Part Number: TDA2HG
Other Parts Discussed in Thread: TDA2, DRA742, PMP, DRA752
Hi Sir
We used TI TDA2 EVM with Linux(linux+BIOS) SDK 3.0.0 for development.
we sometimes found below error message in below three stages
1. At SPL stage
2. At u-boot stage
3. At kernel init stage
U-Boot SPL 2016.05-00002-g68a4cab (Oct 27 2017 - 02:16:08)
DRA752-GP ES1.1
MMC Device 1 not found
*** Warning - No MMC card found, using default environment
Trying to boot from MMC1
spl: falcon_args_file not set in environment, falling back to default
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00002-g68a4cab (Oct 27 2017 - 02:16:08 -0700)
CPU : DRA752-GP ES1.1
Model: TI DRA742
Board: DRA74x EVM REV G.0
DRAM: 1.5 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
** First descriptor is NOT a primary desc on 1:1 **
*** Warning - bad CRC, using default environment
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
165 bytes read in 3 ms (53.7 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3634048 bytes read in 174 ms (19.9 MiB/s)
109715 bytes read in 37 ms (2.8 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x377380 ]
Loading Device Tree to 8ffe2000, end 8ffffc92 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.45-00014-gdee2e68 (root@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Tue Jul 11 20:44:31 PDT 2017
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA742
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES1.1
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef627000 s14848 r8192 d22016 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243264
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=6992fc65-02 rw rootwait ip=none mem=1024M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 328752K/979968K available (6627K kernel code, 371K rwdata, 2492K rodata, 332K init, 290K bss, 446416K reserved, 204800K cma-reserved, 234496K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08f0044 (9121 kB)
[ 0.000000] .init : 0xc08f1000 - 0xc0944000 ( 332 kB)
[ 0.000000] .data : 0xc0944000 - 0xc09a0fd0 ( 372 kB)
[ 0.000000] .bss : 0xc09a2000 - 0xc09ea880 ( 291 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000337] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000345] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000818] Console: colour dummy device 80x30
[ 0.000834] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000840] This ensures that you still see kernel messages. Please
[ 0.000845] update your kernel commandline.
[ 0.000858] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000871] pid_max: default: 32768 minimum: 301
[ 0.000963] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000973] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001506] Initializing cgroup subsys io
[ 0.001522] Initializing cgroup subsys memory
[ 0.001547] Initializing cgroup subsys devices
[ 0.001559] Initializing cgroup subsys freezer
[ 0.001571] Initializing cgroup subsys perf_event
[ 0.001583] Initializing cgroup subsys pids
[ 0.001611] CPU: Testing write buffer coherency: ok
[ 0.001810] /cpus/cpu@0 missing clock-frequency property
[ 0.001826] /cpus/cpu@1 missing clock-frequency property
[ 0.001836] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001876] Setting up static identity map for 0x80008380 - 0x800083e0
[ 0.080164] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080227] Brought up 2 CPUs
[ 0.080240] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080247] CPU: All CPU(s) started in HYP mode.
[ 0.080252] CPU: Virtualization extensions available.
[ 0.080620] devtmpfs: initialized
[ 0.110002] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.110957] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.207336] omap_hwmod: vpe: no dt node
[ 0.207345] ------------[ cut here ]------------
[ 0.207358] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2523 _init.constprop.23+0x200/0x428()
[ 0.207365] omap_hwmod: vpe: doesn't have mpu register target base
[ 0.207371] Modules linked in:
[ 0.207384] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.45-00014-gdee2e68 #1
[ 0.207392] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.207399] Backtrace:
[ 0.207419] [<c00131b8>] (dump_backtrace) from [<c00133b4>] (show_stack+0x18/0x1c)
[ 0.207426] r7:c08fe01c r6:60000013 r5:00000000 r4:c0970e0c
[ 0.207454] [<c001339c>] (show_stack) from [<c02b4e0c>] (dump_stack+0x8c/0xa0)
[ 0.207467] [<c02b4d80>] (dump_stack) from [<c0034f6c>] (warn_slowpath_common+0x88/0xb8)
[ 0.207474] r7:c08fe01c r6:000009db r5:00000009 r4:ef073e58
[ 0.207496] [<c0034ee4>] (warn_slowpath_common) from [<c0034fd4>] (warn_slowpath_fmt+0x38/0x40)
[ 0.207503] r8:000000ab r7:ef1e86c0 r6:00000000 r5:00000000 r4:c08257b0
[ 0.207528] [<c0034fa0>] (warn_slowpath_fmt) from [<c08fe01c>] (_init.constprop.23+0x200/0x428)
[ 0.207534] r3:c0827a90 r2:c08257b0
[ 0.207545] r4:c0954e98
[ 0.207557] [<c08fde1c>] (_init.constprop.23) from [<c08fe374>] (__omap_hwmod_setup_all+0x48/0x98)
[ 0.207564] r10:00000000 r9:c08f1600 r8:000000ab r7:ef1e86c0 r6:c09496b0 r5:c094bb38
[ 0.207585] r4:c0954e98
[ 0.207598] [<c08fe32c>] (__omap_hwmod_setup_all) from [<c000982c>] (do_one_initcall+0x98/0x1e4)
[ 0.207604] r5:c08fe32c r4:c09496b0
[ 0.207620] [<c0009794>] (do_one_initcall) from [<c08f1f68>] (kernel_init_freeable+0x1d4/0x268)
[ 0.207626] r10:00000002 r9:c08f1600 r8:000000ab r7:c0931820 r6:c093eff4 r5:c09a2000
[ 0.207647] r4:c09a2000
[ 0.207664] [<c08f1d94>] (kernel_init_freeable) from [<c0679ce4>] (kernel_init+0x18/0xf4)
[ 0.207670] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0679ccc
[ 0.207690] r4:c09a2000
[ 0.207703] [<c0679ccc>] (kernel_init) from [<c000fb88>] (ret_from_fork+0x14/0x2c)
[ 0.207709] r5:c0679ccc r4:00000000
[ 0.207732] ---[ end trace 98c5860f6f9b790f ]---
[ 0.209863] omap_hwmod: wd_timer2: no dt node
[ 0.209869] ------------[ cut here ]------------
[ 0.209880] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2523 _init.constprop.23+0x200/0x428()
[ 0.209887] omap_hwmod: wd_timer2: doesn't have mpu register target base
[ 0.209892] Modules linked in:
[ 0.209904] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.45-00014-gdee2e68 #1
[ 0.209910] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.209916] Backtrace:
[ 0.209932] [<c00131b8>] (dump_backtrace) from [<c00133b4>] (show_stack+0x18/0x1c)
[ 0.209939] r7:c08fe01c r6:60000013 r5:00000000 r4:c0970e0c
[ 0.209963] [<c001339c>] (show_stack) from [<c02b4e0c>] (dump_stack+0x8c/0xa0)
[ 0.209974] [<c02b4d80>] (dump_stack) from [<c0034f6c>] (warn_slowpath_common+0x88/0xb8)
[ 0.209980] r7:c08fe01c r6:000009db r5:00000009 r4:ef073e58
[ 0.210001] [<c0034ee4>] (warn_slowpath_common) from [<c0034fd4>] (warn_slowpath_fmt+0x38/0x40)
[ 0.210006] r8:000000ab r7:ef1e86c0 r6:00000000 r5:00000000 r4:c08257b0
[ 0.210030] [<c0034fa0>] (warn_slowpath_fmt) from [<c08fe01c>] (_init.constprop.23+0x200/0x428)
[ 0.210036] r3:c0824ad0 r2:c08257b0
[ 0.210047] r4:c0950018
[ 0.210059] [<c08fde1c>] (_init.constprop.23) from [<c08fe374>] (__omap_hwmod_setup_all+0x48/0x98)
[ 0.210064] r10:00000000 r9:c08f1600 r8:000000ab r7:ef1e86c0 r6:c09496b0 r5:c094bb38
[ 0.210085] r4:c0950018
