Part Number: PROCESSOR-SDK-AM437X
Other Parts Discussed in Thread: AM4379
Tool/software: Linux
Hi all:
I recently used AM4379 to make a product. I referred to the circuit diagram of TI AM4379-EVM and made my own AM4379 board.
In view of the cost considerations, my board can not completely copy TI AM4379 EVM. For example, nandflash and DDRAM are the capacity of 512M. Display output using LCD.
So ti-sdk pre-build uboot can't run directly on my board. As a newcomer for embedded Linux, I want to be able to use TI-SDK's root file and filesystem. In my understanding, FS I don't need to do a job of porting to
match my board. It may be necessary to modify the files that need to be used when the uboot configuration or other files. Please tell me if I want to use the TI-SDK kernel and the file system, what direction should I
go?
If you can simply describe the changes I need to do, it will be very helpful to me. I guess I need to modify some of the files based on my own circuit diagram. But I don't know which documents and how to modify it. I
need some guidebooks.
Thanks very much!
