Discussed in Thread: AM3352, TPS65217
Tool/software: Linux
    i am using ti-processor-sdk-03.00.00.04 for enable lcd support for my custom board,
   i am getting error (open /dev/fb0: No such file or directory) while entring fbset command,
  please tell me what are possibility changes to fix it.
my boot log :
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.12-g3639bea54a (root@sridhar-ThinkCentre-M73) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #15 PREE7
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: TI AM335x BeagleBone Black
[    0.000000] cma: Reserved 24 MiB at 0x8d000000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64960
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=0008c673-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 224392K/262144K available (7095K kernel code, 292K rwdata, 2444K rodata, 288K init, 263K bss, 13176K reserved, 24576K c)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0959034   (9541 kB)
[    0.000000]       .init : 0xc095a000 - 0xc09a2000   ( 288 kB)
[    0.000000]       .data : 0xc09a2000 - 0xc09eb248   ( 293 kB)
[    0.000000]        .bss : 0xc09ed000 - 0xc0a2eed8   ( 264 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 19200000 Hz
[    0.000032] sched_clock: 32 bits at 19MHz, resolution 52ns, wraps every 111848106981ns
[    0.000087] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[    0.000111] OMAP clocksource: timer1 at 19200000 Hz
[    0.001133] clocksource_probe: no matching clocksources found
[    0.001513] Console: colour dummy device 80x30
[    0.001574] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001590] This ensures that you still see kernel messages. Please
[    0.001604] update your kernel commandline.
[    0.001640] Calibrating delay loop... 302.28 BogoMIPS (lpj=1511424)
[    0.057729] pid_max: default: 32768 minimum: 301
[    0.058005] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.058035] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.059601] Initializing cgroup subsys io
[    0.059665] Initializing cgroup subsys memory
[    0.059741] Initializing cgroup subsys devices
[    0.059775] Initializing cgroup subsys freezer
[    0.059809] Initializing cgroup subsys perf_event
[    0.059839] Initializing cgroup subsys pids
[    0.059901] CPU: Testing write buffer coherency: ok
[    0.060704] Setting up static identity map for 0x80008200 - 0x80008258
[    0.065832] devtmpfs: initialized
[    0.092689] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.125203] omap_hwmod: debugss: _wait_target_disable failed
[    0.130207] omap_hwmod: d_can0: _wait_target_ready failed: -16
[    0.130234] omap_hwmod: d_can0: cannot be enabled for reset (3)
[    0.134122] omap_hwmod: d_can1: _wait_target_ready failed: -16
[    0.134141] omap_hwmod: d_can1: cannot be enabled for reset (3)
[    0.203392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.208222] pinctrl core: initialized pinctrl subsystem
[    0.211302] NET: Registered protocol family 16
[    0.216480] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.247741] cpuidle: using governor ladder
[    0.277722] cpuidle: using governor menu
[    0.289200] OMAP GPIO hardware version 0.1
[    0.292298] omap_gpio 481ac000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_gpio2_pins, deferrie
[    0.293069] omap_gpio 481ae000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_gpio3_pins, deferrie
[    0.311471] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.379531] edma 49000000.edma: TI EDMA DMA engine driver
[    0.386809] vgaarb: loaded
[    0.388313] SCSI subsystem initialized
[    0.389091] usbcore: registered new interface driver usbfs
[    0.389271] usbcore: registered new interface driver hub
[    0.389498] usbcore: registered new device driver usb
[    0.390764] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring e
[    0.390895] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring e
[    0.391202] media: Linux media interface: v0.10
[    0.391361] Linux video capture interface: v2.00
[    0.391499] pps_core: LinuxPPS API ver. 1 registered
[    0.391519] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.391598] PTP clock support registered
[    0.392134] EDAC MC: Ver: 3.0.0
[    0.394742] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.395452] Advanced Linux Sound Architecture Driver Initialized.
[    0.398345] clocksource: Switched to clocksource timer1
[    0.426111] NET: Registered protocol family 2
[    0.427863] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.427954] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.428026] TCP: Hash tables configured (established 2048 bind 2048)
[    0.428194] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.428247] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.428756] NET: Registered protocol family 1
[    0.429578] RPC: Registered named UNIX socket transport module.