[ 0.210097] [<c08fe32c>] (__omap_hwmod_setup_all) from [<c000982c>] (do_one_initcall+0x98/0x1e4)
[ 0.210103] r5:c08fe32c r4:c09496b0
[ 0.210118] [<c0009794>] (do_one_initcall) from [<c08f1f68>] (kernel_init_freeable+0x1d4/0x268)
[ 0.210124] r10:00000002 r9:c08f1600 r8:000000ab r7:c0931820 r6:c093eff4 r5:c09a2000
[ 0.210145] r4:c09a2000
[ 0.210158] [<c08f1d94>] (kernel_init_freeable) from [<c0679ce4>] (kernel_init+0x18/0xf4)
[ 0.210164] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0679ccc
[ 0.210184] r4:c09a2000
[ 0.210197] [<c0679ccc>] (kernel_init) from [<c000fb88>] (ret_from_fork+0x14/0x2c)
[ 0.210203] r5:c0679ccc r4:00000000
[ 0.210229] ---[ end trace 98c5860f6f9b7910 ]---
[ 0.320995] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.325286] pinctrl core: initialized pinctrl subsystem
[ 0.326145] NET: Registered protocol family 16
[ 0.327069] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.350391] cpuidle: using governor ladder
[ 0.380418] cpuidle: using governor menu
[ 0.388968] OMAP GPIO hardware version 0.1
[ 0.395488] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.412325] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.412339] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.422035] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.422045] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.422514] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.422524] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.423100] OMAP DMA hardware revision 0.0
[ 0.461687] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.462850] edma 43300000.edma: memcpy is disabled
[ 0.467466] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.471747] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.471934] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.472100] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.472264] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.472548] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.472751] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.475943] palmas 0-0058: IRQ missing: skipping irq request
[ 0.491093] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[ 0.563397] pcf857x 0-0020: probed
[ 0.563980] pcf857x 0-0021: probed
[ 0.564133] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.581094] pcf857x 1-0026: probed
[ 0.581633] mcp230xx: probe of 1-0027 failed with error -121
[ 0.581862] mcp230xx: probe of 1-0021 failed with error -121
[ 0.582086] mcp230xx: probe of 1-0025 failed with error -121
[ 0.582816] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.583198] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.583406] media: Linux media interface: v0.10
[ 0.583457] Linux video capture interface: v2.00
[ 0.583495] pps_core: LinuxPPS API ver. 1 registered
[ 0.583502] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.583525] PTP clock support registered
[ 0.583572] EDAC MC: Ver: 3.0.0
[ 0.584345] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.584643] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.584998] Advanced Linux Sound Architecture Driver Initialized.
[ 0.585846] clocksource: Switched to clocksource arch_sys_counter
[ 0.596396] NET: Registered protocol family 2
[ 0.596894] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.596957] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.597082] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.597131] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.597162] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.597364] NET: Registered protocol family 1
[ 0.597631] RPC: Registered named UNIX socket transport module.
[ 0.597640] RPC: Registered udp transport module.
[ 0.597647] RPC: Registered tcp transport module.
[ 0.597653] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.598649] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.601047] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.608697] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.609352] NFS: Registering the id_resolver key type
[ 0.609379] Key type id_resolver registered
[ 0.609386] Key type id_legacy registered
[ 0.609456] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.611418] bounce: pool size: 64 pages
[ 0.611568] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.611585] io scheduler noop registered
[ 0.611600] io scheduler deadline registered
[ 0.611635] io scheduler cfq registered (default)
[ 0.616568] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.619719] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.619732] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.619765] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.619786] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.649646] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.649819] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.649832] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.649843] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.649853] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.650260] PCI: bus0: Fast back to back transfers disabled
[ 0.650378] PCI: bus1: Fast back to back transfers enabled
[ 0.650463] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.650477] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.650490] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.650711] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.652864] fpd3_serdes 1-001b: Removed conflict b/w HDMI SIL
[ 0.674526] fpd3_serdes: probe of 7-002c failed with error -5
[ 0.674685] fpd3_serdes 1-001b: Serializer fpd3_24b_ser ready
[ 0.676634] fpd3_serdes 7-002c: Deserializer fpd3_24b_des ready
[ 0.736687] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.740031] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 2.187274] console [ttyS0] enabled
[ 2.191672] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 2.201385] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[ 2.211438] [drm] Initialized drm 1.1.0 20060810
[ 2.218087] OMAP DSS rev 6.1
[ 2.221855] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.230224] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.326199] loop: module loaded
[ 2.329833] vmemexp device MAJOR num = 246
[ 2.333960] vmemexp class registered
[ 2.337693] /dev/vmemexp device registered
[ 2.341808] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 2.347516] nand: No NAND device found
[ 2.351286] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[ 2.361083] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0
[ 2.368638] libphy: Fixed MDIO Bus: probed
[ 2.415878] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 2.422003] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[ 2.442218] libphy: 48485000.mdio: probed
[ 2.446289] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 2.454330] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 2.463048] cpsw 48484000.ethernet: Detected MACID = 7c:66:9d:f1:d8:92
[ 2.469745] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 2.476743] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:66:9d:f1:d8:93
[ 2.485384] mousedev: PS/2 mouse device common for all mice
[ 2.501806] i2c /dev entries driver
[ 2.506307] ov1063x 1-0037: Failed writing register 0x0103!
