Tool/software: TI-RTOS
Hi Team,
What is the maximum size of QSPI flash memory supported in TDA3x? and what are the different QSPI part number is supported to TDA3x? . where can i get this information?
I am using S70FL01GSAGMFB01 QSPI Flash memory and which having 2 chip select. As our SBL is running from QSPI memory and we have connected two CS to TDA3x.
So does it will affect to RBL or SBL.
As we are using two chipselect. Does it will create ambiguity ?. If it will not create any problem then can you please guide where we have make changed for second chipselect in code?
Please make sure that part number is supported in TDA3x.
