questions about dvsdk compatibility
first ,I want  to update to dvsdk2_00_00_22,when I read the Rules.make in it,the code generation tools's  version is cg6x_6_0_21.But I only have cg6x_6_0_16,does it works in dvsdk2_00_00_22?
second,when we speak the software compatibility,does it means all the software we installed must as same as Rules.make??
    It may work, though 6.0.21 is what was tested with it, if you want to try the newer CGT set you can download the CGT from here.
    All the software packaged in the DVSDK should match the Rules.make file, though the actual definition of what versions are tested together with the DVSDK is given in the release notes.