[ 2.511919] ov1063x: probe of 1-0037 failed with error -121
[ 2.517887] ov1063x 1-0030: Failed writing register 0x0103!
[ 2.523495] ov1063x: probe of 1-0030 failed with error -121
[ 2.534165] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.566476] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.572862] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.579421] evm_3v3_sw: supplied by sysen1
[ 2.659631] mmc0: MAN_BKOPS_EN bit is not set
[ 2.669512] mmc0: new HS200 MMC card at address 0001
[ 2.684959] mmcblk0: mmc0:0001 MMC08G 7.25 GiB
[ 2.689752] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB
[ 2.705959] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB
[ 3.030198] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.039333] aic_dvdd: supplied by evm_3v3_sw
[ 3.045108] davinci-mcasp 48468000.mcasp: ERRATA i868 workaround is enabled
[ 3.052376] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[ 3.059430] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 3.070262] NET: Registered protocol family 10
[ 3.075542] sit: IPv6 over IPv4 tunneling driver
[ 3.080751] NET: Registered protocol family 17
[ 3.085437] Key type dns_resolver registered
[ 3.089856] omap_voltage_late_init: Voltage driver support not added
[ 3.096778] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.102992] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.109719] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.115974] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.124188] Power Management for TI OMAP4+ devices.
[ 3.129332] Registering SWP/SWPB emulation handler
[ 3.136261] dmm 4e000000.dmm: initialized all PAT entries
[ 3.144471] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.151147] [drm] No driver support for vblank timestamp query.
[ 3.157586] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 3.164972] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 3.207180] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 3.221991] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 3.228899] hctosys: unable to open rtc device (rtc0)
[ 3.242543] aic_dvdd: disabling
[ 3.245699] vmmcwl_fixed: disabling
[ 3.249391] ldousb: disabling
[ 3.252785] ALSA device list:
[ 3.255762] #0: DRA7xx-EVM
[ 3.258667] #1: HDMI 58040000.encoder
[ 3.263164] Waiting for root device PARTUUID=6992fc65-02...
[ 3.357933] omap_hsmmc 4809c000.mmc: card busy
[ 3.517930] omap_hsmmc 4809c000.mmc: card busy
[ 3.678025] omap_hsmmc 4809c000.mmc: card busy
[ 3.837949] omap_hsmmc 4809c000.mmc: card busy
[ 3.997936] omap_hsmmc 4809c000.mmc: card busy
[ 4.157945] omap_hsmmc 4809c000.mmc: card busy
[ 4.317946] omap_hsmmc 4809c000.mmc: card busy
[ 4.477947] omap_hsmmc 4809c000.mmc: card busy
[ 4.637946] omap_hsmmc 4809c000.mmc: card busy
[ 4.797946] omap_hsmmc 4809c000.mmc: card busy
[ 4.835866] mmc2: Skipping voltage switch
[ 4.943161] mmc2: host does not support reading read-only switch, assuming write-enable
[ 4.953219] mmc2: new high speed SDHC card at address 0007
[ 4.959210] mmcblk1: mmc2:0007 SD04G 3.71 GiB
[ 4.964875] mmcblk1: p1 p2
[ 5.027143] EXT4-fs (mmcblk1p2): couldn't mount as ext3 due to feature incompatibilities
[ 5.036344] EXT4-fs (mmcblk1p2): couldn't mount as ext2 due to feature incompatibilities
[ 5.502231] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.510436] VFS: Mounted root (ext4 filesystem) on device 179:50.
[ 5.517514] devtmpfs: mounted
[ 5.520719] Freeing unused kernel memory: 332K (c08f1000 - c0944000)
[ 5.528020] This architecture does not have kernel memory protection.
[ 5.796953] systemd[1]: System time before build time, advancing clock.
[ 5.843330] random: systemd: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[ 5.856920] random: systemd: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[ 5.868657] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 5.887185] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 5.917001] systemd[1]: Set hostname to <dra7xx-evm>.
[ 5.982523] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 6.017013] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 6.027263] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 6.051717] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[ 6.072356] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[ 6.175084] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 6.184623] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 6.194592] random: systemd: uninitialized urandom read (16 bytes read, 31 bits of entropy available)
[ 6.546478] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 6.554267] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 6.562034] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 6.569340] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 6.576789] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 6.586267] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 6.619639] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 6.646668] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 6.678375] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 6.706080] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 6.726157] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.746129] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 6.776151] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.806037] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 6.826214] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 6.846034] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.866081] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 6.886073] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 6.906180] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 6.926170] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 6.956061] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 6.976645] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 6.996149] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.056209] systemd[1]: Starting Load Kernel Modules...
[ 7.088240] systemd[1]: Mounting Debug File System...
[ 7.118258] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.132326] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 7.186269] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 7.218151] systemd[1]: Starting Setup Virtual Console...
[ 7.248966] systemd[1]: Mounting Temporary Directory...
[ 7.278254] systemd[1]: Starting Journal Service...
[ 7.308400] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.342819] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 7.366126] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 7.386093] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 7.416317] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Setup Virtual Console.
Starting Create Static Device Nodes in /dev...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 8.067820] systemd-journald[150]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Mounting /media/ram...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ 8.585376] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
Starting Create Volatile Files and Directories...
[ 8.606067] remoteproc0: 58820000.ipu is available
[ OK ] Started Load/Save Random Seed.[ 8.627800] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 8.671152] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Create Volatile Files and Directories.[ 8.706975] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 8.721856] remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 8.750511] remoteproc0: failed to load dra7-ipu1-fw.xem4
[ 8.761907] remoteproc1: 55020000.ipu is available
[ OK ] Found device /dev/ttyS0.[ 8.767320] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 8.803676] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 8.819458] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
Starting Update UTMP about System Boot/Shutdown...
