Other Parts Discussed in Thread: DRA746
Tool/software: Linux
buffer (NV12)?
the chip is DRA746, use for vehicle infotainment.
I need contact my AE for detailed SDK version.
SDK version:
Version SGX_DDK_Linux_CustomerTI sgxddk 19 1.9@2253347 (release) omap5430_linux System Version String: SGX revision = 1.1.6
GL and EGL info my test:
GL Version = OpenGL ES 2.0 build 1.9@2253347
GL Vendor = Imagination Technologies
GL Renderer = PowerVR SGX 544MP
GL Extensions = GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_vertex_half_float GL_OES_texture_float GL_OES_texture_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_fragment_precision_high GL_OES_compressed_ETC1_RGB8_
texture GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_required_internalformat GL_OES_depth_texture GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_standard_derivatives GL_OES_vertex_array_object GL_OES_egl_
sync GL_OES_texture_npot GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_EXT_discard_framebuffer GL_EXT_shader_texture_lod GL_IMG_shader_binary GL_IMG_texture_compression_pvrtc GL_IMG_texture_compression_pvrtc2 G
L_IMG_texture_npot GL_IMG_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_program_binary GL_IMG_uniform_buffer_object GL_IMG_multisampled_render_to_texture GL_TI_image_external_raw_video
z EGL Extensions: EGL_IMG_client_api_ogl EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_vg_parent_image EGL_IMG_cl_im
age EGL_KHR_fence_sync EGL_IMG_hibernate_process EGL_WL_bind_wayland_display EGL_KHR_surfaceless_gles2 EGL_NV_post_sub_buffer