[    0.429612] RPC: Registered udp transport module.
[    0.429629] RPC: Registered tcp transport module.
[    0.429646] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.431739] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.436260] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.457610] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.459759] NFS: Registering the id_resolver key type
[    0.459889] Key type id_resolver registered
[    0.459910] Key type id_legacy registered
[    0.460089] ntfs: driver 2.1.32 [Flags: R/O].
[    0.464633] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.464696] io scheduler noop registered
[    0.464731] io scheduler deadline registered
[    0.465158] io scheduler cfq registered (default)
[    0.469204] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.475897] backlight supply power not found, using dummy regulator
[    0.634516] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.644615] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 94, base_baud = 3000000) is a 8250
[    1.326605] console [ttyS0] enabled
[    1.332584] [drm] Initialized drm 1.1.0 20060810
[    1.358043] loop: module loaded
[    1.367584] libphy: Fixed MDIO Bus: probed
[    1.375343] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.383000] usbcore: registered new interface driver pegasus
[    1.388903] usbcore: registered new interface driver asix
[    1.394424] usbcore: registered new interface driver ax88179_178a
[    1.400683] usbcore: registered new interface driver cdc_ether
[    1.406672] usbcore: registered new interface driver smsc75xx
[    1.412625] usbcore: registered new interface driver smsc95xx
[    1.418532] usbcore: registered new interface driver net1080
[    1.424303] usbcore: registered new interface driver cdc_subset
[    1.430380] usbcore: registered new interface driver zaurus
[    1.436211] usbcore: registered new interface driver cdc_ncm
[    1.443448] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.450067] ehci-pci: EHCI PCI platform driver
[    1.454655] ehci-platform: EHCI generic platform driver
[    1.460354] ehci-omap: OMAP-EHCI Host Controller driver
[    1.465826] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.472113] ohci-pci: OHCI PCI platform driver
[    1.476722] ohci-platform: OHCI generic platform driver
[    1.483149] usbcore: registered new interface driver usb-storage
[    1.490208] mousedev: PS/2 mouse device common for all mice
[    1.497838] i2c /dev entries driver
[    1.505483] cpuidle: enable-method property 'ti,am3352' found operations
[    1.512807] sdhci: Secure Digital Host Controller Interface driver
[    1.519072] sdhci: Copyright(c) Pierre Ossman
[    1.524770] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.608940] Synopsys Designware Multimedia Card Interface Driver
[    1.616019] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.623451] ledtrig-cpu: registered to indicate activity on CPUs
[    1.630160] usbcore: registered new interface driver usbhid
[    1.635718] usbhid: USB HID core driver
[    1.647895] NET: Registered protocol family 10
[    1.652667] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.663360] sit: IPv6 over IPv4 tunneling driver
[    1.670267] NET: Registered protocol family 17
[    1.675000] mmc0: new high speed SDHC card at address aaaa
[    1.681308] Key type dns_resolver registered
[    1.686009] omap_voltage_late_init: Voltage driver support not added
[    1.693864] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[    1.702385] ThumbEE CPU extension supported.
[    1.707004]  mmcblk0: p1 p2
[    1.710700] Registering SWP/SWPB emulation handler
[    1.761599] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.767558] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.775039] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.783729] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 40 kHz
[    1.791797] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 303157 KHz
[    1.799361] cpu cpu0: dev_pm_opp_domain_set_rate: failed to find current OPP for freq 303157894 (-34)
[    1.810876] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 300000 KHz
[    1.821217] hctosys: unable to open rtc device (rtc0)
[    1.835592] ALSA device list:
[    1.838762]   No soundcards found.
[    1.844344] Enter async_synchronize_cookie_domain
[    1.849269] Exit async_synchronize_cookie_domain
[    2.752091] EXT4-fs (mmcblk0p2): recovery complete
[    2.759431] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.767631] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.780422] devtmpfs: mounted
[    2.783491] Enter async_synchronize_cookie_domain
[    2.788706] Exit async_synchronize_cookie_domain
[    2.794225] Freeing unused kernel memory: 288K (c095a000 - c09a2000)
[    2.800608] This architecture does not have kernel memory protection.