[ 8.843195] remoteproc2: 40800000.dsp is available
[ 8.848774] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 8.864023] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 8.888684] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
Starting Network Time Synchronization...
[ 8.908499] remoteproc3: 41000000.dsp is available
[ 8.915722] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 8.952759] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[ 9.629553] SCSI subsystem initialized
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 9.770798] remoteproc2: registered virtio0 (type 7)
[ 9.873363] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 9.938559] CAN device driver interface
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Reached target Basic System.
Starting Avahi mDNS/DNS-SD Stack...
Starting uim-sysfs.service...
Starting Permit User Sessions...
Starting Telephony service...
[ 10.345818] remoteproc1: registered virtio1 (type 7)
[ OK ] Started System Logging Service.
[ OK ] Started Kernel Logging Service.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting Print notice about GPLv3 packages...
[ 11.393572] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[ 11.406912] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 11.413320] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 11.423496] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 11.433144] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
Starting Save/Restore Sound Card State...
[ OK ] Started D-Bus System Message Bus.
[ 11.523843] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=359)
[ 11.558509] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 11.568113] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 11.571951] remoteproc3: registered virtio2 (type 7)
[ 11.588068] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 11.616052] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 11.684392] scsi host0: ahci
[ 11.687788] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 343
[ 11.716089] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 12.055906] ata1: SATA link down (SStatus 0 SControl 300)
[ 12.177197] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 12.206489] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
Starting Network Service...
Starting Login Service...
[ OK ] Started Permit User Sessions.
[ OK ] Started Save/Restore Sound Card State.
[ 12.678155] Bluetooth: Core ver 2.21
[ 12.681790] NET: Registered protocol family 31
[ 12.732304] Bluetooth: HCI device and connection manager initialized
[ 12.754329] Bluetooth: HCI socket layer initialized
[ 12.759270] Bluetooth: L2CAP socket layer initialized
[ 12.836263] Bluetooth: SCO socket layer initialized
[ 12.841648] NET: Registered protocol family 15
[ 12.847917] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 12.880607] net eth1: initializing cpsw version 1.15 (0)
[ OK ] Started Network Service.
[ 12.920606] net eth0: initialized cpsw ale version 1.4
[ 12.955762] net eth0: ALE Table size 1024
[ 13.089921] net eth1: phy found : id is : 0x20005c7a
[ 13.183526] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 13.307013] net eth0: initializing cpsw version 1.15 (0)
[ 13.325515] Initializing XFRM netlink socket
[ 13.349136] remoteproc2: powering up 40800000.dsp
[ 13.373049] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 7432816
[ 13.394916] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 13.400817] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 13.406762] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 13.449662] net eth0: phy found : id is : 0x20005c7a
[ 13.470338] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.474596] remoteproc2: remote processor 40800000.dsp is now up
[ 13.482560] virtio_rpmsg_bus virtio0: rpmsg host is online
[ OK ] Started uim-sysfs.service.
[ 13.507102] remoteproc1: powering up 55020000.ipu
[ 13.548458] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 8835344
[ 13.566799] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 13.623807] remoteproc1: remote processor 55020000.ipu is now up
[ 13.656149] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 13.662403] remoteproc3: powering up 41000000.dsp
[ 13.683376] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 7432816
[ 13.712466] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 13.718361] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 13.724297] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 13.806380] remoteproc3: remote processor 41000000.dsp is now up
[ 13.813822] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 13.897362] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[ 13.906680] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[ 13.925890] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
[ 13.942731] NET: Registered protocol family 41
[ 14.000289] random: nonblocking pool is initialized
Starting rc.pvr.service...
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Network Name Resolution...
[ OK ] Reached target Sound Card.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Started Login Service.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ 14.391825] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ OK ] Started Network Name Resolution.
[ 14.530235] usbcore: registered new interface driver usbfs
[ 14.536703] usbcore: registered new interface driver hub
[ 14.542329] usbcore: registered new device driver usb
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ 14.633326] dwc3 48890000.usb: otg: primary host xhci-hcd.1.auto registered
[ 14.640541] dwc3 48890000.usb: otg: shared host xhci-hcd.1.auto registered
[ 14.649690] dwc3 48890000.usb: otg: can't start till gadget registers
[ 14.656854] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.662795] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 14.672561] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 14.681455] xhci-hcd xhci-hcd.2.auto: irq 502, io mem 0x488d0000
[ 14.689556] hub 1-0:1.0: USB hub found
[ 14.693363] hub 1-0:1.0: 1 port detected
[ 14.693676] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.693689] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 14.693755] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.694806] hub 2-0:1.0: USB hub found
[ 14.694831] hub 2-0:1.0: 1 port detected
[ OK ] Started weston.service.
Starting tiipclad-daemon.service...
Starting telnetd.service...
[ OK ] Started telnetd.service.
[ OK ] Started tiipclad-daemon.service.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting gdbserverproxy.service...
[ OK ] Started gdbserverproxy.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils-dev
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gstreamer1.0-libav
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
parted
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: root
root@dra7xx-evm:~# cd /opt/vision_sdk/
root@dra7xx-evm:/opt/vision_sdk# ./camnodes.sh
cam device major num is
BusyBox v1.24.1 (2017-03-09 08:05:24 IST) multi-call binary.
Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
ls: /dev/cam*: No such file or directory
root@dra7xx-evm:/opt/vision_sdk# ./memcache_load.sh
[ 36.857533] DMA: Module install successful, device major num = 243
[ 36.863838] DRV: Module install successful
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
[HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb69a8000 of size 0x00100000
[HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa1fa8000 of size 0x14a00000
[HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa1ee8000 of size 0x00040000
[HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa1f28000 of size 0x00080000
[HOST] OSA: MEM: 4: Mapped 0xa0530000 to 0xa1ce8000 of size 0x00200000
[HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
[HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
[HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280
[HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20
[HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0
[HOST] OSA: EVE3 Remote Log Shared Memory @ 0xa0314c60
[HOST] OSA: EVE4 Remote Log Shared Memory @ 0xa033c500
[HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
[HOST] [HOST ] 46.665405 s: SYSTEM: System A15 Init in progress !!!
[HOST] [HOST ] 46.665497 s: SYSTEM: IPC: Init in progress !!!
[HOST] [HOST ] 46.665497 s: SYSTEM: IPC: Notify init in progress !!!
[HOST] [HOST ] 46.666870 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
[HOST] [HOST ] 46.666900 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 46.666931 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
[HOST] [HOST ] 46.666961 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 46.668120 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
[HOST] [HOST ] 46.668151 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 46.668181 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
[HOST] [HOST ] 46.668212 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 46.669340 s: SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81)
[HOST] [HOST ] 46.669340 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 46.669371 s: SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80)
[HOST] [HOST ] 46.669401 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 46.669523 s: SYSTEM: IPC: Notify init DONE !!!
[HOST] [HOST ] 46.669554 s: SYSTEM: MSGQ: MsgQ init in progress !!!
[HOST] [HOST ] 46.669706 s: SYSTEM: MSGQ: MsgQ init DONE !!!
[HOST] [HOST ] 46.669737 s: SYSTEM: IPC: Init DONE !!!
[HOST] [HOST ] 46.669737 s: SYSTEM: Initializing A15 Links !!!
[HOST] [HOST ] 46.669859 s: IPC_OUT_0 : Init done - linkid-0x2000000
[HOST] [HOST ] 46.670011 s: IPC_OUT_1 : Init done - linkid-0x2000001
[HOST] [HOST ] 46.670133 s: IPC_OUT_2 : Init done - linkid-0x2000002
[HOST] [HOST ] 46.670255 s: IPC_OUT_3 : Init done - linkid-0x2000003
[HOST] [HOST ] 46.670377 s: IPC_OUT_4 : Init done - linkid-0x2000004
[HOST] [HOST ] 46.670499 s: IPC_IN_0 : Init done - linkid-0x200000a
[HOST] [HOST ] 46.670621 s: IPC_IN_1 : Init done - linkid-0x200000b
[HOST] [HOST ] 46.670743 s: IPC_IN_2 : Init done - linkid-0x200000c
[HOST] [HOST ] 46.670865 s: IPC_IN_3 : Init done - linkid-0x200000d
[HOST] [HOST ] 46.671018 s: IPC_IN_4 : Init done - linkid-0x200000e
[HOST] [HOST ] 46.671109 s: IPC_IN_5 : Init done - linkid-0x200000f
[HOST] [HOST ] 46.671262 s: IPC_IN_6 : Init done - linkid-0x2000010
[HOST] [HOST ] 46.671384 s: NULL_0 : Init done - linkid-0x2000014
[HOST] [HOST ] 46.671506 s: NULL_1 : Init done - linkid-0x2000015
[HOST] [HOST ] 46.671689 s: NULL_SRC_0 : Init done - linkid-0x2000039
[HOST] [HOST ] 46.671841 s: SGX3DSRV_0 : Init done - linkid-0x2000041
[HOST] [HOST ] 46.671963 s: ALGORITHM_0 : Init done - linkid-0x2000031
[HOST] [HOST ] 46.672116 s: ALGORITHM_1 : Init done - linkid-0x2000032
[HOST] [HOST ] 46.672207 s: ALGORITHM_2 : Init done - linkid-0x2000033
[ 40.333690] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[ 40.359911] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[HOST] [HOST ] 46.672512 s: ALGORITHM_4 : Init done - likid-0x2000035
[HOST] [HOST ] 46.672634 s: ALGORITHM_5 : Init done - linkid-0x2000036
[HOST] [HOST ] 46.672756 s: ALGORITHM_6 : Init done - linkid-0x2000037
[HOST] [HOST ] 46.672909 s: ALGORITHM_7 : Init done - linkid-0x2000038
[HOST] [HOST ] 46.673092 s: DUP0 : Init done - linkid-0x0
[HOST] [HOST ] 46.673305 s: DUP1 : Init done - linkid-0x0
[HOST] [HOST ] 46.673458 s: DUP2 : Init done - linkid-0x0
[HOST] [HOST ] 46.673641 s: DUP3 : Init done - linkid-0x0
[HOST] [HOST ] 46.673824 s: DUP4 : Init done - linkid-0x0
[HOST] [HOST ] 46.673946 s: SYNC_0 : Init done - linkid-0x0
[HOST] [HOST ] 46.674068 s: SYNC_1 : Init done - linkid-0x0
[HOST] [HOST ] 46.674190 s: SYNC_2 : Init done - linkid-0x0
[HOST] [HOST ] 46.674312 s: SYNC_3 : Init done - linkid-0x0
[HOST] [HOST ] 46.674464 s: MERGE_0 : Init done - linkid-0x0
[HOST] [HOST ] 46.674586 s: MERGE_1 : Init done - linkid-0x0
[HOST] [HOST ] 46.674739 s: MERGE_2 : Init done - linkid-0x0
[HOST] [HOST ] 46.674861 s: MERGE_3 : Init done - linkid-0x0
[HOST] [HOST ] 46.675013 s: MERGE_4 : Init done - linkid-0x0
[HOST] [HOST ] 46.675166 s: SELECT_0 : Init done - linkid-0x0
[HOST] [HOST ] 46.675288 s: SELECT_1 : Init done - linkid-0x0
[HOST] [HOST ] 46.675410 s: GATE_0 : Init done - linkid-0x0
[HOST] [HOST ] 46.678978 s: GATE_1 : Init done - linkid-0x0
[HOST] [HOST ] 46.679100 s: GATE_2 : Init done - linkid-0x0
[HOST] [HOST ] 46.679222 s: GATE_3 : Init done - linkid-0x0
[HOST] [HOST ] 46.679344 s: SGXFRMCPY_0 : Init done - linkid-0x2000040
[HOST] [HOST ] 46.679466 s: SGX3DSFM_0 : Init done - linkid-0x2000042
[HOST] [HOST ] 46.679466 s: SYSTEM: Initializing A15 Links ... DONE !!!
[HOST] [HOST ] 46.680290 s: OSA: Adjusting global time, timeH by 0 units!!!