[    3.118086] systemd[1]: System time before build time, advancing clock.
[    3.212766] random: systemd urandom read with 39 bits of entropy available
[    3.255884] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCR)
[    3.275615] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[    3.300968] systemd[1]: Set hostname to <am335x-evm>.
[    4.019364] systemd[1]: Configuration file /lib/systemd/system/gpio_init.service is marked executable. Please remove executable permission .
[    4.034204] systemd[1]: Configuration file /lib/systemd/system/gpio_init.service is marked world-writable. Please remove world writability .
[    4.055707] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[    4.629098] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    4.636924] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    4.644864] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    4.652346] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[    4.661794] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    4.715622] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    4.749199] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.779700] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.809835] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.840133] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    4.869613] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.900431] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.962074] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.989661] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.019808] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.049644] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    5.079159] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    5.109203] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.142016] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    5.172430] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    5.209043] systemd[1]: Mounting Debug File System...
[    5.284218] systemd[1]: Starting Journal Service...
[    5.364357] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.426383] systemd[1]: Starting Setup Virtual Console...
[    5.510716] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.625469] systemd[1]: Starting Load Kernel Modules...
[    5.755016] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.823422] systemd[1]: Mounting POSIX Message Queue File System...
[    5.871857] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.[    5.937870] cryptodev: driver 1.8 loaded.
[    5.967560] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    6.119325] systemd[1]: Mounting Temporary Directory...
[    6.314259] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    6.339630] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    6.369449] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    6.400713] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Setup Virtual Console.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Starting udev Coldplug all Devices...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[   10.238566] systemd-journald[69]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[   14.449048] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[  OK  ] Started Load/Save Random Seed.
[   14.580747] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[   14.712894] 47401300.usb-phy supply vcc not found, using dummy regulator
[   14.873370] 47401b00.usb-phy supply vcc not found, using dummy regulator
[  OK  ] Started Create Volatile Files and Directories.
[   15.742673] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[  OK  ] Found device /dev/ttyS0.
[   16.702128] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   16.892624] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   17.026047] omap_hwmod: pruss: _wait_target_ready failed: -16
[   17.153384] ti-pruss 4a300000.pruss: couldn't enable pruss
[   17.182024]  remoteproc0: wkup_m3 is available
[   17.186511]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[   17.200905] ti-pruss: probe of 4a300000.pruss failed with error -16
[   17.226741] omap_hwmod: gfx: failed to hardreset
[   17.428628]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   17.479802] pvrsrvkm 56000000.sgx: Unable to reset SGX!
[   17.604130] omap_hwmod: gfx: _wait_target_ready failed: -16
[   17.708829] PVR_K:(Error): EnableSGXClocks: pm_runtime_get_sync failed (16)
[   17.715843] PVR_K:(Error): SysInitialise: Failed to Enable system clocks (175)
[   17.877109]  remoteproc0: powering up wkup_m3
[   17.927747]  remoteproc0: Booting fw image am335x-pm-firmware.elf, size 216252
[   17.990239] PM: bootloader does not support rtc-only!
[   18.065177]  remoteproc0: remote processor wkup_m3 is now up
[   18.065221] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[   18.101806] asoc-simple-card sound: asoc_simple_card_dai_link_of: Can't find simple-audio-card,codec DT node
[   18.268697] asoc-simple-card sound: parse error -22
[   18.273684] asoc-simple-card: probe of sound failed with error -22
[  OK  ] Found device /dev/ttyS3.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight...htness of backlight:backlight...
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[   21.350913] random: nonblocking pool is initialized
[  OK  ] Started Network Time Synchronization.
[   22.452485] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Found device /dev/mmcblk0p1.
[   27.078232] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[   27.124205] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[   27.186649] hub 1-0:1.0: USB hub found
[   27.211227] hub 1-0:1.0: 1 port detected
[   27.845102] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Synchronize System and HW clocks...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Synchronize System and HW clocks.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Telephony service...