VX_ZONE_INIT:Enabled
VX_ZONE_ERROR:Enabled
VX_ZONE_WARNING:Enabled
[HOST] [DSP1 ] 20.167236 s: ***** DSP1 Firmware build time 18:05:22 Jul 17 2017
[HOST] [DSP1 ] 20.167327 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[HOST] [DSP1 ] 20.174190 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP1 ] 20.174434 s: UTILS: CIO: Init Done !!!
[HOST] [DSP1 ] 20.174464 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP1 ] 20.174495 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 20.491337 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [DSP1 ] 20.510553 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [DSP1 ] 20.535594 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [DSP1 ] 20.555633 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [DSP1 ] 20.575642 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [DSP1 ] 20.595589 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [DSP1 ] 20.595620 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [DSP1 ] 20.595681 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [DSP1 ] 20.595742 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [DSP1 ] 20.595772 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [DSP1 ] 20.595803 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [DSP1 ] 20.595864 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [DSP1 ] 20.595894 s: SYSTEM: Notify init done !!!
[HOST] [DSP1 ] 20.596047 s: SYSTEM: MsgQ init done !!!
[HOST] [DSP1 ] 20.596169 s: SYSTEM: IPC init DONE !!!
[HOST] [DSP1 ] 20.596840 s: tivxInit CoreId = 3
[HOST] [DSP1 ] 20.596901 s: VX_ZONE_INIT:Enabled
[HOST] [DSP1 ] 20.596931 s: VX_ZONE_ERROR:Enabled
[HOST] [DSP1 ] 20.596962 s: VX_ZONE_WARNING:Enabled
[HOST] [DSP1 ] 20.597297 s: VX_ZONE_INIT:[ownReserveC66xL2MEM:97] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes @ 0x0082c000 !!!
[HOST] [DSP1 ] 20.597663 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [DSP1 ] 20.597694 s: SYSTEM: System Common Init Done !!!
[HOST] [DSP1 ] 20.597724 s: SYSTEM: System DSP Init in progress !!!
[HOST] [DSP1 ] 20.597968 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [DSP1 ] 20.597999 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP1 ] 20.598029 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516216 B (504 KB)
[HOST] [DSP1 ] 20.598060 s: SYSTEM: Initializing Links !!!
[HOST] [DSP1 ] 20.605288 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [DSP1 ] 20.605349 s: SYSTEM: System DSP Init Done !!!
[HOST] [DSP1 ] 20.928445 s: UTILS: XMC_MPU: Segments used = 5
[HOST] [DSP1 ] 20.928475 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[HOST] [DSP1 ] 20.928506 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[HOST] [DSP2 ] 20.499115 s: ***** DSP2 Firmware build time 18:08:18 Jul 17 2017
[HOST] [DSP2 ] 20.499176 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[HOST] [DSP2 ] 20.505459 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP2 ] 20.505703 s: UTILS: CIO: Init Done !!!
[HOST] [DSP2 ] 20.505734 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP2 ] 20.505764 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 20.508601 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [DSP2 ] 20.510553 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [DSP2 ] 20.545507 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [DSP2 ] 20.565515 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [DSP2 ] 20.585493 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [DSP2 ] 20.605502 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [DSP2 ] 20.605532 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [DSP2 ] 20.605593 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [DSP2 ] 20.605654 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [DSP2 ] 20.605685 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [DSP2 ] 20.605746 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [DSP2 ] 20.605776 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [DSP2 ] 20.605807 s: SYSTEM: Notify init done !!!
[HOST] [DSP2 ] 20.605990 s: SYSTEM: MsgQ init done !!!
[HOST] [DSP2 ] 20.606081 s: SYSTEM: IPC init DONE !!!
[HOST] [DSP2 ] 20.606752 s: tivxInit CoreId = 4
[HOST] [DSP2 ] 20.606813 s: VX_ZONE_INIT:Enabled
[HOST] [DSP2 ] 20.606874 s: VX_ZONE_ERROR:Enabled
[HOST] [DSP2 ] 20.606905 s: VX_ZONE_WARNING:Enabled
[HOST] [DSP2 ] 20.607240 s: VX_ZONE_INIT:[ownReserveC66xL2MEM:97] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes @ 0x0082c000 !!!
[HOST] [DSP2 ] 20.607606 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [DSP2 ] 20.607637 s: SYSTEM: System Common Init Done !!!
[HOST] [DSP2 ] 20.607667 s: SYSTEM: System DSP Init in progress !!!
[HOST] [DSP2 ] 20.607911 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [DSP2 ] 20.607942 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP2 ] 20.607972 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516216 B (504 KB)
[HOST] [DSP2 ] 20.608003 s: SYSTEM: Initializing Links !!!
[HOST] [DSP2 ] 20.616726 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [DSP2 ] 20.616787 s: SYSTEM: System DSP Init Done !!!
[HOST] [DSP2 ] 20.930458 s: UTILS: XMC_MPU: Segments used = 5
[HOST] [DSP2 ] 20.930488 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[HOST] [DSP2 ] 20.930519 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[HOST] [EVE1 ] 20.489050 s: ***** EVE Firmware build time 18:00:30 Jul 17 2017
[HOST] [EVE1 ] 20.490819 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE1 ] 20.493991 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE1 ] 20.496217 s: UTILS: CIO: Init Done !!!
[HOST] [EVE1 ] 20.497193 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE1 ] 20.498169 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE1 ] 20.525925 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE1 ] 20.535594 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE1 ] 20.545507 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE1 ] 20.585646 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE1 ] 20.615628 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE1 ] 20.635637 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE1 ] 20.636735 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE1 ] 20.637985 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE1 ] 20.639205 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE1 ] 20.640486 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE1 ] 20.641706 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE1 ] 20.643018 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE1 ] 20.644268 s: SYSTEM: Notify init done !!!
[HOST] [EVE1 ] 20.645976 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE1 ] 20.646861 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE1 ] 20.659763 s: tivxInit CoreId = 5
[HOST] [EVE1 ] 20.661227 s: VX_ZONE_INIT:Enabled
[HOST] [EVE1 ] 20.662660 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE1 ] 20.664124 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE1 ] 20.667876 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [EVE1 ] 20.668944 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE1 ] 20.669920 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE1 ] 20.671323 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE1 ] 20.672451 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE1 ] 20.673671 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE1 ] 20.675989 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE1 ] 20.678124 s: SYSTEM: Initializing Links !!!
[HOST] [EVE1 ] 20.762520 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE1 ] 20.763527 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE2 ] 20.489294 s: ***** EVE Firmware build time 18:01:36 Jul 17 2017
[HOST] [EVE2 ] 20.491063 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE2 ] 20.494357 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE2 ] 20.496522 s: UTILS: CIO: Init Done !!!
[HOST] [EVE2 ] 20.497468 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE2 ] 20.498474 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE2 ] 20.545964 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE2 ] 20.555633 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE2 ] 20.565515 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE2 ] 20.585646 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE2 ] 20.635484 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE2 ] 20.655462 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE2 ] 20.656530 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE2 ] 20.657841 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE2 ] 20.659153 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE2 ] 20.660464 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE2 ] 20.661776 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE2 ] 20.663057 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE2 ] 20.664460 s: SYSTEM: Notify init done !!!
[HOST] [EVE2 ] 20.666259 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE2 ] 20.667205 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE2 ] 20.680351 s: tivxInit CoreId = 6
[HOST] [EVE2 ] 20.681906 s: VX_ZONE_INIT:Enabled
[HOST] [EVE2 ] 20.683401 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE2 ] 20.685017 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE2 ] 20.688891 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [EVE2 ] 20.689989 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE2 ] 20.690965 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE2 ] 20.692399 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE2 ] 20.693558 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE2 ] 20.694900 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE2 ] 20.697126 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE2 ] 20.699261 s: SYSTEM: Initializing Links !!!
[HOST] [EVE2 ] 20.783901 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE2 ] 20.784999 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE3 ] 20.489233 s: ***** EVE Firmware build time 18:02:37 Jul 17 2017
[HOST] [EVE3 ] 20.490971 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE3 ] 20.494265 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE3 ] 20.496400 s: UTILS: CIO: Init Done !!!
[HOST] [EVE3 ] 20.497346 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE3 ] 20.498322 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE3 ] 20.565942 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE3 ] 20.575642 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE3 ] 20.585493 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE3 ] 20.615628 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE3 ] 20.635484 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE3 ] 20.675471 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE3 ] 20.676538 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE3 ] 20.677911 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE3 ] 20.679314 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE3 ] 20.680717 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE3 ] 20.682089 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE3 ] 20.683492 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE3 ] 20.684926 s: SYSTEM: Notify init done !!!
[HOST] [EVE3 ] 20.686817 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE3 ] 20.687824 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE3 ] 20.700817 s: tivxInit CoreId = 7
[HOST] [EVE3 ] 20.702372 s: VX_ZONE_INIT:Enabled
[HOST] [EVE3 ] 20.703867 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE3 ] 20.705514 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE3 ] 20.709388 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [EVE3 ] 20.710455 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE3 ] 20.711431 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE3 ] 20.712865 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE3 ] 20.714024 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE3 ] 20.715366 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE3 ] 20.717592 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE3 ] 20.719697 s: SYSTEM: Initializing Links !!!
[HOST] [EVE3 ] 20.800646 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE3 ] 20.801653 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE4 ] 20.489324 s: ***** EVE Firmware build time 18:03:42 Jul 17 2017
[HOST] [EVE4 ] 20.491093 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE4 ] 20.494357 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE4 ] 20.496522 s: UTILS: CIO: Init Done !!!
[HOST] [EVE4 ] 20.497437 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE4 ] 20.498444 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE4 ] 20.585951 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE4 ] 20.595589 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE4 ] 20.605502 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE4 ] 20.635637 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE4 ] 20.655462 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE4 ] 20.675471 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE4 ] 20.676538 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE4 ] 20.677911 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE4 ] 20.679314 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE4 ] 20.680686 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE4 ] 20.682089 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE4 ] 20.683462 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE4 ] 20.684895 s: SYSTEM: Notify init done !!!
[HOST] [EVE4 ] 20.686787 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE4 ] 20.687854 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE4 ] 20.700847 s: tivxInit CoreId = 8
[HOST] [EVE4 ] 20.702403 s: VX_ZONE_INIT:Enabled
[HOST] [EVE4 ] 20.703928 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE4 ] 20.705545 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE4 ] 20.709418 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [EVE4 ] 20.710486 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE4 ] 20.711462 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE4 ] 20.712895 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE4 ] 20.714085 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE4 ] 20.715427 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE4 ] 20.717653 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE4 ] 20.719758 s: SYSTEM: Initializing Links !!!
[HOST] [EVE4 ] 20.800707 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE4 ] 20.801714 s: SYSTEM: System EVE Init Done !!!
[HOST] [IPU2 ] 20.380070 s:
[HOST] [IPU2 ] EVE1 Image Load Completed
[HOST] [IPU2 ] 20.410815 s:
[HOST] [IPU2 ] EVE2 Image Load Completed
[HOST] [IPU2 ] 20.441499 s:
[HOST] [IPU2 ] EVE3 Image Load Completed
[HOST] [IPU2 ] 20.473525 s:
[HOST] [IPU2 ] EVE4 Image Load Completed
[HOST] [IPU2 ] 20.473647 s:
[HOST] [IPU2 ] EVE MMU configuration completed
[HOST] [IPU2 ] 20.473708 s:
[HOST] [IPU2 ] 20.473799 s:
[HOST] [IPU2 ] 20.473860 s:
[HOST] [IPU2 ] 20.473952 s: ***** IPU2 Firmware build time 18:10:45 Jul 17 2017
[HOST] [IPU2 ] 20.474104 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[HOST] [IPU2 ] 20.477459 s: SYSTEM: System Common Init in progress !!!
[HOST] [IPU2 ] 20.488592 s: UTILS: CIO: Init Done !!!
[HOST] [IPU2 ] 20.488714 s: SYSTEM: IPC init in progress !!!
[HOST] [IPU2 ] 20.488806 s: SYSTEM: Attaching to [DSP1] ...
[HOST] [IPU2 ] 20.491337 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [IPU2 ] 20.508601 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [IPU2 ] 20.525925 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [IPU2 ] 20.545964 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [IPU2 ] 20.565942 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [IPU2 ] 20.585951 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [IPU2 ] 20.586042 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [IPU2 ] 20.586195 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [IPU2 ] 20.586317 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [IPU2 ] 20.586439 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [IPU2 ] 20.586561 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [IPU2 ] 20.586652 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [IPU2 ] 20.586805 s: SYSTEM: Notify init done !!!