         Starting Login Service...
[  OK  ] Started System Logging Service.
         Starting Permit User Sessions...
[  OK  ] Started Kernel Logging Service.
         Starting uim-sysfs.service...
[  OK  ] Started Start gpio_init script.
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Telephony service.
         Starting Network Service...
[   31.769245] NET: Registered protocol family 15
         Starting Start USB gadget...
         Starting Avahi mDNS/DNS-SD Stack...
[   32.325853] Bluetooth: Core ver 2.21
[  OK  ] Started Permit User Sessions.[   32.353727] NET: Registered protocol family 31
[   32.412567] Bluetooth: HCI device and connection manager initialized
[   32.439237] Bluetooth: HCI socket layer initialized
[   32.444183] Bluetooth: L2CAP socket layer initialized
[   32.486433] Bluetooth: SCO socket layer initialized
[  OK  ] Started Network Service.
[   34.250892] using random self ethernet address
[   34.255392] using random host ethernet address
[   34.292396] using random self ethernet address
[   34.296895] using random host ethernet address
[   34.372087] usb0: HOST MAC 56:97:65:ed:73:c0
[   34.424312] usb0: MAC 62:59:e8:60:72:7c
[   34.499546] Initializing XFRM netlink socket
[   34.675600] Mass Storage Function, version: 2009/09/11
[   34.712634] LUN: removable file: (no medium)
[   34.717665] LUN: removable read only file: /dev/mmcblk0p1
[   34.783103] Number of LUNs=1
[   34.817881] g_multi gadget: Multifunction Composite Gadget
[   34.858592] g_multi gadget: g_multi ready
[  OK  ] Found device /dev/ttyGS0.
[   35.405296] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[  OK  ] Started Start USB gadget.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
         Mounting Configuration File System...
[  OK  ] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
         Starting Network Name Resolution...
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyGS0.
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Network Name Resolution.
[   33.754660] using random self ethernet address
[   33.774062] using random host ethernet address
[   33.808792] using random self ethernet address
[   33.838762] using random host ethernet address
[   33.911535] usb0: HOST MAC 5e:e6:c0:50:86:f8
[   33.939991] usb0: MAC 42:ef:f6:3f:be:20
[   34.135110] Mass Storage Function, version: 2009/09/11
[   34.178322] LUN: removable file: (no medium)
[   34.224010] LUN: removable read only file: /dev/mmcblk0p1
[   34.278659] Number of LUNs=1
[   34.305234] g_multi gadget: Multifunction Composite Gadget
[   34.339312] g_multi gadget: g_multi ready
[   34.825905] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started uim-sysfs.service.
         Starting rc.pvr.service...
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
[  OK  ] Started weston.service.
         Starting telnetd.service...
[  OK  ] Started telnetd.service.
         Starting thttpd.service...
         Starting gpio3_3.service...
         Starting busybox-udhcpd.service...
[  OK  ] Started thttpd.service.
[  OK  ] Started busybox-udhcpd.service.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2016.05 am335x-evm ttyS0
root@am335x-evm:~# ls
root@am335x-evm:~# fbset
root@am335x-evm:~# ls /dev
autofs              ptyd6               ptyt4               ptyz2               ttyS5               ttyp9               ttyv7
block               ptyd7               ptyt5               ptyz3               ttyS6               ttypa               ttyv8
bus                 ptyd8               ptyt6               ptyz4               ttyS7               ttypb               ttyv9
char                ptyd9               ptyt7               ptyz5               ttyS8               ttypc               ttyva
console             ptyda               ptyt8               ptyz6               ttyS9               ttypd               ttyvb
cpu_dma_latency     ptydb               ptyt9               ptyz7               ttya0               ttype               ttyvc
crypto              ptydc               ptyta               ptyz8               ttya1               ttypf               ttyvd
disk                ptydd               ptytb               ptyz9               ttya2               ttyq0               ttyve
fd                  ptyde               ptytc               ptyza               ttya3               ttyq1               ttyvf
thank you,