[HOST] [IPU2 ] 20.588513 s: SYSTEM: MsgQ init done !!!
[HOST] [IPU2 ] 20.588909 s: SYSTEM: IPC init DONE !!!
[HOST] [IPU2 ] 20.593973 s: tivxInit CoreId = 9
[HOST] [IPU2 ] 20.594156 s: VX_ZONE_INIT:Enabled
[HOST] [IPU2 ] 20.594278 s: VX_ZONE_ERROR:Enabled
[HOST] [IPU2 ] 20.594400 s: VX_ZONE_WARNING:Enabled
[HOST] [IPU2 ] 20.598090 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!!
[HOST] [IPU2 ] 20.598182 s: SYSTEM: System Common Init Done !!!
[HOST] [IPU2 ] 20.598243 s: SYSTEM: System Init in progress !!!
[HOST] [IPU2 ] 20.598304 s: SYSTEM: BSP Common Init in progress !!!
[HOST] [IPU2 ] 20.598395 s: SYSTEM: BSP Common Init Done !!!
[HOST] [IPU2 ] 20.598456 s: SYSTEM: BSP Platform Init in progress !!!
[HOST] [IPU2 ] 20.598548 s: SYSTEM: BSP Platform Init Done !!!
[HOST] [IPU2 ] 20.598609 s: SYSTEM: FVID2 Init in progress !!!
[HOST] [IPU2 ] 20.598792 s: SYSTEM: FVID2 Init Done !!!
[HOST] [IPU2 ] 20.598883 s: SYSTEM: VPS Init in progress !!!
[HOST] [IPU2 ] 20.598944 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[HOST] [IPU2 ] 20.601933 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 20.602025 s: VPDMA Firmware Address = 0xa035ba40
[HOST] [IPU2 ] 20.602116 s: VPDMA Load Address = 0x4897d004
[HOST] [IPU2 ] 20.602238 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 20.602299 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 20.602391 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 20.602696 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 20.602818 s: VPDMA Firmware Address = 0xa035ba40
[HOST] [IPU2 ] 20.602909 s: VPDMA Load Address = 0x4899d004
[HOST] [IPU2 ] 20.603001 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 20.603092 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 20.603153 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 20.603489 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 20.603580 s: VPDMA Firmware Address = 0xa035ba40
[HOST] [IPU2 ] 20.603641 s: VPDMA Load Address = 0x489bd004
[HOST] [IPU2 ] 20.603763 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 20.603855 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 20.603946 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 20.604251 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 20.604343 s: VPDMA Firmware Address = 0xa035ba40
[HOST] [IPU2 ] 20.604434 s: VPDMA Load Address = 0x489dd004
[HOST] [IPU2 ] 20.604526 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 20.604617 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 20.604709 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 20.661227 s: SYSTEM: VPS Init Done !!!
[HOST] [IPU2 ] 20.662111 s: UTILS: DMA: HWI Create for INT25 !!!
[HOST] [IPU2 ] 20.662355 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [IPU2 ] 20.662477 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 253784 B (247 KB)
[HOST] [IPU2 ] 20.662630 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 20.662813 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 346030080 B (330 MB), Free size = 346030080 B (330 MB)
[HOST] [IPU2 ] 20.663026 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 861056 B (0 MB)
[HOST] [IPU2 ] 20.663179 s: SYSTEM: Initializing Links !!!
[HOST] [IPU2 ] 20.919996 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [IPU2 ] 21.004422 s: CHAINS: Application Started !!!
[HOST] [HOST ] 47.024126 s: SYSTEM: System A15 Init Done !!!
[HOST] [HOST ] 47.526078 s:
[HOST] [HOST ]
[HOST] [HOST ] =========
[HOST] [HOST ] Test Menu
[HOST] [HOST ]
[HOST] [HOST ] Single Camera Use-cases,
[HOST] [HOST ] ------------------------
[HOST] [HOST ] 1: 1CH VIP capture + SGX Copy + DISPLAY
[HOST] [HOST ] 2: 1CH VIP capture + Encode + Decode + SGX Copy + DISPLAY
[HOST] [HOST ] 3: 1CH VIP capture + Alg FrameCopy (EVE1) + SGX Copy + DISPLAY - (TDA2xx ONLY)
[HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported)
[HOST] [HOST ] 6: 1CH VIP capture + Alg Frame Copy (A15) + SGX Copy + DISPLAY
[HOST] [HOST ] 7: 1CH VIP + Alg Frame Copy (A15) + Connetor Links (Dup, Merge, Select, Gate on A15) + SGX Copy + DISPLAY
[HOST] [HOST ]
[HOST] [HOST ] Multi-Camera LVDS Use-cases,
[HOST] [HOST ] ----------------------------
[HOST] [HOST ] a: 4CH VIP LVDS capture + SGX MOSAIC + DISPLAY
[HOST] [HOST ] b: 4CH VIP LVDS capture + 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] l: 4CH VIP LVDS 2MP capture + 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] c: 4CH VIP LVDS capture + 3D SRV + 4CH SfM (3D perception demo - EVE1-4/DSP1&2) + DISPLAY - Only on TDA2xx with HDMI 1080p display
[HOST] [HOST ] d: 2CH OV490 2560x720 capture + Split + 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ] e: Surround View Calibration
[HOST] [HOST ] k: CSI2 CAL Surround View Calibration
[HOST] [HOST ] o: 4CH VIP LVDS capture + Adaptive 3D SRV (SGX/A15) + DISPLAY - Only HDMI 1080p display supported
[HOST] [HOST ]
[HOST] [HOST ] AVB RX Use-cases, (TDA2x ONLY)
[HOST] [HOST ] ------------------------------
[HOST] [HOST ]
[HOST] [HOST ] OPENVX Usecase, (TDA2x ONLY)
[HOST] [HOST ] m: OpenVX v1.1 Conformance Test
[HOST] [HOST ] q: OpenVX Tutorials
[HOST] [HOST ]
[HOST] [HOST ] p: CPU Status
[HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
[HOST] [HOST ]
[HOST] [HOST ] s: System Settings
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
BTW, this experipment only happens when we used Linux SDK. If we do system booting by using BIOS SDK, there is no error message
please advise and thanks for your help.
BR
Ymin
